[mpich2-commits] r5386 - in mpich2/trunk: src/mpi/comm	test/mpi/spawn
    goodell at mcs.anl.gov
    Thu Oct  1 11:31:56 CDT 2009
Author: goodell
Date: 2009-10-01 11:31:56 -0500 (Thu, 01 Oct 2009)
New Revision: 5386
Modified:
   mpich2/trunk/src/mpi/comm/comm_create.c
   mpich2/trunk/test/mpi/spawn/disconnect_reconnect3.c
Log:
Fix MPI_Comm_create with dynamic procs (ticket #883).
MPI_Comm_create was broken in a few different ways, primarily when using
intracommunicators that contain processes from multiple MPI_COMM_WORLDs.
Thanks to Edric Ellis for reporting this bug and contributing a test
case.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/mpi/comm/comm_create.c
--- mpich2/trunk/src/mpi/comm/comm_create.c	2009-09-30 12:40:52 UTC (rev 5385)
+++ mpich2/trunk/src/mpi/comm/comm_create.c	2009-10-01 16:31:56 UTC (rev 5386)
@@ -42,6 +42,12 @@
 PMPI_LOCAL int MPIR_Comm_create_intra(MPID_Comm *comm_ptr, MPID_Group *group_ptr, MPI_Comm *newcomm);
 PMPI_LOCAL int MPIR_Comm_create_inter(MPID_Comm *comm_ptr, MPID_Group *group_ptr, MPI_Comm *newcomm);
+/* This function allocates and calculates an array (*mapping_out) such that
+ * (*mapping_out)[i] is the rank in (*mapping_vcr_out) corresponding to local
+ * rank i in the given group_ptr.
+ * Ownership of the (*mapping_out) array is transferred to the caller who is
+ * responsible for freeing it. */
 #undef FUNCNAME
 #define FUNCNAME MPIR_Comm_create_calculate_mapping
 #undef FCNAME
@@ -64,19 +70,11 @@
     MPID_MPI_FUNC_ENTER(MPID_STATE_MPIR_COMM_CREATE_CALCULATE_MAPPING);
     *mapping_out = NULL;
+    *mapping_vcr_out = NULL;
     n = group_ptr->size;
     MPIU_CHKPMEM_MALLOC(mapping,int*,n*sizeof(int),mpi_errno,"mapping");
-    if (comm_ptr->comm_kind == MPID_INTERCOMM) {
-        vcr      = comm_ptr->local_vcr;
-        vcr_size = comm_ptr->local_size;
-    else {
-        vcr      = comm_ptr->vcr;
-        vcr_size = comm_ptr->remote_size;
     /* Make sure that the processes for this group are contained within
        the input communicator.  Also identify the mapping from the ranks of
        the old communicator to the new communicator.
@@ -90,12 +88,14 @@
        exactly the same as the ranks in comm world.
+    /* we examine the group's lpids in both the intracomm and non-comm_world cases */
+    MPIR_Group_setup_lpid_list( group_ptr );
     /* Optimize for groups contained within MPI_COMM_WORLD. */
     if (comm_ptr->comm_kind == MPID_INTRACOMM) {
         int wsize;
         subsetOfWorld = 1;
         wsize         = MPIR_Process.comm_world->local_size;
-        MPIR_Group_setup_lpid_list( group_ptr );
         for (i=0; i<n; i++) {
             int g_lpid = group_ptr->lrank_to_lpid[i].lpid;
@@ -116,7 +116,8 @@
     MPIU_DBG_MSG_D(COMM,VERBOSE, "subsetOfWorld=%d", subsetOfWorld );
     if (subsetOfWorld) {
         /* Override the vcr to be used with the mapping array. */
-        *mapping_vcr_out = MPIR_Process.comm_world->vcr;
+        vcr = MPIR_Process.comm_world->vcr;
+        vcr_size = MPIR_Process.comm_world->local_size;
 #           ifdef HAVE_ERROR_CHECKING
             MPID_BEGIN_ERROR_CHECKS;
@@ -130,14 +131,26 @@
 #           endif
     else {
+        /* N.B. For intracomms only the comm_ptr->vcr is valid and populated,
+         * however local_size and remote_size are always set to the same value for
+         * intracomms.  For intercomms both are valid and populated, with the
+         * local_vcr holding VCs corresponding to the local_group, local_comm, and
+         * local_size.
+         * For this mapping calculation we always want the logically local vcr,
+         * regardless of whether it is stored in the "plain" vcr or local_vcr. */
+        if (comm_ptr->comm_kind == MPID_INTERCOMM) {
+            vcr      = comm_ptr->local_vcr;
+            vcr_size = comm_ptr->local_size;
+        else {
+            vcr      = comm_ptr->vcr;
+            vcr_size = comm_ptr->remote_size;
             /* mapping[i] is the rank in the communicator of the process
                that is the ith element of the group */
-            /* We use the appropriate vcr, depending on whether this is
-               an intercomm (use the local vcr) or an intracomm
-               (remote vcr)
-               Note that this is really the local mapping for intercomm
-               and remote mapping for the intracomm */
             /* FIXME : BUBBLE SORT */
             mapping[i] = -1;
             for (j=0; j<vcr_size; j++) {
@@ -153,7 +166,13 @@
-    *mapping_out = mapping;
+    MPIU_Assert(vcr != NULL);
+    MPIU_Assert(mapping != NULL);
+    *mapping_vcr_out = vcr;
+    *mapping_out     = mapping;
+    MPIU_VG_CHECK_MEM_IS_DEFINED(*mapping_vcr_out, vcr_size * sizeof(**mapping_vcr_out));
+    MPIU_VG_CHECK_MEM_IS_DEFINED(*mapping_out, n * sizeof(**mapping_out));
     MPIU_CHKPMEM_COMMIT();
 fn_exit:
     MPID_MPI_FUNC_EXIT(MPID_STATE_MPIR_COMM_CREATE_CALCULATE_MAPPING);
@@ -164,7 +183,7 @@
 /* This function creates a new VCRT and assigns it to out_vcrt, creates a new
- * vcr and assigns it to out_vcr, then and populates it from the mapping_vcr
+ * vcr and assigns it to out_vcr, and then populates it from the mapping_vcr
  * array according to the rank mapping table provided.
