[mpich2-commits] r4189 - in mpich2/trunk: doc/pmi maint src/binding/f77 src/binding/f90
balaji at mcs.anl.gov
Wed Mar 25 18:48:39 CDT 2009
Author: balaji
Date: 2009-03-25 18:48:38 -0500 (Wed, 25 Mar 2009)
New Revision: 4189
Modified:
mpich2/trunk/doc/pmi/manextract
mpich2/trunk/maint/extractparms
mpich2/trunk/src/binding/f77/buildiface
mpich2/trunk/src/binding/f90/buildiface
Log:
Added "use warnings;" instead of calling "perl -w" directly, as that
seems to be breaking when usedin conjunction with /usr/bin/env.
Reviewed by goodell.
Modified: mpich2/trunk/doc/pmi/manextract
--- mpich2/trunk/doc/pmi/manextract 2009-03-25 18:50:21 UTC (rev 4188)
+++ mpich2/trunk/doc/pmi/manextract 2009-03-25 23:48:38 UTC (rev 4189)
@@ -1,4 +1,4 @@
-#! /usr/bin/env perl -w
+#! /usr/bin/env perl
# This script extracts the text blocks from a source file and creates a
# simple text block out of them.
@@ -7,6 +7,9 @@
# manual can contain the comments from the example source files adi3.c and
# adi3.h.
+use warnings;
$debug = 0;
while (<>) {
if (/\/\*T([^ ]*)[ ]*\n/) {
Modified: mpich2/trunk/maint/extractparms
--- mpich2/trunk/maint/extractparms 2009-03-25 18:50:21 UTC (rev 4188)
+++ mpich2/trunk/maint/extractparms 2009-03-25 23:48:38 UTC (rev 4189)
@@ -1,7 +1,10 @@
# (Tested with -w; 2/23/07)
# Find the parse.sub routine.
+use warnings;
my $maintdir = "maint";
my $rootdir = ".";
if ( ! -s "maint/parse.sub" ) {
Modified: mpich2/trunk/src/binding/f77/buildiface
--- mpich2/trunk/src/binding/f77/buildiface 2009-03-25 18:50:21 UTC (rev 4188)
+++ mpich2/trunk/src/binding/f77/buildiface 2009-03-25 23:48:38 UTC (rev 4189)
@@ -1,4 +1,4 @@
# This file builds candidate interface files from the descriptions in
# mpi.h
@@ -15,6 +15,9 @@
# MPI_Fint etc. as appropriate
+use warnings;
# Setup global variables
%CtoFName = ();
@ExtraRoutines = ();
Modified: mpich2/trunk/src/binding/f90/buildiface
--- mpich2/trunk/src/binding/f90/buildiface 2009-03-25 18:50:21 UTC (rev 4188)
+++ mpich2/trunk/src/binding/f90/buildiface 2009-03-25 23:48:38 UTC (rev 4189)
@@ -1,4 +1,7 @@
+use warnings;
# binding.sub provides the routines for reading the prototype file
# and extracting the function definitions.
require "binding.sub";
More information about the mpich2-commits
