[mpich2-commits] r5495 - mpich2/trunk/src/include
    goodell at mcs.anl.gov
    Tue Oct 20 15:35:20 CDT 2009
Author: goodell
Date: 2009-10-20 15:35:20 -0500 (Tue, 20 Oct 2009)
New Revision: 5495
Modified:
   mpich2/trunk/src/include/mpiatomic.h
Log:
Delete FUNC_{ENTER,EXIT} macros from mpiatomic.h.
I'm deleting them because they are too hard to get working early in the
include sequence.  Ideally we would be able to re-enable them at some
point after some rationalization of our header file ordering.
No reviewer.
Modified: mpich2/trunk/src/include/mpiatomic.h
--- mpich2/trunk/src/include/mpiatomic.h	2009-10-20 20:35:19 UTC (rev 5494)
+++ mpich2/trunk/src/include/mpiatomic.h	2009-10-20 20:35:20 UTC (rev 5495)
@@ -135,15 +135,9 @@
 #define FCNAME MPIDI_QUOTE(FUNCNAME)
 static inline void MPIDU_Owner_init(MPIDU_Owner_info *info)
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_OWNER_INIT);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_OWNER_INIT);
     /* It's OK if multiple processes call this on the same bit of shared_info
        because of the restriction given in the comment above. */
     OPA_store_int(&info->id, MPIDU_OWNER_ID_NONE);
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_OWNER_INIT);
 /* 'after_owner' is an OUT value */
@@ -160,10 +154,7 @@
        implementation for fairly broad portability. */
     MPIDU_Owner_result retval;
     int prev_id;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_OWNER_TRY_ACQUIRE);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_OWNER_TRY_ACQUIRE);
     MPIU_DBG_MSG_D(ALL, VERBOSE, "... my_id=%d", my_id);
     MPIU_DBG_MSG_P(ALL, VERBOSE, "... &info->id=%p", &info->id);
@@ -184,7 +175,6 @@
         MPIU_DBG_MSG_D(ALL, VERBOSE, "... busy, prev_id=%d", prev_id);
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_OWNER_TRY_ACQUIRE);
     return retval;
@@ -200,10 +190,7 @@
     int prev_id;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_OWNER_RELEASE);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_OWNER_RELEASE);
     if (after_owner) *after_owner = MPIDU_OWNER_ID_NONE;
@@ -235,7 +222,6 @@
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_OWNER_RELEASE);
     return retval;
@@ -305,10 +291,7 @@
     int i;
     int prev;
     volatile char *ptr;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_ALLOC_BY_ID);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_ALLOC_BY_ID);
     MPIU_Assert(MPIDU_ALLOC_NULL_ID != id);
     ptr = pool->buf;
@@ -326,7 +309,6 @@
     retval = NULL;
 fn_exit:
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_ALLOC_BY_ID);
     return retval;
@@ -337,13 +319,10 @@
 static inline
 int MPIDU_Alloc_free(MPIDU_Alloc_pool *pool, volatile void *element) {
     int mpi_errno = MPI_SUCCESS;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_ALLOC_FREE);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_ALLOC_FREE);
     /* Do nothing for now... this datastructure isn't safe for deallocation yet.
        Consider replacing with something like
          http://www.research.ibm.com/people/m/michael/spaa-2002.pdf */
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_ALLOC_FREE);
     return mpi_errno;
@@ -359,16 +338,12 @@
 size_t MPIDU_Alloc_calc_size(size_t nmemb, size_t elt_size)
     size_t bytes_needed;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_ALLOC_CALC_SIZE);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_ALLOC_CALC_SIZE);
     bytes_needed = 0;
     bytes_needed += sizeof(MPIDU_Alloc_pool);
     /* each elt has the overhead of one MPIDU_Alloc_pool_entry */
     bytes_needed += nmemb * (sizeof(MPIDU_Alloc_pool_entry) + elt_size);
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_ALLOC_CALC_SIZE);
     return bytes_needed;
@@ -416,10 +391,7 @@
     int i;
     volatile char *ptr;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_ALLOC_CREATE_POOL);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_ALLOC_CREATE_POOL);
     MPIU_Assert(pool != NULL);
     MPIU_Assert(buf != NULL);
     MPIU_Assert(buf_size > 0);
@@ -451,7 +423,6 @@
 fn_fail:
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_ALLOC_CREATE_POOL);
     return mpi_errno;
@@ -517,16 +488,12 @@
 int MPIDU_Shm_barrier_init(MPIDU_Shm_barrier_t *barrier)
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_SHM_BARRIER_INIT);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_SHM_BARRIER_INIT);
     OPA_store_int(&barrier->num_waiting, 0);
     OPA_store_int(&barrier->sig, 0);
     OPA_store_int(&barrier->sig_boss, 0);
     OPA_write_barrier();
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_SHM_BARRIER_INIT);
     return mpi_errno;
@@ -549,10 +516,7 @@
     int cur_sig;
     int prev_waiting;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_SHM_BARRIER_SIMPLE);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_SHM_BARRIER_SIMPLE);
     MPIU_Assert(barrier != NULL);
     /* not strictly needed, but not checking it is a bug waiting to happen */
     MPIU_Assert(rank < num_processes);
@@ -575,7 +539,6 @@
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_SHM_BARRIER_SIMPLE);
     return mpi_errno;
@@ -593,10 +556,7 @@
     int prev;
     int cur_sig;
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_SHM_BARRIER_ENTER);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_SHM_BARRIER_ENTER);
     MPIU_Assert(num_processes > 0);
     MPIU_Assert(rank >= 0);
@@ -623,7 +583,6 @@
 fn_exit:
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_SHM_BARRIER_ENTER);
     return mpi_errno;
@@ -639,10 +598,7 @@
                               int boss_rank)
-    MPIDI_STATE_DECL(MPID_STATE_MPIDU_SHM_BARRIER_RELEASE);
-    MPIDI_FUNC_ENTER(MPID_STATE_MPIDU_SHM_BARRIER_RELEASE);
     if (1 == num_processes) goto fn_exit; /* trivial barrier */
     /* makes this safe to use outside of a conditional */
@@ -654,7 +610,6 @@
 fn_exit:
-    MPIDI_FUNC_EXIT(MPID_STATE_MPIDU_SHM_BARRIER_RELEASE);
     return mpi_errno;
More information about the mpich2-commits
