[mpich2-commits] r4149 - in mpich2/trunk/src/pm/hydra: include launcher/mpiexec launcher/utils utils/env
balaji at mcs.anl.gov
Fri Mar 20 14:35:46 CDT 2009
Author: balaji
Date: 2009-03-20 14:35:46 -0500 (Fri, 20 Mar 2009)
New Revision: 4149
Modified:
mpich2/trunk/src/pm/hydra/include/hydra_base.h
mpich2/trunk/src/pm/hydra/include/hydra_utils.h
mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.h
mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
mpich2/trunk/src/pm/hydra/launcher/utils/lchu.h
mpich2/trunk/src/pm/hydra/utils/env/env.c
Log:
Refactored the launcher code to reduce duplication. Also moved out all
functionality that will likely be common to other launchers, to the
utilities.
Modified: mpich2/trunk/src/pm/hydra/include/hydra_base.h
--- mpich2/trunk/src/pm/hydra/include/hydra_base.h 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/include/hydra_base.h 2009-03-20 19:35:46 UTC (rev 4149)
@@ -92,6 +92,12 @@
+#define HYDU_ERR_CHKANDJUMP(status, chk, error, message) \
+ if ((chk)) \
+ HYDU_ERR_SETANDJUMP(status, error, message); \
#define HYDU_ERR_SETANDJUMP1(status, error, message, arg1) \
status = error; \
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-20 19:35:46 UTC (rev 4149)
@@ -33,6 +33,7 @@
HYD_Env_t *HYDU_env_lookup(HYD_Env_t env, HYD_Env_t * env_list);
HYD_Status HYDU_append_env_to_list(HYD_Env_t env, HYD_Env_t ** env_list);
void HYDU_putenv(char *env_str);
+HYD_Status HYDU_comma_list_to_env_list(char *str, HYD_Env_t **env_list);
/* launch */
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c 2009-03-20 19:35:46 UTC (rev 4149)
@@ -55,7 +55,7 @@
HYDU_FUNC_ENTER();
- status = HYD_LCHI_get_parameters(argc, argv);
+ status = HYD_LCHI_get_parameters(argv);
if (status == HYD_GRACEFUL_ABORT) {
exit(0);
@@ -65,7 +65,7 @@
if (handle.debug)
- HYD_LCHI_print_parameters();
+ HYD_LCHU_print_params();
/* Convert the host file to a host list */
status = HYD_LCHU_create_host_list();
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.h
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.h 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.h 2009-03-20 19:35:46 UTC (rev 4149)
@@ -9,8 +9,7 @@
#include "hydra.h"
-HYD_Status HYD_LCHI_get_parameters(int t_argc, char **t_argv);
-void HYD_LCHI_print_parameters(void);
+HYD_Status HYD_LCHI_get_parameters(char **t_argv);
HYD_Status HYD_LCHI_stdout_cb(int fd, HYD_Event_t events);
HYD_Status HYD_LCHI_stderr_cb(int fd, HYD_Event_t events);
HYD_Status HYD_LCHI_stdin_cb(int fd, HYD_Event_t events);
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-20 19:35:46 UTC (rev 4149)
@@ -14,73 +14,14 @@
HYD_Handle handle;
-#define CHECK_NEXT_ARG_VALID(status) \
- --argc; ++argv; \
- if (!argc || !argv) { \
- (status) = HYD_INTERNAL_ERROR; \
- goto fn_fail; \
+#define INCREMENT_ARGV(status) \
+ if (!(++argv)) { \
+ (status) = HYD_INTERNAL_ERROR; \
+ goto fn_fail; \
-static HYD_Status allocate_proc_params(struct HYD_Proc_params **params)
- struct HYD_Proc_params *proc_params;
- HYD_Status status = HYD_SUCCESS;
- HYDU_FUNC_ENTER();
- HYDU_MALLOC(proc_params, struct HYD_Proc_params *, sizeof(struct HYD_Proc_params), status);
- proc_params->exec_proc_count = 0;
