[mpich2-commits] r4176 - in mpich2/trunk: maint src/packaging/spec
balaji at mcs.anl.gov
Tue Mar 24 04:32:45 CDT 2009
Author: balaji
Date: 2009-03-24 04:32:45 -0500 (Tue, 24 Mar 2009)
New Revision: 4176
Added:
mpich2/trunk/src/packaging/spec/fedora.spec.vin
Removed:
mpich2/trunk/src/packaging/spec/fedora.spec.in
Modified:
mpich2/trunk/maint/updatefiles
Log:
Use *.vin format for source files that are auto-generation during
updatefiles time for consistency.
Modified: mpich2/trunk/maint/updatefiles
--- mpich2/trunk/maint/updatefiles 2009-03-24 09:31:43 UTC (rev 4175)
+++ mpich2/trunk/maint/updatefiles 2009-03-24 09:32:45 UTC (rev 4176)
@@ -778,7 +778,7 @@
BASIC_VERSION=`expr $VERSION : '\([0-9]*\.[0-9]*[\.]*[0-9]*\)[a-zA-Z]*[0-9]*'`
VERSION_EXT=`expr $VERSION : '[0-9]*\.[0-9]*[\.]*[0-9]*\([a-zA-Z]*[0-9]*\)'`
sed -e "s/%BASIC_VERSION%/${BASIC_VERSION}/g" -e "s/%VERSION_EXT%/${VERSION_EXT}/g" \
- src/packaging/spec/fedora.spec.in > src/packaging/spec/fedora.spec
+ src/packaging/spec/fedora.spec.vin > src/packaging/spec/fedora.spec
# The following must be the last statements executed
Deleted: mpich2/trunk/src/packaging/spec/fedora.spec.in
--- mpich2/trunk/src/packaging/spec/fedora.spec.in 2009-03-24 09:31:43 UTC (rev 4175)
+++ mpich2/trunk/src/packaging/spec/fedora.spec.in 2009-03-24 09:32:45 UTC (rev 4176)
@@ -1,323 +0,0 @@
-Summary: A high-performance implementation of MPI
-Name: mpich2
-Version: %BASIC_VERSION%
-Release: %VERSION_EXT%
-License: MIT
-Group: Development/Libraries
-URL: http://www.mcs.anl.gov/research/projects/mpich2
-Source: http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/%{version}%{release}/src/%{name}-%{version}%{release}.tar.gz
-BuildRoot: %{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u} -n)
-BuildRequires: libXt-devel, e2fsprogs-devel
-BuildRequires: java-devel, gcc-gfortran
-BuildRequires: emacs-common, perl, python
-Requires: %{name}-libs = %{version}-%{release}
-Requires: python
-Requires(post): chkconfig
-Requires(preun):chkconfig
-#Requires chkconfig for /usr/sbin/alternatives
-%description
-MPICH2 is a high-performance and widely portable implementation of the
-MPI standard. This release has all MPI-2.1 functions and features
-required by the standard with the exeption of support for the
-"external32" portable I/O format.
-The mpich2 binaries in Fedora were configured to use the default
-process manager 'MPD' using the default device 'ch3'. The ch3 device
-was configured with support for the nemesis channel that allows for
-shared-memory and TCP/IP sockets based communication.
-The Fedora builds also include support for using '/usr/sbin/alternatives'
-and/or the 'module environment' to select which MPI implementation to use
-when multiple implementations are installed.
-%package devel
-Summary: Development files for mpich2
-Requires: %{name} = %{version}-%{release}
-Requires: pkgconfig
-Requires: gcc-gfortran
-Requires(post): /usr/sbin/alternatives
-Requires(preun):/usr/sbin/alternatives
-%description devel
-Contains development headers and libraries for mpich2
-%package libs
-Summary: Libraries and configuration files for mpich2
-%description libs
-Contains the arch dependent libraries and their build configuration for mpich2
-# We only compile with gcc, but other people may want other compilers.
-# Set the compiler here.
