[mpich2-commits] r4062 - in mpich2/trunk: src/mpid/ch3/channels/nemesis/nemesis/netmod/mx src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad src/mpid/ch3/include src/mpid/ch3/src src/mpid/common/datatype src/mpid/dcmfd/src/onesided test/mpi/rma
jayesh at mcs.anl.gov jayesh at mcs.anl.gov
Fri Mar 13 18:08:21 CDT 2009
Author: jayesh
Date: 2009-03-13 18:08:21 -0500 (Fri, 13 Mar 2009)
New Revision: 4062
Added:
   mpich2/trunk/test/mpi/rma/test1_dt.c
Modified:
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_poll.c
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_send.c
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c
   mpich2/trunk/src/mpid/ch3/include/mpidrma.h
   mpich2/trunk/src/mpid/ch3/src/ch3u_handle_recv_req.c
   mpich2/trunk/src/mpid/ch3/src/ch3u_rma_ops.c
   mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c
   mpich2/trunk/src/mpid/common/datatype/mpid_datatype.h
   mpich2/trunk/src/mpid/common/datatype/mpid_type_blockindexed.c
   mpich2/trunk/src/mpid/common/datatype/mpid_type_commit.c
   mpich2/trunk/src/mpid/common/datatype/mpid_type_contiguous.c
   mpich2/trunk/src/mpid/common/datatype/mpid_type_create_pairtype.c
   mpich2/trunk/src/mpid/common/datatype/mpid_type_indexed.c
   mpich2/trunk/src/mpid/common/datatype/mpid_type_struct.c
   mpich2/trunk/src/mpid/common/datatype/mpid_type_vector.c
   mpich2/trunk/src/mpid/common/datatype/mpir_type_flatten.c
   mpich2/trunk/src/mpid/common/datatype/mpir_type_get_contig_blocks.c
   mpich2/trunk/src/mpid/dcmfd/src/onesided/mpid_rma_common.c
   mpich2/trunk/test/mpi/rma/Makefile.sm
   mpich2/trunk/test/mpi/rma/testlist
Log:
1) Modifying the datatype code to find the number of contig blocks in an instance of an MPI derived datatype - Since finding the real number of contig blocks is not easy we find a reasonable upper bound instead. This also fixes the case where the number of contig blocks was uninitialized for contiguous datatypes. Refer ticket #428 for details (2) Adding a test case, test1_dt.c, to test the fix - Review @ rross, thakur
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_poll.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_poll.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_poll.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -731,7 +731,7 @@
   MPID_IOV  *iov;
   MPIDI_msg_sz_t last;
   int num_entries = MX_MAX_SEGMENTS;
-  int iov_num_ub  = rreq->dev.user_count * dt_ptr->n_contig_blocks;
+  int iov_num_ub  = rreq->dev.user_count * dt_ptr->max_contig_blocks;
   int n_iov       = iov_num_ub;
   int mpi_errno   = MPI_SUCCESS;
   int index;
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_send.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_send.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/mx/mx_send.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -395,7 +395,7 @@
     MPID_IOV  *iov;
     int num_entries = MX_MAX_SEGMENTS - first_free_slot;
-    int iov_num_ub  = count * dt_ptr->n_contig_blocks;
+    int iov_num_ub  = count * dt_ptr->max_contig_blocks;
     int index;
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_send.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -289,7 +289,7 @@
     MPID_Request  *sreq =*sreq_p;
Modified: mpich2/trunk/src/mpid/ch3/include/mpidrma.h
--- mpich2/trunk/src/mpid/ch3/include/mpidrma.h	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/ch3/include/mpidrma.h	2009-03-13 23:08:21 UTC (rev 4062)
@@ -13,7 +13,7 @@
 /* to send derived datatype across in RMA ops */
 typedef struct MPIDI_RMA_dtype_info { /* for derived datatypes */
     int           is_contig;
-    int           n_contig_blocks;
+    int           max_contig_blocks;
     int           size;
     MPI_Aint      extent;
     int           dataloop_size; /* not needed because this info is sent in packet header. remove it after lock/unlock is implemented in the device */
