[mpich2-commits] r4229 - in mpich2/trunk/src/pm/hydra: . include pm/pmiserv utils/launch utils/sock
balaji at mcs.anl.gov balaji at mcs.anl.gov
Tue Mar 31 21:12:41 CDT 2009
Author: balaji
Date: 2009-03-31 21:12:40 -0500 (Tue, 31 Mar 2009)
New Revision: 4229
Modified:
   mpich2/trunk/src/pm/hydra/configure.in
   mpich2/trunk/src/pm/hydra/include/hydra_base.h
   mpich2/trunk/src/pm/hydra/include/hydra_utils.h
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_cb.c
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
   mpich2/trunk/src/pm/hydra/utils/launch/launch.c
   mpich2/trunk/src/pm/hydra/utils/sock/sock.c
Log:
We now use threads to connect to different persistent proxies in
parallel and send them relevant executable information.
Modified: mpich2/trunk/src/pm/hydra/configure.in
--- mpich2/trunk/src/pm/hydra/configure.in	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/configure.in	2009-04-01 02:12:40 UTC (rev 4229)
@@ -35,13 +35,15 @@
 CFLAGS=$save_cflags
 dnl Check if the necessary headers are available
-AC_CHECK_HEADERS(unistd.h stdlib.h string.h strings.h stdarg.h sys/types.h sys/socket.h sched.h)
+AC_CHECK_HEADERS(unistd.h stdlib.h string.h strings.h stdarg.h sys/types.h sys/socket.h \
+		 sched.h pthread.h)
 # Check for special types
 AC_TYPE_SIZE_T
 dnl Check for necessary functions
-AC_CHECK_FUNCS(gettimeofday time strdup sigaction signal usleep alloca snprintf unsetenv strerror strsignal)
+AC_CHECK_FUNCS(gettimeofday time strdup sigaction signal usleep alloca snprintf unsetenv \
+	       strerror strsignal)
 dnl Check what we need to do about the environ extern
 AC_CACHE_CHECK([for environ in unistd.h],pac_cv_environ_in_unistd,
Modified: mpich2/trunk/src/pm/hydra/include/hydra_base.h
--- mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/include/hydra_base.h	2009-04-01 02:12:40 UTC (rev 4229)
@@ -57,6 +57,23 @@
 extern char **environ;
 #endif /* MANUAL_EXTERN_ENVIRON */
+/* sockets required headers */
+#include <poll.h>
+#include <fcntl.h>
+#include <netdb.h>
+#include <netinet/in.h>
+#include <netinet/tcp.h>
+#ifdef HAVE_SYS_SOCKET_H
+#include <sys/socket.h>
+#endif
+#if !defined size_t
+#define size_t unsigned int
+#endif /* size_t */
 #define HYD_DEFAULT_PROXY_PORT 9899
 #define HYD_STDOUT  (1)
@@ -132,9 +149,21 @@
     struct HYD_Partition_exec *next;
+#if !defined HAVE_PTHREAD_H
+#error "pthread.h needed"
+#else
+#include <pthread.h>
+#endif
+struct HYD_Thread_context {
+    pthread_t thread;
 /* Partition information */
 struct HYD_Partition {
     char *name;
+    struct sockaddr_in sa;
     char *user_bind_map;
     int total_proc_count;
@@ -167,6 +196,6 @@
     HYD_Env_t *prop_env;
     struct HYD_Exec_info *next;
-} *exec_info;
 #endif /* HYDRA_BASE_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-04-01 02:12:40 UTC (rev 4229)
@@ -171,6 +171,9 @@
 HYD_Status HYDU_create_host_list(char *host_file, struct HYD_Partition **partition_list);
 HYD_Status HYDU_create_process(char **client_arg, HYD_Env_t * env_list,
                                int *in, int *out, int *err, int *pid, int core);
+HYD_Status HYDU_create_thread(void *(func)(void *), void *args,
+                              struct HYD_Thread_context *ctxt);
+HYD_Status HYDU_join_thread(struct HYD_Thread_context ctxt);
 /* signals */
@@ -193,22 +196,10 @@
 /* Sock utilities */
-#include <poll.h>
