[mpich2-commits] r4225 - mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad
mercierg at mcs.anl.gov mercierg at mcs.anl.gov
Mon Mar 30 10:37:41 CDT 2009
Author: mercierg
Date: 2009-03-30 10:37:41 -0500 (Mon, 30 Mar 2009)
New Revision: 4225
Modified:
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_finalize.c
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_poll.c
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c
Log:
switch to events-based iface for recv + bug fixes
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_finalize.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_finalize.c	2009-03-30 07:00:07 UTC (rev 4224)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_finalize.c	2009-03-30 15:37:41 UTC (rev 4225)
@@ -16,6 +16,8 @@
     int mpi_errno = MPI_SUCCESS;
+    common_exit(NULL);
    fn_exit:
      return mpi_errno;
    fn_fail:  ATTRIBUTE((unused))
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h	2009-03-30 07:00:07 UTC (rev 4224)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h	2009-03-30 15:37:41 UTC (rev 4225)
@@ -54,8 +54,10 @@
 /* Callbacks for events */
 void MPID_nem_newmad_get_adi_msg(nm_sr_event_t event, const nm_sr_event_info_t*info);
+void MPID_nem_newmad_get_rreq(nm_sr_event_t event, const nm_sr_event_info_t*info);
 void MPID_nem_newmad_handle_sreq(nm_sr_event_t event, const nm_sr_event_info_t*info);
 /* Dtype management */
 int MPID_nem_newmad_process_sdtype(MPID_Request **sreq_p,  MPI_Datatype datatype,  MPID_Datatype * dt_ptr, const void *buf,
 				   int count, MPIDI_msg_sz_t data_sz, struct iovec **newmad_iov, int  *num_iov, int first_taken);
@@ -65,14 +67,14 @@
 /* Connection management*/
 int MPID_nem_newmad_send_conn_info (MPIDI_VC_t *vc);
-#define MPID_NEM_NMAD_MAX_NETS 3
-#define MY_SIZE (MPID_NEM_MAX_NETMOD_STRING_LEN/2)
+#define MPID_NEM_NMAD_MAX_NETS 4
+#define MPID_NEM_NMAD_MAX_SIZE MPID_NEM_MAX_NETMOD_STRING_LEN
 typedef nm_gate_t mpid_nem_newmad_p_gate_t;
 typedef struct MPID_nem_newmad_vc_area_internal
-    char                     hostname[MY_SIZE];
-    char                     url[MPID_NEM_NMAD_MAX_NETS][MY_SIZE];
+    char                     hostname[MPID_NEM_NMAD_MAX_SIZE];
+    char                     url[MPID_NEM_NMAD_MAX_NETS][MPID_NEM_NMAD_MAX_SIZE];
     uint8_t                  drv_id[MPID_NEM_NMAD_MAX_NETS];
     mpid_nem_newmad_p_gate_t p_gate;
 } MPID_nem_newmad_vc_area_internal_t;
@@ -91,6 +93,7 @@
 typedef struct
     nm_sr_request_t newmad_req;
+    void           *iov;
 } MPID_nem_newmad_req_area;
 /* accessor macro to private fields in REQ */
 #define REQ_FIELD(reqp, field) (((MPID_nem_newmad_req_area *)((reqp)->ch.netmod_area.padding))->field)
@@ -168,6 +171,7 @@
 extern int        mpid_nem_newmad_pending_send_req;
 #define NMAD_IOV_MAX_DEPTH 15 /* NM_SO_PREALLOC_IOV_LEN */
+//#define DEBUG
 #endif //NEWMAD_MODULE_IMPL_H