-%{!?opt_cc: %define opt_cc gcc}
-%{!?opt_fc: %define opt_fc gfortran}
-# Optional CFLAGS to use with the specific compiler...gcc doesn't need any,
-# so uncomment and undefine to NOT use
-%{!?opt_cc_cflags: %define opt_cc_cflags %{optflags}}
-%{!?opt_fc_fflags: %define opt_fc_fflags %{optflags}}
-%ifarch %{ix86} x86_64
-%define selected_channels ch3:nemesis
-%else
-%define selected_channels ch3:sock
-%endif
-%ifarch x86_64 ia64 ppc64 s390x sparc64
-%define mode 64
-%define priority 41
-%else
-%define mode 32
-%define priority 40
-%endif
-%ifarch x86_64
-%define XFLAGS -fPIC
-%endif
-%prep
-%setup -q -n %{name}-%{version}%VERSION_EXT%
-%configure \
- --enable-sharedlibs=gcc \
- --with-device=%{selected_channels} \
- --sysconfdir=%{_sysconfdir}/%{name}-%{mode} \
- --includedir=%{_includedir}/%{name} \
- --libdir=%{_libdir}/%{name} \
- --datadir=%{_datadir}/%{name} \
- --docdir=%{_docdir}/%{name}-%{version} \
- --htmldir=%{_docdir}/%{name}-%{version}/www \
- --with-java=%{_sysconfdir}/alternatives/java_sdk \
- F90=%{opt_fc} \
- F77=%{opt_fc} \
- CFLAGS="%{?opt_cc_cflags} %{?XFLAGS}" \
- CXXFLAGS="%{optflags} %{?XFLAGS}" \
- F90FLAGS="%{?opt_fc_fflags} %{?XFLAGS}" \
- FFLAGS="%{?opt_fc_fflags} %{?XFLAGS}" \
- LDFLAGS='-Wl,-z,noexecstack'
-%build
-#make %{?_smp_mflags} doesn't work
-make
-%install
-rm -rf %{buildroot}
-make DESTDIR=%{buildroot} install
-## Resolve clashes with LAM/OPENMP: mpicxx mpicc mpif77 mpif90 mpiexec mpirun
-rm -f %{buildroot}%{_bindir}/{mpiexec,mpirun,mpdrun}
-mv %{buildroot}%{_mandir}/man1/{,mp-}mpiexec.1
-pushd %{buildroot}%{_bindir}/
-ln -s mpiexec.py mpdrun
-popd
-for b in mpicxx mpicc mpif77 mpif90; do
- mv %{buildroot}%{_bindir}/$b %{buildroot}%{_bindir}/mp%{mode}-$b;
- mv %{buildroot}%{_mandir}/man1/$b.1 %{buildroot}%{_mandir}/man1/mp-$b.1;
-done
-## Setup the executables for environment module
-mkdir -p %{buildroot}%{_datadir}/%{name}/bin%{mode}
- ln -s ../../../bin/mp%{mode}-$b %{buildroot}%{_datadir}/%{name}/bin%{mode}/$b
-done
-for ex in mpiexec mpirun; do
- ln -s ../../../bin/mpiexec.py %{buildroot}%{_datadir}/%{name}/bin%{mode}/$ex
-done
-mv %{buildroot}%{_libdir}/%{name}/pkgconfig %{buildroot}%{_libdir}/
-chmod -x %{buildroot}%{_libdir}/pkgconfig/*.pc
-# Adjust the default module PATH for our changes
-sed -i 's#bin#bin'%{mode}'#' %{buildroot}%{_datadir}/%{name}/%{name}.module
-# Manually copy doc file here instead of the %files section to prevent the rpm
-#build script from throwing the other things in there out
-cp -pr CHANGES COPYRIGHT README RELEASE_NOTES %{buildroot}%{_docdir}/%{name}-%{version}/
-cp -pr src/mpe2/README %{buildroot}%{_docdir}/%{name}-%{version}/README.mpe
-# Silence rpmlint
-sed -i '/^#! \//,1 d' %{buildroot}%{_sysconfdir}/%{name}-%{mode}/{mpi*.conf,mpe_help.*}
-#Rename the MPI routine manpages, to avoid conflict with openmpi
-for man in %{buildroot}%{_mandir}/man3/*; do
- manf=`basename $man .3`
- mv %{buildroot}%{_mandir}/man3/$manf.3 %{buildroot}%{_mandir}/man4/$manf.4
- sed s/3/4/1 -i %{buildroot}%{_mandir}/man4/$manf.4
-done
-# The uninstall script that is installed in this directory is not needed in rpm
-# packaging
-rm -rf %{buildroot}%{_sbindir}/mpe*
-find %{buildroot} -type f -name "*.la" -exec rm -f {} ';'
-%clean
-%post
-/usr/sbin/alternatives \
- --install %{_bindir}/mpirun mpi-run %{_bindir}/mpiexec.py 41 \
- --slave %{_bindir}/mpiexec mpi-exec %{_bindir}/mpiexec.py \
- --slave %{_mandir}/man1/mpiexec.1.gz mpi-exec-man \
- %{_mandir}/man1/mp-mpiexec.1.gz \
