[mpich2-commits] r5481 - mpich2/trunk/confdb
balaji at mcs.anl.gov balaji at mcs.anl.gov
Sun Oct 18 11:15:20 CDT 2009
Author: balaji
Date: 2009-10-18 11:15:20 -0500 (Sun, 18 Oct 2009)
New Revision: 5481
Modified:
   mpich2/trunk/confdb/aclocal.m4
   mpich2/trunk/confdb/aclocal_util.m4
Log:
Move macro definitions out of aclocal.m4 to aclocal_util.m4
(aclocal.m4 should only contain includes to other m4 files). The
problem is basically a small behavioral difference between automake
and simplemake.
Simplemake requires the special file "aclocal.m4" to be present in the
included path (confdb/aclocal.m4). The confdb/aclocal.m4 file needs to
explicitly include all other m4 files as needed.
Automake creates its own aclocal.m4 if its not present, and
automatically includes all m4 files present in the included path
(confdb/*.m4). However, if the included path has another aclocal.m4,
it ignores it.
This is mostly fine, except that confdb/aclocal.m4 contains some
macros which are also being ignored by automake (since it ignores the
entire file), but not by simplemake. This patch just moves them to a
different file. This way, simplemake can continue to use
confdb/aclocal.m4 and automake can continue to ignore it, but things
will still work.
Reviewed by goodell.
Modified: mpich2/trunk/confdb/aclocal.m4
--- mpich2/trunk/confdb/aclocal.m4	2009-10-18 13:18:56 UTC (rev 5480)
+++ mpich2/trunk/confdb/aclocal.m4	2009-10-18 16:15:20 UTC (rev 5481)
@@ -15,102 +15,3 @@
 builtin(include,aclocal_shl.m4)
 builtin(include,fortran90.m4)
 builtin(include,aclocal_libs.m4)
-dnl PAC_MKDIRS(path)
-dnl Create any missing directories in the path
-dnl
-AC_DEFUN([PAC_MKDIRS],[
-# Build any intermediate directories
-for dir in $1 ; do
-    saveIFS="$IFS"
-    IFS="/"
-    tmp_curdir=""
-    for tmp_subdir in $dir ; do
-	tmp_curdir="${tmp_curdir}$tmp_subdir"
-	if test ! -d "$tmp_curdir" ; then mkdir "$tmp_curdir" ; fi
-        tmp_curdir="${tmp_curdir}/"
-    done
-    IFS="$saveIFS"
-done
-dnl Find something to use for mkdir -p.  Eventually, this will
-dnl have a script for backup
-AC_DEFUN([PAC_PROG_MKDIR_P],[
-AC_CACHE_CHECK([whether mkdir -p works],
-pac_cv_mkdir_p,[
-pac_cv_mkdir_p=no
-rm -rf .tmp
-if mkdir -p .tmp/.foo 1>/dev/null 2>&1 ; then
-    if test -d .tmp/.foo ; then
-        pac_cv_mkdir_p=yes
-    fi
-fi
-rm -rf .tmp
-if test "$pac_cv_mkdir_p" = "yes" ; then
-   MKDIR_P="mkdir -p"
-   export MKDIR_P
-else
-   AC_MSG_WARN([mkdir -p does not work; the install step may fail])
-fi
-AC_SUBST(MKDIR_P)
-dnl Test for a clean VPATH directory.  Provide this command with the names
-dnl of all of the generated files that might cause problems
-dnl (Makefiles won't cause problems because there's no VPATH usage for them)
-dnl
-dnl Synopsis
-dnl PAC_VPATH_CHECK([file-names],[directory-names])
-dnl  file-names should be files other than config.status and any header (e.g.,
-dnl fooconf.h) file that should be removed.  It is optional
-AC_DEFUN([PAC_VPATH_CHECK],[
-rm -f conftest*
-date >conftest$$
-# If creating a file in the current directory does not show up in the srcdir
-# then we're doing a VPATH build (or something is very wrong)
-if test ! -s $srcdir/conftest$$ ; then
-    pac_dirtyfiles=""
-    pac_dirtydirs=""
-    pac_header=""
-    ifdef([AC_LIST_HEADER],[pac_header=AC_LIST_HEADER])
-    for file in config.status $pac_header $1 ; do
-        if test -f $srcdir/$file ; then
-	    pac_dirtyfiles="$pac_dirtyfiles $file"
-	fi
-    done
-    ifelse($2,,,[
- 	for dir in $2 ; do
-            if test -d $srcdir/$dir ; then
-                pac_dirtydirs="$pac_dirtydirs $dir"
-	    fi
-	done
-    if test -n "$pac_dirtyfiles" -o -n "$pac_dirtydirs" ; then
-	# Create a nice message about what to remove
-	rmmsg=""
-	if test -n "$pac_dirtyfiles" ; then
-	    rmmsg="files $pac_dirtyfiles"
-        fi
- 	if test -n "$pac_dirtydirs" ; then
-	    if test -n "$rmmsg" ; then
-	        rmmsg="$rmmsg and directories $pac_dirtydirs"
-            else
-                rmmsg="directories $pac_dirtydirs"
-            fi
-        fi
-        if test -f $srcdir/Makefile ; then
-            AC_MSG_ERROR([You cannot do a VPATH build if the source directory has been
-    configured.  Run "make distclean" in $srcdir first and make sure that the
-    $rmmsg have been removed.])
