[mpich2-commits] r5442 - in mpich2/trunk/src/pm/hydra: include pm/pmiserv ui/mpiexec ui/utils utils/launch
balaji at mcs.anl.gov balaji at mcs.anl.gov
Sat Oct 10 20:12:37 CDT 2009
Author: balaji
Date: 2009-10-10 20:12:37 -0500 (Sat, 10 Oct 2009)
New Revision: 5442
Modified:
   mpich2/trunk/src/pm/hydra/include/hydra.h
   mpich2/trunk/src/pm/hydra/include/hydra_base.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
   mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
   mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c
   mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
   mpich2/trunk/src/pm/hydra/ui/utils/uiu.h
   mpich2/trunk/src/pm/hydra/utils/launch/allocate.c
Log:
Redid parts of the environment management code to make it more
manageable, and fixed some random corner case bugs on the way.
Modified: mpich2/trunk/src/pm/hydra/include/hydra.h
--- mpich2/trunk/src/pm/hydra/include/hydra.h	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/include/hydra.h	2009-10-11 01:12:37 UTC (rev 5442)
@@ -40,11 +40,7 @@
     int ranks_per_proc;
     char *bootstrap_exec;
-    /* Global environment */
-    HYD_Env_t *system_env;
-    HYD_Env_t *user_env;
-    HYD_Env_t *inherited_env;
-    HYD_Env_prop_t prop;
+    struct HYD_Env_global global_env;
      HYD_Status(*stdin_cb) (int fd, HYD_Event_t events, void *userp);
      HYD_Status(*stdout_cb) (int fd, HYD_Event_t events, void *userp);
Modified: mpich2/trunk/src/pm/hydra/include/hydra_base.h
--- mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-10-11 01:12:37 UTC (rev 5442)
@@ -134,6 +134,13 @@
     HYD_ENV_PROP_LIST
 } HYD_Env_prop_t;
+struct HYD_Env_global {
+    HYD_Env_t *system;
+    HYD_Env_t *user;
+    HYD_Env_t *inherited;
+    char      *prop;
 /* List of contiguous segments of processes on a partition */
 struct HYD_Partition_segment {
     int start_pid;
@@ -146,8 +153,8 @@
 struct HYD_Partition_exec {
     char *exec[HYD_NUM_TMP_STRINGS];
     int proc_count;
+    char *env_prop;
     int pgid;                   /* All executables with the same PGID belong to the same
                                  * job. */
@@ -221,7 +228,7 @@
     /* Local environment */
+    char *env_prop;
     struct HYD_Exec_info *next;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.h	2009-10-11 01:12:37 UTC (rev 5442)
@@ -35,10 +35,7 @@
     char *ckpoint_prefix;
     int ckpoint_restart;
-    HYD_Env_prop_t genv_prop;
     int global_core_count;
     int partition_core_count;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_utils.c	2009-10-11 01:12:37 UTC (rev 5442)
@@ -34,9 +34,9 @@
     HYD_PMCD_pmi_proxy_params.ckpoint_prefix = NULL;
     HYD_PMCD_pmi_proxy_params.ckpoint_restart = 0;
-    HYD_PMCD_pmi_proxy_params.system_env = NULL;
-    HYD_PMCD_pmi_proxy_params.user_env = NULL;
-    HYD_PMCD_pmi_proxy_params.inherited_env = NULL;
+    HYD_PMCD_pmi_proxy_params.global_env.system = NULL;
+    HYD_PMCD_pmi_proxy_params.global_env.user = NULL;
+    HYD_PMCD_pmi_proxy_params.global_env.inherited = NULL;
     HYD_PMCD_pmi_proxy_params.global_core_count = 0;
     HYD_PMCD_pmi_proxy_params.partition_core_count = 0;
@@ -165,11 +165,14 @@
                 env = HYDU_str_to_env(str);
                 if (!strcmp(argtype, "--global-inherited-env"))
-                    HYDU_append_env_to_list(*env, &HYD_PMCD_pmi_proxy_params.inherited_env);
+                    HYDU_append_env_to_list(*env,
+                                            &HYD_PMCD_pmi_proxy_params.global_env.inherited);
                 else if (!strcmp(argtype, "--global-system-env"))
-                    HYDU_append_env_to_list(*env, &HYD_PMCD_pmi_proxy_params.system_env);
+                                            &HYD_PMCD_pmi_proxy_params.global_env.system);