- --slave %{_mandir}/man1/mpif90.1.gz mpif90-man \
- %{_mandir}/man1/mp-mpif90.1.gz \
- --slave %{_mandir}/man1/mpif77.1.gz mpif77-man \
- %{_mandir}/man1/mp-mpif77.1.gz \
- --slave %{_mandir}/man1/mpicc.1.gz mpicc-man \
- %{_mandir}/man1/mp-mpicc.1.gz \
- --slave %{_mandir}/man1/mpic++.1.gz mpic++-man \
- %{_mandir}/man1/mp-mpicxx.1.gz
-%preun
-/usr/sbin/alternatives --remove mpi-run %{_bindir}/mpiexec.py
-%post devel
- --install %{_bindir}/mpicc mpicc %{_bindir}/mp%{mode}-mpicc %{priority}\
- --slave %{_bindir}/mpicxx mpicxx %{_bindir}/mp%{mode}-mpicxx \
- --slave %{_bindir}/mpif90 mpif90 %{_bindir}/mp%{mode}-mpif90 \
- --slave %{_bindir}/mpif77 mpif77 %{_bindir}/mp%{mode}-mpif77
-%preun devel
-/usr/sbin/alternatives --remove mpicc %{_bindir}/mp%{mode}-mpicc
-%files
-%defattr(-,root,root,-)
-%{_bindir}/*
-%dir %{_datadir}/%{name}
-%dir %{_datadir}/%{name}/bin%{mode}
-%{_datadir}/%{name}/bin%{mode}/mpiexec
-%{_datadir}/%{name}/bin%{mode}/mpirun
-%exclude %{_bindir}/mp%{mode}-mpicc
-%exclude %{_bindir}/mp%{mode}-mpicxx
-%exclude %{_bindir}/mp%{mode}-mpif90
-%exclude %{_bindir}/mp%{mode}-mpif77
-%doc %{_docdir}/%{name}-%{version}/
-%{_mandir}/man1/*
-%if 0%{?fedora} < 11
-%exclude %{_bindir}/mp*.pyc
-%exclude %{_bindir}/mp*.pyo
-%endif
-%files libs
-%dir %{_libdir}/%{name}
-%{_libdir}/%{name}/*.jar
-%{_libdir}/%{name}/mpe*.o
-%{_libdir}/%{name}/*.so.*
-%config %{_sysconfdir}/%{name}-%{mode}/
-%files devel
-%{_bindir}/mp%{mode}-mpicc
-%{_bindir}/mp%{mode}-mpicxx
-%{_bindir}/mp%{mode}-mpif90
-%{_bindir}/mp%{mode}-mpif77
-%{_includedir}/*
-%{_libdir}/%{name}/*.a
-%{_libdir}/%{name}/trace_rlog/libTraceInput.so
-%{_libdir}/pkgconfig/%{name}-ch3.pc
-%{_datadir}/%{name}/%{name}.module
-%{_datadir}/%{name}/bin%{mode}/mpicc
-%{_datadir}/%{name}/bin%{mode}/mpicxx
-%{_datadir}/%{name}/bin%{mode}/mpif90
-%{_datadir}/%{name}/bin%{mode}/mpif77
-%{_datadir}/%{name}/examples*
-%{_datadir}/%{name}/logfiles/
-%{_mandir}/man4/*.gz
-%doc README.testing README.romio README.developer
-%changelog
-* Mon Mar 16 2009 Deji Akingunola <dakingun at gmail.com> - 1.1-0.1
-- Update for the 1.1 (beta) release
-- Stop building with dllchan, it is not fully supported
-* Mon Mar 09 2009 Deji Akingunola <dakingun at gmail.com> - 1.0.8-3
-- Drop the ssm channel from ppc* archs, it fails to build
-- Python scripts in bindir and sbindir are no longer bytecompiled (F-11+)
-- Enhance the spec file to support ia64 and sparc
-- Include mpiexec and mpirun (symlinks) in the environment module bindir
-* Fri Mar 06 2009 Deji Akingunola <dakingun at gmail.com> - 1.0.8-2
-- Fix the source url, pointed out from package review
-- Finally accepted to go into Fedora
-* Sat Oct 24 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.8-1
-- Update to the 1.0.8
-- Configure with the default nemesis channel
-* Fri May 16 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-5
-- Update the alternate compiler/compiler flags macro to allow overriding it
- from command-line
-* Wed Apr 16 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-4
-- Apply patch from Orion Poplawski to silence rpmlint
-* Tue Apr 15 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-3
-- Add a note on the device/channels configuration options used, and
-- Fix logfile listings as suggested by Orion Poplawski (Package review, 171993)
-* Tue Apr 15 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-2
-* Sat Apr 05 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-1
-- Update to 1.0.7
