[mpich2-commits] r5474 - mpich2/trunk/src/pm/hydra/pm/pmiserv
    balaji at mcs.anl.gov
    Thu Oct 15 23:44:28 CDT 2009
Author: balaji
Date: 2009-10-15 23:44:28 -0500 (Thu, 15 Oct 2009)
New Revision: 5474
Modified:
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
Log:
Use smaller variable names where possible.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c	2009-10-16 04:40:40 UTC (rev 5473)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c	2009-10-16 04:44:28 UTC (rev 5474)
@@ -9,7 +9,7 @@
 #include "demux.h"
 #include "pmi_proxy.h"
-struct HYD_pmcd_pmi_proxy_params HYD_pmcd_pmi_proxy_params;
+struct HYD_pmcd_pmip HYD_pmcd_pmip;
 static HYD_status wait_for_procs_to_finish(void)
@@ -25,22 +25,22 @@
          * are, we will just wait for more events. */
         out_count = 0;
         err_count = 0;
-        for (i = 0; i < HYD_pmcd_pmi_proxy_params.local.proxy_process_count; i++) {
-            if (HYD_pmcd_pmi_proxy_params.downstream.out[i] != -1)
+        for (i = 0; i < HYD_pmcd_pmip.local.proxy_process_count; i++) {
+            if (HYD_pmcd_pmip.downstream.out[i] != -1)
                 out_count++;
-            if (HYD_pmcd_pmi_proxy_params.downstream.err[i] != -1)
+            if (HYD_pmcd_pmip.downstream.err[i] != -1)
                 err_count++;
             if (out_count && err_count)
                 break;
-        if (HYD_pmcd_pmi_proxy_params.local.procs_are_launched) {
+        if (HYD_pmcd_pmip.local.procs_are_launched) {
             if (out_count == 0)
-                close(HYD_pmcd_pmi_proxy_params.upstream.out);
+                close(HYD_pmcd_pmip.upstream.out);
             if (err_count == 0)
-                close(HYD_pmcd_pmi_proxy_params.upstream.err);
+                close(HYD_pmcd_pmip.upstream.err);
             /* We are done */
             if (!out_count && !err_count)
@@ -49,21 +49,21 @@
     do {
-        if (HYD_pmcd_pmi_proxy_params.local.procs_are_launched == 0)
+        if (HYD_pmcd_pmip.local.procs_are_launched == 0)
             break;
         pid = waitpid(-1, &ret_status, 0);
         /* Find the pid and mark it as complete. */
         if (pid > 0)
-                if (HYD_pmcd_pmi_proxy_params.downstream.pid[i] == pid)
-                    HYD_pmcd_pmi_proxy_params.downstream.exit_status[i] = ret_status;
+                if (HYD_pmcd_pmip.downstream.pid[i] == pid)
+                    HYD_pmcd_pmip.downstream.exit_status[i] = ret_status;
         /* Check how many more processes are pending */
         count = 0;
-            if (HYD_pmcd_pmi_proxy_params.downstream.exit_status[i] == -1) {
+            if (HYD_pmcd_pmip.downstream.exit_status[i] == -1) {
                 count++;
                 break;
@@ -96,23 +96,22 @@
     HYDU_ERR_POP(status, "bad parameters passed to the proxy\n");
     /* Process launching only happens in the runtime case over here */
-    if (HYD_pmcd_pmi_proxy_params.user_global.launch_mode == HYD_LAUNCH_RUNTIME) {
-        HYD_pmcd_pmi_proxy_params.upstream.out = 1;
-        HYD_pmcd_pmi_proxy_params.upstream.err = 2;
-        HYD_pmcd_pmi_proxy_params.upstream.in = 0;
+    if (HYD_pmcd_pmip.user_global.launch_mode == HYD_LAUNCH_RUNTIME) {
+        HYD_pmcd_pmip.upstream.out = 1;
+        HYD_pmcd_pmip.upstream.err = 2;
+        HYD_pmcd_pmip.upstream.in = 0;
         /* Connect back upstream and the socket to a demux engine */
-        status = HYDU_sock_connect(HYD_pmcd_pmi_proxy_params.upstream.server_name,
-                                   HYD_pmcd_pmi_proxy_params.upstream.server_port,
-                                   &HYD_pmcd_pmi_proxy_params.upstream.control);
+        status = HYDU_sock_connect(HYD_pmcd_pmip.upstream.server_name,
+                                   HYD_pmcd_pmip.upstream.server_port,
+                                   &HYD_pmcd_pmip.upstream.control);
         HYDU_ERR_POP(status, "unable to connect to the main server\n");
-        status = HYDU_sock_write(HYD_pmcd_pmi_proxy_params.upstream.control,
-                                 &HYD_pmcd_pmi_proxy_params.local.id,
-                                 sizeof(HYD_pmcd_pmi_proxy_params.local.id));
+        status = HYDU_sock_write(HYD_pmcd_pmip.upstream.control,
+                                 &HYD_pmcd_pmip.local.id, sizeof(HYD_pmcd_pmip.local.id));
         HYDU_ERR_POP(status, "unable to send the proxy ID to the server\n");
-        status = HYDT_dmx_register_fd(1, &HYD_pmcd_pmi_proxy_params.upstream.control,
+        status = HYDT_dmx_register_fd(1, &HYD_pmcd_pmip.upstream.control,
                                       HYD_STDOUT, NULL, HYD_pmcd_pmi_proxy_control_cmd_cb);
         HYDU_ERR_POP(status, "unable to register fd\n");
@@ -121,15 +120,14 @@
         HYDU_ERR_POP(status, "error waiting for processes to finish\n");
         /* Send the exit status upstream */
-                                 HYD_pmcd_pmi_proxy_params.downstream.exit_status,
-                                 HYD_pmcd_pmi_proxy_params.local.proxy_process_count *
-                                 sizeof(int));
+                                 HYD_pmcd_pmip.downstream.exit_status,
+                                 HYD_pmcd_pmip.local.proxy_process_count * sizeof(int));
         HYDU_ERR_POP(status, "unable to return exit status upstream\n");
-        status = HYDT_dmx_deregister_fd(HYD_pmcd_pmi_proxy_params.upstream.control);
+        status = HYDT_dmx_deregister_fd(HYD_pmcd_pmip.upstream.control);
         HYDU_ERR_POP(status, "unable to deregister fd\n");
-        close(HYD_pmcd_pmi_proxy_params.upstream.control);
+        close(HYD_pmcd_pmip.upstream.control);
         /* cleanup the params structure for the next job */
         status = HYD_pmcd_pmi_proxy_cleanup_params();
@@ -137,8 +135,7 @@
     else {      /* Persistent mode */
         status = HYDU_sock_listen(&listenfd, NULL,
-                                  (uint16_t *) & HYD_pmcd_pmi_proxy_params.upstream.
