[mpich2-commits] r5445 - in mpich2/trunk/src/pm/hydra/utils/bind: . plpa
balaji at mcs.anl.gov balaji at mcs.anl.gov
Sun Oct 11 15:32:14 CDT 2009
Author: balaji
Date: 2009-10-11 15:32:14 -0500 (Sun, 11 Oct 2009)
New Revision: 5445
Modified:
   mpich2/trunk/src/pm/hydra/utils/bind/bind.c
   mpich2/trunk/src/pm/hydra/utils/bind/bind.h
   mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.c
   mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.h
Log:
Modified the binding code to deal with the querying of all information
inside init, instead of doing it for each call.
Modified: mpich2/trunk/src/pm/hydra/utils/bind/bind.c
--- mpich2/trunk/src/pm/hydra/utils/bind/bind.c	2009-10-11 05:44:30 UTC (rev 5444)
+++ mpich2/trunk/src/pm/hydra/utils/bind/bind.c	2009-10-11 20:32:14 UTC (rev 5445)
@@ -15,35 +15,115 @@
 HYD_Status HYDU_bind_init(char *binding, char *bindlib)
-    char *user_bind_map;
+    char *bindstr, *bindentry;
+    int sock, core, thread, i, j;
     HYD_Status status = HYD_SUCCESS;
     HYDU_FUNC_ENTER();
     HYDU_bind_info.support_level = HYDU_BIND_NONE;
-    HYDU_bind_info.bind_map = NULL;
+    HYDU_bind_info.topology = NULL;
+    HYDU_bind_info.bindlib = HYDU_strdup(bindlib);
-    if (binding)
-        HYDU_bind_info.binding = HYDU_strdup(binding);
-    else
-        HYDU_bind_info.binding = HYDU_strdup("none");
+    if (!binding || !strcmp(binding, "none")) {
+        /* If no binding is given, we just set all mappings to -1 */
+        HYDU_MALLOC(HYDU_bind_info.bindmap, int *, sizeof(int), status);
+        HYDU_bind_info.num_procs = 1;
+        HYDU_bind_info.bindmap[0] = -1;
-    if (!strncmp(HYDU_bind_info.binding, "user:", strlen("user:"))) {
-        user_bind_map = HYDU_bind_info.binding + strlen("user:");
-        HYDU_bind_info.binding[strlen("user")] = '\0';
+        goto fn_exit;
-    else
-        user_bind_map = NULL;
-    HYDU_bind_info.bindlib = bindlib;
+    if (!strncmp(binding, "user:", strlen("user:"))) {
+        /* If the user specified the binding, we don't need to
+         * initialize anything */
+        bindstr = HYDU_strdup(binding + strlen("user:"));
+        /* Find the number of processing elements */
+        HYDU_bind_info.num_procs = 0;
+        bindentry = strtok(bindstr, ",");
+        while (bindentry) {
+            HYDU_bind_info.num_procs++;
+            bindentry = strtok(NULL, ",");
+        /* Find the actual processing elements */
+        HYDU_MALLOC(HYDU_bind_info.bindmap, int *, HYDU_bind_info.num_procs * sizeof(int),
+                    status);
+        i = 0;
+            HYDU_bind_info.bindmap[i++] = atoi(bindentry);
+        goto fn_exit;
+    /* If a real binding is required, we initialize the binding
+     * library requested by the user */
 #if defined HAVE_PLPA
     if (!strcmp(HYDU_bind_info.bindlib, "plpa")) {
-        status = HYDU_bind_plpa_init(user_bind_map, &HYDU_bind_info.support_level);
+        status = HYDU_bind_plpa_init(&HYDU_bind_info.support_level);
         HYDU_ERR_POP(status, "unable to initialize plpa\n");
 #endif /* HAVE_PLPA */
+    if (HYDU_bind_info.support_level != HYDU_BIND_NONE) {
+                    status);
+        for (i = 0; i < HYDU_bind_info.num_procs; i++) {
+            /* RR is supported at the basic binding level */
+            if (!strcmp(binding, "rr")) {
+                HYDU_bind_info.bindmap[i] = i;
+                continue;
+            /* If we reached here, the user requested for topology
+             * aware binding. */
+            if (HYDU_bind_info.support_level != HYDU_BIND_TOPO)
+                HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR,
