[mpich2-commits] r4180 - mpich2/trunk/src/mpid/common/locks
buntinas at mcs.anl.gov
Tue Mar 24 16:03:20 CDT 2009
Author: buntinas
Date: 2009-03-24 16:03:20 -0500 (Tue, 24 Mar 2009)
New Revision: 4180
Modified:
mpich2/trunk/src/mpid/common/locks/mpidu_atomic_primitives.h
mpich2/trunk/src/mpid/common/locks/mpidu_atomics_sun_atomic_ops.h
Log:
fixed sun atomic primitives
Modified: mpich2/trunk/src/mpid/common/locks/mpidu_atomic_primitives.h
--- mpich2/trunk/src/mpid/common/locks/mpidu_atomic_primitives.h 2009-03-24 19:43:20 UTC (rev 4179)
+++ mpich2/trunk/src/mpid/common/locks/mpidu_atomic_primitives.h 2009-03-24 21:03:20 UTC (rev 4180)
@@ -8,6 +8,7 @@
#define MPIDU_ATOMIC_PRIMITIVES_H_INCLUDED
#include <mpichconf.h>
+#include <mpid_locksconf.h>
/* FIXME We need assert capability but we can't rely on MPIU_Assert down at this
level. To futher complicate matters this is definitely performance critical
Modified: mpich2/trunk/src/mpid/common/locks/mpidu_atomics_sun_atomic_ops.h
--- mpich2/trunk/src/mpid/common/locks/mpidu_atomics_sun_atomic_ops.h 2009-03-24 19:43:20 UTC (rev 4179)
+++ mpich2/trunk/src/mpid/common/locks/mpidu_atomics_sun_atomic_ops.h 2009-03-24 21:03:20 UTC (rev 4180)
@@ -9,99 +9,90 @@
#include <atomic.h>
-static inline void MPIDU_Atomic_add(volatile int *ptr, int val)
+typedef struct { volatile uint_t v; } MPIDU_Atomic_t;
+typedef struct { void * volatile v; } MPIDU_Atomic_ptr_t;
+static inline int MPIDU_Atomic_load(MPIDU_Atomic_t *ptr)
- atomic_add_int((volatile uint_t *)ptr, val);
+ return (int)ptr->v;
-static inline void MPIDU_Atomic_incr(volatile int *ptr)
+static inline void MPIDU_Atomic_store(MPIDU_Atomic_t *ptr, int val)
- atomic_inc_uint((volatile uint_t *)ptr);
+ ptr->v = (uint)val;
-static inline void MPIDU_Atomic_decr(volatile int *ptr)
+static inline void *MPIDU_Atomic_load_ptr(MPIDU_Atomic_ptr_t *ptr)
- atomic_dec_uint((volatile uint_t *)ptr);
+ return ptr->v;
-static inline int MPIDU_Atomic_decr_and_test(volatile int *ptr)
+static inline void MPIDU_Atomic_store_ptr(MPIDU_Atomic_ptr_t *ptr, void *val)
- return atomic_dec_uint_nv((volatile uint_t *)ptr) == 0;
+ ptr->v = val;
-static inline int MPIDU_Atomic_fetch_and_add(volatile int *ptr, int val)
+static inline void MPIDU_Atomic_add(MPIDU_Atomic_t *ptr, int val)
- return (int)atomic_add_int_nv((volatile uint_t *)ptr, val) - val;
+ atomic_add_int(&ptr->v, val);
-static inline int MPIDU_Atomic_fetch_and_decr(volatile int *ptr)
+static inline void MPIDU_Atomic_incr(MPIDU_Atomic_t *ptr)
- return (int)atomic_dec_uint_nv((volatile uint_t *)ptr) + 1;
+ atomic_inc_uint(&ptr->v);
-static inline int MPIDU_Atomic_fetch_and_incr(volatile int *ptr)
+static inline void MPIDU_Atomic_decr(MPIDU_Atomic_t *ptr)
- return (int)atomic_inc_uint_nv((volatile uint_t *)ptr) - 1;
+ atomic_dec_uint(&ptr->v);
-static inline int *MPIDU_Atomic_cas_int_ptr(int * volatile *ptr, int *oldv, int *newv)
+static inline int MPIDU_Atomic_decr_and_test(MPIDU_Atomic_t *ptr)
- return atomic_cas_ptr(ptr, oldv, newv);
+ return atomic_dec_uint_nv(&ptr->v) == 0;
-static inline int MPIDU_Atomic_cas_int(volatile int *ptr, int oldv, int newv)
+static inline int MPIDU_Atomic_fetch_and_add(MPIDU_Atomic_t *ptr, int val)
- return (int)atomic_cas_uint((volatile uint_t *)ptr, (uint_t)oldv, (uint_t)newv);
+ return (int)atomic_add_int_nv(&ptr->v, val) - val;
-static inline MPI_Aint MPIDU_Atomic_cas_aint(volatile MPI_Aint *ptr, MPI_Aint oldv, MPI_Aint newv)
+static inline int MPIDU_Atomic_fetch_and_decr(MPIDU_Atomic_t *ptr)
- switch (sizeof(MPI_Aint))
- case 4:
- return (MPI_Aint)atomic_cas_32((volatile uint32_t *)ptr, (uint32_t)oldv, (uint32_t)newv);
- break;
- case 8:
- return (MPI_Aint)atomic_cas_64((volatile uint64_t *)ptr, (uint64_t)oldv, (uint64_t)newv);
- break;
- default:
- /* FIXME: A compile-time check for this would be better. */
- MPIU_Assertp(0);
- break;
+ return (int)atomic_dec_uint_nv(&ptr->v) + 1;
+static inline int MPIDU_Atomic_fetch_and_incr(MPIDU_Atomic_t *ptr)
+ return (int)atomic_inc_uint_nv(&ptr->v) - 1;
-static inline int *MPIDU_Atomic_swap_int_ptr(int * volatile *ptr, int *val)
+static inline int *MPIDU_Atomic_cas_ptr(MPIDU_Atomic_ptr_t *ptr, int *oldv, int *newv)
- return atomic_swap_ptr(ptr, val);
+ return atomic_cas_ptr(ptr, oldv, newv);
-static inline int MPIDU_Atomic_swap_int(volatile int *ptr, int val)
+static inline int MPIDU_Atomic_cas_int(MPIDU_Atomic_t *ptr, int oldv, int newv)
- return (int)atomic_swap_uint((volatile uint_t *)ptr, (uint_t) val);
+ return (int)atomic_cas_uint(&ptr->v, (uint_t)oldv, (uint_t)newv);
-static inline MPI_Aint MPIDU_Atomic_swap_aint(volatile MPI_Aint *ptr, MPI_Aint val)
+static inline int *MPIDU_Atomic_swap_ptr(MPIDU_Atomic_ptr_t *ptr, int *val)
- case 4:
- return (MPI_Aint)atomic_swap_32((volatile uint32_t *)ptr, (uint32_t)val);
- break;
- case 8:
- return (MPI_Aint)atomic_swap_64((volatile uint64_t *)ptr, (uint64_t)val);
- break;
- default:
- MPIU_Assertp(0);
- break;
+ return atomic_swap_ptr(ptr, val);
+static inline int MPIDU_Atomic_swap_int(MPIDU_Atomic_t *ptr, int val)
+ return (int)atomic_swap_uint(&ptr->v, (uint_t) val);
#define MPIDU_Shm_write_barrier() membar_producer()
#define MPIDU_Shm_read_barrier() membar_consumer()
#define MPIDU_Shm_read_write_barrier() do { membar_consumer(); membar_producer(); } while (0)
More information about the mpich2-commits
