[mpich2-commits] r4146 - mpich2/trunk/confdb
gropp at mcs.anl.gov
Fri Mar 20 12:00:18 CDT 2009
Author: gropp
Date: 2009-03-20 12:00:18 -0500 (Fri, 20 Mar 2009)
New Revision: 4146
Removed:
mpich2/trunk/confdb/libtool-2.13.m4
mpich2/trunk/confdb/libtool.m4
mpich2/trunk/confdb/ltmain-2.13.sh
mpich2/trunk/confdb/ltmain.sh
Modified:
mpich2/trunk/confdb/README
mpich2/trunk/confdb/aclocal.m4
Log:
Updated the README for confdb with a history and file manifest; removed old libtool files
Modified: mpich2/trunk/confdb/README
--- mpich2/trunk/confdb/README 2009-03-20 16:22:43 UTC (rev 4145)
+++ mpich2/trunk/confdb/README 2009-03-20 17:00:18 UTC (rev 4146)
@@ -1,4 +1,68 @@
-This directory contains autoconf version 2 (2.13) aclocal.m4 files
+This directory contains extensions and other support for GNU autoconf.
They are organized by category, so that you can include subsets in your own
aclocal.m4 files if you prefer (the aclocal.m4 file here includes them
all).
+File Manifest
+Makefile.in - Makefile to build documentation on these macros;
+ requires doctext
+README - This file
+acconfig.h.in - Needed to make autoheader read the other acconfig files
+acconfig_cc.h - Define names needed by autoheader for aclocal_cc.m4
+acconfig_f77.h - Define names needed by autoheader for aclocal_f77.m4
+acconfig_mpi.h - Define names needed by autoheader for aclocal_mpi.m4
+aclangf90.m4 - Fortran 90 support for autoconf 2.52
+aclocal.m4 - Master aclocal file that includes the others
+aclocal_am.m4 - Macros for Automake compatibility
+aclocal_atomic.m4 - Macros for processor-atomic operations
+aclocal_bugfix.m4 - Bug fixes for autoconf macros, including a few extensions
+aclocal_cache.m4 - Bug fixes for result caching in autoconf (from 2.13)
+aclocal_cc.m4 - Macros for C
+aclocal_cross.m4 - Macros for cross-compilation
+aclocal_csharp.m4 - Macros for C#
+aclocal_cxx.m4 - Macros for C++
+aclocal_enable.m4 - Experimental support for AC_ARG_ENABLE.
+aclocal_f77.m4 - Macros for Fortran 77
+aclocal_f90.m4 - Fortran 90 support for autoconf 2.x for x < 52
+aclocal_java.m4 - Macros for Java
+aclocal_make.m4 - Macros for Make
+aclocal_mpi.m4 - Macros for MPI
+aclocal_perl.m4 - Macros for PERL
+aclocal_shl.m4 - Macros for shared libraries
+aclocal_subcfg.m4 - Special support for subdirectory configures in MPICH2
+aclocal_util.m4 - Miscellaneous macros
+aclocal_web.m4 - Macros for web-based documentation
+config.guess - Autoconf support file (needed to run autoconf)
+config.sub - Autoconf support file (needed to run autoconf)
+f90base.m4 - Fortran 90 support for previous autoconf (now obsolete)
+fortran90.m4 - Fortran 90 support for autoconf 2.x for x > 52
+install-sh - Autoconf support file (needed to run autoconf)
+libtool-2.13.m4 - deleted?
+libtool.m4 - deleted?
+ltmain-2.13.sh - deleted?
+ltmain.sh - deleted?
+pac.tex - Master file to create PDF documentation of
+ autoconf macros
+History
+These were originally developed to add features needed for MPICH
+(before MPICH2) to Autoconf 2.12, including better support for Fortran 77
+and Fortran 90, better cross-compilation support, and fixes for bugs
+(including bugs in result caching that would cause incorrect behavior
+when building on multiple systems from the same directory). As
+autoconf evolved (often in ways that were incompatible with previous
+versions), the code in these files attempted to remain compatible
+across a range of autoconf versions (in particular, there are three
+different files for Fortran support, since incompatibilities between
+autoconf versions made this the most efficient and reliable way to
+provide the Fortran services). With the autoconf 2.6x series, we
+decided to stop providing backward compatibility (note that 2.61 isn't
+even compatible with 2.62, so this was a major change in approach).
+However, these files have not been edited to remove macros and
+commands that are no longer relevant.
Modified: mpich2/trunk/confdb/aclocal.m4
--- mpich2/trunk/confdb/aclocal.m4 2009-03-20 16:22:43 UTC (rev 4145)
+++ mpich2/trunk/confdb/aclocal.m4 2009-03-20 17:00:18 UTC (rev 4146)
@@ -28,7 +28,7 @@
builtin(include,aclocal_make.m4)
builtin(include,aclocal_mpi.m4)
builtin(include,aclocal_web.m4)
-builtin(include,libtool.m4)
+dnl builtin(include,libtool.m4)
builtin(include,aclocal_shl.m4)
dnl builtin(include,aclocal_tcl.m4)
builtin(include,aclocal_java.m4)
Deleted: mpich2/trunk/confdb/libtool-2.13.m4
--- mpich2/trunk/confdb/libtool-2.13.m4 2009-03-20 16:22:43 UTC (rev 4145)
+++ mpich2/trunk/confdb/libtool-2.13.m4 2009-03-20 17:00:18 UTC (rev 4146)
@@ -1,3573 +0,0 @@
-# libtool.m4 - Configure libtool for the host system. -*-Shell-script-*-
-## Copyright 1996, 1997, 1998, 1999, 2000, 2001
-## Free Software Foundation, Inc.
-## Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-## This program is free software; you can redistribute it and/or modify
-## it under the terms of the GNU General Public License as published by
-## the Free Software Foundation; either version 2 of the License, or
-## (at your option) any later version.
-## This program is distributed in the hope that it will be useful, but
-## WITHOUT ANY WARRANTY; without even the implied warranty of
-## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-## General Public License for more details.
-## You should have received a copy of the GNU General Public License
-## along with this program; if not, write to the Free Software
-## Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-## As a special exception to the GNU General Public License, if you
-## distribute this file as part of a program that contains a
-## configuration script generated by Autoconf, you may include it under
-## the same distribution terms that you use for the rest of that program.
-# serial 46 AC_PROG_LIBTOOL
-AC_DEFUN([AC_PROG_LIBTOOL],
-[AC_REQUIRE([AC_LIBTOOL_SETUP])dnl
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-AC_SUBST(LIBTOOL)dnl
-# Prevent multiple expansion
-define([AC_PROG_LIBTOOL], [])
-AC_DEFUN([AC_LIBTOOL_SETUP],
-[AC_PREREQ(2.13)dnl
-AC_REQUIRE([AC_ENABLE_SHARED])dnl
-AC_REQUIRE([AC_ENABLE_STATIC])dnl
-AC_REQUIRE([AC_ENABLE_FAST_INSTALL])dnl
-AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([AC_PROG_LD])dnl
-AC_REQUIRE([AC_PROG_LD_RELOAD_FLAG])dnl
-AC_REQUIRE([AC_PROG_NM])dnl
-AC_REQUIRE([AC_PROG_LN_S])dnl
-AC_REQUIRE([AC_DEPLIBS_CHECK_METHOD])dnl
-AC_REQUIRE([AC_OBJEXT])dnl
-AC_REQUIRE([AC_EXEEXT])dnl
-dnl
-_LT_AC_PROG_ECHO_BACKSLASH
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- AC_PATH_MAGIC
- fi
-esac
-AC_CHECK_TOOL(RANLIB, ranlib, :)
-AC_CHECK_TOOL(STRIP, strip, :)
-ifdef([AC_PROVIDE_AC_LIBTOOL_DLOPEN], enable_dlopen=yes, enable_dlopen=no)
-ifdef([AC_PROVIDE_AC_LIBTOOL_WIN32_DLL],
-enable_win32_dll=yes, enable_win32_dll=no)
-AC_ARG_ENABLE(libtool-lock,
- [ --disable-libtool-lock avoid locking (might break parallel builds)])
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-*-*-irix6*)
- # Find out which ABI we are using.
- echo '[#]line __oline__ "configure"' > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile); then
- case `/usr/bin/file conftest.$ac_objext` in
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- AC_CACHE_CHECK([whether the C compiler needs -belf], lt_cv_cc_needs_belf,
- [AC_LANG_SAVE
- AC_LANG_C
- AC_TRY_LINK([],[],[lt_cv_cc_needs_belf=yes],[lt_cv_cc_needs_belf=no])
- AC_LANG_RESTORE])
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-[*-*-cygwin* | *-*-mingw* | *-*-pw32*)
- AC_CHECK_TOOL(DLLTOOL, dlltool, false)
- AC_CHECK_TOOL(AS, as, false)
- AC_CHECK_TOOL(OBJDUMP, objdump, false)
- # recent cygwin and mingw systems supply a stub DllMain which the user
- # can override, but on older systems we have to supply one
- AC_CACHE_CHECK([if libtool should supply DllMain function], lt_cv_need_dllmain,
- [AC_TRY_LINK([],
- [extern int __attribute__((__stdcall__)) DllMain(void*, int, void*);
- DllMain (0, 0, 0);],
- [lt_cv_need_dllmain=no],[lt_cv_need_dllmain=yes])])
- case $host/$CC in
- *-*-cygwin*/gcc*-mno-cygwin*|*-*-mingw*)
- # old mingw systems require "-dll" to link a DLL, while more recent ones
- # require "-mdll"
- CFLAGS="$CFLAGS -mdll"
- AC_CACHE_CHECK([how to link DLLs], lt_cv_cc_dll_switch,
- [AC_TRY_LINK([], [], [lt_cv_cc_dll_switch=-mdll],[lt_cv_cc_dll_switch=-dll])])
- CFLAGS="$SAVE_CFLAGS" ;;
- *-*-cygwin* | *-*-pw32*)
- # cygwin systems need to pass --dll to the linker, and not link
- # crt.o which will require a WinMain at 16 definition.
- lt_cv_cc_dll_switch="-Wl,--dll -nostartfiles" ;;
- esac
-esac
-_LT_AC_LTCONFIG_HACK
-# AC_LIBTOOL_HEADER_ASSERT
-AC_DEFUN([AC_LIBTOOL_HEADER_ASSERT],
-[AC_CACHE_CHECK([whether $CC supports assert without backlinking],
- [lt_cv_func_assert_works],
- [case $host in
- *-*-solaris*)
- if test "$GCC" = yes && test "$with_gnu_ld" != yes; then
- case `$CC --version 2>/dev/null` in
- [[12]].*) lt_cv_func_assert_works=no ;;
- *) lt_cv_func_assert_works=yes ;;
- esac
- fi
- esac])
-if test "x$lt_cv_func_assert_works" = xyes; then
- AC_CHECK_HEADERS(assert.h)
-fi
-])# AC_LIBTOOL_HEADER_ASSERT
-# _LT_AC_CHECK_DLFCN
-AC_DEFUN([_LT_AC_CHECK_DLFCN],
-[AC_CHECK_HEADERS(dlfcn.h)
-])# _LT_AC_CHECK_DLFCN
-# AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-AC_DEFUN([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE],
-[AC_REQUIRE([AC_CANONICAL_HOST])
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-AC_MSG_CHECKING([command to parse $NM output])
-AC_CACHE_VAL([lt_cv_sys_global_symbol_pipe], [dnl
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[[BCDEGRST]]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([[_A-Za-z]][[_A-Za-z0-9]]*\)'
-# Transform the above into a raw symbol and a C symbol.
-symxfrm='\1 \2\3 \3'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern char \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[[BCDT]]'
-cygwin* | mingw* | pw32*)
- symcode='[[ABCDGISTW]]'
-hpux*) # Its linker distinguishes data from code symbols
- lt_cv_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern char \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-irix*)
- symcode='[[BCDEGRST]]'
-solaris* | sysv5*)
- symcode='[[BDT]]'
-sysv4)
- symcode='[[DFNSTU]]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $host_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-if $NM -V 2>&1 | egrep '(GNU|with BFD)' > /dev/null; then
-fi
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
- # Write the raw and C identifiers.
-lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[[ ]]\($symcode$symcode*\)[[ ]][[ ]]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
- # Now try to grab the symbols.
- nlist=conftest.nm
- if AC_TRY_EVAL(NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if egrep ' nm_test_var$' "$nlist" >/dev/null; then
- if egrep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_global_symbol_to_cdecl"' < "$nlist" >> conftest.$ac_ext'
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[[]] =
-EOF
- sed "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr) \&\2},/" < "$nlist" >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr) 0}
-#ifdef __cplusplus
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- save_LIBS="$LIBS"
- save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$no_builtin_flag"
- if AC_TRY_EVAL(ac_link) && test -s conftest; then
- pipe_works=yes
- fi
- LIBS="$save_LIBS"
- CFLAGS="$save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&AC_FD_CC
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&AC_FD_CC
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&AC_FD_CC
- fi
- else
- echo "$progname: failed program was:" >&AC_FD_CC
- cat conftest.$ac_ext >&5
- fi
- rm -f conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- lt_cv_sys_global_symbol_pipe=
- fi
-done
-global_symbol_pipe="$lt_cv_sys_global_symbol_pipe"
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
- global_symbol_to_cdecl=
- global_symbol_to_c_name_address=
-else
- global_symbol_to_cdecl="$lt_cv_global_symbol_to_cdecl"
- global_symbol_to_c_name_address="$lt_cv_global_symbol_to_c_name_address"
-fi
-if test -z "$global_symbol_pipe$global_symbol_to_cdec$global_symbol_to_c_name_address";
-then
- AC_MSG_RESULT(failed)
-else
- AC_MSG_RESULT(ok)
-fi
-]) # AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-# _LT_AC_LIBTOOL_SYS_PATH_SEPARATOR
-AC_DEFUN([_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR],
-[# Find the correct PATH separator. Usually this is `:', but
-# DJGPP uses `;' like DOS.
-if test "X${PATH_SEPARATOR+set}" != Xset; then
- UNAME=${UNAME-`uname 2>/dev/null`}
- case X$UNAME in
- *-DOS) lt_cv_sys_path_separator=';' ;;
- *) lt_cv_sys_path_separator=':' ;;
- esac
- PATH_SEPARATOR=$lt_cv_sys_path_separator
-fi
-])# _LT_AC_LIBTOOL_SYS_PATH_SEPARATOR
-# _LT_AC_PROG_ECHO_BACKSLASH
-# Add some code to the start of the generated configure script which
-# will find an echo command which doesn't interpret backslashes.
-AC_DEFUN([_LT_AC_PROG_ECHO_BACKSLASH],
-[ifdef([AC_DIVERSION_NOTICE], [AC_DIVERT_PUSH(AC_DIVERSION_NOTICE)],
- [AC_DIVERT_PUSH(NOTICE)])
-_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR
-# Check that we are running under the correct shell.
-SHELL=${CONFIG_SHELL-/bin/sh}
-case X$ECHO in
-X*--fallback-echo)
- # Remove one level of quotation (which was required for Make).
- ECHO=`echo "$ECHO" | sed 's,\\\\\[$]\\[$]0,'[$]0','`
-esac
-echo=${ECHO-echo}
-if test "X[$]1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X[$]1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell.
- exec $SHELL "[$]0" --no-reexec ${1+"[$]@"}
-fi
-if test "X[$]1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test "X${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-if test -z "$ECHO"; then
-if test "X${echo_test_string+set}" != Xset; then
-# find a string as large as possible, as long as the shell can cope with it
- for cmd in 'sed 50q "[$]0"' 'sed 20q "[$]0"' 'sed 10q "[$]0"' 'sed 2q "[$]0"' 'echo test'; do
- # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
- if (echo_test_string="`eval $cmd`") 2>/dev/null &&
- echo_test_string="`eval $cmd`" &&
- (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
- then
- break
- fi
- done
-fi
-if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
- test "X$echo_testing_string" = "X$echo_test_string"; then
-else
- # The Solaris, AIX, and Digital Unix default echo programs unquote
- # backslashes. This makes it impossible to quote backslashes using
- # echo "$something" | sed 's/\\/\\\\/g'
- # So, first we look for a working echo in the user's PATH.
- IFS="${IFS= }"; save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for dir in $PATH /usr/ucb; do
- if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
- test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
- echo="$dir/echo"
- break
- fi
- done
- IFS="$save_ifs"
- if test "X$echo" = Xecho; then
- # We didn't find a better echo, so look for alternatives.
- if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
- # This shell has a builtin print -r that does the trick.
- echo='print -r'
- elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
- test "X$CONFIG_SHELL" != X/bin/ksh; then
- # If we have ksh, try running configure again with it.
- ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
- export ORIGINAL_CONFIG_SHELL
- CONFIG_SHELL=/bin/ksh
- export CONFIG_SHELL
- exec $CONFIG_SHELL "[$]0" --no-reexec ${1+"[$]@"}
- else
- # Try using printf.
- echo='printf %s\n'
- if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- # Cool, printf works
- elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- test "X$echo_testing_string" = 'X\t' &&
- echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
- SHELL="$CONFIG_SHELL"
- export SHELL
- echo="$CONFIG_SHELL [$]0 --fallback-echo"
- elif echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- else
- # maybe with a smaller string...
- prev=:
- for cmd in 'echo test' 'sed 2q "[$]0"' 'sed 10q "[$]0"' 'sed 20q "[$]0"' 'sed 50q "[$]0"'; do
- if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
- then
- break
- fi
- prev="$cmd"
- done
- if test "$prev" != 'sed 50q "[$]0"'; then
- echo_test_string=`eval $prev`
- export echo_test_string
- exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "[$]0" ${1+"[$]@"}
- else
- # Oops. We lost completely, so just stick with echo.
- echo=echo
- fi
- fi
- fi
- fi
-fi
-fi
-# Copy echo and quote the copy suitably for passing to libtool from
-# the Makefile, instead of quoting the original, which is used later.
-ECHO=$echo
-if test "X$ECHO" = "X$CONFIG_SHELL [$]0 --fallback-echo"; then
- ECHO="$CONFIG_SHELL \\\$\[$]0 --fallback-echo"
-fi
-AC_SUBST(ECHO)
-AC_DIVERT_POP
-])# _LT_AC_PROG_ECHO_BACKSLASH
-# _LT_AC_TRY_DLOPEN_SELF (ACTION-IF-TRUE, ACTION-IF-TRUE-W-USCORE,
-# ACTION-IF-FALSE, ACTION-IF-CROSS-COMPILING)
-AC_DEFUN([_LT_AC_TRY_DLOPEN_SELF],
-[if test "$cross_compiling" = yes; then :
- [$4]
-else
- AC_REQUIRE([_LT_AC_CHECK_DLFCN])dnl
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
-[#line __oline__ "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- exit (status);
-EOF
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) $1 ;;
- x$lt_dlneed_uscore) $2 ;;
- x$lt_unknown|x*) $3 ;;
- esac
- else :
- # compilation failed
- $3
- fi
-fi
-rm -fr conftest*
-])# _LT_AC_TRY_DLOPEN_SELF
-# AC_LIBTOOL_DLOPEN_SELF
-AC_DEFUN([AC_LIBTOOL_DLOPEN_SELF],
-[if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- cygwin* | mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- AC_CHECK_FUNC([shl_load],
- [lt_cv_dlopen="shl_load"],
- [AC_CHECK_LIB([dld], [shl_load],
- [lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"],
- [AC_CHECK_FUNC([dlopen],
- [lt_cv_dlopen="dlopen"],
- [AC_CHECK_LIB([dl], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"],
- [AC_CHECK_LIB([svld], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"],
- [AC_CHECK_LIB([dld], [dld_link],
- [lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"])
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- save_LDFLAGS="$LDFLAGS"
- eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- AC_CACHE_CHECK([whether a program can dlopen itself],
- lt_cv_dlopen_self, [dnl
- _LT_AC_TRY_DLOPEN_SELF(
- lt_cv_dlopen_self=yes, lt_cv_dlopen_self=yes,
- lt_cv_dlopen_self=no, lt_cv_dlopen_self=cross)
- if test "x$lt_cv_dlopen_self" = xyes; then
- LDFLAGS="$LDFLAGS $link_static_flag"
- AC_CACHE_CHECK([whether a statically linked program can dlopen itself],
- lt_cv_dlopen_self_static, [dnl
- lt_cv_dlopen_self_static=yes, lt_cv_dlopen_self_static=yes,
- lt_cv_dlopen_self_static=no, lt_cv_dlopen_self_static=cross)
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LDFLAGS="$save_LDFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-])# AC_LIBTOOL_DLOPEN_SELF
-AC_DEFUN([_LT_AC_LTCONFIG_HACK],
-[AC_REQUIRE([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE])dnl
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e s/^X//'
-sed_quote_subst='s/\([[\\"\\`$\\\\]]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([[\\"\\`\\\\]]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-need_locks="$enable_libtool_lock"
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$AR" && AR=ar
-test -z "$AR_FLAGS" && AR_FLAGS=cru
-test -z "$AS" && AS=as
-test -z "$CC" && CC=cc
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-test -z "$LD" && LD=ld
-test -z "$LN_S" && LN_S="ln -s"
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-test -z "$NM" && NM=nm
-test -z "$OBJDUMP" && OBJDUMP=objdump
-test -z "$RANLIB" && RANLIB=:
-test -z "$STRIP" && STRIP=:
-test -z "$ac_objext" && ac_objext=o
-if test x"$host" != x"$build"; then
- ac_tool_prefix=${host_alias}-
-else
- ac_tool_prefix=
-fi
-# Transform linux* to *-*-linux-gnu*, to support old configure scripts.
-case $host_os in
-linux-gnu*) ;;
-linux*) host=`echo $host | sed 's/^\(.*-.*-linux\)\(.*\)$/\1-gnu\2/'`
-esac
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
-old_postinstall_cmds='chmod 644 $oldlib'
-old_postuninstall_cmds=
-if test -n "$RANLIB"; then
- case $host_os in
- openbsd*)
- old_postinstall_cmds="\$RANLIB -t \$oldlib~$old_postinstall_cmds"
- old_postinstall_cmds="\$RANLIB \$oldlib~$old_postinstall_cmds"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
-fi
-# Allow CC to be a program name with arguments.
-set dummy $CC
-compiler="[$]2"
-## FIXME: this should be a separate macro
-AC_MSG_CHECKING([for objdir])
-rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- objdir=.libs
-else
- # MS-DOS does not allow filenames that begin with a dot.
- objdir=_libs
-fi
-rmdir .libs 2>/dev/null
-AC_MSG_RESULT($objdir)
-## END FIXME
-AC_ARG_WITH(pic,
-[ --with-pic try to use only PIC/non-PIC objects [default=use both]],
-pic_mode="$withval", pic_mode=default)
-test -z "$pic_mode" && pic_mode=default
-# We assume here that the value for lt_cv_prog_cc_pic will not be cached
-# in isolation, and that seeing it set (from the cache) indicates that
-# the associated values are set (in the cache) correctly too.
-AC_MSG_CHECKING([for $compiler option to produce PIC])
-AC_CACHE_VAL(lt_cv_prog_cc_pic,
-[ lt_cv_prog_cc_pic=
- lt_cv_prog_cc_shlib=
- lt_cv_prog_cc_wl=
- lt_cv_prog_cc_static=
- lt_cv_prog_cc_no_builtin=
- lt_cv_prog_cc_can_build_shared=$can_build_shared
- if test "$GCC" = yes; then
- lt_cv_prog_cc_wl='-Wl,'
- lt_cv_prog_cc_static='-static'
- case $host_os in
- aix*)
- # Below there is a dirty hack to force normal static linking with -ldl
- # The problem is because libdl dynamically linked with both libc and
- # libC (AIX C++ library), which obviously doesn't included in libraries
- # list by gcc. This cause undefined symbols with -static flags.
- # This hack allows C programs to be linked with "-static -ldl", but
- # not sure about C++ programs.
- lt_cv_prog_cc_static="$lt_cv_prog_cc_static ${lt_cv_prog_cc_wl}-lC"
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_cv_prog_cc_pic='-m68020 -resident32 -malways-restore-a4'
- beos* | irix5* | irix6* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_cv_prog_cc_pic='-fno-common'
- cygwin* | mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_cv_prog_cc_pic='-DDLL_EXPORT'
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_cv_prog_cc_pic=-Kconform_pic
- fi
- lt_cv_prog_cc_pic='-fPIC'
- esac
- else
- # PORTME Check for PIC flags for the system compiler.
- case $host_os in
- aix3* | aix4* | aix5*)
- # All AIX code is PIC.
- if test "$host_cpu" = ia64; then
- # AIX 5 now supports IA64 processor
- lt_cv_prog_cc_static='-Bstatic'
- else
- lt_cv_prog_cc_static='-bnso -bI:/lib/syscalls.exp'
- fi
- hpux9* | hpux10* | hpux11*)
- # Is there a better lt_cv_prog_cc_static that works with the bundled CC?
- lt_cv_prog_cc_static="${lt_cv_prog_cc_wl}-a ${lt_cv_prog_cc_wl}archive"
- lt_cv_prog_cc_pic='+Z'
- irix5* | irix6*)
- lt_cv_prog_cc_static='-non_shared'
- # PIC (with -KPIC) is the default.
- newsos6)
- lt_cv_prog_cc_pic='-KPIC'
- osf3* | osf4* | osf5*)
- # All OSF/1 code is PIC.
- sco3.2v5*)
- lt_cv_prog_cc_pic='-Kpic'
- lt_cv_prog_cc_static='-dn'
- lt_cv_prog_cc_shlib='-belf'
- solaris*)
- sunos4*)
- lt_cv_prog_cc_pic='-PIC'
- lt_cv_prog_cc_wl='-Qoption ld '
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- if test "x$host_vendor" = xsni; then
- lt_cv_prog_cc_wl='-LD'
- else
- fi
- uts4*)
- lt_cv_prog_cc_pic='-pic'
- sysv4*MP*)
- if test -d /usr/nec ;then
- lt_cv_prog_cc_pic='-Kconform_pic'
- fi
- lt_cv_prog_cc_can_build_shared=no
- esac
- fi
-if test -z "$lt_cv_prog_cc_pic"; then
- AC_MSG_RESULT([none])
-else
- AC_MSG_RESULT([$lt_cv_prog_cc_pic])
- # Check to make sure the pic_flag actually works.
- AC_MSG_CHECKING([if $compiler PIC flag $lt_cv_prog_cc_pic works])
- AC_CACHE_VAL(lt_cv_prog_cc_pic_works, [dnl
- CFLAGS="$CFLAGS $lt_cv_prog_cc_pic -DPIC"
- AC_TRY_COMPILE([], [], [dnl
- case $host_os in
- # On HP-UX, both CC and GCC only warn that PIC is supported... then
- # they create non-PIC objects. So, if there were any warnings, we
- # assume that PIC is not supported.
- if test -s conftest.err; then
- lt_cv_prog_cc_pic_works=no
- else
- lt_cv_prog_cc_pic_works=yes
- fi
- esac
- ], [dnl
- if test "X$lt_cv_prog_cc_pic_works" = Xno; then
- else
- lt_cv_prog_cc_pic=" $lt_cv_prog_cc_pic"
- fi
- AC_MSG_RESULT([$lt_cv_prog_cc_pic_works])
-fi
-## END FIXME
-# Check for any special shared library compilation flags.
-if test -n "$lt_cv_prog_cc_shlib"; then
- AC_MSG_WARN([\`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries])
- if echo "$old_CC $old_CFLAGS " | egrep -e "[[ ]]$lt_cv_prog_cc_shlib[[ ]]" >/dev/null; then :
- else
- AC_MSG_WARN([add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure])
- fi
-fi
-AC_MSG_CHECKING([if $compiler static flag $lt_cv_prog_cc_static works])
-AC_CACHE_VAL([lt_cv_prog_cc_static_works], [dnl
- lt_cv_prog_cc_static_works=no
- LDFLAGS="$LDFLAGS $lt_cv_prog_cc_static"
- AC_TRY_LINK([], [], [lt_cv_prog_cc_static_works=yes])
-# Belt *and* braces to stop my trousers falling down:
-test "X$lt_cv_prog_cc_static_works" = Xno && lt_cv_prog_cc_static=
-AC_MSG_RESULT([$lt_cv_prog_cc_static_works])
-pic_flag="$lt_cv_prog_cc_pic"
-special_shlib_compile_flags="$lt_cv_prog_cc_shlib"
-wl="$lt_cv_prog_cc_wl"
-link_static_flag="$lt_cv_prog_cc_static"
-no_builtin_flag="$lt_cv_prog_cc_no_builtin"
-can_build_shared="$lt_cv_prog_cc_can_build_shared"
-## END FIXME
-# Check to see if options -o and -c are simultaneously supported by compiler
-AC_MSG_CHECKING([if $compiler supports -c -o file.$ac_objext])
-AC_CACHE_VAL([lt_cv_compiler_c_o], [
-$rm -r conftest 2>/dev/null
-mkdir conftest
-cd conftest
-echo "int some_variable = 0;" > conftest.$ac_ext
-mkdir out
-# According to Tom Tromey, Ian Lance Taylor reported there are C compilers
-# that will create temporary files in the current directory regardless of
-# the output directory. Thus, making CWD read-only will cause this test
-# to fail, enabling locking or at least warning the user not to do parallel
-# builds.
-chmod -w .
-save_CFLAGS="$CFLAGS"
-CFLAGS="$CFLAGS -o out/conftest2.$ac_objext"
-compiler_c_o=no
-if { (eval echo configure:__oline__: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>out/conftest.err; } && test -s out/conftest2.$ac_objext; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- if test -s out/conftest.err; then
- lt_cv_compiler_c_o=no
- else
- lt_cv_compiler_c_o=yes
- fi
-else
- # Append any errors to the config.log.
- cat out/conftest.err 1>&AC_FD_CC
-fi
-CFLAGS="$save_CFLAGS"
-chmod u+w .
-$rm conftest* out/*
-rmdir out
-cd ..
-rmdir conftest
-compiler_c_o=$lt_cv_compiler_c_o
-AC_MSG_RESULT([$compiler_c_o])
-if test x"$compiler_c_o" = x"yes"; then
- # Check to see if we can write to a .lo
- AC_MSG_CHECKING([if $compiler supports -c -o file.lo])
- AC_CACHE_VAL([lt_cv_compiler_o_lo], [
- lt_cv_compiler_o_lo=no
- CFLAGS="$CFLAGS -c -o conftest.lo"
- save_objext="$ac_objext"
- ac_objext=lo
- AC_TRY_COMPILE([], [int some_variable = 0;], [dnl
- else
- lt_cv_compiler_o_lo=yes
- fi
- ac_objext="$save_objext"
- compiler_o_lo=$lt_cv_compiler_o_lo
- AC_MSG_RESULT([$compiler_o_lo])
-else
- compiler_o_lo=no
-fi
-## END FIXME
-# Check to see if we can do hard links to lock some files if needed
-hard_links="nottested"
-if test "$compiler_c_o" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- AC_MSG_CHECKING([if we can lock with hard links])
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- AC_MSG_RESULT([$hard_links])
- if test "$hard_links" = no; then
- AC_MSG_WARN([\`$CC' does not support \`-c -o', so \`make -j' may be unsafe])
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-## END FIXME
-if test "$GCC" = yes; then
- # Check to see if options -fno-rtti -fno-exceptions are supported by compiler
- AC_MSG_CHECKING([if $compiler supports -fno-rtti -fno-exceptions])
- echo "int some_variable = 0;" > conftest.$ac_ext
- CFLAGS="$CFLAGS -fno-rtti -fno-exceptions -c conftest.$ac_ext"
- compiler_rtti_exceptions=no
- else
- compiler_rtti_exceptions=yes
- fi
- AC_MSG_RESULT([$compiler_rtti_exceptions])
- if test "$compiler_rtti_exceptions" = "yes"; then
- no_builtin_flag=' -fno-builtin -fno-rtti -fno-exceptions'
- else
- no_builtin_flag=' -fno-builtin'
- fi
-fi
-## END FIXME
-# See if the linker supports building shared libraries.
-AC_MSG_CHECKING([whether the linker ($LD) supports shared libraries])
-allow_undefined_flag=
-no_undefined_flag=
-need_lib_prefix=unknown
-need_version=unknown
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-archive_cmds=
-archive_expsym_cmds=
-old_archive_from_new_cmds=
-old_archive_from_expsyms_cmds=
-export_dynamic_flag_spec=
-whole_archive_flag_spec=
-thread_safe_flag_spec=
-hardcode_into_libs=no
-hardcode_libdir_flag_spec=
-hardcode_libdir_separator=
-hardcode_direct=no
-hardcode_minus_L=no
-hardcode_shlibpath_var=unsupported
-runpath_var=
-link_all_deplibs=unknown
-always_export_symbols=no
-export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | sed '\''s/.* //'\'' | sort | uniq > $export_symbols'
-# include_expsyms should be a list of space-separated symbols to be *always*
-# included in the symbol list
-include_expsyms=
-# exclude_expsyms can be an egrep regular expression of symbols to exclude
-# it will be wrapped by ` (' and `)$', so one must not match beginning or
-# end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
-# as well as any symbol that contains `d'.
-exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
-# Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
-# platforms (ab)use it in PIC code, but their linkers get confused if
-# the symbol is explicitly referenced. Since portable code cannot
-# rely on this symbol name, it's probably fine to never include it in
-# preloaded symbol tables.
-extract_expsyms_cmds=
-case $host_os in
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
-openbsd*)
- with_gnu_ld=no
-esac
-ld_shlibs=yes
-if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- # On AIX, the GNU linker is very broken
- # Note:Check GNU linker on AIX 5-IA64 when/if it becomes available.
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- amigaos*)
- archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec='-L$libdir'
- hardcode_minus_L=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can use
- # them.
- ld_shlibs=no
- beos*)
- if $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs=no
- fi
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- always_export_symbols=yes
- extract_expsyms_cmds='test -f $output_objdir/impgen.c || \
- sed -e "/^# \/\* impgen\.c starts here \*\//,/^# \/\* impgen.c ends here \*\// { s/^# //;s/^# *$//; p; }" -e d < $''0 > $output_objdir/impgen.c~
- test -f $output_objdir/impgen.exe || (cd $output_objdir && \
- if test "x$HOST_CC" != "x" ; then $HOST_CC -o impgen impgen.c ; \
- else $CC -o impgen impgen.c ; fi)~
- $output_objdir/impgen $dir/$soroot > $output_objdir/$soname-def'
- old_archive_from_expsyms_cmds='$DLLTOOL --as=$AS --dllname $soname --def $output_objdir/$soname-def --output-lib $output_objdir/$newlib'
- # cygwin and mingw dlls have different entry points and sets of symbols
- # to exclude.
- # FIXME: what about values for MSVC?
- dll_entry=__cygwin_dll_entry at 12
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12~
- case $host_os in
- mingw*)
- # mingw values
- dll_entry=_DllMainCRTStartup at 12
- dll_exclude_symbols=DllMain at 12,DllMainCRTStartup at 12,DllEntryPoint at 12~
- esac
- # mingw and cygwin differ, and it's simplest to just exclude the union
- # of the two symbol sets.
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12,DllMainCRTStartup at 12,DllEntryPoint at 12
- # can override, but on older systems we have to supply one (in ltdll.c)
- if test "x$lt_cv_need_dllmain" = "xyes"; then
- ltdll_obj='$output_objdir/$soname-ltdll.'"$ac_objext "
- ltdll_cmds='test -f $output_objdir/$soname-ltdll.c || sed -e "/^# \/\* ltdll\.c starts here \*\//,/^# \/\* ltdll.c ends here \*\// { s/^# //; p; }" -e d < $''0 > $output_objdir/$soname-ltdll.c~
- test -f $output_objdir/$soname-ltdll.$ac_objext || (cd $output_objdir && $CC -c $soname-ltdll.c)~'
- else
- ltdll_obj=
- ltdll_cmds=
- fi
- # Extract the symbol export list from an `--export-all' def file,
- # then regenerate the def file from the symbol export list, so that
- # the compiled dll only exports the symbol export list.
- # Be careful not to strip the DATA tag left be newer dlltools.
- export_symbols_cmds="$ltdll_cmds"'
- $DLLTOOL --export-all --exclude-symbols '$dll_exclude_symbols' --output-def $output_objdir/$soname-def '$ltdll_obj'$libobjs $convenience~
- sed -e "1,/EXPORTS/d" -e "s/ @ [[0-9]]*//" -e "s/ *;.*$//" < $output_objdir/$soname-def > $export_symbols'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is.
- # If DATA tags from a recent dlltool are present, honour them!
- archive_expsym_cmds='if test "x`head -1 $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname-def;
- else
- echo EXPORTS > $output_objdir/$soname-def;
- _lt_hint=1;
- cat $export_symbols | while read symbol; do
- set dummy \$symbol;
- case \[$]# in
- 2) echo " \[$]2 @ \$_lt_hint ; " >> $output_objdir/$soname-def;;
- *) echo " \[$]2 @ \$_lt_hint \[$]3 ; " >> $output_objdir/$soname-def;;
- esac;
- _lt_hint=`expr 1 + \$_lt_hint`;
- done;
- fi~
- '"$ltdll_cmds"'
- $CC -Wl,--base-file,$output_objdir/$soname-base '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp~
- $CC -Wl,--base-file,$output_objdir/$soname-base $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp --output-lib $output_objdir/$libname.dll.a~
- $CC $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags'
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | egrep 'BFD 2\.8' > /dev/null; then
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- else
- ld_shlibs=no
- fi
- sunos4*)
- archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct=yes
- hardcode_shlibpath_var=no
- else
- ld_shlibs=no
- fi
- esac
- if test "$ld_shlibs" = yes; then
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec='${wl}--export-dynamic'
- case $host_os in
- # dlltool doesn't understand --whole-archive et. al.
- whole_archive_flag_spec=
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | egrep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- esac
- fi
-else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[[23]]|aix4.[[23]].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds=''
- hardcode_libdir_separator=':'
- case $host_os in aix4.[[012]]|aix4.[[012]].*)
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- else
- # not using gcc
- shared_flag='${wl}-G'
- else
- if test "$aix_use_runtimelinking" = yes; then
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall can do strange things, so it is better to
- # generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag='-berok'
- hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:/usr/lib:/lib'
- archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag="-z nodefs"
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname ${wl}-h$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
- else
- hardcode_libdir_flag_spec='${wl}-bnolibpath ${wl}-blibpath:$libdir:/usr/lib:/lib'
- # Warning - without using the other run time loading flags,
- allow_undefined_flag='${wl}-berok'
- # This is a bit strange, but is similar to how AIX traditionally builds
- # it's shared libraries.
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"' ~$AR -crlo $objdir/$libname$release.a $objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs=no
- hardcode_libdir_flag_spec=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | sed -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_from_new_cmds='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
- case "$host_os" in
- rhapsody* | darwin1.[[012]])
- allow_undefined_flag='-undefined suppress'
- *) # Darwin 1.3 on
- allow_undefined_flag='-flat_namespace -undefined suppress'
- esac
- # FIXME: Relying on posixy $() will cause problems for
- # cross-compilation, but unfortunately the echo tests do not
- # yet detect zsh echo's removal of \ escapes.
- archive_cmds='$nonopt $(test "x$module" = xyes && echo -bundle || echo -dynamiclib) $allow_undefined_flag -o $lib $libobjs $deplibs$linker_flags -install_name $rpath/$soname $verstring'
- # We need to add '_' to the symbols in $export_symbols first
- #archive_expsym_cmds="$archive_cmds"' && strip -s $export_symbols'
- whole_archive_flag_spec='-all_load $convenience'
- freebsd1*)
- ld_shlibs=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd*)
- archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- case $host_os in
- hpux9*) archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib' ;;
- *) archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags' ;;
- esac
- hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator=:
- hardcode_minus_L=yes # Not in the search PATH, but as the default
- # location of the library.
- export_dynamic_flag_spec='${wl}-E'
- irix5* | irix6*)
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
- link_all_deplibs=yes
- netbsd*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $linker_flags'
- hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
- else
- openbsd[[01]].* | openbsd2.[[0-7]] | openbsd2.[[0-7]].*)
- esac
- fi
- os2*)
- archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_from_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag=' -expect_unresolved \*'
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='for i in `cat $export_symbols`; do printf "-exported_symbol " >> $lib.exp; echo "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
- #Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec='-rpath $libdir'
- fi
- sco3.2v5*)
- hardcode_runpath_var=yes
- export_dynamic_flag_spec='${wl}-Bexport'
- solaris*)
- # gcc --version < 3.0 without binutils cannot create self contained
- # shared libraries reliably, requiring libgcc.a to resolve some of
- # the object symbols generated in some cases. Libraries that use
- # assert need libgcc.a to resolve __eprintf, for example. Linking
- # a copy of libgcc.a into every shared library to guarantee resolving
- # such symbols causes other problems: According to Tim Van Holder
- # <tim.van.holder at pandora.be>, C++ libraries end up with a separate
- # (to the application) exception stack for one thing.
- no_undefined_flag=' -z defs'
- [[12]].*)
- cat <<EOF 1>&2
-*** Warning: Releases of GCC earlier than version 3.0 cannot reliably
-*** create self contained shared libraries on Solaris systems, without
-*** introducing a dependency on libgcc.a. Therefore, libtool is disabling
-*** -no-undefined support, which will at least allow you to build shared
-*** libraries. However, you may find that when you link such libraries
-*** into an application without using GCC, you have to manually add
-*** \`gcc --print-libgcc-file-name\` to the link command. We urge you to
-*** upgrade to a newer version of GCC. Another option is to rebuild your
-*** current GCC to use the GNU linker from GNU binutils 2.9.1 or newer.
-EOF
- esac
- fi
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- case $host_os in
- solaris2.[[0-5]] | solaris2.[[0-5]].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- if test "x$host_vendor" = xsno; then
- archive_cmds='$LD -G -Bsymbolic -h $soname -o $lib $libobjs $deplibs $linker_flags'
- hardcode_direct=yes # is this really true???
- else
- hardcode_direct=no #Motorola manual says yes, but my tests say they lie
- fi
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec='-Bexport'
- sysv5*)
- no_undefined_flag=' -z text'
- uts4*)
- dgux*)
- sysv4*MP*)
- ld_shlibs=yes
- fi
- sysv4.2uw2*)
- archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- hardcode_minus_L=no
- sysv5uw7* | unixware7*)
- no_undefined_flag='${wl}-z ${wl}text'
- archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- ld_shlibs=no
- esac
-fi
-AC_MSG_RESULT([$ld_shlibs])
-test "$ld_shlibs" = no && can_build_shared=no
-## END FIXME
-# Check hardcoding attributes.
-AC_MSG_CHECKING([how to hardcode library paths into programs])
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" || \
- test -n "$runpath_var"; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$hardcode_shlibpath_var" != no &&
- test "$hardcode_minus_L" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action=unsupported
-fi
-AC_MSG_RESULT([$hardcode_action])
-## END FIXME
-striplib=
-old_striplib=
-AC_MSG_CHECKING([whether stripping libraries is possible])
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- AC_MSG_RESULT([yes])
-else
- AC_MSG_RESULT([no])
-fi
-## END FIXME
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-# PORTME Fill in your ld.so characteristics
-AC_MSG_CHECKING([dynamic linker characteristics])
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}.so$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}.so$major'
-aix4* | aix5*)
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}.so$major ${libname}${release}.so$versuffix $libname.so'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[[01]] | aix4.[[01]].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can
- # not hardcode correct soname into executable. Probably we can
- # add versioning support to collect2, so additional links can
- # be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major $libname.so'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([[^/]]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "(cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a)"; (cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a) || exit 1; done'
-beos*)
- library_names_spec='${libname}.so'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi4*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- export_dynamic_flag_spec=-rdynamic
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
- version_type=windows
- need_version=no
- need_lib_prefix=no
- case $GCC,$host_os in
- yes,cygwin*)
- library_names_spec='$libname.dll.a'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | sed -e 's/[[.]]/-/g'`${versuffix}.dll'
- postinstall_cmds='dlpath=`bash 2>&1 -c '\''. $dir/${file}i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog .libs/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`bash 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- yes,mingw*)
- library_names_spec='${libname}`echo ${release} | sed -e 's/[[.]]/-/g'`${versuffix}.dll'
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | sed -e "s/^libraries://" -e "s/;/ /g"`
- yes,pw32*)
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
- library_names_spec='${libname}`echo ${release} | sed -e 's/[[.]]/-/g'`${versuffix}.dll $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}.$(test .$module = .yes && echo so || echo dylib) ${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib) ${libname}.$(test .$module = .yes && echo so || echo dylib)'
- soname_spec='${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib)'
- shlibpath_overrides_runpath=yes
- shlibpath_var=DYLD_LIBRARY_PATH
-freebsd1*)
- dynamic_linker=no
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so $libname.so'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}.so$versuffix $libname.so$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- shlibpath_overrides_runpath=no
- hardcode_into_libs=yes
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so${major} ${libname}.so'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- dynamic_linker="$host_os dld.sl"
- version_type=sunos
- need_version=no
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- library_names_spec='${libname}${release}.sl$versuffix ${libname}${release}.sl$major $libname.sl'
- soname_spec='${libname}${release}.sl$major'
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-irix5* | irix6*)
- version_type=irix
- need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so $libname.so'
- case $host_os in
- irix5*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 ") libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 ") libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 ") libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux-gnuoldld* | linux-gnuaout* | linux-gnucoff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux-gnu*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}.so$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so ${libname}.so'
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-openbsd*)
- need_version=no
- openbsd2.[[89]] | openbsd2.[[89]].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname.dll $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- soname_spec='${libname}${release}.so'
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- if test "$with_gnu_ld" = yes; then
- fi
- need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- case $host_vendor in
- sni)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-uts4*)
-dgux*)
- need_version=no
-sysv4*MP*)
- library_names_spec='$libname.so.$versuffix $libname.so.$major $libname.so'
- soname_spec='$libname.so.$major'
- fi
- dynamic_linker=no
-esac
-AC_MSG_RESULT([$dynamic_linker])
-test "$dynamic_linker" = no && can_build_shared=no
-## END FIXME
-# Report the final consequences.
-AC_MSG_CHECKING([if libtool supports shared libraries])
-AC_MSG_RESULT([$can_build_shared])
-## END FIXME
-AC_MSG_CHECKING([whether to build shared libraries])
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
-esac
-AC_MSG_RESULT([$enable_shared])
-## END FIXME
-AC_MSG_CHECKING([whether to build static libraries])
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-AC_MSG_RESULT([$enable_static])
-## END FIXME
-if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-AC_LIBTOOL_DLOPEN_SELF
-if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- AC_MSG_CHECKING([whether -lc should be explicitly linked in])
- AC_CACHE_VAL([lt_cv_archive_cmds_need_lc],
- [$rm conftest*
- echo 'static int dummy;' > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile); then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_cv_prog_cc_wl
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- save_allow_undefined_flag=$allow_undefined_flag
- if AC_TRY_EVAL(archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1)
- then
- lt_cv_archive_cmds_need_lc=no
- else
- lt_cv_archive_cmds_need_lc=yes
- fi
- allow_undefined_flag=$save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi])
- AC_MSG_RESULT([$lt_cv_archive_cmds_need_lc])
- esac
-fi
-need_lc=${lt_cv_archive_cmds_need_lc-yes}
-## END FIXME
-# The second clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- test -f Makefile && make "$ltmain"
-fi
- trap "$rm \"${ofile}T\"; exit 1" 1 2 15
- $rm -f "${ofile}T"
- echo creating $ofile
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS \
- AR AR_FLAGS CC LD LN_S NM SHELL \
- reload_flag reload_cmds wl \
- pic_flag link_static_flag no_builtin_flag export_dynamic_flag_spec \
- thread_safe_flag_spec whole_archive_flag_spec libname_spec \
- library_names_spec soname_spec \
- RANLIB old_archive_cmds old_archive_from_new_cmds old_postinstall_cmds \
- old_postuninstall_cmds archive_cmds archive_expsym_cmds postinstall_cmds \
- postuninstall_cmds extract_expsyms_cmds old_archive_from_expsyms_cmds \
- old_striplib striplib file_magic_cmd export_symbols_cmds \
- deplibs_check_method allow_undefined_flag no_undefined_flag \
- finish_cmds finish_eval global_symbol_pipe global_symbol_to_cdecl \
- global_symbol_to_c_name_address \
- hardcode_libdir_flag_spec hardcode_libdir_separator \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- compiler_c_o compiler_o_lo need_locks exclude_expsyms include_expsyms; do
- case $var in
- reload_cmds | old_archive_cmds | old_archive_from_new_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- export_symbols_cmds | archive_cmds | archive_expsym_cmds | \
- extract_expsyms_cmds | old_archive_from_expsyms_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- finish_cmds | sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- cat <<__EOF__ > "${ofile}T"
-#! $SHELL
-# `$echo "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996-2000 Free Software Foundation, Inc.
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="sed -e s/^X//"
-if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-# ### BEGIN LIBTOOL CONFIG
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$need_lc
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# The default C compiler.
-CC=$lt_CC
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC
-# The linker used to build libraries.
-LD=$lt_LD
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_wl
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_pic_flag
-pic_mode=$pic_mode
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_compiler_c_o
-# Can we write directly to a .lo ?
-compiler_o_lo=$lt_compiler_o_lo
-# Must we lock files when doing compilation ?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_link_static_flag
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_no_builtin_flag
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds
-archive_expsym_cmds=$lt_archive_expsym_cmds
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator
-# Set to yes if using DIR/libNAME.so during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms
-# ### END LIBTOOL CONFIG
-__EOF__
- case $host_os in
- aix3*)
- cat <<\EOF >> "${ofile}T"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
-fi
-EOF
- esac
- case $host_os in
- cat <<'EOF' >> "${ofile}T"
- # This is a source program that is used to create dlls on Windows
- # Don't remove nor modify the starting and closing comments
-# /* ltdll.c starts here */
-# #define WIN32_LEAN_AND_MEAN
-# #include <windows.h>
-# #undef WIN32_LEAN_AND_MEAN
-# #include <stdio.h>
-# #ifndef __CYGWIN__
-# # ifdef __CYGWIN32__
-# # define __CYGWIN__ __CYGWIN32__
-# # endif
-# #endif
-# #ifdef __cplusplus
-# extern "C" {
-# #endif
-# BOOL APIENTRY DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved);
-# #endif
-# #ifdef __CYGWIN__
-# #include <cygwin/cygwin_dll.h>
-# DECLARE_CYGWIN_DLL( DllMain );
-# #endif
-# HINSTANCE __hDllInstance_base;
-# BOOL APIENTRY
-# DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved)
-# __hDllInstance_base = hInst;
-# return TRUE;
-# /* ltdll.c ends here */
- # This is a source program that is used to create import libraries
- # on Windows for dlls which lack them. Don't remove nor modify the
- # starting and closing comments
-# /* impgen.c starts here */
-# /* Copyright (C) 1999-2000 Free Software Foundation, Inc.
-# This file is part of GNU libtool.
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# GNU General Public License for more details.