-                                  server_port);
+                                  (uint16_t *) & HYD_pmcd_pmip.upstream.server_port);
         HYDU_ERR_POP(status, "unable to listen on socket\n");
         /* Register the listening socket with the demux engine */
@@ -146,7 +143,7 @@
                                       HYD_pmcd_pmi_proxy_control_connect_cb);
-        if (HYD_pmcd_pmi_proxy_params.user_global.launch_mode == HYD_LAUNCH_BOOT) {
+        if (HYD_pmcd_pmip.user_global.launch_mode == HYD_LAUNCH_BOOT) {
             /* Spawn a persistent daemon proxy and exit parent proxy */
             status = HYDU_fork_and_exit(-1);
             HYDU_ERR_POP(status, "Error spawning persistent proxy\n");
@@ -161,17 +158,17 @@
             /* If processes had been launched and terminated, find the
              * exit status, return it and cleanup everything. */
                                          sizeof(int));
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-16 04:40:40 UTC (rev 5473)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-16 04:44:28 UTC (rev 5474)
@@ -11,7 +11,7 @@
 #include "hydra_utils.h"
 #include "pmi_common.h"
-struct HYD_pmcd_pmi_proxy_params {
+struct HYD_pmcd_pmip {
     struct HYD_user_global user_global;
     struct {
@@ -63,7 +63,7 @@
     struct HYD_proxy_exec *exec_list;
-extern struct HYD_pmcd_pmi_proxy_params HYD_pmcd_pmi_proxy_params;
+extern struct HYD_pmcd_pmip HYD_pmcd_pmip;
 /* utils */
 HYD_status HYD_pmcd_pmi_proxy_get_params(char **t_argv);
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c	2009-10-16 04:40:40 UTC (rev 5473)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c	2009-10-16 04:44:28 UTC (rev 5474)
@@ -10,7 +10,7 @@
 #include "demux.h"
 HYD_status HYD_pmcd_pmi_proxy_control_connect_cb(int fd, HYD_event_t events, void *userp)
@@ -65,17 +65,17 @@
         status = HYD_pmcd_pmi_proxy_procinfo(fd);
     else if (cmd == USE_AS_STDOUT) {
-        HYD_pmcd_pmi_proxy_params.upstream.out = fd;
+        HYD_pmcd_pmip.upstream.out = fd;
         status = HYDT_dmx_deregister_fd(fd);
     else if (cmd == USE_AS_STDERR) {
-        HYD_pmcd_pmi_proxy_params.upstream.err = fd;
+        HYD_pmcd_pmip.upstream.err = fd;
     else if (cmd == USE_AS_STDIN) {
-        HYD_pmcd_pmi_proxy_params.upstream.in = fd;
+        HYD_pmcd_pmip.upstream.in = fd;
@@ -104,11 +104,9 @@
      * since they can arrive in any order. */
     if ((cmd == PROC_INFO) || (cmd == USE_AS_STDOUT) || (cmd == USE_AS_STDERR) ||
         (cmd == USE_AS_STDIN))
-        if ((HYD_pmcd_pmi_proxy_params.start_pid != -1) &&
-            (HYD_pmcd_pmi_proxy_params.upstream.out != -1) &&
-            (HYD_pmcd_pmi_proxy_params.upstream.err != -1))
-            if ((HYD_pmcd_pmi_proxy_params.start_pid != 0) ||
-                (HYD_pmcd_pmi_proxy_params.upstream.in != -1)) {
+        if ((HYD_pmcd_pmip.start_pid != -1) &&
+            (HYD_pmcd_pmip.upstream.out != -1) && (HYD_pmcd_pmip.upstream.err != -1))
+            if ((HYD_pmcd_pmip.start_pid != 0) || (HYD_pmcd_pmip.upstream.in != -1)) {
                 status = HYD_pmcd_pmi_proxy_launch_procs();
                 HYDU_ERR_POP(status, "HYD_pmcd_pmi_proxy_launch_procs returned error\n");
@@ -128,7 +126,7 @@
     HYDU_FUNC_ENTER();
-    status = HYDU_sock_stdout_cb(fd, events, HYD_pmcd_pmi_proxy_params.upstream.out, &closed);
+    status = HYDU_sock_stdout_cb(fd, events, HYD_pmcd_pmip.upstream.out, &closed);
     HYDU_ERR_POP(status, "stdout callback error\n");
     if (closed) {
@@ -136,9 +134,9 @@
-            if (HYD_pmcd_pmi_proxy_params.downstream.out[i] == fd)
-                HYD_pmcd_pmi_proxy_params.downstream.out[i] = -1;
+            if (HYD_pmcd_pmip.downstream.out[i] == fd)
+                HYD_pmcd_pmip.downstream.out[i] = -1;
         close(fd);
@@ -159,7 +157,7 @@
     HYDU_FUNC_ENTER();
-    status = HYDU_sock_stdout_cb(fd, events, HYD_pmcd_pmi_proxy_params.upstream.err, &closed);
+    status = HYDU_sock_stdout_cb(fd, events, HYD_pmcd_pmip.upstream.err, &closed);
     if (closed) {
@@ -167,9 +165,9 @@
-            if (HYD_pmcd_pmi_proxy_params.downstream.err[i] == fd)
-                HYD_pmcd_pmi_proxy_params.downstream.err[i] = -1;
+            if (HYD_pmcd_pmip.downstream.err[i] == fd)
+                HYD_pmcd_pmip.downstream.err[i] = -1;
         close(fd);
@@ -190,11 +188,11 @@
     HYDU_FUNC_ENTER();
-    status = HYDU_sock_stdin_cb(HYD_pmcd_pmi_proxy_params.downstream.in, events,
-                                HYD_pmcd_pmi_proxy_params.upstream.in,