Modified: mpich2/trunk/src/mpid/ch3/src/ch3u_handle_recv_req.c
--- mpich2/trunk/src/mpid/ch3/src/ch3u_handle_recv_req.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/ch3/src/ch3u_handle_recv_req.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -574,7 +574,7 @@
     new_dtp->cache_id     = 0;
     new_dtp->name[0]      = 0;
     new_dtp->is_contig = dtype_info->is_contig;
-    new_dtp->n_contig_blocks = dtype_info->n_contig_blocks;
+    new_dtp->max_contig_blocks = dtype_info->max_contig_blocks;
     new_dtp->size = dtype_info->size;
     new_dtp->extent = dtype_info->extent;
     new_dtp->dataloop_size = dtype_info->dataloop_size;
@@ -681,7 +681,7 @@
         last  = SEGMENT_IGNORE_LAST;
         MPID_Datatype_get_ptr(rreq->dev.datatype, dtp);
-        vec_len = dtp->n_contig_blocks * rreq->dev.user_count + 1;
+        vec_len = dtp->max_contig_blocks * rreq->dev.user_count + 1;
         /* +1 needed because Rob says so */
         dloop_vec = (DLOOP_VECTOR *)
             MPIU_Malloc(vec_len * sizeof(DLOOP_VECTOR));
Modified: mpich2/trunk/src/mpid/ch3/src/ch3u_rma_ops.c
--- mpich2/trunk/src/mpid/ch3/src/ch3u_rma_ops.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/ch3/src/ch3u_rma_ops.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -517,7 +517,7 @@
 		MPID_Datatype_get_ptr(target_datatype, dtp);
-		vec_len = dtp->n_contig_blocks * target_count + 1;
+		vec_len = dtp->max_contig_blocks * target_count + 1;
 		MPIU_CHKLMEM_MALLOC(dloop_vec, DLOOP_VECTOR *,
 				    vec_len * sizeof(DLOOP_VECTOR),
Modified: mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c
--- mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -507,7 +507,7 @@
         /* derived datatype on target. fill derived datatype info */
         dtype_info->is_contig = target_dtp->is_contig;
-        dtype_info->n_contig_blocks = target_dtp->n_contig_blocks;
+        dtype_info->max_contig_blocks = target_dtp->max_contig_blocks;
         dtype_info->size = target_dtp->size;
         dtype_info->extent = target_dtp->extent;
         dtype_info->dataloop_size = target_dtp->dataloop_size;
@@ -731,7 +731,7 @@
         MPID_Datatype_get_ptr(rma_op->target_datatype, dtp);
         dtype_info->is_contig = dtp->is_contig;
-        dtype_info->n_contig_blocks = dtp->n_contig_blocks;
+        dtype_info->max_contig_blocks = dtp->max_contig_blocks;
         dtype_info->size = dtp->size;
         dtype_info->extent = dtp->extent;
         dtype_info->dataloop_size = dtp->dataloop_size;
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_datatype.h
--- mpich2/trunk/src/mpid/common/datatype/mpid_datatype.h	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_datatype.h	2009-03-13 23:08:21 UTC (rev 4062)
@@ -381,7 +381,11 @@
      * contiguous.
     int is_contig;
-    int n_contig_blocks; /* # of contig blocks in one instance */
+    /* Upper bound on the number of contig blocks for one instance.
+     * It is not trivial to calculate the *real* number of contig
+     * blocks in the case where old datatype is non-contiguous
     /* pointer to contents and envelope data for the datatype */
     MPID_Datatype_contents *contents;
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_type_blockindexed.c
--- mpich2/trunk/src/mpid/common/datatype/mpid_type_blockindexed.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_type_blockindexed.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -100,7 +100,7 @@
 	new_dtp->element_size = el_sz;
 	new_dtp->eltype       = el_type;
-	new_dtp->n_contig_blocks = count;
+	new_dtp->max_contig_blocks = count;
     else
@@ -129,7 +129,7 @@
-	new_dtp->n_contig_blocks = count * old_dtp->n_contig_blocks;
+	new_dtp->max_contig_blocks = old_dtp->max_contig_blocks * count * blocklength;
     /* priming for loop */
@@ -172,19 +172,21 @@
      * its size and extent are the same, and the old type was also
      * contiguous.
