[mpich2-commits] r4085 - in mpich2/trunk/src/pm/hydra: include launcher/mpiexec utils/string
balaji at mcs.anl.gov
Sun Mar 15 23:49:48 CDT 2009
Author: balaji
Date: 2009-03-15 23:49:48 -0500 (Sun, 15 Mar 2009)
New Revision: 4085
Modified:
mpich2/trunk/src/pm/hydra/include/hydra_utils.h
mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
mpich2/trunk/src/pm/hydra/utils/string/string.c
Log:
Allow mpiexec to take options of the form --bootstrap=ssh.
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-16 03:32:00 UTC (rev 4084)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h 2009-03-16 04:49:48 UTC (rev 4085)
@@ -101,6 +101,7 @@
HYD_Status HYDU_String_alloc_and_join(char **strlist, char **strjoin);
+HYD_Status HYDU_String_break(char *str, char **str1, char **str2);
HYD_Status HYDU_String_int_to_str(int x, char **str);
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c 2009-03-16 03:32:00 UTC (rev 4084)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c 2009-03-16 04:49:48 UTC (rev 4085)
@@ -19,8 +19,10 @@
printf("Global Options (passed to all executables):\n");
printf("\t--verbose [Verbose mode]\n");
+ printf("\t--version [Version information]\n");
printf("\t--enable-x/--disable-x [Enable or disable X forwarding]\n");
printf("\t--proxy-port [Port on which proxies can listen]\n");
+ printf("\t--bootstrap [Bootstrap server to use]\n");
printf("\t-genv {name} {value} [Environment variable name and value]\n");
printf("\t-genvlist {env1,env2,...} [Environment variable list to pass]\n");
printf("\t-genvnone [Do not pass any environment variables]\n");
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-16 03:32:00 UTC (rev 4084)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-16 04:49:48 UTC (rev 4085)
@@ -14,7 +14,7 @@
HYD_Handle handle;
-#define CHECK_NEXT_ARG_VALID(status) \
+#define CHECK_NEXT_ARG_VALID(status) \
--argc; ++argv; \
if (!argc || !argv) { \
@@ -96,7 +96,7 @@
int argc = t_argc, i;
char **argv = t_argv;
- char *env_name, *env_value;
+ char *env_name, *env_value, *str1, *str2;
HYD_Env_t *env;
struct HYD_Proc_params *proc_params;
HYD_Status status = HYD_SUCCESS;
@@ -119,15 +119,21 @@
while (--argc && ++argv) {
+ status = HYDU_String_break(*argv, &str1, &str2);
+ if (status != HYD_SUCCESS) {
+ HYDU_Error_printf("string break returned error\n");
+ goto fn_fail;
/* Help options */
- if (!strcmp(*argv, "-h") || !strcmp(*argv, "--help") || !strcmp(*argv, "-help")) {
+ if (!strcmp(str1, "-h") || !strcmp(str1, "--help") || !strcmp(str1, "-help")) {
/* Just return from this function; the main code will show the usage */
status = HYD_INTERNAL_ERROR;
goto fn_fail;
/* Check what debug level is requested */
- if (!strcmp(*argv, "--verbose")) {
+ if (!strcmp(str1, "--verbose")) {
/* Debug level already set */
if (handle.debug != -1) {
HYDU_Error_printf
@@ -141,7 +147,7 @@
/* Version information */
- if (!strcmp(*argv, "--version")) {
+ if (!strcmp(str1, "--version")) {
/* Just show the version information and continue. This
* option can be used in conjunction with other
* options. */
@@ -151,8 +157,11 @@
/* Bootstrap server */
- if (!strcmp(*argv, "--bootstrap")) {
- CHECK_NEXT_ARG_VALID(status);
+ if (!strcmp(str1, "--bootstrap")) {
+ if (!str2) {
+ CHECK_NEXT_ARG_VALID(status);
+ str2 = *argv;
if (handle.bootstrap != NULL) {
HYDU_Error_printf("Duplicate bootstrap setting; previously set to %s\n",
@@ -161,12 +170,12 @@
goto fn_fail;
- handle.bootstrap = MPIU_Strdup(*argv);
+ handle.bootstrap = MPIU_Strdup(str2);
continue;
/* Check if X forwarding is explicitly set */
- if (!strcmp(*argv, "--enable-x") || !strcmp(*argv, "--disable-x")) {
+ if (!strcmp(str1, "--enable-x") || !strcmp(str1, "--disable-x")) {
/* X forwarding already enabled or disabled */
if (handle.enablex != -1) {
HYDU_Error_printf
@@ -175,13 +184,16 @@
goto fn_fail;
- handle.enablex = !strcmp(*argv, "--enable-x");