-# #include <stdio.h> /* for printf() */
-# #include <unistd.h> /* for open(), lseek(), read() */
-# #include <fcntl.h> /* for O_RDONLY, O_BINARY */
-# #include <string.h> /* for strdup() */
-# /* O_BINARY isn't required (or even defined sometimes) under Unix */
-# #ifndef O_BINARY
-# #define O_BINARY 0
-# #endif
-# static unsigned int
-# pe_get16 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[2];
-# lseek (fd, offset, SEEK_SET);
-# read (fd, b, 2);
-# return b[0] + (b[1]<<8);
-# pe_get32 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[4];
-# read (fd, b, 4);
-# return b[0] + (b[1]<<8) + (b[2]<<16) + (b[3]<<24);
-# pe_as32 (ptr)
-# void *ptr;
-# unsigned char *b = ptr;
-# int
-# main (argc, argv)
-# int argc;
-# char *argv[];
-# int dll;
-# unsigned long pe_header_offset, opthdr_ofs, num_entries, i;
-# unsigned long export_rva, export_size, nsections, secptr, expptr;
-# unsigned long name_rvas, nexp;
-# unsigned char *expdata, *erva;
-# char *filename, *dll_name;
-# filename = argv[1];
-# dll = open(filename, O_RDONLY|O_BINARY);
-# if (dll < 1)
-# return 1;
-# dll_name = filename;
-# for (i=0; filename[i]; i++)
-# if (filename[i] == '/' || filename[i] == '\\' || filename[i] == ':')
-# dll_name = filename + i +1;
-# pe_header_offset = pe_get32 (dll, 0x3c);
-# opthdr_ofs = pe_header_offset + 4 + 20;
-# num_entries = pe_get32 (dll, opthdr_ofs + 92);
-# if (num_entries < 1) /* no exports */
-# return 1;
-# export_rva = pe_get32 (dll, opthdr_ofs + 96);
-# export_size = pe_get32 (dll, opthdr_ofs + 100);
-# nsections = pe_get16 (dll, pe_header_offset + 4 +2);
-# secptr = (pe_header_offset + 4 + 20 +
-# pe_get16 (dll, pe_header_offset + 4 + 16));
-# expptr = 0;
-# for (i = 0; i < nsections; i++)
-# char sname[8];
-# unsigned long secptr1 = secptr + 40 * i;
-# unsigned long vaddr = pe_get32 (dll, secptr1 + 12);
-# unsigned long vsize = pe_get32 (dll, secptr1 + 16);
-# unsigned long fptr = pe_get32 (dll, secptr1 + 20);
-# lseek(dll, secptr1, SEEK_SET);
-# read(dll, sname, 8);
-# if (vaddr <= export_rva && vaddr+vsize > export_rva)
-# expptr = fptr + (export_rva - vaddr);
-# if (export_rva + export_size > vaddr + vsize)
-# export_size = vsize - (export_rva - vaddr);
-# break;
-# expdata = (unsigned char*)malloc(export_size);
-# lseek (dll, expptr, SEEK_SET);
-# read (dll, expdata, export_size);
-# erva = expdata - export_rva;
-# nexp = pe_as32 (expdata+24);
-# name_rvas = pe_as32 (expdata+32);
-# printf ("EXPORTS\n");
-# for (i = 0; i<nexp; i++)
-# unsigned long name_rva = pe_as32 (erva+name_rvas+i*4);
-# printf ("\t%s @ %ld ;\n", erva+name_rva, 1+ i);
-# return 0;
-# /* impgen.c ends here */
-EOF
- esac
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "${ofile}T" || (rm -f "${ofile}T"; exit 1)
- mv -f "${ofile}T" "$ofile" || \
- (rm -f "$ofile" && cp "${ofile}T" "$ofile" && rm -f "${ofile}T")
- chmod +x "$ofile"
-fi
-## END FIXME
-])# _LT_AC_LTCONFIG_HACK
-# AC_LIBTOOL_DLOPEN - enable checks for dlopen support
-AC_DEFUN([AC_LIBTOOL_DLOPEN], [AC_BEFORE([$0],[AC_LIBTOOL_SETUP])])
-# AC_LIBTOOL_WIN32_DLL - declare package support for building win32 dll's
-AC_DEFUN([AC_LIBTOOL_WIN32_DLL], [AC_BEFORE([$0], [AC_LIBTOOL_SETUP])])
-# AC_ENABLE_SHARED - implement the --enable-shared flag
-# Usage: AC_ENABLE_SHARED[(DEFAULT)]
-# Where DEFAULT is either `yes' or `no'. If omitted, it defaults to
-# `yes'.
-AC_DEFUN([AC_ENABLE_SHARED],
-[define([AC_ENABLE_SHARED_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE(shared,
-changequote(<<, >>)dnl
-<< --enable-shared[=PKGS] build shared libraries [default=>>AC_ENABLE_SHARED_DEFAULT],
-changequote([, ])dnl
-[p=${PACKAGE-default}
-case $enableval in
-yes) enable_shared=yes ;;
-no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS="${IFS}:,"
- for pkg in $enableval; do
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- IFS="$ac_save_ifs"
-esac],
-enable_shared=AC_ENABLE_SHARED_DEFAULT)dnl
-# AC_DISABLE_SHARED - set the default shared flag to --disable-shared
-AC_DEFUN([AC_DISABLE_SHARED],
-[AC_BEFORE([$0],[AC_LIBTOOL_SETUP])dnl
-AC_ENABLE_SHARED(no)])
-# AC_ENABLE_STATIC - implement the --enable-static flag
-# Usage: AC_ENABLE_STATIC[(DEFAULT)]
-# `yes'.
-AC_DEFUN([AC_ENABLE_STATIC],
-[define([AC_ENABLE_STATIC_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE(static,
-<< --enable-static[=PKGS] build static libraries [default=>>AC_ENABLE_STATIC_DEFAULT],
-case $enableval in
-yes) enable_static=yes ;;
-no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
-esac],
-enable_static=AC_ENABLE_STATIC_DEFAULT)dnl
-# AC_DISABLE_STATIC - set the default static flag to --disable-static
-AC_DEFUN([AC_DISABLE_STATIC],
-AC_ENABLE_STATIC(no)])
-# AC_ENABLE_FAST_INSTALL - implement the --enable-fast-install flag
-# Usage: AC_ENABLE_FAST_INSTALL[(DEFAULT)]
-# `yes'.
-AC_DEFUN([AC_ENABLE_FAST_INSTALL],
-[define([AC_ENABLE_FAST_INSTALL_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE(fast-install,
-<< --enable-fast-install[=PKGS] optimize for fast installation [default=>>AC_ENABLE_FAST_INSTALL_DEFAULT],
-case $enableval in
-yes) enable_fast_install=yes ;;
-no) enable_fast_install=no ;;
- enable_fast_install=yes
- fi
- done
-esac],
-enable_fast_install=AC_ENABLE_FAST_INSTALL_DEFAULT)dnl
-# AC_DISABLE_FAST_INSTALL - set the default to --disable-fast-install
-AC_DEFUN([AC_DISABLE_FAST_INSTALL],
-AC_ENABLE_FAST_INSTALL(no)])
-# AC_LIBTOOL_PICMODE - implement the --with-pic flag
-# Usage: AC_LIBTOOL_PICMODE[(MODE)]
-# Where MODE is either `yes' or `no'. If omitted, it defaults to
-# `both'.
-AC_DEFUN([AC_LIBTOOL_PICMODE],
-pic_mode=ifelse($#,1,$1,default)])
-# AC_PATH_TOOL_PREFIX - find a file program which can recognise shared library
-AC_DEFUN([AC_PATH_TOOL_PREFIX],
-[AC_MSG_CHECKING([for $1])
-AC_CACHE_VAL(lt_cv_path_MAGIC_CMD,
-[case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a dos path.
- ac_save_MAGIC_CMD="$MAGIC_CMD"
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
-dnl $ac_dummy forces splitting on constant user-supplied paths.
-dnl POSIX.2 word splitting is done only on the output of word expansions,
-dnl not every word. This closes a longstanding sh security hole.
- ac_dummy="ifelse([$2], , $PATH, [$2])"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$1; then
- lt_cv_path_MAGIC_CMD="$ac_dir/$1"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- egrep "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$ac_save_MAGIC_CMD"
-esac])
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- AC_MSG_RESULT($MAGIC_CMD)
-else
- AC_MSG_RESULT(no)
-fi
-# AC_PATH_MAGIC - find a file program which can recognise a shared library
-AC_DEFUN([AC_PATH_MAGIC],
-[AC_REQUIRE([AC_CHECK_TOOL_PREFIX])dnl
-AC_PATH_TOOL_PREFIX(${ac_tool_prefix}file, /usr/bin:$PATH)
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- AC_PATH_TOOL_PREFIX(file, /usr/bin:$PATH)
- else
- MAGIC_CMD=:
- fi
-fi
-# AC_PROG_LD - find the path to the GNU or non-GNU linker
-AC_DEFUN([AC_PROG_LD],
-[AC_ARG_WITH(gnu-ld,
-[ --with-gnu-ld assume the C compiler uses GNU ld [default=no]],
-test "$withval" = no || with_gnu_ld=yes, with_gnu_ld=no)
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-AC_REQUIRE([_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR])dnl
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- AC_MSG_CHECKING([for ld used by GCC])
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- [[\\/]]* | [[A-Za-z]]:[[\\/]]*)
- re_direlt='/[[^/]][[^/]]*/\.\./'
- # Canonicalize the path of ld
- ac_prog=`echo $ac_prog| sed 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| sed "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- AC_MSG_CHECKING([for GNU ld])
-else
- AC_MSG_CHECKING([for non-GNU ld])
-fi
-AC_CACHE_VAL(lt_cv_path_LD,
-[if test -z "$LD"; then
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some GNU ld's only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- if "$lt_cv_path_LD" -v 2>&1 < /dev/null | egrep '(GNU|with BFD)' > /dev/null; then
- test "$with_gnu_ld" != no && break
- else
- test "$with_gnu_ld" != yes && break
- fi
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi])
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- AC_MSG_RESULT($LD)
-else
- AC_MSG_RESULT(no)
-fi
-test -z "$LD" && AC_MSG_ERROR([no acceptable ld found in \$PATH])
-AC_PROG_LD_GNU
-# AC_PROG_LD_GNU -
-AC_DEFUN([AC_PROG_LD_GNU],
-[AC_CACHE_CHECK([if the linker ($LD) is GNU ld], lt_cv_prog_gnu_ld,
-[# I'd rather use --version here, but apparently some GNU ld's only accept -v.
-if $LD -v 2>&1 </dev/null | egrep '(GNU|with BFD)' 1>&5; then
- lt_cv_prog_gnu_ld=yes
-else
- lt_cv_prog_gnu_ld=no
-fi])
-with_gnu_ld=$lt_cv_prog_gnu_ld
-# AC_PROG_LD_RELOAD_FLAG - find reload flag for linker
-# -- PORTME Some linkers may need a different reload flag.
-AC_DEFUN([AC_PROG_LD_RELOAD_FLAG],
-[AC_CACHE_CHECK([for $LD option to reload object files], lt_cv_ld_reload_flag,
-[lt_cv_ld_reload_flag='-r'])
-reload_flag=$lt_cv_ld_reload_flag
-test -n "$reload_flag" && reload_flag=" $reload_flag"
-# AC_DEPLIBS_CHECK_METHOD - how to check for library dependencies
-# -- PORTME fill in with the dynamic library characteristics
-AC_DEFUN([AC_DEPLIBS_CHECK_METHOD],
-[AC_CACHE_CHECK([how to recognise dependant libraries],
-lt_cv_deplibs_check_method,
-[lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given egrep regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix4* | aix5*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi4*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin* | mingw* | pw32*)
- lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
- lt_cv_file_magic_cmd='$OBJDUMP -f'
- lt_cv_deplibs_check_method='file_magic Mach-O dynamically linked shared library'
- lt_cv_file_magic_test_file=`echo /System/Library/Frameworks/System.framework/Versions/*/System | head -1`
- lt_cv_file_magic_test_file='/usr/lib/libSystem.dylib'
- esac
-freebsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD)/i[[3-9]]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-hpux10.20*|hpux11*)
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|PA-RISC[[0-9]].[[0-9]]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
-irix5* | irix6*)
- case $host_os in
- irix5*)
- # this will be overridden with pass_all, but let us keep it just in case
- lt_cv_deplibs_check_method="file_magic ELF 32-bit MSB dynamic lib MIPS - version 1"
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
- lt_cv_deplibs_check_method="file_magic ELF ${libmagic} MSB mips-[[1234]] dynamic lib MIPS - version 1"
- esac
- lt_cv_file_magic_test_file=`echo /lib${libsuff}/libc.so*`
-linux-gnu*)
- case $host_cpu in
- alpha* | hppa* | i*86 | powerpc* | sparc* | ia64* | s390* )
- lt_cv_deplibs_check_method=pass_all ;;
- # glibc up to 2.1.1 does not perform some relocations on ARM
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB (shared object|dynamic lib )' ;;
- esac
- lt_cv_file_magic_test_file=`echo /lib/libc.so* /lib/libc-*.so`
-netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[[^/\.]]+\.so\.[[0-9]]+\.[[0-9]]+$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[[^/\.]]+\.so$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-openbsd*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB shared object'
- else
- lt_cv_deplibs_check_method='file_magic OpenBSD.* shared library'
- fi
- lt_cv_deplibs_check_method='file_magic COFF format alpha shared library'
-sco3.2v5*)
-solaris*)
- lt_cv_file_magic_test_file=/lib/libc.so
-sysv5uw[[78]]* | sysv4*uw2*)
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib) M[[0-9]][[0-9]]* Version [[0-9]]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB dynamic lib"
- esac
-esac
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-# AC_PROG_NM - find the path to a BSD-compatible name lister
-AC_DEFUN([AC_PROG_NM],
-[AC_REQUIRE([_LT_AC_LIBTOOL_SYS_PATH_SEPARATOR])dnl
-AC_MSG_CHECKING([for BSD-compatible nm])
-AC_CACHE_VAL(lt_cv_path_NM,
-[if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm=$ac_dir/${ac_tool_prefix}nm
- if test -f $tmp_nm || test -f $tmp_nm$ac_exeext ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- if ($tmp_nm -B /dev/null 2>&1 | sed '1q'; exit 0) | egrep '(/dev/null|Invalid file or object type)' >/dev/null; then
- lt_cv_path_NM="$tmp_nm -B"
- break
- elif ($tmp_nm -p /dev/null 2>&1 | sed '1q'; exit 0) | egrep /dev/null >/dev/null; then
- lt_cv_path_NM="$tmp_nm -p"
- break
- else
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- fi
- fi
- done
- test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
-fi])
-NM="$lt_cv_path_NM"
-AC_MSG_RESULT([$NM])
-# AC_CHECK_LIBM - check for math library
-AC_DEFUN([AC_CHECK_LIBM],
-[AC_REQUIRE([AC_CANONICAL_HOST])dnl
-LIBM=
-case $host in
-*-*-beos* | *-*-cygwin* | *-*-pw32*)
- # These system don't have libm
-*-ncr-sysv4.3*)
- AC_CHECK_LIB(mw, _mwvalidcheckl, LIBM="-lmw")
- AC_CHECK_LIB(m, main, LIBM="$LIBM -lm")
- AC_CHECK_LIB(m, main, LIBM="-lm")
-esac
-# AC_LIBLTDL_CONVENIENCE[(dir)] - sets LIBLTDL to the link flags for
-# the libltdl convenience library and INCLTDL to the include flags for
-# the libltdl header and adds --enable-ltdl-convenience to the
-# configure arguments. Note that LIBLTDL and INCLTDL are not
-# AC_SUBSTed, nor is AC_CONFIG_SUBDIRS called. If DIR is not
-# provided, it is assumed to be `libltdl'. LIBLTDL will be prefixed
-# with '${top_builddir}/' and INCLTDL will be prefixed with
-# '${top_srcdir}/' (note the single quotes!). If your package is not
-# flat and you're not using automake, define top_builddir and
-# top_srcdir appropriately in the Makefiles.
-AC_DEFUN([AC_LIBLTDL_CONVENIENCE],
- case $enable_ltdl_convenience in
- no) AC_MSG_ERROR([this package needs a convenience libltdl]) ;;
- "") enable_ltdl_convenience=yes
- ac_configure_args="$ac_configure_args --enable-ltdl-convenience" ;;
- esac
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdlc.la
- INCLTDL='-I${top_srcdir}/'ifelse($#,1,[$1],['libltdl'])
-# AC_LIBLTDL_INSTALLABLE[(dir)] - sets LIBLTDL to the link flags for
-# the libltdl installable library and INCLTDL to the include flags for
-# the libltdl header and adds --enable-ltdl-install to the configure
-# arguments. Note that LIBLTDL and INCLTDL are not AC_SUBSTed, nor is
-# AC_CONFIG_SUBDIRS called. If DIR is not provided and an installed
-# libltdl is not found, it is assumed to be `libltdl'. LIBLTDL will
-# be prefixed with '${top_builddir}/' and INCLTDL will be prefixed
-# with '${top_srcdir}/' (note the single quotes!). If your package is
-# not flat and you're not using automake, define top_builddir and
-# In the future, this macro may have to be called after AC_PROG_LIBTOOL.
-AC_DEFUN([AC_LIBLTDL_INSTALLABLE],
- AC_CHECK_LIB(ltdl, main,
- [test x"$enable_ltdl_install" != xyes && enable_ltdl_install=no],
- [if test x"$enable_ltdl_install" = xno; then
- AC_MSG_WARN([libltdl not installed, but installation disabled])
- else
- enable_ltdl_install=yes
- fi
- if test x"$enable_ltdl_install" = x"yes"; then
- ac_configure_args="$ac_configure_args --enable-ltdl-install"
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdl.la
- else
- ac_configure_args="$ac_configure_args --enable-ltdl-install=no"
- LIBLTDL="-lltdl"
- INCLTDL=
- fi
-# old names
-AC_DEFUN([AM_PROG_LIBTOOL], [AC_PROG_LIBTOOL])
-AC_DEFUN([AM_ENABLE_SHARED], [AC_ENABLE_SHARED($@)])
-AC_DEFUN([AM_ENABLE_STATIC], [AC_ENABLE_STATIC($@)])
-AC_DEFUN([AM_DISABLE_SHARED], [AC_DISABLE_SHARED($@)])
-AC_DEFUN([AM_DISABLE_STATIC], [AC_DISABLE_STATIC($@)])
-AC_DEFUN([AM_PROG_LD], [AC_PROG_LD])
-AC_DEFUN([AM_PROG_NM], [AC_PROG_NM])
-# This is just to silence aclocal about the macro not being used
-ifelse([AC_DISABLE_FAST_INSTALL])
Deleted: mpich2/trunk/confdb/libtool.m4
--- mpich2/trunk/confdb/libtool.m4 2009-03-20 16:22:43 UTC (rev 4145)
+++ mpich2/trunk/confdb/libtool.m4 2009-03-20 17:00:18 UTC (rev 4146)
@@ -1,6397 +0,0 @@
-# libtool.m4 - Configure libtool for the host system. -*-Autoconf-*-
-## Copyright 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005
-## Free Software Foundation, Inc.
-## Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-## This file is free software; the Free Software Foundation gives
-## unlimited permission to copy and/or distribute it, with or without
-## modifications, as long as this notice is preserved.
-# serial 48 AC_PROG_LIBTOOL
-# AC_PROVIDE_IFELSE(MACRO-NAME, IF-PROVIDED, IF-NOT-PROVIDED)
-# If this macro is not defined by Autoconf, define it here.
-m4_ifdef([AC_PROVIDE_IFELSE],
- [m4_define([AC_PROVIDE_IFELSE],
- [m4_ifdef([AC_PROVIDE_$1],
- [$2], [$3])])])
-# AC_PROG_LIBTOOL
-AC_DEFUN([AC_PROG_LIBTOOL],
-[AC_REQUIRE([_AC_PROG_LIBTOOL])dnl
-dnl If AC_PROG_CXX has already been expanded, run AC_LIBTOOL_CXX
-dnl immediately, otherwise, hook it in at the end of AC_PROG_CXX.
- AC_PROVIDE_IFELSE([AC_PROG_CXX],
- [AC_LIBTOOL_CXX],
- [define([AC_PROG_CXX], defn([AC_PROG_CXX])[AC_LIBTOOL_CXX
-dnl And a similar setup for Fortran 77 support
- AC_PROVIDE_IFELSE([AC_PROG_F77],
- [AC_LIBTOOL_F77],
- [define([AC_PROG_F77], defn([AC_PROG_F77])[AC_LIBTOOL_F77
-dnl Quote A][M_PROG_GCJ so that aclocal doesn't bring it in needlessly.
-dnl If either AC_PROG_GCJ or A][M_PROG_GCJ have already been expanded, run
-dnl AC_LIBTOOL_GCJ immediately, otherwise, hook it in at the end of both.
- AC_PROVIDE_IFELSE([AC_PROG_GCJ],
- [AC_LIBTOOL_GCJ],
- [AC_PROVIDE_IFELSE([A][M_PROG_GCJ],
- [AC_LIBTOOL_GCJ],
- [AC_PROVIDE_IFELSE([LT_AC_PROG_GCJ],
- [AC_LIBTOOL_GCJ],
- [ifdef([AC_PROG_GCJ],
- [define([AC_PROG_GCJ], defn([AC_PROG_GCJ])[AC_LIBTOOL_GCJ])])
- ifdef([A][M_PROG_GCJ],
- [define([A][M_PROG_GCJ], defn([A][M_PROG_GCJ])[AC_LIBTOOL_GCJ])])
- ifdef([LT_AC_PROG_GCJ],
- [define([LT_AC_PROG_GCJ],
- defn([LT_AC_PROG_GCJ])[AC_LIBTOOL_GCJ])])])])
-])])# AC_PROG_LIBTOOL
-# _AC_PROG_LIBTOOL
-AC_DEFUN([_AC_PROG_LIBTOOL],
-[AC_REQUIRE([AC_LIBTOOL_SETUP])dnl
-AC_BEFORE([$0],[AC_LIBTOOL_CXX])dnl
-AC_BEFORE([$0],[AC_LIBTOOL_F77])dnl
-AC_BEFORE([$0],[AC_LIBTOOL_GCJ])dnl
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-AC_SUBST(LIBTOOL)dnl
-# Prevent multiple expansion
-define([AC_PROG_LIBTOOL], [])
-])# _AC_PROG_LIBTOOL
-# AC_LIBTOOL_SETUP
-AC_DEFUN([AC_LIBTOOL_SETUP],
-[AC_PREREQ(2.50)dnl
-AC_REQUIRE([AC_ENABLE_SHARED])dnl
-AC_REQUIRE([AC_ENABLE_STATIC])dnl
-AC_REQUIRE([AC_ENABLE_FAST_INSTALL])dnl
-AC_REQUIRE([AC_PROG_LD])dnl
-AC_REQUIRE([AC_PROG_LD_RELOAD_FLAG])dnl
-AC_REQUIRE([AC_PROG_NM])dnl
-AC_REQUIRE([AC_PROG_LN_S])dnl
-AC_REQUIRE([AC_DEPLIBS_CHECK_METHOD])dnl
-# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
-AC_REQUIRE([AC_OBJEXT])dnl
-AC_REQUIRE([AC_EXEEXT])dnl
-dnl
-AC_LIBTOOL_SYS_MAX_CMD_LEN
-AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-AC_LIBTOOL_OBJDIR
-AC_REQUIRE([_LT_AC_SYS_COMPILER])dnl
-_LT_AC_PROG_ECHO_BACKSLASH
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e 1s/^X//'
-[sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g']
-# Same as above, but do not quote variable references.
-[double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g']
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Sed substitution to avoid accidental globbing in evaled expressions
-no_glob_subst='s/\*/\\\*/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except MSVC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-AC_CHECK_TOOL(AR, ar, false)
-AC_CHECK_TOOL(RANLIB, ranlib, :)
-AC_CHECK_TOOL(STRIP, strip, :)
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$AR" && AR=ar
-test -z "$AR_FLAGS" && AR_FLAGS=cru
-test -z "$AS" && AS=as
-test -z "$CC" && CC=cc
-test -z "$LTCC" && LTCC=$CC
-test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-test -z "$LD" && LD=ld
-test -z "$LN_S" && LN_S="ln -s"
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-test -z "$NM" && NM=nm
-test -z "$SED" && SED=sed
-test -z "$OBJDUMP" && OBJDUMP=objdump
-test -z "$RANLIB" && RANLIB=:
-test -z "$STRIP" && STRIP=:
-test -z "$ac_objext" && ac_objext=o
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
-old_postinstall_cmds='chmod 644 $oldlib'
-if test -n "$RANLIB"; then
- case $host_os in
- openbsd*)
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$oldlib"
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$oldlib"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
-fi
-_LT_CC_BASENAME([$compiler])
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- AC_PATH_MAGIC
- fi
-esac
-AC_PROVIDE_IFELSE([AC_LIBTOOL_DLOPEN], enable_dlopen=yes, enable_dlopen=no)
-AC_PROVIDE_IFELSE([AC_LIBTOOL_WIN32_DLL],
-enable_win32_dll=yes, enable_win32_dll=no)
-AC_ARG_ENABLE([libtool-lock],
- [AC_HELP_STRING([--disable-libtool-lock],
- [avoid locking (might break parallel builds)])])
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-AC_ARG_WITH([pic],
- [AC_HELP_STRING([--with-pic],
- [try to use only PIC/non-PIC objects @<:@default=use both@:>@])],
- [pic_mode="$withval"],
- [pic_mode=default])
-test -z "$pic_mode" && pic_mode=default
-# Use C for the default configuration in the libtool script
-tagname=
-AC_LIBTOOL_LANG_C_CONFIG
-_LT_AC_TAGCONFIG
-])# AC_LIBTOOL_SETUP
-# _LT_AC_SYS_COMPILER
-AC_DEFUN([_LT_AC_SYS_COMPILER],
-[AC_REQUIRE([AC_PROG_CC])dnl
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-])# _LT_AC_SYS_COMPILER
-# _LT_CC_BASENAME(CC)
-# Calculate cc_basename. Skip known compiler wrappers and cross-prefix.
-AC_DEFUN([_LT_CC_BASENAME],
-[for cc_temp in $1""; do
- case $cc_temp in
- compile | *[[\\/]]compile | ccache | *[[\\/]]ccache ) ;;
- distcc | *[[\\/]]distcc | purify | *[[\\/]]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-# _LT_COMPILER_BOILERPLATE
-# Check for compiler boilerplate output or warnings with
-# the simple compiler test code.
-AC_DEFUN([_LT_COMPILER_BOILERPLATE],
-[ac_outfile=conftest.$ac_objext
-printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$rm conftest*
-])# _LT_COMPILER_BOILERPLATE
-# _LT_LINKER_BOILERPLATE
-# Check for linker boilerplate output or warnings with
-# the simple link test code.
-AC_DEFUN([_LT_LINKER_BOILERPLATE],
-printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$rm conftest*
-])# _LT_LINKER_BOILERPLATE
-# _LT_AC_SYS_LIBPATH_AIX
-# Links a minimal program and checks the executable
-# for the system default hardcoded library path. In most cases,
-# this is /usr/lib:/lib, but when the MPI compilers are used
-# the location of the communication and MPI libs are included too.
-# If we don't find anything, use the default library path according
-# to the aix ld manual.
-AC_DEFUN([_LT_AC_SYS_LIBPATH_AIX],
-[AC_LINK_IFELSE(AC_LANG_PROGRAM,[
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi],[])
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
-])# _LT_AC_SYS_LIBPATH_AIX
-# _LT_AC_SHELL_INIT(ARG)
-AC_DEFUN([_LT_AC_SHELL_INIT],
-[ifdef([AC_DIVERSION_NOTICE],
- [AC_DIVERT_PUSH(AC_DIVERSION_NOTICE)],
- [AC_DIVERT_PUSH(NOTICE)])
-$1
-AC_DIVERT_POP
-])# _LT_AC_SHELL_INIT
-# _LT_AC_PROG_ECHO_BACKSLASH
-# Add some code to the start of the generated configure script which
-# will find an echo command which doesn't interpret backslashes.
-AC_DEFUN([_LT_AC_PROG_ECHO_BACKSLASH],
-[_LT_AC_SHELL_INIT([
-# Check that we are running under the correct shell.
-SHELL=${CONFIG_SHELL-/bin/sh}
-case X$ECHO in
-X*--fallback-echo)
- # Remove one level of quotation (which was required for Make).
- ECHO=`echo "$ECHO" | sed 's,\\\\\[$]\\[$]0,'[$]0','`
-esac
-echo=${ECHO-echo}
-if test "X[$]1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X[$]1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell.
- exec $SHELL "[$]0" --no-reexec ${1+"[$]@"}
-fi
-if test "X[$]1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-if test -z "$ECHO"; then
-if test "X${echo_test_string+set}" != Xset; then
-# find a string as large as possible, as long as the shell can cope with it
- for cmd in 'sed 50q "[$]0"' 'sed 20q "[$]0"' 'sed 10q "[$]0"' 'sed 2q "[$]0"' 'echo test'; do
- # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
- if (echo_test_string=`eval $cmd`) 2>/dev/null &&
- echo_test_string=`eval $cmd` &&
- (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
- then
- break
- fi
- done
-fi
-if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
- test "X$echo_testing_string" = "X$echo_test_string"; then
-else
- # The Solaris, AIX, and Digital Unix default echo programs unquote
- # backslashes. This makes it impossible to quote backslashes using
- # echo "$something" | sed 's/\\/\\\\/g'
- # So, first we look for a working echo in the user's PATH.
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for dir in $PATH /usr/ucb; do
- IFS="$lt_save_ifs"
- if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
- test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
- echo="$dir/echo"
- break
- fi
- done
- if test "X$echo" = Xecho; then
- # We didn't find a better echo, so look for alternatives.
- if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
- # This shell has a builtin print -r that does the trick.
- echo='print -r'
- elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
- test "X$CONFIG_SHELL" != X/bin/ksh; then
- # If we have ksh, try running configure again with it.
- ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
- export ORIGINAL_CONFIG_SHELL
- CONFIG_SHELL=/bin/ksh
- export CONFIG_SHELL
- exec $CONFIG_SHELL "[$]0" --no-reexec ${1+"[$]@"}
- else
- # Try using printf.
- echo='printf %s\n'
- if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- # Cool, printf works
- elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- test "X$echo_testing_string" = 'X\t' &&
- echo_testing_string=`($ORIGINAL_CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
- SHELL="$CONFIG_SHELL"
- export SHELL
- echo="$CONFIG_SHELL [$]0 --fallback-echo"
- elif echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo '\t') 2>/dev/null` &&
- echo_testing_string=`($CONFIG_SHELL "[$]0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- else
- # maybe with a smaller string...
- prev=:
- for cmd in 'echo test' 'sed 2q "[$]0"' 'sed 10q "[$]0"' 'sed 20q "[$]0"' 'sed 50q "[$]0"'; do
- if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
- then
- break
- fi
- prev="$cmd"
- done
- if test "$prev" != 'sed 50q "[$]0"'; then
- echo_test_string=`eval $prev`
- export echo_test_string
- exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "[$]0" ${1+"[$]@"}
- else
- # Oops. We lost completely, so just stick with echo.
- echo=echo
- fi
- fi
- fi
- fi
-fi
-fi
-# Copy echo and quote the copy suitably for passing to libtool from
-# the Makefile, instead of quoting the original, which is used later.
-ECHO=$echo
-if test "X$ECHO" = "X$CONFIG_SHELL [$]0 --fallback-echo"; then
- ECHO="$CONFIG_SHELL \\\$\[$]0 --fallback-echo"
-fi
-AC_SUBST(ECHO)
-])])# _LT_AC_PROG_ECHO_BACKSLASH
-# _LT_AC_LOCK
-AC_DEFUN([_LT_AC_LOCK],
-[AC_ARG_ENABLE([libtool-lock],
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-ia64-*-hpux*)
- # Find out which ABI we are using.
- echo 'int i;' > conftest.$ac_ext
- case `/usr/bin/file conftest.$ac_objext` in
- *ELF-32*)
- HPUX_IA64_MODE="32"
- *ELF-64*)
- HPUX_IA64_MODE="64"
- esac
- fi
- rm -rf conftest*
-*-*-irix6*)
- echo '[#]line __oline__ "configure"' > conftest.$ac_ext
- if test "$lt_cv_prog_gnu_ld" = yes; then
- *32-bit*)
- LD="${LD-ld} -melf32bsmip"
- *N32*)
- LD="${LD-ld} -melf32bmipn32"
- *64-bit*)
- LD="${LD-ld} -melf64bmip"
- esac
- else
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- fi
- rm -rf conftest*
-x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
- case `/usr/bin/file conftest.o` in
- *32-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_i386"
- ppc64-*linux*|powerpc64-*linux*)
- LD="${LD-ld} -m elf32ppclinux"
- s390x-*linux*)
- LD="${LD-ld} -m elf_s390"
- sparc64-*linux*)
- LD="${LD-ld} -m elf32_sparc"
- esac
- *64-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_x86_64"
- ppc*-*linux*|powerpc*-*linux*)
- LD="${LD-ld} -m elf64ppc"
- s390*-*linux*)
- LD="${LD-ld} -m elf64_s390"
- sparc*-*linux*)
- LD="${LD-ld} -m elf64_sparc"
- esac
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- AC_CACHE_CHECK([whether the C compiler needs -belf], lt_cv_cc_needs_belf,
- [AC_LANG_PUSH(C)
- AC_TRY_LINK([],[],[lt_cv_cc_needs_belf=yes],[lt_cv_cc_needs_belf=no])
- AC_LANG_POP])
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-sparc*-*solaris*)
- *64-bit*)
- case $lt_cv_prog_gnu_ld in
- yes*) LD="${LD-ld} -m elf64_sparc" ;;
- *) LD="${LD-ld} -64" ;;
- esac
- esac
- fi
- rm -rf conftest*
-[*-*-cygwin* | *-*-mingw* | *-*-pw32*)
- AC_CHECK_TOOL(DLLTOOL, dlltool, false)
- AC_CHECK_TOOL(AS, as, false)
- AC_CHECK_TOOL(OBJDUMP, objdump, false)
-esac
-need_locks="$enable_libtool_lock"
-])# _LT_AC_LOCK
-# AC_LIBTOOL_COMPILER_OPTION(MESSAGE, VARIABLE-NAME, FLAGS,
-# [OUTPUT-FILE], [ACTION-SUCCESS], [ACTION-FAILURE])
-# Check whether the given compiler option works
-AC_DEFUN([AC_LIBTOOL_COMPILER_OPTION],
-[AC_REQUIRE([LT_AC_PROG_SED])
-AC_CACHE_CHECK([$1], [$2],
- [$2=no
- ifelse([$4], , [ac_outfile=conftest.$ac_objext], [ac_outfile=$4])
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="$3"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
- -e 's: [[^ ]]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:__oline__: $lt_compile\"" >&AS_MESSAGE_LOG_FD)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&AS_MESSAGE_LOG_FD
- echo "$as_me:__oline__: \$? = $ac_status" >&AS_MESSAGE_LOG_FD
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings other than the usual output.
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
- $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
- if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
- $2=yes
- fi
- fi
- $rm conftest*
-if test x"[$]$2" = xyes; then
- ifelse([$5], , :, [$5])
-else
- ifelse([$6], , :, [$6])
-fi
-])# AC_LIBTOOL_COMPILER_OPTION
-# AC_LIBTOOL_LINKER_OPTION(MESSAGE, VARIABLE-NAME, FLAGS,
-# [ACTION-SUCCESS], [ACTION-FAILURE])
-AC_DEFUN([AC_LIBTOOL_LINKER_OPTION],
-[AC_CACHE_CHECK([$1], [$2],
- [$2=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $3"
- printf "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The linker can only warn and ignore the option if not recognized
- if test -s conftest.err; then
- # Append any errors to the config.log.
- cat conftest.err 1>&AS_MESSAGE_LOG_FD
- $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
- if diff conftest.exp conftest.er2 >/dev/null; then
- $2=yes
- fi
- else
- $2=yes
- fi
- fi
- $rm conftest*
- LDFLAGS="$save_LDFLAGS"
- ifelse([$4], , :, [$4])
-else
-fi
-])# AC_LIBTOOL_LINKER_OPTION
-# AC_LIBTOOL_SYS_MAX_CMD_LEN
-AC_DEFUN([AC_LIBTOOL_SYS_MAX_CMD_LEN],
-[# find the maximum length of command line arguments
-AC_MSG_CHECKING([the maximum length of command line arguments])
-AC_CACHE_VAL([lt_cv_sys_max_cmd_len], [dnl
- i=0
- teststring="ABCD"
- case $build_os in
- msdosdjgpp*)
- # On DJGPP, this test can blow up pretty badly due to problems in libc
- # (any single argument exceeding 2000 bytes causes a buffer overrun
- # during glob expansion). Even if it were fixed, the result of this
- # check would be larger than it should be.
- lt_cv_sys_max_cmd_len=12288; # 12K is about right
- gnu*)
- # Under GNU Hurd, this test is not required because there is
- # no limit to the length of command line arguments.
- # Libtool will interpret -1 as no limit whatsoever
- lt_cv_sys_max_cmd_len=-1;
- cygwin* | mingw*)
- # On Win9x/ME, this test blows up -- it succeeds, but takes
- # about 5 minutes as the teststring grows exponentially.
- # Worse, since 9x/ME are not pre-emptively multitasking,
- # you end up with a "frozen" computer, even though with patience
- # the test eventually succeeds (with a max line length of 256k).
- # Instead, let's just punt: use the minimum linelength reported by
- # all of the supported platforms: 8192 (on NT/2K/XP).
- lt_cv_sys_max_cmd_len=8192;
- amigaos*)
- # On AmigaOS with pdksh, this test takes hours, literally.
- # So we just punt and use a minimum line length of 8192.
- netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
- # This has been around since 386BSD, at least. Likely further.
- if test -x /sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
- elif test -x /usr/sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
- else
- lt_cv_sys_max_cmd_len=65536 # usable default for all BSDs
- fi
- # And add a safety zone
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
- interix*)
- # We know the value 262144 and hardcode it with a safety zone (like BSD)
- lt_cv_sys_max_cmd_len=196608
- osf*)
- # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
- # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
- # nice to cause kernel panics so lets avoid the loop below.
- # First set a reasonable default.
- lt_cv_sys_max_cmd_len=16384
- if test -x /sbin/sysconfig; then
- case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
- *1*) lt_cv_sys_max_cmd_len=-1 ;;
- esac
- fi
- sco3.2v5*)
- lt_cv_sys_max_cmd_len=102400
- sysv5* | sco5v6* | sysv4.2uw2*)
- kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
- if test -n "$kargmax"; then
- lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[[ ]]//'`
- else
- lt_cv_sys_max_cmd_len=32768
- fi
- # If test is not a shell built-in, we'll probably end up computing a
- # maximum length that is only half of the actual maximum length, but
- # we can't tell.
- SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
- while (test "X"`$SHELL [$]0 --fallback-echo "X$teststring" 2>/dev/null` \
- = "XX$teststring") >/dev/null 2>&1 &&
- new_result=`expr "X$teststring" : ".*" 2>&1` &&
- lt_cv_sys_max_cmd_len=$new_result &&
- test $i != 17 # 1/2 MB should be enough
- do
- i=`expr $i + 1`
- teststring=$teststring$teststring
- done
- teststring=
- # Add a significant safety factor because C++ compilers can tack on massive
- # amounts of additional arguments before passing them to the linker.
- # It appears as though 1/2 is a usable value.
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
- esac
-if test -n $lt_cv_sys_max_cmd_len ; then
- AC_MSG_RESULT($lt_cv_sys_max_cmd_len)
-else
- AC_MSG_RESULT(none)
-fi
-])# AC_LIBTOOL_SYS_MAX_CMD_LEN
-# _LT_AC_CHECK_DLFCN
-AC_DEFUN([_LT_AC_CHECK_DLFCN],
-[AC_CHECK_HEADERS(dlfcn.h)dnl
-])# _LT_AC_CHECK_DLFCN
-# _LT_AC_TRY_DLOPEN_SELF (ACTION-IF-TRUE, ACTION-IF-TRUE-W-USCORE,
-# ACTION-IF-FALSE, ACTION-IF-CROSS-COMPILING)
-AC_DEFUN([_LT_AC_TRY_DLOPEN_SELF],
-[AC_REQUIRE([_LT_AC_CHECK_DLFCN])dnl
-if test "$cross_compiling" = yes; then :
- [$4]
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<EOF
-[#line __oline__ "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- else
- puts (dlerror ());
- exit (status);
-EOF
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) >&AS_MESSAGE_LOG_FD 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) $1 ;;
- x$lt_dlneed_uscore) $2 ;;
- x$lt_dlunknown|x*) $3 ;;
- esac
- else :
- # compilation failed
- $3
- fi
-fi
-rm -fr conftest*
-])# _LT_AC_TRY_DLOPEN_SELF
-# AC_LIBTOOL_DLOPEN_SELF
-AC_DEFUN([AC_LIBTOOL_DLOPEN_SELF],
-if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- AC_CHECK_LIB([dl], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"],[
- lt_cv_dlopen="dyld"
- AC_CHECK_FUNC([shl_load],
- [lt_cv_dlopen="shl_load"],
- [AC_CHECK_LIB([dld], [shl_load],
- [lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"],
- [AC_CHECK_FUNC([dlopen],
- [lt_cv_dlopen="dlopen"],
- [AC_CHECK_LIB([dl], [dlopen],
- [AC_CHECK_LIB([svld], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"],
- [AC_CHECK_LIB([dld], [dld_link],
- [lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"])
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- AC_CACHE_CHECK([whether a program can dlopen itself],
- lt_cv_dlopen_self, [dnl
- _LT_AC_TRY_DLOPEN_SELF(
- lt_cv_dlopen_self=yes, lt_cv_dlopen_self=yes,
- lt_cv_dlopen_self=no, lt_cv_dlopen_self=cross)
- if test "x$lt_cv_dlopen_self" = xyes; then
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
- AC_CACHE_CHECK([whether a statically linked program can dlopen itself],
- lt_cv_dlopen_self_static, [dnl
- lt_cv_dlopen_self_static=yes, lt_cv_dlopen_self_static=yes,
- lt_cv_dlopen_self_static=no, lt_cv_dlopen_self_static=cross)
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-])# AC_LIBTOOL_DLOPEN_SELF
-# AC_LIBTOOL_PROG_CC_C_O([TAGNAME])
-# Check to see if options -c and -o are simultaneously supported by compiler
-AC_DEFUN([AC_LIBTOOL_PROG_CC_C_O],
-[AC_REQUIRE([_LT_AC_SYS_COMPILER])dnl
-AC_CACHE_CHECK([if $compiler supports -c -o file.$ac_objext],
- [_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)],
- [_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&AS_MESSAGE_LOG_FD
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
- $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
- if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
- _LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)=yes
- fi
- fi
- chmod u+w . 2>&AS_MESSAGE_LOG_FD
- $rm conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
- $rm out/* && rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-])# AC_LIBTOOL_PROG_CC_C_O
-# AC_LIBTOOL_SYS_HARD_LINK_LOCKS([TAGNAME])
-# Check to see if we can do hard links to lock some files if needed
-AC_DEFUN([AC_LIBTOOL_SYS_HARD_LINK_LOCKS],
-[AC_REQUIRE([_LT_AC_LOCK])dnl
-hard_links="nottested"
-if test "$_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- AC_MSG_CHECKING([if we can lock with hard links])
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- AC_MSG_RESULT([$hard_links])
- if test "$hard_links" = no; then
- AC_MSG_WARN([`$CC' does not support `-c -o', so `make -j' may be unsafe])
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-])# AC_LIBTOOL_SYS_HARD_LINK_LOCKS
-# AC_LIBTOOL_OBJDIR
-AC_DEFUN([AC_LIBTOOL_OBJDIR],
-[AC_CACHE_CHECK([for objdir], [lt_cv_objdir],
-[rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- lt_cv_objdir=.libs
-else
- # MS-DOS does not allow filenames that begin with a dot.
- lt_cv_objdir=_libs
-fi
-rmdir .libs 2>/dev/null])
-objdir=$lt_cv_objdir
-])# AC_LIBTOOL_OBJDIR
-# AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH([TAGNAME])
-# Check hardcoding attributes.
-AC_DEFUN([AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH],
-[AC_MSG_CHECKING([how to hardcode library paths into programs])
-_LT_AC_TAGVAR(hardcode_action, $1)=
-if test -n "$_LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)" || \
- test -n "$_LT_AC_TAGVAR(runpath_var, $1)" || \
- test "X$_LT_AC_TAGVAR(hardcode_automatic, $1)" = "Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$_LT_AC_TAGVAR(hardcode_direct, $1)" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, $1)" != no &&
- test "$_LT_AC_TAGVAR(hardcode_minus_L, $1)" != no; then
- # Linking always hardcodes the temporary library directory.
- _LT_AC_TAGVAR(hardcode_action, $1)=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- _LT_AC_TAGVAR(hardcode_action, $1)=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- _LT_AC_TAGVAR(hardcode_action, $1)=unsupported
-fi
-AC_MSG_RESULT([$_LT_AC_TAGVAR(hardcode_action, $1)])
-if test "$_LT_AC_TAGVAR(hardcode_action, $1)" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-])# AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH
-# AC_LIBTOOL_SYS_LIB_STRIP
-AC_DEFUN([AC_LIBTOOL_SYS_LIB_STRIP],
-[striplib=
-old_striplib=
-AC_MSG_CHECKING([whether stripping libraries is possible])
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- AC_MSG_RESULT([yes])
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- else
- AC_MSG_RESULT([no])
-fi
- esac
-fi
-])# AC_LIBTOOL_SYS_LIB_STRIP
-# AC_LIBTOOL_SYS_DYNAMIC_LINKER
-# PORTME Fill in your ld.so characteristics
-AC_DEFUN([AC_LIBTOOL_SYS_DYNAMIC_LINKER],
-[AC_MSG_CHECKING([dynamic linker characteristics])
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- if test "$host_cpu" = ia64; then
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[[01]] | aix4.[[01]].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- if test "$aix_use_runtimelinking" = yes; then
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([[^/]]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[[45]]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | [grep ';[c-zC-Z]:/' >/dev/null]; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[[123]]*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.[[01]]* | freebsdelf3.[[01]]*)
- freebsd3.[[2-9]]* | freebsdelf3.[[2-9]]* | \
- freebsd4.[[0-5]] | freebsdelf4.[[0-5]] | freebsd4.1.1 | freebsdelf4.1.1)
- freebsd*) # from 4.6 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-interix3*)
- need_version=no
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \[$]2)); skip = 1; } { if (!skip) print \[$]0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case $host_os in
- openbsd2.[[89]] | openbsd2.[[89]].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- if test "$with_gnu_ld" = yes; then
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- runpath_var=LD_RUN_PATH
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-uts4*)
- dynamic_linker=no
-esac
-AC_MSG_RESULT([$dynamic_linker])
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-])# AC_LIBTOOL_SYS_DYNAMIC_LINKER
-# _LT_AC_TAGCONFIG
-AC_DEFUN([_LT_AC_TAGCONFIG],
-[AC_ARG_WITH([tags],
- [AC_HELP_STRING([--with-tags@<:@=TAGS@:>@],
- [include additional configurations @<:@automatic@:>@])],
- [tagnames="$withval"])
-if test -f "$ltmain" && test -n "$tagnames"; then
- if test ! -f "${ofile}"; then
- AC_MSG_WARN([output file `$ofile' does not exist])
- fi
- if test -z "$LTCC"; then
- eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
- AC_MSG_WARN([output file `$ofile' does not look like a libtool script])
- else
- AC_MSG_WARN([using `LTCC=$LTCC', extracted from `$ofile'])
- fi
- fi
- if test -z "$LTCFLAGS"; then
- eval "`$SHELL ${ofile} --config | grep '^LTCFLAGS='`"
- fi
- # Extract list of available tagged configurations in $ofile.
- # Note that this assumes the entire list is on one line.
- available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for tagname in $tagnames; do
- # Check whether tagname contains only valid characters
- case `$echo "X$tagname" | $Xsed -e 's:[[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]]::g'` in
- *) AC_MSG_ERROR([invalid tag name: $tagname])
- esac
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
- then
- AC_MSG_ERROR([tag name \"$tagname\" already exists])
- fi
- # Update the list of available tags.
- if test -n "$tagname"; then
- echo appending configuration tag \"$tagname\" to $ofile
- case $tagname in
- CXX)
- if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
- ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
- (test "X$CXX" != "Xg++"))) ; then
- AC_LIBTOOL_LANG_CXX_CONFIG
- else
- tagname=""
- fi
- F77)
- if test -n "$F77" && test "X$F77" != "Xno"; then
- AC_LIBTOOL_LANG_F77_CONFIG
- else
- tagname=""
- fi
- GCJ)
- if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
- AC_LIBTOOL_LANG_GCJ_CONFIG
- else
- tagname=""
- fi
- RC)
- AC_LIBTOOL_LANG_RC_CONFIG
- AC_MSG_ERROR([Unsupported tag name: $tagname])
- esac
- # Append the new tag name to the list of available tags.
- if test -n "$tagname" ; then
- available_tags="$available_tags $tagname"
- fi
- fi
- done
- # Now substitute the updated list of available tags.
- if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
- mv "${ofile}T" "$ofile"
- chmod +x "$ofile"
- else
- rm -f "${ofile}T"
- AC_MSG_ERROR([unable to update list of available tagged configurations.])
- fi
-fi
-])# _LT_AC_TAGCONFIG
-# enable checks for dlopen support
-AC_DEFUN([AC_LIBTOOL_DLOPEN],
- [AC_BEFORE([$0],[AC_LIBTOOL_SETUP])
-# AC_LIBTOOL_WIN32_DLL
-# declare package support for building win32 DLLs
-AC_DEFUN([AC_LIBTOOL_WIN32_DLL],
-[AC_BEFORE([$0], [AC_LIBTOOL_SETUP])
-])# AC_LIBTOOL_WIN32_DLL
-# AC_ENABLE_SHARED([DEFAULT])
-# implement the --enable-shared flag
-# DEFAULT is either `yes' or `no'. If omitted, it defaults to `yes'.
-AC_DEFUN([AC_ENABLE_SHARED],
-[define([AC_ENABLE_SHARED_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE([shared],
- [AC_HELP_STRING([--enable-shared@<:@=PKGS@:>@],
- [build shared libraries @<:@default=]AC_ENABLE_SHARED_DEFAULT[@:>@])],
- [p=${PACKAGE-default}
- case $enableval in
- yes) enable_shared=yes ;;
- no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- for pkg in $enableval; do
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- esac],
- [enable_shared=]AC_ENABLE_SHARED_DEFAULT)
-])# AC_ENABLE_SHARED
-# AC_DISABLE_SHARED
-# set the default shared flag to --disable-shared
-AC_DEFUN([AC_DISABLE_SHARED],
-[AC_BEFORE([$0],[AC_LIBTOOL_SETUP])dnl
-AC_ENABLE_SHARED(no)
-])# AC_DISABLE_SHARED
-# AC_ENABLE_STATIC([DEFAULT])
-# implement the --enable-static flag
-AC_DEFUN([AC_ENABLE_STATIC],
-[define([AC_ENABLE_STATIC_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE([static],
- [AC_HELP_STRING([--enable-static@<:@=PKGS@:>@],
- [build static libraries @<:@default=]AC_ENABLE_STATIC_DEFAULT[@:>@])],
- yes) enable_static=yes ;;
- no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
- esac],
- [enable_static=]AC_ENABLE_STATIC_DEFAULT)
-])# AC_ENABLE_STATIC
-# AC_DISABLE_STATIC
-# set the default static flag to --disable-static
-AC_DEFUN([AC_DISABLE_STATIC],
-AC_ENABLE_STATIC(no)
-])# AC_DISABLE_STATIC
-# AC_ENABLE_FAST_INSTALL([DEFAULT])
-# implement the --enable-fast-install flag
-AC_DEFUN([AC_ENABLE_FAST_INSTALL],
-[define([AC_ENABLE_FAST_INSTALL_DEFAULT], ifelse($1, no, no, yes))dnl
-AC_ARG_ENABLE([fast-install],
- [AC_HELP_STRING([--enable-fast-install@<:@=PKGS@:>@],
- [optimize for fast installation @<:@default=]AC_ENABLE_FAST_INSTALL_DEFAULT[@:>@])],
- yes) enable_fast_install=yes ;;
- no) enable_fast_install=no ;;
- enable_fast_install=yes
- fi
- done
- esac],
- [enable_fast_install=]AC_ENABLE_FAST_INSTALL_DEFAULT)
-])# AC_ENABLE_FAST_INSTALL
-# AC_DISABLE_FAST_INSTALL
-# set the default to --disable-fast-install
-AC_DEFUN([AC_DISABLE_FAST_INSTALL],
-AC_ENABLE_FAST_INSTALL(no)
-])# AC_DISABLE_FAST_INSTALL
-# AC_LIBTOOL_PICMODE([MODE])
-# implement the --with-pic flag
-# MODE is either `yes' or `no'. If omitted, it defaults to `both'.
-AC_DEFUN([AC_LIBTOOL_PICMODE],
-pic_mode=ifelse($#,1,$1,default)
-])# AC_LIBTOOL_PICMODE
-# AC_PROG_EGREP
-# This is predefined starting with Autoconf 2.54, so this conditional
-# definition can be removed once we require Autoconf 2.54 or later.
-m4_ifndef([AC_PROG_EGREP], [AC_DEFUN([AC_PROG_EGREP],
-[AC_CACHE_CHECK([for egrep], [ac_cv_prog_egrep],
- [if echo a | (grep -E '(a|b)') >/dev/null 2>&1
- then ac_cv_prog_egrep='grep -E'
- else ac_cv_prog_egrep='egrep'
- fi])
- EGREP=$ac_cv_prog_egrep
- AC_SUBST([EGREP])
-# AC_PATH_TOOL_PREFIX
-# find a file program which can recognise shared library
-AC_DEFUN([AC_PATH_TOOL_PREFIX],
-[AC_REQUIRE([AC_PROG_EGREP])dnl
-AC_MSG_CHECKING([for $1])
-AC_CACHE_VAL(lt_cv_path_MAGIC_CMD,
-[case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_save_MAGIC_CMD="$MAGIC_CMD"
-dnl $ac_dummy forces splitting on constant user-supplied paths.