-                                HYD_pmcd_pmi_proxy_params.local.stdin_tmp_buf,
-                                &HYD_pmcd_pmi_proxy_params.local.stdin_buf_count,
-                                &HYD_pmcd_pmi_proxy_params.local.stdin_buf_offset, &closed);
+    status = HYDU_sock_stdin_cb(HYD_pmcd_pmip.downstream.in, events,
+                                HYD_pmcd_pmip.upstream.in,
+                                HYD_pmcd_pmip.local.stdin_tmp_buf,
+                                &HYD_pmcd_pmip.local.stdin_buf_count,
+                                &HYD_pmcd_pmip.local.stdin_buf_offset, &closed);
     HYDU_ERR_POP(status, "stdin callback error\n");
     if (closed) {
@@ -202,9 +200,9 @@
-        close(HYD_pmcd_pmi_proxy_params.upstream.in);
-        close(HYD_pmcd_pmi_proxy_params.downstream.in);
-        HYD_pmcd_pmi_proxy_params.downstream.in = -1;
+        close(HYD_pmcd_pmip.upstream.in);
+        close(HYD_pmcd_pmip.downstream.in);
+        HYD_pmcd_pmip.downstream.in = -1;
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-16 04:40:40 UTC (rev 5473)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-16 04:44:28 UTC (rev 5474)
@@ -10,40 +10,40 @@
 #include "hydra_tools.h"
 static HYD_status init_params(void)
     HYD_status status = HYD_SUCCESS;
-    HYDU_init_user_global(&HYD_pmcd_pmi_proxy_params.user_global);
+    HYDU_init_user_global(&HYD_pmcd_pmip.user_global);
-    HYD_pmcd_pmi_proxy_params.system_global.global_core_count = 0;
-    HYD_pmcd_pmi_proxy_params.system_global.pmi_port_str = NULL;
+    HYD_pmcd_pmip.system_global.global_core_count = 0;
+    HYD_pmcd_pmip.system_global.pmi_port_str = NULL;
-    HYD_pmcd_pmi_proxy_params.upstream.server_name = NULL;
-    HYD_pmcd_pmi_proxy_params.upstream.server_port = -1;
-    HYD_pmcd_pmi_proxy_params.upstream.out = -1;
-    HYD_pmcd_pmi_proxy_params.upstream.err = -1;
-    HYD_pmcd_pmi_proxy_params.upstream.in = -1;
-    HYD_pmcd_pmi_proxy_params.upstream.control = -1;
+    HYD_pmcd_pmip.upstream.server_name = NULL;
+    HYD_pmcd_pmip.upstream.server_port = -1;
+    HYD_pmcd_pmip.upstream.out = -1;
+    HYD_pmcd_pmip.upstream.err = -1;
+    HYD_pmcd_pmip.upstream.in = -1;
+    HYD_pmcd_pmip.upstream.control = -1;
-    HYD_pmcd_pmi_proxy_params.downstream.out = NULL;
-    HYD_pmcd_pmi_proxy_params.downstream.err = NULL;
-    HYD_pmcd_pmi_proxy_params.downstream.pid = NULL;
-    HYD_pmcd_pmi_proxy_params.downstream.exit_status = NULL;
+    HYD_pmcd_pmip.downstream.out = NULL;
+    HYD_pmcd_pmip.downstream.err = NULL;
+    HYD_pmcd_pmip.downstream.pid = NULL;
+    HYD_pmcd_pmip.downstream.exit_status = NULL;
-    HYD_pmcd_pmi_proxy_params.local.id = -1;
-    HYD_pmcd_pmi_proxy_params.local.proxy_core_count = 0;
-    HYD_pmcd_pmi_proxy_params.local.proxy_process_count = 0;
-    HYD_pmcd_pmi_proxy_params.local.procs_are_launched = 0;
-    HYD_pmcd_pmi_proxy_params.local.stdin_buf_offset = 0;
-    HYD_pmcd_pmi_proxy_params.local.stdin_buf_count = 0;
-    HYD_pmcd_pmi_proxy_params.local.stdin_tmp_buf[0] = '\0';
+    HYD_pmcd_pmip.local.id = -1;
+    HYD_pmcd_pmip.local.proxy_core_count = 0;
+    HYD_pmcd_pmip.local.proxy_process_count = 0;
+    HYD_pmcd_pmip.local.procs_are_launched = 0;
+    HYD_pmcd_pmip.local.stdin_buf_offset = 0;
+    HYD_pmcd_pmip.local.stdin_buf_count = 0;
+    HYD_pmcd_pmip.local.stdin_tmp_buf[0] = '\0';
-    HYD_pmcd_pmi_proxy_params.start_pid = -1;
-    HYD_pmcd_pmi_proxy_params.exec_list = NULL;
+    HYD_pmcd_pmip.start_pid = -1;
+    HYD_pmcd_pmip.exec_list = NULL;
     return status;
@@ -66,7 +66,7 @@
         /* Working directory */
         if (!strcmp(*argv, "--wdir")) {
             argv++;
-            HYD_pmcd_pmi_proxy_params.user_global.wdir = HYDU_strdup(*argv);
+            HYD_pmcd_pmip.user_global.wdir = HYDU_strdup(*argv);
             continue;
@@ -74,9 +74,9 @@
         if (!strcmp(*argv, "--pmi-port-str")) {
             argv++;
             if (!strcmp(*argv, "HYDRA_NULL"))
             else
-                HYD_pmcd_pmi_proxy_params.system_global.pmi_port_str = HYDU_strdup(*argv);
+                HYD_pmcd_pmip.system_global.pmi_port_str = HYDU_strdup(*argv);
             continue;
@@ -84,9 +84,9 @@
         if (!strcmp(*argv, "--binding")) {
             argv++;
-                HYD_pmcd_pmi_proxy_params.user_global.binding = NULL;
+                HYD_pmcd_pmip.user_global.binding = NULL;
             else
-                HYD_pmcd_pmi_proxy_params.user_global.binding = HYDU_strdup(*argv);
+                HYD_pmcd_pmip.user_global.binding = HYDU_strdup(*argv);
