[mpich2-commits] r4121 - in mpich2/trunk/src/pm/hydra: . bootstrap bootstrap/slurm
balaji at mcs.anl.gov
Wed Mar 18 14:46:13 CDT 2009
Author: balaji
Date: 2009-03-18 14:46:13 -0500 (Wed, 18 Mar 2009)
New Revision: 4121
Added:
mpich2/trunk/src/pm/hydra/bootstrap/slurm/
mpich2/trunk/src/pm/hydra/bootstrap/slurm/Makefile.sm
mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm.h
mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_init.c
mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c
Modified:
mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm
mpich2/trunk/src/pm/hydra/configure.in
Log:
Initial support for slurm (ticket #443).
Modified: mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm
--- mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm 2009-03-18 19:14:41 UTC (rev 4120)
+++ mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm 2009-03-18 19:46:13 UTC (rev 4121)
@@ -4,5 +4,5 @@
# See COPYRIGHT in top-level directory.
-SUBDIRS_hydra_bss_names = ssh fork
+SUBDIRS_hydra_bss_names = ssh fork slurm
SUBDIRS = utils src @hydra_bss_names@ .
Property changes on: mpich2/trunk/src/pm/hydra/bootstrap/slurm
___________________________________________________________________
+ Makefile.in
Makefile
Added: mpich2/trunk/src/pm/hydra/bootstrap/slurm/Makefile.sm
--- mpich2/trunk/src/pm/hydra/bootstrap/slurm/Makefile.sm (rev 0)
+++ mpich2/trunk/src/pm/hydra/bootstrap/slurm/Makefile.sm 2009-03-18 19:46:13 UTC (rev 4121)
@@ -0,0 +1,20 @@
+# -*- Mode: Makefile; -*-
+# (C) 2008 by Argonne National Laboratory.
+# See COPYRIGHT in top-level directory.
+HYDRA_LIB_PATH = ../../lib
+libhydra_a_DIR = ${HYDRA_LIB_PATH}
+libhydra_a_SOURCES = slurm_launch.c slurm_init.c
+INCLUDES = -I${abs_srcdir}/../../include \
+ -I${abs_srcdir}/../../../../include \
+ -I../../include \
+ -I../../../../include \
+ -I${abs_srcdir}/../../launcher/utils \
+ -I${abs_srcdir}/../../pm/utils \
+ -I${abs_srcdir}/../include \
+ -I../include \
+ -I${abs_srcdir}/../utils \
+ -I${abs_srcdir}/../../demux
Added: mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm.h
--- mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm.h (rev 0)
+++ mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm.h 2009-03-18 19:46:13 UTC (rev 4121)
@@ -0,0 +1,14 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2008 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#ifndef SLURM_H_INCLUDED
+#define SLURM_H_INCLUDED
+#include "hydra_base.h"
+HYD_Status HYD_BSCD_slurm_launch_procs(void);
+#endif /* SLURM_H_INCLUDED */
Added: mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_init.c
--- mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_init.c (rev 0)
+++ mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_init.c 2009-03-18 19:46:13 UTC (rev 4121)
@@ -0,0 +1,24 @@
+#include "bsci.h"
+#include "slurm.h"
+struct HYD_BSCI_fns HYD_BSCI_fns;
+HYD_Status HYD_BSCI_slurm_init(void)
+ HYD_Status status = HYD_SUCCESS;
+ HYDU_FUNC_ENTER();
+ HYD_BSCI_fns.launch_procs = HYD_BSCD_slurm_launch_procs;
+ HYDU_FUNC_EXIT();
+ return status;
Added: mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c
--- mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c (rev 0)
+++ mpich2/trunk/src/pm/hydra/bootstrap/slurm/slurm_launch.c 2009-03-18 19:46:13 UTC (rev 4121)
@@ -0,0 +1,82 @@
+#include "hydra.h"
+#include "hydra_utils.h"
+#include "bscu.h"
+#include "slurm.h"
+HYD_Handle handle;
+ struct HYD_Proc_params *proc_params;
+ struct HYD_Partition_list *partition;
+ char *client_arg[HYD_EXEC_ARGS];
+ int i, arg, process_id;
+ /* FIXME: Instead of directly reading from the HYD_Handle
+ * structure, the upper layers should be able to pass what exactly
+ * they want launched. Without this functionality, the proxy
+ * cannot use this and will have to perfom its own launch. */
+ process_id = 0;
+ for (proc_params = handle.proc_params; proc_params; proc_params = proc_params->next) {
+ for (partition = proc_params->partition; partition; partition = partition->next) {
+ if (partition->group_rank) /* Only rank 0 is spawned */
+ continue;
+ /* Setup the executable arguments */
+ arg = 0;
+ /* FIXME: Get the path to srun */
+ client_arg[arg++] = MPIU_Strdup("srun");
+ /* Allow X forwarding only if explicitly requested */
+ if (handle.enablex == 1)
+ client_arg[arg++] = MPIU_Strdup("-X");
+ else if (handle.enablex == 0)
+ client_arg[arg++] = MPIU_Strdup("-x");
+ else /* default mode is disable X */
+ /* Currently, we do not support any partition names other
+ * than host names */
+ client_arg[arg++] = MPIU_Strdup(partition->name);
+ for (i = 0; partition->args[i]; i++)
+ client_arg[arg++] = MPIU_Strdup(partition->args[i]);
+ client_arg[arg++] = NULL;
+ /* The stdin pointer will be some value for process_id 0;
+ * for everyone else, it's NULL. */
+ status = HYDU_Create_process(client_arg, (process_id == 0 ? &handle.in : NULL),
+ &partition->out, &partition->err, &partition->pid);
+ if (status != HYD_SUCCESS) {
+ HYDU_Error_printf("bootstrap spawn process returned error\n");
+ goto fn_fail;
+ for (arg = 0; client_arg[arg]; arg++)
+ HYDU_FREE(client_arg[arg]);
+ /* For the remaining processes, set the stdin fd to -1 */
+ if (process_id != 0)
+ handle.in = -1;
+ process_id++;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
Modified: mpich2/trunk/src/pm/hydra/configure.in
--- mpich2/trunk/src/pm/hydra/configure.in 2009-03-18 19:14:41 UTC (rev 4120)
+++ mpich2/trunk/src/pm/hydra/configure.in 2009-03-18 19:46:13 UTC (rev 4121)
@@ -65,7 +65,7 @@
dnl Check what boot-strap server we should use
AC_ARG_WITH(hydra-bss, [ --with-hydra-bss Boot-strap Server],
[ hydra_bss=$withval ],
- [ hydra_bss="ssh,fork" ])
+ [ hydra_bss="ssh,fork,slurm" ])
AC_MSG_CHECKING(boot-strap server)
AC_MSG_RESULT($hydra_bss)
hydra_bss_names="`echo $hydra_bss | sed -e 's/:/ /g' -e 's/,/ /g'`"
More information about the mpich2-commits