-* Mon Oct 15 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.6p1-1
-- Update to 1.0.6p1
-* Mon Oct 15 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.6-1
-- New version upgrade
-* Mon Jul 31 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-4
-- Create a -mpi-manpages subpackage for the MPI routines manuals
-* Fri Jul 27 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-3
-- Fix java-gcj-compat BR
-- Handle upgrades in the post scripts
-* Mon Jun 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-2
-- Fix typos and make other adjustments arising from Fedora package reviews
-* Mon Jun 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-1
-- Patch #4 release
-* Mon Feb 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p2-1
-- Patch #2 release
-* Tue Jan 09 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p1-1
-- New release with manpages
-- Create a -libs subpackage as it's done in Fedora's openmpi to help with
- multi-libs packaging
-- Disable modules support (until I can properly figure it out)
-* Wed Dec 27 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.5-1
-- New release
-* Sat Nov 18 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4p1-2
-- Set the java_sdk directory so all java bit work
-* Sat Sep 02 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4p1-1
-- Update to version 1.0.4p1
-- Cleanup up spec file to use alternatives similarly to FC's openmpi
-* Wed Aug 02 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4-1
-* Thu May 18 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.3-3
-- Add missing BRs (Orion Polawski)
-* Mon Apr 10 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.3-2
-- Rewrite the spec, borrowing extensively from openmpi's spec by Jason Vas Dias
-- Allows use of environment modules and alternatives
-* Fri Nov 25 2005 Deji Akingunola <dakingun at gmail.com> - 1.0.3-1
-- Update to new version
-* Sat Oct 15 2005 Deji Akingunola <deji.aking at gmail.com> - 1.0.2p1-1
-- Initial package
Copied: mpich2/trunk/src/packaging/spec/fedora.spec.vin (from rev 4167, mpich2/trunk/src/packaging/spec/fedora.spec.in)
--- mpich2/trunk/src/packaging/spec/fedora.spec.vin (rev 0)
+++ mpich2/trunk/src/packaging/spec/fedora.spec.vin 2009-03-24 09:32:45 UTC (rev 4176)
@@ -0,0 +1,323 @@
+Summary: A high-performance implementation of MPI
+Name: mpich2
+Version: %BASIC_VERSION%
+Release: %VERSION_EXT%
+License: MIT
+Group: Development/Libraries
+URL: http://www.mcs.anl.gov/research/projects/mpich2
+Source: http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/%{version}%{release}/src/%{name}-%{version}%{release}.tar.gz
+BuildRoot: %{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u} -n)
+BuildRequires: libXt-devel, e2fsprogs-devel
+BuildRequires: java-devel, gcc-gfortran
+BuildRequires: emacs-common, perl, python
+Requires: %{name}-libs = %{version}-%{release}
+Requires: python
+Requires(post): chkconfig
+Requires(preun):chkconfig
+#Requires chkconfig for /usr/sbin/alternatives
+%description
+MPICH2 is a high-performance and widely portable implementation of the
+MPI standard. This release has all MPI-2.1 functions and features
+required by the standard with the exeption of support for the
+"external32" portable I/O format.
+The mpich2 binaries in Fedora were configured to use the default
+process manager 'MPD' using the default device 'ch3'. The ch3 device
+was configured with support for the nemesis channel that allows for
+shared-memory and TCP/IP sockets based communication.
