[mpich2-commits] r5526 - mpich2/trunk/confdb
    balaji at mcs.anl.gov
    Wed Oct 21 17:51:36 CDT 2009
Author: balaji
Date: 2009-10-21 17:51:36 -0500 (Wed, 21 Oct 2009)
New Revision: 5526
Modified:
   mpich2/trunk/confdb/aclocal_mpi.m4
Log:
Remove one more unused macro. We should try to remove MPICH-specific
macros from confdb if possible.
Modified: mpich2/trunk/confdb/aclocal_mpi.m4
--- mpich2/trunk/confdb/aclocal_mpi.m4	2009-10-21 21:43:52 UTC (rev 5525)
+++ mpich2/trunk/confdb/aclocal_mpi.m4	2009-10-21 22:51:36 UTC (rev 5526)
@@ -11,9 +11,6 @@
 dnl Currently, only checks for lib mpi and mpi.h.  Later, we will add
 dnl MPI_Pcontrol prototype (const int or not?).
 dnl
-dnl If PAC_ARG_MPICH_BUILDING is included, this will work correctly
-dnl when MPICH is being built.
-dnl
 dnl Prerequisites:
 dnl autoconf version 2.13 (for AC_SEARCH_LIBS)
 dnl D*/
@@ -54,30 +51,7 @@
 fi
 ifelse($1,,,[$1])
-dnl
-dnl
-dnl/*D
-dnl PAC_ARG_MPICH_BUILDING - Add configure command-line argument to indicated
-dnl that MPICH is being built
-dnl
-dnl Output Effect:
-dnl Adds the command-line switch '--with-mpichbuilding' that may be used to
-dnl indicate that MPICH is building.  This allows a configure to work-around
-dnl the fact that during a build of MPICH, certain commands, particularly the
-dnl compilation commands such as 'mpicc', are not yet functional.  The
-dnl variable 'pac_lib_mpi_is_building' is set to 'yes' if in an MPICH build,
-dnl 'no' otherwise.
-dnl
-dnl See Also:
-dnl PAC_LIB_MPI
-dnl D*/
-AC_DEFUN([PAC_ARG_MPICH_BUILDING],[
-AC_ARG_WITH(mpichbuilding,
-[--with-mpichbuilding - Assume that MPICH is being built],
-pac_lib_mpi_is_building=$withval,pac_lib_mpi_is_building="no")
-dnl
-dnl
 dnl This should also set MPIRUN.
 dnl
 dnl/*D
More information about the mpich2-commits