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c	2009-03-30 07:00:07 UTC (rev 4224)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c	2009-03-30 15:37:41 UTC (rev 4225)
@@ -49,7 +49,7 @@
 static int         mpid_nem_newmad_myrank;
 static nm_drv_id_t drv_id[MPID_NEM_NMAD_MAX_NETS];
 static char       *url[MPID_NEM_NMAD_MAX_NETS];
-static char        url_keys[MPID_NEM_NMAD_MAX_NETS][MPID_NEM_MAX_NETMOD_STRING_LEN] = {"url_id0","url_id1","url_id2","url_id3"};
+static char        url_keys[MPID_NEM_NMAD_MAX_NETS][MPID_NEM_NMAD_MAX_SIZE] = {"url_id0","url_id1","url_id2","url_id3"};
 static int         mpid_nem_newmad_num_rails = 1 ;
 nm_core_t          mpid_nem_newmad_pcore;
 int                mpid_nem_newmad_pending_send_req = 0;
@@ -170,7 +170,7 @@
 	strcpy(url[0],hostname);
 #endif /* !MULTIRAIL  */
-#endif /* TCP */
+#endif /* TCP */
 #endif
     nm_ns_init(mpid_nem_newmad_pcore);
@@ -221,7 +221,7 @@
    fprintf(stdout,"Size of MPID_nem_mad_module_vc_area_internal_t : %i | size of nm_sr_request_t :%i | Size of req_area : %i\n",
          sizeof(MPID_nem_newmad_vc_area_internal_t),sizeof(nm_sr_request_t), sizeof(MPID_nem_newmad_req_area));
-   MPIU_Assert( sizeof(MPID_nem_newmad_vc_area_internal_t) <= MPID_NEM_VC_NETMOD_AREA_LEN);
+   //MPIU_Assert( sizeof(MPID_nem_newmad_vc_area_internal_t) <= MPID_NEM_VC_NETMOD_AREA_LEN);
    MPIU_Assert( sizeof(MPID_nem_newmad_req_area) <= MPID_NEM_REQ_NETMOD_AREA_LEN);
    mpid_nem_newmad_myrank = pg_rank;
@@ -236,7 +236,8 @@
    mpi_errno = MPID_nem_newmad_get_business_card(pg_rank,bc_val_p, val_max_sz_p);
    if (mpi_errno) MPIU_ERR_POP (mpi_errno);
-   nm_sr_monitor(mpid_nem_newmad_pcore, NM_SR_EVENT_RECV_UNEXPECTED, &MPID_nem_newmad_get_adi_msg);
+   nm_sr_monitor(mpid_nem_newmad_pcore, NM_SR_EVENT_RECV_UNEXPECTED,&MPID_nem_newmad_get_adi_msg);
+   nm_sr_monitor(mpid_nem_newmad_pcore, NM_SR_EVENT_RECV_COMPLETED, &MPID_nem_newmad_get_rreq);
    nm_sr_monitor(mpid_nem_newmad_pcore, NM_SR_EVENT_SEND_COMPLETED, &MPID_nem_newmad_handle_sreq);
    mpi_errno = MPIDI_CH3I_Register_anysource_notification(MPID_nem_newmad_anysource_posted,
@@ -257,10 +258,10 @@
 MPID_nem_newmad_get_business_card (int my_rank, char **bc_val_p, int *val_max_sz_p)
-   char name[MPID_NEM_MAX_NETMOD_STRING_LEN];
+   char name[MPID_NEM_NMAD_MAX_SIZE];
    int index;
-   gethostname(name,MPID_NEM_MAX_NETMOD_STRING_LEN);
+   gethostname(name,MPID_NEM_NMAD_MAX_SIZE);
    mpi_errno = MPIU_Str_add_binary_arg (bc_val_p, val_max_sz_p, MPIDI_CH3I_HOSTNAME_KEY, name, strlen(name));
    if (mpi_errno != MPIU_STR_SUCCESS){
@@ -288,7 +289,7 @@
    fn_exit:
        return mpi_errno;
-   fn_fail:
+   fn_fail: ATTRIBUTE((unused))
        goto fn_exit;
@@ -303,13 +304,13 @@
    int len;
    mpi_errno = MPIU_Str_get_binary_arg (business_card, MPIDI_CH3I_HOSTNAME_KEY, hostname,
-					MPID_NEM_MAX_NETMOD_STRING_LEN, &len);
+					MPID_NEM_NMAD_MAX_SIZE, &len);