+ handle.enablex = !strcmp(str1, "--enable-x");
continue;
/* Check if the proxy port is set */
- if (!strcmp(*argv, "--proxy-port")) {
+ if (!strcmp(str1, "--proxy-port")) {
+ if (!str2) {
+ str2 = *argv;
if (handle.proxy_port != -1) {
HYDU_Error_printf("Duplicate proxy port setting; previously set to %d\n",
@@ -190,13 +202,13 @@
goto fn_fail;
- handle.proxy_port = atoi(*argv);
+ handle.proxy_port = atoi(str2);
continue;
/* Check what all environment variables need to be propagated */
- if (!strcmp(*argv, "-genvall") || !strcmp(*argv, "-genvnone") ||
- !strcmp(*argv, "-genvlist")) {
+ if (!strcmp(str1, "-genvall") || !strcmp(str1, "-genvnone") ||
+ !strcmp(str1, "-genvlist")) {
/* propagation already set */
if (handle.prop != HYD_ENV_PROP_UNSET) {
HYDU_Error_printf
@@ -205,16 +217,21 @@
goto fn_fail;
- if (!strcmp(*argv, "-genvall")) {
+ if (!strcmp(str1, "-genvall")) {
handle.prop = HYD_ENV_PROP_ALL;
- else if (!strcmp(*argv, "-genvnone")) {
+ else if (!strcmp(str1, "-genvnone")) {
handle.prop = HYD_ENV_PROP_NONE;
- else if (!strcmp(*argv, "-genvlist")) {
+ else if (!strcmp(str1, "-genvlist")) {
handle.prop = HYD_ENV_PROP_LIST;
- env_name = strtok(*argv, ",");
+ if (!str2) {
+ str2 = *argv;
+ env_name = strtok(str2, ",");
do {
status = HYDU_Env_create(&env, env_name, NULL);
@@ -233,8 +250,8 @@
- if (!strcmp(*argv, "-envall") || !strcmp(*argv, "-envnone") ||
- !strcmp(*argv, "-envlist")) {
+ if (!strcmp(str1, "-envall") || !strcmp(str1, "-envnone") ||
+ !strcmp(str1, "-envlist")) {
status = get_current_proc_params(&proc_params);
HYDU_Error_printf("get_current_proc_params returned error\n");
@@ -250,17 +267,22 @@
goto fn_fail;
- if (!strcmp(*argv, "-envall")) {
+ if (!strcmp(str1, "-envall")) {
proc_params->prop = HYD_ENV_PROP_ALL;
- else if (!strcmp(*argv, "-envnone")) {
+ else if (!strcmp(str1, "-envnone")) {
proc_params->prop = HYD_ENV_PROP_NONE;
- else if (!strcmp(*argv, "-envlist")) {
+ else if (!strcmp(str1, "-envlist")) {
proc_params->prop = HYD_ENV_PROP_LIST;
+ if (!str2) {
+ str2 = *argv;
do {
if (env_name == NULL)
break;
@@ -281,9 +303,12 @@
/* Add additional environment variables */
- if (!strcmp(*argv, "-genv") || !strcmp(*argv, "-env")) {
- env_name = MPIU_Strdup(*argv);
+ if (!strcmp(str1, "-genv") || !strcmp(str1, "-env")) {
+ if (!str2) {
+ str2 = *argv;
+ env_name = MPIU_Strdup(str2);
env_value = MPIU_Strdup(*argv);
@@ -294,7 +319,7 @@
goto fn_fail;
- if (!strcmp(*argv, "-genv"))
+ if (!strcmp(str1, "-genv"))
HYDU_Env_add_to_list(&handle.user_env, *env);
else {
@@ -310,14 +335,20 @@
continue;
- if (!strcmp(*argv, "-wdir")) {
- handle.wdir = MPIU_Strdup(*argv);
+ if (!strcmp(str1, "-wdir")) {
+ if (!str2) {
+ str2 = *argv;
+ handle.wdir = MPIU_Strdup(str2);
continue;
- if (!strcmp(*argv, "-n") || !strcmp(*argv, "-np")) {
+ if (!strcmp(str1, "-n") || !strcmp(str1, "-np")) {
+ if (!str2) {
+ str2 = *argv;
@@ -334,14 +365,16 @@
goto fn_fail;
- proc_params->exec_proc_count = atoi(*argv);
+ proc_params->exec_proc_count = atoi(str2);
continue;
- if (!strcmp(*argv, "-f")) {
- handle.host_file = MPIU_Strdup(*argv);
+ if (!strcmp(str1, "-f")) {
+ if (!str2) {
+ str2 = *argv;
+ handle.host_file = MPIU_Strdup(str2);
continue;
Modified: mpich2/trunk/src/pm/hydra/utils/string/string.c
--- mpich2/trunk/src/pm/hydra/utils/string/string.c 2009-03-16 03:32:00 UTC (rev 4084)
+++ mpich2/trunk/src/pm/hydra/utils/string/string.c 2009-03-16 04:49:48 UTC (rev 4085)
@@ -34,6 +34,37 @@
+ int i;
+ HYD_Status status = HYD_SUCCESS;
+ HYDU_FUNC_ENTER();
+ if (str == NULL) {
+ str = HYD_INTERNAL_ERROR;
+ goto fn_fail;
+ *str1 = MPIU_Strdup(str);
+ for (i = 0; (*str1)[i] && ((*str1)[i] != '='); i++);
+ if ((*str1)[i] == 0) /* End of the string */
+ *str2 = NULL;
+ else {
+ *str2 = &((*str1)[i+1]);
+ (*str1)[i] = 0;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
int len = 1, max = 10, y;
More information about the mpich2-commits
