[mpich2-commits] r4171 - in mpich2/trunk/src/pm/hydra: . include pm/pmiserv utils/bind utils/launch utils/string
balaji at mcs.anl.gov
Mon Mar 23 04:20:17 CDT 2009
Author: balaji
Date: 2009-03-23 04:20:17 -0500 (Mon, 23 Mar 2009)
New Revision: 4171
Modified:
mpich2/trunk/src/pm/hydra/README
mpich2/trunk/src/pm/hydra/include/hydra_base.h
mpich2/trunk/src/pm/hydra/include/hydra_utils.h
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
mpich2/trunk/src/pm/hydra/utils/bind/bind.c
mpich2/trunk/src/pm/hydra/utils/launch/allocate.c
mpich2/trunk/src/pm/hydra/utils/string/string.c
Log:
This should allow the user to specify process-core mappings within the
hosts file. This is the most general case of such specification. All
other cases can be implemented using this, but are still provided for
two reasons: (1) convenience and (2) the user might not have all the
required topology information for the system processor architecture.
This should resolve ticket #457.
Modified: mpich2/trunk/src/pm/hydra/README
--- mpich2/trunk/src/pm/hydra/README 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/README 2009-03-23 09:20:17 UTC (rev 4171)
@@ -144,15 +144,18 @@
$ cat hosts
- donner:4 map=1,2,3,4
- foo:4 map=4,3,2,1
+ donner:4 map=0,-1,-1,3
+ foo:4 map=3,2
shakey:2
-Using this method, each host can be given a different mapping. Note
-that the last line does not have any mapping: in this case, the
-processes on that machine are not bound to any core.
+Using this method, each host can be given a different mapping. Any
+unspecified mappings are treated as (-1), referring to no binding.
+Command-line based mappings are given a higher priority than the
+host-file based mappings. So, if a mapping is given at both places,
+the host-file mappings are ignored.
X Forwarding
Modified: mpich2/trunk/src/pm/hydra/include/hydra_base.h
--- mpich2/trunk/src/pm/hydra/include/hydra_base.h 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/include/hydra_base.h 2009-03-23 09:20:17 UTC (rev 4171)
@@ -64,6 +64,7 @@
typedef unsigned short HYD_Event_t;
#define HYD_TMPBUF_SIZE (64 * 1024)
+#define HYD_TMP_STRLEN 1024
#define HYD_NUM_TMP_STRINGS 200
@@ -121,6 +122,7 @@
/* Partition information */
struct HYD_Partition {
char *name;
+ char *user_bind_map;
int total_proc_count;
/* Segment list will contain one-pass of the hosts file */
@@ -136,7 +138,7 @@
int out;
int err;
int exit_status;
- char *proxy_args[HYD_NUM_TMP_STRINGS]; /* Full argument list */
+ char *proxy_args[HYD_NUM_TMP_STRINGS]; /* Full argument list */
struct HYD_Partition *next;
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-23 09:20:17 UTC (rev 4171)
@@ -19,11 +19,11 @@
#include "plpa_internal.h"
HYD_Status HYDU_bind_init(char *user_bind_map);
void HYDU_bind_process(int core);
-int HYDU_next_core(int core, HYD_Binding binding);
+int HYDU_bind_get_core_id(int id, HYD_Binding binding);
#else
#define HYDU_bind_init(...) HYD_SUCCESS
#define HYDU_bind_process(...) HYD_SUCCESS
-#define HYDU_next_core(...) (-1)
+#define HYDU_bind_get_core_id(...) (-1)
#endif /* PROC_BINDING */
@@ -50,6 +50,8 @@
HYD_Status HYDU_alloc_partition_segment(struct HYD_Partition_segment **segment);
HYD_Status HYDU_merge_partition_segment(char *name, struct HYD_Partition_segment *segment,
struct HYD_Partition **partition_list);
+HYD_Status HYDU_merge_partition_mapping(char *name, char *map, int num_procs,
+ struct HYD_Partition **partition_list);