+                                    "topology binding not supported on this platform\n");
+            if (!strcmp(binding, "buddy")) {
+                thread = i / (HYDU_bind_info.num_sockets * HYDU_bind_info.num_cores);
+                core = i % (HYDU_bind_info.num_sockets * HYDU_bind_info.num_cores);
+                core /= HYDU_bind_info.num_sockets;
+                sock = i % HYDU_bind_info.num_sockets;
+            else if (!strcmp(binding, "pack")) {
+                sock = i / (HYDU_bind_info.num_cores * HYDU_bind_info.num_threads);
+                core = i % (HYDU_bind_info.num_cores * HYDU_bind_info.num_threads);
+                core /= HYDU_bind_info.num_threads;
+                thread = i % HYDU_bind_info.num_threads;
+            else {
+                HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "unknown binding option\n");
+            for (j = 0; j < HYDU_bind_info.num_procs; j++) {
+                if (HYDU_bind_info.topology[j].socket_rank == sock &&
+                    HYDU_bind_info.topology[j].core_rank == core &&
+                    HYDU_bind_info.topology[j].thread_rank == thread) {
+                    HYDU_bind_info.bindmap[i] = HYDU_bind_info.topology[j].processor_id;
+                    break;
+    else {
+        /* If no binding is supported, we just set all mappings to -1 */
   fn_exit:
     HYDU_FUNC_EXIT();
     return status;
@@ -76,69 +156,5 @@
 int HYDU_bind_get_core_id(int id)
-    int sock, core, thread, i, realid;
-    HYD_Status status = HYD_SUCCESS;
-    HYDU_FUNC_ENTER();
-    if (HYDU_bind_info.support_level != HYDU_BIND_NONE) {
-        realid = (id % HYDU_bind_info.num_procs);
-        /* NONE, RR and USER are supported at the basic binding
-         * level */
-        if (!strcmp(HYDU_bind_info.binding, "none")) {
-            return -1;
-        else if (!strcmp(HYDU_bind_info.binding, "rr")) {
-            return HYDU_bind_info.bind_map[realid].processor_id;
-        else if (!strcmp(HYDU_bind_info.binding, "user")) {
-            if (!HYDU_bind_info.user_bind_valid)
-                return -1;
-            else
-                return HYDU_bind_info.user_bind_map[realid];
-        /* If we reached here, the user requested for topology aware
-         * binding. */
-        if (HYDU_bind_info.support_level == HYDU_BIND_TOPO) {
-            if (!strcmp(HYDU_bind_info.binding, "buddy")) {
-                thread = realid / (HYDU_bind_info.num_sockets * HYDU_bind_info.num_cores);
-                core = realid % (HYDU_bind_info.num_sockets * HYDU_bind_info.num_cores);
-                core /= HYDU_bind_info.num_sockets;
-                sock = realid % HYDU_bind_info.num_sockets;
-            else if (!strcmp(HYDU_bind_info.binding, "pack")) {
-                sock = realid / (HYDU_bind_info.num_cores * HYDU_bind_info.num_threads);
-                core = realid % (HYDU_bind_info.num_cores * HYDU_bind_info.num_threads);
-                core /= HYDU_bind_info.num_threads;
-                thread = realid % HYDU_bind_info.num_threads;
-            else {
-                HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "unknown binding option\n");
-            for (i = 0; i < HYDU_bind_info.num_procs; i++) {
-                if (HYDU_bind_info.bind_map[i].socket_rank == sock &&
-                    HYDU_bind_info.bind_map[i].core_rank == core &&
-                    HYDU_bind_info.bind_map[i].thread_rank == thread) {
-                    return HYDU_bind_info.bind_map[i].processor_id;
-        else {
-            HYDU_Error_printf("Topology-aware binding is not supported on this platform\n");