                 else if (!strcmp(argtype, "--global-user-env"))
-                    HYDU_append_env_to_list(*env, &HYD_PMCD_pmi_proxy_params.user_env);
+                                            &HYD_PMCD_pmi_proxy_params.global_env.user);
                 HYDU_FREE(env);
@@ -179,8 +182,10 @@
         /* Global environment type */
         if (!strcmp(*argv, "--genv-prop")) {
             argv++;
-            HYD_PMCD_pmi_proxy_params.genv_prop =
-                (HYD_Env_prop_t) (unsigned int) atoi(*argv);
+            if (strcmp(*argv, "HYDRA_NULL"))
+                HYD_PMCD_pmi_proxy_params.global_env.prop = HYDU_strdup(*argv);
+            else
+                HYD_PMCD_pmi_proxy_params.global_env.prop = NULL;
             continue;
@@ -272,7 +277,10 @@
         if (!strcmp(*argv, "--exec-env-prop")) {
             argv++;
-            exec->prop = (HYD_Env_prop_t) (unsigned int) atoi(*argv);
+                exec->env_prop = HYDU_strdup(*argv);
+            else
+                exec->env_prop = NULL;
             continue;
@@ -419,14 +427,14 @@
     if (HYD_PMCD_pmi_proxy_params.ckpoint_prefix)
         HYDU_FREE(HYD_PMCD_pmi_proxy_params.ckpoint_prefix);
-    if (HYD_PMCD_pmi_proxy_params.system_env)
-        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.system_env);
+    if (HYD_PMCD_pmi_proxy_params.global_env.system)
+        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.global_env.system);
-    if (HYD_PMCD_pmi_proxy_params.user_env)
-        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.user_env);
+    if (HYD_PMCD_pmi_proxy_params.global_env.user)
+        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.global_env.user);
-    if (HYD_PMCD_pmi_proxy_params.inherited_env)
-        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.inherited_env);
+    if (HYD_PMCD_pmi_proxy_params.global_env.inherited)
+        HYDU_env_free_list(HYD_PMCD_pmi_proxy_params.global_env.inherited);
     if (HYD_PMCD_pmi_proxy_params.segment_list) {
         segment = HYD_PMCD_pmi_proxy_params.segment_list;
@@ -529,7 +537,7 @@
 HYD_Status HYD_PMCD_pmi_proxy_launch_procs(void)
     int i, j, arg, stdin_fd, process_id, core, pmi_id;
-    char *str;
+    char *str, *envstr, *list;
     char *client_args[HYD_NUM_TMP_STRINGS];
     HYD_Env_t *env, *prop_env = NULL;
     struct HYD_Partition_segment *segment;
@@ -605,20 +613,37 @@
          *    - System env
-        /* Global inherited env is set when either genvall or envall
-         * is specified. */
-        if ((exec->prop != HYD_ENV_PROP_NONE) &&
-            ((exec->prop == HYD_ENV_PROP_ALL) ||
-             (exec->prop == HYD_ENV_PROP_UNSET &&
-              HYD_PMCD_pmi_proxy_params.genv_prop == HYD_ENV_PROP_ALL))) {
-            for (env = HYD_PMCD_pmi_proxy_params.inherited_env; env; env = env->next) {
+        /* Global inherited env */
+        if ((exec->env_prop && !strcmp(exec->env_prop, "all")) ||
+            (!exec->env_prop && !strcmp(HYD_PMCD_pmi_proxy_params.global_env.prop, "all"))) {
+            for (env = HYD_PMCD_pmi_proxy_params.global_env.inherited; env; env = env->next) {
                 status = HYDU_append_env_to_list(*env, &prop_env);
                 HYDU_ERR_POP(status, "unable to add env to list\n");
+        else if ((exec->env_prop && !strncmp(exec->env_prop, "list", strlen("list"))) ||
+                  !strncmp(HYD_PMCD_pmi_proxy_params.global_env.prop, "list",
+                           strlen("list")))) {
+            if (exec->env_prop)
+                list = HYDU_strdup(exec->env_prop + strlen("list:"));
+            else
+                list = HYDU_strdup(HYD_PMCD_pmi_proxy_params.global_env.prop + strlen("list:"));