HYD_Status HYDU_alloc_partition_exec(struct HYD_Partition_exec **exec);
HYD_Status HYDU_create_host_list(char *host_file, struct HYD_Partition **partition_list);
HYD_Status HYDU_create_process(char **client_arg, HYD_Env_t * env_list,
@@ -105,6 +107,8 @@
/* Memory utilities */
+#include <ctype.h>
#define HYDU_MALLOC(p, type, size, status) \
(p) = (type) MPIU_Malloc((size)); \
@@ -135,6 +139,7 @@
char *HYDU_int_to_str(int x);
char *HYDU_strerror(int error);
int HYDU_strlist_lastidx(char **strlist);
+char **HYDU_str_to_strlist(char *str);
/* Timer utilities */
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_proxy.c 2009-03-23 09:20:17 UTC (rev 4171)
@@ -73,7 +73,6 @@
/* Spawn the processes */
process_id = 0;
- core = -1;
for (exec = HYD_PMCD_pmi_proxy_params.exec_list; exec; exec = exec->next) {
for (i = 0; i < exec->proc_count; i++) {
@@ -106,7 +105,7 @@
client_args[arg++] = MPIU_Strdup(exec->exec[j]);
client_args[arg++] = NULL;
- core = HYDU_next_core(core, HYD_PMCD_pmi_proxy_params.binding);
+ core = HYDU_bind_get_core_id(process_id, HYD_PMCD_pmi_proxy_params.binding);
if (pmi_id == 0) {
status = HYDU_create_process(client_args, exec->prop_env,
&HYD_PMCD_pmi_proxy_params.in,
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_serv_launch.c 2009-03-23 09:20:17 UTC (rev 4171)
@@ -130,6 +130,8 @@
partition->proxy_args[arg++] = HYDU_int_to_str(handle.binding);
if (handle.user_bind_map)
partition->proxy_args[arg++] = MPIU_Strdup(handle.user_bind_map);
+ else if (partition->user_bind_map)
+ partition->proxy_args[arg++] = MPIU_Strdup(partition->user_bind_map);
else
partition->proxy_args[arg++] = MPIU_Strdup("HYDRA_NO_USER_MAP");
Modified: mpich2/trunk/src/pm/hydra/utils/bind/bind.c
--- mpich2/trunk/src/pm/hydra/utils/bind/bind.c 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/utils/bind/bind.c 2009-03-23 09:20:17 UTC (rev 4171)
@@ -16,8 +16,7 @@
int user_bind_valid;
int *user_bind_map;
-} bind_info = {
-0, -1, -1, -1, NULL, 0, NULL};
+} bind_info;
@@ -139,71 +138,39 @@
-int HYDU_next_core(int old_core, HYD_Binding binding)
- int socket = 0, core = 0;
+ int socket = 0, core = 0, curid, realid;
int i, j;
HYDU_FUNC_ENTER();
if (bind_info.supported) {
+ realid = (id % (bind_info.num_cores * bind_info.num_sockets));
if (binding == HYD_BIND_RR) {
- /* Round-robin is easy; just give the next core */
- return ((old_core + 1) % (bind_info.num_sockets * bind_info.num_cores));
+ return (id % (bind_info.num_sockets * bind_info.num_cores));
else if (binding == HYD_BIND_BUDDY) {
- if (old_core < -1)
- return 0;
- /* First find the old core */
+ /* If we reached the maximum, loop around */
+ curid = 0;
for (core = 0; core < bind_info.num_cores; core++) {
for (socket = 0; socket < bind_info.num_sockets; socket++) {
- if (bind_info.bind_map[socket][core] == old_core)
- break;
+ if (curid == realid)
+ return bind_info.bind_map[socket][core];
+ curid++;
- break;
- /* If there is another socket available after this, give
- * the same core ID on that socket */
- if (socket < bind_info.num_sockets - 1)
- return bind_info.bind_map[socket + 1][core];
- /* If we are the last socket, and there is a core left
- * after ours, give that core on the first socket */
- else if (core < bind_info.num_cores - 1)
- return bind_info.bind_map[0][core + 1];
- /* If we are the last socket and last core, loop back to
- * the start */
- else
- return bind_info.bind_map[0][0];
else if (binding == HYD_BIND_PACK) {
- return 0;