-dnl POSIX.2 word splitting is done only on the output of word expansions,
-dnl not every word. This closes a longstanding sh security hole.
- ac_dummy="ifelse([$2], , $PATH, [$2])"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$1; then
- lt_cv_path_MAGIC_CMD="$ac_dir/$1"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- $EGREP "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$lt_save_MAGIC_CMD"
-esac])
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- AC_MSG_RESULT($MAGIC_CMD)
-else
- AC_MSG_RESULT(no)
-fi
-])# AC_PATH_TOOL_PREFIX
-# AC_PATH_MAGIC
-# find a file program which can recognise a shared library
-AC_DEFUN([AC_PATH_MAGIC],
-[AC_PATH_TOOL_PREFIX(${ac_tool_prefix}file, /usr/bin$PATH_SEPARATOR$PATH)
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- AC_PATH_TOOL_PREFIX(file, /usr/bin$PATH_SEPARATOR$PATH)
- else
- MAGIC_CMD=:
- fi
-fi
-])# AC_PATH_MAGIC
-# AC_PROG_LD
-# find the pathname to the GNU or non-GNU linker
-AC_DEFUN([AC_PROG_LD],
-[AC_ARG_WITH([gnu-ld],
- [AC_HELP_STRING([--with-gnu-ld],
- [assume the C compiler uses GNU ld @<:@default=no@:>@])],
- [test "$withval" = no || with_gnu_ld=yes],
- [with_gnu_ld=no])
-AC_REQUIRE([LT_AC_PROG_SED])dnl
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- AC_MSG_CHECKING([for ld used by $CC])
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[[^/]][[^/]]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- AC_MSG_CHECKING([for GNU ld])
-else
- AC_MSG_CHECKING([for non-GNU ld])
-fi
-AC_CACHE_VAL(lt_cv_path_LD,
-[if test -z "$LD"; then
- for ac_dir in $PATH; do
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some variants of GNU ld only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi])
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- AC_MSG_RESULT($LD)
-else
- AC_MSG_RESULT(no)
-fi
-test -z "$LD" && AC_MSG_ERROR([no acceptable ld found in \$PATH])
-AC_PROG_LD_GNU
-])# AC_PROG_LD
-# AC_PROG_LD_GNU
-AC_DEFUN([AC_PROG_LD_GNU],
-AC_CACHE_CHECK([if the linker ($LD) is GNU ld], lt_cv_prog_gnu_ld,
-[# I'd rather use --version here, but apparently some GNU lds only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac])
-with_gnu_ld=$lt_cv_prog_gnu_ld
-])# AC_PROG_LD_GNU
-# AC_PROG_LD_RELOAD_FLAG
-# find reload flag for linker
-# -- PORTME Some linkers may need a different reload flag.
-AC_DEFUN([AC_PROG_LD_RELOAD_FLAG],
-[AC_CACHE_CHECK([for $LD option to reload object files],
- lt_cv_ld_reload_flag,
- [lt_cv_ld_reload_flag='-r'])
-reload_flag=$lt_cv_ld_reload_flag
-case $reload_flag in
-*) reload_flag=" $reload_flag" ;;
-esac
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-case $host_os in
- darwin*)
- reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
- else
- reload_cmds='$LD$reload_flag -o $output$reload_objs'
- fi
-esac
-])# AC_PROG_LD_RELOAD_FLAG
-# AC_DEPLIBS_CHECK_METHOD
-# how to check for library dependencies
-# -- PORTME fill in with the dynamic library characteristics
-AC_DEFUN([AC_DEPLIBS_CHECK_METHOD],
-[AC_CACHE_CHECK([how to recognise dependent libraries],
-lt_cv_deplibs_check_method,
-[lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given extended regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix4* | aix5*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi[[45]]*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin*)
- # func_win32_libid is a shell function defined in ltmain.sh
- lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
- lt_cv_file_magic_cmd='func_win32_libid'
-mingw* | pw32*)
- # Base MSYS/MinGW do not provide the 'file' command needed by
- # func_win32_libid shell function, so use a weaker test based on 'objdump'.
- lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
- lt_cv_file_magic_cmd='$OBJDUMP -f'
-freebsd* | kfreebsd*-gnu | dragonfly*)
- if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[[3-9]]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-hpux10.20* | hpux11*)
- case $host_cpu in
- ia64*)
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|ELF-[[0-9]][[0-9]]) shared object file - IA64'
- lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
- hppa*64*)
- [lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]']
- lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|PA-RISC[[0-9]].[[0-9]]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
- esac
-interix3*)
- # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so|\.a)$'
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
-linux*)
-netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so\.[[0-9]]+\.[[0-9]]+|_pic\.a)$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so|_pic\.a)$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-nto-qnx*)
- lt_cv_deplibs_check_method=unknown
-openbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so\.[[0-9]]+\.[[0-9]]+|\.so|_pic\.a)$'
- else
- fi
-solaris*)
-sysv4 | sysv4.3*)
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib) M[[0-9]][[0-9]]* Version [[0-9]]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB (shared object|dynamic lib )'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB dynamic lib"
- lt_cv_file_magic_test_file=/lib/libc.so
- siemens)
- pc)
- esac
-esac
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-])# AC_DEPLIBS_CHECK_METHOD
-# AC_PROG_NM
-# find the pathname to a BSD-compatible name lister
-AC_DEFUN([AC_PROG_NM],
-[AC_CACHE_CHECK([for BSD-compatible nm], lt_cv_path_NM,
-[if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- lt_nm_to_check="${ac_tool_prefix}nm"
- if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
- lt_nm_to_check="$lt_nm_to_check nm"
- fi
- for lt_tmp_nm in $lt_nm_to_check; do
- for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm="$ac_dir/$lt_tmp_nm"
- if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
- */dev/null* | *'Invalid file or object type'*)
- lt_cv_path_NM="$tmp_nm -B"
- break
- case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
- */dev/null*)
- lt_cv_path_NM="$tmp_nm -p"
- break
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- esac
- esac
- fi
- done
- done
- test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
-fi])
-NM="$lt_cv_path_NM"
-])# AC_PROG_NM
-# AC_CHECK_LIBM
-# check for math library
-AC_DEFUN([AC_CHECK_LIBM],
-[AC_REQUIRE([AC_CANONICAL_HOST])dnl
-LIBM=
-case $host in
-*-*-beos* | *-*-cygwin* | *-*-pw32* | *-*-darwin*)
- # These system don't have libm, or don't need it
-*-ncr-sysv4.3*)
- AC_CHECK_LIB(mw, _mwvalidcheckl, LIBM="-lmw")
- AC_CHECK_LIB(m, cos, LIBM="$LIBM -lm")
- AC_CHECK_LIB(m, cos, LIBM="-lm")
-esac
-])# AC_CHECK_LIBM
-# AC_LIBLTDL_CONVENIENCE([DIRECTORY])
-# sets LIBLTDL to the link flags for the libltdl convenience library and
-# LTDLINCL to the include flags for the libltdl header and adds
-# --enable-ltdl-convenience to the configure arguments. Note that
-# AC_CONFIG_SUBDIRS is not called here. If DIRECTORY is not provided,
-# it is assumed to be `libltdl'. LIBLTDL will be prefixed with
-# '${top_builddir}/' and LTDLINCL will be prefixed with '${top_srcdir}/'
-# (note the single quotes!). If your package is not flat and you're not
-# using automake, define top_builddir and top_srcdir appropriately in
-# the Makefiles.
-AC_DEFUN([AC_LIBLTDL_CONVENIENCE],
- case $enable_ltdl_convenience in
- no) AC_MSG_ERROR([this package needs a convenience libltdl]) ;;
- "") enable_ltdl_convenience=yes
- ac_configure_args="$ac_configure_args --enable-ltdl-convenience" ;;
- esac
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdlc.la
- LTDLINCL='-I${top_srcdir}/'ifelse($#,1,[$1],['libltdl'])
- # For backwards non-gettext consistent compatibility...
- INCLTDL="$LTDLINCL"
-])# AC_LIBLTDL_CONVENIENCE
-# AC_LIBLTDL_INSTALLABLE([DIRECTORY])
-# sets LIBLTDL to the link flags for the libltdl installable library and
-# --enable-ltdl-install to the configure arguments. Note that
-# and an installed libltdl is not found, it is assumed to be `libltdl'.
-# LIBLTDL will be prefixed with '${top_builddir}/'# and LTDLINCL with
-# '${top_srcdir}/' (note the single quotes!). If your package is not
-# flat and you're not using automake, define top_builddir and top_srcdir
-# appropriately in the Makefiles.
-# In the future, this macro may have to be called after AC_PROG_LIBTOOL.
-AC_DEFUN([AC_LIBLTDL_INSTALLABLE],
- AC_CHECK_LIB(ltdl, lt_dlinit,
- [test x"$enable_ltdl_install" != xyes && enable_ltdl_install=no],
- [if test x"$enable_ltdl_install" = xno; then
- AC_MSG_WARN([libltdl not installed, but installation disabled])
- else
- enable_ltdl_install=yes
- fi
- if test x"$enable_ltdl_install" = x"yes"; then
- ac_configure_args="$ac_configure_args --enable-ltdl-install"
- LIBLTDL='${top_builddir}/'ifelse($#,1,[$1],['libltdl'])/libltdl.la
- else
- ac_configure_args="$ac_configure_args --enable-ltdl-install=no"
- LIBLTDL="-lltdl"
- LTDLINCL=
- fi
-])# AC_LIBLTDL_INSTALLABLE
-# AC_LIBTOOL_CXX
-# enable support for C++ libraries
-AC_DEFUN([AC_LIBTOOL_CXX],
-[AC_REQUIRE([_LT_AC_LANG_CXX])
-])# AC_LIBTOOL_CXX
-# _LT_AC_LANG_CXX
-AC_DEFUN([_LT_AC_LANG_CXX],
-[AC_REQUIRE([AC_PROG_CXX])
-AC_REQUIRE([_LT_AC_PROG_CXXCPP])
-_LT_AC_SHELL_INIT([tagnames=${tagnames+${tagnames},}CXX])
-])# _LT_AC_LANG_CXX
-# _LT_AC_PROG_CXXCPP
-AC_DEFUN([_LT_AC_PROG_CXXCPP],
-AC_REQUIRE([AC_PROG_CXX])
-if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
- AC_PROG_CXXCPP
-fi
-])# _LT_AC_PROG_CXXCPP
-# AC_LIBTOOL_F77
-# enable support for Fortran 77 libraries
-AC_DEFUN([AC_LIBTOOL_F77],
-[AC_REQUIRE([_LT_AC_LANG_F77])
-])# AC_LIBTOOL_F77
-# _LT_AC_LANG_F77
-AC_DEFUN([_LT_AC_LANG_F77],
-[AC_REQUIRE([AC_PROG_F77])
-_LT_AC_SHELL_INIT([tagnames=${tagnames+${tagnames},}F77])
-])# _LT_AC_LANG_F77
-# AC_LIBTOOL_GCJ
-# enable support for GCJ libraries
-AC_DEFUN([AC_LIBTOOL_GCJ],
-[AC_REQUIRE([_LT_AC_LANG_GCJ])
-])# AC_LIBTOOL_GCJ
-# _LT_AC_LANG_GCJ
-AC_DEFUN([_LT_AC_LANG_GCJ],
-[AC_PROVIDE_IFELSE([AC_PROG_GCJ],[],
- [AC_PROVIDE_IFELSE([A][M_PROG_GCJ],[],
- [AC_PROVIDE_IFELSE([LT_AC_PROG_GCJ],[],
- [ifdef([AC_PROG_GCJ],[AC_REQUIRE([AC_PROG_GCJ])],
- [ifdef([A][M_PROG_GCJ],[AC_REQUIRE([A][M_PROG_GCJ])],
- [AC_REQUIRE([A][C_PROG_GCJ_OR_A][M_PROG_GCJ])])])])])])
-_LT_AC_SHELL_INIT([tagnames=${tagnames+${tagnames},}GCJ])
-])# _LT_AC_LANG_GCJ
-# AC_LIBTOOL_RC
-# enable support for Windows resource files
-AC_DEFUN([AC_LIBTOOL_RC],
-[AC_REQUIRE([LT_AC_PROG_RC])
-_LT_AC_SHELL_INIT([tagnames=${tagnames+${tagnames},}RC])
-])# AC_LIBTOOL_RC
-# AC_LIBTOOL_LANG_C_CONFIG
-# Ensure that the configuration vars for the C compiler are
-# suitably defined. Those variables are subsequently used by
-# AC_LIBTOOL_CONFIG to write the compiler configuration to `libtool'.
-AC_DEFUN([AC_LIBTOOL_LANG_C_CONFIG], [_LT_AC_LANG_C_CONFIG])
-AC_DEFUN([_LT_AC_LANG_C_CONFIG],
-[lt_save_CC="$CC"
-AC_LANG_PUSH(C)
-# Source file extension for C test sources.
-ac_ext=c
-# Object file extension for compiled C test sources.
-objext=o
-_LT_AC_TAGVAR(objext, $1)=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(){return(0);}\n'
-_LT_AC_SYS_COMPILER
-# save warnings/boilerplate of simple test code
-_LT_COMPILER_BOILERPLATE
-_LT_LINKER_BOILERPLATE
-## CAVEAT EMPTOR:
-## There is no encapsulation within the following macros, do not change
-## the running order or otherwise move them around unless you know exactly
-## what you are doing...
-AC_LIBTOOL_PROG_COMPILER_NO_RTTI($1)
-AC_LIBTOOL_PROG_COMPILER_PIC($1)
-AC_LIBTOOL_PROG_CC_C_O($1)
-AC_LIBTOOL_SYS_HARD_LINK_LOCKS($1)
-AC_LIBTOOL_PROG_LD_SHLIBS($1)
-AC_LIBTOOL_SYS_DYNAMIC_LINKER($1)
-AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH($1)
-AC_LIBTOOL_SYS_LIB_STRIP
-AC_LIBTOOL_DLOPEN_SELF
-# Report which library types will actually be built
-AC_MSG_CHECKING([if libtool supports shared libraries])
-AC_MSG_RESULT([$can_build_shared])
-AC_MSG_CHECKING([whether to build shared libraries])
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case $host_os in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4* | aix5*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
-esac
-AC_MSG_RESULT([$enable_shared])
-AC_MSG_CHECKING([whether to build static libraries])
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-AC_MSG_RESULT([$enable_static])
-AC_LIBTOOL_CONFIG($1)
-AC_LANG_POP
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_C_CONFIG
-# AC_LIBTOOL_LANG_CXX_CONFIG
-AC_DEFUN([AC_LIBTOOL_LANG_CXX_CONFIG], [_LT_AC_LANG_CXX_CONFIG(CXX)])
-AC_DEFUN([_LT_AC_LANG_CXX_CONFIG],
-[AC_LANG_PUSH(C++)
-_LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no
-_LT_AC_TAGVAR(allow_undefined_flag, $1)=
-_LT_AC_TAGVAR(always_export_symbols, $1)=no
-_LT_AC_TAGVAR(archive_expsym_cmds, $1)=
-_LT_AC_TAGVAR(export_dynamic_flag_spec, $1)=
-_LT_AC_TAGVAR(hardcode_direct, $1)=no
-_LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)=
-_LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)=
-_LT_AC_TAGVAR(hardcode_libdir_separator, $1)=
-_LT_AC_TAGVAR(hardcode_minus_L, $1)=no
-_LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
-_LT_AC_TAGVAR(hardcode_automatic, $1)=no
-_LT_AC_TAGVAR(module_cmds, $1)=
-_LT_AC_TAGVAR(module_expsym_cmds, $1)=
-_LT_AC_TAGVAR(link_all_deplibs, $1)=unknown
-_LT_AC_TAGVAR(old_archive_cmds, $1)=$old_archive_cmds
-_LT_AC_TAGVAR(no_undefined_flag, $1)=
-_LT_AC_TAGVAR(whole_archive_flag_spec, $1)=
-_LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)=no
-# Dependencies to place before and after the object being linked:
-_LT_AC_TAGVAR(predep_objects, $1)=
-_LT_AC_TAGVAR(postdep_objects, $1)=
-_LT_AC_TAGVAR(predeps, $1)=
-_LT_AC_TAGVAR(postdeps, $1)=
-_LT_AC_TAGVAR(compiler_lib_search_path, $1)=
-# Source file extension for C++ test sources.
-ac_ext=cpp
-# Object file extension for compiled C++ test sources.
-objext=o
-lt_simple_link_test_code='int main(int, char *[[]]) { return(0); }\n'
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# Allow CC to be a program name with arguments.
-lt_save_CC=$CC
-lt_save_LD=$LD
-lt_save_GCC=$GCC
-GCC=$GXX
-lt_save_with_gnu_ld=$with_gnu_ld
-lt_save_path_LD=$lt_cv_path_LD
-if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
- lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
-else
- $as_unset lt_cv_prog_gnu_ld
-fi
-if test -n "${lt_cv_path_LDCXX+set}"; then
- lt_cv_path_LD=$lt_cv_path_LDCXX
-else
- $as_unset lt_cv_path_LD
-fi
-test -z "${LDCXX+set}" || LD=$LDCXX
-CC=${CXX-"c++"}
-compiler=$CC
-_LT_AC_TAGVAR(compiler, $1)=$CC
-_LT_CC_BASENAME([$compiler])
-# We don't want -fno-exception wen compiling C++ code, so set the
-# no_builtin_flag separately
-if test "$GXX" = yes; then
- _LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=' -fno-builtin'
-else
-fi
- # Set up default GNU C++ configuration
- AC_PROG_LD
- # Check if GNU C++ uses GNU ld as the underlying linker, since the
- # archiving commands below assume that GNU ld is being used.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}--rpath ${wl}$libdir'
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}--export-dynamic'
- # If archive_cmds runs LD, not CC, wlarc should be empty
- # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
- # investigate it a little bit more. (MM)
- wlarc='${wl}'
- # ancient GNU ld didn't support --whole-archive et. al.
- if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
- grep 'no-whole-archive' > /dev/null; then
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- else
- with_gnu_ld=no
- wlarc=
- # A generic and very simple default shared library creation
- # command for GNU C++ for the case where it uses the native
- # linker, instead of GNU ld. If possible, this setting should
- # overridden to take advantage of the native linker features on
- # the platform it is being used on.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- fi
- # Commands to make compiler produce verbose output that lists
- # what "hidden" libraries, object files and flags are used when
- # linking a shared library.
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
-else
- GXX=no
- with_gnu_ld=no
- wlarc=
-fi
-# PORTME: fill in a description of your system's C++ link characteristics
-AC_MSG_CHECKING([whether the $compiler linker ($LD) supports shared libraries])
-_LT_AC_TAGVAR(ld_shlibs, $1)=yes
-case $host_os in
- aix3*)
- # FIXME: insert proper C++ library support
- _LT_AC_TAGVAR(ld_shlibs, $1)=no
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[[23]]|aix4.[[23]].*|aix5*)
- for ld_flag in $LDFLAGS; do
- case $ld_flag in
- *-brtl*)
- aix_use_runtimelinking=yes
- break
- esac
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- _LT_AC_TAGVAR(archive_cmds, $1)=''
- _LT_AC_TAGVAR(hardcode_direct, $1)=yes
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1)=':'
- _LT_AC_TAGVAR(link_all_deplibs, $1)=yes
- if test "$GXX" = yes; then
- case $host_os in aix4.[[012]]|aix4.[[012]].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- _LT_AC_TAGVAR(hardcode_direct, $1)=unsupported
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=yes
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-L$libdir'
- fi
- esac
- shared_flag='-shared'
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- _LT_AC_TAGVAR(always_export_symbols, $1)=yes
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- _LT_AC_SYS_LIBPATH_AIX
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-blibpath:$libdir:'"$aix_libpath"
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R $libdir:/usr/lib:/lib'
- _LT_AC_TAGVAR(allow_undefined_flag, $1)="-z nodefs"
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
- # Warning - without using the other run time loading flags,
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' ${wl}-bernotok'
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' ${wl}-berok'
- # Exported symbols can be pulled into shared objects from archives
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='$convenience'
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- fi
- chorus*)
- case $cc_basename in
- esac
- cygwin* | mingw* | pw32*)
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1) is actually meaningless,
- # as there is no search path for DLLs.
- _LT_AC_TAGVAR(always_export_symbols, $1)=no
- _LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)=yes
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- fi
- darwin* | rhapsody*)
- case $host_os in
- rhapsody* | darwin1.[[012]])
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-undefined ${wl}suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[[012]])
- 10.*)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-undefined ${wl}dynamic_lookup'
- esac
- fi
- esac
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no
- _LT_AC_TAGVAR(hardcode_direct, $1)=no
- _LT_AC_TAGVAR(hardcode_automatic, $1)=yes
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)=''
- if test "$GXX" = yes ; then
- lt_int_apple_cc_single_mod=no
- output_verbose_link_cmd='echo'
- if $CC -dumpspecs 2>&1 | $EGREP 'single_module' >/dev/null ; then
- lt_int_apple_cc_single_mod=yes
- fi
- if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- fi
- _LT_AC_TAGVAR(module_cmds, $1)='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- _LT_AC_TAGVAR(module_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- xlc*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- esac
- fi
- dgux*)
- ec++*)
- ghcx*)
- # Green Hills C++ Compiler
- esac
- freebsd[[12]]*)
- # C++ shared libraries reported to be fairly broken before switch to ELF
- freebsd-elf*)
- freebsd* | kfreebsd*-gnu | dragonfly*)
- # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
- # conventions
- _LT_AC_TAGVAR(ld_shlibs, $1)=yes
- gnu*)
- hpux9*)
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}+b ${wl}$libdir'
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1)=:
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-E'
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=yes # Not in the search PATH,
- # but as the default
- # location of the library.
- CC*)
- aCC*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- # There doesn't appear to be a way to prevent this compiler from
- # explicitly linking system object files so we need to strip them
- # from the output so that they don't get included in the library
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "[[-]]L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- fi
- esac
- hpux10*|hpux11*)
- if test $with_gnu_ld = no; then
- case $host_cpu in
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)='+b $libdir'
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=no
- esac
- CC*)
- aCC*)
- case $host_cpu in
- hppa*64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- case $host_cpu in
- hppa*64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- fi
- else
- fi
- esac
- interix3*)
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath,$libdir'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- irix5* | irix6*)
- CC*)
- # SGI C++
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- # Archives containing C++ object files must be created using
- # "CC -ar", where "CC" is the IRIX C++ compiler. This is
- # necessary to make sure instantiated templates are included
- # in the archive.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -ar -WR,-u -o $oldlib $oldobjs'
- if test "$with_gnu_ld" = no; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
- fi
- fi
- esac
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath ${wl}$libdir'
- linux*)
- KCC*)
- # Kuck and Associates, Inc. (KAI) C++ Compiler
- # KCC will only create a shared library if the output file
- # ends with ".so" (or ".sl" for HP-UX), so rename the library
- # to its proper name (with version) after linking.
- _LT_AC_TAGVAR(archive_cmds, $1)='tempext=`echo $shared_ext | $SED -e '\''s/\([[^()0-9A-Za-z{}]]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='tempext=`echo $shared_ext | $SED -e '\''s/\([[^()0-9A-Za-z{}]]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}--rpath,$libdir'
- # "CC -Bstatic", where "CC" is the KAI C++ compiler.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -Bstatic -o $oldlib $oldobjs'
- icpc*)
- # Intel C++
- with_gnu_ld=yes
- # version 8.0 and above of icpc choke on multiply defined symbols
- # if we add $predep_objects and $postdep_objects, however 7.1 and
- # earlier do not add the objects themselves.
- case `$CC -V 2>&1` in
- *"Version 7."*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- *) # Version 8.0 or newer
- tmp_idyn=
- case $host_cpu in
- ia64*) tmp_idyn=' -i_dynamic';;
- esac
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- esac
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
- pgCC*)
- # Portland Group C++ compiler
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
- cxx*)
- # Compaq C++
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-rpath $libdir'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx*)
- esac
- netbsd*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
- wlarc=
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-R$libdir'
- fi
- # Workaround some broken pre-1.5 toolchains
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
- openbsd2*)
- # C++ shared libraries are fairly broken
- openbsd*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
- fi
- osf3*)
- KCC*)
- RCC*)
- # Rational C++ 2.4.1
- cxx*)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' ${wl}-expect_unresolved ${wl}\*'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- if test "$GXX" = yes && test "$with_gnu_ld" = no; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- fi
- esac
- osf4* | osf5*)
- KCC*)
- # the KAI C++ compiler.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -o $oldlib $oldobjs'
- RCC*)
- cxx*)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' -expect_unresolved \*'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
- echo "-hidden">> $lib.exp~
- $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~
- $rm $lib.exp'
- # dependencies.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- fi
- esac
- psos*)
- sunos4*)
- CC*)
- # Sun C++ 4.x
- lcc*)
- # Lucid
- esac
- solaris*)
- CC*)
- # Sun C++ 4.2, 5.x and Centerline C++
- _LT_AC_TAGVAR(archive_cmds_need_lc,$1)=yes
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' -zdefs'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -G${allow_undefined_flag} ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- case $host_os in
- solaris2.[[0-5]] | solaris2.[[0-5]].*) ;;
- # The C++ compiler is used as linker so we must use $wl
- # flag to pass the commands to the underlying system
- # linker. We must also pass each convience library through
- # to the system linker between allextract/defaultextract.
- # The C++ compiler will combine linker options so we
- # cannot just pass the convience library names through
- # without $wl.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract'
- esac
- # "CC -xar", where "CC" is the Sun C++ compiler. This is
- # in the archive.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC -xar -o $oldlib $oldobjs'
- gcx*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- # The C++ compiler must be used to create the archive.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
- # GNU C++ compiler with Solaris linker
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' ${wl}-z ${wl}defs'
- if $CC --version | grep -v '^2\.7' > /dev/null; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- else
- # g++ 2.7 appears to require `-G' NOT `-shared' on this
- # platform.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- fi
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R $wl$libdir'
- fi
- esac
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[[01]].[[10]]* | unixware7* | sco3.2v5.0.[[024]]*)
- _LT_AC_TAGVAR(no_undefined_flag, $1)='${wl}-z,text'
- runpath_var='LD_RUN_PATH'
- CC*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- esac
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- # For security reasons, it is highly recommended that you always
- # use absolute paths for naming shared libraries, and exclude the
- # DT_RUNPATH tag from executables and libraries. But doing so
- # requires that you compile everything twice, which is a pain.
- # So that behaviour is only enabled if SCOABSPATH is set to a
- # non-empty value in the environment. Most likely only useful for
- # creating official distributions of packages.
- # This is a hack until libtool officially supports absolute path
- # names for shared libraries.
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-z,nodefs'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-Bexport'
- CC*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- esac
- tandem*)
- NCC*)
- # NonStop-UX NCC 3.20
- esac
- vxworks*)
-esac
-AC_MSG_RESULT([$_LT_AC_TAGVAR(ld_shlibs, $1)])
-test "$_LT_AC_TAGVAR(ld_shlibs, $1)" = no && can_build_shared=no
-_LT_AC_TAGVAR(GCC, $1)="$GXX"
-_LT_AC_TAGVAR(LD, $1)="$LD"
-## CAVEAT EMPTOR:
-AC_LIBTOOL_POSTDEP_PREDEP($1)
-AC_LANG_POP
-CC=$lt_save_CC
-LDCXX=$LD
-LD=$lt_save_LD
-GCC=$lt_save_GCC
-with_gnu_ldcxx=$with_gnu_ld
-with_gnu_ld=$lt_save_with_gnu_ld
-lt_cv_path_LDCXX=$lt_cv_path_LD
-lt_cv_path_LD=$lt_save_path_LD
-lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
-lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
-])# AC_LIBTOOL_LANG_CXX_CONFIG
-# AC_LIBTOOL_POSTDEP_PREDEP([TAGNAME])
-# Figure out "hidden" library dependencies from verbose
-# compiler output when linking a shared library.
-# Parse the compiler output and extract the necessary
-# objects, libraries and library flags.
-AC_DEFUN([AC_LIBTOOL_POSTDEP_PREDEP],[
-dnl we can't use the lt_simple_compile_test_code here,
-dnl because it contains code intended for an executable,
-dnl not a library. It's possible we should let each
-dnl tag define a new lt_????_link_test_code variable,
-dnl but it's only used here...
-ifelse([$1],[],[cat > conftest.$ac_ext <<EOF
-int a;
-void foo (void) { a = 0; }
-EOF
-],[$1],[CXX],[cat > conftest.$ac_ext <<EOF
-class Foo
-public:
- Foo (void) { a = 0; }
-private:
- int a;
-EOF
-],[$1],[F77],[cat > conftest.$ac_ext <<EOF
- subroutine foo
- implicit none
- integer*4 a
- a=0
- return
- end
-EOF
-],[$1],[GCJ],[cat > conftest.$ac_ext <<EOF
-public class foo {
- private int a;
- public void bar (void) {
- a = 0;
-EOF
-dnl Parse the compiler output and extract the necessary
-dnl objects, libraries and library flags.
-if AC_TRY_EVAL(ac_compile); then
- # Parse the compiler output and extract the necessary
- # objects, libraries and library flags.
- # Sentinel used to keep track of whether or not we are before
- # the conftest object file.
- pre_test_object_deps_done=no
- # The `*' in the case matches for architectures that use `case' in
- # $output_verbose_cmd can trigger glob expansion during the loop
- # eval without this substitution.
- output_verbose_link_cmd=`$echo "X$output_verbose_link_cmd" | $Xsed -e "$no_glob_subst"`
- for p in `eval $output_verbose_link_cmd`; do
- case $p in
- -L* | -R* | -l*)
- # Some compilers place space between "-{L,R}" and the path.
- # Remove the space.
- if test $p = "-L" \
- || test $p = "-R"; then
- prev=$p
- continue
- else
- prev=
- fi
- if test "$pre_test_object_deps_done" = no; then
- case $p in
- -L* | -R*)
- # Internal compiler library paths should come after those
- # provided the user. The postdeps already come after the
- # user supplied libs so there is no need to process them.
- if test -z "$_LT_AC_TAGVAR(compiler_lib_search_path, $1)"; then
- _LT_AC_TAGVAR(compiler_lib_search_path, $1)="${prev}${p}"
- else
- _LT_AC_TAGVAR(compiler_lib_search_path, $1)="${_LT_AC_TAGVAR(compiler_lib_search_path, $1)} ${prev}${p}"
- fi
- # The "-l" case would never come before the object being
- # linked, so don't bother handling this case.
- esac
- else
- if test -z "$_LT_AC_TAGVAR(postdeps, $1)"; then
- _LT_AC_TAGVAR(postdeps, $1)="${prev}${p}"
- else
- _LT_AC_TAGVAR(postdeps, $1)="${_LT_AC_TAGVAR(postdeps, $1)} ${prev}${p}"
- fi
- fi
- *.$objext)
- # This assumes that the test object file only shows up
- # once in the compiler output.
- if test "$p" = "conftest.$objext"; then
- pre_test_object_deps_done=yes
- continue
- fi
- if test -z "$_LT_AC_TAGVAR(predep_objects, $1)"; then
- _LT_AC_TAGVAR(predep_objects, $1)="$p"
- else
- _LT_AC_TAGVAR(predep_objects, $1)="$_LT_AC_TAGVAR(predep_objects, $1) $p"
- fi
- else
- if test -z "$_LT_AC_TAGVAR(postdep_objects, $1)"; then
- _LT_AC_TAGVAR(postdep_objects, $1)="$p"
- else
- _LT_AC_TAGVAR(postdep_objects, $1)="$_LT_AC_TAGVAR(postdep_objects, $1) $p"
- fi
- fi
- *) ;; # Ignore the rest.
- esac
- done
- # Clean up.
- rm -f a.out a.exe
-else
- echo "libtool.m4: error: problem compiling $1 test program"
-fi
-$rm -f confest.$objext
-# PORTME: override above test on systems where it is broken
-ifelse([$1],[CXX],
-[case $host_os in
-interix3*)
- # Interix 3.5 installs completely hosed .la files for C++, so rather than
- # hack all around it, let's just trust "g++" to DTRT.
- _LT_AC_TAGVAR(predep_objects,$1)=
- _LT_AC_TAGVAR(postdep_objects,$1)=
- _LT_AC_TAGVAR(postdeps,$1)=
-solaris*)
- CC*)
- # Adding this requires a known-good setup of shared libraries for
- # Sun compiler versions before 5.6, else PIC objects from an old
- # archive will be linked into the output, leading to subtle bugs.
- _LT_AC_TAGVAR(postdeps,$1)='-lCstd -lCrun'
- esac
-esac
-case " $_LT_AC_TAGVAR(postdeps, $1) " in
-*" -lc "*) _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no ;;
-esac
-])# AC_LIBTOOL_POSTDEP_PREDEP
-# AC_LIBTOOL_LANG_F77_CONFIG
-AC_DEFUN([AC_LIBTOOL_LANG_F77_CONFIG], [_LT_AC_LANG_F77_CONFIG(F77)])
-AC_DEFUN([_LT_AC_LANG_F77_CONFIG],
-AC_LANG_PUSH(Fortran 77)
-# Source file extension for f77 test sources.
-ac_ext=f
-# Object file extension for compiled f77 test sources.
-objext=o
-lt_simple_compile_test_code=" subroutine t\n return\n end\n"
-lt_simple_link_test_code=" program t\n end\n"
-lt_save_CC="$CC"
-CC=${F77-"f77"}
-compiler=$CC
-case $host_os in
-aix3*)
- fi
-aix4* | aix5*)
- fi
-esac
-_LT_AC_TAGVAR(GCC, $1)="$G77"
-AC_LANG_POP
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_F77_CONFIG
-# AC_LIBTOOL_LANG_GCJ_CONFIG
-AC_DEFUN([AC_LIBTOOL_LANG_GCJ_CONFIG], [_LT_AC_LANG_GCJ_CONFIG(GCJ)])
-AC_DEFUN([_LT_AC_LANG_GCJ_CONFIG],
-[AC_LANG_SAVE
-# Source file extension for Java test sources.
-ac_ext=java
-# Object file extension for compiled Java test sources.
-objext=o
-lt_simple_compile_test_code="class foo {}\n"
-lt_simple_link_test_code='public class conftest { public static void main(String[[]] argv) {}; }\n'
-lt_save_CC="$CC"
-CC=${GCJ-"gcj"}
-compiler=$CC
-# GCJ did not exist at the time GCC didn't implicitly link libc in.
-## CAVEAT EMPTOR:
-AC_LANG_RESTORE
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_GCJ_CONFIG
-# AC_LIBTOOL_LANG_RC_CONFIG
-# Ensure that the configuration vars for the Windows resource compiler are
-AC_DEFUN([AC_LIBTOOL_LANG_RC_CONFIG], [_LT_AC_LANG_RC_CONFIG(RC)])
-AC_DEFUN([_LT_AC_LANG_RC_CONFIG],
-[AC_LANG_SAVE
-# Source file extension for RC test sources.
-ac_ext=rc
-# Object file extension for compiled RC test sources.
-objext=o
-lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
-lt_simple_link_test_code="$lt_simple_compile_test_code"
-lt_save_CC="$CC"
-CC=${RC-"windres"}
-compiler=$CC
-_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)=yes
-AC_LANG_RESTORE
-CC="$lt_save_CC"
-])# AC_LIBTOOL_LANG_RC_CONFIG
-# AC_LIBTOOL_CONFIG([TAGNAME])
-# If TAGNAME is not passed, then create an initial libtool script
-# with a default configuration from the untagged config vars. Otherwise
-# add code to config.status for appending the configuration named by
-# TAGNAME from the matching tagged config vars.
-AC_DEFUN([AC_LIBTOOL_CONFIG],
-[# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- _LT_AC_TAGVAR(compiler, $1) \
- _LT_AC_TAGVAR(CC, $1) \
- _LT_AC_TAGVAR(LD, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1) \
- _LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1) \
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1) \
- _LT_AC_TAGVAR(thread_safe_flag_spec, $1) \
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1) \
- _LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1) \
- _LT_AC_TAGVAR(old_archive_cmds, $1) \
- _LT_AC_TAGVAR(old_archive_from_new_cmds, $1) \
- _LT_AC_TAGVAR(predep_objects, $1) \
- _LT_AC_TAGVAR(postdep_objects, $1) \
- _LT_AC_TAGVAR(predeps, $1) \
- _LT_AC_TAGVAR(postdeps, $1) \
- _LT_AC_TAGVAR(compiler_lib_search_path, $1) \
- _LT_AC_TAGVAR(archive_cmds, $1) \
- _LT_AC_TAGVAR(archive_expsym_cmds, $1) \
- _LT_AC_TAGVAR(postinstall_cmds, $1) \
- _LT_AC_TAGVAR(postuninstall_cmds, $1) \
- _LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1) \
- _LT_AC_TAGVAR(allow_undefined_flag, $1) \
- _LT_AC_TAGVAR(no_undefined_flag, $1) \
- _LT_AC_TAGVAR(export_symbols_cmds, $1) \
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1) \
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1) \
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1) \
- _LT_AC_TAGVAR(hardcode_automatic, $1) \
- _LT_AC_TAGVAR(module_cmds, $1) \
- _LT_AC_TAGVAR(module_expsym_cmds, $1) \
- _LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1) \
- _LT_AC_TAGVAR(exclude_expsyms, $1) \
- _LT_AC_TAGVAR(include_expsyms, $1); do
- case $var in
- _LT_AC_TAGVAR(old_archive_cmds, $1) | \
- _LT_AC_TAGVAR(old_archive_from_new_cmds, $1) | \
- _LT_AC_TAGVAR(archive_cmds, $1) | \
- _LT_AC_TAGVAR(archive_expsym_cmds, $1) | \
- _LT_AC_TAGVAR(module_cmds, $1) | \
- _LT_AC_TAGVAR(module_expsym_cmds, $1) | \
- _LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1) | \
- _LT_AC_TAGVAR(export_symbols_cmds, $1) | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\[$]0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\[$]0 --fallback-echo"[$]/[$]0 --fallback-echo"/'`
- esac
-ifelse([$1], [],
- [cfgfile="${ofile}T"
- trap "$rm \"$cfgfile\"; exit 1" 1 2 15
- $rm -f "$cfgfile"
- AC_MSG_NOTICE([creating $ofile])],
- [cfgfile="$ofile"])
- cat <<__EOF__ >> "$cfgfile"
-ifelse([$1], [],
-[#! $SHELL
-# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
-# Free Software Foundation, Inc.
-# This file is part of GNU Libtool:
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# A sed program that does not truncate output.
-SED=$lt_SED
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="$SED -e 1s/^X//"
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# The names of the tagged configurations supported by this script.
-available_tags=
-# ### BEGIN LIBTOOL CONFIG],
-[# ### BEGIN LIBTOOL TAG CONFIG: $tagname])
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$_LT_AC_TAGVAR(archive_cmds_need_lc, $1)
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$_LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-host_os=$host_os
-# The build system.
-build_alias=$build_alias
-build=$build
-build_os=$build_os
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# LTCC compiler flags.
-LTCFLAGS=$lt_LTCFLAGS
-# A language-specific compiler.
-CC=$lt_[]_LT_AC_TAGVAR(compiler, $1)
-# Is the compiler the GNU C compiler?
-with_gcc=$_LT_AC_TAGVAR(GCC, $1)
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_[]_LT_AC_TAGVAR(LD, $1)
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_wl, $1)
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_[]_LT_AC_TAGVAR(lt_cv_prog_compiler_c_o, $1)
-# Must we lock files when doing compilation?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_static, $1)
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_[]_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_[]_LT_AC_TAGVAR(export_dynamic_flag_spec, $1)
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_[]_LT_AC_TAGVAR(whole_archive_flag_spec, $1)
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_[]_LT_AC_TAGVAR(thread_safe_flag_spec, $1)
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_[]_LT_AC_TAGVAR(old_archive_cmds, $1)
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_[]_LT_AC_TAGVAR(old_archive_from_new_cmds, $1)
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_[]_LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1)
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_[]_LT_AC_TAGVAR(archive_cmds, $1)
-archive_expsym_cmds=$lt_[]_LT_AC_TAGVAR(archive_expsym_cmds, $1)
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_[]_LT_AC_TAGVAR(module_cmds, $1)
-module_expsym_cmds=$lt_[]_LT_AC_TAGVAR(module_expsym_cmds, $1)
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_[]_LT_AC_TAGVAR(predep_objects, $1)
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_[]_LT_AC_TAGVAR(postdep_objects, $1)
-# shared library.
-predeps=$lt_[]_LT_AC_TAGVAR(predeps, $1)
-# shared library.
-postdeps=$lt_[]_LT_AC_TAGVAR(postdeps, $1)
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_[]_LT_AC_TAGVAR(compiler_lib_search_path, $1)
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_[]_LT_AC_TAGVAR(allow_undefined_flag, $1)
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_[]_LT_AC_TAGVAR(no_undefined_flag, $1)
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$_LT_AC_TAGVAR(hardcode_action, $1)
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_[]_LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_[]_LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_[]_LT_AC_TAGVAR(hardcode_libdir_separator, $1)
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$_LT_AC_TAGVAR(hardcode_direct, $1)
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$_LT_AC_TAGVAR(hardcode_minus_L, $1)
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$_LT_AC_TAGVAR(hardcode_shlibpath_var, $1)
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$_LT_AC_TAGVAR(hardcode_automatic, $1)
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$_LT_AC_TAGVAR(link_all_deplibs, $1)
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$_LT_AC_TAGVAR(fix_srcfile_path, $1)"
-# Set to yes if exported symbols are required.
-always_export_symbols=$_LT_AC_TAGVAR(always_export_symbols, $1)
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_[]_LT_AC_TAGVAR(export_symbols_cmds, $1)
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_[]_LT_AC_TAGVAR(exclude_expsyms, $1)
-# Symbols that must always be exported.
-include_expsyms=$lt_[]_LT_AC_TAGVAR(include_expsyms, $1)
-ifelse([$1],[],
-[# ### END LIBTOOL CONFIG],
-[# ### END LIBTOOL TAG CONFIG: $tagname])
-__EOF__
-ifelse([$1],[], [
- case $host_os in
- aix3*)
- cat <<\EOF >> "$cfgfile"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
-fi
-EOF
- esac
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
- mv -f "$cfgfile" "$ofile" || \
- (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
- chmod +x "$ofile"
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-])# AC_LIBTOOL_CONFIG
-# AC_LIBTOOL_PROG_COMPILER_NO_RTTI([TAGNAME])
-AC_DEFUN([AC_LIBTOOL_PROG_COMPILER_NO_RTTI],
-[AC_REQUIRE([_LT_AC_SYS_COMPILER])dnl
-_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=
-if test "$GCC" = yes; then
- AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -fno-rtti -fno-exceptions],
- lt_cv_prog_compiler_rtti_exceptions,
- [-fno-rtti -fno-exceptions], [],
- [_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)="$_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1) -fno-rtti -fno-exceptions"])
-fi
-])# AC_LIBTOOL_PROG_COMPILER_NO_RTTI
-# AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-AC_DEFUN([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE],
-[AC_REQUIRE([AC_CANONICAL_HOST])
-AC_REQUIRE([AC_PROG_NM])
-AC_REQUIRE([AC_OBJEXT])
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-AC_MSG_CHECKING([command to parse $NM output from $compiler object])
-AC_CACHE_VAL([lt_cv_sys_global_symbol_pipe],
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[[BCDEGRST]]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([[_A-Za-z]][[_A-Za-z0-9]]*\)'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[[BCDT]]'
-cygwin* | mingw* | pw32*)
- symcode='[[ABCDGISTW]]'
-hpux*) # Its linker distinguishes data from code symbols
- if test "$host_cpu" = ia64; then
- symcode='[[ABCDEGRST]]'
- fi
- lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-linux*)
- symcode='[[ABCDGIRSTW]]'
- fi
-irix* | nonstopux*)
- symcode='[[BCDEGRST]]'
-osf*)
- symcode='[[BCDEGQRST]]'
-solaris*)
- symcode='[[BDRT]]'
-sco3.2v5*)
- symcode='[[DT]]'
-sysv4.2uw2*)
- symcode='[[DT]]'
-sysv5* | sco5v6* | unixware* | OpenUNIX*)
- symcode='[[ABDT]]'
-sysv4)
- symcode='[[DFNSTU]]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $build_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-case `$NM -V 2>&1` in
-*GNU* | *'with BFD'*)
- symcode='[[ABCDGIRSTW]]' ;;
-esac
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
- # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
- symxfrm="\\1 $ac_symprfx\\2 \\2"
- # Write the raw and C identifiers.
- lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[[ ]]\($symcode$symcode*\)[[ ]][[ ]]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
- if AC_TRY_EVAL(ac_compile); then
- # Now try to grab the symbols.
- nlist=conftest.nm
- if AC_TRY_EVAL(NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if grep ' nm_test_var$' "$nlist" >/dev/null; then
- if grep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr_t void *
-#else
-# define lt_ptr_t char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr_t address;
-lt_preloaded_symbols[[]] =
-EOF
- $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr_t) 0}
-#ifdef __cplusplus
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- lt_save_LIBS="$LIBS"
- lt_save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$_LT_AC_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)"
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext}; then
- pipe_works=yes
- fi
- LIBS="$lt_save_LIBS"
- CFLAGS="$lt_save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "$progname: failed program was:" >&AS_MESSAGE_LOG_FD
- cat conftest.$ac_ext >&5
- fi
- rm -f conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- fi
-done
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
- AC_MSG_RESULT(failed)
-else
- AC_MSG_RESULT(ok)
-fi
-]) # AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE
-# AC_LIBTOOL_PROG_COMPILER_PIC([TAGNAME])
-AC_DEFUN([AC_LIBTOOL_PROG_COMPILER_PIC],
-[_LT_AC_TAGVAR(lt_prog_compiler_wl, $1)=
-_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=
-_LT_AC_TAGVAR(lt_prog_compiler_static, $1)=
-AC_MSG_CHECKING([for $compiler option to produce PIC])
- ifelse([$1],[CXX],[
- # C++ specific cases for pic, static, wl, etc.
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='-Wl,'
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | os2* | pw32*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-DDLL_EXPORT'
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-fno-common'
- *djgpp*)
- # DJGPP does not support shared libraries at all
- interix3*)
- # Interix 3.x gcc -fpic/-fPIC options generate broken code.
- # Instead, we relocate shared libraries at runtime.
- sysv4*MP*)
- if test -d /usr/nec; then
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case $host_cpu in
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-fPIC'
- esac
- esac
- else
- case $host_os in
- aix4* | aix5*)
- else
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-bnso -bI:/lib/syscalls.exp'
- fi
- chorus*)
- cxch68*)
- # _LT_AC_TAGVAR(lt_prog_compiler_static, $1)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
- esac
- darwin*)
- xlc*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-qnocommon'
- esac
- dgux*)
- ec++*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-KPIC'
- ghcx*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-pic'
- esac
- # FreeBSD uses GNU C++
- hpux9* | hpux10* | hpux11*)
- CC*)
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='${wl}-a ${wl}archive'
- if test "$host_cpu" != ia64; then
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='+Z'
- fi
- aCC*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- interix*)
- # This is c89, which is MS Visual C++ (no shared libs)
- # Anyone wants to do a port?
- irix5* | irix6* | nonstopux*)
- CC*)
- _LT_AC_TAGVAR(lt_prog_compiler_static, $1)='-non_shared'
- # CC pic flag -KPIC is the default.
- esac
- linux*)
- KCC*)
- # KAI C++ Compiler
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='--backend -Wl,'
- icpc* | ecpc*)
- # Intel C++
- pgCC*)
- # Portland Group C++ compiler.
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-fpic'
- cxx*)
- # Compaq C++
- # Make sure the PIC flag is empty. It appears that all Alpha
- # Linux and Compaq Tru64 Unix objects are PIC.
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-W c,exportall'
- esac
- netbsd*)
- osf3* | osf4* | osf5*)
- KCC*)
- RCC*)
- cxx*)
- # Digital/Compaq C++
- esac
- psos*)
- solaris*)
- CC*)
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='-Qoption ld '
- gcx*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-PIC'
- esac
- sunos4*)
- CC*)
- # Sun C++ 4.x
- lcc*)
- # Lucid
- esac
- tandem*)
- NCC*)
- esac
- sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
- CC*)
- esac
- vxworks*)
- _LT_AC_TAGVAR(lt_prog_compiler_can_build_shared, $1)=no
- esac
- fi
- if test "$GCC" = yes; then
- case $host_os in
- aix*)
- fi
- amigaos*)
- # like `-m68040'.
- mingw* | pw32* | os2*)
- interix3*)
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- enable_shared=no
- sysv4*MP*)
- fi
- hpux*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- fi
- darwin*)
- xlc*)
- esac
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- # PIC (with -KPIC) is the default.
- newsos6)
- linux*)
- icc* | ecc*)
- pgcc* | pgf77* | pgf90* | pgf95*)
- # Portland Group compilers (*not* the Pentium gcc compiler,
- # which looks to be a dead project)
- ccc*)
- # All Alpha code is PIC.
- esac
- # All OSF/1 code is PIC.
- solaris*)
- f77* | f90* | f95*)
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='-Qoption ld ';;
- _LT_AC_TAGVAR(lt_prog_compiler_wl, $1)='-Wl,';;
- esac
- sunos4*)
- sysv4 | sysv4.2uw2* | sysv4.3*)
- sysv4*MP*)
- if test -d /usr/nec ;then
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)='-Kconform_pic'
- fi
- unicos*)
- uts4*)
- esac
- fi
-AC_MSG_RESULT([$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)])
-# Check to make sure the PIC flag actually works.
-if test -n "$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)"; then
- AC_LIBTOOL_COMPILER_OPTION([if $compiler PIC flag $_LT_AC_TAGVAR(lt_prog_compiler_pic, $1) works],
- _LT_AC_TAGVAR(lt_prog_compiler_pic_works, $1),
- [$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)ifelse([$1],[],[ -DPIC],[ifelse([$1],[CXX],[ -DPIC],[])])], [],
- [case $_LT_AC_TAGVAR(lt_prog_compiler_pic, $1) in
- *) _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=" $_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)" ;;
- esac],
- [_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)=
- _LT_AC_TAGVAR(lt_prog_compiler_can_build_shared, $1)=no])
-fi
-case $host_os in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- _LT_AC_TAGVAR(lt_prog_compiler_pic, $1)="$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)ifelse([$1],[],[ -DPIC],[ifelse([$1],[CXX],[ -DPIC],[])])"
-esac
-# Check to make sure the static flag actually works.
-wl=$_LT_AC_TAGVAR(lt_prog_compiler_wl, $1) eval lt_tmp_static_flag=\"$_LT_AC_TAGVAR(lt_prog_compiler_static, $1)\"
-AC_LIBTOOL_LINKER_OPTION([if $compiler static flag $lt_tmp_static_flag works],
- _LT_AC_TAGVAR(lt_prog_compiler_static_works, $1),
- $lt_tmp_static_flag,
- [_LT_AC_TAGVAR(lt_prog_compiler_static, $1)=])
-# AC_LIBTOOL_PROG_LD_SHLIBS([TAGNAME])
-# See if the linker supports building shared libraries.
-AC_DEFUN([AC_LIBTOOL_PROG_LD_SHLIBS],
-[AC_MSG_CHECKING([whether the $compiler linker ($LD) supports shared libraries])
-ifelse([$1],[CXX],[
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- case $host_os in
- aix4* | aix5*)
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\[$]2 == "T") || (\[$]2 == "D") || (\[$]2 == "B")) && ([substr](\[$]3,1,1) != ".")) { print \[$]3 } }'\'' | sort -u > $export_symbols'
- else
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\[$]2 == "T") || (\[$]2 == "D") || (\[$]2 == "B")) && ([substr](\[$]3,1,1) != ".")) { print \[$]3 } }'\'' | sort -u > $export_symbols'
- fi
- pw32*)
- _LT_AC_TAGVAR(export_symbols_cmds, $1)="$ltdll_cmds"
- cygwin* | mingw*)
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[[BCDGRS]] /s/.* \([[^ ]]*\)/\1 DATA/;/^.* __nm__/s/^.* __nm__\([[^ ]]*\) [[^ ]]*/\1 DATA/;/^I /d;/^[[AITW]] /s/.* //'\'' | sort | uniq > $export_symbols'
- esac
- runpath_var=
- _LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)=no
- _LT_AC_TAGVAR(old_archive_From_new_cmds, $1)=
- _LT_AC_TAGVAR(old_archive_from_expsyms_cmds, $1)=
- _LT_AC_TAGVAR(thread_safe_flag_spec, $1)=
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=no
- _LT_AC_TAGVAR(link_all_deplibs, $1)=unknown
- _LT_AC_TAGVAR(hardcode_automatic, $1)=no
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- _LT_AC_TAGVAR(include_expsyms, $1)=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- _LT_AC_TAGVAR(exclude_expsyms, $1)="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- # Just being paranoid about ensuring that cc_basename is set.