+            envstr = strtok(list, ",");
+            while (envstr) {
+                     env && strcmp(env->env_name, envstr); env = env->next);
+                if (env) {
+                    status = HYDU_append_env_to_list(*env, &prop_env);
+                    HYDU_ERR_POP(status, "unable to add env to list\n");
+                envstr = strtok(NULL, ",");
         /* Next priority order is the global user env */
-        for (env = HYD_PMCD_pmi_proxy_params.user_env; env; env = env->next) {
+        for (env = HYD_PMCD_pmi_proxy_params.global_env.user; env; env = env->next) {
@@ -630,7 +655,7 @@
         /* Highest priority is the system env */
-        for (env = HYD_PMCD_pmi_proxy_params.system_env; env; env = env->next) {
+        for (env = HYD_PMCD_pmi_proxy_params.global_env.system; env; env = env->next) {
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-10-11 01:12:37 UTC (rev 5442)
@@ -209,11 +209,11 @@
     /* Create the arguments list for each proxy */
     process_id = 0;
     FORALL_ACTIVE_PARTITIONS(partition, HYD_handle.partition_list) {
-        for (inherited_env_count = 0, env = HYD_handle.inherited_env; env;
+        for (inherited_env_count = 0, env = HYD_handle.global_env.inherited; env;
              env = env->next, inherited_env_count++);
-        for (user_env_count = 0, env = HYD_handle.user_env; env;
+        for (user_env_count = 0, env = HYD_handle.global_env.user; env;
              env = env->next, user_env_count++);
-        for (system_env_count = 0, env = HYD_handle.system_env; env;
+        for (system_env_count = 0, env = HYD_handle.global_env.system; env;
              env = env->next, system_env_count++);
         for (segment_count = 0, segment = partition->segment_list; segment;
@@ -280,28 +280,31 @@
             partition->base->exec_args[arg++] = HYDU_strdup("--ckpoint-restart");
         partition->base->exec_args[arg++] = HYDU_strdup("--global-inherited-env");
-        for (i = 0, env = HYD_handle.inherited_env; env; env = env->next, i++);
+        for (i = 0, env = HYD_handle.global_env.inherited; env; env = env->next, i++);
         partition->base->exec_args[arg++] = HYDU_int_to_str(i);
         partition->base->exec_args[arg++] = NULL;
-        HYDU_list_append_env_to_str(HYD_handle.inherited_env, partition->base->exec_args);
+        HYDU_list_append_env_to_str(HYD_handle.global_env.inherited,
+                                    partition->base->exec_args);
         arg = HYDU_strlist_lastidx(partition->base->exec_args);
         partition->base->exec_args[arg++] = HYDU_strdup("--global-user-env");
-        for (i = 0, env = HYD_handle.user_env; env; env = env->next, i++);
+        for (i = 0, env = HYD_handle.global_env.user; env; env = env->next, i++);
-        HYDU_list_append_env_to_str(HYD_handle.user_env, partition->base->exec_args);
+        HYDU_list_append_env_to_str(HYD_handle.global_env.user,
         partition->base->exec_args[arg++] = HYDU_strdup("--global-system-env");
-        for (i = 0, env = HYD_handle.system_env; env; env = env->next, i++);
+        for (i = 0, env = HYD_handle.global_env.system; env; env = env->next, i++);
-        HYDU_list_append_env_to_str(HYD_handle.system_env, partition->base->exec_args);
+        HYDU_list_append_env_to_str(HYD_handle.global_env.system,
         partition->base->exec_args[arg++] = HYDU_strdup("--genv-prop");
-        partition->base->exec_args[arg++] = HYDU_int_to_str(HYD_handle.prop);
+        partition->base->exec_args[arg++] = HYDU_strdup(HYD_handle.global_env.prop);
         /* Pass the segment information */
@@ -333,7 +336,8 @@
             partition->base->exec_args[arg++] = HYDU_strdup("--exec-env-prop");
-            partition->base->exec_args[arg++] = HYDU_int_to_str(exec->prop);
