[mpich2-commits] r4212 - in mpich2/trunk/src/pm/hydra/launcher: mpiexec utils
balaji at mcs.anl.gov
Fri Mar 27 13:02:56 CDT 2009
Author: balaji
Date: 2009-03-27 13:02:56 -0500 (Fri, 27 Mar 2009)
New Revision: 4212
Modified:
mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
Log:
Fixing yet another bug with the environment variable passing that got
introduced in r4190.
Reviewed by Jayesh.
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-27 06:12:37 UTC (rev 4211)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-27 18:02:56 UTC (rev 4212)
@@ -31,7 +31,7 @@
HYD_Status HYD_LCHI_get_parameters(char **t_argv)
- int i;
+ int i, local_env_set;
char **argv = t_argv, *tmp;
char *env_name, *env_value, *str[4] = { NULL }, *progname = *argv;
HYD_Env_t *env;
@@ -310,19 +310,23 @@
if (handle.prop == HYD_ENV_PROP_UNSET && tmp)
handle.prop = !strcmp(tmp, "all") ? HYD_ENV_PROP_ALL : HYD_ENV_PROP_NONE;
- /* If nothing is set for the global environment, set it to the default */
- if (handle.prop == HYD_ENV_PROP_UNSET)
- handle.prop = HYD_ENV_PROP_ALL;
/* Make sure local executable is set */
+ local_env_set = 0;
for (exec_info = handle.exec_info_list; exec_info; exec_info = exec_info->next) {
if (exec_info->exec[0] == NULL)
HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "no executable specified\n");
if (exec_info->exec_proc_count == 0)
exec_info->exec_proc_count = 1;
+ if (exec_info->prop != HYD_ENV_PROP_UNSET)
+ local_env_set = 1;
+ /* If no global or local environment is set, use the default */
+ if ((handle.prop == HYD_ENV_PROP_UNSET) && (local_env_set == 0))
+ handle.prop = HYD_ENV_PROP_ALL;
if (handle.proxy_port == -1)
handle.proxy_port = HYD_DEFAULT_PROXY_PORT;
Modified: mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
--- mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-27 06:12:37 UTC (rev 4211)
+++ mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-27 18:02:56 UTC (rev 4212)
@@ -129,6 +129,12 @@
+ else if (handle.prop == HYD_ENV_PROP_UNSET) {
+ for (env = handle.user_env; env; env = env->next) {
+ status = HYDU_append_env_to_list(*env, &handle.prop_env);
+ HYDU_ERR_POP(status, "unable to add env to list\n");
while (exec_info) {
@@ -154,6 +160,12 @@
+ else if (exec_info->prop == HYD_ENV_PROP_UNSET) {
+ for (env = exec_info->user_env; env; env = env->next) {
+ status = HYDU_append_env_to_list(*env, &exec_info->prop_env);
exec_info = exec_info->next;
More information about the mpich2-commits
