[mpich2-commits] r5486 - in mpich2/trunk/src/pm/hydra: rmk/include rmk/pbs rmk/src rmk/utils tools/bootstrap/include tools/bootstrap/slurm tools/bootstrap/src tools/bootstrap/utils ui/mpiexec
balaji at mcs.anl.gov balaji at mcs.anl.gov
Mon Oct 19 14:24:20 CDT 2009
Author: balaji
Date: 2009-10-19 14:24:19 -0500 (Mon, 19 Oct 2009)
New Revision: 5486
Modified:
   mpich2/trunk/src/pm/hydra/rmk/include/rmki.h.in
   mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs.h
   mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs_query_node_list.c
   mpich2/trunk/src/pm/hydra/rmk/src/rmki_query_node_list.c
   mpich2/trunk/src/pm/hydra/rmk/utils/rmku.h
   mpich2/trunk/src/pm/hydra/rmk/utils/rmku_query_node_list.c
   mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in
   mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm.h
   mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm_query_node_list.c
   mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_node_list.c
   mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu.h
   mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_node_list.c
   mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
Log:
Rename misleading variable and function names.
Modified: mpich2/trunk/src/pm/hydra/rmk/include/rmki.h.in
--- mpich2/trunk/src/pm/hydra/rmk/include/rmki.h.in	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/rmk/include/rmki.h.in	2009-10-19 19:24:19 UTC (rev 5486)
@@ -10,7 +10,7 @@
 #include "hydra.h"
 struct HYD_rmki_fns {
-    HYD_status(*query_node_list) (int *num_nodes, struct HYD_proxy **proxy_list);
+    HYD_status(*query_node_list) (int *num_cores, struct HYD_proxy **proxy_list);
 extern struct HYD_rmki_fns HYD_rmki_fns;
@@ -18,7 +18,7 @@
 HYD_status HYD_rmki_init(char *rmk);
 /* Non-zero nodes means that the RMK should allocate the nodes if needed */
-HYD_status HYD_rmki_query_node_list(int *num_nodes, struct HYD_proxy **proxy_list);
+HYD_status HYD_rmki_query_node_list(int *num_cores, struct HYD_proxy **proxy_list);
 /* Each resource management kernel has to expose an initialization function */
 @hydra_rmk_init_decl@
Modified: mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs.h
--- mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs.h	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs.h	2009-10-19 19:24:19 UTC (rev 5486)
@@ -9,6 +9,6 @@
 #include "hydra_base.h"
-HYD_status HYD_rmkd_pbs_query_node_list(int *num_nodes, struct HYD_proxy **proxy_list);
+HYD_status HYD_rmkd_pbs_query_node_list(int *num_cores, struct HYD_proxy **proxy_list);
 #endif /* RMK_PBS_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs_query_node_list.c
--- mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs_query_node_list.c	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/rmk/pbs/rmk_pbs_query_node_list.c	2009-10-19 19:24:19 UTC (rev 5486)
@@ -38,7 +38,7 @@
     goto fn_exit;
     char *hostfile;
     HYD_status status = HYD_SUCCESS;
@@ -53,7 +53,7 @@
         total_num_procs = 0;
         status = HYDU_parse_hostfile(hostfile, process_mfile_token);
         HYDU_ERR_POP(status, "error parsing hostfile\n");
-        *num_nodes = total_num_procs;
+        *num_cores = total_num_procs;
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/rmk/src/rmki_query_node_list.c
--- mpich2/trunk/src/pm/hydra/rmk/src/rmki_query_node_list.c	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/rmk/src/rmki_query_node_list.c	2009-10-19 19:24:19 UTC (rev 5486)
@@ -7,13 +7,13 @@
 #include "rmki.h"
     HYDU_FUNC_ENTER();
-    status = HYD_rmki_fns.query_node_list(num_nodes, proxy_list);
+    status = HYD_rmki_fns.query_node_list(num_cores, proxy_list);