+The Fedora builds also include support for using '/usr/sbin/alternatives'
+and/or the 'module environment' to select which MPI implementation to use
+when multiple implementations are installed.
+%package devel
+Summary: Development files for mpich2
+Requires: %{name} = %{version}-%{release}
+Requires: pkgconfig
+Requires: gcc-gfortran
+Requires(post): /usr/sbin/alternatives
+Requires(preun):/usr/sbin/alternatives
+%description devel
+Contains development headers and libraries for mpich2
+%package libs
+Summary: Libraries and configuration files for mpich2
+%description libs
+Contains the arch dependent libraries and their build configuration for mpich2
+# We only compile with gcc, but other people may want other compilers.
+# Set the compiler here.
+%{!?opt_cc: %define opt_cc gcc}
+%{!?opt_fc: %define opt_fc gfortran}
+# Optional CFLAGS to use with the specific compiler...gcc doesn't need any,
+# so uncomment and undefine to NOT use
+%{!?opt_cc_cflags: %define opt_cc_cflags %{optflags}}
+%{!?opt_fc_fflags: %define opt_fc_fflags %{optflags}}
+%ifarch %{ix86} x86_64
+%define selected_channels ch3:nemesis
+%else
+%define selected_channels ch3:sock
+%endif
+%ifarch x86_64 ia64 ppc64 s390x sparc64
+%define mode 64
+%define priority 41
+%else
+%define mode 32
+%define priority 40
+%endif
+%ifarch x86_64
+%define XFLAGS -fPIC
+%endif
+%prep
+%setup -q -n %{name}-%{version}%VERSION_EXT%
+%configure \
+ --enable-sharedlibs=gcc \
+ --with-device=%{selected_channels} \
+ --sysconfdir=%{_sysconfdir}/%{name}-%{mode} \
+ --includedir=%{_includedir}/%{name} \
+ --libdir=%{_libdir}/%{name} \
+ --datadir=%{_datadir}/%{name} \
+ --docdir=%{_docdir}/%{name}-%{version} \
+ --htmldir=%{_docdir}/%{name}-%{version}/www \
+ --with-java=%{_sysconfdir}/alternatives/java_sdk \
+ F90=%{opt_fc} \
+ F77=%{opt_fc} \
+ CFLAGS="%{?opt_cc_cflags} %{?XFLAGS}" \
+ CXXFLAGS="%{optflags} %{?XFLAGS}" \
+ F90FLAGS="%{?opt_fc_fflags} %{?XFLAGS}" \
+ FFLAGS="%{?opt_fc_fflags} %{?XFLAGS}" \
+ LDFLAGS='-Wl,-z,noexecstack'
+%build
+#make %{?_smp_mflags} doesn't work
+make
+%install
+rm -rf %{buildroot}
+make DESTDIR=%{buildroot} install
+## Resolve clashes with LAM/OPENMP: mpicxx mpicc mpif77 mpif90 mpiexec mpirun
+rm -f %{buildroot}%{_bindir}/{mpiexec,mpirun,mpdrun}
+mv %{buildroot}%{_mandir}/man1/{,mp-}mpiexec.1
+pushd %{buildroot}%{_bindir}/
+ln -s mpiexec.py mpdrun
+popd
+for b in mpicxx mpicc mpif77 mpif90; do
+ mv %{buildroot}%{_bindir}/$b %{buildroot}%{_bindir}/mp%{mode}-$b;
+ mv %{buildroot}%{_mandir}/man1/$b.1 %{buildroot}%{_mandir}/man1/mp-$b.1;
+done
+## Setup the executables for environment module
+mkdir -p %{buildroot}%{_datadir}/%{name}/bin%{mode}
+ ln -s ../../../bin/mp%{mode}-$b %{buildroot}%{_datadir}/%{name}/bin%{mode}/$b
+done
+for ex in mpiexec mpirun; do
+ ln -s ../../../bin/mpiexec.py %{buildroot}%{_datadir}/%{name}/bin%{mode}/$ex
+done
+mv %{buildroot}%{_libdir}/%{name}/pkgconfig %{buildroot}%{_libdir}/
+chmod -x %{buildroot}%{_libdir}/pkgconfig/*.pc
+# Adjust the default module PATH for our changes
+sed -i 's#bin#bin'%{mode}'#' %{buildroot}%{_datadir}/%{name}/%{name}.module
+# Manually copy doc file here instead of the %files section to prevent the rpm
+#build script from throwing the other things in there out
+cp -pr CHANGES COPYRIGHT README RELEASE_NOTES %{buildroot}%{_docdir}/%{name}-%{version}/