-fn_exit:
-    HYDU_FUNC_EXIT();
-    return -1;
-fn_fail:
-    goto fn_exit;
+    return HYDU_bind_info.bindmap[id % HYDU_bind_info.num_procs];
Modified: mpich2/trunk/src/pm/hydra/utils/bind/bind.h
--- mpich2/trunk/src/pm/hydra/utils/bind/bind.h	2009-10-11 05:44:30 UTC (rev 5444)
+++ mpich2/trunk/src/pm/hydra/utils/bind/bind.h	2009-10-11 20:32:14 UTC (rev 5445)
@@ -15,32 +15,29 @@
     HYDU_BIND_TOPO
 } HYDU_bind_support_level_t;
-typedef struct {
-    int processor_id;
-    int socket_rank;
-    int socket_id;
-    int core_rank;
-    int core_id;
-    int thread_rank;
-    int thread_id;
-} HYDU_bind_map_t;
 struct HYDU_bind_info {
     HYDU_bind_support_level_t support_level;
     int num_procs;
     int num_sockets;
     int num_cores;
     int num_threads;
-    char *binding;
+    int *bindmap;
     char *bindlib;
-    HYDU_bind_map_t *bind_map;
-    int user_bind_valid;
-    int *user_bind_map;
+    struct HYDU_topology {
+        int processor_id;
+        int socket_rank;
+        int socket_id;
+        int core_rank;
+        int core_id;
+        int thread_rank;
+        int thread_id;
+    } *topology;
 extern struct HYDU_bind_info HYDU_bind_info;
Modified: mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.c
--- mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.c	2009-10-11 05:44:30 UTC (rev 5444)
+++ mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.c	2009-10-11 20:32:14 UTC (rev 5445)
@@ -13,7 +13,7 @@
 #include "plpa.h"
 #include "plpa_internal.h"
-HYD_Status HYDU_bind_plpa_init(char *user_bind_map, HYDU_bind_support_level_t *support_level)
+HYD_Status HYDU_bind_plpa_init(HYDU_bind_support_level_t *support_level)
     PLPA_NAME(api_type_t) p;
     int ret, i, j, max, id;
@@ -38,16 +38,16 @@
         goto fn_fail;
-    HYDU_MALLOC(HYDU_bind_info.bind_map, HYDU_bind_map_t *,
-                HYDU_bind_info.num_procs * sizeof(HYDU_bind_map_t), status);
+    HYDU_MALLOC(HYDU_bind_info.topology, struct HYDU_topology *,
+                HYDU_bind_info.num_procs * sizeof(struct HYDU_topology), status);
-        HYDU_bind_info.bind_map[i].processor_id = -1;
-        HYDU_bind_info.bind_map[i].socket_rank = -1;
-        HYDU_bind_info.bind_map[i].socket_id = -1;
-        HYDU_bind_info.bind_map[i].core_rank = -1;
-        HYDU_bind_info.bind_map[i].core_id = -1;
-        HYDU_bind_info.bind_map[i].thread_rank = -1;
-        HYDU_bind_info.bind_map[i].thread_id = -1;
+        HYDU_bind_info.topology[i].processor_id = -1;
+        HYDU_bind_info.topology[i].socket_rank = -1;
+        HYDU_bind_info.topology[i].socket_id = -1;
+        HYDU_bind_info.topology[i].core_rank = -1;
+        HYDU_bind_info.topology[i].core_id = -1;
+        HYDU_bind_info.topology[i].thread_rank = -1;
+        HYDU_bind_info.topology[i].thread_id = -1;
@@ -55,38 +55,16 @@
         if (ret) {
             /* Unable to get processor ID */
             HYDU_Warn_printf("plpa get processor id failed\n");
-            if (HYDU_bind_info.bind_map)
-                HYDU_FREE(HYDU_bind_info.bind_map);
+            if (HYDU_bind_info.topology)
+                HYDU_FREE(HYDU_bind_info.topology);
             goto fn_fail;
-        HYDU_bind_info.bind_map[i].processor_id = processor;
+        HYDU_bind_info.topology[i].processor_id = processor;
     /* We have qualified for basic binding support level */
     *support_level = HYDU_BIND_BASIC;
-    /* If the user is specifying the binding, we just use it */
-    if (user_bind_map) {
-        HYDU_MALLOC(HYDU_bind_info.user_bind_map, int *,
-                    HYDU_bind_info.num_procs * sizeof(int), status);
-            HYDU_bind_info.user_bind_map[i] = -1;