  * mapping[i] is the index in the old vcr of index i in the new vcr */
@@ -187,8 +206,8 @@
     vcr = *out_vcr;
         MPIU_DBG_MSG_FMT(COMM,VERBOSE,
-                         (MPIU_DBG_FDEST, "dupping from old_vcr=%p rank=%d into new_rank=%d in new_vcr=%p",
-                          mapping_vcr, mapping[i], i, vcr));
+                         (MPIU_DBG_FDEST, "dupping from mapping_vcr=%p rank=%d into new_rank=%d/%d in new_vcr=%p",
+                          mapping_vcr, mapping[i], i, n, vcr));
         mpi_errno = MPID_VCR_Dup(mapping_vcr[mapping[i]], &vcr[i]);
         if (mpi_errno) MPIU_ERR_POP(mpi_errno);
@@ -233,9 +252,6 @@
     if (group_ptr->rank != MPI_UNDEFINED) {
         MPID_VCR *mapping_vcr = NULL;
-        /* Default choice of mapping vcr */
-        mapping_vcr = comm_ptr->local_vcr;
         mpi_errno = MPIR_Comm_create_calculate_mapping(group_ptr, comm_ptr, &mapping_vcr, &mapping);
@@ -305,8 +321,8 @@
     int *remote_mapping = NULL;
     int remote_size = -1;
     int rinfo[2];
-    MPID_VCR *mapping_vcr = 0;
-    MPID_VCR *remote_mapping_vcr = 0;
+    MPID_VCR *mapping_vcr = NULL;
+    MPID_VCR *remote_mapping_vcr = NULL;
     MPIU_THREADPRIV_DECL;
     MPIU_CHKLMEM_DECL(1);
@@ -334,8 +350,6 @@
     MPIU_Assert(new_context_id != 0);
     MPIU_Assert(new_context_id != comm_ptr->recvcontext_id);
     remote_mapping_vcr = comm_ptr->vcr;
Modified: mpich2/trunk/test/mpi/spawn/disconnect_reconnect3.c
--- mpich2/trunk/test/mpi/spawn/disconnect_reconnect3.c	2009-09-30 12:40:52 UTC (rev 5385)
+++ mpich2/trunk/test/mpi/spawn/disconnect_reconnect3.c	2009-10-01 16:31:56 UTC (rev 5386)
@@ -14,6 +14,7 @@
 #ifdef HAVE_STRING_H
 #include <string.h>
 #endif
+#include <assert.h>
  * This test tests the disconnect code for processes that span process groups.
@@ -32,6 +33,45 @@
 static char MTEST_Descrip[] = "A simple test of Comm_connect/accept/disconnect";
+ * Reverse the order of the ranks in a communicator
+ * Thanks to Edric Ellis for contributing this portion of the test program.
+void checkReverseMergedComm( MPI_Comm comm ) {
+    MPI_Group origGroup;
+    MPI_Group newGroup;
+    MPI_Comm newComm;
+    int buf = 5;
+    int *newGroupRanks = NULL;
+    int ii;
+    int merged_size;
+    assert(comm != MPI_COMM_NULL);
+    /* try a bcast as a weak sanity check that the communicator works */
+    MPI_Bcast(&buf, 1, MPI_INT, 0, comm);
+    MPI_Comm_size(comm, &merged_size);
+    newGroupRanks = calloc(merged_size, sizeof(int));
+    for ( ii = 0; ii < merged_size; ++ii ) {
+        newGroupRanks[ii] = merged_size - ii - 1;
+    MPI_Comm_group( comm, &origGroup );
+    MPI_Group_incl( origGroup, merged_size, newGroupRanks, &newGroup );
+    free( newGroupRanks );
+    MPI_Comm_create( comm, newGroup, &newComm );
+    assert(newComm != MPI_COMM_NULL);
+    MPI_Bcast(&buf, 1, MPI_INT, 0, newComm);
+    MPI_Group_free( &origGroup );
+    MPI_Group_free( &newGroup );
+    MPI_Comm_free( &newComm );
 int main(int argc, char *argv[])
     int errs = 0;
@@ -86,6 +126,8 @@
 	MPI_Intercomm_merge(intercomm, 1, &intracomm);
+    checkReverseMergedComm(intracomm);
     /* We now have a valid intracomm containing all processes */
     MPI_Comm_rank(intracomm, &rank);
More information about the mpich2-commits