- _LT_CC_BASENAME([$compiler])
- case $host_os in
- cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- interix*)
- # we just hope/assume this is gcc and not c89 (= MSVC++)
- with_gnu_ld=yes
- openbsd*)
- with_gnu_ld=no
- esac
- if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # Set some defaults for GNU ld with shared library support. These
- # are reset later if shared libraries are not supported. Putting them
- # here allows them to be overridden if necessary.
- runpath_var=LD_RUN_PATH
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}--rpath ${wl}$libdir'
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- supports_anon_versioning=no
- case `$LD -v 2>/dev/null` in
- *\ [[01]].* | *\ 2.[[0-9]].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- _LT_AC_TAGVAR(ld_shlibs, $1)=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-L$libdir'
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- fi
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1) is actually meaningless,
- # as there is no search path for DLLs.
- _LT_AC_TAGVAR(always_export_symbols, $1)=no
- _LT_AC_TAGVAR(enable_shared_with_static_runtimes, $1)=yes
- _LT_AC_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[[BCDGRS]] /s/.* \([[^ ]]*\)/\1 DATA/'\'' | $SED -e '\''/^[[AITW]] /s/.* //'\'' | sort | uniq > $export_symbols'
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- fi
- interix3*)
- _LT_AC_TAGVAR(hardcode_direct, $1)=no
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-E'
- linux*)
- tmp_addflag=
- case $cc_basename,$host_cpu in
- pgcc*) # Portland Group C compiler
- tmp_addflag=' $pic_flag'
- pgf77* | pgf90* | pgf95*) # Portland Group f77 and f90 compilers
- tmp_addflag=' $pic_flag -Mnomain' ;;
- ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
- tmp_addflag=' -i_dynamic' ;;
- efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
- tmp_addflag=' -i_dynamic -nofor_main' ;;
- ifc* | ifort*) # Intel Fortran compiler
- tmp_addflag=' -nofor_main' ;;
- esac
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- if test $supports_anon_versioning = yes; then
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$echo "{ global:" > $output_objdir/$libname.ver~
- cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
- $echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- else
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- fi
- sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
- case `$LD -v 2>&1` in
- *\ [[01]].* | *\ 2.[[0-9]].* | *\ 2.1[[0-5]].*)
- cat <<_LT_EOF 1>&2
-*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
-*** reliably create shared libraries on SCO systems. Therefore, libtool
-*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
-_LT_EOF
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
- else
- fi
- esac
- sunos4*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- _LT_AC_TAGVAR(hardcode_direct, $1)=yes
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=no
- else
- fi
- esac
- if test "$_LT_AC_TAGVAR(ld_shlibs, $1)" = no; then
- runpath_var=
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- _LT_AC_TAGVAR(always_export_symbols, $1)=yes
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- _LT_AC_TAGVAR(hardcode_minus_L, $1)=yes
- if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- _LT_AC_TAGVAR(hardcode_direct, $1)=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- else
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[[23]]|aix4.[[23]].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- _LT_AC_TAGVAR(archive_cmds, $1)=''
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1)=':'
- _LT_AC_TAGVAR(link_all_deplibs, $1)=yes
- case $host_os in aix4.[[012]]|aix4.[[012]].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- _LT_AC_SYS_LIBPATH_AIX
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-blibpath:$libdir:'"$aix_libpath"
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R $libdir:/usr/lib:/lib'
- _LT_AC_TAGVAR(allow_undefined_flag, $1)="-z nodefs"
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
- # Warning - without using the other run time loading flags,
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' ${wl}-bernotok'
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' ${wl}-berok'
- # Exported symbols can be pulled into shared objects from archives
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='$convenience'
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- bsdi[[45]]*)
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- shrext_cmds=".dll"
- # FIXME: Setting linknames here is a bad hack.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- _LT_AC_TAGVAR(old_archive_From_new_cmds, $1)='true'
- # FIXME: Should let the user specify the lib program.
- _LT_AC_TAGVAR(old_archive_cmds, $1)='lib /OUT:$oldlib$oldobjs$old_deplibs'
- _LT_AC_TAGVAR(fix_srcfile_path, $1)='`cygpath -w "$srcfile"`'
- darwin* | rhapsody*)
- case $host_os in
- rhapsody* | darwin1.[[012]])
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-undefined ${wl}suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[[012]])
- 10.*)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-undefined ${wl}dynamic_lookup'
- esac
- fi
- esac
- _LT_AC_TAGVAR(archive_cmds_need_lc, $1)=no
- _LT_AC_TAGVAR(hardcode_automatic, $1)=yes
- _LT_AC_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)=''
- if test "$GCC" = yes ; then
- output_verbose_link_cmd='echo'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- _LT_AC_TAGVAR(module_cmds, $1)='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- _LT_AC_TAGVAR(module_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- case $cc_basename in
- xlc*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- esac
- fi
- dgux*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- freebsd1*)
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | kfreebsd*-gnu | dragonfly*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}+b ${wl}$libdir'
- _LT_AC_TAGVAR(hardcode_libdir_separator, $1)=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- hpux10*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- fi
- if test "$with_gnu_ld" = no; then
- fi
- hpux11*)
- case $host_cpu in
- hppa*64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- case $host_cpu in
- hppa*64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)='+b $libdir'
- esac
- fi
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec_ld, $1)='-rpath $libdir'
- fi
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath ${wl}$libdir'
- netbsd*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath,$libdir'
- else
- case $host_os in
- openbsd[[01]].* | openbsd2.[[0-7]] | openbsd2.[[0-7]].*)
- esac
- fi
- os2*)
- _LT_AC_TAGVAR(archive_cmds, $1)='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- _LT_AC_TAGVAR(old_archive_From_new_cmds, $1)='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' ${wl}-expect_unresolved ${wl}\*'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=' -expect_unresolved \*'
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='-rpath $libdir'
- fi
- solaris*)
- _LT_AC_TAGVAR(no_undefined_flag, $1)=' -z text'
- wlarc='${wl}'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- wlarc=''
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[[0-5]] | solaris2.[[0-5]].*) ;;
- # The compiler driver will combine linker options so we
- # cannot just pass the convience library names through
- # without $wl, iff we do not link with $LD.
- # Luckily, gcc supports the same syntax we need for Sun Studio.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- case $wlarc in
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='-z allextract$convenience -z defaultextract' ;;
- _LT_AC_TAGVAR(whole_archive_flag_spec, $1)='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
- esac ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- case $host_vendor in
- sni)
- _LT_AC_TAGVAR(hardcode_direct, $1)=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- _LT_AC_TAGVAR(archive_cmds, $1)='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- _LT_AC_TAGVAR(reload_cmds, $1)='$CC -r -o $output$reload_objs'
- motorola)
- _LT_AC_TAGVAR(hardcode_direct, $1)=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='-Bexport'
- sysv4*MP*)
- hardcode_runpath_var=yes
- _LT_AC_TAGVAR(ld_shlibs, $1)=yes
- fi
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[[01]].[[10]]* | unixware7*)
- _LT_AC_TAGVAR(no_undefined_flag, $1)='${wl}-z,text'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- _LT_AC_TAGVAR(allow_undefined_flag, $1)='${wl}-z,nodefs'
- _LT_AC_TAGVAR(hardcode_libdir_flag_spec, $1)='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
- _LT_AC_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-Bexport'
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_AC_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_AC_TAGVAR(archive_expsym_cmds, $1)='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- uts4*)
- esac
- fi
-AC_MSG_RESULT([$_LT_AC_TAGVAR(ld_shlibs, $1)])
-test "$_LT_AC_TAGVAR(ld_shlibs, $1)" = no && can_build_shared=no
-# Do we need to explicitly link libc?
-case "x$_LT_AC_TAGVAR(archive_cmds_need_lc, $1)" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $_LT_AC_TAGVAR(archive_cmds, $1) in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- AC_MSG_CHECKING([whether -lc should be explicitly linked in])
- $rm conftest*
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile) 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$_LT_AC_TAGVAR(lt_prog_compiler_wl, $1)
- pic_flag=$_LT_AC_TAGVAR(lt_prog_compiler_pic, $1)
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$_LT_AC_TAGVAR(allow_undefined_flag, $1)
- if AC_TRY_EVAL(_LT_AC_TAGVAR(archive_cmds, $1) 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1)
- then
- else
- fi
- _LT_AC_TAGVAR(allow_undefined_flag, $1)=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $rm conftest*
- AC_MSG_RESULT([$_LT_AC_TAGVAR(archive_cmds_need_lc, $1)])
- esac
- fi
-esac
-])# AC_LIBTOOL_PROG_LD_SHLIBS
-# _LT_AC_FILE_LTDLL_C
-# Be careful that the start marker always follows a newline.
-AC_DEFUN([_LT_AC_FILE_LTDLL_C], [
-# /* ltdll.c starts here */
-# #define WIN32_LEAN_AND_MEAN
-# #include <windows.h>
-# #undef WIN32_LEAN_AND_MEAN
-# #include <stdio.h>
-# #ifndef __CYGWIN__
-# # ifdef __CYGWIN32__
-# # define __CYGWIN__ __CYGWIN32__
-# # endif
-# #endif
-# #ifdef __cplusplus
-# extern "C" {
-# #endif
-# BOOL APIENTRY DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved);
-# #endif
-# #ifdef __CYGWIN__
-# #include <cygwin/cygwin_dll.h>
-# DECLARE_CYGWIN_DLL( DllMain );
-# #endif
-# HINSTANCE __hDllInstance_base;
-# BOOL APIENTRY
-# DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved)
-# __hDllInstance_base = hInst;
-# return TRUE;
-# /* ltdll.c ends here */
-])# _LT_AC_FILE_LTDLL_C
-# _LT_AC_TAGVAR(VARNAME, [TAGNAME])
-AC_DEFUN([_LT_AC_TAGVAR], [ifelse([$2], [], [$1], [$1_$2])])
-# old names
-AC_DEFUN([AM_PROG_LIBTOOL], [AC_PROG_LIBTOOL])
-AC_DEFUN([AM_ENABLE_SHARED], [AC_ENABLE_SHARED($@)])
-AC_DEFUN([AM_ENABLE_STATIC], [AC_ENABLE_STATIC($@)])
-AC_DEFUN([AM_DISABLE_SHARED], [AC_DISABLE_SHARED($@)])
-AC_DEFUN([AM_DISABLE_STATIC], [AC_DISABLE_STATIC($@)])
-AC_DEFUN([AM_PROG_LD], [AC_PROG_LD])
-AC_DEFUN([AM_PROG_NM], [AC_PROG_NM])
-# This is just to silence aclocal about the macro not being used
-ifelse([AC_DISABLE_FAST_INSTALL])
-AC_DEFUN([LT_AC_PROG_GCJ],
-[AC_CHECK_TOOL(GCJ, gcj, no)
- test "x${GCJFLAGS+set}" = xset || GCJFLAGS="-g -O2"
- AC_SUBST(GCJFLAGS)
-AC_DEFUN([LT_AC_PROG_RC],
-[AC_CHECK_TOOL(RC, windres, no)
-# NOTE: This macro has been submitted for inclusion into #
-# GNU Autoconf as AC_PROG_SED. When it is available in #
-# a released version of Autoconf we should remove this #
-# macro and use it instead. #
-# LT_AC_PROG_SED
-# Check for a fully-functional sed program, that truncates
-# as few characters as possible. Prefer GNU sed if found.
-AC_DEFUN([LT_AC_PROG_SED],
-[AC_MSG_CHECKING([for a sed that does not truncate output])
-AC_CACHE_VAL(lt_cv_path_SED,
-[# Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for lt_ac_prog in sed gsed; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
- lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
- fi
- done
- done
-done
-lt_ac_max=0
-lt_ac_count=0
-# Add /usr/xpg4/bin/sed as it is typically found on Solaris
-# along with /bin/sed that truncates output.
-for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
- test ! -f $lt_ac_sed && continue
- cat /dev/null > conftest.in
- lt_ac_count=0
- echo $ECHO_N "0123456789$ECHO_C" >conftest.in
- # Check for GNU sed and select it if it is found.
- if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
- lt_cv_path_SED=$lt_ac_sed
- break
- fi
- while true; do
- cat conftest.in conftest.in >conftest.tmp
- mv conftest.tmp conftest.in
- cp conftest.in conftest.nl
- echo >>conftest.nl
- $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
- cmp -s conftest.out conftest.nl || break
- # 10000 chars as input seems more than enough
- test $lt_ac_count -gt 10 && break
- lt_ac_count=`expr $lt_ac_count + 1`
- if test $lt_ac_count -gt $lt_ac_max; then
- lt_ac_max=$lt_ac_count
- fi
- done
-done
-SED=$lt_cv_path_SED
-AC_MSG_RESULT([$SED])
Deleted: mpich2/trunk/confdb/ltmain-2.13.sh
--- mpich2/trunk/confdb/ltmain-2.13.sh 2009-03-20 16:22:43 UTC (rev 4145)
+++ mpich2/trunk/confdb/ltmain-2.13.sh 2009-03-20 17:00:18 UTC (rev 4146)
@@ -1,4988 +0,0 @@
-# ltmain.sh - Provide generalized library-building support services.
-# NOTE: Changing this file will not affect anything until you rerun configure.
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# Check that we have a working $echo.
-if test "X$1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X$1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell, and then maybe $echo will work.
- exec $SHELL "$0" --no-reexec ${1+"$@"}
-fi
-if test "X$1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The name of this program.
-progname=`$echo "$0" | sed 's%^.*/%%'`
-modename="$progname"
-# Constants.
-PROGRAM=ltmain.sh
-PACKAGE=libtool
-VERSION=1.4.2
-TIMESTAMP=" (1.922.2.54 2001/09/11 03:33:37)"
-default_mode=
-help="Try \`$progname --help' for more information."
-magic="%%%MAGIC variable%%%"
-mkdir="mkdir"
-mv="mv -f"
-rm="rm -f"
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e 1s/^X//'
-sed_quote_subst='s/\([\\`\\"$\\\\]\)/\\\1/g'
-SP2NL='tr \040 \012'
-NL2SP='tr \015\012 \040\040'
-# NLS nuisances.
-# Only set LANG and LC_ALL to C if already set.
-# These must not be set unconditionally because not all systems understand
-# e.g. LANG=C (notably SCO).
-# We save the old values to restore during execute mode.
-if test "${LC_ALL+set}" = set; then
- save_LC_ALL="$LC_ALL"; LC_ALL=C; export LC_ALL
-fi
-if test "${LANG+set}" = set; then
- save_LANG="$LANG"; LANG=C; export LANG
-fi
-# Make sure IFS has a sensible default
-: ${IFS=" "}
-if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
- echo "$modename: not configured to build any kind of library" 1>&2
- echo "Fatal configuration error. See the $PACKAGE docs for more information." 1>&2
- exit 1
-fi
-# Global variables.
-mode=$default_mode
-nonopt=
-prev=
-prevopt=
-run=
-show="$echo"
-show_help=
-execute_dlfiles=
-lo2o="s/\\.lo\$/.${objext}/"
-o2lo="s/\\.${objext}\$/.lo/"
-# Parse our command line options once, thoroughly.
-while test $# -gt 0
-do
- arg="$1"
- shift
- case $arg in
- -*=*) optarg=`$echo "X$arg" | $Xsed -e 's/[-_a-zA-Z0-9]*=//'` ;;
- *) optarg= ;;
- esac
- # If the previous option needs an argument, assign it.
- if test -n "$prev"; then
- case $prev in
- execute_dlfiles)
- execute_dlfiles="$execute_dlfiles $arg"
- eval "$prev=\$arg"
- esac
- prev=
- prevopt=
- continue
- fi
- # Have we seen a non-optional argument yet?
- case $arg in
- --help)
- show_help=yes
- --version)
- echo "$PROGRAM (GNU $PACKAGE) $VERSION$TIMESTAMP"
- exit 0
- --config)
- sed -e '1,/^# ### BEGIN LIBTOOL CONFIG/d' -e '/^# ### END LIBTOOL CONFIG/,$d' $0
- exit 0
- --debug)
- echo "$progname: enabling shell trace mode"
- set -x
- --dry-run | -n)
- run=:
- --features)
- echo "host: $host"
- if test "$build_libtool_libs" = yes; then
- echo "enable shared libraries"
- else
- echo "disable shared libraries"
- fi
- if test "$build_old_libs" = yes; then
- echo "enable static libraries"
- else
- echo "disable static libraries"
- fi
- exit 0
- --finish) mode="finish" ;;
- --mode) prevopt="--mode" prev=mode ;;
- --mode=*) mode="$optarg" ;;
- --quiet | --silent)
- show=:
- -dlopen)
- prevopt="-dlopen"
- prev=execute_dlfiles
- $echo "$modename: unrecognized option \`$arg'" 1>&2
- $echo "$help" 1>&2
- exit 1
- nonopt="$arg"
- break
- esac
-done
-if test -n "$prevopt"; then
- $echo "$modename: option \`$prevopt' requires an argument" 1>&2
- exit 1
-fi
-# If this variable is set in any of the actions, the command in it
-# will be execed at the end. This prevents here-documents from being
-# left over by shells.
-exec_cmd=
-if test -z "$show_help"; then
- # Infer the operation mode.
- if test -z "$mode"; then
- case $nonopt in
- *cc | *++ | gcc* | *-gcc*)
- mode=link
- for arg
- do
- case $arg in
- -c)
- mode=compile
- break
- esac
- done
- *db | *dbx | *strace | *truss)
- mode=execute
- *install*|cp|mv)
- mode=install
- *rm)
- mode=uninstall
- # If we have no mode, but dlfiles were specified, then do execute mode.
- test -n "$execute_dlfiles" && mode=execute
- # Just use the default operation mode.
- if test -n "$nonopt"; then
- $echo "$modename: warning: cannot infer operation mode from \`$nonopt'" 1>&2
- else
- $echo "$modename: warning: cannot infer operation mode without MODE-ARGS" 1>&2
- fi
- fi
- esac
- fi
- # Only execute mode is allowed to have -dlopen flags.
- if test -n "$execute_dlfiles" && test "$mode" != execute; then
- $echo "$modename: unrecognized option \`-dlopen'" 1>&2
- exit 1
- fi
- # Change the help message to a mode-specific one.
- generic_help="$help"
- help="Try \`$modename --help --mode=$mode' for more information."
- # These modes are in order of execution frequency so that they run quickly.
- case $mode in
- # libtool compile mode
- compile)
- modename="$modename: compile"
- # Get the compilation command and the source file.
- base_compile=
- prev=
- lastarg=
- srcfile="$nonopt"
- suppress_output=
- user_target=no
- for arg
- do
- case $prev in
- xcompiler)
- # Aesthetically quote the previous argument.
- prev=
- lastarg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- # Double-quote args containing other shell metacharacters.
- # Many Bourne shells cannot handle close brackets correctly
- # in scan sets, so we specify it separately.
- arg="\"$arg\""
- esac
- # Add the previous argument to base_compile.
- if test -z "$base_compile"; then
- base_compile="$lastarg"
- else
- base_compile="$base_compile $lastarg"
- fi
- continue
- esac
- # Accept any command-line options.
- case $arg in
- -o)
- if test "$user_target" != "no"; then
- $echo "$modename: you cannot specify \`-o' more than once" 1>&2
- exit 1
- fi
- user_target=next
- -static)
- build_old_libs=yes
- continue
- -prefer-pic)
- pic_mode=yes
- continue
- -prefer-non-pic)
- pic_mode=no
- continue
- -Xcompiler)
- prev=xcompiler
- continue
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "s/^-Wc,//"`
- lastarg=
- save_ifs="$IFS"; IFS=','
- for arg in $args; do
- IFS="$save_ifs"
- case $arg in
- arg="\"$arg\""
- esac
- lastarg="$lastarg $arg"
- done
- IFS="$save_ifs"
- lastarg=`$echo "X$lastarg" | $Xsed -e "s/^ //"`
- # Add the arguments to base_compile.
- else
- fi
- continue
- esac
- case $user_target in
- next)
- # The next one is the -o target name
- user_target=yes
- continue
- yes)
- # We got the output file
- user_target=set
- libobj="$arg"
- continue
- esac
- # Accept the current argument as the source file.
- lastarg="$srcfile"
- srcfile="$arg"
- # Backslashify any backslashes, double quotes, and dollar signs.
- # These are the only characters that are still specially
- # interpreted inside of double-quoted scrings.
- lastarg=`$echo "X$lastarg" | $Xsed -e "$sed_quote_subst"`
- case $lastarg in
- lastarg="\"$lastarg\""
- esac
- else
- fi
- done
- set)
- no)
- # Get the name of the library object.
- libobj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%'`
- $echo "$modename: you must specify a target with \`-o'" 1>&2
- exit 1
- esac
- # Recognize several different file suffixes.
- # If the user specifies -o file.o, it is replaced with file.lo
- xform='[cCFSfmso]'
- case $libobj in
- *.ada) xform=ada ;;
- *.adb) xform=adb ;;
- *.ads) xform=ads ;;
- *.asm) xform=asm ;;
- *.c++) xform=c++ ;;
- *.cc) xform=cc ;;
- *.cpp) xform=cpp ;;
- *.cxx) xform=cxx ;;
- *.f90) xform=f90 ;;
- *.for) xform=for ;;
- esac
- libobj=`$echo "X$libobj" | $Xsed -e "s/\.$xform$/.lo/"`
- case $libobj in
- *.lo) obj=`$echo "X$libobj" | $Xsed -e "$lo2o"` ;;
- $echo "$modename: cannot determine name of library object from \`$libobj'" 1>&2
- exit 1
- esac
- $echo "$modename: you must specify a compilation command" 1>&2
- exit 1
- fi
- # Delete any leftover library objects.
- removelist="$obj $libobj"
- else
- removelist="$libobj"
- fi
- $run $rm $removelist
- trap "$run $rm $removelist; exit 1" 1 2 15
- # On Cygwin there's no "real" PIC flag so we must build both object types
- case $host_os in
- cygwin* | mingw* | pw32* | os2*)
- pic_mode=default
- esac
- if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
- # non-PIC code in shared libraries is not supported
- pic_mode=default
- fi
- # Calculate the filename of the output object if compiler does
- # not support -o with -c
- if test "$compiler_c_o" = no; then
- output_obj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%' -e 's%\.[^.]*$%%'`.${objext}
- lockfile="$output_obj.lock"
- removelist="$removelist $output_obj $lockfile"
- else
- need_locks=no
- lockfile=
- fi
- # Lock this critical section if it is needed
- # We use this script file to make the link, it avoids creating a new file
- if test "$need_locks" = yes; then
- until $run ln "$0" "$lockfile" 2>/dev/null; do
- $show "Waiting for $lockfile to be removed"
- sleep 2
- done
- elif test "$need_locks" = warn; then
- if test -f "$lockfile"; then
- echo "\
-*** ERROR, $lockfile exists and contains:
-`cat $lockfile 2>/dev/null`
-This indicates that another process is trying to use the same
-temporary object file, and libtool could not work around it because
-your compiler does not support \`-c' and \`-o' together. If you
-repeat this compilation, it may succeed, by chance, but you had better
-avoid parallel builds (make -j) in this platform, or get a better
-compiler."
- exit 1
- fi
- echo $srcfile > "$lockfile"
- fi
- if test -n "$fix_srcfile_path"; then
- eval srcfile=\"$fix_srcfile_path\"
- fi
- # Only build a PIC object if we are building libtool libraries.
- # Without this assignment, base_compile gets emptied.
- fbsd_hideous_sh_bug=$base_compile
- if test "$pic_mode" != no; then
- # All platforms use -DPIC, to notify preprocessed assembler code.
- command="$base_compile $srcfile $pic_flag -DPIC"
- else
- # Don't build PIC code
- command="$base_compile $srcfile"
- fi
- lo_libobj="$libobj"
- dir=`$echo "X$libobj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$dir" = "X$libobj"; then
- dir="$objdir"
- else
- dir="$dir/$objdir"
- fi
- libobj="$dir/"`$echo "X$libobj" | $Xsed -e 's%^.*/%%'`
- if test -d "$dir"; then
- $show "$rm $libobj"
- $run $rm $libobj
- else
- $show "$mkdir $dir"
- $run $mkdir $dir
- status=$?
- if test $status -ne 0 && test ! -d $dir; then
- exit $status
- fi
- fi
- fi
- if test "$compiler_o_lo" = yes; then
- output_obj="$libobj"
- command="$command -o $output_obj"
- elif test "$compiler_c_o" = yes; then
- output_obj="$obj"
- fi
- $run $rm "$output_obj"
- $show "$command"
- if $run eval "$command"; then :
- else
- test -n "$output_obj" && $run $rm $removelist
- exit 1
- fi
- if test "$need_locks" = warn &&
- test x"`cat $lockfile 2>/dev/null`" != x"$srcfile"; then
- echo "\
-*** ERROR, $lockfile contains:
-but it should contain:
-$srcfile
-compiler."
- exit 1
- fi
- # Just move the object if needed, then go on to compile the next one
- if test x"$output_obj" != x"$libobj"; then
- $show "$mv $output_obj $libobj"
- if $run $mv $output_obj $libobj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # If we have no pic_flag, then copy the object into place and finish.
- if (test -z "$pic_flag" || test "$pic_mode" != default) &&
- test "$build_old_libs" = yes; then
- # Rename the .lo from within objdir to obj
- if test -f $obj; then
- $show $rm $obj
- $run $rm $obj
- fi
- $show "$mv $libobj $obj"
- if $run $mv $libobj $obj; then :
- else
- error=$?
- exit $error
- fi
- xdir=`$echo "X$obj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$obj"; then
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$obj" | $Xsed -e "s%.*/%%"`
- libobj=`$echo "X$baseobj" | $Xsed -e "$o2lo"`
- # Now arrange that obj and lo_libobj become the same file
- $show "(cd $xdir && $LN_S $baseobj $libobj)"
- if $run eval '(cd $xdir && $LN_S $baseobj $libobj)'; then
- # Unlock the critical section if it was locked
- if test "$need_locks" != no; then
- $run $rm "$lockfile"
- fi
- exit 0
- else
- error=$?
- exit $error
- fi
- fi
- # Allow error messages only from the first compilation.
- suppress_output=' >/dev/null 2>&1'
- fi
- # Only build a position-dependent object if we build old libraries.
- if test "$pic_mode" != yes; then
- else
- fi
- if test "$compiler_c_o" = yes; then
- command="$command -o $obj"
- output_obj="$obj"
- fi
- # Suppress compiler output if we already did a PIC compilation.
- command="$command$suppress_output"
- $show "$command"
- else
- exit 1
- fi
- echo "\
-$srcfile
-compiler."
- exit 1
- fi
- if test x"$output_obj" != x"$obj"; then
- $show "$mv $output_obj $obj"
- if $run $mv $output_obj $obj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # Create an invalid libtool object if no PIC, so that we do not
- # accidentally link it into a program.
- if test "$build_libtool_libs" != yes; then
- $show "echo timestamp > $libobj"
- $run eval "echo timestamp > \$libobj" || exit $?
- else
- # Move the .lo from within objdir
- $show "$mv $libobj $lo_libobj"
- if $run $mv $libobj $lo_libobj; then :
- else
- error=$?
- exit $error
- fi
- fi
- fi
- fi
- exit 0
- # libtool link mode
- link | relink)
- modename="$modename: link"
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
- # It is impossible to link a dll without this setting, and
- # we shouldn't force the makefile maintainer to figure out
- # which system we are compiling for in order to pass an extra
- # flag for every libtool invokation.
- # allow_undefined=no
- # FIXME: Unfortunately, there are problems with the above when trying
- # to make a dll which has undefined symbols, in which case not
- # even a static library is built. For now, we need to specify
- # -no-undefined on the libtool link line when we can be certain
- # that all symbols are satisfied, otherwise we get a static library.
- allow_undefined=yes
- esac
- libtool_args="$nonopt"
- compile_command="$nonopt"
- finalize_command="$nonopt"
- compile_rpath=
- finalize_rpath=
- compile_shlibpath=
- finalize_shlibpath=
- convenience=
- old_convenience=
- deplibs=
- old_deplibs=
- compiler_flags=
- linker_flags=
- dllsearchpath=
- lib_search_path=`pwd`
- avoid_version=no
- dlfiles=
- dlprefiles=
- dlself=no
- export_dynamic=no
- export_symbols=
- export_symbols_regex=
- generated=
- libobjs=
- ltlibs=
- module=no
- no_install=no
- objs=
- prefer_static_libs=no
- preload=no
- prev=
- prevarg=
- release=
- rpath=
- xrpath=
- perm_rpath=
- temp_rpath=
- thread_safe=no
- vinfo=
- # We need to know -static, to get the right output filenames.
- for arg
- do
- case $arg in
- -all-static | -static)
- if test "X$arg" = "X-all-static"; then
- if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
- $echo "$modename: warning: complete static linking is impossible in this configuration" 1>&2
- fi
- if test -n "$link_static_flag"; then
- dlopen_self=$dlopen_self_static
- fi
- else
- if test -z "$pic_flag" && test -n "$link_static_flag"; then
- fi
- fi
- build_libtool_libs=no
- prefer_static_libs=yes
- break
- esac
- done
- # See if our shared archives depend on static archives.
- test -n "$old_archive_from_new_cmds" && build_old_libs=yes
- # Go through the arguments, transforming them on the way.
- while test $# -gt 0; do
- arg="$1"
- shift
- case $arg in
- qarg=\"`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`\" ### testsuite: skip nested quoting test
- *) qarg=$arg ;;
- esac
- libtool_args="$libtool_args $qarg"
- case $prev in
- output)
- compile_command="$compile_command @OUTPUT@"
- finalize_command="$finalize_command @OUTPUT@"
- esac
- case $prev in
- dlfiles|dlprefiles)
- if test "$preload" = no; then
- # Add the symbol object into the linking commands.
- compile_command="$compile_command @SYMFILE@"
- finalize_command="$finalize_command @SYMFILE@"
- preload=yes
- fi
- case $arg in
- *.la | *.lo) ;; # We handle these cases below.
- force)
- if test "$dlself" = no; then
- dlself=needless
- export_dynamic=yes
- fi
- prev=
- continue
- self)
- if test "$prev" = dlprefiles; then
- dlself=yes
- elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
- dlself=yes
- else
- dlself=needless
- fi
- prev=
- continue
- if test "$prev" = dlfiles; then
- dlfiles="$dlfiles $arg"
- else
- dlprefiles="$dlprefiles $arg"
- fi
- prev=
- continue
- esac
- expsyms)
- export_symbols="$arg"
- if test ! -f "$arg"; then
- $echo "$modename: symbol file \`$arg' does not exist"
- exit 1
- fi
- prev=
- continue
- expsyms_regex)
- export_symbols_regex="$arg"
- prev=
- continue
- release)
- release="-$arg"
- prev=
- continue
- rpath | xrpath)
- # We need an absolute path.
- case $arg in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- $echo "$modename: only absolute run-paths are allowed" 1>&2
- exit 1
- esac
- if test "$prev" = rpath; then
- case "$rpath " in
- *" $arg "*) ;;
- *) rpath="$rpath $arg" ;;
- esac
- else
- case "$xrpath " in
- *" $arg "*) ;;
- *) xrpath="$xrpath $arg" ;;
- esac
- fi
- prev=
- continue
- xcompiler)
- compiler_flags="$compiler_flags $qarg"
- prev=
- compile_command="$compile_command $qarg"
- finalize_command="$finalize_command $qarg"
- continue
- xlinker)
- linker_flags="$linker_flags $qarg"
- compiler_flags="$compiler_flags $wl$qarg"
- prev=
- compile_command="$compile_command $wl$qarg"
- finalize_command="$finalize_command $wl$qarg"
- continue
- eval "$prev=\"\$arg\""
- prev=
- continue
- esac
- fi # test -n $prev
- prevarg="$arg"
- case $arg in
- -all-static)
- compile_command="$compile_command $link_static_flag"
- finalize_command="$finalize_command $link_static_flag"
- fi
- continue
- -allow-undefined)
- # FIXME: remove this flag sometime in the future.
- $echo "$modename: \`-allow-undefined' is deprecated because it is the default" 1>&2
- continue
- -avoid-version)
- avoid_version=yes
- continue
- -dlopen)
- prev=dlfiles
- continue
- -dlpreopen)
- prev=dlprefiles
- continue
- -export-dynamic)
- continue
- -export-symbols | -export-symbols-regex)
- if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
- $echo "$modename: more than one -exported-symbols argument is not allowed"
- exit 1
- fi
- if test "X$arg" = "X-export-symbols"; then
- prev=expsyms
- else
- prev=expsyms_regex
- fi
- continue
- # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
- # so, if we see these flags be careful not to treat them like -L
- -L[A-Z][A-Z]*:*)
- case $with_gcc/$host in
- no/*-*-irix*)
- compile_command="$compile_command $arg"
- finalize_command="$finalize_command $arg"
- esac
- continue
- -L*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-L//'`
- case $dir in
- absdir=`cd "$dir" && pwd`
- if test -z "$absdir"; then
- $echo "$modename: cannot determine absolute directory name of \`$dir'" 1>&2
- exit 1
- fi
- dir="$absdir"
- esac
- case "$deplibs " in
- *" -L$dir "*) ;;
- deplibs="$deplibs -L$dir"
- lib_search_path="$lib_search_path $dir"
- esac
- case $host in
- case :$dllsearchpath: in
- *":$dir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$dir";;
- esac
- esac
- continue
- -l*)
- if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
- case $host in
- *-*-cygwin* | *-*-pw32* | *-*-beos*)
- # These systems don't actually have a C or math library (as such)
- continue
- *-*-mingw* | *-*-os2*)
- # These systems don't actually have a C library (as such)
- test "X$arg" = "X-lc" && continue
- *-*-openbsd*)
- # Do not include libc due to us having libc/libc_r.
- esac
- elif test "X$arg" = "X-lc_r"; then
- case $host in
- *-*-openbsd*)
- # Do not include libc_r directly, use -pthread flag.
- continue
- esac
- fi
- deplibs="$deplibs $arg"
- continue
- -module)
- module=yes
- continue
- -no-fast-install)
- fast_install=no
- continue
- -no-install)
- case $host in
- # The PATH hackery in wrapper scripts is required on Windows
- # in order for the loader to find any dlls it needs.
- $echo "$modename: warning: \`-no-install' is ignored for $host" 1>&2
- $echo "$modename: warning: assuming \`-no-fast-install' instead" 1>&2
- fast_install=no
- *) no_install=yes ;;
- esac
- continue
- -no-undefined)
- allow_undefined=no
- continue
- -o) prev=output ;;
- -release)
- prev=release
- continue
- -rpath)
- prev=rpath
- continue
- -R)
- prev=xrpath
- continue
- -R*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-R//'`
- case $dir in
- exit 1
- esac
- *" $dir "*) ;;
- *) xrpath="$xrpath $dir" ;;
- esac
- continue
- -static)
- # The effects of -static are defined in a previous loop.
- # We used to do the same as -all-static on platforms that
- # didn't have a PIC flag, but the assumption that the effects
- # would be equivalent was wrong. It would break on at least
- # Digital Unix and AIX.
- continue
- -thread-safe)
- thread_safe=yes
- continue
- -version-info)
- prev=vinfo
- continue
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wc,//'`
- arg=
- for flag in $args; do
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- arg="$arg $wl$flag"
- compiler_flags="$compiler_flags $flag"
- done
- IFS="$save_ifs"
- arg=`$echo "X$arg" | $Xsed -e "s/^ //"`
- -Wl,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wl,//'`
- arg=
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- compiler_flags="$compiler_flags $wl$flag"
- linker_flags="$linker_flags $flag"
- done
- IFS="$save_ifs"
- -Xcompiler)
- prev=xcompiler
- continue
- -Xlinker)
- prev=xlinker
- continue
- # Some other compiler flag.
- # Unknown arguments in both finalize_command and compile_command need
- # to be aesthetically quoted because they are evaled later.
- arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- *.lo | *.$objext)
- # A library or standard object.
- # This file was specified with -dlopen.
- if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
- prev=
- continue
- else
- # If libtool objects are unsupported, then we need to preload.
- prev=dlprefiles
- fi
- fi
- # Preload the old-style object.
- dlprefiles="$dlprefiles "`$echo "X$arg" | $Xsed -e "$lo2o"`
- prev=
- else
- case $arg in
- *.lo) libobjs="$libobjs $arg" ;;
- *) objs="$objs $arg" ;;
- esac
- fi
- *.$libext)
- # An archive.
- old_deplibs="$old_deplibs $arg"
- continue
- *.la)
- # A libtool-controlled library.
- # This library was specified with -dlopen.
- prev=
- elif test "$prev" = dlprefiles; then
- # The library was specified with -dlpreopen.
- prev=
- else
- fi
- continue
- # Some other compiler argument.
- case $arg in
- arg="\"$arg\""
- esac
- esac # arg
- # Now actually substitute the argument into the commands.
- if test -n "$arg"; then
- fi
- done # argument parsing loop
- $echo "$modename: the \`$prevarg' option requires an argument" 1>&2
- exit 1
- fi
- if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
- eval arg=\"$export_dynamic_flag_spec\"
- fi
- # calculate the name of the file, without its directory
- outputname=`$echo "X$output" | $Xsed -e 's%^.*/%%'`
- libobjs_save="$libobjs"
- if test -n "$shlibpath_var"; then
- # get the directories listed in $shlibpath_var
- eval shlib_search_path=\`\$echo \"X\${$shlibpath_var}\" \| \$Xsed -e \'s/:/ /g\'\`
- else
- shlib_search_path=
- fi
- eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
- eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
- output_objdir=`$echo "X$output" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$output_objdir" = "X$output"; then
- output_objdir="$objdir"
- else
- output_objdir="$output_objdir/$objdir"
- fi
- # Create the object directory.
- if test ! -d "$output_objdir"; then
- $show "$mkdir $output_objdir"
- $run $mkdir $output_objdir
- status=$?
- if test "$status" -ne 0 && test ! -d "$output_objdir"; then
- exit $status
- fi
- fi
- # Determine the type of output
- case $output in
- $echo "$modename: you must specify an output file" 1>&2
- exit 1
- *.$libext) linkmode=oldlib ;;
- *.lo | *.$objext) linkmode=obj ;;
- *.la) linkmode=lib ;;
- *) linkmode=prog ;; # Anything else should be a program.
- esac
- specialdeplibs=
- libs=
- # Find all interdependent deplibs by searching for libraries
- # that are linked more than once (e.g. -la -lb -la)
- for deplib in $deplibs; do
- case "$libs " in
- *" $deplib "*) specialdeplibs="$specialdeplibs $deplib" ;;
- esac
- libs="$libs $deplib"
- done
- deplibs=
- newdependency_libs=
- newlib_search_path=
- need_relink=no # whether we're linking any uninstalled libtool libraries
- notinst_deplibs= # not-installed libtool libraries
- notinst_path= # paths that contain not-installed libtool libraries
- case $linkmode in
- lib)
- passes="conv link"
- for file in $dlfiles $dlprefiles; do
- case $file in
- *.la) ;;
- $echo "$modename: libraries can \`-dlopen' only libtool libraries: $file" 1>&2
- exit 1
- esac
- done
- prog)
- compile_deplibs=
- finalize_deplibs=
- alldeplibs=no
- newdlfiles=
- newdlprefiles=
- passes="conv scan dlopen dlpreopen link"
- *) passes="conv"
- esac
- for pass in $passes; do
- if test "$linkmode" = prog; then
- # Determine which files to process
- case $pass in
- dlopen)
- libs="$dlfiles"
- save_deplibs="$deplibs" # Collect dlpreopened libraries
- deplibs=
- dlpreopen) libs="$dlprefiles" ;;
- link) libs="$deplibs %DEPLIBS% $dependency_libs" ;;
- esac
- fi
- for deplib in $libs; do
- lib=
- found=no
- case $deplib in
- -l*)
- if test "$linkmode" = oldlib && test "$linkmode" = obj; then
- $echo "$modename: warning: \`-l' is ignored for archives/objects: $deplib" 1>&2
- continue
- fi
- if test "$pass" = conv; then
- deplibs="$deplib $deplibs"
- continue
- fi
- name=`$echo "X$deplib" | $Xsed -e 's/^-l//'`
- for searchdir in $newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path; do
- # Search the libtool library
- lib="$searchdir/lib${name}.la"
- if test -f "$lib"; then
- found=yes
- break
- fi
- done
- if test "$found" != yes; then
- # deplib doesn't seem to be a libtool library
- if test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$deplib $compile_deplibs"
- finalize_deplibs="$deplib $finalize_deplibs"
- else
- test "$linkmode" = lib && newdependency_libs="$deplib $newdependency_libs"
- fi
- continue
- fi
- ;; # -l
- -L*)
- case $linkmode in
- lib)
- test "$pass" = conv && continue
- newdependency_libs="$deplib $newdependency_libs"
- newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`
- prog)
- continue
- fi
- if test "$pass" = scan; then
- else
- fi
- $echo "$modename: warning: \`-L' is ignored for archives/objects: $deplib" 1>&2
- esac # linkmode
- continue
- ;; # -L
- -R*)
- if test "$pass" = link; then
- dir=`$echo "X$deplib" | $Xsed -e 's/^-R//'`
- # Make sure the xrpath contains only unique directories.
- *" $dir "*) ;;
- esac
- fi
- continue
- *.la) lib="$deplib" ;;
- *.$libext)
- continue
- fi
- case $linkmode in
- lib)
- if test "$deplibs_check_method" != pass_all; then
- echo
- echo "*** Warning: This library needs some functionality provided by $deplib."
- echo "*** I have the capability to make that library automatically link in when"
- echo "*** you link to this library. But I can only do this if you have a"
- echo "*** shared version of the library, which you do not appear to have."
- else
- echo
- echo "*** Warning: Linking the shared library $output against the"
- echo "*** static library $deplib is not portable!"
- fi
- continue
- prog)
- if test "$pass" != link; then
- else
- fi
- continue
- esac # linkmode
- ;; # *.$libext
- *.lo | *.$objext)
- if test "$pass" = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlopen support or we're linking statically,
- # we need to preload.
- newdlprefiles="$newdlprefiles $deplib"
- else
- newdlfiles="$newdlfiles $deplib"
- fi
- continue
- %DEPLIBS%)
- alldeplibs=yes
- continue
- esac # case $deplib
- if test "$found" = yes || test -f "$lib"; then :
- else
- $echo "$modename: cannot find the library \`$lib'" 1>&2
- exit 1
- fi
- # Check to see that this really is a libtool archive.
- if (sed -e '2q' $lib | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- ladir=`$echo "X$lib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$ladir" = "X$lib" && ladir="."
- dlname=
- dlopen=
- dlpreopen=
- libdir=
- library_names=
- old_library=
- # If the library was installed with an old release of libtool,
- # it will not redefine variable installed.
- installed=yes
- # Read the .la file
- case $lib in
- */* | *\\*) . $lib ;;
- *) . ./$lib ;;
- esac
- if test "$linkmode,$pass" = "lib,link" ||
- test "$linkmode,$pass" = "prog,scan" ||
- { test "$linkmode" = oldlib && test "$linkmode" = obj; }; then
- # Add dl[pre]opened files of deplib
- test -n "$dlopen" && dlfiles="$dlfiles $dlopen"
- test -n "$dlpreopen" && dlprefiles="$dlprefiles $dlpreopen"
- fi
- # Only check for convenience libraries
- deplibs="$lib $deplibs"
- if test -z "$libdir"; then
- if test -z "$old_library"; then
- $echo "$modename: cannot find name of link library for \`$lib'" 1>&2
- exit 1
- fi
- # It is a libtool convenience library, so add in its objects.
- convenience="$convenience $ladir/$objdir/$old_library"
- old_convenience="$old_convenience $ladir/$objdir/$old_library"
- tmp_libs=
- for deplib in $dependency_libs; do
- case "$tmp_libs " in
- esac
- tmp_libs="$tmp_libs $deplib"
- done
- elif test "$linkmode" != prog && test "$linkmode" != lib; then
- $echo "$modename: \`$lib' is not a convenience library" 1>&2
- exit 1
- fi
- continue
- fi # $pass = conv
- # Get the name of the library we link against.
- linklib=
- for l in $old_library $library_names; do
- linklib="$l"
- done
- if test -z "$linklib"; then
- exit 1
- fi
- if test "$pass" = dlopen; then
- $echo "$modename: cannot -dlopen a convenience library: \`$lib'" 1>&2
- exit 1
- fi
- if test -z "$dlname" || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlname, no dlopen support or we're linking
- # statically, we need to preload.
- dlprefiles="$dlprefiles $lib"
- else
- newdlfiles="$newdlfiles $lib"
- fi
- continue
- fi # $pass = dlopen
- case $ladir in
- [\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
- abs_ladir=`cd "$ladir" && pwd`
- if test -z "$abs_ladir"; then
- $echo "$modename: warning: cannot determine absolute directory name of \`$ladir'" 1>&2
- $echo "$modename: passing it literally to the linker, although it might fail" 1>&2
- abs_ladir="$ladir"
- fi
- esac
- laname=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- # Find the relevant object directory and library name.
- if test "X$installed" = Xyes; then
- if test ! -f "$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- $echo "$modename: warning: library \`$lib' was moved." 1>&2
- dir="$ladir"
- absdir="$abs_ladir"
- libdir="$abs_ladir"
- else
- dir="$libdir"
- absdir="$libdir"
- fi
- else
- dir="$ladir/$objdir"
- absdir="$abs_ladir/$objdir"
- # Remove this search path later
- notinst_path="$notinst_path $abs_ladir"
- fi # $installed = yes
- name=`$echo "X$laname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- # This library was specified with -dlpreopen.
- if test "$pass" = dlpreopen; then
- $echo "$modename: cannot -dlpreopen a convenience library: \`$lib'" 1>&2
- exit 1
- fi
- # Prefer using a static library (so that no silly _DYNAMIC symbols
- # are required to link).
- if test -n "$old_library"; then
- newdlprefiles="$newdlprefiles $dir/$old_library"
- # Otherwise, use the dlname, so that lt_dlopen finds it.
- elif test -n "$dlname"; then
- newdlprefiles="$newdlprefiles $dir/$dlname"
- else
- newdlprefiles="$newdlprefiles $dir/$linklib"
- fi
- fi # $pass = dlpreopen
- # Link the convenience library
- if test "$linkmode" = lib; then
- deplibs="$dir/$old_library $deplibs"
- elif test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$dir/$old_library $compile_deplibs"
- finalize_deplibs="$dir/$old_library $finalize_deplibs"
- else
- fi
- continue
- fi
- if test "$linkmode" = prog && test "$pass" != link; then
- newlib_search_path="$newlib_search_path $ladir"
- linkalldeplibs=no
- if test "$link_all_deplibs" != no || test -z "$library_names" ||
- test "$build_libtool_libs" = no; then
- linkalldeplibs=yes
- fi
- tmp_libs=
- case $deplib in
- -L*) newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`;; ### testsuite: skip nested quoting test
- esac
- # Need to link against all dependency_libs?
- if test "$linkalldeplibs" = yes; then
- else
- # Need to hardcode shared library paths
- # or/and link against static libraries
- fi
- esac
- done # for deplib
- continue
- fi # $linkmode = prog...
- link_static=no # Whether the deplib will be linked statically
- if test -n "$library_names" &&
- { test "$prefer_static_libs" = no || test -z "$old_library"; }; then
- # Link against this shared library
- if test "$linkmode,$pass" = "prog,link" ||
- { test "$linkmode" = lib && test "$hardcode_into_libs" = yes; }; then
- # Hardcode the library path.
- # Skip directories that are in the system default run-time
- # search path.
- case " $sys_lib_dlsearch_path " in
- *" $absdir "*) ;;
- case "$compile_rpath " in
- *" $absdir "*) ;;
- *) compile_rpath="$compile_rpath $absdir"
- esac
- esac
- *" $libdir "*) ;;
- case "$finalize_rpath " in
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir"
- esac
- esac
- # We need to hardcode the library path
- # Make sure the rpath contains only unique directories.
- case "$temp_rpath " in
- *" $dir "*) ;;
- *" $absdir "*) ;;
- *) temp_rpath="$temp_rpath $dir" ;;
- esac
- fi
- fi
- fi # $linkmode,$pass = prog,link...
- if test "$alldeplibs" = yes &&
- { test "$deplibs_check_method" = pass_all ||
- { test "$build_libtool_libs" = yes &&
- test -n "$library_names"; }; }; then
- # We only need to search for static libraries
- continue
- fi
- if test "$installed" = no; then
- notinst_deplibs="$notinst_deplibs $lib"
- need_relink=yes
- fi
- if test -n "$old_archive_from_expsyms_cmds"; then
- # figure out the soname
- set dummy $library_names
- realname="$2"
- shift; shift
- libname=`eval \\$echo \"$libname_spec\"`
- # use dlname if we got it. it's perfectly good, no?
- if test -n "$dlname"; then
- soname="$dlname"
- elif test -n "$soname_spec"; then
- # bleh windows
- case $host in
- *cygwin*)
- major=`expr $current - $age`
- versuffix="-$major"
- esac
- eval soname=\"$soname_spec\"
- else
- soname="$realname"
- fi
- # Make a new name for the extract_expsyms_cmds to use
- soroot="$soname"
- soname=`echo $soroot | sed -e 's/^.*\///'`
- newlib="libimp-`echo $soname | sed 's/^lib//;s/\.dll$//'`.a"
- # If the library has no export list, then create one now
- if test -f "$output_objdir/$soname-def"; then :
- else
- $show "extracting exported symbol list from \`$soname'"
- save_ifs="$IFS"; IFS='~'
- eval cmds=\"$extract_expsyms_cmds\"
- for cmd in $cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || exit $?
- done
- IFS="$save_ifs"
- fi
- # Create $newlib
- if test -f "$output_objdir/$newlib"; then :; else
- $show "generating import library for \`$soname'"
- eval cmds=\"$old_archive_from_expsyms_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # make sure the library variables are pointing to the new library
- dir=$output_objdir
- linklib=$newlib
- fi # test -n "$old_archive_from_expsyms_cmds"
- if test "$linkmode" = prog || test "$mode" != relink; then
- add_shlibpath=
- add_dir=
- add=
- lib_linked=yes
- case $hardcode_action in
- immediate | unsupported)
- if test "$hardcode_direct" = no; then
- add="$dir/$linklib"
- elif test "$hardcode_minus_L" = no; then
- case $host in
- *-*-sunos*) add_shlibpath="$dir" ;;
- esac
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = no; then
- add_shlibpath="$dir"
- add="-l$name"
- else
- lib_linked=no
- fi
- relink)
- if test "$hardcode_direct" = yes; then
- elif test "$hardcode_minus_L" = yes; then
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = yes; then
- add="-l$name"
- else
- lib_linked=no
- fi
- *) lib_linked=no ;;
- esac
- if test "$lib_linked" != yes; then
- $echo "$modename: configuration error: unsupported hardcode properties"
- exit 1
- fi
- if test -n "$add_shlibpath"; then
- case :$compile_shlibpath: in
- *":$add_shlibpath:"*) ;;
- *) compile_shlibpath="$compile_shlibpath$add_shlibpath:" ;;
- esac
- fi
- test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
- test -n "$add" && compile_deplibs="$add $compile_deplibs"
- else
- test -n "$add_dir" && deplibs="$add_dir $deplibs"
- test -n "$add" && deplibs="$add $deplibs"
- if test "$hardcode_direct" != yes && \
- test "$hardcode_minus_L" != yes && \
- test "$hardcode_shlibpath_var" = yes; then
- case :$finalize_shlibpath: in
- *":$libdir:"*) ;;
- *) finalize_shlibpath="$finalize_shlibpath$libdir:" ;;
- esac
- fi
- fi
- fi
- if test "$linkmode" = prog || test "$mode" = relink; then
- add_shlibpath=
- add_dir=
- add=
- # Finalize command for both is simple: just hardcode it.
- add="$libdir/$linklib"
- add_dir="-L$libdir"
- add="-l$name"
- *":$libdir:"*) ;;
- esac
- add="-l$name"
- else
- # We cannot seem to hardcode it, guess we'll fake it.
- add="-l$name"
- fi
- test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
- test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
- else
- fi
- fi
- elif test "$linkmode" = prog; then
- continue
- fi
- # Try to link the static library
- # Here we assume that one of hardcode_direct or hardcode_minus_L
- # is not unsupported. This is valid on all known static and
- # shared platforms.