             continue;
@@ -94,28 +94,28 @@
         /* Binding library */
         if (!strcmp(*argv, "--bindlib")) {
             argv++;
-            HYD_pmcd_pmi_proxy_params.user_global.bindlib = HYDU_strdup(*argv);
+            HYD_pmcd_pmip.user_global.bindlib = HYDU_strdup(*argv);
             continue;
         /* Checkpointing library */
         if (!strcmp(*argv, "--ckpointlib")) {
             argv++;
-            HYD_pmcd_pmi_proxy_params.user_global.ckpointlib = HYDU_strdup(*argv);
+            HYD_pmcd_pmip.user_global.ckpointlib = HYDU_strdup(*argv);
             continue;
         if (!strcmp(*argv, "--ckpoint-prefix")) {
             argv++;
-                HYD_pmcd_pmi_proxy_params.user_global.ckpoint_prefix = NULL;
+                HYD_pmcd_pmip.user_global.ckpoint_prefix = NULL;
             else
-                HYD_pmcd_pmi_proxy_params.user_global.ckpoint_prefix = HYDU_strdup(*argv);
+                HYD_pmcd_pmip.user_global.ckpoint_prefix = HYDU_strdup(*argv);
             continue;
         if (!strcmp(*argv, "--ckpoint-restart")) {
-            HYD_pmcd_pmi_proxy_params.user_global.ckpoint_restart = 1;
+            HYD_pmcd_pmip.user_global.ckpoint_restart = 1;
             continue;
@@ -143,16 +143,12 @@
                 if (!strcmp(argtype, "--global-inherited-env"))
                     HYDU_append_env_to_list(*env,
-                                            &HYD_pmcd_pmi_proxy_params.user_global.global_env.
-                                            inherited);
+                                            &HYD_pmcd_pmip.user_global.global_env.inherited);
                 else if (!strcmp(argtype, "--global-system-env"))
-                                            system);
+                                            &HYD_pmcd_pmip.user_global.global_env.system);
                 else if (!strcmp(argtype, "--global-user-env"))
-                    HYDU_append_env_to_list(*env,
-                                            user);
+                    HYDU_append_env_to_list(*env, &HYD_pmcd_pmip.user_global.global_env.user);
                 HYDU_FREE(env);
@@ -163,42 +159,41 @@
         if (!strcmp(*argv, "--genv-prop")) {
             argv++;
             if (strcmp(*argv, "HYDRA_NULL"))
-                HYD_pmcd_pmi_proxy_params.user_global.global_env.prop = HYDU_strdup(*argv);
+                HYD_pmcd_pmip.user_global.global_env.prop = HYDU_strdup(*argv);
             else
-                HYD_pmcd_pmi_proxy_params.user_global.global_env.prop = NULL;
+                HYD_pmcd_pmip.user_global.global_env.prop = NULL;
             continue;
         /* One-pass Count */
         if (!strcmp(*argv, "--global-core-count")) {
             argv++;
-            HYD_pmcd_pmi_proxy_params.system_global.global_core_count = atoi(*argv);
+            HYD_pmcd_pmip.system_global.global_core_count = atoi(*argv);
             continue;
         /* Process count */
         if (!strcmp(*argv, "--proxy-core-count")) {
             argv++;
-            HYD_pmcd_pmi_proxy_params.local.proxy_core_count = atoi(*argv);
+            HYD_pmcd_pmip.local.proxy_core_count = atoi(*argv);
             continue;
         /* Process count */
         if (!strcmp(*argv, "--start-pid")) {
             argv++;
-            HYD_pmcd_pmi_proxy_params.start_pid = atoi(*argv);
+            HYD_pmcd_pmip.start_pid = atoi(*argv);
             continue;
         /* New executable */
         if (!strcmp(*argv, "--exec")) {
-            if (HYD_pmcd_pmi_proxy_params.exec_list == NULL) {
-                status = HYDU_alloc_proxy_exec(&HYD_pmcd_pmi_proxy_params.exec_list);
+            if (HYD_pmcd_pmip.exec_list == NULL) {
+                status = HYDU_alloc_proxy_exec(&HYD_pmcd_pmip.exec_list);
                 HYDU_ERR_POP(status, "unable to allocate proxy exec\n");
             else {
-                for (exec = HYD_pmcd_pmi_proxy_params.exec_list; exec->next;
-                     exec = exec->next);
+                for (exec = HYD_pmcd_pmip.exec_list; exec->next; exec = exec->next);
                 status = HYDU_alloc_proxy_exec(&exec->next);
@@ -208,7 +203,7 @@
         /* Process count */
         if (!strcmp(*argv, "--exec-proc-count")) {
             argv++;
-            for (exec = HYD_pmcd_pmi_proxy_params.exec_list; exec->next; exec = exec->next);
             exec->proc_count = atoi(*argv);
             continue;
@@ -248,7 +243,7 @@
         /* Fall through case is application parameters. Load
          * everything into the args variable. */