    if ((mpi_errno != MPIU_STR_SUCCESS)){
        MPIU_ERR_SETANDJUMP(mpi_errno,MPI_ERR_OTHER, "**argstr_hostd");
    mpi_errno = MPIU_Str_get_binary_arg (business_card, url_keys[index], url,
@@ -328,10 +329,10 @@
 MPID_nem_newmad_connect_to_root (const char *business_card, MPIDI_VC_t *new_vc)
-   fn_exit:
-       return mpi_errno;
-   fn_fail:
-       goto fn_exit;
+ fn_exit:
+    return mpi_errno;
+    goto fn_exit;
 #undef FUNCNAME
@@ -342,12 +343,12 @@
 MPID_nem_newmad_vc_init (MPIDI_VC_t *vc)
     MPIDI_CH3I_VC           *vc_ch = (MPIDI_CH3I_VC *)vc->channel_private;
-    char                     business_card[MPID_NEM_MAX_NETMOD_STRING_LEN];
+    char                     business_card[MPID_NEM_NMAD_MAX_SIZE];
     int                      ret;
     int                      index;
-    mpi_errno = vc->pg->getConnInfo(vc->pg_rank, business_card, MPID_NEM_MAX_NETMOD_STRING_LEN, vc->pg);
+    mpi_errno = vc->pg->getConnInfo(vc->pg_rank, business_card, MPID_NEM_NMAD_MAX_SIZE, vc->pg);
     if (mpi_errno) MPIU_ERR_POP(mpi_errno);
     (((MPID_nem_newmad_vc_area *)((MPIDI_CH3I_VC *)(vc)->channel_private)->netmod_area.padding)->area) =
@@ -400,7 +401,7 @@
  fn_exit:
        return mpi_errno;
- fn_fail:
        goto fn_exit;
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_poll.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_poll.c	2009-03-30 07:00:07 UTC (rev 4224)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_poll.c	2009-03-30 15:37:41 UTC (rev 4225)
@@ -37,8 +37,13 @@
 void
-    nm_tag_t match_info = info->recv_unexpected.tag;
+    nm_tag_t          match_info = info->recv_unexpected.tag;
     MPIR_Context_id_t ctxt;
+#ifdef DEBUG
+    fprintf(stdout,"===> Getting ADI MSG match is %lx \n",match_info);
+#endif
     NEM_NMAD_MATCH_GET_CTXT(match_info, ctxt);
     if(ctxt == NEM_NMAD_INTRA_CTXT)
@@ -69,6 +74,7 @@
     return;
 #undef FUNCNAME
 #define FUNCNAME MPID_nem_newmad_directRecv
 #undef FCNAME
@@ -86,12 +92,10 @@
 	MPIR_Context_id_t context    = rreq->dev.match.parts.context_id;
 	Nmad_Nem_tag_t    tag        = rreq->dev.match.parts.tag;
 	int               ret;
-	int               num_seg = 1;
 	MPIDI_msg_sz_t    data_sz;
 	int               dt_contig;
 	MPI_Aint          dt_true_lb;
 	MPID_Datatype    *dt_ptr;
-	struct iovec      newmad_iov[NMAD_IOV_MAX_DEPTH];
 	NEM_NMAD_DIRECT_MATCH(match_info,0,source,context);
 	if (tag != MPI_ANY_TAG)
@@ -102,25 +106,41 @@
 	    MPIU_Assert(0);
+#ifdef DEBUG
+	fprintf(stdout,"========> Posting Recv req  %p (match is %lx) \n",rreq,match_info);
+#endif
 	MPIDI_Datatype_get_info(rreq->dev.user_count,rreq->dev.datatype, dt_contig, data_sz, dt_ptr,dt_true_lb);
 	rreq->dev.OnDataAvail = NULL;
 	if (dt_contig)
-            newmad_iov[0].iov_base = (char*)(rreq->dev.user_buf) + dt_true_lb;
-            newmad_iov[0].iov_len  = data_sz;
+	    ret = nm_sr_irecv_with_ref(mpid_nem_newmad_pcore,VC_FIELD(vc,p_gate),match_info,