- if test "$hardcode_direct" != unsupported; then
- test -n "$old_library" && linklib="$old_library"
- compile_deplibs="$dir/$linklib $compile_deplibs"
- finalize_deplibs="$dir/$linklib $finalize_deplibs"
- else
- compile_deplibs="-l$name -L$dir $compile_deplibs"
- finalize_deplibs="-l$name -L$dir $finalize_deplibs"
- fi
- elif test "$build_libtool_libs" = yes; then
- # Not a shared library
- # We're trying link a shared library against a static one
- # but the system doesn't support it.
- # Just print a warning and add the library to dependency_libs so
- # that the program can be linked against the static library.
- echo
- echo "*** Warning: This library needs some functionality provided by $lib."
- if test "$module" = yes; then
- echo "*** Therefore, libtool will create a static module, that should work "
- echo "*** as long as the dlopening application is linked with the -dlopen flag."
- if test -z "$global_symbol_pipe"; then
- echo
- echo "*** However, this would only work if libtool was able to extract symbol"
- echo "*** lists from a program, using \`nm' or equivalent, but libtool could"
- echo "*** not find such a program. So, this module is probably useless."
- echo "*** \`nm' from GNU binutils and a full rebuild may help."
- fi
- if test "$build_old_libs" = no; then
- build_libtool_libs=module
- else
- fi
- fi
- else
- convenience="$convenience $dir/$old_library"
- old_convenience="$old_convenience $dir/$old_library"
- link_static=yes
- fi
- fi # link shared/static library?
- if test -n "$dependency_libs" &&
- { test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes ||
- test "$link_static" = yes; }; then
- # Extract -R from dependency_libs
- temp_deplibs=
- for libdir in $dependency_libs; do
- case $libdir in
- -R*) temp_xrpath=`$echo "X$libdir" | $Xsed -e 's/^-R//'`
- case " $xrpath " in
- *" $temp_xrpath "*) ;;
- *) xrpath="$xrpath $temp_xrpath";;
- esac;;
- *) temp_deplibs="$temp_deplibs $libdir";;
- esac
- done
- dependency_libs="$temp_deplibs"
- fi
- newlib_search_path="$newlib_search_path $absdir"
- # Link against this library
- test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
- # ... and its dependency_libs
- tmp_libs=
- esac
- done
- if test "$link_all_deplibs" != no; then
- # Add the search paths of all dependency libraries
- case $deplib in
- -L*) path="$deplib" ;;
- *.la)
- dir=`$echo "X$deplib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$dir" = "X$deplib" && dir="."
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
- $echo "$modename: warning: cannot determine absolute directory name of \`$dir'" 1>&2
- absdir="$dir"
- fi
- esac
- if grep "^installed=no" $deplib > /dev/null; then
- path="-L$absdir/$objdir"
- else
- eval libdir=`sed -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
- $echo "$modename: \`$deplib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- if test "$absdir" != "$libdir"; then
- $echo "$modename: warning: \`$deplib' seems to be moved" 1>&2
- fi
- path="-L$absdir"
- fi
- *) continue ;;
- esac
- case " $deplibs " in
- *" $path "*) ;;
- *) deplibs="$deplibs $path" ;;
- esac
- done
- fi # link_all_deplibs != no
- fi # linkmode = lib
- done # for deplib in $libs
- # Link the dlpreopened libraries before other libraries
- for deplib in $save_deplibs; do
- done
- fi
- if test "$pass" != dlopen; then
- test "$pass" != scan && dependency_libs="$newdependency_libs"
- if test "$pass" != conv; then
- # Make sure lib_search_path contains only unique directories.
- lib_search_path=
- for dir in $newlib_search_path; do
- case "$lib_search_path " in
- *" $dir "*) ;;
- *) lib_search_path="$lib_search_path $dir" ;;
- esac
- done
- fi
- if test "$linkmode,$pass" != "prog,link"; then
- vars="deplibs"
- else
- vars="compile_deplibs finalize_deplibs"
- fi
- for var in $vars dependency_libs; do
- # Add libraries to $var in reverse order
- eval tmp_libs=\"\$$var\"
- new_libs=
- for deplib in $tmp_libs; do
- case $deplib in
- -L*) new_libs="$deplib $new_libs" ;;
- case " $specialdeplibs " in
- *" $deplib "*) new_libs="$deplib $new_libs" ;;
- case " $new_libs " in
- *" $deplib "*) ;;
- *) new_libs="$deplib $new_libs" ;;
- esac
- esac
- esac
- done
- tmp_libs=
- for deplib in $new_libs; do
- case $deplib in
- -L*)
- case " $tmp_libs " in
- *" $deplib "*) ;;
- *) tmp_libs="$tmp_libs $deplib" ;;
- esac
- esac
- done
- eval $var=\"$tmp_libs\"
- done # for var
- fi
- if test "$pass" = "conv" &&
- { test "$linkmode" = "lib" || test "$linkmode" = "prog"; }; then
- libs="$deplibs" # reset libs
- deplibs=
- fi
- done # for pass
- dlfiles="$newdlfiles"
- dlprefiles="$newdlprefiles"
- fi
- case $linkmode in
- oldlib)
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen' is ignored for archives" 1>&2
- fi
- if test -n "$rpath"; then
- $echo "$modename: warning: \`-rpath' is ignored for archives" 1>&2
- fi
- if test -n "$xrpath"; then
- $echo "$modename: warning: \`-R' is ignored for archives" 1>&2
- fi
- if test -n "$vinfo"; then
- $echo "$modename: warning: \`-version-info' is ignored for archives" 1>&2
- fi
- if test -n "$release"; then
- $echo "$modename: warning: \`-release' is ignored for archives" 1>&2
- fi
- $echo "$modename: warning: \`-export-symbols' is ignored for archives" 1>&2
- fi
- # Now set the variables for building old libraries.
- oldlibs="$output"
- objs="$objs$old_deplibs"
- lib)
- # Make sure we only generate libraries of the form `libNAME.la'.
- case $outputname in
- lib*)
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- eval libname=\"$libname_spec\"
- if test "$module" = no; then
- $echo "$modename: libtool library \`$output' must begin with \`lib'" 1>&2
- exit 1
- fi
- if test "$need_lib_prefix" != no; then
- # Add the "lib" prefix for modules if required
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- else
- libname=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- fi
- esac
- if test -n "$objs"; then
- $echo "$modename: cannot build libtool library \`$output' from non-libtool objects on this host:$objs" 2>&1
- exit 1
- else
- echo
- echo "*** Warning: Linking the shared library $output against the non-libtool"
- echo "*** objects $objs is not portable!"
- libobjs="$libobjs $objs"
- fi
- fi
- if test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen self' is ignored for libtool libraries" 1>&2
- fi
- set dummy $rpath
- if test "$#" -gt 2; then
- $echo "$modename: warning: ignoring multiple \`-rpath's for a libtool library" 1>&2
- fi
- install_libdir="$2"
- oldlibs=
- if test -z "$rpath"; then
- # Building a libtool convenience library.
- libext=al
- oldlibs="$output_objdir/$libname.$libext $oldlibs"
- build_libtool_libs=convenience
- fi
- $echo "$modename: warning: \`-version-info' is ignored for convenience libraries" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for convenience libraries" 1>&2
- fi
- else
- # Parse the version information argument.
- save_ifs="$IFS"; IFS=':'
- set dummy $vinfo 0 0 0
- IFS="$save_ifs"
- if test -n "$8"; then
- $echo "$modename: too many parameters to \`-version-info'" 1>&2
- exit 1
- fi
- current="$2"
- revision="$3"
- age="$4"
- # Check that each of the things are valid numbers.
- case $current in
- [0-9]*) ;;
- $echo "$modename: CURRENT \`$current' is not a nonnegative integer" 1>&2
- $echo "$modename: \`$vinfo' is not valid version information" 1>&2
- exit 1
- esac
- case $revision in
- [0-9]*) ;;
- $echo "$modename: REVISION \`$revision' is not a nonnegative integer" 1>&2
- exit 1
- esac
- case $age in
- [0-9]*) ;;
- $echo "$modename: AGE \`$age' is not a nonnegative integer" 1>&2
- exit 1
- esac
- if test "$age" -gt "$current"; then
- $echo "$modename: AGE \`$age' is greater than the current interface number \`$current'" 1>&2
- exit 1
- fi
- # Calculate the version variables.
- major=
- versuffix=
- verstring=
- case $version_type in
- none) ;;
- darwin)
- # Like Linux, but with the current version available in
- # verstring for coding it into the library header
- major=.`expr $current - $age`
- versuffix="$major.$age.$revision"
- # Darwin ld doesn't like 0 for these options...
- minor_current=`expr $current + 1`
- verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
- freebsd-aout)
- major=".$current"
- versuffix=".$current.$revision";
- freebsd-elf)
- major=".$current"
- versuffix=".$current";
- irix)
- major=`expr $current - $age + 1`
- verstring="sgi$major.$revision"
- # Add in all the interfaces that we are compatible with.
- loop=$revision
- while test "$loop" -ne 0; do
- iface=`expr $revision - $loop`
- loop=`expr $loop - 1`
- verstring="sgi$major.$iface:$verstring"
- done
- # Before this point, $major must not contain `.'.
- major=.$major
- versuffix="$major.$revision"
- linux)
- osf)
- versuffix=".$current.$age.$revision"
- verstring="$current.$age.$revision"
- loop=$age
- iface=`expr $current - $loop`
- verstring="$verstring:${iface}.0"
- done
- # Make executables depend on our current version.
- verstring="$verstring:${current}.0"
- sunos)
- major=".$current"
- windows)
- # Use '-' rather than '.', since we only want one
- # extension on DOS 8.3 filesystems.
- $echo "$modename: unknown library version type \`$version_type'" 1>&2
- exit 1
- esac
- # Clear the version info if we defaulted, and they specified a release.
- if test -z "$vinfo" && test -n "$release"; then
- major=
- verstring="0.0"
- darwin)
- # we can't check for "0.0" in archive_cmds due to quoting
- # problems, so we reset it completely
- verstring=""
- verstring="0.0"
- esac
- if test "$need_version" = no; then
- versuffix=
- else
- versuffix=".0.0"
- fi
- fi
- # Remove version info from name if versioning should be avoided
- if test "$avoid_version" = yes && test "$need_version" = no; then
- major=
- versuffix=
- verstring=""
- fi
- # Check to see if the archive will have undefined symbols.
- if test "$allow_undefined" = yes; then
- if test "$allow_undefined_flag" = unsupported; then
- $echo "$modename: warning: undefined symbols not allowed in $host shared libraries" 1>&2
- fi
- else
- # Don't allow undefined symbols.
- allow_undefined_flag="$no_undefined_flag"
- fi
- fi
- if test "$mode" != relink; then
- # Remove our outputs.
- $show "${rm}r $output_objdir/$outputname $output_objdir/$libname.* $output_objdir/${libname}${release}.*"
- $run ${rm}r $output_objdir/$outputname $output_objdir/$libname.* $output_objdir/${libname}${release}.*
- fi
- if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
- oldlibs="$oldlibs $output_objdir/$libname.$libext"
- # Transform .lo files to .o files.
- oldobjs="$objs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e "$lo2o" | $NL2SP`
- fi
- # Eliminate all temporary directories.
- for path in $notinst_path; do
- lib_search_path=`echo "$lib_search_path " | sed -e 's% $path % %g'`
- deplibs=`echo "$deplibs " | sed -e 's% -L$path % %g'`
- dependency_libs=`echo "$dependency_libs " | sed -e 's% -L$path % %g'`
- done
- # If the user specified any rpath flags, then add them.
- temp_xrpath=
- for libdir in $xrpath; do
- temp_xrpath="$temp_xrpath -R$libdir"
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir" ;;
- esac
- done
- if test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes; then
- dependency_libs="$temp_xrpath $dependency_libs"
- fi
- fi
- # Make sure dlfiles contains only unique files that won't be dlpreopened
- old_dlfiles="$dlfiles"
- dlfiles=
- for lib in $old_dlfiles; do
- case " $dlprefiles $dlfiles " in
- *" $lib "*) ;;
- *) dlfiles="$dlfiles $lib" ;;
- esac
- done
- # Make sure dlprefiles contains only unique files
- old_dlprefiles="$dlprefiles"
- dlprefiles=
- for lib in $old_dlprefiles; do
- case "$dlprefiles " in
- *" $lib "*) ;;
- *) dlprefiles="$dlprefiles $lib" ;;
- esac
- done
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos*)
- # these systems don't actually have a c library (as such)!
- *-*-rhapsody* | *-*-darwin1.[012])
- # Rhapsody C library is in the System framework
- deplibs="$deplibs -framework System"
- *-*-netbsd*)
- # Don't link with libc until the a.out ld.so is fixed.
- *-*-openbsd*)
- # Add libc to deplibs on all other systems if necessary.
- if test "$build_libtool_need_lc" = "yes"; then
- deplibs="$deplibs -lc"
- fi
- esac
- fi
- # Transform deplibs into only deplibs that can be linked in shared.
- name_save=$name
- libname_save=$libname
- release_save=$release
- versuffix_save=$versuffix
- major_save=$major
- # I'm not sure if I'm treating the release correctly. I think
- # release should show up in the -l (ie -lgmp5) so we don't want to
- # add it in twice. Is that correct?
- release=""
- versuffix=""
- major=""
- newdeplibs=
- droppeddeps=no
- case $deplibs_check_method in
- pass_all)
- # Don't check for shared/static. Everything works.
- # This might be a little naive. We might want to check
- # whether the library exists or not. But this is on
- # osf3 & osf4 and I'm not really sure... Just
- # implementing what was already the behaviour.
- newdeplibs=$deplibs
- test_compile)
- # This code stresses the "libraries are programs" paradigm to its
- # limits. Maybe even breaks it. We compile a program, linking it
- # against the deplibs as a proxy for the library. Then we can check
- # whether they linked in statically or dynamically with ldd.
- $rm conftest.c
- cat > conftest.c <<EOF
- int main() { return 0; }
-EOF
- $rm conftest
- $CC -o conftest conftest.c $deplibs
- if test "$?" -eq 0 ; then
- ldd_output=`ldd conftest`
- for i in $deplibs; do
- name="`expr $i : '-l\(.*\)'`"
- # If $name is empty we are operating on a -L argument.
- if test -n "$name" && test "$name" != "0"; then
- deplib_matches=`eval \\$echo \"$library_names_spec\"`
- set dummy $deplib_matches
- deplib_match=$2
- if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
- newdeplibs="$newdeplibs $i"
- else
- droppeddeps=yes
- echo
- echo "*** Warning: This library needs some functionality provided by $i."
- fi
- else
- fi
- done
- else
- # Error occured in the first compile. Let's try to salvage the situation:
- # Compile a seperate program for each library.
- $rm conftest
- $CC -o conftest conftest.c $i
- # Did it work?
- deplib_match=$2
- else
- droppeddeps=yes
- echo
- fi
- else
- droppeddeps=yes
- echo
- echo "*** Warning! Library $i is needed by this library but I was not able to"
- echo "*** make it link in! You will probably need to install it or some"
- echo "*** library that it depends on before this library will be fully"
- echo "*** functional. Installing it before continuing would be even better."
- fi
- else
- fi
- done
- fi
- file_magic*)
- set dummy $deplibs_check_method
- file_magic_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- for a_deplib in $deplibs; do
- name="`expr $a_deplib : '-l\(.*\)'`"
- for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
- potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
- for potent_lib in $potential_libs; do
- # Follow soft links.
- if ls -lLd "$potent_lib" 2>/dev/null \
- | grep " -> " >/dev/null; then
- continue
- fi
- # The statement above tries to avoid entering an
- # endless loop below, in case of cyclic links.
- # We might still enter an endless loop, since a link
- # loop can be closed while we follow links,
- # but so what?
- potlib="$potent_lib"
- while test -h "$potlib" 2>/dev/null; do
- potliblink=`ls -ld $potlib | sed 's/.* -> //'`
- case $potliblink in
- [\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
- *) potlib=`$echo "X$potlib" | $Xsed -e 's,[^/]*$,,'`"$potliblink";;
- esac
- done
- if eval $file_magic_cmd \"\$potlib\" 2>/dev/null \
- | sed 10q \
- | egrep "$file_magic_regex" > /dev/null; then
- newdeplibs="$newdeplibs $a_deplib"
- a_deplib=""
- break 2
- fi
- done
- done
- if test -n "$a_deplib" ; then
- droppeddeps=yes
- echo
- echo "*** Warning: This library needs some functionality provided by $a_deplib."
- fi
- else
- # Add a -L argument.
- fi
- done # Gone through all deplibs.
- match_pattern*)
- match_pattern_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- if eval echo \"$potent_lib\" 2>/dev/null \
- | sed 10q \
- | egrep "$match_pattern_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- droppeddeps=yes
- echo
- fi
- else
- fi
- none | unknown | *)
- newdeplibs=""
- if $echo "X $deplibs" | $Xsed -e 's/ -lc$//' \
- -e 's/ -[LR][^ ]*//g' -e 's/[ ]//g' |
- grep . >/dev/null; then
- echo
- if test "X$deplibs_check_method" = "Xnone"; then
- echo "*** Warning: inter-library dependencies are not supported in this platform."
- else
- echo "*** Warning: inter-library dependencies are not known to be supported."
- fi
- echo "*** All declared inter-library dependencies are being dropped."
- droppeddeps=yes
- fi
- esac
- versuffix=$versuffix_save
- major=$major_save
- release=$release_save
- libname=$libname_save
- name=$name_save
- case $host in
- # On Rhapsody replace the C library is the System framework
- newdeplibs=`$echo "X $newdeplibs" | $Xsed -e 's/ -lc / -framework System /'`
- esac
- if test "$droppeddeps" = yes; then
- echo
- echo "*** Warning: libtool could not satisfy all declared inter-library"
- echo "*** dependencies of module $libname. Therefore, libtool will create"
- echo "*** a static module, that should work as long as the dlopening"
- echo "*** application is linked with the -dlopen flag."
- echo
- fi
- oldlibs="$output_objdir/$libname.$libext"
- else
- fi
- else
- echo "*** The inter-library dependencies that have been dropped here will be"
- echo "*** automatically added whenever a program is linked with this library"
- echo "*** or is declared to -dlopen it."
- if test "$allow_undefined" = no; then
- echo
- echo "*** Since this library must not contain undefined symbols,"
- echo "*** because either the platform does not support them or"
- echo "*** it was explicitly requested with -no-undefined,"
- echo "*** libtool will only create a static version of it."
- else
- fi
- fi
- fi
- fi
- # Done checking deplibs!
- deplibs=$newdeplibs
- fi
- # All the library-specific variables (install_libdir is set above).
- library_names=
- old_library=
- dlname=
- # Test again, we may have decided not to build it any more
- if test "$hardcode_into_libs" = yes; then
- # Hardcode the library paths
- hardcode_libdirs=
- dep_rpath=
- rpath="$finalize_rpath"
- test "$mode" != relink && rpath="$compile_rpath$rpath"
- for libdir in $rpath; do
- if test -n "$hardcode_libdir_flag_spec"; then
- if test -n "$hardcode_libdir_separator"; then
- if test -z "$hardcode_libdirs"; then
- hardcode_libdirs="$libdir"
- else
- # Just accumulate the unique libdirs.
- case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
- *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
- hardcode_libdirs="$hardcode_libdirs$hardcode_libdir_separator$libdir"
- esac
- fi
- else
- eval flag=\"$hardcode_libdir_flag_spec\"
- dep_rpath="$dep_rpath $flag"
- fi
- elif test -n "$runpath_var"; then
- case "$perm_rpath " in
- *" $libdir "*) ;;
- *) perm_rpath="$perm_rpath $libdir" ;;
- esac
- fi
- done
- # Substitute the hardcoded libdirs into the rpath.
- if test -n "$hardcode_libdir_separator" &&
- test -n "$hardcode_libdirs"; then
- libdir="$hardcode_libdirs"
- eval dep_rpath=\"$hardcode_libdir_flag_spec\"
- fi
- if test -n "$runpath_var" && test -n "$perm_rpath"; then
- # We should set the runpath_var.
- rpath=
- for dir in $perm_rpath; do
- rpath="$rpath$dir:"
- done
- eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
- fi
- test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
- fi
- shlibpath="$finalize_shlibpath"
- test "$mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
- if test -n "$shlibpath"; then
- eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
- fi
- # Get the real and link names of the library.
- eval library_names=\"$library_names_spec\"
- realname="$2"
- shift; shift
- if test -n "$soname_spec"; then
- else
- fi
- test -z "$dlname" && dlname=$soname
- lib="$output_objdir/$realname"
- for link
- do
- linknames="$linknames $link"
- done
- # Ensure that we have .o objects for linkers which dislike .lo
- # (e.g. aix) in case we are running --disable-static
- for obj in $libobjs; do
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$obj" | $Xsed -e 's%^.*/%%'`
- oldobj=`$echo "X$baseobj" | $Xsed -e "$lo2o"`
- if test ! -f $xdir/$oldobj; then
- $show "(cd $xdir && ${LN_S} $baseobj $oldobj)"
- $run eval '(cd $xdir && ${LN_S} $baseobj $oldobj)' || exit $?
- fi
- done
- # Use standard objects if they are pic
- test -z "$pic_flag" && libobjs=`$echo "X$libobjs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
- $show "generating symbol list for \`$libname.la'"
- export_symbols="$output_objdir/$libname.exp"
- $run $rm $export_symbols
- eval cmds=\"$export_symbols_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex"; then
- $show "egrep -e \"$export_symbols_regex\" \"$export_symbols\" > \"${export_symbols}T\""
- $run eval 'egrep -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
- $show "$mv \"${export_symbols}T\" \"$export_symbols\""
- $run eval '$mv "${export_symbols}T" "$export_symbols"'
- fi
- fi
- fi
- if test -n "$export_symbols" && test -n "$include_expsyms"; then
- $run eval '$echo "X$include_expsyms" | $SP2NL >> "$export_symbols"'
- fi
- if test -n "$convenience"; then
- if test -n "$whole_archive_flag_spec"; then
- eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${outputname}x"
- $show "${rm}r $gentop"
- $run ${rm}r "$gentop"
- $show "mkdir $gentop"
- $run mkdir "$gentop"
- status=$?
- if test "$status" -ne 0 && test ! -d "$gentop"; then
- exit $status
- fi
- generated="$generated $gentop"
- for xlib in $convenience; do
- # Extract the objects.
- case $xlib in
- [\\/]* | [A-Za-z]:[\\/]*) xabs="$xlib" ;;
- *) xabs=`pwd`"/$xlib" ;;
- esac
- xlib=`$echo "X$xlib" | $Xsed -e 's%^.*/%%'`
- xdir="$gentop/$xlib"
- $show "${rm}r $xdir"
- $run ${rm}r "$xdir"
- $show "mkdir $xdir"
- $run mkdir "$xdir"
- status=$?
- if test "$status" -ne 0 && test ! -d "$xdir"; then
- exit $status
- fi
- $show "(cd $xdir && $AR x $xabs)"
- $run eval "(cd \$xdir && $AR x \$xabs)" || exit $?
- libobjs="$libobjs "`find $xdir -name \*.o -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
- eval flag=\"$thread_safe_flag_spec\"
- fi
- # Make a backup of the uninstalled library when relinking
- if test "$mode" = relink; then
- $run eval '(cd $output_objdir && $rm ${realname}U && $mv $realname ${realname}U)' || exit $?
- fi
- # Do each of the archive commands.
- if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
- eval cmds=\"$archive_expsym_cmds\"
- else
- eval cmds=\"$archive_cmds\"
- fi
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Restore the uninstalled library and exit
- $run eval '(cd $output_objdir && $rm ${realname}T && $mv $realname ${realname}T && $mv "$realname"U $realname)' || exit $?
- exit 0
- fi
- # Create links to the real library.
- for linkname in $linknames; do
- if test "$realname" != "$linkname"; then
- $show "(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval '(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)' || exit $?
- fi
- done
- # If -module or -export-dynamic was specified, set the dlname.
- if test "$module" = yes || test "$export_dynamic" = yes; then
- # On all known operating systems, these are identical.
- dlname="$soname"
- fi
- fi
- obj)
- if test -n "$deplibs"; then
- $echo "$modename: warning: \`-l' and \`-L' are ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-dlopen' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-rpath' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-R' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-version-info' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for objects" 1>&2
- fi
- case $output in
- *.lo)
- if test -n "$objs$old_deplibs"; then
- $echo "$modename: cannot build library object \`$output' from non-libtool objects" 1>&2
- exit 1
- fi
- libobj="$output"
- obj=`$echo "X$output" | $Xsed -e "$lo2o"`
- libobj=
- obj="$output"
- esac
- # Delete the old objects.
- $run $rm $obj $libobj
- # Objects from convenience libraries. This assumes
- # single-version convenience libraries. Whenever we create
- # different ones for PIC/non-PIC, this we'll have to duplicate
- # the extraction.
- reload_conv_objs=
- gentop=
- # reload_cmds runs $LD directly, so let us get rid of
- # -Wl from whole_archive_flag_spec
- wl=
- eval reload_conv_objs=\"\$reload_objs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${obj}x"
- status=$?
- exit $status
- fi
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- reload_conv_objs="$reload_objs "`find $xdir -name \*.o -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- # Create the old-style object.
- reload_objs="$objs$old_deplibs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}$'/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
- output="$obj"
- eval cmds=\"$reload_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Exit if we aren't doing a library object file.
- if test -z "$libobj"; then
- if test -n "$gentop"; then
- $run ${rm}r $gentop
- fi
- exit 0
- fi
- fi
- # Create an invalid libtool object if no PIC, so that we don't
- $run eval "echo timestamp > $libobj" || exit $?
- exit 0
- fi
- if test -n "$pic_flag" || test "$pic_mode" != default; then
- # Only do commands if we really have different PIC objects.
- reload_objs="$libobjs $reload_conv_objs"
- output="$libobj"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- else
- # Just create a symlink.
- $show $rm $libobj
- $run $rm $libobj
- xdir=`$echo "X$libobj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$libobj"; then
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$libobj" | $Xsed -e 's%^.*/%%'`
- $show "(cd $xdir && $LN_S $oldobj $baseobj)"
- $run eval '(cd $xdir && $LN_S $oldobj $baseobj)' || exit $?
- fi
- fi
- exit 0
- prog)
- case $host in
- *cygwin*) output=`echo $output | sed -e 's,.exe$,,;s,$,.exe,'` ;;
- esac
- $echo "$modename: warning: \`-version-info' is ignored for programs" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for programs" 1>&2
- fi
- if test "$preload" = yes; then
- if test "$dlopen_support" = unknown && test "$dlopen_self" = unknown &&
- test "$dlopen_self_static" = unknown; then
- $echo "$modename: warning: \`AC_LIBTOOL_DLOPEN' not used. Assuming no dlopen support."
- fi
- fi
- case $host in
- compile_deplibs=`$echo "X $compile_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- finalize_deplibs=`$echo "X $finalize_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- esac
- compile_command="$compile_command $compile_deplibs"
- finalize_command="$finalize_command $finalize_deplibs"
- if test -n "$rpath$xrpath"; then
- for libdir in $rpath $xrpath; do
- # This is the magic to use -rpath.
- *" $libdir "*) ;;
- esac
- done
- fi
- # Now hardcode the library paths
- rpath=
- hardcode_libdirs=
- for libdir in $compile_rpath $finalize_rpath; do
- else
- esac
- fi
- else
- rpath="$rpath $flag"
- fi
- *" $libdir "*) ;;
- esac
- fi
- case $host in
- *":$libdir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$libdir";;
- esac
- esac
- done
- eval rpath=\" $hardcode_libdir_flag_spec\"
- fi
- compile_rpath="$rpath"
- rpath=
- hardcode_libdirs=
- for libdir in $finalize_rpath; do
- else
- esac
- fi
- else
- fi
- case "$finalize_perm_rpath " in
- *" $libdir "*) ;;
- *) finalize_perm_rpath="$finalize_perm_rpath $libdir" ;;
- esac
- fi
- done
- fi
- finalize_rpath="$rpath"
- if test -n "$libobjs" && test "$build_old_libs" = yes; then
- # Transform all the library objects into standard objects.
- compile_command=`$echo "X$compile_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- finalize_command=`$echo "X$finalize_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- fi
- dlsyms=
- if test -n "$NM" && test -n "$global_symbol_pipe"; then
- dlsyms="${outputname}S.c"
- else
- $echo "$modename: not configured to extract global symbols from dlpreopened files" 1>&2
- fi
- fi
- if test -n "$dlsyms"; then
- case $dlsyms in
- *.c)
- # Discover the nlist of each of the dlfiles.
- nlist="$output_objdir/${outputname}.nm"
- $show "$rm $nlist ${nlist}S ${nlist}T"
- $run $rm "$nlist" "${nlist}S" "${nlist}T"
- # Parse the name list into a source file.
- $show "creating $output_objdir/$dlsyms"
- test -z "$run" && $echo > "$output_objdir/$dlsyms" "\
-/* $dlsyms - symbol resolution table for \`$outputname' dlsym emulation. */
-/* Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP */
-#ifdef __cplusplus
-extern \"C\" {
-#endif
-/* Prevent the only kind of declaration conflicts we can make. */
-#define lt_preloaded_symbols some_other_symbol
-/* External symbol declarations for the compiler. */\
- if test "$dlself" = yes; then
- $show "generating symbol list for \`$output'"
- test -z "$run" && $echo ': @PROGRAM@ ' > "$nlist"
- # Add our own program objects to the symbol list.
- progfiles=`$echo "X$objs$old_deplibs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- for arg in $progfiles; do
- $show "extracting global C symbols from \`$arg'"
- $run eval "$NM $arg | $global_symbol_pipe >> '$nlist'"
- done
- if test -n "$exclude_expsyms"; then
- $run eval 'egrep -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
- $run eval '$mv "$nlist"T "$nlist"'
- fi
- $run eval 'egrep -e "$export_symbols_regex" "$nlist" > "$nlist"T'
- fi
- export_symbols="$output_objdir/$output.exp"
- $run eval "sed -n -e '/^: @PROGRAM@$/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
- else
- $run eval "sed -e 's/\([][.*^$]\)/\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$output.exp"'
- $run eval 'grep -f "$output_objdir/$output.exp" < "$nlist" > "$nlist"T'
- $run eval 'mv "$nlist"T "$nlist"'
- fi
- fi
- for arg in $dlprefiles; do
- name=`echo "$arg" | sed -e 's%^.*/%%'`
- $run eval 'echo ": $name " >> "$nlist"'
- done
- if test -z "$run"; then
- # Make sure we have at least an empty file.
- test -f "$nlist" || : > "$nlist"
- egrep -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
- $mv "$nlist"T "$nlist"
- fi
- # Try sorting and uniquifying the output.
- if grep -v "^: " < "$nlist" | sort +2 | uniq > "$nlist"S; then
- else
- grep -v "^: " < "$nlist" > "$nlist"S
- fi
- if test -f "$nlist"S; then
- eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$dlsyms"'
- else
- echo '/* NONE */' >> "$output_objdir/$dlsyms"
- fi
- $echo >> "$output_objdir/$dlsyms" "\
-#undef lt_preloaded_symbols
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[] =
- eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$dlsyms"
- {0, (lt_ptr) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif\
- fi
- pic_flag_for_symtable=
- case $host in
- # compiling the symbol table file with pic_flag works around
- # a FreeBSD bug that causes programs to crash when -lm is
- # linked before any other PIC object. But we must not use
- # pic_flag when linking with -static. The problem exists in
- # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
- *-*-freebsd2*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
- case "$compile_command " in
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag -DPIC -DFREEBSD_WORKAROUND";;
- esac;;
- *-*-hpux*)
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag -DPIC";;
- esac
- esac
- # Now compile the dynamic symbol file.
- $show "(cd $output_objdir && $CC -c$no_builtin_flag$pic_flag_for_symtable \"$dlsyms\")"
- $run eval '(cd $output_objdir && $CC -c$no_builtin_flag$pic_flag_for_symtable "$dlsyms")' || exit $?
- # Clean up the generated files.
- $show "$rm $output_objdir/$dlsyms $nlist ${nlist}S ${nlist}T"
- $run $rm "$output_objdir/$dlsyms" "$nlist" "${nlist}S" "${nlist}T"
- # Transform the symbol file into the correct name.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- $echo "$modename: unknown suffix for \`$dlsyms'" 1>&2
- exit 1
- esac
- else
- # We keep going just in case the user didn't refer to
- # lt_preloaded_symbols. The linker will fail if global_symbol_pipe
- # really was required.
- # Nullify the symbol file.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s% @SYMFILE@%%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s% @SYMFILE@%%"`
- fi
- if test "$need_relink" = no || test "$build_libtool_libs" != yes; then
- # Replace the output file specification.
- compile_command=`$echo "X$compile_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- link_command="$compile_command$compile_rpath"
- # We have no uninstalled library dependencies, so finalize right now.
- $show "$link_command"
- $run eval "$link_command"
- status=$?
- # Delete the generated files.
- $show "$rm $output_objdir/${outputname}S.${objext}"
- $run $rm "$output_objdir/${outputname}S.${objext}"
- fi
- exit $status
- fi
- # We should set the shlibpath_var
- rpath=
- for dir in $temp_rpath; do
- case $dir in
- # Absolute path.
- # Relative path: add a thisdir entry.
- rpath="$rpath\$thisdir/$dir:"
- esac
- done
- temp_rpath="$rpath"
- fi
- if test -n "$compile_shlibpath$finalize_shlibpath"; then
- compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
- fi
- if test -n "$finalize_shlibpath"; then
- finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
- fi
- compile_var=
- finalize_var=
- if test -n "$runpath_var"; then
- if test -n "$perm_rpath"; then
- rpath=
- done
- compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- if test -n "$finalize_perm_rpath"; then
- rpath=
- for dir in $finalize_perm_rpath; do
- done
- finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- fi
- if test "$no_install" = yes; then
- # We don't need to create a wrapper script.
- link_command="$compile_var$compile_command$compile_rpath"
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- # Delete the old output file.
- $run $rm $output
- # Link the executable and exit
- $run eval "$link_command" || exit $?
- exit 0
- fi
- if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- relink_command="$finalize_var$finalize_command$finalize_rpath"
- $echo "$modename: warning: this platform does not like uninstalled shared libraries" 1>&2
- $echo "$modename: \`$output' will be relinked during installation" 1>&2
- else
- if test "$fast_install" != no; then
- link_command="$finalize_var$compile_command$finalize_rpath"
- if test "$fast_install" = yes; then
- relink_command=`$echo "X$compile_var$compile_command$compile_rpath" | $Xsed -e 's%@OUTPUT@%\$progdir/\$file%g'`
- else
- # fast_install is set to needless
- relink_command=
- fi
- else
- fi
- fi
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
- # Delete the old output files.
- $run $rm $output $output_objdir/$outputname $output_objdir/lt-$outputname
- # Now create the wrapper script.
- $show "creating $output"
- # Quote the relink command for shipping.
- if test -n "$relink_command"; then
- # Preserve any variables that may affect compiler behavior
- for var in $variables_saved_for_relink; do
- if eval test -z \"\${$var+set}\"; then
- relink_command="{ test -z \"\${$var+set}\" || unset $var || { $var=; export $var; }; }; $relink_command"
- elif eval var_value=\$$var; test -z "$var_value"; then
- relink_command="$var=; export $var; $relink_command"
- else
- var_value=`$echo "X$var_value" | $Xsed -e "$sed_quote_subst"`
- relink_command="$var=\"$var_value\"; export $var; $relink_command"
- fi
- done
- relink_command="(cd `pwd`; $relink_command)"
- relink_command=`$echo "X$relink_command" | $Xsed -e "$sed_quote_subst"`
- fi
- # Quote $echo for shipping.
- if test "X$echo" = "X$SHELL $0 --fallback-echo"; then
- case $0 in
- [\\/]* | [A-Za-z]:[\\/]*) qecho="$SHELL $0 --fallback-echo";;
- *) qecho="$SHELL `pwd`/$0 --fallback-echo";;
- esac
- qecho=`$echo "X$qecho" | $Xsed -e "$sed_quote_subst"`
- else
- qecho=`$echo "X$echo" | $Xsed -e "$sed_quote_subst"`
- fi
- # Only actually do things if our run command is non-null.
- # win32 will think the script is a binary if it has
- # a .exe suffix, so we strip it off here.
- case $output in
- *.exe) output=`echo $output|sed 's,.exe$,,'` ;;
- esac
- # test for cygwin because mv fails w/o .exe extensions
- case $host in
- *cygwin*) exeext=.exe ;;
- *) exeext= ;;
- esac
- $rm $output
- trap "$rm $output; exit 1" 1 2 15
- $echo > $output "\
-#! $SHELL
-# $output - temporary wrapper script for $objdir/$outputname
-# Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
-# The $output program cannot be directly executed until all the libtool
-# libraries that it depends on are installed.
-# This wrapper script should never be moved out of the build directory.
-# If it is, it will not operate correctly.
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e 1s/^X//'
-sed_quote_subst='$sed_quote_subst'
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test \"\${CDPATH+set}\" = set; then CDPATH=:; export CDPATH; fi
-relink_command=\"$relink_command\"
-# This environment variable determines our operation mode.
-if test \"\$libtool_install_magic\" = \"$magic\"; then
- # install mode needs the following variable:
- notinst_deplibs='$notinst_deplibs'
-else
- # When we are sourced in execute mode, \$file and \$echo are already set.
- if test \"\$libtool_execute_magic\" != \"$magic\"; then
- echo=\"$qecho\"
- file=\"\$0\"
- # Make sure echo works.
- if test \"X\$1\" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
- elif test \"X\`(\$echo '\t') 2>/dev/null\`\" = 'X\t'; then
- # Yippee, \$echo works!
- else
- # Restart under the correct shell, and then maybe \$echo will work.
- exec $SHELL \"\$0\" --no-reexec \${1+\"\$@\"}
- fi
- fi\
- $echo >> $output "\
- # Find the directory that this script lives in.
- thisdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*$%%'\`
- test \"x\$thisdir\" = \"x\$file\" && thisdir=.
- # Follow symbolic links until we get to the real thisdir.
- file=\`ls -ld \"\$file\" | sed -n 's/.*-> //p'\`
- while test -n \"\$file\"; do
- destdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*\$%%'\`
- # If there was a directory component, then change thisdir.
- if test \"x\$destdir\" != \"x\$file\"; then
- case \"\$destdir\" in
- [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
- *) thisdir=\"\$thisdir/\$destdir\" ;;
- esac
- fi
- file=\`\$echo \"X\$file\" | \$Xsed -e 's%^.*/%%'\`
- file=\`ls -ld \"\$thisdir/\$file\" | sed -n 's/.*-> //p'\`
- done
- # Try to get the absolute directory name.
- absdir=\`cd \"\$thisdir\" && pwd\`
- test -n \"\$absdir\" && thisdir=\"\$absdir\"
- echo >> $output "\
- program=lt-'$outputname'$exeext
- progdir=\"\$thisdir/$objdir\"
- if test ! -f \"\$progdir/\$program\" || \\
- { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | sed 1q\`; \\
- test \"X\$file\" != \"X\$progdir/\$program\"; }; then
- file=\"\$\$-\$program\"
- if test ! -d \"\$progdir\"; then
- $mkdir \"\$progdir\"
- else
- $rm \"\$progdir/\$file\"
- fi"
- # relink executable if necessary
- if test -n \"\$relink_command\"; then
- if relink_command_output=\`eval \$relink_command 2>&1\`; then :
- else
- $echo \"\$relink_command_output\" >&2
- exit 1
- fi
- fi
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
- { $rm \"\$progdir/\$program\";
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\"; }
- fi"
- else
- program='$outputname'
- fi
- if test -f \"\$progdir/\$program\"; then"
- # Export our shlibpath_var if we have one.
- if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
- # Add our own library path to $shlibpath_var
- $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
- # Some systems cannot cope with colon-terminated $shlibpath_var
- # The second colon is a workaround for a bug in BeOS R4 sed
- $shlibpath_var=\`\$echo \"X\$$shlibpath_var\" | \$Xsed -e 's/::*\$//'\`
- export $shlibpath_var
- fi
- # fixup the dll searchpath if we need to.
- if test -n "$dllsearchpath"; then
- # Add the dll search path components to the executable PATH
- PATH=$dllsearchpath:\$PATH
- fi
- # Run the actual program with our arguments.
- case $host in
- # win32 systems need to use the prog path for dll
- # lookup to work
- *-*-cygwin* | *-*-pw32*)
- exec \$progdir/\$program \${1+\"\$@\"}
- # Backslashes separate directories on plain windows
- *-*-mingw | *-*-os2*)
- exec \$progdir\\\\\$program \${1+\"\$@\"}
- # Export the path to the program.
- PATH=\"\$progdir:\$PATH\"
- export PATH
- exec \$program \${1+\"\$@\"}
- esac
- \$echo \"\$0: cannot exec \$program \${1+\"\$@\"}\"
- exit 1
- fi
- else
- # The program doesn't exist.
- \$echo \"\$0: error: \$progdir/\$program does not exist\" 1>&2
- \$echo \"This script is just a wrapper for \$program.\" 1>&2
- echo \"See the $PACKAGE documentation for more information.\" 1>&2
- exit 1
- fi
-fi\
- chmod +x $output
- fi
- exit 0
- esac
- # See if we need to build an old-fashioned archive.
- for oldlib in $oldlibs; do
- if test "$build_libtool_libs" = convenience; then
- oldobjs="$libobjs_save"
- addlibs="$convenience"
- build_libtool_libs=no
- else
- if test "$build_libtool_libs" = module; then
- else
- oldobjs="$objs$old_deplibs "`$echo "X$libobjs_save" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`
- fi
- addlibs="$old_convenience"
- fi
- if test -n "$addlibs"; then
- status=$?
- exit $status
- fi
- # Add in members from convenience archives.
- for xlib in $addlibs; do
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- oldobjs="$oldobjs "`find $xdir -name \*.${objext} -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- # Do each command in the archive commands.
- if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
- eval cmds=\"$old_archive_from_new_cmds\"
- else
- # Ensure that we have .o objects in place in case we decided
- # not to build a shared library, and have fallen back to building
- # static libs even though --disable-static was passed!
- for oldobj in $oldobjs; do
- if test ! -f $oldobj; then
- xdir=`$echo "X$oldobj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$oldobj"; then
- xdir="."
- else
- xdir="$xdir"
- fi
- baseobj=`$echo "X$oldobj" | $Xsed -e 's%^.*/%%'`
- obj=`$echo "X$baseobj" | $Xsed -e "$o2lo"`
- $show "(cd $xdir && ${LN_S} $obj $baseobj)"
- $run eval '(cd $xdir && ${LN_S} $obj $baseobj)' || exit $?
- fi
- done
- eval cmds=\"$old_archive_cmds\"
- fi
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- done
- if test -n "$generated"; then
- $show "${rm}r$generated"
- $run ${rm}r$generated
- fi
- # Now create the libtool archive.
- case $output in
- *.la)
- old_library=
- test "$build_old_libs" = yes && old_library="$libname.$libext"
- else
- fi
- done
- # Quote the link command for shipping.
- relink_command="(cd `pwd`; $SHELL $0 --mode=relink $libtool_args)"
- # Only create the output if not a dry run.
- for installed in no yes; do
- if test "$installed" = yes; then
- if test -z "$install_libdir"; then
- break
- fi
- output="$output_objdir/$outputname"i
- # Replace all uninstalled libtool libraries with the installed ones
- case $deplib in
- *.la)
- name=`$echo "X$deplib" | $Xsed -e 's%^.*/%%'`
- exit 1
- fi
- newdependency_libs="$newdependency_libs $libdir/$name"
- *) newdependency_libs="$newdependency_libs $deplib" ;;
- esac
- done
- dependency_libs="$newdependency_libs"
- newdlfiles=
- for lib in $dlfiles; do
- name=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- eval libdir=`sed -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
- exit 1
- fi
- newdlfiles="$newdlfiles $libdir/$name"
- done
- newdlprefiles=
- for lib in $dlprefiles; do
- exit 1
- fi
- newdlprefiles="$newdlprefiles $libdir/$name"
- done
- fi
- $rm $output
- # place dlname in correct position for cygwin
- tdlname=$dlname
- case $host,$output,$installed,$module,$dlname in
- *cygwin*,*lai,yes,no,*.dll) tdlname=../bin/$dlname ;;
- esac
-# $outputname - a libtool library file
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# The name that we can dlopen(3).
-dlname='$tdlname'
-# Names of this library.
-library_names='$library_names'
-# The name of the static archive.
-old_library='$old_library'
-# Libraries that this one depends upon.
-dependency_libs='$dependency_libs'
-# Version information for $libname.
-current=$current
-age=$age
-revision=$revision
-# Is this an already installed library?
-installed=$installed
-# Files to dlopen/dlpreopen
-dlopen='$dlfiles'
-dlpreopen='$dlprefiles'
-# Directory that this library needs to be installed in:
-libdir='$install_libdir'"
- if test "$installed" = no && test "$need_relink" = yes; then
-relink_command=\"$relink_command\""
- fi
- done
- fi
- # Do a symbolic link so that the libtool archive can be found in
- # LD_LIBRARY_PATH before the program is installed.
- $show "(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)"
- $run eval '(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)' || exit $?
- esac
- exit 0
- # libtool install mode
- install)
- modename="$modename: install"
- # There may be an optional sh(1) argument at the beginning of
- # install_prog (especially on Windows NT).
- if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
- # Allow the use of GNU shtool's install command.
- $echo "X$nonopt" | $Xsed | grep shtool > /dev/null; then
- # Aesthetically quote it.
- arg=`$echo "X$nonopt" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$arg "
- arg="$1"
- shift
- else
- install_prog=
- arg="$nonopt"
- fi
- # The real first argument should be the name of the installation program.
- arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog$arg"
- # We need to accept at least all the BSD install flags.
- dest=
- files=
- opts=
- prev=
- install_type=
- isdir=no
- stripme=
- for arg
- do
- if test -n "$dest"; then
- files="$files $dest"
- dest="$arg"
- continue
- fi
- case $arg in
- -d) isdir=yes ;;
- -f) prev="-f" ;;
- -g) prev="-g" ;;
- -m) prev="-m" ;;
- -o) prev="-o" ;;
- -s)
- stripme=" -s"
- continue
- # If the previous option needed an argument, then skip it.
- if test -n "$prev"; then
- prev=
- else
- dest="$arg"
- continue
- fi
- esac
- # Aesthetically quote the argument.
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog $arg"
- done
- if test -z "$install_prog"; then
- $echo "$modename: you must specify an install program" 1>&2
- $echo "$help" 1>&2
- exit 1
- fi
- $echo "$modename: the \`$prev' option requires an argument" 1>&2
- exit 1
- fi
- if test -z "$files"; then
- if test -z "$dest"; then
- $echo "$modename: no file or destination specified" 1>&2
- else
- $echo "$modename: you must specify a destination" 1>&2
- fi
- exit 1
- fi
- # Strip any trailing slash from the destination.
- dest=`$echo "X$dest" | $Xsed -e 's%/$%%'`
- # Check to see that the destination is a directory.
- test -d "$dest" && isdir=yes
- if test "$isdir" = yes; then
- destdir="$dest"
- destname=
- else
- destdir=`$echo "X$dest" | $Xsed -e 's%/[^/]*$%%'`
- test "X$destdir" = "X$dest" && destdir=.
- destname=`$echo "X$dest" | $Xsed -e 's%^.*/%%'`
- # Not a directory, so check to see that there is only one file specified.
- set dummy $files
- $echo "$modename: \`$dest' is not a directory" 1>&2
- exit 1
- fi
- fi
- case $destdir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- for file in $files; do
- case $file in
- *.lo) ;;
- $echo "$modename: \`$destdir' must be an absolute directory name" 1>&2
- exit 1
- esac
- done
- esac
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- staticlibs=
- future_libdirs=
- current_libdirs=
- # Do each installation.
- case $file in
- *.$libext)
- # Do the static libraries later.
- staticlibs="$staticlibs $file"
- *.la)
- if (sed -e '2q' $file | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- $echo "$modename: \`$file' is not a valid libtool archive" 1>&2
- exit 1
- fi
- library_names=
- old_library=
- relink_command=
- # If there is no directory component, then add one.
- case $file in
- */* | *\\*) . $file ;;
- *) . ./$file ;;
- esac
- # Add the libdir to current_libdirs if it is the destination.
- if test "X$destdir" = "X$libdir"; then
- case "$current_libdirs " in
- *" $libdir "*) ;;
- *) current_libdirs="$current_libdirs $libdir" ;;
- esac
- else
- # Note the libdir as a future libdir.
- case "$future_libdirs " in
- *" $libdir "*) ;;
- *) future_libdirs="$future_libdirs $libdir" ;;
- esac
- fi
- dir=`$echo "X$file" | $Xsed -e 's%/[^/]*$%%'`/
- test "X$dir" = "X$file/" && dir=
- dir="$dir$objdir"
- $echo "$modename: warning: relinking \`$file'" 1>&2
- $show "$relink_command"
- if $run eval "$relink_command"; then :
- else
- $echo "$modename: error: relink \`$file' with the above command before installing it" 1>&2
- continue
- fi
- fi
- # See the names of the shared library.
- if test -n "$2"; then
- realname="$2"
- shift
- shift
- srcname="$realname"
- test -n "$relink_command" && srcname="$realname"T
- # Install the shared library and build the symlinks.
- $show "$install_prog $dir/$srcname $destdir/$realname"
- $run eval "$install_prog $dir/$srcname $destdir/$realname" || exit $?
- if test -n "$stripme" && test -n "$striplib"; then
- $show "$striplib $destdir/$realname"
- $run eval "$striplib $destdir/$realname" || exit $?
- fi
- if test "$#" -gt 0; then
- # Delete the old symlinks, and create new ones.
- for linkname
- do
- if test "$linkname" != "$realname"; then
- $show "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- fi
- done
- fi
- # Do each command in the postinstall commands.
- lib="$destdir/$realname"
- eval cmds=\"$postinstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # Install the pseudo-library for information purposes.
- name=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- instname="$dir/$name"i
- $show "$install_prog $instname $destdir/$name"
- $run eval "$install_prog $instname $destdir/$name" || exit $?
- # Maybe install the static library, too.
- test -n "$old_library" && staticlibs="$staticlibs $dir/$old_library"
- *.lo)
- # Install (i.e. copy) a libtool object.
- # Figure out destination file name, if it wasn't already specified.
- if test -n "$destname"; then
- destfile="$destdir/$destname"
- else
- destfile=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- destfile="$destdir/$destfile"
- fi
- # Deduce the name of the destination old-style object file.
- case $destfile in
- *.lo)
- staticdest=`$echo "X$destfile" | $Xsed -e "$lo2o"`
- *.$objext)
- staticdest="$destfile"
- destfile=
- $echo "$modename: cannot copy a libtool object to \`$destfile'" 1>&2
- exit 1
- esac
- # Install the libtool object if requested.
- if test -n "$destfile"; then
- $show "$install_prog $file $destfile"
- $run eval "$install_prog $file $destfile" || exit $?
- fi
- # Install the old object if enabled.
- if test "$build_old_libs" = yes; then
- # Deduce the name of the old-style object file.
- staticobj=`$echo "X$file" | $Xsed -e "$lo2o"`
- $show "$install_prog $staticobj $staticdest"
- $run eval "$install_prog \$staticobj \$staticdest" || exit $?
- fi
- exit 0
- else
- fi
- # Do a test to see if this is really a libtool program.
- if (sed -e '4q' $file | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- notinst_deplibs=
- relink_command=
- case $file in
- *) . ./$file ;;
- esac
- # Check the variables that should have been set.
- if test -z "$notinst_deplibs"; then
- $echo "$modename: invalid libtool wrapper script \`$file'" 1>&2
- exit 1
- fi
- finalize=yes
- for lib in $notinst_deplibs; do
- # Check to see that each library is installed.
- libdir=
- if test -f "$lib"; then
- case $lib in
- */* | *\\*) . $lib ;;
- *) . ./$lib ;;
- esac
- fi
- libfile="$libdir/"`$echo "X$lib" | $Xsed -e 's%^.*/%%g'` ### testsuite: skip nested quoting test
- if test -n "$libdir" && test ! -f "$libfile"; then
- $echo "$modename: warning: \`$lib' has not been installed in \`$libdir'" 1>&2
- finalize=no
- fi
- done
- relink_command=
- case $file in
- *) . ./$file ;;
- esac
- outputname=
- if test "$fast_install" = no && test -n "$relink_command"; then
- if test "$finalize" = yes && test -z "$run"; then
- tmpdir="/tmp"
- test -n "$TMPDIR" && tmpdir="$TMPDIR"
- tmpdir=`mktemp -d $tmpdir/libtool-XXXXXX 2> /dev/null`
- if test $? = 0 ; then :
- else
- tmpdir="$tmpdir/libtool-$$"
- fi
- if $mkdir -p "$tmpdir" && chmod 700 "$tmpdir"; then :
- else
- $echo "$modename: error: cannot create temporary directory \`$tmpdir'" 1>&2
- continue
- fi
- file=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- outputname="$tmpdir/$file"
- relink_command=`$echo "X$relink_command" | $Xsed -e 's%@OUTPUT@%'"$outputname"'%g'`
- else
- ${rm}r "$tmpdir"
- continue
- fi
- file="$outputname"
- else
- $echo "$modename: warning: cannot relink \`$file'" 1>&2
- fi
- else
- # Install the binary that we compiled earlier.