         for (arg = 0; *argv && strcmp(*argv, "--exec");) {
             exec->exec[arg++] = HYDU_strdup(*argv);
             ++argv;
@@ -285,61 +280,60 @@
     while (++argv && *argv) {
         if (!strcmp(*argv, "--launch-mode")) {
             ++argv;
-            HYD_pmcd_pmi_proxy_params.user_global.launch_mode =
+            HYD_pmcd_pmip.user_global.launch_mode =
                 (HYD_launch_mode_t) (unsigned int) atoi(*argv);
             continue;
         if (!strcmp(*argv, "--proxy-port")) {
             ++argv;
-                    HYDU_strdup(strtok(*argv, ":"));
-                HYD_pmcd_pmi_proxy_params.upstream.server_port = atoi(strtok(NULL, ":"));
+                HYD_pmcd_pmip.upstream.server_name = HYDU_strdup(strtok(*argv, ":"));
+                HYD_pmcd_pmip.upstream.server_port = atoi(strtok(NULL, ":"));
             else {
-                HYD_pmcd_pmi_proxy_params.upstream.server_port = atoi(*argv);
+                HYD_pmcd_pmip.upstream.server_port = atoi(*argv);
             continue;
         if (!strcmp(*argv, "--proxy-id")) {
             ++argv;
-            HYD_pmcd_pmi_proxy_params.local.id = atoi(*argv);
+            HYD_pmcd_pmip.local.id = atoi(*argv);
             continue;
         if (!strcmp(*argv, "--debug")) {
-            HYD_pmcd_pmi_proxy_params.user_global.debug = 1;
+            HYD_pmcd_pmip.user_global.debug = 1;
             continue;
         if (!strcmp(*argv, "--enable-x")) {
-            HYD_pmcd_pmi_proxy_params.user_global.enablex = 1;
+            HYD_pmcd_pmip.user_global.enablex = 1;
             continue;
         if (!strcmp(*argv, "--disable-x")) {
-            HYD_pmcd_pmi_proxy_params.user_global.enablex = 0;
+            HYD_pmcd_pmip.user_global.enablex = 0;
             continue;
         if (!strcmp(*argv, "--bootstrap")) {
             ++argv;
-            HYD_pmcd_pmi_proxy_params.user_global.bootstrap = HYDU_strdup(*argv);
+            HYD_pmcd_pmip.user_global.bootstrap = HYDU_strdup(*argv);
             continue;
         if (!strcmp(*argv, "--bootstrap-exec")) {
             ++argv;
-            HYD_pmcd_pmi_proxy_params.user_global.bootstrap_exec = HYDU_strdup(*argv);
+            HYD_pmcd_pmip.user_global.bootstrap_exec = HYDU_strdup(*argv);
             continue;
-    status = HYDT_bsci_init(HYD_pmcd_pmi_proxy_params.user_global.bootstrap,
-                            HYD_pmcd_pmi_proxy_params.user_global.bootstrap_exec,
-                            HYD_pmcd_pmi_proxy_params.user_global.enablex,
-                            HYD_pmcd_pmi_proxy_params.user_global.debug);
+    status = HYDT_bsci_init(HYD_pmcd_pmip.user_global.bootstrap,
+                            HYD_pmcd_pmip.user_global.bootstrap_exec,
+                            HYD_pmcd_pmip.user_global.enablex,
+                            HYD_pmcd_pmip.user_global.debug);
     HYDU_ERR_POP(status, "proxy unable to initialize bootstrap\n");
-    if (HYD_pmcd_pmi_proxy_params.local.id == -1) {
+    if (HYD_pmcd_pmip.local.id == -1) {
         /* We didn't get a proxy ID during launch; query the
          * bootstrap server for it. */
-        status = HYDT_bsci_query_proxy_id(&HYD_pmcd_pmi_proxy_params.local.id);
+        status = HYDT_bsci_query_proxy_id(&HYD_pmcd_pmip.local.id);
         HYDU_ERR_POP(status, "unable to query bootstrap server for proxy ID\n");
@@ -359,44 +353,44 @@
     HYDU_FUNC_ENTER();
-    if (HYD_pmcd_pmi_proxy_params.upstream.server_name)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.upstream.server_name);
+    if (HYD_pmcd_pmip.upstream.server_name)
+        HYDU_FREE(HYD_pmcd_pmip.upstream.server_name);
-    if (HYD_pmcd_pmi_proxy_params.user_global.bootstrap)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.user_global.bootstrap);
+    if (HYD_pmcd_pmip.user_global.bootstrap)
+        HYDU_FREE(HYD_pmcd_pmip.user_global.bootstrap);
-    if (HYD_pmcd_pmi_proxy_params.user_global.bootstrap_exec)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.user_global.bootstrap_exec);
+    if (HYD_pmcd_pmip.user_global.bootstrap_exec)
+        HYDU_FREE(HYD_pmcd_pmip.user_global.bootstrap_exec);
-    if (HYD_pmcd_pmi_proxy_params.user_global.wdir)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.user_global.wdir);
+    if (HYD_pmcd_pmip.user_global.wdir)
+        HYDU_FREE(HYD_pmcd_pmip.user_global.wdir);
-    if (HYD_pmcd_pmi_proxy_params.system_global.pmi_port_str)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.system_global.pmi_port_str);
+    if (HYD_pmcd_pmip.system_global.pmi_port_str)