-    if (old_is_contig && ((MPI_Aint) new_dtp->size == new_dtp->extent))
+    new_dtp->is_contig = 0;
+    if (old_is_contig)
 	contig_count = MPID_Type_blockindexed_count_contig(count,
 							   blocklength,
 							   displacement_array,
 							   dispinbytes,
 							   old_extent);
-	new_dtp->is_contig = (contig_count == 1) ? 1 : 0;
+        new_dtp->max_contig_blocks = contig_count;
+        if( (contig_count == 1) &&
+                ((MPI_Aint) new_dtp->size == new_dtp->extent) )
+            new_dtp->is_contig = 1;
-    else
-	new_dtp->is_contig = 0;
     *newtype = new_dtp->handle;
     return mpi_errno;
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_type_commit.c
--- mpich2/trunk/src/mpid/common/datatype/mpid_type_commit.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_type_commit.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -87,7 +87,7 @@
 #endif
 	MPIU_DBG_PRINTF(("# contig blocks = %d\n",
-			 (int) datatype_ptr->n_contig_blocks));
+			 (int) datatype_ptr->max_contig_blocks));
 #if 0
 	MPIDI_Dataloop_dot_printf(datatype_ptr->dataloop, 0, 1);
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_type_contiguous.c
--- mpich2/trunk/src/mpid/common/datatype/mpid_type_contiguous.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_type_contiguous.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -86,6 +86,7 @@
+        new_dtp->max_contig_blocks = 1;
     else
@@ -121,6 +122,10 @@
 	new_dtp->is_contig    = old_dtp->is_contig;
+        if(old_dtp->is_contig)
+        else
+            new_dtp->max_contig_blocks = count * old_dtp->max_contig_blocks;
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_type_create_pairtype.c
--- mpich2/trunk/src/mpid/common/datatype/mpid_type_create_pairtype.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_type_create_pairtype.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -167,7 +167,7 @@
     new_dtp->is_contig       = (((MPI_Aint) type_size) == type_extent) ? 1 : 0;
-    new_dtp->n_contig_blocks = (((MPI_Aint) type_size) == type_extent) ? 1 : 2;
+    new_dtp->max_contig_blocks = (((MPI_Aint) type_size) == type_extent) ? 1 : 2;
     /* fill in dataloops -- only case where we precreate dataloops
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_type_indexed.c
--- mpich2/trunk/src/mpid/common/datatype/mpid_type_indexed.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_type_indexed.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -108,7 +108,7 @@
 	new_dtp->element_size = (MPI_Aint) el_sz;
     else
@@ -137,7 +137,11 @@
-	new_dtp->n_contig_blocks = old_dtp->n_contig_blocks * count;
+        new_dtp->max_contig_blocks = 0;
+        for(i=0; i<count; i++)
+                += old_dtp->max_contig_blocks
+                    * ((MPI_Aint *)blocklength_array)[i];
     /* find the first nonzero blocklength element */
@@ -203,20 +207,21 @@
      * block, its size and extent are the same, and the old type
      * was also contiguous.
-    contig_count = MPID_Type_indexed_count_contig(count,
+    if(old_is_contig)
+        contig_count = MPID_Type_indexed_count_contig(count,
 						  blocklength_array,
 						  displacement_array,
 						  dispinbytes,
 						  old_extent);
-    if ((contig_count == 1) && ((MPI_Aint) new_dtp->size == new_dtp->extent))
-	new_dtp->is_contig = old_is_contig;
+            ((MPI_Aint) new_dtp->size == new_dtp->extent))
-    else
     return mpi_errno;
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_type_struct.c
--- mpich2/trunk/src/mpid/common/datatype/mpid_type_struct.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_type_struct.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -209,7 +209,7 @@
 	return MPID_Type_zerolen(newtype);
-    new_dtp->n_contig_blocks = 0;
     for (i=0; i < count; i++)
 	int is_builtin =
@@ -241,7 +241,7 @@
 	    size += tmp_el_sz * blocklength_array[i];