-#include <fcntl.h>
-#include <netdb.h>
-#include <netinet/in.h>
-#include <netinet/tcp.h>
-#ifdef HAVE_SYS_SOCKET_H
-#include <sys/socket.h>
-#endif
-#if !defined size_t
-#define size_t unsigned int
-#endif /* size_t */
 HYD_Status HYDU_sock_listen(int *listen_fd, char *port_range, uint16_t * port);
-HYD_Status HYDU_sock_connect(const char *host, uint16_t port, int *fd);
+HYD_Status HYDU_sock_gethostbyname(const char *host, struct sockaddr_in *sa, uint16_t port);
+HYD_Status HYDU_sock_connect(struct sockaddr_in sa, int *fd);
+HYD_Status HYDU_sock_tryconnect(struct sockaddr_in sa, int *fd);
 HYD_Status HYDU_sock_accept(int listen_fd, int *fd);
 HYD_Status HYDU_sock_readline(int fd, char *buf, int maxlen, int *linelen);
 HYD_Status HYDU_sock_read(int fd, void *buf, int maxlen, int *count);
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy_cb.c	2009-04-01 02:12:40 UTC (rev 4229)
@@ -115,6 +115,8 @@
         for (i = 0; i < HYD_PMCD_pmi_proxy_params.exec_proc_count; i++)
             if (HYD_PMCD_pmi_proxy_params.out[i] == fd)
                 HYD_PMCD_pmi_proxy_params.out[i] = -1;
+        close(fd);
   fn_exit:
@@ -145,6 +147,8 @@
             if (HYD_PMCD_pmi_proxy_params.err[i] == fd)
                 HYD_PMCD_pmi_proxy_params.err[i] = -1;
+        close(fd);
   fn_exit:
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_cb.c	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_cb.c	2009-04-01 02:12:40 UTC (rev 4229)
@@ -179,7 +179,9 @@
      * bunch of processes to do this. */
     /* Connect to all proxies and send a KILL command */
     for (partition = handle.partition_list; partition; partition = partition->next) {
-        status = HYDU_sock_connect(partition->name, handle.proxy_port, &fd);
+        /* We only "try" to connect here, since the proxy might have
+         * already exited and the connect might fail. */
+        status = HYDU_sock_tryconnect(partition->sa, &fd);
         if (status != HYD_SUCCESS) {
             HYDU_Warn_printf("unable to connect to the proxy on %s\n", partition->name);
             overall_status = HYD_INTERNAL_ERROR;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c	2009-04-01 02:12:40 UTC (rev 4229)
@@ -15,6 +15,102 @@
 int HYD_PMCD_pmi_serv_listenfd;
 HYD_Handle handle;
+static void launch_helper(void *args)
+    struct HYD_Partition *partition = (struct HYD_Partition *) args;
+    int first_partition = (partition == handle.partition_list);
+    enum HYD_PMCD_pmi_proxy_cmds cmd;
+    int i, list_len, arg_len;
+    HYD_Status status = HYD_SUCCESS;
+     * Here are the steps we will follow:
+     * 1. Put all the arguments to pass in to a string list.
+     * 2. Connect to the proxy (this will be our primary control
+     *    socket).
+     * 3. Read this string list and write the following to the socket:
+     *    (a) The PROC_INFO command.
+     *    (b) Integer sized data with the number of arguments to
+     *        follow.
+     *    (c) For each argument to pass, first send an integer which
+     *        tells the proxy how many bytes are coming in that
+     *        argument.
+     * 4. Open two new sockets and connect them to the proxy.
+     * 5. On the first new socket, send USE_AS_STDOUT and the second
+     *    send USE_AS_STDERR.
+     * 6. For PMI_ID "0", open a separate socket and send the
+     *    USE_AS_STDIN command on it.