+            partition->base->exec_args[arg++] = exec->env_prop ? HYDU_strdup(exec->env_prop) :
+                HYDU_strdup("HYDRA_NULL");
             HYDU_list_append_strlist(exec->exec, partition->base->exec_args);
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/mpiexec.c	2009-10-11 01:12:37 UTC (rev 5442)
@@ -161,10 +161,6 @@
-    /* Consolidate the environment list that we need to propagate */
-    status = HYD_UIU_create_env_list();
-    HYDU_ERR_POP(status, "unable to create env list\n");
     status = HYD_UIU_merge_exec_info_to_partition();
     HYDU_ERR_POP(status, "unable to merge exec info\n");
Modified: mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/ui/mpiexec/utils.c	2009-10-11 01:12:37 UTC (rev 5442)
@@ -63,7 +63,7 @@
     status = HYDU_env_create(&env, env_name, env_value);
     HYDU_ERR_POP(status, "unable to create env struct\n");
-    HYDU_append_env_to_list(*env, &HYD_handle.user_env);
+    HYDU_append_env_to_list(*env, &HYD_handle.global_env.user);
   fn_exit:
     return status;
@@ -74,9 +74,10 @@
 static HYD_Status genvlist_fn(char *arg, char ***argv)
+    int len;
     HYD_Status status = HYD_SUCCESS;
-    HYDU_ERR_CHKANDJUMP(status, HYD_handle.prop != HYD_ENV_PROP_UNSET,
+    HYDU_ERR_CHKANDJUMP(status, HYD_handle.global_env.prop,
                         HYD_INTERNAL_ERROR, "duplicate environment setting\n");
     if (**argv && IS_HELP(**argv)) {
@@ -89,8 +90,9 @@
         HYDU_ERR_SETANDJUMP(status, HYD_GRACEFUL_ABORT, "");
-    HYD_handle.prop = HYD_ENV_PROP_LIST;
-    HYDU_comma_list_to_env_list(**argv, &HYD_handle.user_env);
+    len = strlen("list:") + strlen(**argv) + 1;
+    HYDU_MALLOC(HYD_handle.global_env.prop, char *, len, status);
+    HYDU_snprintf(HYD_handle.global_env.prop, len, "list:%s", **argv);
     (*argv)++;
   fn_exit:
@@ -104,7 +106,7 @@
@@ -114,7 +116,7 @@
-    HYD_handle.prop = HYD_ENV_PROP_NONE;
+    HYD_handle.global_env.prop = HYDU_strdup("none");
   fn_exit:
     return status;
@@ -127,7 +129,7 @@
@@ -137,7 +139,7 @@
-    HYD_handle.prop = HYD_ENV_PROP_ALL;
+    HYD_handle.global_env.prop = HYDU_strdup("all");
   fn_exit:
     return status;
@@ -243,14 +245,15 @@
 static HYD_Status envlist_fn(char *arg, char ***argv)
+    int len;
     struct HYD_Exec_info *exec_info;
     status = HYD_UIU_get_current_exec_info(&exec_info);
     HYDU_ERR_POP(status, "get_current_exec_info returned error\n");
-    HYDU_ERR_CHKANDJUMP(status, exec_info->prop != HYD_ENV_PROP_UNSET,
-                        HYD_INTERNAL_ERROR, "duplicate environment setting\n");
+    HYDU_ERR_CHKANDJUMP(status, exec_info->env_prop, HYD_INTERNAL_ERROR,
+                        "duplicate environment setting\n");
         printf("\n");
@@ -262,8 +265,9 @@
-    exec_info->prop = HYD_ENV_PROP_LIST;
-    HYDU_comma_list_to_env_list(**argv, &exec_info->user_env);
+    HYDU_MALLOC(exec_info->env_prop, char *, len, status);
+    HYDU_snprintf(exec_info->env_prop, len, "list:%s", **argv);
     (*argv)++;
   fn_exit:
@@ -281,8 +285,8 @@
         printf("\n");
@@ -291,7 +295,7 @@
-    exec_info->prop = HYD_ENV_PROP_NONE;
+    exec_info->env_prop = HYDU_strdup("none");
   fn_exit:
     return status;
@@ -308,8 +312,8 @@
         printf("\n");
@@ -318,7 +322,7 @@
-    exec_info->prop = HYD_ENV_PROP_ALL;
+    exec_info->env_prop = HYDU_strdup("all");
   fn_exit:
     return status;
@@ -1008,7 +1012,7 @@
         (HYD_handle.launch_mode == HYD_LAUNCH_SHUTDOWN)) {
         /* No environment */
-        HYDU_ERR_CHKANDJUMP(status, HYD_handle.prop != HYD_ENV_PROP_UNSET, HYD_INTERNAL_ERROR,
+        HYDU_ERR_CHKANDJUMP(status, HYD_handle.global_env.prop, HYD_INTERNAL_ERROR,
                             "env setting not required for booting/shutting proxies\n");