     HYDU_ERR_POP(status, "RMK device returned error while querying node list\n");
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/rmk/utils/rmku.h
--- mpich2/trunk/src/pm/hydra/rmk/utils/rmku.h	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/rmk/utils/rmku.h	2009-10-19 19:24:19 UTC (rev 5486)
@@ -9,6 +9,6 @@
-HYD_status HYD_rmku_query_node_list(int *num_nodes, struct HYD_proxy **proxy_list);
+HYD_status HYD_rmku_query_node_list(int *num_cores, struct HYD_proxy **proxy_list);
 #endif /* RMKU_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/rmk/utils/rmku_query_node_list.c
--- mpich2/trunk/src/pm/hydra/rmk/utils/rmku_query_node_list.c	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/rmk/utils/rmku_query_node_list.c	2009-10-19 19:24:19 UTC (rev 5486)
@@ -9,7 +9,7 @@
 #include "bsci.h"
 #include "rmku.h"
@@ -17,7 +17,7 @@
     /* We just query the bootstrap server for the node list and return
      * it to the upper layer. */
-    status = HYDT_bsci_query_node_list(num_nodes, proxy_list);
+    status = HYDT_bsci_query_node_list(num_cores, proxy_list);
     HYDU_ERR_POP(status, "bootstrap device returned error while querying node list\n");
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h.in	2009-10-19 19:24:19 UTC (rev 5486)
@@ -18,7 +18,7 @@
                                struct HYD_proxy *proxy_list);
     HYD_status(*finalize) (void);
     HYD_status(*wait_for_completion) (struct HYD_proxy *proxy_list);
     HYD_status(*query_usize) (int *size);
     HYD_status(*query_proxy_id) (int *proxy_id);
@@ -30,7 +30,7 @@
 HYD_status HYDT_bsci_finalize(void);
 HYD_status HYDT_bsci_wait_for_completion(struct HYD_proxy *proxy_list);
-HYD_status HYDT_bsci_query_node_list(int *num_nodes, struct HYD_proxy **proxy_list);
+HYD_status HYDT_bsci_query_node_list(int *num_cores, struct HYD_proxy **proxy_list);
 HYD_status HYDT_bsci_query_usize(int *size);
 HYD_status HYDT_bsci_query_proxy_id(int *proxy_id);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm.h
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm.h	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm.h	2009-10-19 19:24:19 UTC (rev 5486)
@@ -12,6 +12,6 @@
 HYD_status HYDT_bscd_slurm_launch_procs(char **global_args, const char *proxy_id_str,
 HYD_status HYDT_bscd_slurm_query_proxy_id(int *proxy_id);
-HYD_status HYDT_bscd_slurm_query_node_list(int *num_nodes, struct HYD_proxy **proxy_list);
+HYD_status HYDT_bscd_slurm_query_node_list(int *num_cores, struct HYD_proxy **proxy_list);
 #endif /* SLURM_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm_query_node_list.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm_query_node_list.c	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/slurm/slurm_query_node_list.c	2009-10-19 19:24:19 UTC (rev 5486)
@@ -99,11 +99,11 @@
     goto fn_exit;
     char *str, *num_procs;
     char *tmp1[HYD_NUM_TMP_STRINGS], *tmp2[HYD_NUM_TMP_STRINGS];
-    int i, j;
+    int i, j, start_pid;
     HYDU_FUNC_ENTER();
@@ -118,19 +118,20 @@
         full_str_to_groups(str, tmp1);
         num_procs = strtok(num_procs, "(");
-        *num_nodes = 0;
+        start_pid = 0;
         for (i = 0; tmp1[i]; i++) {
             status = group_to_individual_nodes(tmp1[i], tmp2);
             HYDU_ERR_POP(status, "unable to parse node list\n");
             for (j = 0; tmp2[j]; j++) {
-                status = HYDU_merge_proxy_segment(tmp2[j], *num_nodes, atoi(num_procs),
+                status = HYDU_merge_proxy_segment(tmp2[j], start_pid, atoi(num_procs),
                                                   proxy_list);
                 HYDU_ERR_POP(status, "merge proxy segment failed\n");
-                *num_nodes += atoi(num_procs);