- proc_params->partition = NULL;
- proc_params->exec[0] = NULL;
- proc_params->user_env = NULL;
- proc_params->prop = HYD_ENV_PROP_UNSET;
- proc_params->prop_env = NULL;
- proc_params->stdout_cb = NULL;
- proc_params->stderr_cb = NULL;
- proc_params->next = NULL;
- *params = proc_params;
- fn_exit:
- HYDU_FUNC_EXIT();
- return status;
- fn_fail:
- goto fn_exit;
-static HYD_Status get_current_proc_params(struct HYD_Proc_params **params)
- if (handle.proc_params == NULL) {
- status = allocate_proc_params(&handle.proc_params);
- HYDU_ERR_POP(status, "unable to allocate proc_params\n");
- proc_params = handle.proc_params;
- while (proc_params->next)
- proc_params = proc_params->next;
- fn_exit:
- HYDU_FUNC_EXIT();
- return status;
- fn_fail:
- goto fn_exit;
static void show_version(void)
printf("MPICH2 Version: %s\n", MPICH2_VERSION);
@@ -89,9 +30,9 @@
- int argc = t_argc, i;
+ int i;
char **argv = t_argv;
char *env_name, *env_value, *str1, *str2, *progname = *argv;
HYD_Env_t *env;
@@ -105,190 +46,178 @@
status = HYDU_list_global_env(&handle.global_env);
HYDU_ERR_POP(status, "unable to get the global env list\n");
- while (--argc && ++argv) {
+ while (++argv) {
- status = HYDU_strsplit(*argv, &str1, &str2, '=');
- HYDU_ERR_POP(status, "string break returned error\n");
- if (!strcmp(str1, "-h") || !strcmp(str1, "--help") || !strcmp(str1, "-help"))
+ if (!strcmp(*argv, "-h") || !strcmp(*argv, "-help") || !strcmp(*argv, "--help"))
HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "");
- if (!strcmp(str1, "--verbose")) {
- if (handle.debug != -1)
- HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "duplicate debug level\n");
+ if (!strcmp(*argv, "--version")) {
+ show_version();
+ HYDU_ERR_SETANDJUMP(status, HYD_GRACEFUL_ABORT, "");
+ if (!strcmp(*argv, "--verbose")) {
+ HYDU_ERR_CHKANDJUMP(status, handle.debug != -1, HYD_INTERNAL_ERROR,
+ "duplicate debug level\n");
handle.debug = 1;
continue;
- if (!strcmp(str1, "--version")) {
- show_version();
- HYDU_ERR_SETANDJUMP(status, HYD_GRACEFUL_ABORT, "");
+ if (!strcmp(*argv, "--enable-x") || !strcmp(*argv, "--disable-x")) {
+ HYDU_ERR_CHKANDJUMP(status, handle.enablex != -1, HYD_INTERNAL_ERROR,
+ "duplicate enable-x\n");
+ handle.enablex = !strcmp(*argv, "--enable-x");
+ continue;
- if (!strcmp(str1, "--bootstrap")) {
- if (!str2) {
- CHECK_NEXT_ARG_VALID(status);
- str2 = *argv;
- if (handle.bootstrap != NULL)
- HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "duplicate bootstrap\n");
- handle.bootstrap = MPIU_Strdup(str2);
+ if (!strcmp(*argv, "-genvall")) {
+ HYDU_ERR_CHKANDJUMP(status, handle.prop != HYD_ENV_PROP_UNSET,
+ HYD_INTERNAL_ERROR, "duplicate prop setting\n");
+ handle.prop = HYD_ENV_PROP_ALL;
continue;
- if (!strcmp(str1, "--enable-x") || !strcmp(str1, "--disable-x")) {
- if (handle.enablex != -1)
- HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "duplicate enable-x\n");
- handle.enablex = !strcmp(str1, "--enable-x");
+ if (!strcmp(*argv, "-genvnone")) {
+ handle.prop = HYD_ENV_PROP_NONE;
continue;
- if (!strcmp(str1, "--proxy-port")) {
- if (!str2) {
- str2 = *argv;
- if (handle.proxy_port != -1)
- HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "duplicate proxy port\n");