- file=`$echo "X$file" | $Xsed -e "s%\([^/]*\)$%$objdir/\1%"`
- fi
- fi
- # remove .exe since cygwin /usr/bin/install will append another
- # one anyways
- case $install_prog,$host in
- /usr/bin/install*,*cygwin*)
- case $file:$destfile in
- *.exe:*.exe)
- # this is ok
- *.exe:*)
- destfile=$destfile.exe
- *:*.exe)
- destfile=`echo $destfile | sed -e 's,.exe$,,'`
- esac
- esac
- $show "$install_prog$stripme $file $destfile"
- $run eval "$install_prog\$stripme \$file \$destfile" || exit $?
- test -n "$outputname" && ${rm}r "$tmpdir"
- esac
- done
- for file in $staticlibs; do
- # Set up the ranlib parameters.
- oldlib="$destdir/$name"
- $show "$install_prog $file $oldlib"
- $run eval "$install_prog \$file \$oldlib" || exit $?
- $show "$old_striplib $oldlib"
- $run eval "$old_striplib $oldlib" || exit $?
- fi
- eval cmds=\"$old_postinstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- done
- if test -n "$future_libdirs"; then
- $echo "$modename: warning: remember to run \`$progname --finish$future_libdirs'" 1>&2
- fi
- if test -n "$current_libdirs"; then
- # Maybe just do a dry run.
- test -n "$run" && current_libdirs=" -n$current_libdirs"
- exec_cmd='$SHELL $0 --finish$current_libdirs'
- else
- exit 0
- fi
- # libtool finish mode
- finish)
- modename="$modename: finish"
- libdirs="$nonopt"
- admincmds=
- if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
- for dir
- do
- libdirs="$libdirs $dir"
- done
- for libdir in $libdirs; do
- if test -n "$finish_cmds"; then
- # Do each command in the finish commands.
- eval cmds=\"$finish_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || admincmds="$admincmds
- $cmd"
- done
- IFS="$save_ifs"
- fi
- if test -n "$finish_eval"; then
- # Do the single finish_eval.
- eval cmds=\"$finish_eval\"
- $run eval "$cmds" || admincmds="$admincmds
- $cmds"
- fi
- done
- fi
- # Exit here if they wanted silent mode.
- test "$show" = : && exit 0
- echo "----------------------------------------------------------------------"
- echo "Libraries have been installed in:"
- echo " $libdir"
- done
- echo
- echo "If you ever happen to want to link against installed libraries"
- echo "in a given directory, LIBDIR, you must either use libtool, and"
- echo "specify the full pathname of the library, or use the \`-LLIBDIR'"
- echo "flag during linking and do at least one of the following:"
- if test -n "$shlibpath_var"; then
- echo " - add LIBDIR to the \`$shlibpath_var' environment variable"
- echo " during execution"
- fi
- echo " - add LIBDIR to the \`$runpath_var' environment variable"
- echo " during linking"
- fi
- libdir=LIBDIR
- echo " - use the \`$flag' linker flag"
- fi
- if test -n "$admincmds"; then
- echo " - have your system administrator run these commands:$admincmds"
- fi
- if test -f /etc/ld.so.conf; then
- echo " - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
- fi
- echo
- echo "See any operating system documentation about shared libraries for"
- echo "more information, such as the ld(1) and ld.so(8) manual pages."
- exit 0
- # libtool execute mode
- execute)
- modename="$modename: execute"
- # The first argument is the command name.
- cmd="$nonopt"
- if test -z "$cmd"; then
- $echo "$modename: you must specify a COMMAND" 1>&2
- $echo "$help"
- exit 1
- fi
- # Handle -dlopen flags immediately.
- for file in $execute_dlfiles; do
- if test ! -f "$file"; then
- $echo "$modename: \`$file' is not a file" 1>&2
- exit 1
- fi
- dir=
- case $file in
- *.la)
- # Check to see that this really is a libtool archive.
- else
- $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- # Read the libtool library.
- dlname=
- library_names=
- case $file in
- *) . ./$file ;;
- esac
- # Skip this library if it cannot be dlopened.
- if test -z "$dlname"; then
- # Warn if it was a shared library.
- test -n "$library_names" && $echo "$modename: warning: \`$file' was not linked with \`-export-dynamic'"
- continue
- fi
- test "X$dir" = "X$file" && dir=.
- if test -f "$dir/$objdir/$dlname"; then
- dir="$dir/$objdir"
- else
- $echo "$modename: cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'" 1>&2
- exit 1
- fi
- *.lo)
- # Just add the directory containing the .lo file.
- $echo "$modename: warning \`-dlopen' is ignored for non-libtool libraries and objects" 1>&2
- continue
- esac
- # Get the absolute pathname.
- absdir=`cd "$dir" && pwd`
- test -n "$absdir" && dir="$absdir"
- # Now add the directory to shlibpath_var.
- if eval "test -z \"\$$shlibpath_var\""; then
- eval "$shlibpath_var=\"\$dir\""
- else
- eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
- fi
- done
- # This variable tells wrapper scripts just to set shlibpath_var
- # rather than running their programs.
- libtool_execute_magic="$magic"
- # Check if any of the arguments is a wrapper script.
- args=
- for file
- do
- case $file in
- case $file in
- *) . ./$file ;;
- esac
- # Transform arg to wrapped name.
- file="$progdir/$program"
- fi
- esac
- # Quote arguments (to preserve shell metacharacters).
- file=`$echo "X$file" | $Xsed -e "$sed_quote_subst"`
- args="$args \"$file\""
- done
- # Export the shlibpath_var.
- eval "export $shlibpath_var"
- fi
- # Restore saved enviroment variables
- if test "${save_LC_ALL+set}" = set; then
- LC_ALL="$save_LC_ALL"; export LC_ALL
- fi
- if test "${save_LANG+set}" = set; then
- LANG="$save_LANG"; export LANG
- fi
- # Now prepare to actually exec the command.
- exec_cmd="\$cmd$args"
- else
- # Display what would be done.
- eval "\$echo \"\$shlibpath_var=\$$shlibpath_var\""
- $echo "export $shlibpath_var"
- fi
- $echo "$cmd$args"
- exit 0
- fi
- # libtool clean and uninstall mode
- clean | uninstall)
- modename="$modename: $mode"
- rm="$nonopt"
- files=
- rmforce=
- exit_status=0
- for arg
- do
- case $arg in
- -f) rm="$rm $arg"; rmforce=yes ;;
- -*) rm="$rm $arg" ;;
- *) files="$files $arg" ;;
- esac
- done
- if test -z "$rm"; then
- $echo "$modename: you must specify an RM program" 1>&2
- exit 1
- fi
- rmdirs=
- if test "X$dir" = "X$file"; then
- dir=.
- objdir="$objdir"
- else
- objdir="$dir/$objdir"
- fi
- test "$mode" = uninstall && objdir="$dir"
- # Remember objdir for removal later, being careful to avoid duplicates
- if test "$mode" = clean; then
- case " $rmdirs " in
- *" $objdir "*) ;;
- *) rmdirs="$rmdirs $objdir" ;;
- esac
- fi
- # Don't error if the file doesn't exist and rm -f was used.
- if (test -L "$file") >/dev/null 2>&1 \
- || (test -h "$file") >/dev/null 2>&1 \
- || test -f "$file"; then
- elif test -d "$file"; then
- exit_status=1
- continue
- elif test "$rmforce" = yes; then
- continue
- fi
- rmfiles="$file"
- case $name in
- *.la)
- # Possibly a libtool archive, so verify it.
- . $dir/$name
- # Delete the libtool libraries and symlinks.
- for n in $library_names; do
- rmfiles="$rmfiles $objdir/$n"
- done
- test -n "$old_library" && rmfiles="$rmfiles $objdir/$old_library"
- test "$mode" = clean && rmfiles="$rmfiles $objdir/$name $objdir/${name}i"
- if test "$mode" = uninstall; then
- if test -n "$library_names"; then
- # Do each command in the postuninstall commands.
- eval cmds=\"$postuninstall_cmds\"
- save_ifs="$IFS"; IFS='~'
- for cmd in $cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd"
- if test "$?" -ne 0 && test "$rmforce" != yes; then
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- if test -n "$old_library"; then
- # Do each command in the old_postuninstall commands.
- eval cmds=\"$old_postuninstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd"
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- # FIXME: should reinstall the best remaining shared library.
- fi
- fi
- *.lo)
- oldobj=`$echo "X$name" | $Xsed -e "$lo2o"`
- rmfiles="$rmfiles $dir/$oldobj"
- fi
- # Do a test to see if this is a libtool program.
- if test "$mode" = clean &&
- (sed -e '4q' $file | egrep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- relink_command=
- . $dir/$file
- rmfiles="$rmfiles $objdir/$name $objdir/${name}S.${objext}"
- if test "$fast_install" = yes && test -n "$relink_command"; then
- rmfiles="$rmfiles $objdir/lt-$name"
- fi
- fi
- esac
- $show "$rm $rmfiles"
- $run $rm $rmfiles || exit_status=1
- done
- # Try to remove the ${objdir}s in the directories where we deleted files
- for dir in $rmdirs; do
- if test -d "$dir"; then
- $show "rmdir $dir"
- $run rmdir $dir >/dev/null 2>&1
- fi
- done
- exit $exit_status
- $echo "$modename: you must specify a MODE" 1>&2
- $echo "$generic_help" 1>&2
- exit 1
- esac
- if test -z "$exec_cmd"; then
- $echo "$modename: invalid operation mode \`$mode'" 1>&2
- exit 1
- fi
-fi # test -z "$show_help"
-if test -n "$exec_cmd"; then
- eval exec $exec_cmd
- exit 1
-fi
-# We need to display help for each of the modes.
-case $mode in
-"") $echo \
-"Usage: $modename [OPTION]... [MODE-ARG]...
-Provide generalized library-building support services.
- --config show all configuration variables
- --debug enable verbose shell tracing
--n, --dry-run display commands without modifying any files
- --features display basic configuration information and exit
- --finish same as \`--mode=finish'
- --help display this help message and exit
- --mode=MODE use operation mode MODE [default=inferred from MODE-ARGS]
- --quiet same as \`--silent'
- --silent don't print informational messages
- --version print version information
-MODE must be one of the following:
- clean remove files from the build directory
- compile compile a source file into a libtool object
- execute automatically set library path, then run a program
- finish complete the installation of libtool libraries
- install install libraries or executables
- link create a library or an executable
- uninstall remove libraries from an installed directory
-MODE-ARGS vary depending on the MODE. Try \`$modename --help --mode=MODE' for
-a more detailed description of MODE."
- exit 0
-clean)
- $echo \
-"Usage: $modename [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
-Remove files from the build directory.
-RM is the name of the program to use to delete files associated with each FILE
-(typically \`/bin/rm'). RM-OPTIONS are options (such as \`-f') to be passed
-to RM.
-If FILE is a libtool library, object or program, all the files associated
-with it are deleted. Otherwise, only FILE itself is deleted using RM."
-compile)
- $echo \
-"Usage: $modename [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
-Compile a source file into a libtool library object.
-This mode accepts the following additional options:
- -o OUTPUT-FILE set the output file name to OUTPUT-FILE
- -prefer-pic try to building PIC objects only
- -prefer-non-pic try to building non-PIC objects only
- -static always build a \`.o' file suitable for static linking
-COMPILE-COMMAND is a command to be used in creating a \`standard' object file
-from the given SOURCEFILE.
-The output file name is determined by removing the directory component from
-SOURCEFILE, then substituting the C source code suffix \`.c' with the
-library object suffix, \`.lo'."
-execute)
- $echo \
-"Usage: $modename [OPTION]... --mode=execute COMMAND [ARGS]...
-Automatically set library path, then run a program.
- -dlopen FILE add the directory containing FILE to the library path
-This mode sets the library path environment variable according to \`-dlopen'
-flags.
-If any of the ARGS are libtool executable wrappers, then they are translated
-into their corresponding uninstalled binary, and any of their required library
-directories are added to the library path.
-Then, COMMAND is executed, with ARGS as arguments."
-finish)
- $echo \
-"Usage: $modename [OPTION]... --mode=finish [LIBDIR]...
-Complete the installation of libtool libraries.
-Each LIBDIR is a directory that contains libtool libraries.
-The commands that this mode executes may require superuser privileges. Use
-the \`--dry-run' option if you just want to see what would be executed."
-install)
- $echo \
-"Usage: $modename [OPTION]... --mode=install INSTALL-COMMAND...
-Install executables or libraries.
-INSTALL-COMMAND is the installation command. The first component should be
-either the \`install' or \`cp' program.
-The rest of the components are interpreted as arguments to that command (only
-BSD-compatible install options are recognized)."
-link)
- $echo \
-"Usage: $modename [OPTION]... --mode=link LINK-COMMAND...
-Link object files or libraries together to form another library, or to
-create an executable program.
-LINK-COMMAND is a command using the C compiler that you would use to create
-a program from several object files.
-The following components of LINK-COMMAND are treated specially:
- -all-static do not do any dynamic linking at all
- -avoid-version do not add a version suffix if possible
- -dlopen FILE \`-dlpreopen' FILE if it cannot be dlopened at runtime
- -dlpreopen FILE link in FILE and add its symbols to lt_preloaded_symbols
- -export-dynamic allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
- -export-symbols SYMFILE
- try to export only the symbols listed in SYMFILE
- -export-symbols-regex REGEX
- try to export only the symbols matching REGEX
- -LLIBDIR search LIBDIR for required installed libraries
- -lNAME OUTPUT-FILE requires the installed library libNAME
- -module build a library that can dlopened
- -no-fast-install disable the fast-install mode
- -no-install link a not-installable executable
- -no-undefined declare that a library does not refer to external symbols
- -o OUTPUT-FILE create OUTPUT-FILE from the specified objects
- -release RELEASE specify package release information
- -rpath LIBDIR the created library will eventually be installed in LIBDIR
- -R[ ]LIBDIR add LIBDIR to the runtime path of programs and libraries
- -static do not do any dynamic linking of libtool libraries
- -version-info CURRENT[:REVISION[:AGE]]
- specify library version info [each variable defaults to 0]
-All other options (arguments beginning with \`-') are ignored.
-Every other argument is treated as a filename. Files ending in \`.la' are
-treated as uninstalled libtool libraries, other files are standard or library
-object files.
-If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
-only library objects (\`.lo' files) may be specified, and \`-rpath' is
-required, except when creating a convenience library.
-If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
-using \`ar' and \`ranlib', or on Windows using \`lib'.
-If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
-is created, otherwise an executable program is created."
-uninstall)
- $echo \
-"Usage: $modename [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
-Remove libraries from an installation directory.
-to RM.
-If FILE is a libtool library, all the files associated with it are deleted.
-Otherwise, only FILE itself is deleted using RM."
- exit 1
-esac
-echo
-$echo "Try \`$modename --help' for more information about other modes."
-exit 0
-# Local Variables:
-# mode:shell-script
-# sh-indentation:2
-# End:
Deleted: mpich2/trunk/confdb/ltmain.sh
--- mpich2/trunk/confdb/ltmain.sh 2009-03-20 16:22:43 UTC (rev 4145)
+++ mpich2/trunk/confdb/ltmain.sh 2009-03-20 17:00:18 UTC (rev 4146)
@@ -1,6426 +0,0 @@
-# ltmain.sh - Provide generalized library-building support services.
-# NOTE: Changing this file will not affect anything until you rerun configure.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004
-# Free Software Foundation, Inc.
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-basename="s,^.*/,,g"
-# Work around backward compatibility issue on IRIX 6.5. On IRIX 6.4+, sh
-# is ksh but when the shell is invoked as "sh" and the current value of
-# the _XPG environment variable is not equal to 1 (one), the special
-# positional parameter $0, within a function call, is the name of the
-# function.
-progpath="$0"
-# The name of this program:
-progname=`echo "$progpath" | $SED $basename`
-modename="$progname"
-# Global variables:
-EXIT_SUCCESS=0
-EXIT_FAILURE=1
-PROGRAM=ltmain.sh
-PACKAGE=libtool
-VERSION=1.5.6
-TIMESTAMP=" (1.1220.2.95 2004/04/11 05:50:42) Debian$Rev: 224 $"
-# Check that we have a working $echo.
-if test "X$1" = X--no-reexec; then
- shift
-elif test "X$1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell, and then maybe $echo will work.
- exec $SHELL "$progpath" --no-reexec ${1+"$@"}
-fi
-if test "X$1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit $EXIT_SUCCESS
-fi
-default_mode=
-help="Try \`$progname --help' for more information."
-magic="%%%MAGIC variable%%%"
-mkdir="mkdir"
-mv="mv -f"
-rm="rm -f"
-Xsed="${SED}"' -e 1s/^X//'
-sed_quote_subst='s/\([\\`\\"$\\\\]\)/\\\1/g'
-# test EBCDIC or ASCII
-case `echo A|tr A '\301'` in
- A) # EBCDIC based system
- SP2NL="tr '\100' '\n'"
- NL2SP="tr '\r\n' '\100\100'"
- *) # Assume ASCII based system
- SP2NL="tr '\040' '\012'"
- NL2SP="tr '\015\012' '\040\040'"
-esac
-# NLS nuisances.
-# Only set LANG and LC_ALL to C if already set.
-# These must not be set unconditionally because not all systems understand
-# e.g. LANG=C (notably SCO).
-# We save the old values to restore during execute mode.
-if test "${LC_ALL+set}" = set; then
- save_LC_ALL="$LC_ALL"; LC_ALL=C; export LC_ALL
-fi
-if test "${LANG+set}" = set; then
- save_LANG="$LANG"; LANG=C; export LANG
-fi
-# Make sure IFS has a sensible default
-: ${IFS="
-if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
- $echo "$modename: not configured to build any kind of library" 1>&2
- $echo "Fatal configuration error. See the $PACKAGE docs for more information." 1>&2
- exit $EXIT_FAILURE
-fi
-# Global variables.
-mode=$default_mode
-nonopt=
-prev=
-prevopt=
-run=
-show="$echo"
-show_help=
-execute_dlfiles=
-lo2o="s/\\.lo\$/.${objext}/"
-o2lo="s/\\.${objext}\$/.lo/"
-# Shell function definitions:
-# This seems to be the best place for them
-# func_win32_libid arg
-# return the library type of file 'arg'
-# Need a lot of goo to handle *both* DLLs and import libs
-# Has to be a shell function in order to 'eat' the argument
-# that is supplied when $file_magic_command is called.
-func_win32_libid () {
- win32_libid_type="unknown"
- win32_fileres=`file -L $1 2>/dev/null`
- case $win32_fileres in
- *ar\ archive\ import\ library*) # definitely import
- win32_libid_type="x86 archive import"
- *ar\ archive*) # could be an import, or static
- if eval $OBJDUMP -f $1 | $SED -e '10q' 2>/dev/null | \
- $EGREP -e 'file format pe-i386(.*architecture: i386)?' >/dev/null ; then
- win32_nmres=`eval $NM -f posix -A $1 | \
- sed -n -e '1,100{/ I /{x;/import/!{s/^/import/;h;p;};x;};}'`
- if test "X$win32_nmres" = "Ximport" ; then
- else
- win32_libid_type="x86 archive static"
- fi
- fi
- *DLL*)
- win32_libid_type="x86 DLL"
- *executable*) # but shell scripts are "executable" too...
- *MS\ Windows\ PE\ Intel*)
- esac
- esac
- $echo $win32_libid_type
-# func_infer_tag arg
-# Infer tagged configuration to use if any are available and
-# if one wasn't chosen via the "--tag" command line option.
-# Only attempt this if the compiler in the base compile
-# command doesn't match the default compiler.
-# arg is usually of the form 'gcc ...'
-func_infer_tag () {
- if test -n "$available_tags" && test -z "$tagname"; then
- CC_quoted=
- for arg in $CC; do
- case $arg in
- arg="\"$arg\""
- esac
- CC_quoted="$CC_quoted $arg"
- done
- case $@ in
- # Blanks in the command may have been stripped by the calling shell,
- # but not from the CC environment variable when configure was run.
- " $CC "* | "$CC "* | " `$echo $CC` "* | "`$echo $CC` "* | " $CC_quoted"* | "$CC_quoted "* | " `$echo $CC_quoted` "* | "`$echo $CC_quoted` "*) ;;
- # Blanks at the start of $base_compile will cause this to fail
- # if we don't check for them as well.
- for z in $available_tags; do
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $z$" < "$progpath" > /dev/null; then
- # Evaluate the configuration.
- eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$z'$/,/^# ### END LIBTOOL TAG CONFIG: '$z'$/p' < $progpath`"
- CC_quoted=
- # Double-quote args containing other shell metacharacters.
- case $arg in
- arg="\"$arg\""
- esac
- done
- case "$@ " in
- # The compiler in the base compile command matches
- # the one in the tagged configuration.
- # Assume this is the tagged configuration we want.
- tagname=$z
- break
- esac
- fi
- done
- # If $tagname still isn't set, then no tagged configuration
- # was found and let the user know that the "--tag" command
- # line option must be used.
- if test -z "$tagname"; then
- $echo "$modename: unable to infer tagged configuration"
- $echo "$modename: specify a tag with \`--tag'" 1>&2
-# else
-# $echo "$modename: using $tagname tagged configuration"
- fi
- esac
- fi
-# End of Shell function definitions
-# Darwin sucks
-eval std_shrext=\"$shrext_cmds\"
-# Parse our command line options once, thoroughly.
-while test "$#" -gt 0
-do
- arg="$1"
- shift
- case $arg in
- -*=*) optarg=`$echo "X$arg" | $Xsed -e 's/[-_a-zA-Z0-9]*=//'` ;;
- *) optarg= ;;
- esac
- # If the previous option needs an argument, assign it.
- case $prev in
- execute_dlfiles)
- execute_dlfiles="$execute_dlfiles $arg"
- tag)
- tagname="$arg"
- preserve_args="${preserve_args}=$arg"
- # Check whether tagname contains only valid characters
- case $tagname in
- *[!-_A-Za-z0-9,/]*)
- $echo "$progname: invalid tag name: $tagname" 1>&2
- esac
- case $tagname in
- CC)
- # Don't test for the "default" C tag, as we know, it's there, but
- # not specially marked.
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "$progpath" > /dev/null; then
- taglist="$taglist $tagname"
- eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$tagname'$/,/^# ### END LIBTOOL TAG CONFIG: '$tagname'$/p' < $progpath`"
- else
- $echo "$progname: ignoring unknown tag $tagname" 1>&2
- fi
- esac
- eval "$prev=\$arg"
- esac
- prev=
- prevopt=
- continue
- fi
- # Have we seen a non-optional argument yet?
- case $arg in
- --help)
- show_help=yes
- --version)
- $echo "$PROGRAM (GNU $PACKAGE) $VERSION$TIMESTAMP"
- $echo
- $echo "Copyright (C) 2003 Free Software Foundation, Inc."
- $echo "This is free software; see the source for copying conditions. There is NO"
- $echo "warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
- --config)
- ${SED} -e '1,/^# ### BEGIN LIBTOOL CONFIG/d' -e '/^# ### END LIBTOOL CONFIG/,$d' $progpath
- # Now print the configurations for the tags.
- for tagname in $taglist; do
- ${SED} -n -e "/^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$/,/^# ### END LIBTOOL TAG CONFIG: $tagname$/p" < "$progpath"
- done
- --debug)
- $echo "$progname: enabling shell trace mode"
- set -x
- preserve_args="$preserve_args $arg"
- --dry-run | -n)
- run=:
- --features)
- $echo "host: $host"
- if test "$build_libtool_libs" = yes; then
- $echo "enable shared libraries"
- else
- $echo "disable shared libraries"
- fi
- $echo "enable static libraries"
- else
- $echo "disable static libraries"
- fi
- --finish) mode="finish" ;;
- --mode) prevopt="--mode" prev=mode ;;
- --mode=*) mode="$optarg" ;;
- --preserve-dup-deps) duplicate_deps="yes" ;;
- --quiet | --silent)
- show=:
- --tag) prevopt="--tag" prev=tag ;;
- --tag=*)
- set tag "$optarg" ${1+"$@"}
- shift
- prev=tag
- preserve_args="$preserve_args --tag"
- -dlopen)
- prevopt="-dlopen"
- prev=execute_dlfiles
- $echo "$modename: unrecognized option \`$arg'" 1>&2
- nonopt="$arg"
- break
- esac
-done
-if test -n "$prevopt"; then
- $echo "$modename: option \`$prevopt' requires an argument" 1>&2
-fi
-# If this variable is set in any of the actions, the command in it
-# will be execed at the end. This prevents here-documents from being
-# left over by shells.
-exec_cmd=
-if test -z "$show_help"; then
- # Infer the operation mode.
- if test -z "$mode"; then
- $echo "*** Warning: inferring the mode of operation is deprecated." 1>&2
- $echo "*** Future versions of Libtool will require -mode=MODE be specified." 1>&2
- case $nonopt in
- *cc | cc* | *++ | gcc* | *-gcc* | g++* | xlc*)
- mode=link
- for arg
- do
- case $arg in
- -c)
- mode=compile
- break
- esac
- done
- *db | *dbx | *strace | *truss)
- mode=execute
- *install*|cp|mv)
- mode=install
- *rm)
- mode=uninstall
- # If we have no mode, but dlfiles were specified, then do execute mode.
- test -n "$execute_dlfiles" && mode=execute
- # Just use the default operation mode.
- if test -n "$nonopt"; then
- $echo "$modename: warning: cannot infer operation mode from \`$nonopt'" 1>&2
- else
- $echo "$modename: warning: cannot infer operation mode without MODE-ARGS" 1>&2
- fi
- fi
- esac
- fi
- # Only execute mode is allowed to have -dlopen flags.
- if test -n "$execute_dlfiles" && test "$mode" != execute; then
- $echo "$modename: unrecognized option \`-dlopen'" 1>&2
- fi
- # Change the help message to a mode-specific one.
- generic_help="$help"
- help="Try \`$modename --help --mode=$mode' for more information."
- # These modes are in order of execution frequency so that they run quickly.
- case $mode in
- # libtool compile mode
- compile)
- modename="$modename: compile"
- # Get the compilation command and the source file.
- base_compile=
- srcfile="$nonopt" # always keep a non-empty value in "srcfile"
- suppress_opt=yes
- suppress_output=
- arg_mode=normal
- libobj=
- later=
- for arg
- do
- case "$arg_mode" in
- arg )
- # do not "continue". Instead, add this to base_compile
- lastarg="$arg"
- arg_mode=normal
- target )
- libobj="$arg"
- arg_mode=normal
- continue
- normal )
- # Accept any command-line options.
- case $arg in
- -o)
- if test -n "$libobj" ; then
- $echo "$modename: you cannot specify \`-o' more than once" 1>&2
- fi
- arg_mode=target
- continue
- -static | -prefer-pic | -prefer-non-pic)
- later="$later $arg"
- continue
- -no-suppress)
- suppress_opt=no
- continue
- -Xcompiler)
- arg_mode=arg # the next one goes into the "base_compile" arg list
- continue # The current "srcfile" will either be retained or
- ;; # replaced later. I would guess that would be a bug.
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "s/^-Wc,//"`
- lastarg=
- save_ifs="$IFS"; IFS=','
- for arg in $args; do
- IFS="$save_ifs"
- # Many Bourne shells cannot handle close brackets correctly
- # in scan sets, so we specify it separately.
- case $arg in
- arg="\"$arg\""
- esac
- lastarg="$lastarg $arg"
- done
- IFS="$save_ifs"
- lastarg=`$echo "X$lastarg" | $Xsed -e "s/^ //"`
- # Add the arguments to base_compile.
- base_compile="$base_compile $lastarg"
- continue
- # Accept the current argument as the source file.
- # The previous "srcfile" becomes the current argument.
- lastarg="$srcfile"
- srcfile="$arg"
- esac # case $arg
- esac # case $arg_mode
- # Aesthetically quote the previous argument.
- lastarg=`$echo "X$lastarg" | $Xsed -e "$sed_quote_subst"`
- case $lastarg in
- lastarg="\"$lastarg\""
- esac
- done # for arg
- case $arg_mode in
- arg)
- $echo "$modename: you must specify an argument for -Xcompile"
- target)
- $echo "$modename: you must specify a target with \`-o'" 1>&2
- # Get the name of the library object.
- [ -z "$libobj" ] && libobj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%'`
- esac
- # Recognize several different file suffixes.
- # If the user specifies -o file.o, it is replaced with file.lo
- xform='[cCFSifmso]'
- case $libobj in
- *.ada) xform=ada ;;
- *.adb) xform=adb ;;
- *.ads) xform=ads ;;
- *.asm) xform=asm ;;
- *.c++) xform=c++ ;;
- *.cc) xform=cc ;;
- *.ii) xform=ii ;;
- *.class) xform=class ;;
- *.cpp) xform=cpp ;;
- *.cxx) xform=cxx ;;
- *.f90) xform=f90 ;;
- *.for) xform=for ;;
- *.java) xform=java ;;
- esac
- libobj=`$echo "X$libobj" | $Xsed -e "s/\.$xform$/.lo/"`
- case $libobj in
- *.lo) obj=`$echo "X$libobj" | $Xsed -e "$lo2o"` ;;
- $echo "$modename: cannot determine name of library object from \`$libobj'" 1>&2
- esac
- func_infer_tag $base_compile
- for arg in $later; do
- case $arg in
- -static)
- build_old_libs=yes
- continue
- -prefer-pic)
- pic_mode=yes
- continue
- -prefer-non-pic)
- pic_mode=no
- continue
- esac
- done
- objname=`$echo "X$obj" | $Xsed -e 's%^.*/%%'`
- xdir=`$echo "X$obj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$obj"; then
- xdir=
- else
- xdir=$xdir/
- fi
- lobj=${xdir}$objdir/$objname
- if test -z "$base_compile"; then
- $echo "$modename: you must specify a compilation command" 1>&2
- fi
- # Delete any leftover library objects.
- removelist="$obj $lobj $libobj ${libobj}T"
- else
- removelist="$lobj $libobj ${libobj}T"
- fi
- $run $rm $removelist
- trap "$run $rm $removelist; exit $EXIT_FAILURE" 1 2 15
- # On Cygwin there's no "real" PIC flag so we must build both object types
- case $host_os in
- cygwin* | mingw* | pw32* | os2*)
- pic_mode=default
- esac
- if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
- # non-PIC code in shared libraries is not supported
- pic_mode=default
- fi
- # Calculate the filename of the output object if compiler does
- # not support -o with -c
- if test "$compiler_c_o" = no; then
- output_obj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%' -e 's%\.[^.]*$%%'`.${objext}
- lockfile="$output_obj.lock"
- removelist="$removelist $output_obj $lockfile"
- else
- output_obj=
- need_locks=no
- lockfile=
- fi
- # Lock this critical section if it is needed
- # We use this script file to make the link, it avoids creating a new file
- if test "$need_locks" = yes; then
- until $run ln "$progpath" "$lockfile" 2>/dev/null; do
- $show "Waiting for $lockfile to be removed"
- sleep 2
- done
- elif test "$need_locks" = warn; then
- if test -f "$lockfile"; then
- $echo "\
-*** ERROR, $lockfile exists and contains:
-`cat $lockfile 2>/dev/null`
-This indicates that another process is trying to use the same
-temporary object file, and libtool could not work around it because
-your compiler does not support \`-c' and \`-o' together. If you
-repeat this compilation, it may succeed, by chance, but you had better
-avoid parallel builds (make -j) in this platform, or get a better
-compiler."
- fi
- $echo $srcfile > "$lockfile"
- fi
- if test -n "$fix_srcfile_path"; then
- eval srcfile=\"$fix_srcfile_path\"
- fi
- $run $rm "$libobj" "${libobj}T"
- # Create a libtool object file (analogous to a ".la" file),
- # but don't create it if we're doing a dry run.
- test -z "$run" && cat > ${libobj}T <<EOF
-# $libobj - a libtool object file
-# Name of the PIC object.
-EOF
- # Only build a PIC object if we are building libtool libraries.
- # Without this assignment, base_compile gets emptied.
- fbsd_hideous_sh_bug=$base_compile
- if test "$pic_mode" != no; then
- command="$base_compile $srcfile $pic_flag"
- else
- # Don't build PIC code
- command="$base_compile $srcfile"
- fi
- if test ! -d "${xdir}$objdir"; then
- $show "$mkdir ${xdir}$objdir"
- $run $mkdir ${xdir}$objdir
- status=$?
- if test "$status" -ne 0 && test ! -d "${xdir}$objdir"; then
- exit $status
- fi
- fi
- if test -z "$output_obj"; then
- # Place PIC objects in $objdir
- command="$command -o $lobj"
- fi
- $run $rm "$lobj" "$output_obj"
- $show "$command"
- if $run eval "$command"; then :
- else
- test -n "$output_obj" && $run $rm $removelist
- fi
- if test "$need_locks" = warn &&
- test "X`cat $lockfile 2>/dev/null`" != "X$srcfile"; then
- $echo "\
-*** ERROR, $lockfile contains:
-but it should contain:
-$srcfile
-compiler."
- fi
- # Just move the object if needed, then go on to compile the next one
- if test -n "$output_obj" && test "X$output_obj" != "X$lobj"; then
- $show "$mv $output_obj $lobj"
- if $run $mv $output_obj $lobj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # Append the name of the PIC object to the libtool object file.
- test -z "$run" && cat >> ${libobj}T <<EOF
-pic_object='$objdir/$objname'
-EOF
- # Allow error messages only from the first compilation.
- if test "$suppress_opt" = yes; then
- suppress_output=' >/dev/null 2>&1'
- fi
- else
- # No PIC object so indicate it doesn't exist in the libtool
- # object file.
-pic_object=none
-EOF
- fi
- # Only build a position-dependent object if we build old libraries.
- if test "$pic_mode" != yes; then
- else
- fi
- if test "$compiler_c_o" = yes; then
- command="$command -o $obj"
- fi
- # Suppress compiler output if we already did a PIC compilation.
- command="$command$suppress_output"
- $run $rm "$obj" "$output_obj"
- $show "$command"
- else
- fi
- $echo "\
-$srcfile
-compiler."
- fi
- if test -n "$output_obj" && test "X$output_obj" != "X$obj"; then
- $show "$mv $output_obj $obj"
- if $run $mv $output_obj $obj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # Append the name of the non-PIC object the libtool object file.
- # Only append if the libtool object file exists.
-# Name of the non-PIC object.
-non_pic_object='$objname'
-EOF
- else
-non_pic_object=none
-EOF
- fi
- $run $mv "${libobj}T" "${libobj}"
- # Unlock the critical section if it was locked
- if test "$need_locks" != no; then
- $run $rm "$lockfile"
- fi
- # libtool link mode
- link | relink)
- modename="$modename: link"
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
- # It is impossible to link a dll without this setting, and
- # we shouldn't force the makefile maintainer to figure out
- # which system we are compiling for in order to pass an extra
- # flag for every libtool invocation.
- # allow_undefined=no
- # FIXME: Unfortunately, there are problems with the above when trying
- # to make a dll which has undefined symbols, in which case not
- # even a static library is built. For now, we need to specify
- # -no-undefined on the libtool link line when we can be certain
- # that all symbols are satisfied, otherwise we get a static library.
- allow_undefined=yes
- esac
- libtool_args="$nonopt"
- base_compile="$nonopt $@"
- compile_command="$nonopt"
- finalize_command="$nonopt"
- compile_rpath=
- finalize_rpath=
- compile_shlibpath=
- finalize_shlibpath=
- convenience=
- old_convenience=
- deplibs=
- old_deplibs=
- compiler_flags=
- linker_flags=
- dllsearchpath=
- lib_search_path=`pwd`
- inst_prefix_dir=
- avoid_version=no
- dlfiles=
- dlprefiles=
- dlself=no
- export_dynamic=no
- export_symbols=
- export_symbols_regex=
- generated=
- libobjs=
- ltlibs=
- module=no
- no_install=no
- objs=
- non_pic_objects=
- precious_files_regex=
- prefer_static_libs=no
- preload=no
- prev=
- prevarg=
- release=
- rpath=
- xrpath=
- perm_rpath=
- temp_rpath=
- thread_safe=no
- vinfo=
- vinfo_number=no
- # We need to know -static, to get the right output filenames.
- for arg
- do
- case $arg in
- -all-static | -static)
- if test "X$arg" = "X-all-static"; then
- if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
- $echo "$modename: warning: complete static linking is impossible in this configuration" 1>&2
- fi
- if test -n "$link_static_flag"; then
- dlopen_self=$dlopen_self_static
- fi
- else
- if test -z "$pic_flag" && test -n "$link_static_flag"; then
- fi
- fi
- prefer_static_libs=yes
- break
- esac
- done
- # See if our shared archives depend on static archives.
- test -n "$old_archive_from_new_cmds" && build_old_libs=yes
- # Go through the arguments, transforming them on the way.
- while test "$#" -gt 0; do
- arg="$1"
- shift
- case $arg in
- qarg=\"`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`\" ### testsuite: skip nested quoting test
- *) qarg=$arg ;;
- esac
- libtool_args="$libtool_args $qarg"
- case $prev in
- output)
- compile_command="$compile_command @OUTPUT@"
- finalize_command="$finalize_command @OUTPUT@"
- esac
- case $prev in
- dlfiles|dlprefiles)
- if test "$preload" = no; then
- # Add the symbol object into the linking commands.
- compile_command="$compile_command @SYMFILE@"
- finalize_command="$finalize_command @SYMFILE@"
- preload=yes
- fi
- case $arg in
- *.la | *.lo) ;; # We handle these cases below.
- force)
- if test "$dlself" = no; then
- dlself=needless
- export_dynamic=yes
- fi
- prev=
- continue
- self)
- if test "$prev" = dlprefiles; then
- dlself=yes
- elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
- dlself=yes
- else
- dlself=needless
- fi
- prev=
- continue
- if test "$prev" = dlfiles; then
- dlfiles="$dlfiles $arg"
- else
- dlprefiles="$dlprefiles $arg"
- fi
- prev=
- continue
- esac
- expsyms)
- export_symbols="$arg"
- if test ! -f "$arg"; then
- $echo "$modename: symbol file \`$arg' does not exist"
- fi
- prev=
- continue
- expsyms_regex)
- export_symbols_regex="$arg"
- prev=
- continue
- inst_prefix)
- inst_prefix_dir="$arg"
- prev=
- continue
- precious_regex)
- precious_files_regex="$arg"
- prev=
- continue
- release)
- release="-$arg"
- prev=
- continue
- objectlist)
- if test -f "$arg"; then
- save_arg=$arg
- moreargs=
- for fil in `cat $save_arg`
- do
-# moreargs="$moreargs $fil"
- arg=$fil
- # A libtool-controlled object.
- # Check to see that this really is a libtool object.
- if (${SED} -e '2q' $arg | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- pic_object=
- non_pic_object=
- # Read the .lo file
- case $arg in
- */* | *\\*) . $arg ;;
- *) . ./$arg ;;
- esac
- if test -z "$pic_object" || \
- test -z "$non_pic_object" ||
- test "$pic_object" = none && \
- test "$non_pic_object" = none; then
- $echo "$modename: cannot find name of object for \`$arg'" 1>&2
- fi
- # Extract subdirectory from the argument.
- xdir=`$echo "X$arg" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$arg"; then
- xdir=
- else
- xdir="$xdir/"
- fi
- if test "$pic_object" != none; then
- # Prepend the subdirectory the object is found in.
- pic_object="$xdir$pic_object"
- if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
- dlfiles="$dlfiles $pic_object"
- prev=
- continue
- else
- # If libtool objects are unsupported, then we need to preload.
- prev=dlprefiles
- fi
- fi
- # CHECK ME: I think I busted this. -Ossama
- # Preload the old-style object.
- dlprefiles="$dlprefiles $pic_object"
- prev=
- fi
- # A PIC object.
- libobjs="$libobjs $pic_object"
- arg="$pic_object"
- fi
- # Non-PIC object.
- if test "$non_pic_object" != none; then
- non_pic_object="$xdir$non_pic_object"
- # A standard non-PIC object
- non_pic_objects="$non_pic_objects $non_pic_object"
- if test -z "$pic_object" || test "$pic_object" = none ; then
- arg="$non_pic_object"
- fi
- fi
- else
- # Only an error if not doing a dry-run.
- if test -z "$run"; then
- $echo "$modename: \`$arg' is not a valid libtool object" 1>&2
- else
- # Dry-run case.
- xdir=
- else
- xdir="$xdir/"
- fi
- pic_object=`$echo "X${xdir}${objdir}/${arg}" | $Xsed -e "$lo2o"`
- non_pic_object=`$echo "X${xdir}${arg}" | $Xsed -e "$lo2o"`
- fi
- fi
- done
- else
- $echo "$modename: link input file \`$save_arg' does not exist"
- fi
- arg=$save_arg
- prev=
- continue
- rpath | xrpath)
- # We need an absolute path.
- case $arg in
- $echo "$modename: only absolute run-paths are allowed" 1>&2
- esac
- if test "$prev" = rpath; then
- case "$rpath " in
- *" $arg "*) ;;
- *) rpath="$rpath $arg" ;;
- esac
- else
- case "$xrpath " in
- *" $arg "*) ;;
- *) xrpath="$xrpath $arg" ;;
- esac
- fi
- prev=
- continue
- xcompiler)
- compiler_flags="$compiler_flags $qarg"
- prev=
- compile_command="$compile_command $qarg"
- finalize_command="$finalize_command $qarg"
- continue
- xlinker)
- linker_flags="$linker_flags $qarg"
- compiler_flags="$compiler_flags $wl$qarg"
- prev=
- compile_command="$compile_command $wl$qarg"
- finalize_command="$finalize_command $wl$qarg"
- continue
- xcclinker)
- prev=
- continue
- shrext)
- shrext_cmds="$arg"
- prev=
- continue
- eval "$prev=\"\$arg\""
- prev=
- continue
- esac
- fi # test -n "$prev"
- prevarg="$arg"
- case $arg in
- -all-static)
- compile_command="$compile_command $link_static_flag"
- finalize_command="$finalize_command $link_static_flag"
- fi
- continue
- -allow-undefined)
- # FIXME: remove this flag sometime in the future.
- $echo "$modename: \`-allow-undefined' is deprecated because it is the default" 1>&2
- continue
- -avoid-version)
- avoid_version=yes
- continue
- -dlopen)
- prev=dlfiles
- continue
- -dlpreopen)
- prev=dlprefiles
- continue
- -export-dynamic)
- continue
- -export-symbols | -export-symbols-regex)
- if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
- $echo "$modename: more than one -exported-symbols argument is not allowed"
- fi
- if test "X$arg" = "X-export-symbols"; then
- prev=expsyms
- else
- prev=expsyms_regex
- fi
- continue
- -inst-prefix-dir)
- prev=inst_prefix
- continue
- # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
- # so, if we see these flags be careful not to treat them like -L
- -L[A-Z][A-Z]*:*)
- case $with_gcc/$host in
- no/*-*-irix* | /*-*-irix*)
- compile_command="$compile_command $arg"
- finalize_command="$finalize_command $arg"
- esac
- continue
- -L*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-L//'`
- case $dir in
- if test -z "$absdir"; then
- $echo "$modename: cannot determine absolute directory name of \`$dir'" 1>&2
- fi
- dir="$absdir"
- esac
- case "$deplibs " in
- *" -L$dir "*) ;;
- deplibs="$deplibs -L$dir"
- lib_search_path="$lib_search_path $dir"
- esac
- case $host in
- case :$dllsearchpath: in
- *":$dir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$dir";;
- esac
- esac
- continue
- -l*)
- if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
- case $host in
- *-*-cygwin* | *-*-pw32* | *-*-beos*)
- # These systems don't actually have a C or math library (as such)
- continue
- *-*-mingw* | *-*-os2*)
- # These systems don't actually have a C library (as such)
- test "X$arg" = "X-lc" && continue
- *-*-openbsd* | *-*-freebsd*)
- # Do not include libc due to us having libc/libc_r.
- *-*-rhapsody* | *-*-darwin1.[012])
- # Rhapsody C and math libraries are in the System framework
- deplibs="$deplibs -framework System"
- continue
- esac
- elif test "X$arg" = "X-lc_r"; then
- case $host in
- # Do not include libc_r directly, use -pthread flag.
- continue
- esac
- fi
- deplibs="$deplibs $arg"
- continue
- -mt|-mthreads|-kthread|-Kthread|-pthread|-pthreads|--thread-safe)
- continue
- -module)
- module=yes
- continue
- # gcc -m* arguments should be passed to the linker via $compiler_flags
- # in order to pass architecture information to the linker
- # (e.g. 32 vs 64-bit). This may also be accomplished via -Wl,-mfoo
- # but this is not reliable with gcc because gcc may use -mfoo to
- # select a different linker, different libraries, etc, while
- # -Wl,-mfoo simply passes -mfoo to the linker.
- -m*)
- # Unknown arguments in both finalize_command and compile_command need
- # to be aesthetically quoted because they are evaled later.
- case $arg in
- arg="\"$arg\""
- esac
- if test "$with_gcc" = "yes" ; then
- compiler_flags="$compiler_flags $arg"
- fi
- continue
- -shrext)
- prev=shrext
- continue
- -no-fast-install)
- fast_install=no
- continue
- -no-install)
- case $host in
- # The PATH hackery in wrapper scripts is required on Windows
- # in order for the loader to find any dlls it needs.
- $echo "$modename: warning: \`-no-install' is ignored for $host" 1>&2
- $echo "$modename: warning: assuming \`-no-fast-install' instead" 1>&2
- fast_install=no
- *) no_install=yes ;;
- esac
- continue
- -no-undefined)
- allow_undefined=no
- continue
- -objectlist)
- prev=objectlist
- continue
- -o) prev=output ;;
- -precious-files-regex)
- prev=precious_regex
- continue
- -release)
- prev=release
- continue
- -rpath)
- prev=rpath
- continue
- -R)
- prev=xrpath
- continue
- -R*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-R//'`
- case $dir in
- esac
- *" $dir "*) ;;
- *) xrpath="$xrpath $dir" ;;
- esac
- continue
- -static)
- # The effects of -static are defined in a previous loop.
- # We used to do the same as -all-static on platforms that
- # didn't have a PIC flag, but the assumption that the effects
- # would be equivalent was wrong. It would break on at least
- # Digital Unix and AIX.
- continue
- -thread-safe)
- thread_safe=yes
- continue
- -version-info)
- prev=vinfo
- continue
- -version-number)
- prev=vinfo
- vinfo_number=yes
- continue
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wc,//'`
- arg=
- for flag in $args; do
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- arg="$arg $wl$flag"
- compiler_flags="$compiler_flags $flag"
- done
- IFS="$save_ifs"
- arg=`$echo "X$arg" | $Xsed -e "s/^ //"`
- -Wl,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wl,//'`
- arg=
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- compiler_flags="$compiler_flags $wl$flag"
- linker_flags="$linker_flags $flag"
- done
- IFS="$save_ifs"
- -Xcompiler)
- prev=xcompiler
- continue
- -Xlinker)
- prev=xlinker
- continue
- -XCClinker)
- prev=xcclinker
- continue
- # Some other compiler flag.
- case $arg in
- arg="\"$arg\""
- esac
- *.$objext)
- # A standard object.
- objs="$objs $arg"
- *.lo)
- pic_object=
- non_pic_object=
- case $arg in
- *) . ./$arg ;;
- esac
- fi
- xdir=
- else
- xdir="$xdir/"
- fi
- prev=
- continue
- else
- prev=dlprefiles
- fi
- fi
- prev=
- fi
- # A PIC object.
- arg="$pic_object"
- fi
- # Non-PIC object.
- fi
- fi
- else
- else
- # Dry-run case.
- xdir=
- else
- xdir="$xdir/"
- fi
- fi
- fi
- *.$libext)
- # An archive.
- old_deplibs="$old_deplibs $arg"
- continue
- *.la)
- # A libtool-controlled library.
- # This library was specified with -dlopen.
- prev=
- elif test "$prev" = dlprefiles; then
- # The library was specified with -dlpreopen.
- prev=
- else
- fi
- continue
- # Some other compiler argument.
- case $arg in
- arg="\"$arg\""
- esac
- esac # arg
- # Now actually substitute the argument into the commands.
- if test -n "$arg"; then
- fi
- done # argument parsing loop
- $echo "$modename: the \`$prevarg' option requires an argument" 1>&2
- fi
- if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
- eval arg=\"$export_dynamic_flag_spec\"
- fi
- oldlibs=
- # calculate the name of the file, without its directory
- outputname=`$echo "X$output" | $Xsed -e 's%^.*/%%'`
- libobjs_save="$libobjs"
- # get the directories listed in $shlibpath_var
- eval shlib_search_path=\`\$echo \"X\${$shlibpath_var}\" \| \$Xsed -e \'s/:/ /g\'\`
- else
- shlib_search_path=
- fi
- eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
- eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
- output_objdir=`$echo "X$output" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$output_objdir" = "X$output"; then
- output_objdir="$objdir"
- else
- output_objdir="$output_objdir/$objdir"
- fi
- # Create the object directory.
- if test ! -d "$output_objdir"; then
- $show "$mkdir $output_objdir"
- $run $mkdir $output_objdir
- status=$?
- if test "$status" -ne 0 && test ! -d "$output_objdir"; then
- exit $status
- fi
- fi
- # Determine the type of output
- case $output in
- $echo "$modename: you must specify an output file" 1>&2
- *.$libext) linkmode=oldlib ;;
- *.lo | *.$objext) linkmode=obj ;;
- *.la) linkmode=lib ;;
- *) linkmode=prog ;; # Anything else should be a program.
- esac
- case $host in
- *cygwin* | *mingw* | *pw32*)
- # don't eliminate duplications in $postdeps and $predeps
- duplicate_compiler_generated_deps=yes
- duplicate_compiler_generated_deps=$duplicate_deps
- esac
- specialdeplibs=
- libs=
- # Find all interdependent deplibs by searching for libraries
- # that are linked more than once (e.g. -la -lb -la)
- for deplib in $deplibs; do
- if test "X$duplicate_deps" = "Xyes" ; then
- case "$libs " in
- *" $deplib "*) specialdeplibs="$specialdeplibs $deplib" ;;
- esac
- fi
- libs="$libs $deplib"
- done
- if test "$linkmode" = lib; then
- libs="$predeps $libs $compiler_lib_search_path $postdeps"
- # Compute libraries that are listed more than once in $predeps
- # $postdeps and mark them as special (i.e., whose duplicates are
- # not to be eliminated).
- pre_post_deps=
- if test "X$duplicate_compiler_generated_deps" = "Xyes" ; then
- for pre_post_dep in $predeps $postdeps; do
- case "$pre_post_deps " in
- *" $pre_post_dep "*) specialdeplibs="$specialdeplibs $pre_post_deps" ;;
- esac
- pre_post_deps="$pre_post_deps $pre_post_dep"
- done
- fi
- pre_post_deps=
- fi
- deplibs=
- newlib_search_path=
- need_relink=no # whether we're linking any uninstalled libtool libraries
- notinst_deplibs= # not-installed libtool libraries
- notinst_path= # paths that contain not-installed libtool libraries
- case $linkmode in
- lib)
- passes="conv link"
- for file in $dlfiles $dlprefiles; do
- case $file in
- *.la) ;;
- $echo "$modename: libraries can \`-dlopen' only libtool libraries: $file" 1>&2
- esac
- done
- prog)
- compile_deplibs=
- finalize_deplibs=
- alldeplibs=no
- newdlfiles=
- newdlprefiles=
- passes="conv scan dlopen dlpreopen link"
- *) passes="conv"
- esac
- for pass in $passes; do
- if test "$linkmode,$pass" = "lib,link" ||
- test "$linkmode,$pass" = "prog,scan"; then
- libs="$deplibs"
- deplibs=
- fi
- if test "$linkmode" = prog; then
- case $pass in
- dlopen) libs="$dlfiles" ;;
- dlpreopen) libs="$dlprefiles" ;;
- link)
- libs="$deplibs %DEPLIBS%"
- test "X$link_all_deplibs" != Xno && libs="$libs $dependency_libs"
- esac
- fi
- if test "$pass" = dlopen; then
- # Collect dlpreopened libraries
- save_deplibs="$deplibs"
- deplibs=
- fi
- for deplib in $libs; do
- lib=
- found=no
- case $deplib in
- if test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$deplib $compile_deplibs"
- finalize_deplibs="$deplib $finalize_deplibs"
- else
- deplibs="$deplib $deplibs"
- fi
- continue
- -l*)
- if test "$linkmode" != lib && test "$linkmode" != prog; then
- $echo "$modename: warning: \`-l' is ignored for archives/objects" 1>&2
- continue
- fi
- name=`$echo "X$deplib" | $Xsed -e 's/^-l//'`
- for searchdir in $newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path; do
- for search_ext in .la $std_shrext .so .a; do
- # Search the libtool library
- lib="$searchdir/lib${name}${search_ext}"
- if test "$search_ext" = ".la"; then
- found=yes
- else
- found=no
- fi
- break 2
- fi
- done
- done
- if test "$found" != yes; then
- # deplib doesn't seem to be a libtool library
- else
- test "$linkmode" = lib && newdependency_libs="$deplib $newdependency_libs"
- fi
- continue
- else # deplib is a libtool library
- # If $allow_libtool_libs_with_static_runtimes && $deplib is a stdlib,
- # We need to do some special things here, and not later.
