[mpich2-commits] r5467 - in mpich2/trunk/src/pm/hydra: pm/pmiserv ui/mpiexec utils/others
balaji at mcs.anl.gov balaji at mcs.anl.gov
Thu Oct 15 12:10:37 CDT 2009
Author: balaji
Date: 2009-10-15 12:10:37 -0500 (Thu, 15 Oct 2009)
New Revision: 5467
Modified:
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
   mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
   mpich2/trunk/src/pm/hydra/utils/others/others.c
Log:
White space cleanup.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c	2009-10-15 17:10:32 UTC (rev 5466)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c	2009-10-15 17:10:37 UTC (rev 5467)
@@ -137,8 +137,8 @@
     else {      /* Persistent mode */
         status = HYDU_sock_listen(&listenfd, NULL,
-                                  (uint16_t *) & HYD_PMCD_pmi_proxy_params.upstream.
-                                  server_port);
+                                  (uint16_t *) & HYD_PMCD_pmi_proxy_params.
+                                  upstream.server_port);
         HYDU_ERR_POP(status, "unable to listen on socket\n");
         /* Register the listening socket with the demux engine */
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-15 17:10:32 UTC (rev 5466)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-15 17:10:37 UTC (rev 5467)
@@ -143,16 +143,16 @@
                 if (!strcmp(argtype, "--global-inherited-env"))
                     HYDU_append_env_to_list(*env,
-                                            &HYD_PMCD_pmi_proxy_params.user_global.global_env.
-                                            inherited);
+                                            &HYD_PMCD_pmi_proxy_params.user_global.
+                                            global_env.inherited);
                 else if (!strcmp(argtype, "--global-system-env"))
-                                            system);
+                                            global_env.system);
                 else if (!strcmp(argtype, "--global-user-env"))
-                                            user);
+                                            global_env.user);
                 HYDU_FREE(env);
@@ -580,8 +580,8 @@
             while (envstr) {
                 env =
                     HYDU_env_lookup(envstr,
-                                    HYD_PMCD_pmi_proxy_params.user_global.global_env.
-                                    inherited);
+                                    HYD_PMCD_pmi_proxy_params.user_global.
                 if (env) {
                     status = HYDU_append_env_to_list(*env, &prop_env);
                     HYDU_ERR_POP(status, "unable to add env to list\n");
@@ -624,8 +624,8 @@
             pmi_id = HYDU_local_to_global_id(process_id,
                                              HYD_PMCD_pmi_proxy_params.start_pid,
                                              HYD_PMCD_pmi_proxy_params.local.proxy_core_count,
-                                             HYD_PMCD_pmi_proxy_params.system_global.
-                                             global_core_count);
+                                             system_global.global_core_count);
             if (HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str) {
                 str = HYDU_int_to_str(pmi_id);
@@ -648,12 +648,12 @@
             if (pmi_id == 0) {
                 status = HYDU_create_process(client_args, prop_env,
                                              &HYD_PMCD_pmi_proxy_params.downstream.in,
-                                             &HYD_PMCD_pmi_proxy_params.downstream.
-                                             out[process_id],
-                                             err[process_id],
-                                             pid[process_id], core);
+                                             downstream.out[process_id],
+                                             downstream.err[process_id],
+                                             downstream.pid[process_id], core);
                 HYD_PMCD_pmi_proxy_params.local.stdin_buf_offset = 0;
                 HYD_PMCD_pmi_proxy_params.local.stdin_buf_count = 0;
@@ -668,12 +668,12 @@
             else {
                 status = HYDU_create_process(client_args, prop_env, NULL,
-                                             out[process_id],
-                                             err[process_id],
             HYDU_ERR_POP(status, "create process returned error\n");
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-10-15 17:10:32 UTC (rev 5466)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-10-15 17:10:37 UTC (rev 5467)
@@ -255,7 +255,8 @@
         proxy->exec_launch_info[arg++] = HYDU_strdup("--ckpoint-prefix");
         if (HYD_handle.user_global.ckpoint_prefix)
-            proxy->exec_launch_info[arg++] = HYDU_strdup(HYD_handle.user_global.ckpoint_prefix);
+            proxy->exec_launch_info[arg++] =
+                HYDU_strdup(HYD_handle.user_global.ckpoint_prefix);
         else
             proxy->exec_launch_info[arg++] = HYDU_strdup("HYDRA_NULL");
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-15 17:10:32 UTC (rev 5466)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-15 17:10:37 UTC (rev 5467)
@@ -211,8 +211,7 @@
     FORALL_ACTIVE_PROXIES(proxy, HYD_handle.proxy_list)
-        HYDU_MALLOC(proxy->exit_status, int *, proxy->proxy_process_count * sizeof(int),
-                    status);
+    HYDU_MALLOC(proxy->exit_status, int *, proxy->proxy_process_count * sizeof(int), status);
     /* Launch the processes */
     status = HYD_PMCI_launch_procs();
Modified: mpich2/trunk/src/pm/hydra/utils/others/others.c
--- mpich2/trunk/src/pm/hydra/utils/others/others.c	2009-10-15 17:10:32 UTC (rev 5466)
+++ mpich2/trunk/src/pm/hydra/utils/others/others.c	2009-10-15 17:10:37 UTC (rev 5467)
@@ -25,7 +25,7 @@
         /* Run to the last proxy */
         for (proxy = *proxy_list; proxy->next; proxy = proxy->next);
-        if (strcmp(proxy->hostname, hostname)) { /* hostname doesn't match */
+        if (strcmp(proxy->hostname, hostname)) {        /* hostname doesn't match */
             status = HYDU_alloc_proxy(&proxy->next);
             HYDU_ERR_POP(status, "unable to alloc proxy\n");
             proxy->next->hostname = HYDU_strdup(hostname);
@@ -42,9 +42,7 @@
     goto fn_exit;
-int HYDU_local_to_global_id(int local_id, int start_pid, int core_count,
-                            int global_core_count)
+int HYDU_local_to_global_id(int local_id, int start_pid, int core_count, int global_core_count)
-    return ((local_id / core_count) * global_core_count) + (local_id % core_count) +
-        start_pid;
+    return ((local_id / core_count) * global_core_count) + (local_id % core_count) + start_pid;
More information about the mpich2-commits mailing list