- handle.proxy_port = atoi(str2);
+ if (!strcmp(*argv, "-genvlist")) {
+ handle.prop = HYD_ENV_PROP_LIST;
+ INCREMENT_ARGV(status);
+ HYDU_comma_list_to_env_list(*argv, &handle.user_env);
continue;
- if (!strcmp(str1, "-genvall") || !strcmp(str1, "-genvnone") ||
- !strcmp(str1, "-genvlist")) {
- if (handle.prop != HYD_ENV_PROP_UNSET)
- HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "duplicate prop setting\n");
+ if (!strcmp(*argv, "-genv")) {
+ env_name = MPIU_Strdup(*argv);
+ env_value = MPIU_Strdup(*argv);
- if (!strcmp(str1, "-genvall"))
- handle.prop = HYD_ENV_PROP_ALL;
- else if (!strcmp(str1, "-genvnone"))
- handle.prop = HYD_ENV_PROP_NONE;
- else if (!strcmp(str1, "-genvlist")) {
- handle.prop = HYD_ENV_PROP_LIST;
+ status = HYDU_env_create(&env, env_name, env_value);
+ HYDU_ERR_POP(status, "unable to create env struct\n");
- if (!str2) {
- str2 = *argv;
+ HYDU_append_env_to_list(*env, &handle.user_env);
+ continue;
- env_name = strtok(str2, ",");
- do {
- status = HYDU_env_create(&env, env_name, NULL);
- HYDU_ERR_POP(status, "unable to create env struct\n");
+ if (!strcmp(*argv, "-envall")) {
+ status = HYD_LCHU_get_current_proc_params(&proc_params);
+ HYDU_ERR_POP(status, "get_current_proc_params returned error\n");
- status = HYDU_append_env_to_list(*env, &handle.user_env);
- HYDU_ERR_POP(status, "unable to add env to list\n");
- } while ((env_name = strtok(NULL, ",")));
+ HYDU_ERR_CHKANDJUMP(status, proc_params->prop != HYD_ENV_PROP_UNSET,
+ proc_params->prop = HYD_ENV_PROP_ALL;
continue;
- if (!strcmp(str1, "-envall") || !strcmp(str1, "-envnone") ||
- !strcmp(str1, "-envlist")) {
- status = get_current_proc_params(&proc_params);
+ if (!strcmp(*argv, "-envnone")) {
- if (proc_params->prop != HYD_ENV_PROP_UNSET)
+ proc_params->prop = HYD_ENV_PROP_NONE;
+ continue;
- if (!strcmp(str1, "-envall"))
- proc_params->prop = HYD_ENV_PROP_ALL;
- else if (!strcmp(str1, "-envnone"))
- proc_params->prop = HYD_ENV_PROP_NONE;
- else if (!strcmp(str1, "-envlist")) {
- proc_params->prop = HYD_ENV_PROP_LIST;
+ if (!strcmp(*argv, "-envlist")) {
- if (!str2) {
- str2 = *argv;
+ proc_params->prop = HYD_ENV_PROP_LIST;
- do {
- if (env_name == NULL)
- break;
- status = HYDU_append_env_to_list(*env, &proc_params->prop_env);
- } while (env_name);
+ HYDU_comma_list_to_env_list(*argv, &proc_params->user_env);
continue;
- /* Add additional environment variables */
- if (!strcmp(str1, "-genv") || !strcmp(str1, "-env")) {
- if (!str2) {
- str2 = *argv;
- env_name = MPIU_Strdup(str2);
+ if (!strcmp(*argv, "-env")) {
- if (!strcmp(str1, "-genv"))
- HYDU_append_env_to_list(*env, &handle.user_env);
- else {
- HYDU_ERR_POP(status, "get_current_proc_params returned error\n");
- HYDU_append_env_to_list(*env, &proc_params->user_env);
- HYDU_FREE(env);
+ HYDU_append_env_to_list(*env, &proc_params->user_env);
continue;
- if (!strcmp(str1, "-wdir")) {
- if (!str2) {
- str2 = *argv;
- handle.wdir = MPIU_Strdup(str2);
+ if (!strcmp(*argv, "-wdir")) {
+ handle.wdir = MPIU_Strdup(*argv);
continue;
- if (!strcmp(str1, "-n") || !strcmp(str1, "-np")) {
- if (!str2) {
- str2 = *argv;
+ if (!strcmp(*argv, "-n") || !strcmp(*argv, "-np")) {