+        HYDU_FREE(HYD_pmcd_pmip.system_global.pmi_port_str);
-    if (HYD_pmcd_pmi_proxy_params.user_global.binding)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.user_global.binding);
+    if (HYD_pmcd_pmip.user_global.binding)
+        HYDU_FREE(HYD_pmcd_pmip.user_global.binding);
-    if (HYD_pmcd_pmi_proxy_params.user_global.bindlib)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.user_global.bindlib);
+    if (HYD_pmcd_pmip.user_global.bindlib)
+        HYDU_FREE(HYD_pmcd_pmip.user_global.bindlib);
-    if (HYD_pmcd_pmi_proxy_params.user_global.ckpointlib)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.user_global.ckpointlib);
+    if (HYD_pmcd_pmip.user_global.ckpointlib)
+        HYDU_FREE(HYD_pmcd_pmip.user_global.ckpointlib);
-    if (HYD_pmcd_pmi_proxy_params.user_global.ckpoint_prefix)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.user_global.ckpoint_prefix);
+    if (HYD_pmcd_pmip.user_global.ckpoint_prefix)
+        HYDU_FREE(HYD_pmcd_pmip.user_global.ckpoint_prefix);
-    if (HYD_pmcd_pmi_proxy_params.user_global.global_env.system)
-        HYDU_env_free_list(HYD_pmcd_pmi_proxy_params.user_global.global_env.system);
+    if (HYD_pmcd_pmip.user_global.global_env.system)
+        HYDU_env_free_list(HYD_pmcd_pmip.user_global.global_env.system);
-    if (HYD_pmcd_pmi_proxy_params.user_global.global_env.user)
-        HYDU_env_free_list(HYD_pmcd_pmi_proxy_params.user_global.global_env.user);
+    if (HYD_pmcd_pmip.user_global.global_env.user)
+        HYDU_env_free_list(HYD_pmcd_pmip.user_global.global_env.user);
-    if (HYD_pmcd_pmi_proxy_params.user_global.global_env.inherited)
-        HYDU_env_free_list(HYD_pmcd_pmi_proxy_params.user_global.global_env.inherited);
+    if (HYD_pmcd_pmip.user_global.global_env.inherited)
+        HYDU_env_free_list(HYD_pmcd_pmip.user_global.global_env.inherited);
-    if (HYD_pmcd_pmi_proxy_params.exec_list) {
-        exec = HYD_pmcd_pmi_proxy_params.exec_list;
+    if (HYD_pmcd_pmip.exec_list) {
+        exec = HYD_pmcd_pmip.exec_list;
         while (exec) {
             texec = exec->next;
             HYDU_free_strlist(exec->exec);
@@ -407,17 +401,17 @@
-    if (HYD_pmcd_pmi_proxy_params.downstream.pid)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.downstream.pid);
+    if (HYD_pmcd_pmip.downstream.pid)
+        HYDU_FREE(HYD_pmcd_pmip.downstream.pid);
-    if (HYD_pmcd_pmi_proxy_params.downstream.out)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.downstream.out);
+    if (HYD_pmcd_pmip.downstream.out)
+        HYDU_FREE(HYD_pmcd_pmip.downstream.out);
-    if (HYD_pmcd_pmi_proxy_params.downstream.err)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.downstream.err);
+    if (HYD_pmcd_pmip.downstream.err)
+        HYDU_FREE(HYD_pmcd_pmip.downstream.err);
-    if (HYD_pmcd_pmi_proxy_params.downstream.exit_status)
-        HYDU_FREE(HYD_pmcd_pmi_proxy_params.downstream.exit_status);
+    if (HYD_pmcd_pmip.downstream.exit_status)
+        HYDU_FREE(HYD_pmcd_pmip.downstream.exit_status);
     HYDT_bind_finalize();
@@ -471,7 +465,7 @@
     /* Save this fd as we need to send back the exit status on
      * this. */
-    HYD_pmcd_pmi_proxy_params.upstream.control = fd;
+    HYD_pmcd_pmip.upstream.control = fd;
   fn_exit:
     HYDU_FUNC_EXIT();
@@ -494,59 +488,57 @@
     HYDU_FUNC_ENTER();
-    for (exec = HYD_pmcd_pmi_proxy_params.exec_list; exec; exec = exec->next)
-        HYD_pmcd_pmi_proxy_params.local.proxy_process_count += exec->proc_count;
+    for (exec = HYD_pmcd_pmip.exec_list; exec; exec = exec->next)
+        HYD_pmcd_pmip.local.proxy_process_count += exec->proc_count;
-    HYDU_MALLOC(pmi_ids, int *, HYD_pmcd_pmi_proxy_params.local.proxy_process_count *
-                sizeof(int), status);
+    HYDU_MALLOC(pmi_ids, int *, HYD_pmcd_pmip.local.proxy_process_count * sizeof(int), status);
         pmi_ids[i] =
-            HYDU_local_to_global_id(i, HYD_pmcd_pmi_proxy_params.start_pid,
-                                    HYD_pmcd_pmi_proxy_params.local.proxy_core_count,
-                                    HYD_pmcd_pmi_proxy_params.system_global.global_core_count);
+            HYDU_local_to_global_id(i, HYD_pmcd_pmip.start_pid,
+                                    HYD_pmcd_pmip.local.proxy_core_count,
+                                    HYD_pmcd_pmip.system_global.global_core_count);
-    HYDU_MALLOC(HYD_pmcd_pmi_proxy_params.downstream.out, int *,
-                HYD_pmcd_pmi_proxy_params.local.proxy_process_count * sizeof(int), status);