- if test "X$allow_libtool_libs_with_static_runtimes" = "Xyes" ; then
- case " $predeps $postdeps " in
- *" $deplib "*)
- if (${SED} -e '2q' $lib |
- grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- library_names=
- old_library=
- case $lib in
- *) . ./$lib ;;
- esac
- for l in $old_library $library_names; do
- ll="$l"
- done
- if test "X$ll" = "X$old_library" ; then # only static version available
- found=no
- ladir=`$echo "X$lib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$ladir" = "X$lib" && ladir="."
- lib=$ladir/$old_library
- else
- fi
- continue
- fi
- fi
- esac
- fi
- fi
- ;; # -l
- -L*)
- case $linkmode in
- lib)
- test "$pass" = conv && continue
- newdependency_libs="$deplib $newdependency_libs"
- newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`
- prog)
- if test "$pass" = conv; then
- continue
- fi
- if test "$pass" = scan; then
- else
- fi
- $echo "$modename: warning: \`-L' is ignored for archives/objects" 1>&2
- esac # linkmode
- continue
- ;; # -L
- -R*)
- if test "$pass" = link; then
- dir=`$echo "X$deplib" | $Xsed -e 's/^-R//'`
- # Make sure the xrpath contains only unique directories.
- *" $dir "*) ;;
- esac
- fi
- continue
- *.la) lib="$deplib" ;;
- *.$libext)
- continue
- fi
- case $linkmode in
- lib)
- if test "$deplibs_check_method" != pass_all; then
- $echo
- $echo "*** Warning: Trying to link with static lib archive $deplib."
- $echo "*** I have the capability to make that library automatically link in when"
- $echo "*** you link to this library. But I can only do this if you have a"
- $echo "*** shared version of the library, which you do not appear to have"
- $echo "*** because the file extensions .$libext of this argument makes me believe"
- $echo "*** that it is just a static archive that I should not used here."
- else
- $echo
- $echo "*** Warning: Linking the shared library $output against the"
- $echo "*** static library $deplib is not portable!"
- fi
- continue
- prog)
- if test "$pass" != link; then
- else
- fi
- continue
- esac # linkmode
- ;; # *.$libext
- *.lo | *.$objext)
- elif test "$linkmode" = prog; then
- if test "$pass" = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlopen support or we're linking statically,
- # we need to preload.
- newdlprefiles="$newdlprefiles $deplib"
- else
- newdlfiles="$newdlfiles $deplib"
- fi
- fi
- continue
- %DEPLIBS%)
- alldeplibs=yes
- continue
- esac # case $deplib
- if test "$found" = yes || test -f "$lib"; then :
- else
- $echo "$modename: cannot find the library \`$lib'" 1>&2
- fi
- if (${SED} -e '2q' $lib | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- fi
- dlname=
- dlopen=
- dlpreopen=
- libdir=
- library_names=
- old_library=
- # If the library was installed with an old release of libtool,
- # it will not redefine variables installed, or shouldnotlink
- installed=yes
- shouldnotlink=no
- # Read the .la file
- case $lib in
- *) . ./$lib ;;
- esac
- test "$linkmode,$pass" = "prog,scan" ||
- { test "$linkmode" != prog && test "$linkmode" != lib; }; then
- test -n "$dlopen" && dlfiles="$dlfiles $dlopen"
- test -n "$dlpreopen" && dlprefiles="$dlprefiles $dlpreopen"
- fi
- # Only check for convenience libraries
- deplibs="$lib $deplibs"
- if test -z "$libdir"; then
- if test -z "$old_library"; then
- $echo "$modename: cannot find name of link library for \`$lib'" 1>&2
- fi
- # It is a libtool convenience library, so add in its objects.
- convenience="$convenience $ladir/$objdir/$old_library"
- old_convenience="$old_convenience $ladir/$objdir/$old_library"
- tmp_libs=
- for deplib in $dependency_libs; do
- case "$tmp_libs " in
- esac
- fi
- tmp_libs="$tmp_libs $deplib"
- done
- elif test "$linkmode" != prog && test "$linkmode" != lib; then
- $echo "$modename: \`$lib' is not a convenience library" 1>&2
- fi
- continue
- fi # $pass = conv
- # Get the name of the library we link against.
- linklib=
- linklib="$l"
- done
- if test -z "$linklib"; then
- fi
- $echo "$modename: cannot -dlopen a convenience library: \`$lib'" 1>&2
- fi
- if test -z "$dlname" ||
- test "$dlopen_support" != yes ||
- test "$build_libtool_libs" = no; then
- # If there is no dlname, no dlopen support or we're linking
- # statically, we need to preload. We also need to preload any
- # dependent libraries so libltdl's deplib preloader doesn't
- # bomb out in the load deplibs phase.
- dlprefiles="$dlprefiles $lib $dependency_libs"
- else
- newdlfiles="$newdlfiles $lib"
- fi
- continue
- fi # $pass = dlopen
- case $ladir in
- [\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
- abs_ladir=`cd "$ladir" && pwd`
- if test -z "$abs_ladir"; then
- $echo "$modename: warning: cannot determine absolute directory name of \`$ladir'" 1>&2
- $echo "$modename: passing it literally to the linker, although it might fail" 1>&2
- abs_ladir="$ladir"
- fi
- esac
- laname=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- # Find the relevant object directory and library name.
- if test "X$installed" = Xyes; then
- if test ! -f "$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- $echo "$modename: warning: library \`$lib' was moved." 1>&2
- dir="$ladir"
- absdir="$abs_ladir"
- libdir="$abs_ladir"
- else
- dir="$libdir"
- absdir="$libdir"
- fi
- else
- dir="$ladir/$objdir"
- absdir="$abs_ladir/$objdir"
- # Remove this search path later
- notinst_path="$notinst_path $abs_ladir"
- fi # $installed = yes
- name=`$echo "X$laname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- # This library was specified with -dlpreopen.
- if test "$pass" = dlpreopen; then
- $echo "$modename: cannot -dlpreopen a convenience library: \`$lib'" 1>&2
- fi
- # Prefer using a static library (so that no silly _DYNAMIC symbols
- # are required to link).
- newdlprefiles="$newdlprefiles $dir/$old_library"
- # Otherwise, use the dlname, so that lt_dlopen finds it.
- elif test -n "$dlname"; then
- newdlprefiles="$newdlprefiles $dir/$dlname"
- else
- newdlprefiles="$newdlprefiles $dir/$linklib"
- fi
- fi # $pass = dlpreopen
- # Link the convenience library
- deplibs="$dir/$old_library $deplibs"
- elif test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$dir/$old_library $compile_deplibs"
- finalize_deplibs="$dir/$old_library $finalize_deplibs"
- else
- deplibs="$lib $deplibs" # used for prog,scan pass
- fi
- continue
- fi
- if test "$linkmode" = prog && test "$pass" != link; then
- newlib_search_path="$newlib_search_path $ladir"
- linkalldeplibs=no
- if test "$link_all_deplibs" != no || test -z "$library_names" ||
- linkalldeplibs=yes
- fi
- tmp_libs=
- case $deplib in
- -L*) newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`;; ### testsuite: skip nested quoting test
- esac
- # Need to link against all dependency_libs?
- if test "$linkalldeplibs" = yes; then
- else
- # Need to hardcode shared library paths
- # or/and link against static libraries
- fi
- esac
- fi
- done # for deplib
- continue
- fi # $linkmode = prog...
- if test -n "$library_names" &&
- { test "$prefer_static_libs" = no || test -z "$old_library"; }; then
- # We need to hardcode the library path
- # Make sure the rpath contains only unique directories.
- case "$temp_rpath " in
- *" $dir "*) ;;
- *" $absdir "*) ;;
- *) temp_rpath="$temp_rpath $dir" ;;
- esac
- fi
- # Hardcode the library path.
- # Skip directories that are in the system default run-time
- # search path.
- case " $sys_lib_dlsearch_path " in
- *" $absdir "*) ;;
- case "$compile_rpath " in
- *" $absdir "*) ;;
- *) compile_rpath="$compile_rpath $absdir"
- esac
- esac
- *" $libdir "*) ;;
- case "$finalize_rpath " in
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir"
- esac
- esac
- fi # $linkmode,$pass = prog,link...
- if test "$alldeplibs" = yes &&
- { test "$deplibs_check_method" = pass_all ||
- { test "$build_libtool_libs" = yes &&
- test -n "$library_names"; }; }; then
- # We only need to search for static libraries
- continue
- fi
- fi
- link_static=no # Whether the deplib will be linked statically
- if test "$installed" = no; then
- notinst_deplibs="$notinst_deplibs $lib"
- need_relink=yes
- fi
- # This is a shared library
- # Warn about portability, can't link against -module's on
- # some systems (darwin)
- if test "$shouldnotlink" = yes && test "$pass" = link ; then
- $echo
- $echo "*** Warning: Linking the executable $output against the loadable module"
- else
- $echo "*** Warning: Linking the shared library $output against the loadable module"
- fi
- $echo "*** $linklib is not portable!"
- fi
- if test "$linkmode" = lib &&
- test "$hardcode_into_libs" = yes; then
- # search path.
- *" $absdir "*) ;;
- *" $absdir "*) ;;
- esac
- esac
- *" $libdir "*) ;;
- *" $libdir "*) ;;
- esac
- esac
- fi
- if test -n "$old_archive_from_expsyms_cmds"; then
- # figure out the soname
- set dummy $library_names
- realname="$2"
- shift; shift
- libname=`eval \\$echo \"$libname_spec\"`
- # use dlname if we got it. it's perfectly good, no?
- if test -n "$dlname"; then
- soname="$dlname"
- elif test -n "$soname_spec"; then
- # bleh windows
- case $host in
- *cygwin* | mingw*)
- major=`expr $current - $age`
- versuffix="-$major"
- esac
- eval soname=\"$soname_spec\"
- else
- soname="$realname"
- fi
- # Make a new name for the extract_expsyms_cmds to use
- soroot="$soname"
- soname=`$echo $soroot | ${SED} -e 's/^.*\///'`
- newlib="libimp-`$echo $soname | ${SED} 's/^lib//;s/\.dll$//'`.a"
- # If the library has no export list, then create one now
- if test -f "$output_objdir/$soname-def"; then :
- else
- $show "extracting exported symbol list from \`$soname'"
- cmds=$extract_expsyms_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- $run eval "$cmd" || exit $?
- done
- IFS="$save_ifs"
- fi
- # Create $newlib
- if test -f "$output_objdir/$newlib"; then :; else
- $show "generating import library for \`$soname'"
- cmds=$old_archive_from_expsyms_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # make sure the library variables are pointing to the new library
- dir=$output_objdir
- linklib=$newlib
- fi # test -n "$old_archive_from_expsyms_cmds"
- if test "$linkmode" = prog || test "$mode" != relink; then
- add_shlibpath=
- add_dir=
- add=
- lib_linked=yes
- case $hardcode_action in
- immediate | unsupported)
- if test "$hardcode_direct" = no; then
- add="$dir/$linklib"
- case $host in
- *-*-sco3.2v5* ) add_dir="-L$dir" ;;
- *-*-darwin* )
- # if the lib is a module then we can not link against
- # it, someone is ignoring the new warnings I added
- if /usr/bin/file -L $add 2> /dev/null | $EGREP "bundle" >/dev/null ; then
- $echo "** Warning, lib $linklib is a module, not a shared library"
- if test -z "$old_library" ; then
- $echo
- $echo "** And there doesn't seem to be a static archive available"
- $echo "** The link will probably fail, sorry"
- else
- add="$dir/$old_library"
- fi
- fi
- esac
- elif test "$hardcode_minus_L" = no; then
- case $host in
- *-*-sunos*) add_shlibpath="$dir" ;;
- esac
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = no; then
- add_shlibpath="$dir"
- add="-l$name"
- else
- lib_linked=no
- fi
- relink)
- if test "$hardcode_direct" = yes; then
- elif test "$hardcode_minus_L" = yes; then
- add_dir="-L$dir"
- # Try looking first in the location we're being installed to.
- if test -n "$inst_prefix_dir"; then
- case "$libdir" in
- add_dir="$add_dir -L$inst_prefix_dir$libdir"
- esac
- fi
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = yes; then
- add="-l$name"
- else
- lib_linked=no
- fi
- *) lib_linked=no ;;
- esac
- if test "$lib_linked" != yes; then
- $echo "$modename: configuration error: unsupported hardcode properties"
- fi
- if test -n "$add_shlibpath"; then
- case :$compile_shlibpath: in
- *":$add_shlibpath:"*) ;;
- *) compile_shlibpath="$compile_shlibpath$add_shlibpath:" ;;
- esac
- fi
- test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
- test -n "$add" && compile_deplibs="$add $compile_deplibs"
- else
- test -n "$add_dir" && deplibs="$add_dir $deplibs"
- test -n "$add" && deplibs="$add $deplibs"
- if test "$hardcode_direct" != yes && \
- test "$hardcode_minus_L" != yes && \
- test "$hardcode_shlibpath_var" = yes; then
- case :$finalize_shlibpath: in
- *":$libdir:"*) ;;
- *) finalize_shlibpath="$finalize_shlibpath$libdir:" ;;
- esac
- fi
- fi
- fi
- if test "$linkmode" = prog || test "$mode" = relink; then
- add_shlibpath=
- add_dir=
- add=
- # Finalize command for both is simple: just hardcode it.
- add="$libdir/$linklib"
- add_dir="-L$libdir"
- add="-l$name"
- *":$libdir:"*) ;;
- esac
- add="-l$name"
- elif test "$hardcode_automatic" = yes; then
- if test -n "$inst_prefix_dir" &&
- test -f "$inst_prefix_dir$libdir/$linklib" ; then
- add="$inst_prefix_dir$libdir/$linklib"
- else
- fi
- else
- # We cannot seem to hardcode it, guess we'll fake it.
- case "$libdir" in
- esac
- fi
- add="-l$name"
- fi
- test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
- test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
- else
- fi
- fi
- # Here we assume that one of hardcode_direct or hardcode_minus_L
- # is not unsupported. This is valid on all known static and
- # shared platforms.
- if test "$hardcode_direct" != unsupported; then
- test -n "$old_library" && linklib="$old_library"
- compile_deplibs="$dir/$linklib $compile_deplibs"
- finalize_deplibs="$dir/$linklib $finalize_deplibs"
- else
- compile_deplibs="-l$name -L$dir $compile_deplibs"
- finalize_deplibs="-l$name -L$dir $finalize_deplibs"
- fi
- elif test "$build_libtool_libs" = yes; then
- # Not a shared library
- # We're trying link a shared library against a static one
- # but the system doesn't support it.
- # Just print a warning and add the library to dependency_libs so
- # that the program can be linked against the static library.
- $echo
- $echo "*** Warning: This system can not link to static lib archive $lib."
- $echo "*** shared version of the library, which you do not appear to have."
- if test "$module" = yes; then
- $echo "*** But as you try to build a module library, libtool will still create "
- $echo "*** a static module, that should work as long as the dlopening application"
- $echo "*** is linked with the -dlopen flag to resolve symbols at runtime."
- if test -z "$global_symbol_pipe"; then
- $echo
- $echo "*** However, this would only work if libtool was able to extract symbol"
- $echo "*** lists from a program, using \`nm' or equivalent, but libtool could"
- $echo "*** not find such a program. So, this module is probably useless."
- $echo "*** \`nm' from GNU binutils and a full rebuild may help."
- fi
- if test "$build_old_libs" = no; then
- build_libtool_libs=module
- else
- build_libtool_libs=no
- fi
- fi
- else
- convenience="$convenience $dir/$old_library"
- old_convenience="$old_convenience $dir/$old_library"
- link_static=yes
- fi
- fi # link shared/static library?
- if test -n "$dependency_libs" &&
- { test "$hardcode_into_libs" != yes ||
- test "$build_old_libs" = yes ||
- test "$link_static" = yes; }; then
- # Extract -R from dependency_libs
- temp_deplibs=
- for libdir in $dependency_libs; do
- case $libdir in
- -R*) temp_xrpath=`$echo "X$libdir" | $Xsed -e 's/^-R//'`
- case " $xrpath " in
- *" $temp_xrpath "*) ;;
- *) xrpath="$xrpath $temp_xrpath";;
- esac;;
- *) temp_deplibs="$temp_deplibs $libdir";;
- esac
- done
- dependency_libs="$temp_deplibs"
- fi
- newlib_search_path="$newlib_search_path $absdir"
- # Link against this library
- test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
- # ... and its dependency_libs
- tmp_libs=
- esac
- fi
- done
- if test "$link_all_deplibs" != no; then
- # Add the search paths of all dependency libraries
- case $deplib in
- -L*) path="$deplib" ;;
- *.la)
- dir=`$echo "X$deplib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$dir" = "X$deplib" && dir="."
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
- absdir=`cd "$dir" && pwd`
- $echo "$modename: warning: cannot determine absolute directory name of \`$dir'" 1>&2
- absdir="$dir"
- fi
- esac
- if grep "^installed=no" $deplib > /dev/null; then
- path="$absdir/$objdir"
- else
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
- $echo "$modename: \`$deplib' is not a valid libtool archive" 1>&2
- fi
- if test "$absdir" != "$libdir"; then
- $echo "$modename: warning: \`$deplib' seems to be moved" 1>&2
- fi
- path="$absdir"
- fi
- depdepl=
- case $host in
- *-*-darwin*)
- # we do not want to link against static libs,
- # but need to link against shared
- eval deplibrary_names=`${SED} -n -e 's/^library_names=\(.*\)$/\1/p' $deplib`
- if test -n "$deplibrary_names" ; then
- for tmp in $deplibrary_names ; do
- depdepl=$tmp
- done
- if test -f "$path/$depdepl" ; then
- depdepl="$path/$depdepl"
- fi
- # do not add paths which are already there
- case " $newlib_search_path " in
- *" $path "*) ;;
- *) newlib_search_path="$newlib_search_path $path";;
- esac
- fi
- path=""
- path="-L$path"
- esac
- -l*)
- case $host in
- *-*-darwin*)
- # Again, we only want to link against shared libraries
- eval tmp_libs=`$echo "X$deplib" | $Xsed -e "s,^\-l,,"`
- for tmp in $newlib_search_path ; do
- if test -f "$tmp/lib$tmp_libs.dylib" ; then
- eval depdepl="$tmp/lib$tmp_libs.dylib"
- break
- fi
- done
- path=""
- *) continue ;;
- esac
- *) continue ;;
- esac
- case " $deplibs " in
- *" $depdepl "*) ;;
- *) deplibs="$depdepl $deplibs" ;;
- esac
- *" $path "*) ;;
- *) deplibs="$deplibs $path" ;;
- esac
- done
- fi # link_all_deplibs != no
- fi # linkmode = lib
- done # for deplib in $libs
- dependency_libs="$newdependency_libs"
- # Link the dlpreopened libraries before other libraries
- for deplib in $save_deplibs; do
- done
- fi
- if test "$pass" != dlopen; then
- if test "$pass" != conv; then
- # Make sure lib_search_path contains only unique directories.
- lib_search_path=
- for dir in $newlib_search_path; do
- case "$lib_search_path " in
- *" $dir "*) ;;
- *) lib_search_path="$lib_search_path $dir" ;;
- esac
- done
- fi
- if test "$linkmode,$pass" != "prog,link"; then
- vars="deplibs"
- else
- vars="compile_deplibs finalize_deplibs"
- fi
- for var in $vars dependency_libs; do
- # Add libraries to $var in reverse order
- eval tmp_libs=\"\$$var\"
- new_libs=
- for deplib in $tmp_libs; do
- # FIXME: Pedantically, this is the right thing to do, so
- # that some nasty dependency loop isn't accidentally
- # broken:
- #new_libs="$deplib $new_libs"
- # Pragmatically, this seems to cause very few problems in
- # practice:
- case $deplib in
- -L*) new_libs="$deplib $new_libs" ;;
- -R*) ;;
- # And here is the reason: when a library appears more
- # than once as an explicit dependence of a library, or
- # is implicitly linked in more than once by the
- # compiler, it is considered special, and multiple
- # occurrences thereof are not removed. Compare this
- # with having the same library being listed as a
- # dependency of multiple other libraries: in this case,
- # we know (pedantically, we assume) the library does not
- # need to be listed more than once, so we keep only the
- # last copy. This is not always right, but it is rare
- # enough that we require users that really mean to play
- # such unportable linking tricks to link the library
- # using -Wl,-lname, so that libtool does not consider it
- # for duplicate removal.
- case " $specialdeplibs " in
- *" $deplib "*) new_libs="$deplib $new_libs" ;;
- case " $new_libs " in
- *" $deplib "*) ;;
- *) new_libs="$deplib $new_libs" ;;
- esac
- esac
- esac
- done
- tmp_libs=
- for deplib in $new_libs; do
- case $deplib in
- -L*)
- case " $tmp_libs " in
- *" $deplib "*) ;;
- *) tmp_libs="$tmp_libs $deplib" ;;
- esac
- esac
- done
- eval $var=\"$tmp_libs\"
- done # for var
- fi
- # Last step: remove runtime libs from dependency_libs
- # (they stay in deplibs)
- tmp_libs=
- for i in $dependency_libs ; do
- case " $predeps $postdeps $compiler_lib_search_path " in
- *" $i "*)
- i=""
- esac
- if test -n "$i" ; then
- tmp_libs="$tmp_libs $i"
- fi
- done
- dependency_libs=$tmp_libs
- done # for pass
- dlfiles="$newdlfiles"
- dlprefiles="$newdlprefiles"
- fi
- case $linkmode in
- oldlib)
- if test -n "$deplibs"; then
- $echo "$modename: warning: \`-l' and \`-L' are ignored for archives" 1>&2
- fi
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen' is ignored for archives" 1>&2
- fi
- if test -n "$rpath"; then
- $echo "$modename: warning: \`-rpath' is ignored for archives" 1>&2
- fi
- if test -n "$xrpath"; then
- $echo "$modename: warning: \`-R' is ignored for archives" 1>&2
- fi
- if test -n "$vinfo"; then
- $echo "$modename: warning: \`-version-info/-version-number' is ignored for archives" 1>&2
- fi
- if test -n "$release"; then
- $echo "$modename: warning: \`-release' is ignored for archives" 1>&2
- fi
- $echo "$modename: warning: \`-export-symbols' is ignored for archives" 1>&2
- fi
- # Now set the variables for building old libraries.
- oldlibs="$output"
- objs="$objs$old_deplibs"
- lib)
- # Make sure we only generate libraries of the form `libNAME.la'.
- case $outputname in
- lib*)
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- eval shared_ext=\"$shrext_cmds\"
- eval libname=\"$libname_spec\"
- if test "$module" = no; then
- $echo "$modename: libtool library \`$output' must begin with \`lib'" 1>&2
- $echo "$help" 1>&2
- fi
- if test "$need_lib_prefix" != no; then
- # Add the "lib" prefix for modules if required
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- else
- libname=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- fi
- esac
- if test -n "$objs"; then
- $echo "$modename: cannot build libtool library \`$output' from non-libtool objects on this host:$objs" 2>&1
- else
- $echo
- $echo "*** Warning: Linking the shared library $output against the non-libtool"
- $echo "*** objects $objs is not portable!"
- libobjs="$libobjs $objs"
- fi
- fi
- if test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen self' is ignored for libtool libraries" 1>&2
- fi
- set dummy $rpath
- if test "$#" -gt 2; then
- $echo "$modename: warning: ignoring multiple \`-rpath's for a libtool library" 1>&2
- fi
- install_libdir="$2"
- oldlibs=
- if test -z "$rpath"; then
- # Building a libtool convenience library.
- # Some compilers have problems with a `.al' extension so
- # convenience libraries should have the same extension an
- # archive normally would.
- oldlibs="$output_objdir/$libname.$libext $oldlibs"
- build_libtool_libs=convenience
- fi
- $echo "$modename: warning: \`-version-info/-version-number' is ignored for convenience libraries" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for convenience libraries" 1>&2
- fi
- else
- # Parse the version information argument.
- save_ifs="$IFS"; IFS=':'
- set dummy $vinfo 0 0 0
- IFS="$save_ifs"
- if test -n "$8"; then
- $echo "$modename: too many parameters to \`-version-info'" 1>&2
- fi
- # convert absolute version numbers to libtool ages
- # this retains compatibility with .la files and attempts
- # to make the code below a bit more comprehensible
- case $vinfo_number in
- yes)
- number_major="$2"
- number_minor="$3"
- number_revision="$4"
- # There are really only two kinds -- those that
- # use the current revision as the major version
- # and those that subtract age and use age as
- # a minor version. But, then there is irix
- # which has an extra 1 added just for fun
- case $version_type in
- darwin|linux|osf|windows)
- current=`expr $number_major + $number_minor`
- age="$number_minor"
- revision="$number_revision"
- freebsd-aout|freebsd-elf|sunos)
- current="$number_major"
- revision="$number_minor"
- age="0"
- irix|nonstopux)
- current=`expr $number_major + $number_minor - 1`
- $echo "$modename: unknown library version type \`$version_type'" 1>&2
- esac
- no)
- current="$2"
- revision="$3"
- age="$4"
- esac
- # Check that each of the things are valid numbers.
- case $current in
- 0|[1-9]|[1-9][0-9]|[1-9][0-9][0-9]|[1-9][0-9][0-9][0-9]|[1-9][0-9][0-9][0-9][0-9]) ;;
- $echo "$modename: CURRENT \`$current' is not a nonnegative integer" 1>&2
- $echo "$modename: \`$vinfo' is not valid version information" 1>&2
- esac
- case $revision in
- $echo "$modename: REVISION \`$revision' is not a nonnegative integer" 1>&2
- esac
- case $age in
- $echo "$modename: AGE \`$age' is not a nonnegative integer" 1>&2
- esac
- if test "$age" -gt "$current"; then
- $echo "$modename: AGE \`$age' is greater than the current interface number \`$current'" 1>&2
- fi
- # Calculate the version variables.
- major=
- versuffix=
- verstring=
- none) ;;
- darwin)
- # Like Linux, but with the current version available in
- # verstring for coding it into the library header
- major=.`expr $current - $age`
- versuffix="$major.$age.$revision"
- # Darwin ld doesn't like 0 for these options...
- minor_current=`expr $current + 1`
- verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
- freebsd-aout)
- major=".$current"
- versuffix=".$current.$revision";
- freebsd-elf)
- major=".$current"
- versuffix=".$current";
- irix | nonstopux)
- major=`expr $current - $age + 1`
- nonstopux) verstring_prefix=nonstopux ;;
- *) verstring_prefix=sgi ;;
- esac
- verstring="$verstring_prefix$major.$revision"
- # Add in all the interfaces that we are compatible with.
- loop=$revision
- while test "$loop" -ne 0; do
- iface=`expr $revision - $loop`
- loop=`expr $loop - 1`
- verstring="$verstring_prefix$major.$iface:$verstring"
- done
- # Before this point, $major must not contain `.'.
- major=.$major
- versuffix="$major.$revision"
- linux)
- osf)
- versuffix=".$current.$age.$revision"
- verstring="$current.$age.$revision"
- loop=$age
- iface=`expr $current - $loop`
- verstring="$verstring:${iface}.0"
- done
- # Make executables depend on our current version.
- verstring="$verstring:${current}.0"
- sunos)
- major=".$current"
- windows)
- # Use '-' rather than '.', since we only want one
- # extension on DOS 8.3 filesystems.
- esac
- # Clear the version info if we defaulted, and they specified a release.
- if test -z "$vinfo" && test -n "$release"; then
- major=
- darwin)
- # we can't check for "0.0" in archive_cmds due to quoting
- # problems, so we reset it completely
- verstring=
- verstring="0.0"
- esac
- if test "$need_version" = no; then
- versuffix=
- else
- versuffix=".0.0"
- fi
- fi
- # Remove version info from name if versioning should be avoided
- if test "$avoid_version" = yes && test "$need_version" = no; then
- major=
- versuffix=
- verstring=""
- fi
- # Check to see if the archive will have undefined symbols.
- if test "$allow_undefined" = yes; then
- if test "$allow_undefined_flag" = unsupported; then
- $echo "$modename: warning: undefined symbols not allowed in $host shared libraries" 1>&2
- fi
- else
- # Don't allow undefined symbols.
- allow_undefined_flag="$no_undefined_flag"
- fi
- fi
- if test "$mode" != relink; then
- # Remove our outputs, but don't remove object files since they
- # may have been created when compiling PIC objects.
- removelist=
- tempremovelist=`$echo "$output_objdir/*"`
- for p in $tempremovelist; do
- case $p in
- *.$objext)
- $output_objdir/$outputname | $output_objdir/$libname.* | $output_objdir/${libname}${release}.*)
- if test "X$precious_files_regex" != "X"; then
- if echo $p | $EGREP -e "$precious_files_regex" >/dev/null 2>&1
- then
- continue
- fi
- fi
- removelist="$removelist $p"
- esac
- done
- if test -n "$removelist"; then
- $show "${rm}r $removelist"
- $run ${rm}r $removelist
- fi
- fi
- if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
- oldlibs="$oldlibs $output_objdir/$libname.$libext"
- # Transform .lo files to .o files.
- oldobjs="$objs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e "$lo2o" | $NL2SP`
- fi
- # Eliminate all temporary directories.
- for path in $notinst_path; do
- lib_search_path=`$echo "$lib_search_path " | ${SED} -e 's% $path % %g'`
- deplibs=`$echo "$deplibs " | ${SED} -e 's% -L$path % %g'`
- dependency_libs=`$echo "$dependency_libs " | ${SED} -e 's% -L$path % %g'`
- done
- # If the user specified any rpath flags, then add them.
- temp_xrpath=
- for libdir in $xrpath; do
- temp_xrpath="$temp_xrpath -R$libdir"
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir" ;;
- esac
- done
- if test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes; then
- dependency_libs="$temp_xrpath $dependency_libs"
- fi
- fi
- # Make sure dlfiles contains only unique files that won't be dlpreopened
- old_dlfiles="$dlfiles"
- dlfiles=
- for lib in $old_dlfiles; do
- case " $dlprefiles $dlfiles " in
- *" $lib "*) ;;
- *) dlfiles="$dlfiles $lib" ;;
- esac
- done
- # Make sure dlprefiles contains only unique files
- old_dlprefiles="$dlprefiles"
- dlprefiles=
- for lib in $old_dlprefiles; do
- case "$dlprefiles " in
- *" $lib "*) ;;
- *) dlprefiles="$dlprefiles $lib" ;;
- esac
- done
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos*)
- # these systems don't actually have a c library (as such)!
- # Rhapsody C library is in the System framework
- *-*-netbsd*)
- # Don't link with libc until the a.out ld.so is fixed.
- # Add libc to deplibs on all other systems if necessary.
- if test "$build_libtool_need_lc" = "yes"; then
- deplibs="$deplibs -lc"
- fi
- esac
- fi
- # Transform deplibs into only deplibs that can be linked in shared.
- name_save=$name
- libname_save=$libname
- release_save=$release
- versuffix_save=$versuffix
- major_save=$major
- # I'm not sure if I'm treating the release correctly. I think
- # release should show up in the -l (ie -lgmp5) so we don't want to
- # add it in twice. Is that correct?
- release=""
- versuffix=""
- major=""
- newdeplibs=
- droppeddeps=no
- case $deplibs_check_method in
- pass_all)
- # Don't check for shared/static. Everything works.
- # This might be a little naive. We might want to check
- # whether the library exists or not. But this is on
- # osf3 & osf4 and I'm not really sure... Just
- # implementing what was already the behavior.
- newdeplibs=$deplibs
- test_compile)
- # This code stresses the "libraries are programs" paradigm to its
- # limits. Maybe even breaks it. We compile a program, linking it
- # against the deplibs as a proxy for the library. Then we can check
- # whether they linked in statically or dynamically with ldd.
- $rm conftest.c
- cat > conftest.c <<EOF
- int main() { return 0; }
-EOF
- $rm conftest
- $LTCC -o conftest conftest.c $deplibs
- if test "$?" -eq 0 ; then
- ldd_output=`ldd conftest`
- for i in $deplibs; do
- name="`expr $i : '-l\(.*\)'`"
- # If $name is empty we are operating on a -L argument.
- if test "$name" != "" && test "$name" -ne "0"; then
- *" $i "*)
- newdeplibs="$newdeplibs $i"
- i=""
- esac
- fi
- deplib_matches=`eval \\$echo \"$library_names_spec\"`
- set dummy $deplib_matches
- deplib_match=$2
- if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
- else
- droppeddeps=yes
- $echo
- $echo "*** Warning: dynamic linker does not accept needed library $i."
- $echo "*** shared version of the library, which I believe you do not have"
- $echo "*** because a test_compile did reveal that the linker did not use it for"
- $echo "*** its dynamic dependency list that programs get resolved with at runtime."
- fi
- fi
- else
- fi
- done
- else
- # Error occurred in the first compile. Let's try to salvage
- # the situation: Compile a separate program for each library.
- if test "$name" != "" && test "$name" != "0"; then
- $rm conftest
- $LTCC -o conftest conftest.c $i
- # Did it work?
- *" $i "*)
- i=""
- esac
- fi
- deplib_match=$2
- else
- droppeddeps=yes
- $echo
- $echo "*** because a test_compile did reveal that the linker did not use this one"
- $echo "*** as a dynamic dependency that programs can get resolved with at runtime."
- fi
- fi
- else
- droppeddeps=yes
- $echo
- $echo "*** Warning! Library $i is needed by this library but I was not able to"
- $echo "*** make it link in! You will probably need to install it or some"
- $echo "*** library that it depends on before this library will be fully"
- $echo "*** functional. Installing it before continuing would be even better."
- fi
- else
- fi
- done
- fi
- file_magic*)
- set dummy $deplibs_check_method
- file_magic_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- for a_deplib in $deplibs; do
- name="`expr $a_deplib : '-l\(.*\)'`"
- *" $a_deplib "*)
- newdeplibs="$newdeplibs $a_deplib"
- a_deplib=""
- esac
- fi
- if test -n "$a_deplib" ; then
- for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
- potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
- for potent_lib in $potential_libs; do
- # Follow soft links.
- if ls -lLd "$potent_lib" 2>/dev/null \
- | grep " -> " >/dev/null; then
- continue
- fi
- # The statement above tries to avoid entering an
- # endless loop below, in case of cyclic links.
- # We might still enter an endless loop, since a link
- # loop can be closed while we follow links,
- # but so what?
- potlib="$potent_lib"
- while test -h "$potlib" 2>/dev/null; do
- potliblink=`ls -ld $potlib | ${SED} 's/.* -> //'`
- case $potliblink in
- [\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
- *) potlib=`$echo "X$potlib" | $Xsed -e 's,[^/]*$,,'`"$potliblink";;
- esac
- done
- if eval $file_magic_cmd \"\$potlib\" 2>/dev/null \
- | ${SED} 10q \
- | $EGREP "$file_magic_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- $echo
- $echo "*** Warning: linker path does not have real file for library $a_deplib."
- $echo "*** because I did check the linker path looking for a file starting"
- if test -z "$potlib" ; then
- $echo "*** with $libname but no candidates were found. (...for file magic test)"
- else
- $echo "*** with $libname and none of the candidates passed a file format test"
- $echo "*** using a file magic. Last file checked: $potlib"
- fi
- fi
- else
- # Add a -L argument.
- fi
- done # Gone through all deplibs.
- match_pattern*)
- match_pattern_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- if test -n "$name" && test "$name" != "0"; then
- *" $a_deplib "*)
- a_deplib=""
- esac
- fi
- potlib="$potent_lib" # see symlink-check above in file_magic test
- if eval $echo \"$potent_lib\" 2>/dev/null \
- | ${SED} 10q \
- | $EGREP "$match_pattern_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- $echo
- $echo "*** with $libname but no candidates were found. (...for regex pattern test)"
- else
- $echo "*** using a regex pattern. Last file checked: $potlib"
- fi
- fi
- else
- fi
- none | unknown | *)
- newdeplibs=""
- tmp_deplibs=`$echo "X $deplibs" | $Xsed -e 's/ -lc$//' \
- -e 's/ -[LR][^ ]*//g'`
- for i in $predeps $postdeps ; do
- # can't use Xsed below, because $i might contain '/'
- tmp_deplibs=`$echo "X $tmp_deplibs" | ${SED} -e "1s,^X,," -e "s,$i,,"`
- done
- fi
- if $echo "X $tmp_deplibs" | $Xsed -e 's/[ ]//g' \
- | grep . >/dev/null; then
- $echo
- if test "X$deplibs_check_method" = "Xnone"; then
- $echo "*** Warning: inter-library dependencies are not supported in this platform."
- else
- $echo "*** Warning: inter-library dependencies are not known to be supported."
- fi
- $echo "*** All declared inter-library dependencies are being dropped."
- droppeddeps=yes
- fi
- esac
- versuffix=$versuffix_save
- major=$major_save
- release=$release_save
- libname=$libname_save
- name=$name_save
- case $host in
- # On Rhapsody replace the C library is the System framework
- newdeplibs=`$echo "X $newdeplibs" | $Xsed -e 's/ -lc / -framework System /'`
- esac
- if test "$droppeddeps" = yes; then
- $echo
- $echo "*** Warning: libtool could not satisfy all declared inter-library"
- $echo "*** dependencies of module $libname. Therefore, libtool will create"
- $echo "*** a static module, that should work as long as the dlopening"
- $echo "*** application is linked with the -dlopen flag."
- $echo
- fi
- oldlibs="$output_objdir/$libname.$libext"
- else
- fi
- else
- $echo "*** The inter-library dependencies that have been dropped here will be"
- $echo "*** automatically added whenever a program is linked with this library"
- $echo "*** or is declared to -dlopen it."
- if test "$allow_undefined" = no; then
- $echo
- $echo "*** Since this library must not contain undefined symbols,"
- $echo "*** because either the platform does not support them or"
- $echo "*** it was explicitly requested with -no-undefined,"
- $echo "*** libtool will only create a static version of it."
- else
- fi
- fi
- fi
- fi
- # Done checking deplibs!
- deplibs=$newdeplibs
- fi
- # All the library-specific variables (install_libdir is set above).
- library_names=
- old_library=
- dlname=
- # Test again, we may have decided not to build it any more
- if test "$build_libtool_libs" = yes; then
- if test "$hardcode_into_libs" = yes; then
- # Hardcode the library paths
- hardcode_libdirs=
- dep_rpath=
- rpath="$finalize_rpath"
- test "$mode" != relink && rpath="$compile_rpath$rpath"
- for libdir in $rpath; do
- if test -n "$hardcode_libdir_flag_spec"; then
- if test -n "$hardcode_libdir_separator"; then
- if test -z "$hardcode_libdirs"; then
- hardcode_libdirs="$libdir"
- else
- # Just accumulate the unique libdirs.
- case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
- *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
- hardcode_libdirs="$hardcode_libdirs$hardcode_libdir_separator$libdir"
- esac
- fi
- else
- eval flag=\"$hardcode_libdir_flag_spec\"
- dep_rpath="$dep_rpath $flag"
- fi
- elif test -n "$runpath_var"; then
- case "$perm_rpath " in
- *" $libdir "*) ;;
- *) perm_rpath="$perm_rpath $libdir" ;;
- esac
- fi
- done
- # Substitute the hardcoded libdirs into the rpath.
- if test -n "$hardcode_libdir_separator" &&
- test -n "$hardcode_libdirs"; then
- libdir="$hardcode_libdirs"
- if test -n "$hardcode_libdir_flag_spec_ld"; then
- eval dep_rpath=\"$hardcode_libdir_flag_spec_ld\"
- else
- eval dep_rpath=\"$hardcode_libdir_flag_spec\"
- fi
- fi
- if test -n "$runpath_var" && test -n "$perm_rpath"; then
- # We should set the runpath_var.
- rpath=
- for dir in $perm_rpath; do
- rpath="$rpath$dir:"
- done
- eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
- fi
- test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
- fi
- shlibpath="$finalize_shlibpath"
- test "$mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
- if test -n "$shlibpath"; then
- eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
- fi
- # Get the real and link names of the library.
- eval library_names=\"$library_names_spec\"
- realname="$2"
- shift; shift
- if test -n "$soname_spec"; then
- else
- fi
- if test -z "$dlname"; then
- dlname=$soname
- fi
- lib="$output_objdir/$realname"
- for link
- do
- linknames="$linknames $link"
- done
- # Use standard objects if they are pic
- test -z "$pic_flag" && libobjs=`$echo "X$libobjs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
- $show "generating symbol list for \`$libname.la'"
- export_symbols="$output_objdir/$libname.exp"
- $run $rm $export_symbols
- cmds=$export_symbols_cmds
- save_ifs="$IFS"; IFS='~'
- for cmd in $cmds; do
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- if len=`expr "X$cmd" : ".*"` &&
- test "$len" -le "$max_cmd_len" || test "$max_cmd_len" -le -1; then
- $show "$cmd"
- skipped_export=false
- else
- # The command line is too long to execute in one step.
- $show "using reloadable object file for export list..."
- skipped_export=:
- fi
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex"; then
- $show "$EGREP -e \"$export_symbols_regex\" \"$export_symbols\" > \"${export_symbols}T\""
- $run eval '$EGREP -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
- $show "$mv \"${export_symbols}T\" \"$export_symbols\""
- $run eval '$mv "${export_symbols}T" "$export_symbols"'
- fi
- fi
- fi
- if test -n "$export_symbols" && test -n "$include_expsyms"; then
- $run eval '$echo "X$include_expsyms" | $SP2NL >> "$export_symbols"'
- fi
- tmp_deplibs=
- for test_deplib in $deplibs; do
- case " $convenience " in
- *" $test_deplib "*) ;;
- tmp_deplibs="$tmp_deplibs $test_deplib"
- esac
- done
- deplibs="$tmp_deplibs"
- if test -n "$convenience"; then
- if test -n "$whole_archive_flag_spec"; then
- save_libobjs=$libobjs
- eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${outputname}x"
- $show "${rm}r $gentop"
- $run ${rm}r "$gentop"
- $show "$mkdir $gentop"
- $run $mkdir "$gentop"
- status=$?
- if test "$status" -ne 0 && test ! -d "$gentop"; then
- exit $status
- fi
- generated="$generated $gentop"
- for xlib in $convenience; do
- # Extract the objects.
- case $xlib in
- [\\/]* | [A-Za-z]:[\\/]*) xabs="$xlib" ;;
- *) xabs=`pwd`"/$xlib" ;;
- esac
- xlib=`$echo "X$xlib" | $Xsed -e 's%^.*/%%'`
- xdir="$gentop/$xlib"
- $show "${rm}r $xdir"
- $run ${rm}r "$xdir"
- $show "$mkdir $xdir"
- $run $mkdir "$xdir"
- status=$?
- if test "$status" -ne 0 && test ! -d "$xdir"; then
- exit $status
- fi
- # We will extract separately just the conflicting names and we will no
- # longer touch any unique names. It is faster to leave these extract
- # automatically by $AR in one run.
- $show "(cd $xdir && $AR x $xabs)"
- $run eval "(cd \$xdir && $AR x \$xabs)" || exit $?
- if ($AR t "$xabs" | sort | sort -uc >/dev/null 2>&1); then
- else
- $echo "$modename: warning: object name conflicts; renaming object files" 1>&2
- $echo "$modename: warning: to ensure that they will not overwrite" 1>&2
- $AR t "$xabs" | sort | uniq -cd | while read -r count name
- do
- i=1
- while test "$i" -le "$count"
- do
- # Put our $i before any first dot (extension)
- # Never overwrite any file
- name_to="$name"
- while test "X$name_to" = "X$name" || test -f "$xdir/$name_to"
- do
- name_to=`$echo "X$name_to" | $Xsed -e "s/\([^.]*\)/\1-$i/"`
- done
- $show "(cd $xdir && $AR xN $i $xabs '$name' && $mv '$name' '$name_to')"
- $run eval "(cd \$xdir && $AR xN $i \$xabs '$name' && $mv '$name' '$name_to')" || exit $?
- i=`expr $i + 1`
- done
- done
- fi
- libobjs="$libobjs "`find $xdir -name \*.$objext -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
- eval flag=\"$thread_safe_flag_spec\"
- fi
- # Make a backup of the uninstalled library when relinking
- if test "$mode" = relink; then
- $run eval '(cd $output_objdir && $rm ${realname}U && $mv $realname ${realname}U)' || exit $?
- fi
- # Do each of the archive commands.
- if test "$module" = yes && test -n "$module_cmds" ; then
- if test -n "$export_symbols" && test -n "$module_expsym_cmds"; then
- eval test_cmds=\"$module_expsym_cmds\"
- cmds=$module_expsym_cmds
- else
- eval test_cmds=\"$module_cmds\"
- cmds=$module_cmds
- fi
- else
- if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
- eval test_cmds=\"$archive_expsym_cmds\"
- cmds=$archive_expsym_cmds
- else
- eval test_cmds=\"$archive_cmds\"
- cmds=$archive_cmds
- fi
- fi
- if test "X$skipped_export" != "X:" && len=`expr "X$test_cmds" : ".*"` &&
- else
- # The command line is too long to link in one step, link piecewise.
- $echo "creating reloadable object files..."
- # Save the value of $output and $libobjs because we want to
- # use them later. If we have whole_archive_flag_spec, we
- # want to use save_libobjs as it was before
- # whole_archive_flag_spec was expanded, because we can't
- # assume the linker understands whole_archive_flag_spec.
- # This may have to be revisited, in case too many
- # convenience libraries get linked in and end up exceeding
- # the spec.
- if test -z "$convenience" || test -z "$whole_archive_flag_spec"; then
- fi
- save_output=$output
- # Clear the reloadable object creation command queue and
- # initialize k to one.
- test_cmds=
- concat_cmds=
- objlist=
- delfiles=
- last_robj=
- k=1
- output=$output_objdir/$save_output-${k}.$objext
- # Loop over the list of objects to be linked.
- for obj in $save_libobjs
- do
- eval test_cmds=\"$reload_cmds $objlist $last_robj\"
- if test "X$objlist" = X ||
- { len=`expr "X$test_cmds" : ".*"` &&
- test "$len" -le "$max_cmd_len"; }; then
- objlist="$objlist $obj"
- else
- # The command $test_cmds is almost too long, add a
- # command to the queue.
- if test "$k" -eq 1 ; then
- # The first file doesn't have a previous command to add.
- eval concat_cmds=\"$reload_cmds $objlist $last_robj\"
- else
- # All subsequent reloadable object files will link in
- # the last one created.
- eval concat_cmds=\"\$concat_cmds~$reload_cmds $objlist $last_robj\"
- fi
- last_robj=$output_objdir/$save_output-${k}.$objext
- k=`expr $k + 1`
- objlist=$obj
- len=1
- fi
- done
- # Handle the remaining objects by creating one last
- # reloadable object file. All subsequent reloadable object
- # files will link in the last one created.
- test -z "$concat_cmds" || concat_cmds=$concat_cmds~
- eval concat_cmds=\"\${concat_cmds}$reload_cmds $objlist $last_robj\"
- if ${skipped_export-false}; then
- libobjs=$output
- # Append the command to create the export file.
- eval concat_cmds=\"\$concat_cmds~$export_symbols_cmds\"
- fi
- # Set up a command to remove the reloadale object files
- # after they are used.
- i=0
- while test "$i" -lt "$k"
- do
- i=`expr $i + 1`
- delfiles="$delfiles $output_objdir/$save_output-${i}.$objext"
- done
- $echo "creating a temporary reloadable object file: $output"
- # Loop through the commands generated above and execute them.
- for cmd in $concat_cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- libobjs=$output
- # Restore the value of output.
- output=$save_output
- if test -n "$convenience" && test -n "$whole_archive_flag_spec"; then
- fi
- # Expand the library linking commands again to reset the
- # value of $libobjs for piecewise linking.
- else
- cmds=$module_cmds
- fi
- else
- else
- fi
- fi
- # Append the command to remove the reloadable object files
- # to the just-reset $cmds.
- eval cmds=\"\$cmds~\$rm $delfiles\"
- fi
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Restore the uninstalled library and exit
- $run eval '(cd $output_objdir && $rm ${realname}T && $mv $realname ${realname}T && $mv "$realname"U $realname)' || exit $?
- exit $EXIT_SUCCESS
- fi
- # Create links to the real library.
- for linkname in $linknames; do
- if test "$realname" != "$linkname"; then
- $show "(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval '(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)' || exit $?
- fi
- done
- # If -module or -export-dynamic was specified, set the dlname.
- if test "$module" = yes || test "$export_dynamic" = yes; then
- # On all known operating systems, these are identical.
- dlname="$soname"
- fi
- fi
- obj)
- $echo "$modename: warning: \`-l' and \`-L' are ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-dlopen' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-rpath' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-R' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-version-info' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for objects" 1>&2
- fi
- case $output in
- *.lo)
- if test -n "$objs$old_deplibs"; then
- $echo "$modename: cannot build library object \`$output' from non-libtool objects" 1>&2
- exit $EXIT_FAILURE
- fi
- libobj="$output"
- obj=`$echo "X$output" | $Xsed -e "$lo2o"`
- libobj=
- obj="$output"
- esac
- # Delete the old objects.
- $run $rm $obj $libobj
- # Objects from convenience libraries. This assumes
- # single-version convenience libraries. Whenever we create
- # different ones for PIC/non-PIC, this we'll have to duplicate
- # the extraction.
- reload_conv_objs=
- gentop=
- # reload_cmds runs $LD directly, so let us get rid of
- # -Wl from whole_archive_flag_spec
- wl=
- eval reload_conv_objs=\"\$reload_objs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${obj}x"
- status=$?
- exit $status
- fi
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- else
- do
- i=1
- do
- name_to="$name"
- do
- done
- i=`expr $i + 1`
- done
- done
- fi
- reload_conv_objs="$reload_objs "`find $xdir -name \*.$objext -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- # Create the old-style object.
- reload_objs="$objs$old_deplibs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}$'/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
- output="$obj"
- cmds=$reload_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Exit if we aren't doing a library object file.
- if test -z "$libobj"; then
- if test -n "$gentop"; then
- $run ${rm}r $gentop
- fi
- fi
- if test "$build_libtool_libs" != yes; then
- fi
- # Create an invalid libtool object if no PIC, so that we don't
- # accidentally link it into a program.
- # $show "echo timestamp > $libobj"
- # $run eval "echo timestamp > $libobj" || exit $?
- fi
- if test -n "$pic_flag" || test "$pic_mode" != default; then
- # Only do commands if we really have different PIC objects.
- reload_objs="$libobjs $reload_conv_objs"
- output="$libobj"
- cmds=$reload_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- fi
- prog)
- case $host in
- *cygwin*) output=`$echo $output | ${SED} -e 's,.exe$,,;s,$,.exe,'` ;;
- esac
- $echo "$modename: warning: \`-version-info' is ignored for programs" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for programs" 1>&2
- fi
- if test "$preload" = yes; then
- if test "$dlopen_support" = unknown && test "$dlopen_self" = unknown &&
- test "$dlopen_self_static" = unknown; then
- $echo "$modename: warning: \`AC_LIBTOOL_DLOPEN' not used. Assuming no dlopen support."
- fi
- fi
- case $host in
- compile_deplibs=`$echo "X $compile_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- finalize_deplibs=`$echo "X $finalize_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- esac
- case $host in
- *darwin*)
- # Don't allow lazy linking, it breaks C++ global constructors
- if test "$tagname" = CXX ; then
- compile_command="$compile_command ${wl}-bind_at_load"
- finalize_command="$finalize_command ${wl}-bind_at_load"
- fi
- esac
- compile_command="$compile_command $compile_deplibs"
- finalize_command="$finalize_command $finalize_deplibs"
- if test -n "$rpath$xrpath"; then
- for libdir in $rpath $xrpath; do
- # This is the magic to use -rpath.