+cp -pr src/mpe2/README %{buildroot}%{_docdir}/%{name}-%{version}/README.mpe
+# Silence rpmlint
+sed -i '/^#! \//,1 d' %{buildroot}%{_sysconfdir}/%{name}-%{mode}/{mpi*.conf,mpe_help.*}
+#Rename the MPI routine manpages, to avoid conflict with openmpi
+for man in %{buildroot}%{_mandir}/man3/*; do
+ manf=`basename $man .3`
+ mv %{buildroot}%{_mandir}/man3/$manf.3 %{buildroot}%{_mandir}/man4/$manf.4
+ sed s/3/4/1 -i %{buildroot}%{_mandir}/man4/$manf.4
+done
+# The uninstall script that is installed in this directory is not needed in rpm
+# packaging
+rm -rf %{buildroot}%{_sbindir}/mpe*
+find %{buildroot} -type f -name "*.la" -exec rm -f {} ';'
+%clean
+%post
+/usr/sbin/alternatives \
+ --install %{_bindir}/mpirun mpi-run %{_bindir}/mpiexec.py 41 \
+ --slave %{_bindir}/mpiexec mpi-exec %{_bindir}/mpiexec.py \
+ --slave %{_mandir}/man1/mpiexec.1.gz mpi-exec-man \
+ %{_mandir}/man1/mp-mpiexec.1.gz \
+ --slave %{_mandir}/man1/mpif90.1.gz mpif90-man \
+ %{_mandir}/man1/mp-mpif90.1.gz \
+ --slave %{_mandir}/man1/mpif77.1.gz mpif77-man \
+ %{_mandir}/man1/mp-mpif77.1.gz \
+ --slave %{_mandir}/man1/mpicc.1.gz mpicc-man \
+ %{_mandir}/man1/mp-mpicc.1.gz \
+ --slave %{_mandir}/man1/mpic++.1.gz mpic++-man \
+ %{_mandir}/man1/mp-mpicxx.1.gz
+%preun
+/usr/sbin/alternatives --remove mpi-run %{_bindir}/mpiexec.py
+%post devel
+ --install %{_bindir}/mpicc mpicc %{_bindir}/mp%{mode}-mpicc %{priority}\
+ --slave %{_bindir}/mpicxx mpicxx %{_bindir}/mp%{mode}-mpicxx \
+ --slave %{_bindir}/mpif90 mpif90 %{_bindir}/mp%{mode}-mpif90 \
+ --slave %{_bindir}/mpif77 mpif77 %{_bindir}/mp%{mode}-mpif77
+%preun devel
+/usr/sbin/alternatives --remove mpicc %{_bindir}/mp%{mode}-mpicc
+%files
+%defattr(-,root,root,-)
+%{_bindir}/*
+%dir %{_datadir}/%{name}
+%dir %{_datadir}/%{name}/bin%{mode}
+%{_datadir}/%{name}/bin%{mode}/mpiexec
+%{_datadir}/%{name}/bin%{mode}/mpirun
+%exclude %{_bindir}/mp%{mode}-mpicc
+%exclude %{_bindir}/mp%{mode}-mpicxx
+%exclude %{_bindir}/mp%{mode}-mpif90
+%exclude %{_bindir}/mp%{mode}-mpif77
+%doc %{_docdir}/%{name}-%{version}/
+%{_mandir}/man1/*
+%if 0%{?fedora} < 11
+%exclude %{_bindir}/mp*.pyc
+%exclude %{_bindir}/mp*.pyo
+%endif
+%files libs
+%dir %{_libdir}/%{name}
+%{_libdir}/%{name}/*.jar
+%{_libdir}/%{name}/mpe*.o
+%{_libdir}/%{name}/*.so.*
+%config %{_sysconfdir}/%{name}-%{mode}/
+%files devel
+%{_bindir}/mp%{mode}-mpicc
+%{_bindir}/mp%{mode}-mpicxx
+%{_bindir}/mp%{mode}-mpif90
+%{_bindir}/mp%{mode}-mpif77
+%{_includedir}/*
+%{_libdir}/%{name}/*.a
+%{_libdir}/%{name}/trace_rlog/libTraceInput.so
+%{_libdir}/pkgconfig/%{name}-ch3.pc
+%{_datadir}/%{name}/%{name}.module
+%{_datadir}/%{name}/bin%{mode}/mpicc
+%{_datadir}/%{name}/bin%{mode}/mpicxx
+%{_datadir}/%{name}/bin%{mode}/mpif90
+%{_datadir}/%{name}/bin%{mode}/mpif77
+%{_datadir}/%{name}/examples*
+%{_datadir}/%{name}/logfiles/
+%{_mandir}/man4/*.gz
+%doc README.testing README.romio README.developer
+%changelog
+* Mon Mar 16 2009 Deji Akingunola <dakingun at gmail.com> - 1.1-0.1
+- Update for the 1.1 (beta) release
+- Stop building with dllchan, it is not fully supported
+* Mon Mar 09 2009 Deji Akingunola <dakingun at gmail.com> - 1.0.8-3
+- Drop the ssm channel from ppc* archs, it fails to build
+- Python scripts in bindir and sbindir are no longer bytecompiled (F-11+)