-    HYDU_MALLOC(HYD_pmcd_pmi_proxy_params.downstream.err, int *,
-    HYDU_MALLOC(HYD_pmcd_pmi_proxy_params.downstream.pid, int *,
-    HYDU_MALLOC(HYD_pmcd_pmi_proxy_params.downstream.exit_status, int *,
+    HYDU_MALLOC(HYD_pmcd_pmip.downstream.out, int *,
+                HYD_pmcd_pmip.local.proxy_process_count * sizeof(int), status);
+    HYDU_MALLOC(HYD_pmcd_pmip.downstream.err, int *,
+    HYDU_MALLOC(HYD_pmcd_pmip.downstream.pid, int *,
+    HYDU_MALLOC(HYD_pmcd_pmip.downstream.exit_status, int *,
     /* Initialize the exit status */
-        HYD_pmcd_pmi_proxy_params.downstream.exit_status[i] = -1;
+        HYD_pmcd_pmip.downstream.exit_status[i] = -1;
-    status = HYDT_bind_init(HYD_pmcd_pmi_proxy_params.user_global.binding,
-                            HYD_pmcd_pmi_proxy_params.user_global.bindlib);
+    status = HYDT_bind_init(HYD_pmcd_pmip.user_global.binding,
+                            HYD_pmcd_pmip.user_global.bindlib);
     HYDU_ERR_POP(status, "unable to initialize process binding\n");
-    status = HYDT_ckpoint_init(HYD_pmcd_pmi_proxy_params.user_global.ckpointlib,
-                               HYD_pmcd_pmi_proxy_params.user_global.ckpoint_prefix);
+    status = HYDT_ckpoint_init(HYD_pmcd_pmip.user_global.ckpointlib,
+                               HYD_pmcd_pmip.user_global.ckpoint_prefix);
     HYDU_ERR_POP(status, "unable to initialize checkpointing\n");
-    if (HYD_pmcd_pmi_proxy_params.user_global.ckpoint_restart) {
-        status = HYDU_env_create(&env, "PMI_PORT",
-                                 HYD_pmcd_pmi_proxy_params.system_global.pmi_port_str);
+    if (HYD_pmcd_pmip.user_global.ckpoint_restart) {
+        status = HYDU_env_create(&env, "PMI_PORT", HYD_pmcd_pmip.system_global.pmi_port_str);
         HYDU_ERR_POP(status, "unable to create env\n");
         /* Restart the proxy.  Specify stdin fd only if pmi_id 0 is in this proxy. */
-        status = HYDT_ckpoint_restart(env, HYD_pmcd_pmi_proxy_params.local.proxy_process_count,
+        status = HYDT_ckpoint_restart(env, HYD_pmcd_pmip.local.proxy_process_count,
                                       pmi_ids,
                                       pmi_ids[0] ? NULL :
-                                      &HYD_pmcd_pmi_proxy_params.downstream.in,
-                                      HYD_pmcd_pmi_proxy_params.downstream.out,
-                                      HYD_pmcd_pmi_proxy_params.downstream.err);
+                                      &HYD_pmcd_pmip.downstream.in,
+                                      HYD_pmcd_pmip.downstream.out,
+                                      HYD_pmcd_pmip.downstream.err);
         HYDU_ERR_POP(status, "checkpoint restart failure\n");
         goto fn_spawn_complete;
     /* Spawn the processes */
     process_id = 0;
-    for (exec = HYD_pmcd_pmi_proxy_params.exec_list; exec; exec = exec->next) {
+    for (exec = HYD_pmcd_pmip.exec_list; exec; exec = exec->next) {
          * Increasing priority order:
@@ -558,30 +550,25 @@
         /* Global inherited env */
         if ((exec->env_prop && !strcmp(exec->env_prop, "all")) ||
-            (!exec->env_prop && !strcmp(HYD_pmcd_pmi_proxy_params.user_global.global_env.prop,
-                                        "all"))) {
-            for (env = HYD_pmcd_pmi_proxy_params.user_global.global_env.inherited; env;
-                 env = env->next) {
+            (!exec->env_prop && !strcmp(HYD_pmcd_pmip.user_global.global_env.prop, "all"))) {
+            for (env = HYD_pmcd_pmip.user_global.global_env.inherited; env; env = env->next) {
                 status = HYDU_append_env_to_list(*env, &prop_env);
                 HYDU_ERR_POP(status, "unable to add env to list\n");
         else if ((exec->env_prop && !strncmp(exec->env_prop, "list", strlen("list"))) ||
                  (!exec->env_prop &&
-                  !strncmp(HYD_pmcd_pmi_proxy_params.user_global.global_env.prop, "list",
+                  !strncmp(HYD_pmcd_pmip.user_global.global_env.prop, "list",
                            strlen("list")))) {
             if (exec->env_prop)
                 list = HYDU_strdup(exec->env_prop + strlen("list:"));
             else
-                list = HYDU_strdup(HYD_pmcd_pmi_proxy_params.user_global.global_env.prop +
+                list = HYDU_strdup(HYD_pmcd_pmip.user_global.global_env.prop +
                                    strlen("list:"));
             envstr = strtok(list, ",");
             while (envstr) {
-                env =
-                    HYDU_env_lookup(envstr,