         /* No binding */
@@ -1148,12 +1152,13 @@
     /* Check environment for setting the inherited environment */
     tmp = getenv("HYDRA_ENV");
-    if (HYD_handle.prop == HYD_ENV_PROP_UNSET && tmp)
-        HYD_handle.prop = !strcmp(tmp, "all") ? HYD_ENV_PROP_ALL : HYD_ENV_PROP_NONE;
+    if (HYD_handle.global_env.prop == NULL && tmp)
+            !strcmp(tmp, "all") ? HYDU_strdup("all") : HYDU_strdup("none");
     /* If no global environment is set, use the default */
-    if (HYD_handle.prop == HYD_ENV_PROP_UNSET)
+    if (HYD_handle.global_env.prop == NULL)
   fn_exit:
     return status;
@@ -1174,7 +1179,7 @@
     HYD_UIU_init_params();
-    status = HYDU_list_inherited_env(&HYD_handle.inherited_env);
+    status = HYDU_list_inherited_env(&HYD_handle.global_env.inherited);
     HYDU_ERR_POP(status, "unable to get the inherited env list\n");
     argv++;
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.c
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.c	2009-10-11 01:12:37 UTC (rev 5442)
@@ -37,10 +37,10 @@
     HYD_handle.ranks_per_proc = -1;
     HYD_handle.bootstrap_exec = NULL;
-    HYD_handle.inherited_env = NULL;
-    HYD_handle.system_env = NULL;
-    HYD_handle.user_env = NULL;
-    HYD_handle.prop = HYD_ENV_PROP_UNSET;
+    HYD_handle.global_env.inherited = NULL;
+    HYD_handle.global_env.system = NULL;
+    HYD_handle.global_env.user = NULL;
+    HYD_handle.global_env.prop = NULL;
     HYD_handle.stdin_cb = NULL;
     HYD_handle.stdout_cb = NULL;
@@ -96,15 +96,18 @@
     if (HYD_handle.bootstrap_exec)
         HYDU_FREE(HYD_handle.bootstrap_exec);
-    if (HYD_handle.inherited_env)
-        HYDU_env_free_list(HYD_handle.inherited_env);
+    if (HYD_handle.global_env.inherited)
+        HYDU_env_free_list(HYD_handle.global_env.inherited);
-    if (HYD_handle.system_env)
-        HYDU_env_free_list(HYD_handle.system_env);
+    if (HYD_handle.global_env.system)
+        HYDU_env_free_list(HYD_handle.global_env.system);
-    if (HYD_handle.user_env)
-        HYDU_env_free_list(HYD_handle.user_env);
+    if (HYD_handle.global_env.user)
+        HYDU_env_free_list(HYD_handle.global_env.user);
+    if (HYD_handle.global_env.prop)
+        HYDU_FREE(HYD_handle.global_env.prop);
     if (HYD_handle.exec_info_list)
         HYDU_free_exec_info_list(HYD_handle.exec_info_list);
@@ -116,49 +119,6 @@
-HYD_Status HYD_UIU_create_env_list(void)
-    struct HYD_Exec_info *exec_info;
-    HYD_Env_t *env, *run;
-    HYD_Status status = HYD_SUCCESS;
-    HYDU_FUNC_ENTER();
-    if (HYD_handle.prop == HYD_ENV_PROP_LIST) {
-        for (env = HYD_handle.user_env; env; env = env->next) {
-            run = HYDU_env_lookup(*env, HYD_handle.inherited_env);
-            if (run) {
-                /* Dump back the updated environment to the user list */
-                status = HYDU_append_env_to_list(*run, &HYD_handle.user_env);
-                HYDU_ERR_POP(status, "unable to add env to list\n");
-    exec_info = HYD_handle.exec_info_list;
-    while (exec_info) {
-        if (exec_info->prop == HYD_ENV_PROP_LIST) {
-            for (env = exec_info->user_env; env; env = env->next) {
-                if (run) {
-                    status = HYDU_append_env_to_list(*run, &exec_info->user_env);
-        exec_info = exec_info->next;
-  fn_exit:
-    HYDU_FUNC_EXIT();
-    return status;
-  fn_fail:
-    goto fn_exit;
 HYD_Status HYD_UIU_get_current_exec_info(struct HYD_Exec_info **info)
@@ -205,7 +165,8 @@
         partition->exec_list->exec[i] = NULL;
         partition->exec_list->proc_count = num_procs;
-        partition->exec_list->prop = exec_info->prop;
+        partition->exec_list->env_prop = exec_info->env_prop ?