-        HYDU_bind_info.user_bind_valid = 1;
-        i = 0;
-        str = strtok(user_bind_map, ",");
-        do {
-            if (!str || i >= HYDU_bind_info.num_procs)
-                break;
-            HYDU_bind_info.user_bind_map[i++] = atoi(str);
-            str = strtok(NULL, ",");
-        } while (1);
-        /* For user binding, we don't need to get the topology
-         * information */
-        goto fn_exit;
     /* PLPA only gives information about sockets and cores */
     ret = PLPA_NAME(get_socket_info) (&HYDU_bind_info.num_sockets, &max);
     if (ret) {
@@ -107,7 +85,7 @@
     /* Find the socket and core IDs for all processor IDs */
-        ret = PLPA_NAME(map_to_socket_core) (HYDU_bind_info.bind_map[i].processor_id,
+        ret = PLPA_NAME(map_to_socket_core) (HYDU_bind_info.topology[i].processor_id,
                                              &sock, &core);
         if (ret) {
             /* Unable to get number of cores */
@@ -115,18 +93,18 @@
             goto fn_fail;
-        HYDU_bind_info.bind_map[i].socket_id = sock;
-        HYDU_bind_info.bind_map[i].core_id = core;
+        HYDU_bind_info.topology[i].socket_id = sock;
+        HYDU_bind_info.topology[i].core_id = core;
         thread = -1;
         for (j = 0; j < i; j++)
-            if (HYDU_bind_info.bind_map[j].socket_id == sock &&
-                HYDU_bind_info.bind_map[j].core_id == core)
-                thread = HYDU_bind_info.bind_map[j].thread_id;
+            if (HYDU_bind_info.topology[j].socket_id == sock &&
+                HYDU_bind_info.topology[j].core_id == core)
+                thread = HYDU_bind_info.topology[j].thread_id;
         thread++;
-        HYDU_bind_info.bind_map[i].thread_id = thread;
-        HYDU_bind_info.bind_map[i].thread_rank = thread;
+        HYDU_bind_info.topology[i].thread_id = thread;
+        HYDU_bind_info.topology[i].thread_rank = thread;
     /* Find the rank of each socket ID */
@@ -138,21 +116,21 @@
             goto fn_fail;
-            if (HYDU_bind_info.bind_map[j].socket_id == id)
-                HYDU_bind_info.bind_map[j].socket_rank = i;
+            if (HYDU_bind_info.topology[j].socket_id == id)
+                HYDU_bind_info.topology[j].socket_rank = i;
     /* Find the rank of each core ID */
     for (i = 0; i < HYDU_bind_info.num_cores; i++) {
-        ret = PLPA_NAME(get_core_id) (HYDU_bind_info.bind_map[0].socket_id, i, &id);
+        ret = PLPA_NAME(get_core_id) (HYDU_bind_info.topology[0].socket_id, i, &id);
         if (ret) {
             /* Unable to get socket id */
             HYDU_Warn_printf("plpa unable to get socket id\n");
             goto fn_fail;
-            if (HYDU_bind_info.bind_map[j].core_id == id)
-                HYDU_bind_info.bind_map[j].core_rank = i;
+            if (HYDU_bind_info.topology[j].core_id == id)
+                HYDU_bind_info.topology[j].core_rank = i;
     /* We have qualified for topology-aware binding support level */
Modified: mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.h
--- mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.h	2009-10-11 05:44:30 UTC (rev 5444)
+++ mpich2/trunk/src/pm/hydra/utils/bind/plpa/bind_plpa.h	2009-10-11 20:32:14 UTC (rev 5445)
@@ -7,7 +7,7 @@
 #ifndef BIND_PLPA_H_INCLUDED
 #define BIND_PLPA_H_INCLUDED
-HYD_Status HYDU_bind_plpa_init(char *user_bind_map, HYDU_bind_support_level_t *support_level);
+HYD_Status HYDU_bind_plpa_init(HYDU_bind_support_level_t *support_level);
 HYD_Status HYDU_bind_plpa_process(int core);
 #endif /* BIND_PLPA_H_INCLUDED */
More information about the mpich2-commits mailing list