if (proc_params->exec_proc_count != 0)
HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "duplicate proc count\n");
- proc_params->exec_proc_count = atoi(str2);
+ proc_params->exec_proc_count = atoi(*argv);
continue;
- if (!strcmp(str1, "-f")) {
+ if (!strcmp(*argv, "-f")) {
+ handle.host_file = MPIU_Strdup(*argv);
+ continue;
+ /* The below options allow for "--foo=x" form of argument,
+ * instead of "--foo x" for convenience. */
+ status = HYDU_strsplit(*argv, &str1, &str2, '=');
+ HYDU_ERR_POP(status, "string break returned error\n");
+ if (!strcmp(str1, "--bootstrap")) {
if (!str2) {
str2 = *argv;
- handle.host_file = MPIU_Strdup(str2);
+ HYDU_ERR_CHKANDJUMP(status, handle.bootstrap, HYD_INTERNAL_ERROR,
+ "duplicate bootstrap server\n");
+ handle.bootstrap = MPIU_Strdup(str2);
continue;
+ if (!strcmp(str1, "--proxy-port")) {
+ if (!str2) {
+ str2 = *argv;
+ HYDU_ERR_CHKANDJUMP(status, handle.proxy_port != -1, HYD_INTERNAL_ERROR,
+ "duplicate proxy port\n");
+ handle.proxy_port = atoi(str2);
+ continue;
if (*argv[0] == '-')
HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "unrecognized argument\n");
/* Read the executable till you hit the end of a ":" */
do {
if (!strcmp(*argv, ":")) { /* Next executable */
- status = allocate_proc_params(&proc_params->next);
+ status = HYD_LCHU_allocate_proc_params(&proc_params->next);
HYDU_ERR_POP(status, "allocate_proc_params returned error\n");
break;
@@ -298,9 +227,9 @@
i++;
proc_params->exec[i] = MPIU_Strdup(*argv);
proc_params->exec[i + 1] = NULL;
- } while (--argc && ++argv);
+ } while (++argv && *argv);
+ if (!(*argv))
break;
continue;
@@ -319,23 +248,11 @@
"allocated space is too small for absolute path\n");
- * We use the following priority order to specify the bootstrap server:
- * 1. Specified to mpiexec using --bootstrap
- * 2. Specified through the environment HYDRA_BOOTSTRAP
- * 3. If nothing is given, we use the default bootstrap server
if (handle.bootstrap == NULL && getenv("HYDRA_BOOTSTRAP"))
handle.bootstrap = MPIU_Strdup(getenv("HYDRA_BOOTSTRAP"));
if (handle.bootstrap == NULL)
handle.bootstrap = MPIU_Strdup(HYDRA_DEFAULT_BSS);
- * We use the following priority order to specify the host file:
- * 1. Specified to mpiexec using -f
- * 2. Specified through the environment HYDRA_HOST_FILE
- * 3. If nothing is given, we use the local host
if (handle.host_file == NULL && getenv("HYDRA_HOST_FILE"))
handle.host_file = MPIU_Strdup(getenv("HYDRA_HOST_FILE"));
if (handle.host_file == NULL)
@@ -368,92 +285,3 @@
fn_fail:
goto fn_exit;
- HYD_Env_t *env;
- int i, j;
- struct HYD_Partition_list *partition;
- HYDU_Debug("\n");
- HYDU_Debug("=================================================");
- HYDU_Debug("\n");
- HYDU_Debug("mpiexec options:\n");
- HYDU_Debug("----------------\n");
- HYDU_Debug(" Base path: %s\n", handle.base_path);
- HYDU_Debug(" Proxy port: %d\n", handle.proxy_port);
- HYDU_Debug(" Bootstrap server: %s\n", handle.bootstrap);
- HYDU_Debug(" Debug level: %d\n", handle.debug);
- HYDU_Debug(" Enable X: %d\n", handle.enablex);
- HYDU_Debug(" Working dir: %s\n", handle.wdir);
- HYDU_Debug(" Host file: %s\n", handle.host_file);
- HYDU_Debug("\n");
