[mpich2-commits] r4161 - in mpich2/trunk/src/pm/hydra/launcher: mpiexec utils
balaji at mcs.anl.gov
Sun Mar 22 15:25:45 CDT 2009
Author: balaji
Date: 2009-03-22 15:25:45 -0500 (Sun, 22 Mar 2009)
New Revision: 4161
Modified:
mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
Log:
Some more fixes to the environment passing. This time for environment
variables that are local for each executable.
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-22 18:09:06 UTC (rev 4160)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-22 20:25:45 UTC (rev 4161)
@@ -32,7 +32,7 @@
HYD_Status HYD_LCHI_get_parameters(char **t_argv)
- int i, env_pref;
+ int i;
char **argv = t_argv;
char *env_name, *env_value, *str1, *str2, *progname = *argv;
HYD_Env_t *env;
@@ -279,8 +279,10 @@
status = HYDU_get_base_path(progname, handle.wdir, &handle.base_path);
HYDU_ERR_POP(status, "unable to get base path\n");
+ if (handle.prop == HYD_ENV_PROP_UNSET)
+ handle.prop = HYD_ENV_PROP_ALL;
/* Check if any individual app has an environment preference */
- env_pref = 0;
for (exec_info = handle.exec_info_list; exec_info; exec_info = exec_info->next) {
if (exec_info->exec[0] == NULL)
HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "no executable specified\n");
@@ -288,21 +290,11 @@
if (exec_info->exec_proc_count == 0)
exec_info->exec_proc_count = 1;
- if (handle.prop == HYD_ENV_PROP_UNSET && exec_info->prop != HYD_ENV_PROP_UNSET)
- env_pref = 1;
+ /* If no local env property is set, use the global one */
+ if (exec_info->prop == HYD_ENV_PROP_UNSET)
+ exec_info->prop = handle.prop;
- /* Only if someone has an individual preference, assign executable
- * specific environment. Otherwise, just optimize by setting one
- * global environment (common case). */
- if (env_pref) {
- for (exec_info = handle.exec_info_list; exec_info; exec_info = exec_info->next)
- if (exec_info->prop == HYD_ENV_PROP_UNSET)
- exec_info->prop = HYD_ENV_PROP_ALL;
- else if (handle.prop == HYD_ENV_PROP_UNSET)
- handle.prop = HYD_ENV_PROP_ALL;
if (handle.proxy_port == -1)
handle.proxy_port = HYD_DEFAULT_PROXY_PORT;
Modified: mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
--- mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-22 18:09:06 UTC (rev 4160)
+++ mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-22 20:25:45 UTC (rev 4161)
@@ -113,6 +113,12 @@
HYDU_ERR_POP(status, "unable to add env to list\n");
+ else if (handle.prop == HYD_ENV_PROP_NONE) {
+ for (env = handle.user_env; env; env = env->next) {
+ status = HYDU_append_env_to_list(*env, &handle.prop_env);
+ HYDU_ERR_POP(status, "unable to add env to list\n");
else if (handle.prop == HYD_ENV_PROP_LIST) {
run = HYDU_env_lookup(*env, handle.global_env);
@@ -132,6 +138,12 @@
+ else if (exec_info->prop == HYD_ENV_PROP_NONE) {
+ for (env = exec_info->user_env; env; env = env->next) {
+ status = HYDU_append_env_to_list(*env, &exec_info->prop_env);
else if (exec_info->prop == HYD_ENV_PROP_LIST) {
More information about the mpich2-commits