+                start_pid += atoi(num_procs);
+        *num_cores = start_pid;
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_node_list.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_node_list.c	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_node_list.c	2009-10-19 19:24:19 UTC (rev 5486)
@@ -8,13 +8,13 @@
 #include "bsci.h"
 #include "bscu.h"
     HYDU_FUNC_ENTER();
-    status = HYDT_bsci_fns.query_node_list(num_nodes, proxy_list);
+    status = HYDT_bsci_fns.query_node_list(num_cores, proxy_list);
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu.h
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu.h	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu.h	2009-10-19 19:24:19 UTC (rev 5486)
@@ -11,7 +11,7 @@
 HYD_status HYDT_bscu_finalize(void);
 HYD_status HYDT_bscu_wait_for_completion(struct HYD_proxy *proxy_list);
-HYD_status HYDT_bscu_query_node_list(int *num_nodes, struct HYD_proxy **proxy_list);
+HYD_status HYDT_bscu_query_node_list(int *num_cores, struct HYD_proxy **proxy_list);
 HYD_status HYDT_bscu_query_usize(int *size);
 HYD_status HYDT_bscu_query_proxy_id(int *proxy_id);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_node_list.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_node_list.c	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_node_list.c	2009-10-19 19:24:19 UTC (rev 5486)
@@ -8,15 +8,14 @@
 #include "hydra_utils.h"
 #include "bscu.h"
     HYDU_FUNC_ENTER();
-    /* We don't know anything about nodes or resources. Just return
-     * NULL. */
-    *num_nodes = 0;
+    /* We don't know anything about nodes or resources */
+    *num_cores = 0;
     *proxy_list = NULL;
     HYDU_FUNC_EXIT();
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-19 19:24:18 UTC (rev 5485)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-19 19:24:19 UTC (rev 5486)
@@ -108,7 +108,7 @@
     struct HYD_proxy *proxy;
     struct HYD_proxy_exec *exec;
     struct HYD_exec_info *exec_info;
-    int exit_status = 0, timeout, i, process_id, proc_count, num_nodes = 0;
+    int exit_status = 0, timeout, i, process_id, proc_count, num_cores;
     HYDU_FUNC_ENTER();
@@ -130,10 +130,11 @@
     if (HYD_handle.proxy_list == NULL) {
         /* Proxy list is not created yet. The user might not have
-         * provided the host file. Query the RMK. We pass a zero node
+         * provided the host file. Query the RMK. We pass a zero core
          * count, so the RMK will give us all the nodes it already has
          * and won't try to allocate any more. */
-        status = HYD_rmki_query_node_list(&num_nodes, &HYD_handle.proxy_list);
+        num_cores = 0;
+        status = HYD_rmki_query_node_list(&num_cores, &HYD_handle.proxy_list);
         HYDU_ERR_POP(status, "unable to query the RMK for a node list\n");
         /* We don't have an allocation capability yet, but when we do,
@@ -147,7 +148,7 @@
         else {
             /* The RMK returned a node list */
-            HYD_handle.global_core_count += num_nodes;
+            HYD_handle.global_core_count += num_cores;
@@ -155,10 +156,10 @@
      * available nodes to each executable */
     for (exec_info = HYD_handle.exec_info_list; exec_info; exec_info = exec_info->next) {
         if (exec_info->process_count == 0) {
-            if (num_nodes == 0)
+            if (num_cores == 0)
                 exec_info->process_count = 1;
             else
-                exec_info->process_count = num_nodes;
+                exec_info->process_count = num_cores;
             /* If we didn't get anything from the user, take whatever
              * the RMK gave */
More information about the mpich2-commits mailing list