- HYDU_Debug(" Global environment:\n");
- HYDU_Debug(" -------------------\n");
- for (env = handle.global_env; env; env = env->next)
- HYDU_Debug(" %s=%s\n", env->env_name, env->env_value);
- if (handle.system_env) {
- HYDU_Debug("\n");
- HYDU_Debug(" Hydra internal environment:\n");
- HYDU_Debug(" ---------------------------\n");
- for (env = handle.system_env; env; env = env->next)
- if (handle.user_env) {
- HYDU_Debug("\n");
- HYDU_Debug(" User set environment:\n");
- HYDU_Debug(" ---------------------\n");
- for (env = handle.user_env; env; env = env->next)
- HYDU_Debug("\n\n");
- HYDU_Debug(" Process parameters:\n");
- HYDU_Debug(" *******************\n");
- i = 1;
- for (proc_params = handle.proc_params; proc_params; proc_params = proc_params->next) {
- HYDU_Debug(" Executable ID: %2d\n", i++);
- HYDU_Debug(" -----------------\n");
- HYDU_Debug(" Process count: %d\n", proc_params->exec_proc_count);
- HYDU_Debug(" Executable: ");
- for (j = 0; proc_params->exec[j]; j++)
- HYDU_Debug("%s ", proc_params->exec[j]);
- HYDU_Debug("\n");
- if (proc_params->user_env) {
- HYDU_Debug("\n");
- HYDU_Debug(" .....................\n");
- for (env = proc_params->user_env; env; env = env->next)
- j = 0;
- for (partition = proc_params->partition; partition; partition = partition->next) {
- HYDU_Debug("\n");
- HYDU_Debug(" Partition ID: %2d\n", j++);
- HYDU_Debug(" ----------------\n");
- HYDU_Debug(" Partition name: %s\n", partition->name);
- HYDU_Debug(" Partition process count: %d\n", partition->proc_count);
- HYDU_Debug("\n");
- HYDU_Debug("\n");
- HYDU_FUNC_EXIT();
- return;
Modified: mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
--- mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-20 19:35:46 UTC (rev 4149)
@@ -304,3 +304,150 @@
fn_fail:
goto fn_exit;
+void HYD_LCHU_print_params(void)
+ HYD_Env_t *env;
+ int i, j;
+ struct HYD_Proc_params *proc_params;
+ struct HYD_Partition_list *partition;
+ HYDU_FUNC_ENTER();
+ HYDU_Debug("\n");
+ HYDU_Debug("=================================================");
+ HYDU_Debug("\n");
+ HYDU_Debug("mpiexec options:\n");
+ HYDU_Debug("----------------\n");
+ HYDU_Debug(" Base path: %s\n", handle.base_path);
+ HYDU_Debug(" Proxy port: %d\n", handle.proxy_port);
+ HYDU_Debug(" Bootstrap server: %s\n", handle.bootstrap);
+ HYDU_Debug(" Debug level: %d\n", handle.debug);
+ HYDU_Debug(" Enable X: %d\n", handle.enablex);
+ HYDU_Debug(" Working dir: %s\n", handle.wdir);
+ HYDU_Debug(" Host file: %s\n", handle.host_file);
+ HYDU_Debug("\n");
+ HYDU_Debug(" Global environment:\n");
+ HYDU_Debug(" -------------------\n");
+ for (env = handle.global_env; env; env = env->next)
+ HYDU_Debug(" %s=%s\n", env->env_name, env->env_value);
+ if (handle.system_env) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" Hydra internal environment:\n");
+ HYDU_Debug(" ---------------------------\n");
+ for (env = handle.system_env; env; env = env->next)
+ if (handle.user_env) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" User set environment:\n");
+ HYDU_Debug(" ---------------------\n");
+ for (env = handle.user_env; env; env = env->next)
+ HYDU_Debug("\n\n");
+ HYDU_Debug(" Process parameters:\n");