+     * 7. We need to figure out what to do with the LAUNCH_JOB
+     *    command; since it's going on a different socket, it might go
+     *    out-of-order. Maybe a state machine on the proxy to see if
+     *    it got all the information it needs to launch the job would
+     *    work.
+    status = HYDU_sock_connect(partition->sa, &partition->control_fd);
+    HYDU_ERR_POP(status, "unable to connect to proxy\n");
+    cmd = PROC_INFO;
+    status = HYDU_sock_write(partition->control_fd, &cmd,
+                             sizeof(enum HYD_PMCD_pmi_proxy_cmds));
+    HYDU_ERR_POP(status, "unable to write data to proxy\n");
+    /* Check how many arguments we have */
+    list_len = HYDU_strlist_lastidx(partition->proxy_args);
+    status = HYDU_sock_write(partition->control_fd, &list_len, sizeof(int));
+    /* Convert the string list to parseable data and send */
+    for (i = 0; partition->proxy_args[i]; i++) {
+        arg_len = strlen(partition->proxy_args[i]) + 1;
+        status = HYDU_sock_write(partition->control_fd, &arg_len, sizeof(int));
+        status = HYDU_sock_write(partition->control_fd, partition->proxy_args[i], arg_len);
+    /* Create an stdout socket */
+    status = HYDU_sock_connect(partition->sa, &partition->out);
+    cmd = USE_AS_STDOUT;
+    status = HYDU_sock_write(partition->out, &cmd, sizeof(enum HYD_PMCD_pmi_proxy_cmds));
+    /* Create an stderr socket */
+    status = HYDU_sock_connect(partition->sa, &partition->err);
+    cmd = USE_AS_STDERR;
+    status = HYDU_sock_write(partition->err, &cmd, sizeof(enum HYD_PMCD_pmi_proxy_cmds));
+    /* If rank 0 is here, create an stdin socket */
+    if (first_partition) {
+        status = HYDU_sock_connect(partition->sa, &handle.in);
+        cmd = USE_AS_STDIN;
+        status = HYDU_sock_write(handle.in, &cmd, sizeof(enum HYD_PMCD_pmi_proxy_cmds));
+  fn_exit:
+    return;
+  fn_fail:
+    goto fn_exit;
 static HYD_Status fill_in_proxy_args(void)
     int i, arg, process_id;
@@ -198,7 +294,7 @@
+        status = HYDU_sock_connect(partition->sa, &fd);
         cmd = PROXY_SHUTDOWN;
@@ -218,41 +314,10 @@
 static HYD_Status launch_procs_in_persistent_mode(void)
     struct HYD_Partition *partition;
-    enum HYD_PMCD_pmi_proxy_cmds cmd;
-    int i, list_len, arg_len, first_partition;
+    int len, id;
+    struct HYD_Thread_context *thread_context;
-     * Here are the steps we will follow:
-     * 1. Put all the arguments to pass in to a string list.
-     * 2. Connect to the proxy (this will be our primary control
-     *    socket).
-     * 3. Read this string list and write the following to the socket:
-     *    (a) The PROC_INFO command.
-     *    (b) Integer sized data with the number of arguments to
-     *        follow.
-     *    (c) For each argument to pass, first send an integer which
-     *        tells the proxy how many bytes are coming in that
-     *        argument.
-     * 4. Open two new sockets and connect them to the proxy.
-     * 5. On the first new socket, send USE_AS_STDOUT and the second
-     *    send USE_AS_STDERR.
-     * 6. For PMI_ID "0", open a separate socket and send the
-     *    USE_AS_STDIN command on it.