+				       (char*)(rreq->dev.user_buf) + dt_true_lb,data_sz,
+				       &(REQ_FIELD(rreq,newmad_req)),(void*)rreq);
 	else
-	    struct iovec *newmad_iov_ptr = &(newmad_iov[0]);
+	    int           num_seg = 0;
+	    struct iovec *newmad_iov_ptr = NULL;
+	    struct iovec *newmad_iov = (struct iovec *)MPIU_Malloc(NMAD_IOV_MAX_DEPTH*sizeof(struct iovec));
+	    newmad_iov_ptr = &(newmad_iov[0]);
 	    MPID_nem_newmad_process_rdtype(&rreq,dt_ptr,data_sz,&newmad_iov_ptr,&num_seg);
+	    MPIU_Assert(num_seg <= NMAD_IOV_MAX_DEPTH);
+#ifdef DEBUG
+		int index;
+		for(index = 0; index < num_seg ; index++)
+			fprintf(stdout,"======================\n");
+			fprintf(stdout,"RECV nmad_iov[%i]: [base %p][len %i]\n",index,
+				newmad_iov[index].iov_base,newmad_iov[index].iov_len);
+#endif
+	    ret = nm_sr_irecv_iov_with_ref(mpid_nem_newmad_pcore,VC_FIELD(vc,p_gate),match_info,
+					   newmad_iov,num_seg,&(REQ_FIELD(rreq,newmad_req)),(void*)rreq);
+	    REQ_FIELD(rreq,iov) = newmad_iov;
-	MPIU_Assert(num_seg <= NMAD_IOV_MAX_DEPTH);
-	ret = nm_sr_irecv_iov_with_ref(mpid_nem_newmad_pcore,VC_FIELD(vc,p_gate),match_info,
-				       newmad_iov,num_seg,&(REQ_FIELD(rreq,newmad_req)),(void*)rreq);
  fn_exit:
@@ -130,83 +150,74 @@
     goto fn_exit;
 #undef FUNCNAME
-#define FUNCNAME MPID_nem_newmad_poll_recv
+#define FUNCNAME MPID_nem_newmad_get_rreq
 #undef FCNAME
 #define FCNAME MPIDI_QUOTE(FUNCNAME)
-static int
-MPID_nem_newmad_poll_recv(void)
-   int              mpi_errno = MPI_SUCCESS;
-   nm_sr_request_t *p_out_req = NULL;
-   MPID_Request    *req = NULL;
-   int              ret;
+   nm_sr_request_t  *p_request = info->recv_completed.p_request;
+   MPID_Request     *req = NULL;
+   void             *ref;
+   nm_tag_t          match_info = 0;
+   MPIR_Context_id_t ctxt;
+   size_t            size;
-   ret = nm_sr_recv_success(mpid_nem_newmad_pcore, &p_out_req);
-   if (p_out_req != NULL)
+   nm_sr_get_size(mpid_nem_newmad_pcore, p_request, &size);
+   nm_sr_get_tag(mpid_nem_newmad_pcore, p_request, &match_info);
+   nm_sr_get_ref(mpid_nem_newmad_pcore, p_request, &ref);
+   req =  (MPID_Request *)ref;
+   MPIU_Assert(req != NULL);
+#ifdef DEBUG
+   fprintf(stdout,"========> Completing Recv req  %p (match is %lx) \n",req,match_info);
+#endif
+   NEM_NMAD_MATCH_GET_CTXT(match_info, ctxt);
+   if(ctxt == NEM_NMAD_INTRA_CTXT)
-       nm_tag_t          match_info = 0;
-       MPIR_Context_id_t ctxt;
-       size_t            size;
-       MPID_Request     *req;
-       void             *ref;
-       nm_sr_get_size(mpid_nem_newmad_pcore, p_out_req, &size);
-       nm_sr_get_tag(mpid_nem_newmad_pcore, p_out_req, &match_info);
-       nm_sr_get_ref(mpid_nem_newmad_pcore,p_out_req,&ref);
-       req =  (MPID_Request *)ref;
-       MPIU_Assert(req != NULL);
-       NEM_NMAD_MATCH_GET_CTXT(match_info, ctxt);
-       if(ctxt == NEM_NMAD_INTRA_CTXT)
