[mpich2-commits] r5503 - mpich2/trunk/src/mpi/datatype
goodell at mcs.anl.gov
Tue Oct 20 15:35:37 CDT 2009
Author: goodell
Date: 2009-10-20 15:35:37 -0500 (Tue, 20 Oct 2009)
New Revision: 5503
Modified:
mpich2/trunk/src/mpi/datatype/typeutil.c
Log:
Use proper allocation routines for predefined pair-types.
For some reason this was basically using a copy of the allocation code.
It still needs a little bit more cleanup, but it's much better now.
No reviewer.
Modified: mpich2/trunk/src/mpi/datatype/typeutil.c
--- mpich2/trunk/src/mpi/datatype/typeutil.c 2009-10-20 20:35:36 UTC (rev 5502)
+++ mpich2/trunk/src/mpi/datatype/typeutil.c 2009-10-20 20:35:37 UTC (rev 5503)
@@ -139,53 +139,39 @@
int MPIR_Datatype_init(void)
int i;
- MPIU_Handle_common *ptr;
+ MPID_Datatype *ptr;
MPIU_Assert(MPID_Datatype_mem.initialized == 0);
MPIU_Assert(MPID_DATATYPE_PREALLOC >= 5);
-#if 0
- /* initialize also gets us our first pointer */
- ptr = MPIU_Handle_direct_init(MPID_Datatype_mem.direct,
- MPID_Datatype_mem.direct_size,
- MPID_Datatype_mem.size,
- MPID_Datatype_mem.kind);
+ for (i=0; mpi_pairtypes[i] != (MPI_Datatype) -1; ++i) {
+ /* types based on 'long long' and 'long double', may be disabled at
+ configure time, and their values set to MPI_DATATYPE_NULL. skip any
+ such types. */
+ if (mpi_pairtypes[i] == MPI_DATATYPE_NULL) continue;
+ /* XXX: this allocation strategy isn't right if one or more of the
+ pairtypes is MPI_DATATYPE_NULL. in fact, the assert below will
+ fail if any type other than the las in the list is equal to
+ MPI_DATATYPE_NULL. obviously, this should be fixed, but I need
+ to talk to Rob R. first. -- BRT */
+ /* XXX DJG it does work, but only because MPI_LONG_DOUBLE_INT is the
+ * only one that is ever optional and it comes last */
- MPID_Datatype_mem.initialized = 1;
- MPID_Datatype_mem.avail = ptr->next;
-#else
- ptr = MPIU_Handle_obj_alloc_unsafe( &MPID_Datatype_mem );
-#endif
- MPIU_Assert((void *) ptr == (void *) (MPID_Datatype_direct + HANDLE_INDEX(mpi_pairtypes[0])));
- MPID_Type_create_pairtype(mpi_pairtypes[0], (MPID_Datatype *) ptr);
+ /* we use the _unsafe version because we are still in MPI_Init, before
+ * multiple threads are permitted and possibly before support for
+ * critical sections is entirely setup */
+ ptr = (MPID_Datatype *)MPIU_Handle_obj_alloc_unsafe( &MPID_Datatype_mem );
- for (i=1; mpi_pairtypes[i] != (MPI_Datatype) -1; i++) {
- /* types based on 'long long' and 'long double', may be disabled at
- configure time, and their values set to MPI_DATATYPE_NULL. skip any
- such types. */
- if (mpi_pairtypes[i] == MPI_DATATYPE_NULL) continue;
+ MPIU_Assert(ptr);
+ MPIU_Assert(ptr->handle == mpi_pairtypes[i]);
+ /* this is a redundant alternative to the previous statement */
+ MPIU_Assert((void *) ptr == (void *) (MPID_Datatype_direct + HANDLE_INDEX(mpi_pairtypes[i])));
- /* XXX: this allocation strategy isn't right if one or more of the
- pairtypes is MPI_DATATYPE_NULL. in fact, the assert below will
- fail if any type other than the las in the list is equal to
- MPI_DATATYPE_NULL. obviously, this should be fixed, but I need
- to talk to Rob R. first. -- BRT */
- ptr = MPID_Datatype_mem.avail;
- ptr->next = 0;
- MPIU_Assert(ptr);
- (void *) (MPID_Datatype_direct + HANDLE_INDEX(mpi_pairtypes[i])));
- MPID_Type_create_pairtype(mpi_pairtypes[i], (MPID_Datatype *) ptr);
+ MPID_Type_create_pairtype(mpi_pairtypes[i], (MPID_Datatype *) ptr);
-#if 0
- MPIU_Handle_obj_alloc_complete(&MPID_Datatype_mem, 1);
-#endif
- MPIR_Add_finalize(MPIR_Datatype_finalize, 0,
- MPIR_FINALIZE_CALLBACK_PRIO-1);
+ MPIR_Add_finalize(MPIR_Datatype_finalize, 0,
+ MPIR_FINALIZE_CALLBACK_PRIO-1);
return MPI_SUCCESS;
More information about the mpich2-commits