-                                    inherited);
+                env = HYDU_env_lookup(envstr, HYD_pmcd_pmip.user_global.global_env.inherited);
                 if (env) {
@@ -591,7 +578,7 @@
         /* Next priority order is the global user env */
-        for (env = HYD_pmcd_pmi_proxy_params.user_global.global_env.user; env; env = env->next) {
+        for (env = HYD_pmcd_pmip.user_global.global_env.user; env; env = env->next) {
@@ -603,17 +590,16 @@
         /* Highest priority is the system env */
-        for (env = HYD_pmcd_pmi_proxy_params.user_global.global_env.system; env;
+        for (env = HYD_pmcd_pmip.user_global.global_env.system; env; env = env->next) {
         /* Set the PMI port string to connect to. We currently just
          * use the global PMI port. */
-        if (HYD_pmcd_pmi_proxy_params.system_global.pmi_port_str) {
+        if (HYD_pmcd_pmip.system_global.pmi_port_str) {
+                                     HYD_pmcd_pmip.system_global.pmi_port_str);
@@ -622,12 +608,11 @@
         for (i = 0; i < exec->proc_count; i++) {
             pmi_id = HYDU_local_to_global_id(process_id,
-                                             HYD_pmcd_pmi_proxy_params.start_pid,
-                                             global_core_count);
+                                             HYD_pmcd_pmip.start_pid,
                 str = HYDU_int_to_str(pmi_id);
                 status = HYDU_env_create(&env, "PMI_ID", str);
@@ -636,7 +621,7 @@
-            if (chdir(HYD_pmcd_pmi_proxy_params.user_global.wdir) < 0)
+            if (chdir(HYD_pmcd_pmip.user_global.wdir) < 0)
                 HYDU_ERR_SETANDJUMP1(status, HYD_INTERNAL_ERROR,
                                      "unable to change wdir (%s)\n", HYDU_strerror(errno));
@@ -647,33 +632,27 @@
             core = HYDT_bind_get_core_id(process_id);
             if (pmi_id == 0) {
                 status = HYDU_create_process(client_args, prop_env,
-                                             out[process_id],
-                                             err[process_id],
-                                             pid[process_id], core);
+                                             &HYD_pmcd_pmip.downstream.out[process_id],
+                                             &HYD_pmcd_pmip.downstream.err[process_id],
+                                             &HYD_pmcd_pmip.downstream.pid[process_id], core);
-                status = HYDU_sock_set_nonblock(HYD_pmcd_pmi_proxy_params.upstream.in);
+                status = HYDU_sock_set_nonblock(HYD_pmcd_pmip.upstream.in);
                 HYDU_ERR_POP(status, "unable to set upstream stdin fd to nonblocking\n");
-                stdin_fd = HYD_pmcd_pmi_proxy_params.downstream.in;
+                stdin_fd = HYD_pmcd_pmip.downstream.in;
                 status = HYDT_dmx_register_fd(1, &stdin_fd, HYD_STDIN, NULL,
                                               HYD_pmcd_pmi_proxy_stdin_cb);
             else {
                 status = HYDU_create_process(client_args, prop_env, NULL,
-                                             out[process_id],
-                                             err[process_id],
             HYDU_ERR_POP(status, "create process returned error\n");
@@ -686,18 +665,18 @@
   fn_spawn_complete:
     /* Everything is spawned, register the required FDs  */
-    status = HYDT_dmx_register_fd(HYD_pmcd_pmi_proxy_params.local.proxy_process_count,
+    status = HYDT_dmx_register_fd(HYD_pmcd_pmip.local.proxy_process_count,
                                   HYD_STDOUT, NULL, HYD_pmcd_pmi_proxy_stdout_cb);
-                                  HYD_pmcd_pmi_proxy_params.downstream.err,
+                                  HYD_pmcd_pmip.downstream.err,
                                   HYD_STDOUT, NULL, HYD_pmcd_pmi_proxy_stderr_cb);
     /* Indicate that the processes have been launched */
-    HYD_pmcd_pmi_proxy_params.local.procs_are_launched = 1;
+    HYD_pmcd_pmip.local.procs_are_launched = 1;
   fn_exit:
     if (pmi_ids)
@@ -717,10 +696,10 @@
     HYDU_FUNC_ENTER();
     /* Send the kill signal to all processes */
-        if (HYD_pmcd_pmi_proxy_params.downstream.pid[i] != -1) {
-            kill(HYD_pmcd_pmi_proxy_params.downstream.pid[i], SIGTERM);
-            kill(HYD_pmcd_pmi_proxy_params.downstream.pid[i], SIGKILL);
+        if (HYD_pmcd_pmip.downstream.pid[i] != -1) {
+            kill(HYD_pmcd_pmip.downstream.pid[i], SIGTERM);
+            kill(HYD_pmcd_pmip.downstream.pid[i], SIGKILL);
More information about the mpich2-commits
