[mpich2-commits] r5483 - in mpich2/trunk/src/mpl: . src
balaji at mcs.anl.gov
Sun Oct 18 14:21:07 CDT 2009
Author: balaji
Date: 2009-10-18 14:21:07 -0500 (Sun, 18 Oct 2009)
New Revision: 5483
Added:
mpich2/trunk/src/mpl/src/mplstr.c
Removed:
mpich2/trunk/src/mpl/src/string/
Modified:
mpich2/trunk/src/mpl/Makefile.am
Log:
Simplify the directory structure for MPL.
Modified: mpich2/trunk/src/mpl/Makefile.am
--- mpich2/trunk/src/mpl/Makefile.am 2009-10-18 16:50:26 UTC (rev 5482)
+++ mpich2/trunk/src/mpl/Makefile.am 2009-10-18 19:21:07 UTC (rev 5483)
@@ -8,4 +8,4 @@
AM_CPPFLAGS = -I$(top_srcdir)/include
noinst_LIBRARIES = libmpl.a
-libmpl_a_SOURCES = src/string/mplstr.c
+libmpl_a_SOURCES = src/mplstr.c
Copied: mpich2/trunk/src/mpl/src/mplstr.c (from rev 5482, mpich2/trunk/src/mpl/src/string/mplstr.c)
--- mpich2/trunk/src/mpl/src/mplstr.c (rev 0)
+++ mpich2/trunk/src/mpl/src/mplstr.c 2009-10-18 19:21:07 UTC (rev 5483)
@@ -0,0 +1,196 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2001 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#include "mplstr.h"
+#ifndef MPL_HAVE_SNPRINTF
+/* FIXME: This is an approximate form, which works for most cases, but
+ * might not work for all. */
+int MPL_snprintf(char *str, size_t size, const char *format, ...)
+ int n;
+ const char *p;
+ char *out_str = str;
+ va_list list;
+ va_start(list, format);
+ p = format;
+ while (*p && size > 0) {
+ char *nf;
+ nf = strchr(p, '%');
+ if (!nf) {
+ /* No more format characters */
+ while (size-- > 0 && *p) {
+ *out_str++ = *p++;
+ else {
+ int nc;
+ int width = -1;
+ /* Copy until nf */
+ while (p < nf && size-- > 0) {
+ /* p now points at nf */
+ /* Handle the format character */
+ nc = nf[1];
+ if (isdigit(nc)) {
+ /* Get the field width */
+ /* FIXME : Assumes ASCII */
+ width = nc - '0';
+ p = nf + 2;
+ while (*p && isdigit(*p)) {
+ width = 10 * width + (*p++ - '0');
+ /* When there is no longer a digit, get the format
+ * character */
+ nc = *p++;
+ else {
+ /* Skip over the format string */
+ p += 2;
+ switch (nc) {
+ case '%':
+ *out_str++ = '%';
+ size--;
+ break;
+ case 'd':
+ int val;
+ char tmp[20];
+ char *t = tmp;
+ /* Get the argument, of integer type */
+ val = va_arg(list, int);
+ sprintf(tmp, "%d", val);
+ if (width > 0) {
+ int tmplen = strlen(tmp);
+ /* If a width was specified, pad with spaces on the
+ * left (on the right if %-3d given; not implemented yet */
+ while (size-- > 0 && width-- > tmplen)
+ *out_str++ = ' ';
+ while (size-- > 0 && *t) {
+ *out_str++ = *t++;
+ break;
+ case 'x':
+ int val;
+ char tmp[20];
+ char *t = tmp;
+ sprintf(tmp, "%x", val);
+ if (width > 0) {
+ *out_str++ = ' ';
+ break;
+ case 'p':
+ void *val;
+ char tmp[20];
+ char *t = tmp;
+ /* Get the argument, of pointer type */
+ val = va_arg(list, void *);
+ sprintf(tmp, "%p", val);
+ if (width > 0) {
+ *out_str++ = ' ';
+ break;
+ case 's':
+ char *s_arg;
+ /* Get the argument, of pointer to char type */
+ s_arg = va_arg(list, char *);
+ while (size-- > 0 && s_arg && *s_arg) {
+ *out_str++ = *s_arg++;
+ break;
+ default:
+ /* Error, unknown case */
+ return -1;
+ break;
+ va_end(list);
+ if (size-- > 0)
+ *out_str++ = '\0';
+ n = (int) (out_str - str);
+ return n;
+#endif /* MPL_HAVE_SNPRINTF */
+#ifndef MPL_HAVE_STRDUP
+#ifdef MPL_strdup
+#undef MPL_strdup
+#endif
+ MPL_strdup - Duplicate a string
+ Synopsis:
+.vb
+ char *MPL_strdup(const char *str)
+.ve
+ Input Parameter:
+. str - null-terminated string to duplicate
+ Return value:
+ A pointer to a copy of the string, including the terminating null. A
+ null pointer is returned on error, such as out-of-memory.
+ Module:
+ Utility
+char *MPL_strdup(const char *str)
+ char *restrict p = (char *) malloc(strlen(str) + 1);
+ const char *restrict in_p = str;
+ char *save_p;
+ save_p = p;
+ if (p) {
+ while (*in_p) {
+ *p++ = *in_p++;
+ *p = 0;
+ return save_p;
+#endif /* MPL_HAVE_STRDUP */
Property changes on: mpich2/trunk/src/mpl/src/mplstr.c
___________________________________________________________________
Added: svn:mergeinfo
+ /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/branches/release/mpich2-1.1.1/src/mpl/src/string/mplstr.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpl/src/string/mplstr.c:5406
More information about the mpich2-commits
