[mpich2-commits] r5463 - mpich2/trunk/test/mpi/manual
gropp at mcs.anl.gov gropp at mcs.anl.gov
Thu Oct 15 10:29:05 CDT 2009
Author: gropp
Date: 2009-10-15 10:29:05 -0500 (Thu, 15 Oct 2009)
New Revision: 5463
Added:
   mpich2/trunk/test/mpi/manual/spawntest_child.c
   mpich2/trunk/test/mpi/manual/spawntest_master.c
Modified:
   mpich2/trunk/test/mpi/manual/Makefile.sm
   mpich2/trunk/test/mpi/manual/README
Log:
Added a test program for use of MPI_Comm_disconnect, provided by the Parallel R group that thought they had a problem with MPI_Comm_disconnect
Modified: mpich2/trunk/test/mpi/manual/Makefile.sm
--- mpich2/trunk/test/mpi/manual/Makefile.sm	2009-10-14 21:46:13 UTC (rev 5462)
+++ mpich2/trunk/test/mpi/manual/Makefile.sm	2009-10-15 15:29:05 UTC (rev 5463)
@@ -1,11 +1,13 @@
 INCLUDES = -I../include -I${srcdir}/../include
 smvar_do_sharedlibs = 0
-singjoin_SOURCES    = singjoin.c
-testconnect_SOURCES = testconnect.c
+singjoin_SOURCES          = singjoin.c
+testconnect_SOURCES       = testconnect.c
 testconnectserial_SOURCES = testconnectserial.c tchandlers.c tcutil.c
-testconnectserial_LDADD = -lm
-dimsbalanced_SOURCES = dimsbalanced.c
+testconnectserial_LDADD   = -lm
+dimsbalanced_SOURCES      = dimsbalanced.c
+spawntest_master_SOURCES  = spawntest_master.c
+spawntest_child_SOURCES   = spawntest_child.c
 testconnectserial.o: testconnectserial.c
 	$(C_COMPILE) -c -DMPICHLIBSTR=\"$(MPIDIR)\" $<
Modified: mpich2/trunk/test/mpi/manual/README
--- mpich2/trunk/test/mpi/manual/README	2009-10-14 21:46:13 UTC (rev 5462)
+++ mpich2/trunk/test/mpi/manual/README	2009-10-15 15:29:05 UTC (rev 5463)
@@ -18,5 +18,12 @@
                default MPI_Dims_create when there is no underlying
                network topology.
+spawntest_master, spawntest_child - A test of MPI_Comm_disconnect to ensure
+		  that once processes are disconnected, one can proceed
+		  through MPI_Finalize without waiting for the other to
+		  also proceed through MPI_Finalize.  This test is
+		  designed to succeed even if either the child or master
+		  waits for the other in MPI_Finalize.  If MPI_Comm_disconnect
+		  works correctly, the spawned children (4 by default),
+		  should exit roughly 30 seconds before the master.
Added: mpich2/trunk/test/mpi/manual/spawntest_child.c
--- mpich2/trunk/test/mpi/manual/spawntest_child.c	                        (rev 0)
+++ mpich2/trunk/test/mpi/manual/spawntest_child.c	2009-10-15 15:29:05 UTC (rev 5463)
@@ -0,0 +1,42 @@
+#include "mpi.h"
+#include <stdio.h>
+#include <string.h>
+int main(int argc, char **argv)
+  int my_rank;
+  int partner;
+  int size, i,t;
+  char greeting[100];
+  MPI_Comm parentcomm;
+  MPI_Comm allcomm;
+  MPI_Init(&argc, &argv);
+  MPI_Comm_rank(MPI_COMM_WORLD, &my_rank);
+  MPI_Comm_size(MPI_COMM_WORLD, &size);
+  MPI_Comm_get_parent(&parentcomm);
+  if ( parentcomm == MPI_COMM_NULL )
+      fprintf(stdout, "parentcomm is null\n");
+  MPI_Intercomm_merge( parentcomm, 1, &allcomm);
+  /* Without the Free of allcomm, the children *must not exit* until the
+     master calls MPI_Finalize. */
+  MPI_Barrier( allcomm );
+  /* According to 10.5.4, case 1b in MPI2.2, the children and master are
+     still connected unless MPI_Comm_disconnect is used with allcomm.
+     MPI_Comm_free is not sufficient */
+  MPI_Comm_free( &allcomm );
+  MPI_Comm_disconnect( &parentcomm );
+  fprintf(stdout, "%s:%d\n", __FILE__, __LINE__ );fflush(stdout);
+  MPI_Finalize();
+  fprintf(stdout, "%d:child exiting.\n", my_rank );fflush(stdout);
+  return 0;
Added: mpich2/trunk/test/mpi/manual/spawntest_master.c
--- mpich2/trunk/test/mpi/manual/spawntest_master.c	                        (rev 0)
+++ mpich2/trunk/test/mpi/manual/spawntest_master.c	2009-10-15 15:29:05 UTC (rev 5463)
@@ -0,0 +1,51 @@
+#include "mpi.h"
+#include <stdio.h>
+#include <stdlib.h>
+#define NUM_SPAWNS 4
+int main( int argc, char *argv[] )
+  int np = NUM_SPAWNS;
+  int my_rank,i, size, newsize;
+  int errcodes[NUM_SPAWNS];
+  MPI_Comm allcomm;
+  MPI_Comm intercomm;
+  MPI_Init( &argc, &argv );
+  MPI_Comm_spawn( "./spawntest_child", MPI_ARGV_NULL, np, MPI_INFO_NULL, 0,
+		  MPI_COMM_WORLD, &intercomm, errcodes );
+  if ( intercomm == MPI_COMM_NULL )
+      fprintf(stdout, "intercomm is null\n");
+  MPI_Intercomm_merge(intercomm, 0, &allcomm);
+  MPI_Comm_rank(allcomm, &my_rank);
+  MPI_Comm_size(allcomm, &size);
+  MPI_Comm_disconnect( &intercomm );
+  fprintf(stdout, "%s:%d: Sleep starting; children should exit\n",
+	  __FILE__, __LINE__ );fflush(stdout);
+  sleep(30);
+  fprintf(stdout,
+	  "%s:%d: Sleep done; all children should have already exited\n",
+  MPI_Finalize();
+  return 0;
More information about the mpich2-commits mailing list