-     * 7. We need to figure out what to do with the LAUNCH_JOB
-     *    command; since it's going on a different socket, it might go
-     *    out-of-order. Maybe a state machine on the proxy to see if
-     *    it got all the information it needs to launch the job would
-     *    work.
     status = fill_in_proxy_args();
     HYDU_ERR_POP(status, "unable to fill in proxy arguments\n");
@@ -262,65 +327,31 @@
     status = HYD_BSCI_init(handle.bootstrap);
     HYDU_ERR_POP(status, "bootstrap server initialization failed\n");
-    first_partition = 1;
+    len = 0;
     for (partition = handle.partition_list; partition && partition->exec_list;
-         partition = partition->next) {
+         partition = partition->next)
+        len++;
-        status = HYDU_sock_connect(partition->name, handle.proxy_port, &partition->control_fd);
-        HYDU_ERR_POP(status, "unable to connect to proxy\n");
+    HYDU_MALLOC(thread_context, struct HYD_Thread_context *,
+                len * sizeof(struct HYD_Thread_context), status);
-        cmd = PROC_INFO;
-        status = HYDU_sock_write(partition->control_fd, &cmd,
-                                 sizeof(enum HYD_PMCD_pmi_proxy_cmds));
-        HYDU_ERR_POP(status, "unable to write data to proxy\n");
+    id = 0;
+    for (partition = handle.partition_list; partition && partition->exec_list;
+         partition = partition->next) {
+        HYDU_create_thread(launch_helper, (void *) partition, &thread_context[id]);
+        id++;
-        /* Check how many arguments we have */
-        list_len = HYDU_strlist_lastidx(partition->proxy_args);
-        status = HYDU_sock_write(partition->control_fd, &list_len, sizeof(int));
+    id = 0;
+        HYDU_join_thread(thread_context[id]);
-        /* Convert the string list to parseable data and send */
-        for (i = 0; partition->proxy_args[i]; i++) {
-            arg_len = strlen(partition->proxy_args[i]) + 1;
-            status = HYDU_sock_write(partition->control_fd, &arg_len, sizeof(int));
-            status = HYDU_sock_write(partition->control_fd, partition->proxy_args[i], arg_len);
-        /* Register the control socket with the demux engine */
         status = HYD_DMX_register_fd(1, &partition->control_fd, HYD_STDOUT, partition,
                                      HYD_PMCD_pmi_serv_control_cb);
+        HYDU_ERR_POP(status, "unable to register control fd\n");
-        /* Create an stdout socket */
-        status = HYDU_sock_connect(partition->name, handle.proxy_port, &partition->out);
-        cmd = USE_AS_STDOUT;
-        status = HYDU_sock_write(partition->out, &cmd, sizeof(enum HYD_PMCD_pmi_proxy_cmds));
-        /* Create an stderr socket */
-        status = HYDU_sock_connect(partition->name, handle.proxy_port, &partition->err);
-        cmd = USE_AS_STDERR;
-        status = HYDU_sock_write(partition->err, &cmd, sizeof(enum HYD_PMCD_pmi_proxy_cmds));
-        /* If rank 0 is here, create an stdin socket */
-        if (first_partition) {
-            status = HYDU_sock_connect(partition->name, handle.proxy_port, &handle.in);
-            cmd = USE_AS_STDIN;
-            status = HYDU_sock_write(handle.in, &cmd, sizeof(enum HYD_PMCD_pmi_proxy_cmds));
-            first_partition = 0;
+        id++;
   fn_exit:
@@ -330,6 +361,7 @@
     goto fn_exit;
  * HYD_PMCI_launch_procs: Here are the steps we follow:
@@ -355,6 +387,7 @@
     uint16_t port;
     char hostname[MAX_HOSTNAME_LEN];
     HYD_Env_t *env;