+ HYDU_Debug(" *******************\n");
+ i = 1;
+ for (proc_params = handle.proc_params; proc_params; proc_params = proc_params->next) {
+ HYDU_Debug(" Executable ID: %2d\n", i++);
+ HYDU_Debug(" -----------------\n");
+ HYDU_Debug(" Process count: %d\n", proc_params->exec_proc_count);
+ HYDU_Debug(" Executable: ");
+ for (j = 0; proc_params->exec[j]; j++)
+ HYDU_Debug("%s ", proc_params->exec[j]);
+ HYDU_Debug("\n");
+ if (proc_params->user_env) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" .....................\n");
+ for (env = proc_params->user_env; env; env = env->next)
+ j = 0;
+ for (partition = proc_params->partition; partition; partition = partition->next) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" Partition ID: %2d\n", j++);
+ HYDU_Debug(" ----------------\n");
+ HYDU_Debug(" Partition name: %s\n", partition->name);
+ HYDU_Debug(" Partition process count: %d\n", partition->proc_count);
+ HYDU_Debug("\n");
+ HYDU_Debug("\n");
+ HYDU_FUNC_EXIT();
+ return;
+HYD_Status HYD_LCHU_allocate_proc_params(struct HYD_Proc_params **params)
+ HYD_Status status = HYD_SUCCESS;
+ HYDU_MALLOC(proc_params, struct HYD_Proc_params *, sizeof(struct HYD_Proc_params), status);
+ proc_params->exec_proc_count = 0;
+ proc_params->partition = NULL;
+ proc_params->exec[0] = NULL;
+ proc_params->user_env = NULL;
+ proc_params->prop = HYD_ENV_PROP_UNSET;
+ proc_params->prop_env = NULL;
+ proc_params->stdout_cb = NULL;
+ proc_params->stderr_cb = NULL;
+ proc_params->next = NULL;
+ *params = proc_params;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
+HYD_Status HYD_LCHU_get_current_proc_params(struct HYD_Proc_params **params)
+ if (handle.proc_params == NULL) {
+ status = HYD_LCHU_allocate_proc_params(&handle.proc_params);
+ HYDU_ERR_POP(status, "unable to allocate proc_params\n");
+ proc_params = handle.proc_params;
+ while (proc_params->next)
+ proc_params = proc_params->next;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
Modified: mpich2/trunk/src/pm/hydra/launcher/utils/lchu.h
--- mpich2/trunk/src/pm/hydra/launcher/utils/lchu.h 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/launcher/utils/lchu.h 2009-03-20 19:35:46 UTC (rev 4149)
@@ -14,5 +14,8 @@
void HYD_LCHU_free_proc_params(void);
HYD_Status HYD_LCHU_create_host_list(void);
HYD_Status HYD_LCHU_create_env_list(void);
+void HYD_LCHU_print_params(void);
+HYD_Status HYD_LCHU_allocate_proc_params(struct HYD_Proc_params **params);
+HYD_Status HYD_LCHU_get_current_proc_params(struct HYD_Proc_params **params);
#endif /* LCHU_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/utils/env/env.c
--- mpich2/trunk/src/pm/hydra/utils/env/env.c 2009-03-20 18:09:24 UTC (rev 4148)
+++ mpich2/trunk/src/pm/hydra/utils/env/env.c 2009-03-20 19:35:46 UTC (rev 4149)
@@ -296,3 +296,29 @@
HYDU_FUNC_EXIT();
return;
+ char *env_name;
+ HYD_Env_t *env;
+ env_name = strtok(str, ",");
+ do {
+ status = HYDU_env_create(&env, env_name, NULL);
+ status = HYDU_append_env_to_list(*env, env_list);
+ HYDU_ERR_POP(status, "unable to add env to list\n");
+ } while ((env_name = strtok(NULL, ",")));
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
More information about the mpich2-commits