-        else
-    configured.  Remove the $rmmsg in $srcdir.])
-        fi
-    fi
-fi
-rm -f conftest*
Modified: mpich2/trunk/confdb/aclocal_util.m4
--- mpich2/trunk/confdb/aclocal_util.m4	2009-10-18 13:18:56 UTC (rev 5480)
+++ mpich2/trunk/confdb/aclocal_util.m4	2009-10-18 16:15:20 UTC (rev 5481)
@@ -46,3 +46,100 @@
 		$2="$$2 $1"]
+dnl PAC_MKDIRS(path)
+dnl Create any missing directories in the path
+AC_DEFUN([PAC_MKDIRS],[
+# Build any intermediate directories
+for dir in $1 ; do
+    saveIFS="$IFS"
+    IFS="/"
+    tmp_curdir=""
+    for tmp_subdir in $dir ; do
+	tmp_curdir="${tmp_curdir}$tmp_subdir"
+	if test ! -d "$tmp_curdir" ; then mkdir "$tmp_curdir" ; fi
+        tmp_curdir="${tmp_curdir}/"
+    done
+    IFS="$saveIFS"
+done
+dnl Find something to use for mkdir -p.  Eventually, this will
+dnl have a script for backup
+AC_DEFUN([PAC_PROG_MKDIR_P],[
+AC_CACHE_CHECK([whether mkdir -p works],
+pac_cv_mkdir_p,[
+pac_cv_mkdir_p=no
+rm -rf .tmp
+if mkdir -p .tmp/.foo 1>/dev/null 2>&1 ; then
+    if test -d .tmp/.foo ; then
+        pac_cv_mkdir_p=yes
+    fi
+fi
+rm -rf .tmp
+if test "$pac_cv_mkdir_p" = "yes" ; then
+   MKDIR_P="mkdir -p"
+   export MKDIR_P
+else
+   AC_MSG_WARN([mkdir -p does not work; the install step may fail])
+fi
+AC_SUBST(MKDIR_P)
+dnl Test for a clean VPATH directory.  Provide this command with the names
+dnl of all of the generated files that might cause problems
+dnl (Makefiles won't cause problems because there's no VPATH usage for them)
+dnl
+dnl Synopsis
+dnl PAC_VPATH_CHECK([file-names],[directory-names])
+dnl  file-names should be files other than config.status and any header (e.g.,
+dnl fooconf.h) file that should be removed.  It is optional
+AC_DEFUN([PAC_VPATH_CHECK],[
+rm -f conftest*
+date >conftest$$
+# If creating a file in the current directory does not show up in the srcdir
+# then we're doing a VPATH build (or something is very wrong)
+if test ! -s $srcdir/conftest$$ ; then
+    pac_dirtyfiles=""
+    pac_dirtydirs=""
+    pac_header=""
+    ifdef([AC_LIST_HEADER],[pac_header=AC_LIST_HEADER])
+    for file in config.status $pac_header $1 ; do
+        if test -f $srcdir/$file ; then
+	    pac_dirtyfiles="$pac_dirtyfiles $file"
+	fi
+    done
+    ifelse($2,,,[
+ 	for dir in $2 ; do
+            if test -d $srcdir/$dir ; then
+                pac_dirtydirs="$pac_dirtydirs $dir"
+	    fi
+	done
+    if test -n "$pac_dirtyfiles" -o -n "$pac_dirtydirs" ; then
+	# Create a nice message about what to remove
+	rmmsg=""
+	if test -n "$pac_dirtyfiles" ; then
+	    rmmsg="files $pac_dirtyfiles"
+        fi
+ 	if test -n "$pac_dirtydirs" ; then
+	    if test -n "$rmmsg" ; then
+	        rmmsg="$rmmsg and directories $pac_dirtydirs"
+            else
+                rmmsg="directories $pac_dirtydirs"
+            fi
+        fi
+        if test -f $srcdir/Makefile ; then
+            AC_MSG_ERROR([You cannot do a VPATH build if the source directory has been
+    configured.  Run "make distclean" in $srcdir first and make sure that the
+    $rmmsg have been removed.])
+        else
+    configured.  Remove the $rmmsg in $srcdir.])
+        fi
+    fi
+fi
+rm -f conftest*
More information about the mpich2-commits mailing list