+       if (req->kind == MPID_REQUEST_RECV)
-	   if (req->kind == MPID_REQUEST_RECV)
+	   if (size <= sizeof(MPIDI_CH3_PktGeneric_t))
-	       if (size <= sizeof(MPIDI_CH3_PktGeneric_t))
-		   MPID_nem_handle_pkt(req->ch.vc,(char *)&(req->dev.pending_pkt),(MPIDI_msg_sz_t)(size));
-	       else
-		   MPID_nem_handle_pkt(req->ch.vc,(char *)(req->dev.tmpbuf),(MPIDI_msg_sz_t)(req->dev.tmpbuf_sz));
-		   MPIU_Free(req->dev.tmpbuf);
-	       MPIDI_CH3_Request_destroy(req);
+	       MPID_nem_handle_pkt(req->ch.vc,(char *)&(req->dev.pending_pkt),(MPIDI_msg_sz_t)(size));
 	   else
-	       MPIU_Assert(0);
+	       MPID_nem_handle_pkt(req->ch.vc,(char *)(req->dev.tmpbuf),(MPIDI_msg_sz_t)(req->dev.tmpbuf_sz));
+	       MPIU_Free(req->dev.tmpbuf);
+	   MPIDI_CH3_Request_destroy(req);
        else
-	   if ((req->kind == MPID_REQUEST_RECV) || (req->kind == MPID_PREQUEST_RECV))
-	       int found = FALSE;
-	       nm_sr_request_t *nmad_request = NULL;
-	       MPIU_Assert(MPIDI_Request_get_type(req) != MPIDI_REQUEST_TYPE_GET_RESP);
-	       MPIU_THREAD_CS_ENTER(MSGQUEUE,req);
-	       MPID_NEM_NMAD_GET_REQ_FROM_HASH(req,nmad_request);
-	       found = MPIDI_CH3U_Recvq_DP(req);
-	       if(found){
-		   MPID_nem_newmad_handle_rreq(req,nmad_request,match_info,size);
-	       if(nmad_request != NULL)
-		   MPIU_Assert(req->dev.match.parts.rank == MPI_ANY_SOURCE);
-		   MPIU_Free(nmad_request);
-	       MPIU_THREAD_CS_EXIT(MSGQUEUE,req);
+	   MPIU_Assert(0);
+   else
+       if ((req->kind == MPID_REQUEST_RECV) || (req->kind == MPID_PREQUEST_RECV))
+	   int found = FALSE;
+	   nm_sr_request_t *nmad_request = NULL;
+	   MPIU_Assert(MPIDI_Request_get_type(req) != MPIDI_REQUEST_TYPE_GET_RESP);
+	   MPIU_THREAD_CS_ENTER(MSGQUEUE,req);
+	   MPID_NEM_NMAD_GET_REQ_FROM_HASH(req,nmad_request);
+	   found = MPIDI_CH3U_Recvq_DP(req);
+	   if(found){
+	       MPID_nem_newmad_handle_rreq(req,nmad_request,match_info,size);
-	   else
+	   if(nmad_request != NULL)
-	       MPIU_Assert(0);
+	       MPIU_Assert(req->dev.match.parts.rank == MPI_ANY_SOURCE);
+	       MPIU_Free(nmad_request);
+	   MPIU_THREAD_CS_EXIT(MSGQUEUE,req);
+       else
+	   MPIU_Assert(0);
- fn_exit:
-   return mpi_errno;
- fn_fail:  ATTRIBUTE((unused))
-   goto fn_exit;
 #undef FUNCNAME
@@ -218,21 +229,8 @@
-   MPID_nem_newmad_poll_recv();
+   nm_schedule(mpid_nem_newmad_pcore);
-   if (in_or_out)
-       MPID_nem_newmad_poll_send();
-   else
  fn_exit:
    return mpi_errno;
@@ -257,7 +255,9 @@
     nm_sr_get_ref(mpid_nem_newmad_pcore,p_request,&ref);
+#ifdef DEBUG
+    fprintf(stdout,"========> Completing Send req  %p (match is %lx) \n",req,match_info);
+#endif
     if(ctxt != NEM_NMAD_INTRA_CTXT)
@@ -345,6 +345,7 @@
 		MPIU_ERR_SETSIMPLE(req->status.MPI_ERROR,MPI_ERR_TYPE,"**dtypemismatch");
+	MPIU_Free(REQ_FIELD(req,iov));
     MPIDI_Comm_get_vc(req->comm, req->status.MPI_SOURCE, &vc);
@@ -478,6 +479,14 @@