- *" $libdir "*) ;;
- esac
- done
- fi
- # Now hardcode the library paths
- rpath=
- hardcode_libdirs=
- for libdir in $compile_rpath $finalize_rpath; do
- else
- esac
- fi
- else
- rpath="$rpath $flag"
- fi
- *" $libdir "*) ;;
- esac
- fi
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
- case :$dllsearchpath: in
- *":$libdir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$libdir";;
- esac
- esac
- done
- eval rpath=\" $hardcode_libdir_flag_spec\"
- fi
- compile_rpath="$rpath"
- rpath=
- hardcode_libdirs=
- for libdir in $finalize_rpath; do
- else
- esac
- fi
- else
- fi
- case "$finalize_perm_rpath " in
- *" $libdir "*) ;;
- *) finalize_perm_rpath="$finalize_perm_rpath $libdir" ;;
- esac
- fi
- done
- fi
- finalize_rpath="$rpath"
- if test -n "$libobjs" && test "$build_old_libs" = yes; then
- # Transform all the library objects into standard objects.
- compile_command=`$echo "X$compile_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- finalize_command=`$echo "X$finalize_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- fi
- dlsyms=
- if test -n "$NM" && test -n "$global_symbol_pipe"; then
- dlsyms="${outputname}S.c"
- else
- $echo "$modename: not configured to extract global symbols from dlpreopened files" 1>&2
- fi
- fi
- if test -n "$dlsyms"; then
- case $dlsyms in
- *.c)
- # Discover the nlist of each of the dlfiles.
- nlist="$output_objdir/${outputname}.nm"
- $show "$rm $nlist ${nlist}S ${nlist}T"
- $run $rm "$nlist" "${nlist}S" "${nlist}T"
- # Parse the name list into a source file.
- $show "creating $output_objdir/$dlsyms"
- test -z "$run" && $echo > "$output_objdir/$dlsyms" "\
-/* $dlsyms - symbol resolution table for \`$outputname' dlsym emulation. */
-/* Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP */
-#ifdef __cplusplus
-extern \"C\" {
-#endif
-/* Prevent the only kind of declaration conflicts we can make. */
-#define lt_preloaded_symbols some_other_symbol
-/* External symbol declarations for the compiler. */\
- if test "$dlself" = yes; then
- $show "generating symbol list for \`$output'"
- test -z "$run" && $echo ': @PROGRAM@ ' > "$nlist"
- # Add our own program objects to the symbol list.
- progfiles=`$echo "X$objs$old_deplibs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- for arg in $progfiles; do
- $show "extracting global C symbols from \`$arg'"
- $run eval "$NM $arg | $global_symbol_pipe >> '$nlist'"
- done
- if test -n "$exclude_expsyms"; then
- $run eval '$EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
- $run eval '$mv "$nlist"T "$nlist"'
- fi
- $run eval '$EGREP -e "$export_symbols_regex" "$nlist" > "$nlist"T'
- fi
- export_symbols="$output_objdir/$output.exp"
- $run eval "${SED} -n -e '/^: @PROGRAM@$/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
- else
- $run eval "${SED} -e 's/\([][.*^$]\)/\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$output.exp"'
- $run eval 'grep -f "$output_objdir/$output.exp" < "$nlist" > "$nlist"T'
- $run eval 'mv "$nlist"T "$nlist"'
- fi
- fi
- for arg in $dlprefiles; do
- name=`$echo "$arg" | ${SED} -e 's%^.*/%%'`
- $run eval '$echo ": $name " >> "$nlist"'
- done
- if test -z "$run"; then
- # Make sure we have at least an empty file.
- test -f "$nlist" || : > "$nlist"
- $EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
- $mv "$nlist"T "$nlist"
- fi
- # Try sorting and uniquifying the output.
- if grep -v "^: " < "$nlist" |
- if sort -k 3 </dev/null >/dev/null 2>&1; then
- sort -k 3
- else
- sort +2
- fi |
- uniq > "$nlist"S; then
- else
- grep -v "^: " < "$nlist" > "$nlist"S
- fi
- if test -f "$nlist"S; then
- eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$dlsyms"'
- else
- $echo '/* NONE */' >> "$output_objdir/$dlsyms"
- fi
- $echo >> "$output_objdir/$dlsyms" "\
-#undef lt_preloaded_symbols
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[] =
- eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$dlsyms"
- {0, (lt_ptr) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif\
- fi
- pic_flag_for_symtable=
- case $host in
- # compiling the symbol table file with pic_flag works around
- # a FreeBSD bug that causes programs to crash when -lm is
- # linked before any other PIC object. But we must not use
- # pic_flag when linking with -static. The problem exists in
- # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
- *-*-freebsd2*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
- case "$compile_command " in
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag -DFREEBSD_WORKAROUND";;
- esac;;
- *-*-hpux*)
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag";;
- esac
- esac
- # Now compile the dynamic symbol file.
- $show "(cd $output_objdir && $LTCC -c$no_builtin_flag$pic_flag_for_symtable \"$dlsyms\")"
- $run eval '(cd $output_objdir && $LTCC -c$no_builtin_flag$pic_flag_for_symtable "$dlsyms")' || exit $?
- # Clean up the generated files.
- $show "$rm $output_objdir/$dlsyms $nlist ${nlist}S ${nlist}T"
- $run $rm "$output_objdir/$dlsyms" "$nlist" "${nlist}S" "${nlist}T"
- # Transform the symbol file into the correct name.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- $echo "$modename: unknown suffix for \`$dlsyms'" 1>&2
- esac
- else
- # We keep going just in case the user didn't refer to
- # lt_preloaded_symbols. The linker will fail if global_symbol_pipe
- # really was required.
- # Nullify the symbol file.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s% @SYMFILE@%%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s% @SYMFILE@%%"`
- fi
- if test "$need_relink" = no || test "$build_libtool_libs" != yes; then
- # Replace the output file specification.
- compile_command=`$echo "X$compile_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- link_command="$compile_command$compile_rpath"
- # We have no uninstalled library dependencies, so finalize right now.
- $show "$link_command"
- $run eval "$link_command"
- status=$?
- # Delete the generated files.
- $show "$rm $output_objdir/${outputname}S.${objext}"
- $run $rm "$output_objdir/${outputname}S.${objext}"
- fi
- exit $status
- fi
- if test -n "$shlibpath_var"; then
- # We should set the shlibpath_var
- rpath=
- for dir in $temp_rpath; do
- case $dir in
- # Absolute path.
- # Relative path: add a thisdir entry.
- rpath="$rpath\$thisdir/$dir:"
- esac
- done
- temp_rpath="$rpath"
- fi
- if test -n "$compile_shlibpath$finalize_shlibpath"; then
- compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
- fi
- if test -n "$finalize_shlibpath"; then
- finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
- fi
- compile_var=
- finalize_var=
- if test -n "$runpath_var"; then
- if test -n "$perm_rpath"; then
- rpath=
- done
- compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- if test -n "$finalize_perm_rpath"; then
- rpath=
- for dir in $finalize_perm_rpath; do
- done
- finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- fi
- if test "$no_install" = yes; then
- # We don't need to create a wrapper script.
- link_command="$compile_var$compile_command$compile_rpath"
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- # Delete the old output file.
- $run $rm $output
- # Link the executable and exit
- $run eval "$link_command" || exit $?
- fi
- if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- relink_command="$finalize_var$finalize_command$finalize_rpath"
- $echo "$modename: warning: this platform does not like uninstalled shared libraries" 1>&2
- $echo "$modename: \`$output' will be relinked during installation" 1>&2
- else
- if test "$fast_install" != no; then
- link_command="$finalize_var$compile_command$finalize_rpath"
- if test "$fast_install" = yes; then
- relink_command=`$echo "X$compile_var$compile_command$compile_rpath" | $Xsed -e 's%@OUTPUT@%\$progdir/\$file%g'`
- else
- # fast_install is set to needless
- relink_command=
- fi
- else
- fi
- fi
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
- # Delete the old output files.
- $run $rm $output $output_objdir/$outputname $output_objdir/lt-$outputname
- # Now create the wrapper script.
- $show "creating $output"
- # Quote the relink command for shipping.
- if test -n "$relink_command"; then
- # Preserve any variables that may affect compiler behavior
- for var in $variables_saved_for_relink; do
- if eval test -z \"\${$var+set}\"; then
- relink_command="{ test -z \"\${$var+set}\" || unset $var || { $var=; export $var; }; }; $relink_command"
- elif eval var_value=\$$var; test -z "$var_value"; then
- relink_command="$var=; export $var; $relink_command"
- else
- var_value=`$echo "X$var_value" | $Xsed -e "$sed_quote_subst"`
- relink_command="$var=\"$var_value\"; export $var; $relink_command"
- fi
- done
- relink_command="(cd `pwd`; $relink_command)"
- relink_command=`$echo "X$relink_command" | $Xsed -e "$sed_quote_subst"`
- fi
- # Quote $echo for shipping.
- if test "X$echo" = "X$SHELL $progpath --fallback-echo"; then
- case $progpath in
- [\\/]* | [A-Za-z]:[\\/]*) qecho="$SHELL $progpath --fallback-echo";;
- *) qecho="$SHELL `pwd`/$progpath --fallback-echo";;
- esac
- qecho=`$echo "X$qecho" | $Xsed -e "$sed_quote_subst"`
- else
- qecho=`$echo "X$echo" | $Xsed -e "$sed_quote_subst"`
- fi
- # Only actually do things if our run command is non-null.
- # win32 will think the script is a binary if it has
- # a .exe suffix, so we strip it off here.
- case $output in
- *.exe) output=`$echo $output|${SED} 's,.exe$,,'` ;;
- esac
- # test for cygwin because mv fails w/o .exe extensions
- case $host in
- *cygwin*)
- exeext=.exe
- outputname=`$echo $outputname|${SED} 's,.exe$,,'` ;;
- *) exeext= ;;
- esac
- case $host in
- *cygwin* | *mingw* )
- cwrappersource=`$echo ${objdir}/lt-${output}.c`
- cwrapper=`$echo ${output}.exe`
- $rm $cwrappersource $cwrapper
- trap "$rm $cwrappersource $cwrapper; exit $EXIT_FAILURE" 1 2 15
- cat > $cwrappersource <<EOF
-/* $cwrappersource - temporary wrapper executable for $objdir/$outputname
- Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
- The $output program cannot be directly executed until all the libtool
- libraries that it depends on are installed.
- This wrapper executable should never be moved out of the build directory.
- If it is, it will not operate correctly.
- Currently, it simply execs the wrapper *script* "/bin/sh $output",
- but could eventually absorb all of the scripts functionality and
- exec $objdir/$outputname directly.
-EOF
- cat >> $cwrappersource<<"EOF"
-#include <stdio.h>
-#include <stdlib.h>
-#include <unistd.h>
-#include <malloc.h>
-#include <stdarg.h>
-#include <assert.h>
-#if defined(PATH_MAX)
-# define LT_PATHMAX PATH_MAX
-#elif defined(MAXPATHLEN)
-# define LT_PATHMAX MAXPATHLEN
-#else
-# define LT_PATHMAX 1024
-#endif
-#ifndef DIR_SEPARATOR
-#define DIR_SEPARATOR '/'
-#endif
-#if defined (_WIN32) || defined (__MSDOS__) || defined (__DJGPP__) || \
- defined (__OS2__)
-#define HAVE_DOS_BASED_FILE_SYSTEM
-#ifndef DIR_SEPARATOR_2
-#define DIR_SEPARATOR_2 '\\'
-#endif
-#endif
-# define IS_DIR_SEPARATOR(ch) ((ch) == DIR_SEPARATOR)
-#else /* DIR_SEPARATOR_2 */
-# define IS_DIR_SEPARATOR(ch) \
- (((ch) == DIR_SEPARATOR) || ((ch) == DIR_SEPARATOR_2))
-#endif /* DIR_SEPARATOR_2 */
-#define XMALLOC(type, num) ((type *) xmalloc ((num) * sizeof(type)))
-#define XFREE(stale) do { \
- if (stale) { free ((void *) stale); stale = 0; } \
-} while (0)
-const char *program_name = NULL;
-void * xmalloc (size_t num);
-char * xstrdup (const char *string);
-char * basename (const char *name);
-char * fnqualify(const char *path);
-char * strendzap(char *str, const char *pat);
-void lt_fatal (const char *message, ...);
-int
-main (int argc, char *argv[])
- char **newargz;
- int i;
- program_name = (char *) xstrdup ((char *) basename (argv[0]));
- newargz = XMALLOC(char *, argc+2);
-EOF
- cat >> $cwrappersource <<EOF
- newargz[0] = "$SHELL";
-EOF
- cat >> $cwrappersource <<"EOF"
- newargz[1] = fnqualify(argv[0]);
- /* we know the script has the same name, without the .exe */
- /* so make sure newargz[1] doesn't end in .exe */
- strendzap(newargz[1],".exe");
- for (i = 1; i < argc; i++)
- newargz[i+1] = xstrdup(argv[i]);
- newargz[argc+1] = NULL;
-EOF
- execv("$SHELL",newargz);
-EOF
-void *
-xmalloc (size_t num)
- void * p = (void *) malloc (num);
- if (!p)
- lt_fatal ("Memory exhausted");
- return p;
-char *
-xstrdup (const char *string)
- return string ? strcpy ((char *) xmalloc (strlen (string) + 1), string) : NULL
-char *
-basename (const char *name)
- const char *base;
-#if defined (HAVE_DOS_BASED_FILE_SYSTEM)
- /* Skip over the disk name in MSDOS pathnames. */
- if (isalpha (name[0]) && name[1] == ':')
- name += 2;
-#endif
- for (base = name; *name; name++)
- if (IS_DIR_SEPARATOR (*name))
- base = name + 1;
- return (char *) base;
-char *
-fnqualify(const char *path)
- size_t size;
- char *p;
- char tmp[LT_PATHMAX + 1];
- assert(path != NULL);
- /* Is it qualified already? */
- if (isalpha (path[0]) && path[1] == ':')
- return xstrdup (path);
-#endif
- if (IS_DIR_SEPARATOR (path[0]))
- /* prepend the current directory */
- /* doesn't handle '~' */
- if (getcwd (tmp, LT_PATHMAX) == NULL)
- lt_fatal ("getcwd failed");
- size = strlen(tmp) + 1 + strlen(path) + 1; /* +2 for '/' and '\0' */
- p = XMALLOC(char, size);
- sprintf(p, "%s%c%s", tmp, DIR_SEPARATOR, path);
- return p;
-char *
-strendzap(char *str, const char *pat)
- size_t len, patlen;
- assert(str != NULL);
- assert(pat != NULL);
- len = strlen(str);
- patlen = strlen(pat);
- if (patlen <= len)
- str += len - patlen;
- if (strcmp(str, pat) == 0)
- *str = '\0';
- return str;
-static void
-lt_error_core (int exit_status, const char * mode,
- const char * message, va_list ap)
- fprintf (stderr, "%s: %s: ", program_name, mode);
- vfprintf (stderr, message, ap);
- fprintf (stderr, ".\n");
- if (exit_status >= 0)
- exit (exit_status);
-void
-lt_fatal (const char *message, ...)
- va_list ap;
- va_start (ap, message);
- lt_error_core (EXIT_FAILURE, "FATAL", message, ap);
- va_end (ap);
-EOF
- # we should really use a build-platform specific compiler
- # here, but OTOH, the wrappers (shell script and this C one)
- # are only useful if you want to execute the "real" binary.
- # Since the "real" binary is built for $host, then this
- # wrapper might as well be built for $host, too.
- $run $LTCC -s -o $cwrapper $cwrappersource
- esac
- $rm $output
- trap "$rm $output; exit $EXIT_FAILURE" 1 2 15
- $echo > $output "\
-#! $SHELL
-# $output - temporary wrapper script for $objdir/$outputname
-# Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
-# The $output program cannot be directly executed until all the libtool
-# libraries that it depends on are installed.
-# This wrapper script should never be moved out of the build directory.
-# If it is, it will not operate correctly.
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='${SED} -e 1s/^X//'
-sed_quote_subst='$sed_quote_subst'
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test \"\${CDPATH+set}\" = set; then CDPATH=:; export CDPATH; fi
-relink_command=\"$relink_command\"
-# This environment variable determines our operation mode.
-if test \"\$libtool_install_magic\" = \"$magic\"; then
- # install mode needs the following variable:
- notinst_deplibs='$notinst_deplibs'
-else
- # When we are sourced in execute mode, \$file and \$echo are already set.
- if test \"\$libtool_execute_magic\" != \"$magic\"; then
- echo=\"$qecho\"
- file=\"\$0\"
- # Make sure echo works.
- if test \"X\$1\" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
- elif test \"X\`(\$echo '\t') 2>/dev/null\`\" = 'X\t'; then
- # Yippee, \$echo works!
- else
- # Restart under the correct shell, and then maybe \$echo will work.
- exec $SHELL \"\$0\" --no-reexec \${1+\"\$@\"}
- fi
- fi\
- $echo >> $output "\
- # Find the directory that this script lives in.
- thisdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*$%%'\`
- test \"x\$thisdir\" = \"x\$file\" && thisdir=.
- # Follow symbolic links until we get to the real thisdir.
- file=\`ls -ld \"\$file\" | ${SED} -n 's/.*-> //p'\`
- while test -n \"\$file\"; do
- destdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*\$%%'\`
- # If there was a directory component, then change thisdir.
- if test \"x\$destdir\" != \"x\$file\"; then
- case \"\$destdir\" in
- [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
- *) thisdir=\"\$thisdir/\$destdir\" ;;
- esac
- fi
- file=\`\$echo \"X\$file\" | \$Xsed -e 's%^.*/%%'\`
- file=\`ls -ld \"\$thisdir/\$file\" | ${SED} -n 's/.*-> //p'\`
- done
- # Try to get the absolute directory name.
- absdir=\`cd \"\$thisdir\" && pwd\`
- test -n \"\$absdir\" && thisdir=\"\$absdir\"
- program=lt-'$outputname'$exeext
- progdir=\"\$thisdir/$objdir\"
- if test ! -f \"\$progdir/\$program\" || \\
- { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | ${SED} 1q\`; \\
- test \"X\$file\" != \"X\$progdir/\$program\"; }; then
- file=\"\$\$-\$program\"
- if test ! -d \"\$progdir\"; then
- $mkdir \"\$progdir\"
- else
- $rm \"\$progdir/\$file\"
- fi"
- # relink executable if necessary
- if test -n \"\$relink_command\"; then
- if relink_command_output=\`eval \$relink_command 2>&1\`; then :
- else
- $echo \"\$relink_command_output\" >&2
- fi
- fi
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
- { $rm \"\$progdir/\$program\";
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\"; }
- fi"
- else
- program='$outputname'
- fi
- if test -f \"\$progdir/\$program\"; then"
- # Export our shlibpath_var if we have one.
- if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
- # Add our own library path to $shlibpath_var
- $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
- # Some systems cannot cope with colon-terminated $shlibpath_var
- # The second colon is a workaround for a bug in BeOS R4 sed
- $shlibpath_var=\`\$echo \"X\$$shlibpath_var\" | \$Xsed -e 's/::*\$//'\`
- export $shlibpath_var
- fi
- # fixup the dll searchpath if we need to.
- if test -n "$dllsearchpath"; then
- # Add the dll search path components to the executable PATH
- PATH=$dllsearchpath:\$PATH
- fi
- # Run the actual program with our arguments.
- case $host in
- # Backslashes separate directories on plain windows
- *-*-mingw | *-*-os2*)
- exec \$progdir\\\\\$program \${1+\"\$@\"}
- exec \$progdir/\$program \${1+\"\$@\"}
- esac
- \$echo \"\$0: cannot exec \$program \${1+\"\$@\"}\"
- fi
- else
- # The program doesn't exist.
- \$echo \"\$0: error: \$progdir/\$program does not exist\" 1>&2
- \$echo \"This script is just a wrapper for \$program.\" 1>&2
- $echo \"See the $PACKAGE documentation for more information.\" 1>&2
- fi
-fi\
- chmod +x $output
- fi
- esac
- # See if we need to build an old-fashioned archive.
- for oldlib in $oldlibs; do
- if test "$build_libtool_libs" = convenience; then
- oldobjs="$libobjs_save"
- addlibs="$convenience"
- else
- if test "$build_libtool_libs" = module; then
- else
- oldobjs="$old_deplibs $non_pic_objects"
- fi
- addlibs="$old_convenience"
- fi
- if test -n "$addlibs"; then
- status=$?
- exit $status
- fi
- # Add in members from convenience archives.
- for xlib in $addlibs; do
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- else
- do
- i=1
- do
- name_to="$name"
- do
- done
- i=`expr $i + 1`
- done
- done
- fi
- oldobjs="$oldobjs "`find $xdir -name \*.${objext} -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- # Do each command in the archive commands.
- if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
- cmds=$old_archive_from_new_cmds
- else
- eval cmds=\"$old_archive_cmds\"
- if len=`expr "X$cmds" : ".*"` &&
- cmds=$old_archive_cmds
- else
- # the command line is too long to link in one step, link in parts
- $echo "using piecewise archive linking..."
- save_RANLIB=$RANLIB
- RANLIB=:
- objlist=
- concat_cmds=
- save_oldobjs=$oldobjs
- # GNU ar 2.10+ was changed to match POSIX; thus no paths are
- # encoded into archives. This makes 'ar r' malfunction in
- # this piecewise linking case whenever conflicting object
- # names appear in distinct ar calls; check, warn and compensate.
- if (for obj in $save_oldobjs
- do
- $echo "X$obj" | $Xsed -e 's%^.*/%%'
- done | sort | sort -uc >/dev/null 2>&1); then
- else
- $echo "$modename: warning: object name conflicts; overriding AR_FLAGS to 'cq'" 1>&2
- $echo "$modename: warning: to ensure that POSIX-compatible ar will work" 1>&2
- AR_FLAGS=cq
- fi
- # Is there a better way of finding the last object in the list?
- for obj in $save_oldobjs
- do
- last_oldobj=$obj
- done
- do
- oldobjs="$objlist $obj"
- eval test_cmds=\"$old_archive_cmds\"
- if len=`expr "X$test_cmds" : ".*"` &&
- test "$len" -le "$max_cmd_len"; then
- else
- # the above command should be used before it gets too long
- oldobjs=$objlist
- if test "$obj" = "$last_oldobj" ; then
- RANLIB=$save_RANLIB
- fi
- eval concat_cmds=\"\${concat_cmds}$old_archive_cmds\"
- objlist=
- fi
- done
- oldobjs=$objlist
- if test "X$oldobjs" = "X" ; then
- eval cmds=\"\$concat_cmds\"
- else
- eval cmds=\"\$concat_cmds~\$old_archive_cmds\"
- fi
- fi
- fi
- eval cmd=\"$cmd\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || exit $?
- done
- IFS="$save_ifs"
- done
- if test -n "$generated"; then
- $show "${rm}r$generated"
- $run ${rm}r$generated
- fi
- # Now create the libtool archive.
- case $output in
- *.la)
- old_library=
- test "$build_old_libs" = yes && old_library="$libname.$libext"
- else
- fi
- done
- # Quote the link command for shipping.
- relink_command="(cd `pwd`; $SHELL $progpath $preserve_args --mode=relink $libtool_args @inst_prefix_dir@)"
- if test "$hardcode_automatic" = yes ; then
- relink_command=
- fi
- # Only create the output if not a dry run.
- for installed in no yes; do
- if test "$installed" = yes; then
- if test -z "$install_libdir"; then
- break
- fi
- output="$output_objdir/$outputname"i
- # Replace all uninstalled libtool libraries with the installed ones
- newdependency_libs=
- for deplib in $dependency_libs; do
- case $deplib in
- *.la)
- name=`$echo "X$deplib" | $Xsed -e 's%^.*/%%'`
- if test -z "$libdir"; then
- fi
- newdependency_libs="$newdependency_libs $libdir/$name"
- *) newdependency_libs="$newdependency_libs $deplib" ;;
- esac
- done
- newdlfiles=
- for lib in $dlfiles; do
- name=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
- $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
- fi
- newdlfiles="$newdlfiles $libdir/$name"
- done
- newdlprefiles=
- for lib in $dlprefiles; do
- fi
- newdlprefiles="$newdlprefiles $libdir/$name"
- done
- else
- newdlfiles=
- case $lib in
- [\\/]* | [A-Za-z]:[\\/]*) abs="$lib" ;;
- *) abs=`pwd`"/$lib" ;;
- esac
- newdlfiles="$newdlfiles $abs"
- done
- newdlprefiles=
- case $lib in
- esac
- newdlprefiles="$newdlprefiles $abs"
- done
- fi
- $rm $output
- # place dlname in correct position for cygwin
- tdlname=$dlname
- case $host,$output,$installed,$module,$dlname in
- *cygwin*,*lai,yes,no,*.dll | *mingw*,*lai,yes,no,*.dll) tdlname=../bin/$dlname ;;
- esac
-# $outputname - a libtool library file
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# The name that we can dlopen(3).
-dlname='$tdlname'
-# Names of this library.
-library_names='$library_names'
-# The name of the static archive.
-old_library='$old_library'
-# Libraries that this one depends upon.
-dependency_libs='$dependency_libs'
-# Version information for $libname.
-current=$current
-age=$age
-revision=$revision
-# Is this an already installed library?
-installed=$installed
-# Should we warn about portability when linking against -modules?
-shouldnotlink=$module
-# Files to dlopen/dlpreopen
-dlopen='$dlfiles'
-dlpreopen='$dlprefiles'
-# Directory that this library needs to be installed in:
-libdir='$install_libdir'"
- if test "$installed" = no && test "$need_relink" = yes; then
-relink_command=\"$relink_command\""
- fi
- done
- fi
- # Do a symbolic link so that the libtool archive can be found in
- # LD_LIBRARY_PATH before the program is installed.
- $show "(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)"
- $run eval '(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)' || exit $?
- esac
- # libtool install mode
- install)
- modename="$modename: install"
- # There may be an optional sh(1) argument at the beginning of
- # install_prog (especially on Windows NT).
- if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
- # Allow the use of GNU shtool's install command.
- $echo "X$nonopt" | $Xsed | grep shtool > /dev/null; then
- # Aesthetically quote it.
- arg=`$echo "X$nonopt" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$arg "
- arg="$1"
- shift
- else
- install_prog=
- arg="$nonopt"
- fi
- # The real first argument should be the name of the installation program.
- arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog$arg"
- # We need to accept at least all the BSD install flags.
- dest=
- files=
- opts=
- prev=
- install_type=
- isdir=no
- stripme=
- for arg
- do
- if test -n "$dest"; then
- files="$files $dest"
- dest="$arg"
- continue
- fi
- case $arg in
- -d) isdir=yes ;;
- -f) prev="-f" ;;
- -g) prev="-g" ;;
- -m) prev="-m" ;;
- -o) prev="-o" ;;
- -s)
- stripme=" -s"
- continue
- # If the previous option needed an argument, then skip it.
- if test -n "$prev"; then
- prev=
- else
- dest="$arg"
- continue
- fi
- esac
- # Aesthetically quote the argument.
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog $arg"
- done
- if test -z "$install_prog"; then
- $echo "$modename: you must specify an install program" 1>&2
- fi
- $echo "$modename: the \`$prev' option requires an argument" 1>&2
- fi
- if test -z "$files"; then
- if test -z "$dest"; then
- $echo "$modename: no file or destination specified" 1>&2
- else
- $echo "$modename: you must specify a destination" 1>&2
- fi
- fi
- # Strip any trailing slash from the destination.
- dest=`$echo "X$dest" | $Xsed -e 's%/$%%'`
- # Check to see that the destination is a directory.
- test -d "$dest" && isdir=yes
- if test "$isdir" = yes; then
- destdir="$dest"
- destname=
- else
- destdir=`$echo "X$dest" | $Xsed -e 's%/[^/]*$%%'`
- test "X$destdir" = "X$dest" && destdir=.
- destname=`$echo "X$dest" | $Xsed -e 's%^.*/%%'`
- # Not a directory, so check to see that there is only one file specified.
- set dummy $files
- $echo "$modename: \`$dest' is not a directory" 1>&2
- fi
- fi
- case $destdir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- for file in $files; do
- case $file in
- *.lo) ;;
- $echo "$modename: \`$destdir' must be an absolute directory name" 1>&2
- esac
- done
- esac
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- staticlibs=
- future_libdirs=
- current_libdirs=
- # Do each installation.
- case $file in
- *.$libext)
- # Do the static libraries later.
- staticlibs="$staticlibs $file"
- *.la)
- # Check to see that this really is a libtool archive.
- if (${SED} -e '2q' $file | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- $echo "$modename: \`$file' is not a valid libtool archive" 1>&2
- fi
- library_names=
- old_library=
- relink_command=
- # If there is no directory component, then add one.
- case $file in
- */* | *\\*) . $file ;;
- *) . ./$file ;;
- esac
- # Add the libdir to current_libdirs if it is the destination.
- if test "X$destdir" = "X$libdir"; then
- case "$current_libdirs " in
- *" $libdir "*) ;;
- *) current_libdirs="$current_libdirs $libdir" ;;
- esac
- else
- # Note the libdir as a future libdir.
- case "$future_libdirs " in
- *" $libdir "*) ;;
- *) future_libdirs="$future_libdirs $libdir" ;;
- esac
- fi
- dir=`$echo "X$file" | $Xsed -e 's%/[^/]*$%%'`/
- test "X$dir" = "X$file/" && dir=
- dir="$dir$objdir"
- # Determine the prefix the user has applied to our future dir.
- inst_prefix_dir=`$echo "$destdir" | $SED "s%$libdir\$%%"`
- # Don't allow the user to place us outside of our expected
- # location b/c this prevents finding dependent libraries that
- # are installed to the same prefix.
- # At present, this check doesn't affect windows .dll's that
- # are installed into $libdir/../bin (currently, that works fine)
- # but it's something to keep an eye on.
- if test "$inst_prefix_dir" = "$destdir"; then
- $echo "$modename: error: cannot install \`$file' to a directory not ending in $libdir" 1>&2
- fi
- if test -n "$inst_prefix_dir"; then
- # Stick the inst_prefix_dir data into the link command.
- relink_command=`$echo "$relink_command" | $SED "s%@inst_prefix_dir@%-inst-prefix-dir $inst_prefix_dir%"`
- else
- relink_command=`$echo "$relink_command" | $SED "s%@inst_prefix_dir@%%"`
- fi
- $echo "$modename: warning: relinking \`$file'" 1>&2
- $show "$relink_command"
- if $run eval "$relink_command"; then :
- else
- $echo "$modename: error: relink \`$file' with the above command before installing it" 1>&2
- fi
- fi
- # See the names of the shared library.
- set dummy $library_names
- if test -n "$2"; then
- realname="$2"
- shift
- shift
- srcname="$realname"
- test -n "$relink_command" && srcname="$realname"T
- # Install the shared library and build the symlinks.
- $show "$install_prog $dir/$srcname $destdir/$realname"
- $run eval "$install_prog $dir/$srcname $destdir/$realname" || exit $?
- if test -n "$stripme" && test -n "$striplib"; then
- $show "$striplib $destdir/$realname"
- $run eval "$striplib $destdir/$realname" || exit $?
- fi
- if test "$#" -gt 0; then
- # Delete the old symlinks, and create new ones.
- for linkname
- do
- if test "$linkname" != "$realname"; then
- $show "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- fi
- done
- fi
- # Do each command in the postinstall commands.
- lib="$destdir/$realname"
- cmds=$postinstall_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # Install the pseudo-library for information purposes.
- name=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- instname="$dir/$name"i
- $show "$install_prog $instname $destdir/$name"
- $run eval "$install_prog $instname $destdir/$name" || exit $?
- # Maybe install the static library, too.
- test -n "$old_library" && staticlibs="$staticlibs $dir/$old_library"
- *.lo)
- # Install (i.e. copy) a libtool object.
- # Figure out destination file name, if it wasn't already specified.
- if test -n "$destname"; then
- destfile="$destdir/$destname"
- else
- destfile=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- destfile="$destdir/$destfile"
- fi
- # Deduce the name of the destination old-style object file.
- case $destfile in
- *.lo)
- staticdest=`$echo "X$destfile" | $Xsed -e "$lo2o"`
- *.$objext)
- staticdest="$destfile"
- destfile=
- $echo "$modename: cannot copy a libtool object to \`$destfile'" 1>&2
- $echo "$help" 1>&2
- esac
- # Install the libtool object if requested.
- if test -n "$destfile"; then
- $show "$install_prog $file $destfile"
- $run eval "$install_prog $file $destfile" || exit $?
- fi
- # Install the old object if enabled.
- if test "$build_old_libs" = yes; then
- # Deduce the name of the old-style object file.
- staticobj=`$echo "X$file" | $Xsed -e "$lo2o"`
- $show "$install_prog $staticobj $staticdest"
- $run eval "$install_prog \$staticobj \$staticdest" || exit $?
- fi
- else
- fi
- # If the file is missing, and there is a .exe on the end, strip it
- # because it is most likely a libtool script we actually want to
- # install
- stripped_ext=""
- case $file in
- *.exe)
- if test ! -f "$file"; then
- file=`$echo $file|${SED} 's,.exe$,,'`
- stripped_ext=".exe"
- fi
- esac
- # Do a test to see if this is really a libtool program.
- case $host in
- *cygwin*|*mingw*)
- wrapper=`$echo $file | ${SED} -e 's,.exe$,,'`
- wrapper=$file
- esac
- if (${SED} -e '4q' $wrapper | grep "^# Generated by .*$PACKAGE")>/dev/null 2>&1; then
- notinst_deplibs=
- relink_command=
- # To insure that "foo" is sourced, and not "foo.exe",
- # finese the cygwin/MSYS system by explicitly sourcing "foo."
- # which disallows the automatic-append-.exe behavior.
- case $build in
- *cygwin* | *mingw*) wrapperdot=${wrapper}. ;;
- *) wrapperdot=${wrapper} ;;
- esac
- case $file in
- */* | *\\*) . ${wrapperdot} ;;
- *) . ./${wrapperdot} ;;
- esac
- # Check the variables that should have been set.
- if test -z "$notinst_deplibs"; then
- $echo "$modename: invalid libtool wrapper script \`$wrapper'" 1>&2
- fi
- finalize=yes
- for lib in $notinst_deplibs; do
- # Check to see that each library is installed.
- libdir=
- if test -f "$lib"; then
- case $lib in
- */* | *\\*) . $lib ;;
- *) . ./$lib ;;
- esac
- fi
- libfile="$libdir/"`$echo "X$lib" | $Xsed -e 's%^.*/%%g'` ### testsuite: skip nested quoting test
- if test -n "$libdir" && test ! -f "$libfile"; then
- $echo "$modename: warning: \`$lib' has not been installed in \`$libdir'" 1>&2
- finalize=no
- fi
- done
- relink_command=
- case $build in
- esac
- case $file in
- esac
- outputname=
- if test "$fast_install" = no && test -n "$relink_command"; then
- if test "$finalize" = yes && test -z "$run"; then
- tmpdir="/tmp"
- test -n "$TMPDIR" && tmpdir="$TMPDIR"
- tmpdir="$tmpdir/libtool-$$"
- save_umask=`umask`
- umask 0077
- if $mkdir "$tmpdir"; then
- umask $save_umask
- else
- umask $save_umask
- $echo "$modename: error: cannot create temporary directory \`$tmpdir'" 1>&2
- continue
- fi
- file=`$echo "X$file$stripped_ext" | $Xsed -e 's%^.*/%%'`
- outputname="$tmpdir/$file"
- relink_command=`$echo "X$relink_command" | $Xsed -e 's%@OUTPUT@%'"$outputname"'%g'`
- else
- ${rm}r "$tmpdir"
- continue
- fi
- file="$outputname"
- else
- $echo "$modename: warning: cannot relink \`$file'" 1>&2
- fi
- else
- # Install the binary that we compiled earlier.
- file=`$echo "X$file$stripped_ext" | $Xsed -e "s%\([^/]*\)$%$objdir/\1%"`
- fi
- fi
- # remove .exe since cygwin /usr/bin/install will append another
- # one anyways
- case $install_prog,$host in
- */usr/bin/install*,*cygwin*)
- case $file:$destfile in
- *.exe:*.exe)
- # this is ok
- *.exe:*)
- destfile=$destfile.exe
- *:*.exe)
- destfile=`$echo $destfile | ${SED} -e 's,.exe$,,'`
- esac
- esac
- $show "$install_prog$stripme $file $destfile"
- $run eval "$install_prog\$stripme \$file \$destfile" || exit $?
- test -n "$outputname" && ${rm}r "$tmpdir"
- esac
- done
- for file in $staticlibs; do
- # Set up the ranlib parameters.
- oldlib="$destdir/$name"
- $show "$install_prog $file $oldlib"
- $run eval "$install_prog \$file \$oldlib" || exit $?
- if test -n "$stripme" && test -n "$old_striplib"; then
- $show "$old_striplib $oldlib"
- $run eval "$old_striplib $oldlib" || exit $?
- fi
- cmds=$old_postinstall_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- done
- IFS="$save_ifs"
- done
- if test -n "$future_libdirs"; then
- $echo "$modename: warning: remember to run \`$progname --finish$future_libdirs'" 1>&2
- fi
- if test -n "$current_libdirs"; then
- # Maybe just do a dry run.
- test -n "$run" && current_libdirs=" -n$current_libdirs"
- exec_cmd='$SHELL $progpath $preserve_args --finish$current_libdirs'
- else
- fi
- # libtool finish mode
- finish)
- modename="$modename: finish"
- libdirs="$nonopt"
- admincmds=
- if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
- for dir
- do
- libdirs="$libdirs $dir"
- done
- for libdir in $libdirs; do
- if test -n "$finish_cmds"; then
- # Do each command in the finish commands.
- cmds=$finish_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- $run eval "$cmd" || admincmds="$admincmds
- $cmd"
- done
- IFS="$save_ifs"
- fi
- if test -n "$finish_eval"; then
- # Do the single finish_eval.
- eval cmds=\"$finish_eval\"
- $run eval "$cmds" || admincmds="$admincmds
- $cmds"
- fi
- done
- fi
- # Exit here if they wanted silent mode.
- test "$show" = : && exit $EXIT_SUCCESS
- $echo "----------------------------------------------------------------------"
- $echo "Libraries have been installed in:"
- $echo " $libdir"
- done
- $echo
- $echo "If you ever happen to want to link against installed libraries"
- $echo "in a given directory, LIBDIR, you must either use libtool, and"
- $echo "specify the full pathname of the library, or use the \`-LLIBDIR'"
- $echo "flag during linking and do at least one of the following:"
- $echo " - add LIBDIR to the \`$shlibpath_var' environment variable"
- $echo " during execution"
- fi
- $echo " - add LIBDIR to the \`$runpath_var' environment variable"
- $echo " during linking"
- fi
- libdir=LIBDIR
- $echo " - use the \`$flag' linker flag"
- fi
- if test -n "$admincmds"; then
- $echo " - have your system administrator run these commands:$admincmds"
- fi
- if test -f /etc/ld.so.conf; then
- $echo " - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
- fi
- $echo
- $echo "See any operating system documentation about shared libraries for"
- $echo "more information, such as the ld(1) and ld.so(8) manual pages."
- # libtool execute mode
- execute)
- modename="$modename: execute"
- # The first argument is the command name.
- cmd="$nonopt"
- if test -z "$cmd"; then
- $echo "$modename: you must specify a COMMAND" 1>&2
- $echo "$help"
- fi
- # Handle -dlopen flags immediately.
- for file in $execute_dlfiles; do
- $echo "$modename: \`$file' is not a file" 1>&2
- fi
- dir=
- case $file in
- *.la)
- else
- fi
- # Read the libtool library.
- dlname=
- library_names=
- case $file in
- *) . ./$file ;;
- esac
- # Skip this library if it cannot be dlopened.
- # Warn if it was a shared library.
- test -n "$library_names" && $echo "$modename: warning: \`$file' was not linked with \`-export-dynamic'"
- continue
- fi
- test "X$dir" = "X$file" && dir=.
- if test -f "$dir/$objdir/$dlname"; then
- dir="$dir/$objdir"
- else
- $echo "$modename: cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'" 1>&2
- fi
- *.lo)
- # Just add the directory containing the .lo file.
- $echo "$modename: warning \`-dlopen' is ignored for non-libtool libraries and objects" 1>&2
- continue
- esac
- # Get the absolute pathname.
- absdir=`cd "$dir" && pwd`
- test -n "$absdir" && dir="$absdir"
- # Now add the directory to shlibpath_var.
- if eval "test -z \"\$$shlibpath_var\""; then
- eval "$shlibpath_var=\"\$dir\""
- else
- eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
- fi
- done
- # This variable tells wrapper scripts just to set shlibpath_var
- # rather than running their programs.
- libtool_execute_magic="$magic"
- # Check if any of the arguments is a wrapper script.
- args=
- for file
- do
- case $file in
- if (${SED} -e '4q' $file | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- case $file in
- *) . ./$file ;;
- esac
- # Transform arg to wrapped name.
- file="$progdir/$program"
- fi
- esac
- # Quote arguments (to preserve shell metacharacters).
- file=`$echo "X$file" | $Xsed -e "$sed_quote_subst"`
- args="$args \"$file\""
- done
- # Export the shlibpath_var.
- eval "export $shlibpath_var"
- fi
- # Restore saved environment variables
- if test "${save_LC_ALL+set}" = set; then
- LC_ALL="$save_LC_ALL"; export LC_ALL
- fi
- if test "${save_LANG+set}" = set; then
- LANG="$save_LANG"; export LANG
- fi
- # Now prepare to actually exec the command.
- exec_cmd="\$cmd$args"
- else
- # Display what would be done.
- eval "\$echo \"\$shlibpath_var=\$$shlibpath_var\""
- $echo "export $shlibpath_var"
- fi
- $echo "$cmd$args"
- fi
- # libtool clean and uninstall mode
- clean | uninstall)
- modename="$modename: $mode"
- rm="$nonopt"
- files=
- rmforce=
- exit_status=0
- for arg
- do
- case $arg in
- -f) rm="$rm $arg"; rmforce=yes ;;
- -*) rm="$rm $arg" ;;
- *) files="$files $arg" ;;
- esac
- done
- if test -z "$rm"; then
- $echo "$modename: you must specify an RM program" 1>&2
- fi
- rmdirs=
- origobjdir="$objdir"
- if test "X$dir" = "X$file"; then
- dir=.
- objdir="$origobjdir"
- else
- objdir="$dir/$origobjdir"
- fi
- test "$mode" = uninstall && objdir="$dir"
- # Remember objdir for removal later, being careful to avoid duplicates
- if test "$mode" = clean; then
- case " $rmdirs " in
- *" $objdir "*) ;;
- *) rmdirs="$rmdirs $objdir" ;;
- esac
- fi
- # Don't error if the file doesn't exist and rm -f was used.
- if (test -L "$file") >/dev/null 2>&1 \
- || (test -h "$file") >/dev/null 2>&1 \
- || test -f "$file"; then
- elif test -d "$file"; then
- exit_status=1
- continue
- elif test "$rmforce" = yes; then
- continue
- fi
- rmfiles="$file"
- case $name in
- *.la)
- # Possibly a libtool archive, so verify it.
- . $dir/$name
- # Delete the libtool libraries and symlinks.
- for n in $library_names; do
- rmfiles="$rmfiles $objdir/$n"
- done
- test -n "$old_library" && rmfiles="$rmfiles $objdir/$old_library"
- test "$mode" = clean && rmfiles="$rmfiles $objdir/$name $objdir/${name}i"
- if test "$mode" = uninstall; then
- if test -n "$library_names"; then
- # Do each command in the postuninstall commands.
- cmds=$postuninstall_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- $run eval "$cmd"
- if test "$?" -ne 0 && test "$rmforce" != yes; then
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- if test -n "$old_library"; then
- # Do each command in the old_postuninstall commands.
- cmds=$old_postuninstall_cmds
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $show "$cmd"
- $run eval "$cmd"
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- # FIXME: should reinstall the best remaining shared library.
- fi
- fi
- *.lo)
- # Possibly a libtool object, so verify it.
- # Read the .lo file
- . $dir/$name
- # Add PIC object to the list of files to remove.
- if test -n "$pic_object" \
- && test "$pic_object" != none; then
- rmfiles="$rmfiles $dir/$pic_object"
- fi
- # Add non-PIC object to the list of files to remove.
- if test -n "$non_pic_object" \
- && test "$non_pic_object" != none; then
- rmfiles="$rmfiles $dir/$non_pic_object"
- fi
- fi
- if test "$mode" = clean ; then
- noexename=$name
- case $file in
- *.exe)
- noexename=`$echo $name|${SED} 's,.exe$,,'`
- # $file with .exe has already been added to rmfiles,
- # add $file without .exe
- rmfiles="$rmfiles $file"
- esac
- # Do a test to see if this is a libtool program.
- relink_command=
- . $dir/$noexename
- # note $name still contains .exe if it was in $file originally
- # as does the version of $file that was added into $rmfiles
- rmfiles="$rmfiles $objdir/$name $objdir/${name}S.${objext}"
- if test "$fast_install" = yes && test -n "$relink_command"; then
- rmfiles="$rmfiles $objdir/lt-$name"
- fi
- if test "X$noexename" != "X$name" ; then
- rmfiles="$rmfiles $objdir/lt-${noexename}.c"
- fi
- fi
- fi
- esac
- $show "$rm $rmfiles"
- $run $rm $rmfiles || exit_status=1
- done
- # Try to remove the ${objdir}s in the directories where we deleted files
- for dir in $rmdirs; do
- if test -d "$dir"; then
- $show "rmdir $dir"
- $run rmdir $dir >/dev/null 2>&1
- fi
- done
- exit $exit_status
- $echo "$modename: you must specify a MODE" 1>&2
- $echo "$generic_help" 1>&2
- esac
- if test -z "$exec_cmd"; then
- $echo "$modename: invalid operation mode \`$mode'" 1>&2
- fi
-fi # test -z "$show_help"
-if test -n "$exec_cmd"; then
- eval exec $exec_cmd
-fi
-# We need to display help for each of the modes.
-case $mode in
-"") $echo \
-"Usage: $modename [OPTION]... [MODE-ARG]...
-Provide generalized library-building support services.
- --config show all configuration variables
- --debug enable verbose shell tracing
--n, --dry-run display commands without modifying any files
- --features display basic configuration information and exit
- --finish same as \`--mode=finish'
- --help display this help message and exit
- --mode=MODE use operation mode MODE [default=inferred from MODE-ARGS]
- --quiet same as \`--silent'
- --silent don't print informational messages
- --tag=TAG use configuration variables from tag TAG
- --version print version information
-MODE must be one of the following:
- clean remove files from the build directory
- compile compile a source file into a libtool object
- execute automatically set library path, then run a program
- finish complete the installation of libtool libraries
- install install libraries or executables
- link create a library or an executable
- uninstall remove libraries from an installed directory
-MODE-ARGS vary depending on the MODE. Try \`$modename --help --mode=MODE' for
-a more detailed description of MODE.
-Report bugs to <bug-libtool at gnu.org>."
-clean)
- $echo \
-"Usage: $modename [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
-Remove files from the build directory.
-RM is the name of the program to use to delete files associated with each FILE
-(typically \`/bin/rm'). RM-OPTIONS are options (such as \`-f') to be passed
-to RM.
-If FILE is a libtool library, object or program, all the files associated
-with it are deleted. Otherwise, only FILE itself is deleted using RM."
-compile)
- $echo \
-"Usage: $modename [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
-Compile a source file into a libtool library object.
-This mode accepts the following additional options:
- -o OUTPUT-FILE set the output file name to OUTPUT-FILE
- -prefer-pic try to building PIC objects only
- -prefer-non-pic try to building non-PIC objects only
- -static always build a \`.o' file suitable for static linking
-COMPILE-COMMAND is a command to be used in creating a \`standard' object file
-from the given SOURCEFILE.
-The output file name is determined by removing the directory component from
-SOURCEFILE, then substituting the C source code suffix \`.c' with the
-library object suffix, \`.lo'."
-execute)
- $echo \
-"Usage: $modename [OPTION]... --mode=execute COMMAND [ARGS]...
-Automatically set library path, then run a program.
- -dlopen FILE add the directory containing FILE to the library path
-This mode sets the library path environment variable according to \`-dlopen'
-flags.
-If any of the ARGS are libtool executable wrappers, then they are translated
-into their corresponding uninstalled binary, and any of their required library
-directories are added to the library path.
-Then, COMMAND is executed, with ARGS as arguments."
-finish)
- $echo \
-"Usage: $modename [OPTION]... --mode=finish [LIBDIR]...
-Complete the installation of libtool libraries.
-Each LIBDIR is a directory that contains libtool libraries.
-The commands that this mode executes may require superuser privileges. Use
-the \`--dry-run' option if you just want to see what would be executed."
-install)
- $echo \
-"Usage: $modename [OPTION]... --mode=install INSTALL-COMMAND...
-Install executables or libraries.
-INSTALL-COMMAND is the installation command. The first component should be
-either the \`install' or \`cp' program.
-The rest of the components are interpreted as arguments to that command (only
-BSD-compatible install options are recognized)."
-link)
- $echo \
-"Usage: $modename [OPTION]... --mode=link LINK-COMMAND...
-Link object files or libraries together to form another library, or to
-create an executable program.
-LINK-COMMAND is a command using the C compiler that you would use to create
-a program from several object files.
-The following components of LINK-COMMAND are treated specially:
- -all-static do not do any dynamic linking at all
- -avoid-version do not add a version suffix if possible
- -dlopen FILE \`-dlpreopen' FILE if it cannot be dlopened at runtime
- -dlpreopen FILE link in FILE and add its symbols to lt_preloaded_symbols
- -export-dynamic allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
- -export-symbols SYMFILE
- try to export only the symbols listed in SYMFILE
- -export-symbols-regex REGEX
- try to export only the symbols matching REGEX
- -LLIBDIR search LIBDIR for required installed libraries
- -lNAME OUTPUT-FILE requires the installed library libNAME
- -module build a library that can dlopened
- -no-fast-install disable the fast-install mode
- -no-install link a not-installable executable
- -no-undefined declare that a library does not refer to external symbols
- -o OUTPUT-FILE create OUTPUT-FILE from the specified objects
- -objectlist FILE Use a list of object files found in FILE to specify objects
- -precious-files-regex REGEX
- don't remove output files matching REGEX
- -release RELEASE specify package release information
- -rpath LIBDIR the created library will eventually be installed in LIBDIR
- -R[ ]LIBDIR add LIBDIR to the runtime path of programs and libraries
- -static do not do any dynamic linking of libtool libraries
- -version-info CURRENT[:REVISION[:AGE]]
- specify library version info [each variable defaults to 0]
-All other options (arguments beginning with \`-') are ignored.
-Every other argument is treated as a filename. Files ending in \`.la' are
-treated as uninstalled libtool libraries, other files are standard or library
-object files.
-If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
-only library objects (\`.lo' files) may be specified, and \`-rpath' is
-required, except when creating a convenience library.
-If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
-using \`ar' and \`ranlib', or on Windows using \`lib'.
-If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
-is created, otherwise an executable program is created."
-uninstall)
- $echo \
-"Usage: $modename [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
-Remove libraries from an installation directory.
-to RM.
-If FILE is a libtool library, all the files associated with it are deleted.
-Otherwise, only FILE itself is deleted using RM."
-esac
-$echo
-$echo "Try \`$modename --help' for more information about other modes."
-exit $EXIT_SUCCESS
-# The TAGs below are defined such that we never get into a situation
-# in which we disable both kinds of libraries. Given conflicting
-# choices, we go for a static library, that is the most portable,
-# since we can't tell whether shared libraries were disabled because
-# the user asked for that or because the platform doesn't support
-# them. This is particularly important on AIX, because we don't
-# support having both static and shared libraries enabled at the same
-# time on that platform, so we default to a shared-only configuration.
-# If a disable-shared tag is given, we'll fallback to a static-only
-# configuration. But we'll never go from static-only to shared-only.
-# ### BEGIN LIBTOOL TAG CONFIG: disable-shared
-build_libtool_libs=no
-build_old_libs=yes
-# ### END LIBTOOL TAG CONFIG: disable-shared
-# ### BEGIN LIBTOOL TAG CONFIG: disable-static
-build_old_libs=`case $build_libtool_libs in yes) $echo no;; *) $echo yes;; esac`
-# ### END LIBTOOL TAG CONFIG: disable-static
-# Local Variables:
-# mode:shell-script
-# sh-indentation:2
-# End:
More information about the mpich2-commits