+- Enhance the spec file to support ia64 and sparc
+- Include mpiexec and mpirun (symlinks) in the environment module bindir
+* Fri Mar 06 2009 Deji Akingunola <dakingun at gmail.com> - 1.0.8-2
+- Fix the source url, pointed out from package review
+- Finally accepted to go into Fedora
+* Sat Oct 24 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.8-1
+- Update to the 1.0.8
+- Configure with the default nemesis channel
+* Fri May 16 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-5
+- Update the alternate compiler/compiler flags macro to allow overriding it
+ from command-line
+* Wed Apr 16 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-4
+- Apply patch from Orion Poplawski to silence rpmlint
+* Tue Apr 15 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-3
+- Add a note on the device/channels configuration options used, and
+- Fix logfile listings as suggested by Orion Poplawski (Package review, 171993)
+* Tue Apr 15 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-2
+* Sat Apr 05 2008 Deji Akingunola <dakingun at gmail.com> - 1.0.7-1
+- Update to 1.0.7
+* Mon Oct 15 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.6p1-1
+- Update to 1.0.6p1
+* Mon Oct 15 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.6-1
+- New version upgrade
+* Mon Jul 31 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-4
+- Create a -mpi-manpages subpackage for the MPI routines manuals
+* Fri Jul 27 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-3
+- Fix java-gcj-compat BR
+- Handle upgrades in the post scripts
+* Mon Jun 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-2
+- Fix typos and make other adjustments arising from Fedora package reviews
+* Mon Jun 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p4-1
+- Patch #4 release
+* Mon Feb 12 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p2-1
+- Patch #2 release
+* Tue Jan 09 2007 Deji Akingunola <dakingun at gmail.com> - 1.0.5p1-1
+- New release with manpages
+- Create a -libs subpackage as it's done in Fedora's openmpi to help with
+ multi-libs packaging
+- Disable modules support (until I can properly figure it out)
+* Wed Dec 27 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.5-1
+- New release
+* Sat Nov 18 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4p1-2
+- Set the java_sdk directory so all java bit work
+* Sat Sep 02 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4p1-1
+- Update to version 1.0.4p1
+- Cleanup up spec file to use alternatives similarly to FC's openmpi
+* Wed Aug 02 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.4-1
+* Thu May 18 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.3-3
+- Add missing BRs (Orion Polawski)
+* Mon Apr 10 2006 Deji Akingunola <dakingun at gmail.com> - 1.0.3-2
+- Rewrite the spec, borrowing extensively from openmpi's spec by Jason Vas Dias
+- Allows use of environment modules and alternatives
+* Fri Nov 25 2005 Deji Akingunola <dakingun at gmail.com> - 1.0.3-1
+- Update to new version
+* Sat Oct 15 2005 Deji Akingunola <deji.aking at gmail.com> - 1.0.2p1-1
+- Initial package
Property changes on: mpich2/trunk/src/packaging/spec/fedora.spec.vin
___________________________________________________________________
More information about the mpich2-commits
