[mpich2-commits] r5458 - in mpich2/trunk/src/pm/hydra: include	pm/pmiserv ui/utils utils/alloc
    balaji at mcs.anl.gov
    Wed Oct 14 06:36:00 CDT 2009
Author: balaji
Date: 2009-10-14 06:36:00 -0500 (Wed, 14 Oct 2009)
New Revision: 5458
Modified:
   mpich2/trunk/src/pm/hydra/include/hydra_utils.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
   mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
   mpich2/trunk/src/pm/hydra/utils/alloc/alloc.c
Log:
Unify structure initialization.
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-10-14 11:35:56 UTC (rev 5457)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-10-14 11:36:00 UTC (rev 5458)
@@ -121,6 +121,16 @@
 #endif
+/* alloc */
+void HYDU_init_user_global(struct HYD_User_global *user_global);
+void HYDU_init_global_env(struct HYD_Env_global*global_env);
+HYD_Status HYDU_alloc_proxy(struct HYD_Proxy **proxy);
+HYD_Status HYDU_alloc_exec_info(struct HYD_Exec_info **exec_info);
+void HYDU_free_exec_info_list(struct HYD_Exec_info *exec_info_list);
+void HYDU_free_proxy_list(struct HYD_Proxy *proxy_list);
+HYD_Status HYDU_alloc_proxy_segment(struct HYD_Proxy_segment **segment);
+HYD_Status HYDU_alloc_proxy_exec(struct HYD_Proxy_exec **exec);
 /* args */
 HYD_Status HYDU_find_in_path(const char *execname, char **path);
 char *HYDU_getcwd(void);
@@ -128,20 +138,17 @@
 HYD_Status HYDU_parse_hostfile(char *hostfile,
                                HYD_Status(*process_token) (char *token, int newline));
 /* bind */
 HYD_Status HYDU_bind_init(char *binding, char *bindlib);
 HYD_Status HYDU_bind_process(int core);
 int HYDU_bind_get_core_id(int id);
 /* debug */
 HYD_Status HYDU_dbg_init(const char *str);
 void HYDU_dump_prefix(FILE *fp);
 void HYDU_dump_noprefix(FILE *fp, const char *str, ...);
 void HYDU_dump(FILE *fp, const char *str, ...);
 /* env */
 HYD_Status HYDU_env_to_str(HYD_Env_t * env, char **str);
 HYD_Status HYDU_str_to_env(char *str, HYD_Env_t **env);
@@ -156,7 +163,6 @@
 HYD_Status HYDU_putenv_list(HYD_Env_t * env_list, HYD_Env_overwrite_t overwrite);
 HYD_Status HYDU_comma_list_to_env_list(char *str, HYD_Env_t ** env_list);
 /* launch */
 #if defined HAVE_THREAD_SUPPORT
 struct HYD_Thread_context {
@@ -164,14 +170,6 @@
 #endif /* HAVE_THREAD_SUPPORT */
-HYD_Status HYDU_alloc_proxy(struct HYD_Proxy **proxy);
-void HYDU_free_proxy_list(struct HYD_Proxy *proxy);
-HYD_Status HYDU_alloc_exec_info(struct HYD_Exec_info **exec_info);
-void HYDU_free_exec_info_list(struct HYD_Exec_info *exec_info_list);
-HYD_Status HYDU_alloc_proxy_segment(struct HYD_Proxy_segment **segment);
-HYD_Status HYDU_merge_proxy_segment(char *name, struct HYD_Proxy_segment *segment,
-                                        struct HYD_Proxy **proxy_list);
-HYD_Status HYDU_alloc_proxy_exec(struct HYD_Proxy_exec **exec);
 HYD_Status HYDU_create_process(char **client_arg, HYD_Env_t * env_list,
                                int *in, int *out, int *err, int *pid, int core);
 HYD_Status HYDU_fork_and_exit(int core);
@@ -180,10 +178,13 @@
                               struct HYD_Thread_context *ctxt);
 HYD_Status HYDU_join_thread(struct HYD_Thread_context ctxt);
+/* others */
+HYD_Status HYDU_merge_proxy_segment(char *name, struct HYD_Proxy_segment *segment,
+                                        struct HYD_Proxy **proxy_list);