+            HYDU_strdup(exec_info->env_prop) : NULL;
         partition->exec_list->user_env = HYDU_env_list_dup(exec_info->user_env);
     else {
@@ -221,7 +182,7 @@
         exec->exec[i] = NULL;
         exec->proc_count = num_procs;
-        exec->prop = exec_info->prop;
+        exec->env_prop = exec_info->env_prop ? HYDU_strdup(exec_info->env_prop) : NULL;
         exec->user_env = HYDU_env_list_dup(exec_info->user_env);
@@ -315,22 +276,22 @@
     HYDU_dump(stdout, "\n");
     HYDU_dump(stdout, "  Global environment:\n");
     HYDU_dump(stdout, "  -------------------\n");
-    for (env = HYD_handle.inherited_env; env; env = env->next)
+    for (env = HYD_handle.global_env.inherited; env; env = env->next)
         HYDU_dump(stdout, "    %s=%s\n", env->env_name, env->env_value);
-    if (HYD_handle.system_env) {
+    if (HYD_handle.global_env.system) {
         HYDU_dump(stdout, "  Hydra internal environment:\n");
         HYDU_dump(stdout, "  ---------------------------\n");
-        for (env = HYD_handle.system_env; env; env = env->next)
+        for (env = HYD_handle.global_env.system; env; env = env->next)
-    if (HYD_handle.user_env) {
+    if (HYD_handle.global_env.user) {
         HYDU_dump(stdout, "  User set environment:\n");
         HYDU_dump(stdout, "  ---------------------\n");
+        for (env = HYD_handle.global_env.user; env; env = env->next)
Modified: mpich2/trunk/src/pm/hydra/ui/utils/uiu.h
--- mpich2/trunk/src/pm/hydra/ui/utils/uiu.h	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/ui/utils/uiu.h	2009-10-11 01:12:37 UTC (rev 5442)
@@ -12,7 +12,6 @@
 void HYD_UIU_init_params(void);
 void HYD_UIU_free_params(void);
 HYD_Status HYD_UIU_merge_exec_info_to_partition(void);
-HYD_Status HYD_UIU_create_env_list(void);
 HYD_Status HYD_UIU_get_current_exec_info(struct HYD_Exec_info **info);
 void HYD_UIU_print_params(void);
Modified: mpich2/trunk/src/pm/hydra/utils/launch/allocate.c
--- mpich2/trunk/src/pm/hydra/utils/launch/allocate.c	2009-10-09 21:02:40 UTC (rev 5441)
+++ mpich2/trunk/src/pm/hydra/utils/launch/allocate.c	2009-10-11 01:12:37 UTC (rev 5442)
@@ -83,7 +83,7 @@
     (*exec_info)->exec_proc_count = 0;
     (*exec_info)->exec[0] = NULL;
     (*exec_info)->user_env = NULL;
-    (*exec_info)->prop = HYD_ENV_PROP_UNSET;
+    (*exec_info)->env_prop = NULL;
     (*exec_info)->next = NULL;
   fn_exit:
@@ -106,6 +106,9 @@
         run = exec_info->next;
         HYDU_free_strlist(exec_info->exec);
+        if (exec_info->env_prop)
+            HYDU_FREE(exec_info->env_prop);
         HYDU_env_free_list(exec_info->user_env);
         exec_info->user_env = NULL;
@@ -154,6 +157,8 @@
             HYDU_free_strlist(exec->exec);
             if (exec->user_env)
                 HYDU_env_free(exec->user_env);
+                HYDU_FREE(exec->env_prop);
             HYDU_FREE(exec);
             exec = texec;
@@ -369,7 +374,7 @@
     HYDU_MALLOC(*exec, struct HYD_Partition_exec *, sizeof(struct HYD_Partition_exec), status);
     (*exec)->exec[0] = NULL;
     (*exec)->proc_count = 0;
-    (*exec)->prop = HYD_ENV_PROP_UNSET;
+    (*exec)->env_prop = NULL;
     (*exec)->user_env = NULL;
     (*exec)->next = NULL;
More information about the mpich2-commits mailing list
