[mpich2-commits] r4096 - in mpich2/trunk/src/mpid/ch3: . channels/nemesis/nemesis/netmod/tcp
gropp at mcs.anl.gov gropp at mcs.anl.gov
Mon Mar 16 18:29:32 CDT 2009
Author: gropp
Date: 2009-03-16 18:29:32 -0500 (Mon, 16 Mar 2009)
New Revision: 4096
Modified:
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c
   mpich2/trunk/src/mpid/ch3/configure.in
Log:
Added _ALL_SOURCE as option for struct ifconf; needed for AIX
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c	2009-03-16 20:48:21 UTC (rev 4095)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c	2009-03-16 23:29:32 UTC (rev 4096)
@@ -29,6 +29,14 @@
 #define _SVID_SOURCE
 #endif
+#ifdef USE_ALL_SOURCE_FOR_IFCONF
+/* This is a very special case.  Allow the use of some extensions for just
+   the rest of this file so that we can get the ifconf structure
+   This is needed for AIX.
+#define _ALL_SOURCE
+#endif
 #include "tcp_impl.h"
 #include <sys/types.h>
Modified: mpich2/trunk/src/mpid/ch3/configure.in
--- mpich2/trunk/src/mpid/ch3/configure.in	2009-03-16 20:48:21 UTC (rev 4095)
+++ mpich2/trunk/src/mpid/ch3/configure.in	2009-03-16 23:29:32 UTC (rev 4096)
@@ -99,13 +99,10 @@
 			   [ rankbits=$withval ],
 			   [ rankbits=16 ])
 AC_MSG_RESULT($rankbits)
-if test "$rankbits" = "16" ; then
-   AC_DEFINE(CH3_RANK_BITS,16,[Define the number of CH3_RANK_BITS])
-elif test "$rankbits" = "32" ; then
-   AC_DEFINE(CH3_RANK_BITS,32,[Define the number of CH3_RANK_BITS])
-else
+if test "$rankbits" != "16" -a "$rankbits" != "32" ; then
    AC_MSG_ERROR(Only 16 or 32-bit ranks are supported)
 fi
+AC_DEFINE_UNQUOTED(CH3_RANK_BITS,$rankbits,[Define the number of CH3_RANK_BITS])
 AC_CHECK_HEADERS(assert.h limits.h string.h sys/types.h sys/uio.h uuid/uuid.h \
     time.h ctype.h unistd.h arpa/inet.h sys/socket.h net/if.h)
@@ -141,6 +138,14 @@
 AC_C_BIGENDIAN
 # If we need the socket code, see if we can use struct ifconf
+# Some systems require special compile options or definitions, or
+# special header files.
+# To simplify this sequence of tests, we set
+#   pac_found_struct_ifconf
+# to yes when we figure out how to get struct ifconf
+pac_found_struct_ifconf=no
 # sys/socket.h is needed on Solaris
 AC_CACHE_CHECK([whether we can use struct ifconf],
 pac_cv_have_struct_ifconf,[
@@ -151,9 +156,10 @@
 #endif
 #include <net/if.h>
 ],[struct ifconf conftest;],
-pac_cv_have_struct_ifconf=yes,pac_cv_have_struct_ifconf=no)])
+[pac_cv_have_struct_ifconf=yes;pac_found_struct_ifconf=yes],
+ pac_cv_have_struct_ifconf=no)])
-if test "$pac_cv_have_struct_ifconf" = "no" ; then
+if test "$pac_found_struct_ifconf" = "no" ; then
     # Try again with _SVID_SOURCE
     AC_CACHE_CHECK([whether we can use struct ifconf with _SVID_SOURCE],
 pac_cv_have_struct_ifconf_with_svid,[
@@ -165,15 +171,14 @@
 #endif
 #include <net/if.h>
-pac_cv_have_struct_ifconf_with_svid=yes,
+pac_cv_have_struct_ifconf_with_svid=yes;pac_found_struct_ifconf=yes,
 pac_cv_have_struct_ifconf_with_svid=no)])
     if test "$pac_cv_have_struct_ifconf_with_svid" = yes ; then
         AC_DEFINE(USE_SVIDSOURCE_FOR_IFCONF,1,[Define if _SVID_SOURCE needs to be defined for struct ifconf])
     fi
 fi
-if test "$pac_cv_have_struct_ifconf" = "no" -a \
-        "$pac_cv_have_struct_ifconf_with_svid" = "no" ; then
     # Try again with undef _POSIX_C_SOURCE
     AC_CACHE_CHECK([whether we can use struct ifconf without _POSIX_C_SOURCE],
 pac_cv_have_struct_ifconf_without_posix,[
@@ -185,16 +190,33 @@
 #endif
 #include <net/if.h>
-pac_cv_have_struct_ifconf_without_posix=yes,
+pac_cv_have_struct_ifconf_without_posix=yes;pac_found_struct_ifconf=yes,
 pac_cv_have_struct_ifconf_without_posix=no)])
     if test "$pac_cv_have_struct_ifconf_without_posix" = yes ; then
         AC_DEFINE(USE_NOPOSIX_FOR_IFCONF,1,[Define if _POSIX_C_SOURCE needs to be undefined for struct ifconf])
     fi
 fi
-if test "$pac_cv_have_struct_ifconf" = "yes" -o \
-        "$pac_cv_have_struct_ifconf_with_svid" = "yes" -o \
-        "$pac_cv_have_struct_ifconf_without_posix" ; then
+    # Try again with _ALL_SOURCE
+    AC_CACHE_CHECK([whether we can use struct ifconf with _ALL_SOURCE],
+pac_cv_have_struct_ifconf_with_svid,[
+AC_TRY_COMPILE([
+#include <sys/types.h>
+#ifdef HAVE_SYS_SOCKET_H
+#include <sys/socket.h>
+#endif
+#include <net/if.h>
+],[struct ifconf conftest;],
+pac_cv_have_struct_ifconf_with_all_source=yes;pac_found_struct_ifconf=yes,
+pac_cv_have_struct_ifconf_with_all_source=no)])
+    if test "$pac_cv_have_struct_ifconf_with_all_source" = yes ; then
+        AC_DEFINE(USE_ALL_SOURCE_FOR_IFCONF,1,[Define if _ALL_SOURCE needs to be defined for struct ifconf])
+    fi
+fi
+if test "$pac_found_struct_ifconf" = "yes" ; then
     AC_DEFINE(HAVE_STRUCT_IFCONF,1,[Define if struct ifconf can be used])
 fi
More information about the mpich2-commits mailing list