 int HYDU_local_to_global_id(int local_id, int core_count,
                             struct HYD_Proxy_segment *segment_list, int global_core_count);
 /* signals */
 #ifdef NEEDS_POSIX_FOR_SIGACTION
 #define _POSIX_SOURCE
@@ -202,7 +203,6 @@
 HYD_Status HYDU_set_signal(int signum, void (*handler) (int));
 HYD_Status HYDU_set_common_signals(void (*handler) (int));
 /* Sock utilities */
 enum HYDU_sock_comm_flag {
     HYDU_SOCK_COMM_MSGWAIT = 0x01
@@ -223,7 +223,6 @@
 HYD_Status HYDU_sock_stdin_cb(int fd, HYD_Event_t events, int stdin_fd, char *buf,
                               int *buf_count, int *buf_offset, int *closed);
 /* Memory utilities */
 #include <ctype.h>
@@ -282,7 +281,6 @@
 int HYDU_strlist_lastidx(char **strlist);
 char **HYDU_str_to_strlist(char *str);
 /* Timer utilities */
 /* FIXME: HYD_Time should be OS specific */
 #ifdef HAVE_TIME
@@ -292,11 +290,10 @@
 void HYDU_time_set(HYD_Time * time, int *val);
 int HYDU_time_left(HYD_Time start, HYD_Time timeout);
 /* checkpointing */
 HYD_Status HYDU_ckpoint_init(char *ckpointlib, char *ckpoint_prefix);
 HYD_Status HYDU_ckpoint_suspend(void);
-HYD_Status HYDU_ckpoint_restart(HYD_Env_t *envlist, int num_ranks, int ranks[], int *in, int *out, int *err);
+HYD_Status HYDU_ckpoint_restart(HYD_Env_t *envlist, int num_ranks, int ranks[], int *in,
+                                int *out, int *err);
 #endif /* HYDRA_UTILS_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-14 11:35:56 UTC (rev 5457)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-14 11:36:00 UTC (rev 5458)
@@ -15,38 +15,13 @@
     HYD_Status status = HYD_SUCCESS;
-    HYD_PMCD_pmi_proxy_params.user_global.bootstrap = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.bootstrap_exec = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.launch_mode = HYD_LAUNCH_UNSET;
+    HYDU_init_user_global(&HYD_PMCD_pmi_proxy_params.user_global);
-    HYD_PMCD_pmi_proxy_params.upstream.server_name = NULL;
-    HYD_PMCD_pmi_proxy_params.upstream.server_port = -1;
-    HYD_PMCD_pmi_proxy_params.local.id = -1;
-    HYD_PMCD_pmi_proxy_params.user_global.debug = 0;
-    HYD_PMCD_pmi_proxy_params.user_global.enablex = -1;
-    HYD_PMCD_pmi_proxy_params.user_global.wdir = NULL;
+    HYD_PMCD_pmi_proxy_params.system_global.global_core_count = 0;
     HYD_PMCD_pmi_proxy_params.system_global.pmi_port_str = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.binding = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.bindlib = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.ckpointlib = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.ckpoint_prefix = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.ckpoint_restart = 0;
-    HYD_PMCD_pmi_proxy_params.user_global.global_env.system = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.global_env.user = NULL;
-    HYD_PMCD_pmi_proxy_params.user_global.global_env.inherited = NULL;
-    HYD_PMCD_pmi_proxy_params.system_global.global_core_count = 0;
-    HYD_PMCD_pmi_proxy_params.local.core_count = 0;
-    HYD_PMCD_pmi_proxy_params.local.process_count = 0;
-    HYD_PMCD_pmi_proxy_params.local.procs_are_launched = 0;
-    HYD_PMCD_pmi_proxy_params.segment_list = NULL;
-    HYD_PMCD_pmi_proxy_params.exec_list = NULL;