- for (core = 0; core < bind_info.num_cores; core++) {
- for (socket = 0; socket < bind_info.num_sockets; socket++) {
- break;
+ curid = 0;
+ for (socket = 0; socket < bind_info.num_sockets; socket++) {
+ for (core = 0; core < bind_info.num_cores; core++) {
+ curid++;
- break;
- /* If there is another core available after this, give
- * that core ID on the same socket */
- if (core < bind_info.num_cores - 1)
- return bind_info.bind_map[socket][core + 1];
- /* If we are the last core, and there is a socket left
- * after ours, give the first core on that socket */
- else if (socket < bind_info.num_sockets - 1)
- return bind_info.bind_map[socket + 1][0];
- * the start */
- else
else if (binding == HYD_BIND_NONE) {
return -1;
@@ -211,18 +178,8 @@
else if (binding == HYD_BIND_USER) {
if (!bind_info.user_bind_valid)
return -1;
- if (old_core < 0)
- return bind_info.user_bind_map[0];
- for (i = 0; i < ((bind_info.num_cores * bind_info.num_sockets) - 1); i++) {
- if (bind_info.user_bind_map[i] == old_core) {
- j = ((i + 1) % (bind_info.num_cores * bind_info.num_sockets));
- return bind_info.user_bind_map[j];
- else if (bind_info.user_bind_map[i] == -1)
- return -1;
+ else
+ return bind_info.user_bind_map[realid];
else {
Modified: mpich2/trunk/src/pm/hydra/utils/launch/allocate.c
--- mpich2/trunk/src/pm/hydra/utils/launch/allocate.c 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/utils/launch/allocate.c 2009-03-23 09:20:17 UTC (rev 4171)
@@ -14,6 +14,7 @@
HYDU_MALLOC(*partition, struct HYD_Partition *, sizeof(struct HYD_Partition), status);
(*partition)->name = NULL;
+ (*partition)->user_bind_map = NULL;
(*partition)->segment_list = NULL;
(*partition)->total_proc_count = 0;
@@ -96,6 +97,8 @@
tpartition = partition->next;
HYDU_FREE(partition->name);
+ if (partition->user_bind_map)
+ HYDU_FREE(partition->user_bind_map);
segment = partition->segment_list;
while (segment) {
@@ -198,12 +201,129 @@
-HYD_Status HYDU_alloc_partition_exec(struct HYD_Partition_exec ** exec)
+static int count_elements(char *str, char *delim)
+ int count;
+ HYDU_FUNC_ENTER();
+ strtok(str, delim);
+ count = 1;
+ while (strtok(NULL, delim))
+ count++;
+ HYDU_FUNC_EXIT();
+ return count;
+static char *pad_string(char *str, char *pad, int count)
+ char *tmp[HYD_NUM_TMP_STRINGS], *out;
+ int i, j;
HYD_Status status = HYD_SUCCESS;
HYDU_FUNC_ENTER();
+ i = 0;
+ tmp[i++] = MPIU_Strdup(str);
+ for (j = 0; j < count; j++)
+ tmp[i++] = MPIU_Strdup(pad);
+ tmp[i] = NULL;
+ status = HYDU_str_alloc_and_join(tmp, &out);
+ HYDU_ERR_POP(status, "unable to join strings\n");
+ HYDU_free_strlist(tmp);
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return out;
+ fn_fail:
+ goto fn_exit;
+ struct HYD_Partition *partition;
+ char *tmp[HYD_NUM_TMP_STRINGS], *x;
+ int i, count;
+ HYD_Status status = HYD_SUCCESS;
+ if (*partition_list == NULL) {
+ HYDU_alloc_partition(partition_list);
+ (*partition_list)->name = MPIU_Strdup(name);
+ x = MPIU_Strdup(map);
+ count = num_procs - count_elements(x, ",");
+ HYDU_FREE(x);
+ (*partition_list)->user_bind_map = pad_string(map, ",-1", count);
+ else {
+ partition = *partition_list;
+ while (partition) {
+ if (strcmp(partition->name, name) == 0) {
+ /* Found a partition with the same name; append */
+ if (partition->user_bind_map == NULL) {
+ HYDU_FREE(x);
+ partition->user_bind_map = pad_string(map, ",-1", count);
+ else {
+ HYDU_FREE(x);
+ i = 0;
+ tmp[i++] = MPIU_Strdup(partition->user_bind_map);