+    struct HYD_Partition *partition;
     HYDU_FUNC_ENTER();
@@ -406,6 +439,13 @@
     status = HYD_PMCD_pmi_create_pg();
     HYDU_ERR_POP(status, "unable to create process group\n");
+    /* For each partition, get the appropriate sockaddr to connect to */
+    for (partition = handle.partition_list; partition; partition = partition->next) {
+        status = HYDU_sock_gethostbyname(partition->name, &partition->sa,
+                                         handle.proxy_port);
+        HYDU_ERR_POP(status, "unable to get sockaddr information\n");
     if (handle.launch_mode == HYD_LAUNCH_RUNTIME) {
         status = launch_procs_in_runtime_mode();
         HYDU_ERR_POP(status, "error launching procs in runtime mode\n");
Modified: mpich2/trunk/src/pm/hydra/utils/launch/launch.c
--- mpich2/trunk/src/pm/hydra/utils/launch/launch.c	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/utils/launch/launch.c	2009-04-01 02:12:40 UTC (rev 4229)
@@ -82,3 +82,46 @@
   fn_fail:
     goto fn_exit;
+    int ret;
+    HYDU_FUNC_ENTER();
+    ret = pthread_create(&ctxt->thread, NULL, func, args);
+    if (ret < 0)
+        HYDU_ERR_SETANDJUMP1(status, HYD_INTERNAL_ERROR, "pthread create failed (%s)\n",
+                             HYDU_strerror(errno));
+  fn_exit:
+    HYDU_FUNC_EXIT();
+    return status;
+  fn_fail:
+    goto fn_exit;
+    int ret;
+    ret = pthread_join(ctxt.thread, NULL);
+    if (ret < 0)
+        HYDU_ERR_SETANDJUMP1(status, HYD_INTERNAL_ERROR, "pthread join failed (%s)\n",
+  fn_exit:
+    HYDU_FUNC_EXIT();
+    return status;
+  fn_fail:
+    goto fn_exit;
Modified: mpich2/trunk/src/pm/hydra/utils/sock/sock.c
--- mpich2/trunk/src/pm/hydra/utils/sock/sock.c	2009-03-31 17:56:21 UTC (rev 4228)
+++ mpich2/trunk/src/pm/hydra/utils/sock/sock.c	2009-04-01 02:12:40 UTC (rev 4229)
@@ -105,25 +105,39 @@
-    struct sockaddr_in sa;
     struct hostent *ht;
     HYDU_FUNC_ENTER();
-    memset((char *) &sa, 0, sizeof(sa));
-    sa.sin_family = AF_INET;
-    sa.sin_port = htons(port);
+    memset((char *) sa, 0, sizeof(struct sockaddr_in));
+    (*sa).sin_family = AF_INET;
+    (*sa).sin_port = htons(port);
     /* Get the remote host's IP address */
     ht = gethostbyname(host);
     if (ht == NULL)
         HYDU_ERR_SETANDJUMP1(status, HYD_INVALID_PARAM,
                              "unable to get host address (%s)\n", HYDU_strerror(errno));
-    memcpy(&sa.sin_addr, ht->h_addr_list[0], ht->h_length);
+    memcpy(&sa->sin_addr, ht->h_addr_list[0], ht->h_length);
+  fn_exit:
+    HYDU_FUNC_EXIT();
+    return status;
+  fn_fail:
+    goto fn_exit;
     /* Create a socket and set the required options */
     *fd = socket(AF_INET, SOCK_STREAM, 0);
     if (*fd < 0)
@@ -148,6 +162,36 @@
+    /* Create a socket and set the required options */
+    *fd = socket(AF_INET, SOCK_STREAM, 0);
+    if (*fd < 0)
+        HYDU_ERR_SETANDJUMP1(status, HYD_SOCK_ERROR, "cannot open socket (%s)\n",
+    /* Not being able to connect is not an error in all cases. So we
+     * return an error, but only print a warning message. The upper
+     * layer can decide what to do with the return status. */
+    if (connect(*fd, (struct sockaddr *) &sa, sizeof(sa)) < 0) {
+        HYDU_Warn_printf("connect error (%s)\n", HYDU_strerror(errno));
+        status = HYD_SOCK_ERROR;
+        goto fn_fail;
+  fn_exit:
+    HYDU_FUNC_EXIT();
+    return status;
+  fn_fail:
+    goto fn_exit;
More information about the mpich2-commits mailing list