     iov = MPIU_Malloc(iov_num_ub*sizeof(MPID_IOV));
     MPID_Segment_unpack_vector(rreq->dev.segment_ptr, rreq->dev.segment_first, &last,iov, &n_iov);
     MPIU_Assert(last == rreq->dev.segment_size);
+#ifdef DEBUG
+    for(index = 0; index < n_iov ; index++)
+	    fprintf(stdout,"RECV iov[%i]: [base %p][len %i]\n",index,
+		    iov[index].MPID_IOV_BUF,iov[index].MPID_IOV_LEN);
+#endif
     if(n_iov <= NMAD_IOV_MAX_DEPTH)
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c	2009-03-30 07:00:07 UTC (rev 4224)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c	2009-03-30 15:37:41 UTC (rev 4225)
@@ -26,6 +26,9 @@
     MPIDI_DBG_Print_packet((MPIDI_CH3_Pkt_t *)hdr);
     NEM_NMAD_ADI_MATCH(match_info);
+    fprintf(stdout,"iSendContig ========> Sending ADI msg  for req %p (match is %lx) \n",sreq,match_info);
     memcpy(&(sreq->dev.pending_pkt),(char *)hdr,sizeof(MPIDI_CH3_PktGeneric_t));
     mad_iov[0].iov_base = (char *)&(sreq->dev.pending_pkt);
     mad_iov[0].iov_len  = sizeof(MPIDI_CH3_PktGeneric_t);
@@ -74,6 +77,10 @@
     sreq->dev.OnDataAvail = 0;
+#ifdef DEBUG
+    fprintf(stdout,"StartcontigMsg ========> Sending ADI msg  for req %p (match is %lx) \n",sreq,match_info);
+#endif
@@ -128,6 +135,9 @@
 				       sreq->dev.user_count,data_sz, &mad_iov_ptr,&num_iov,1);
+#ifdef DEBUG
+    fprintf(stdout,"SendNonContig ========> Sending ADI msg  for req %p (match is %lx) \n",sreq,match_info);
+#endif
     memcpy(&(sreq->dev.pending_pkt),(char *)header,sizeof(MPIDI_CH3_PktGeneric_t));
@@ -160,6 +170,7 @@
     int            dt_contig;
+    int            index;
     MPIDI_STATE_DECL(MPID_STATE_MPID_NEM_NEWMAD_DIRECTSEND);
     MPIDI_FUNC_ENTER(MPID_STATE_MPID_NEM_NEWMAD_DIRECTSEND);
@@ -174,7 +185,9 @@
     sreq->ch.vc = vc;
     sreq->dev.OnDataAvail = NULL;
     NEM_NMAD_DIRECT_MATCH(match_info,tag,comm->rank,comm->context_id + context_offset);
+#ifdef DEBUG
+    fprintf(stdout,"Direct Send ========> Sending NON ADI msg for req %p (match is %lx) \n",sreq,match_info);
+#endif
     if(data_sz)
 	if (dt_contig)
@@ -189,6 +202,14 @@
 	    MPID_nem_newmad_process_sdtype(&sreq,datatype,dt_ptr,buf,count,data_sz,&mad_iov_ptr,&num_iov,0);
 	MPIU_Assert(num_iov <= NMAD_IOV_MAX_DEPTH);
+#ifdef DEBUG
+	for(index = 0; index < num_iov ; index++)
+		fprintf(stdout,"SEND nmad_iov[%i]: [base %p][len %i]\n",index,
+			mad_iov[index].iov_base,mad_iov[index].iov_len);
+#endif
 	nm_sr_isend_iov_with_ref(mpid_nem_newmad_pcore, VC_FIELD(vc, p_gate), match_info,
 				 mad_iov, num_iov, &(REQ_FIELD(sreq,newmad_req)),(void*)sreq);
@@ -302,6 +323,15 @@
     MPID_Segment_pack_vector(sreq->dev.segment_ptr, sreq->dev.segment_first, &last,iov, &n_iov);
     MPIU_Assert(last == sreq->dev.segment_size);
+#ifdef DEBUG
+	    fprintf(stdout,"SEND: iov[%i]: [base %p][len %i]\n",index,
+#endif
     if(n_iov <= num_entries)
More information about the mpich2-commits mailing list