+ tmp[i++] = MPIU_Strdup(",");
+ tmp[i++] = pad_string(map, ",-1", count);
+ tmp[i++] = NULL;
+ status = HYDU_str_alloc_and_join(tmp, &partition->user_bind_map);
+ break;
+ else if (partition->next == NULL) {
+ HYDU_alloc_partition(&partition->next);
+ partition->next->name = MPIU_Strdup(name);
+ partition->next->user_bind_map = MPIU_Strdup(map);
+ break;
+ else {
+ partition = partition->next;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
+HYD_Status HYDU_alloc_partition_exec(struct HYD_Partition_exec **exec)
HYDU_MALLOC(*exec, struct HYD_Partition_exec *, sizeof(struct HYD_Partition_exec), status);
(*exec)->exec[0] = NULL;
(*exec)->proc_count = 0;
@@ -223,8 +343,9 @@
FILE *fp = NULL;
- char line[2 * MAX_HOSTNAME_LEN], *hostname, *procs;
- int num_procs, total_count;
+ char line[HYD_TMP_STRLEN], *hostname, *procs, **arg_list;
+ char *str[2] = { NULL };
+ int num_procs, total_count, arg, i;
struct HYD_Partition_segment *segment;
@@ -246,15 +367,10 @@
"unable to open host file: %s\n", host_file);
total_count = 0;
- while (!feof(fp)) {
- line[0] = 0;
- if ((fscanf(fp, "%s", line) < 0) && errno)
- HYDU_ERR_SETANDJUMP1(status, HYD_INTERNAL_ERROR,
- "unable to read input line (errno: %d)\n", errno);
- if (line[0] == 0)
- break;
+ while (fgets(line, HYD_TMP_STRLEN, fp)) {
+ arg_list = HYDU_str_to_strlist(line);
- hostname = strtok(line, ":");
+ hostname = strtok(arg_list[0], ":");
procs = strtok(NULL, ":");
num_procs = procs ? atoi(procs) : 1;
@@ -264,15 +380,34 @@
HYDU_alloc_partition_segment(&segment);
segment->start_pid = total_count;
segment->proc_count = num_procs;
- HYDU_merge_partition_segment(hostname, segment, partition_list);
+ status = HYDU_merge_partition_segment(hostname, segment, partition_list);
+ HYDU_ERR_POP(status, "merge partition segment failed\n");
total_count += num_procs;
+ /* Check for the remaining parameters */
+ arg = 1;
+ while (arg_list[arg]) {
+ status = HYDU_strsplit(arg_list[arg], &str[0], &str[1], '=');
+ HYDU_ERR_POP(status, "unable to split string\n");
+ if (!strcmp(str[0], "map")) {
+ status = HYDU_merge_partition_mapping(hostname, str[1], num_procs,
+ partition_list);
+ HYDU_ERR_POP(status, "merge partition mapping failed\n");
+ arg++;
fclose(fp);
fn_exit:
+ for (i = 0; i < 2; i++)
+ if (str[i])
+ HYDU_FREE(str[i]);
HYDU_FUNC_EXIT();
return status;
Modified: mpich2/trunk/src/pm/hydra/utils/string/string.c
--- mpich2/trunk/src/pm/hydra/utils/string/string.c 2009-03-23 06:36:59 UTC (rev 4170)
+++ mpich2/trunk/src/pm/hydra/utils/string/string.c 2009-03-23 09:20:17 UTC (rev 4171)
@@ -59,8 +59,9 @@
HYDU_FUNC_ENTER();
- for (i = 0; strlist[i] != NULL; i++)
+ for (i = 0; strlist[i] != NULL; i++) {
len += strlen(strlist[i]);
HYDU_MALLOC(*strjoin, char *, len + 1, status);
count = 0;
@@ -168,3 +169,43 @@
return i;
+ int argc = 0;
+ char **strlist;
+ char *p, *r;
+ HYDU_MALLOC(strlist, char **, HYD_NUM_TMP_STRINGS * sizeof(char *), status);
+ p = str;
+ while (*p) {
+ while (isspace(*p))
+ p++;
+ if (argc >= HYD_NUM_TMP_STRINGS)
+ HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "too many arguments in line\n");
+ /* Make a copy and NULL terminate it */
+ strlist[argc] = MPIU_Strdup(p);
+ r = strlist[argc];
+ while (*r && !isspace(*r))
+ r++;
+ *r = 0;
+ while (*p && !isspace(*p))
+ p++;
+ argc++;
+ strlist[argc] = NULL;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return strlist;
+ fn_fail:
+ goto fn_exit;
More information about the mpich2-commits