+    HYD_PMCD_pmi_proxy_params.upstream.server_name = NULL;
+    HYD_PMCD_pmi_proxy_params.upstream.server_port = -1;
     HYD_PMCD_pmi_proxy_params.upstream.out = -1;
     HYD_PMCD_pmi_proxy_params.upstream.err = -1;
     HYD_PMCD_pmi_proxy_params.upstream.in = -1;
@@ -58,10 +33,17 @@
     HYD_PMCD_pmi_proxy_params.downstream.pid = NULL;
     HYD_PMCD_pmi_proxy_params.downstream.exit_status = NULL;
+    HYD_PMCD_pmi_proxy_params.local.id = -1;
+    HYD_PMCD_pmi_proxy_params.local.core_count = 0;
+    HYD_PMCD_pmi_proxy_params.local.process_count = 0;
+    HYD_PMCD_pmi_proxy_params.local.procs_are_launched = 0;
     HYD_PMCD_pmi_proxy_params.local.stdin_buf_offset = 0;
     HYD_PMCD_pmi_proxy_params.local.stdin_buf_count = 0;
     HYD_PMCD_pmi_proxy_params.local.stdin_tmp_buf[0] = '\0';
+    HYD_PMCD_pmi_proxy_params.segment_list = NULL;
+    HYD_PMCD_pmi_proxy_params.exec_list = NULL;
     return status;
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-14 11:35:56 UTC (rev 5457)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-14 11:36:00 UTC (rev 5458)
@@ -10,36 +10,22 @@
 void HYD_UIU_init_params(void)
+    HYDU_init_user_global(&HYD_handle.user_global);
     HYD_handle.base_path = NULL;
     HYD_handle.proxy_port = -1;
-    HYD_handle.user_global.launch_mode = HYD_LAUNCH_UNSET;
-    HYD_handle.user_global.bootstrap = NULL;
     HYD_handle.css = NULL;
     HYD_handle.rmk = NULL;
-    HYD_handle.user_global.binding = NULL;
-    HYD_handle.user_global.bindlib = NULL;
-    HYD_handle.user_global.ckpointlib = NULL;
     HYD_handle.ckpoint_int = -1;
-    HYD_handle.user_global.ckpoint_prefix = NULL;
-    HYD_handle.user_global.ckpoint_restart = 0;
-    HYD_handle.user_global.debug = -1;
     HYD_handle.print_rank_map = -1;
     HYD_handle.print_all_exitcodes = -1;
-    HYD_handle.user_global.enablex = -1;
     HYD_handle.pm_env = -1;
-    HYD_handle.user_global.wdir = NULL;
     HYD_handle.ranks_per_proc = -1;
-    HYD_handle.user_global.bootstrap_exec = NULL;
-    HYD_handle.user_global.global_env.inherited = NULL;
-    HYD_handle.user_global.global_env.system = NULL;
-    HYD_handle.user_global.global_env.user = NULL;
-    HYD_handle.user_global.global_env.prop = NULL;
     HYD_handle.stdin_cb = NULL;
     HYD_handle.stdout_cb = NULL;
     HYD_handle.stderr_cb = NULL;
Modified: mpich2/trunk/src/pm/hydra/utils/alloc/alloc.c
--- mpich2/trunk/src/pm/hydra/utils/alloc/alloc.c	2009-10-14 11:35:56 UTC (rev 5457)
+++ mpich2/trunk/src/pm/hydra/utils/alloc/alloc.c	2009-10-14 11:36:00 UTC (rev 5458)
@@ -6,6 +6,34 @@
 #include "hydra_utils.h"
+    user_global->bootstrap = NULL;
+    user_global->bootstrap_exec = NULL;
+    user_global->binding = NULL;
+    user_global->bindlib = NULL;
+    user_global->ckpointlib = NULL;
+    user_global->ckpoint_prefix = NULL;
+    user_global->ckpoint_restart = 0;
+    user_global->enablex = -1;
+    user_global->debug = -1;
+    user_global->wdir = NULL;
+    user_global->launch_mode = HYD_LAUNCH_UNSET;
+    HYDU_init_global_env(&user_global->global_env);
+void HYDU_init_global_env(struct HYD_Env_global *global_env)
+    global_env->system = NULL;
+    global_env->user = NULL;
+    global_env->inherited = NULL;
+    global_env->prop = NULL;
     static int proxy_id = 0;
More information about the mpich2-commits
