[mpich2-commits] r4079 - in mpich2/trunk/src/pm/hydra: . bootstrap/include bootstrap/src pm/central
balaji at mcs.anl.gov
Sun Mar 15 02:23:33 CDT 2009
Author: balaji
Date: 2009-03-15 02:23:32 -0500 (Sun, 15 Mar 2009)
New Revision: 4079
Modified:
mpich2/trunk/src/pm/hydra/README
mpich2/trunk/src/pm/hydra/bootstrap/include/bsci.h
mpich2/trunk/src/pm/hydra/bootstrap/src/bsci_init.c
mpich2/trunk/src/pm/hydra/pm/central/proxy_utils.c
Log:
Cleanup and documentation.
Modified: mpich2/trunk/src/pm/hydra/README
--- mpich2/trunk/src/pm/hydra/README 2009-03-15 04:31:17 UTC (rev 4078)
+++ mpich2/trunk/src/pm/hydra/README 2009-03-15 07:23:32 UTC (rev 4079)
@@ -4,8 +4,12 @@
Hydra is a process management system for starting parallel jobs,
especially MPICH2 jobs. Hydra is designed to natively work with
multiple daemons such as ssh, pbs, slurm and sge. However, in the
-current release, only ssh is supported.
+current release, only ssh and fork are supported.
+More detailed documentation of the internal workings of Hydra are
+available on the "Developer Documentation" wiki page:
+http://wiki.mcs.anl.gov/mpich2/index.php/Category:Design_Documents
How to use Hydra
@@ -37,7 +41,7 @@
To run your application on these nodes, use mpiexec:
- $ mpiexec -n 4 -f hosts ./app
+ $ mpiexec -f hosts -n 4 ./app
Environment settings
@@ -51,3 +55,28 @@
For csh/tcsh:
setenv HYDRA_HOST_FILE <path_to_host_file>/hosts
+Bootstrap servers
+Hydra supports SSH and FORK bootstrap servers to launch processes. You
+can pick these through the mpiexec option --bootstrap:
+ $ mpiexec --bootstrap ssh -f hosts -n 4 ./app
+ (or)
+ $ mpiexec --bootstrap fork -f hosts -n 4 ./app
+The default bootstrap server is ssh.
+X Forwarding
+X-forwarding is specific to each bootstrap server. Some servers do it
+by default, while some don't. For ssh, this is disabled by default. To
+enable it, you should use the option --enable-x to mpiexec.
+ $ mpiexec --enable-x -f hosts -n 4 ./app
Modified: mpich2/trunk/src/pm/hydra/bootstrap/include/bsci.h
--- mpich2/trunk/src/pm/hydra/bootstrap/include/bsci.h 2009-03-15 04:31:17 UTC (rev 4078)
+++ mpich2/trunk/src/pm/hydra/bootstrap/include/bsci.h 2009-03-15 07:23:32 UTC (rev 4079)
@@ -18,7 +18,7 @@
extern struct HYD_BSCI_fns HYD_BSCI_fns;
-HYD_Status HYD_BSCI_init(char * bootstrap);
+HYD_Status HYD_BSCI_init(char *bootstrap);
HYD_Status HYD_BSCI_launch_procs(void);
HYD_Status HYD_BSCI_finalize(void);
HYD_Status HYD_BSCI_get_usize(int *size);
Modified: mpich2/trunk/src/pm/hydra/bootstrap/src/bsci_init.c
--- mpich2/trunk/src/pm/hydra/bootstrap/src/bsci_init.c 2009-03-15 04:31:17 UTC (rev 4078)
+++ mpich2/trunk/src/pm/hydra/bootstrap/src/bsci_init.c 2009-03-15 07:23:32 UTC (rev 4079)
@@ -10,7 +10,7 @@
HYD_Status status = HYD_SUCCESS;
@@ -44,10 +44,10 @@
if (HYD_BSCI_fns.finalize == NULL)
HYD_BSCI_fns.finalize = HYD_BSCU_finalize;
-fn_exit:
+ fn_exit:
HYDU_FUNC_EXIT();
return status;
-fn_fail:
+ fn_fail:
goto fn_exit;
Modified: mpich2/trunk/src/pm/hydra/pm/central/proxy_utils.c
--- mpich2/trunk/src/pm/hydra/pm/central/proxy_utils.c 2009-03-15 04:31:17 UTC (rev 4078)
+++ mpich2/trunk/src/pm/hydra/pm/central/proxy_utils.c 2009-03-15 07:23:32 UTC (rev 4079)
@@ -93,7 +93,7 @@
* where they are not removed, we do it ourselves. */
if (*str == '"') {
str++;
- str[strlen(str)-1] = 0;
+ str[strlen(str) - 1] = 0;
HYDU_Env_putenv(str);
More information about the mpich2-commits
