[mpich2-commits] r5519 - in mpich2/trunk: . confdb src/mpid/ch3/channels/shm src/mpid/ch3/channels/sock src/mpid/ch3/channels/ssm src/mpid/globus src/pm/gforker src/pm/remshell src/pm/smpd src/util/logging/rlog
balaji at mcs.anl.gov
Wed Oct 21 15:34:39 CDT 2009
Author: balaji
Date: 2009-10-21 15:34:39 -0500 (Wed, 21 Oct 2009)
New Revision: 5519
Modified:
mpich2/trunk/confdb/aclocal_util.m4
mpich2/trunk/configure.in
mpich2/trunk/src/mpid/ch3/channels/shm/configure.in
mpich2/trunk/src/mpid/ch3/channels/sock/configure.in
mpich2/trunk/src/mpid/ch3/channels/ssm/configure.in
mpich2/trunk/src/mpid/globus/configure.in
mpich2/trunk/src/pm/gforker/configure.in
mpich2/trunk/src/pm/remshell/configure.in
mpich2/trunk/src/pm/smpd/configure.in
mpich2/trunk/src/util/logging/rlog/configure.in
Log:
Get rid of PAC_PROG_MKDIR_P and use AC_PROG_MKDIR_P instead. It seems
to be more thorough in its checks in the newer versions of autoconf.
Modified: mpich2/trunk/confdb/aclocal_util.m4
--- mpich2/trunk/confdb/aclocal_util.m4 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/confdb/aclocal_util.m4 2009-10-21 20:34:39 UTC (rev 5519)
@@ -64,29 +64,6 @@
done
-dnl Find something to use for mkdir -p. Eventually, this will
-dnl have a script for backup
-AC_DEFUN([PAC_PROG_MKDIR_P],[
-AC_CACHE_CHECK([whether mkdir -p works],
-pac_cv_mkdir_p,[
-pac_cv_mkdir_p=no
-rm -rf .tmp
-if mkdir -p .tmp/.foo 1>/dev/null 2>&1 ; then
- if test -d .tmp/.foo ; then
- pac_cv_mkdir_p=yes
- fi
-fi
-rm -rf .tmp
-if test "$pac_cv_mkdir_p" = "yes" ; then
- MKDIR_P="mkdir -p"
- export MKDIR_P
-else
- AC_MSG_WARN([mkdir -p does not work; the install step may fail])
-fi
-AC_SUBST(MKDIR_P)
dnl Test for a clean VPATH directory. Provide this command with the names
dnl of all of the generated files that might cause problems
dnl (Makefiles won't cause problems because there's no VPATH usage for them)
Modified: mpich2/trunk/configure.in
--- mpich2/trunk/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -2736,7 +2736,7 @@
# On Mac OS/X, install breaks libraries unless used with the -p switch
PAC_PROG_INSTALL_BREAKS_LIBS
# We also need mkdir -p.
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
Modified: mpich2/trunk/src/mpid/ch3/channels/shm/configure.in
--- mpich2/trunk/src/mpid/ch3/channels/shm/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/mpid/ch3/channels/shm/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -43,7 +43,7 @@
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
AC_CHECK_PROGS(AR,ar)
if test -z "$AR" ; then
Modified: mpich2/trunk/src/mpid/ch3/channels/sock/configure.in
--- mpich2/trunk/src/mpid/ch3/channels/sock/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/mpid/ch3/channels/sock/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -42,7 +42,7 @@
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
Modified: mpich2/trunk/src/mpid/ch3/channels/ssm/configure.in
--- mpich2/trunk/src/mpid/ch3/channels/ssm/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/mpid/ch3/channels/ssm/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -46,7 +46,7 @@
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
Modified: mpich2/trunk/src/mpid/globus/configure.in
--- mpich2/trunk/src/mpid/globus/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/mpid/globus/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -63,7 +63,7 @@
AC_PROG_INSTALL
PAC_PROG_CHECK_INSTALL_WORKS
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
Modified: mpich2/trunk/src/pm/gforker/configure.in
--- mpich2/trunk/src/pm/gforker/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/pm/gforker/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -88,7 +88,7 @@
PAC_ARG_STRICT
AC_PROG_INSTALL
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
dnl AC_CHECK_PROGS(AR,ar)
dnl AC_PROG_RANLIB
Modified: mpich2/trunk/src/pm/remshell/configure.in
--- mpich2/trunk/src/pm/remshell/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/pm/remshell/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -84,7 +84,7 @@
PAC_ARG_STRICT
AC_PROG_INSTALL
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
dnl AC_PROG_RANLIB
Modified: mpich2/trunk/src/pm/smpd/configure.in
--- mpich2/trunk/src/pm/smpd/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/pm/smpd/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -68,7 +68,7 @@
AC_PROG_CC
AC_PROG_INSTALL
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
dnl
dnl check for compiler characteristics
Modified: mpich2/trunk/src/util/logging/rlog/configure.in
--- mpich2/trunk/src/util/logging/rlog/configure.in 2009-10-21 19:25:35 UTC (rev 5518)
+++ mpich2/trunk/src/util/logging/rlog/configure.in 2009-10-21 20:34:39 UTC (rev 5519)
@@ -76,7 +76,7 @@
dnl On Mac OS/X, install breaks libraries unless used with the -p switch
dnl We also need mkdir -p.
-PAC_PROG_MKDIR_P
+AC_PROG_MKDIR_P
PAC_PROG_MAKE
dnl
AC_PATH_PROG(PERL,perl)
More information about the mpich2-commits