-	    new_dtp->n_contig_blocks++;
+	    new_dtp->max_contig_blocks++;
 	else
@@ -265,7 +265,7 @@
 	    size += old_dtp->size * blocklength_array[i];
-	    new_dtp->n_contig_blocks += old_dtp->n_contig_blocks;
+	    new_dtp->max_contig_blocks += old_dtp->max_contig_blocks;
 	/* element size and type */
Modified: mpich2/trunk/src/mpid/common/datatype/mpid_type_vector.c
--- mpich2/trunk/src/mpid/common/datatype/mpid_type_vector.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpid_type_vector.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -97,7 +97,7 @@
 	eff_stride = (strideinbytes) ? stride : (stride * el_sz);
@@ -125,7 +125,7 @@
 	eff_stride = (strideinbytes) ? stride : (stride * old_dtp->extent);
@@ -151,6 +151,7 @@
 	old_is_contig)
     else {
Modified: mpich2/trunk/src/mpid/common/datatype/mpir_type_flatten.c
--- mpich2/trunk/src/mpid/common/datatype/mpir_type_flatten.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpir_type_flatten.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -41,7 +41,7 @@
     MPID_Datatype_get_ptr(type, datatype_ptr);
     MPIU_Assert(datatype_ptr->is_committed);
-    MPIU_Assert(*array_len_p >= datatype_ptr->n_contig_blocks);
+    MPIU_Assert(*array_len_p >= datatype_ptr->max_contig_blocks);
     segp = MPID_Segment_alloc();
     MPID_Segment_init(0, 1, type, segp, 0); /* first 0 is bufptr,
Modified: mpich2/trunk/src/mpid/common/datatype/mpir_type_get_contig_blocks.c
--- mpich2/trunk/src/mpid/common/datatype/mpir_type_get_contig_blocks.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/common/datatype/mpir_type_get_contig_blocks.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -36,6 +36,6 @@
-    *nr_blocks_p = datatype_ptr->n_contig_blocks;
+    *nr_blocks_p = datatype_ptr->max_contig_blocks;
     return 0;
Modified: mpich2/trunk/src/mpid/dcmfd/src/onesided/mpid_rma_common.c
--- mpich2/trunk/src/mpid/dcmfd/src/onesided/mpid_rma_common.c	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/src/mpid/dcmfd/src/onesided/mpid_rma_common.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -92,7 +92,7 @@
         /* Use existing routines to get IOV */
         MPID_Datatype_get_ptr(dt, dtp);
-        nb = dtp->n_contig_blocks + 1;
+        nb = dtp->max_contig_blocks + 1;
         MPIDU_MALLOC(mv, MPID_Type_map, nb * sizeof(*mv), last, "MPID_Type_map");
         MPID_assert(mv != NULL);
Modified: mpich2/trunk/test/mpi/rma/Makefile.sm
--- mpich2/trunk/test/mpi/rma/Makefile.sm	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/test/mpi/rma/Makefile.sm	2009-03-13 23:08:21 UTC (rev 4062)
@@ -47,6 +47,8 @@
 fetchandadd_tree_am_SOURCES = fetchandadd_tree_am.c
 accfence2_am_SOURCES = accfence2_am.c
+test1_dt_SOURCES = test1_dt.c
 attrorderwin_SOURCES = attrorderwin.c
 wincall_SOURCES = wincall.c
 fkeyvalwin_SOURCES = fkeyvalwin.c
Added: mpich2/trunk/test/mpi/rma/test1_dt.c
--- mpich2/trunk/test/mpi/rma/test1_dt.c	                        (rev 0)
+++ mpich2/trunk/test/mpi/rma/test1_dt.c	2009-03-13 23:08:21 UTC (rev 4062)
@@ -0,0 +1,82 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ *  (C) 2001 by Argonne National Laboratory.
+ *      See COPYRIGHT in top-level directory.
+#include "mpi.h"
+#include "stdio.h"
+#include "mpitest.h"
+/* tests a series of puts, gets, and accumulate on 2 processes using fence */
+/* Same as test1.c but uses derived datatypes to receive data */
+#define SIZE 100
+int main(int argc, char *argv[])
+    int rank, nprocs, A[SIZE], B[SIZE], i;
+    MPI_Win win;
+    MPI_Datatype contig_2ints;
+    int errs = 0;
+    MTest_Init(&argc,&argv);
+    MPI_Comm_size(MPI_COMM_WORLD,&nprocs);
+    MPI_Comm_rank(MPI_COMM_WORLD,&rank);
+    if (nprocs != 2) {
+        printf("Run this program with 2 processes\n");
+        MPI_Abort(MPI_COMM_WORLD,1);
+    if (rank == 0) {
+        for (i=0; i<SIZE; i++)
+            A[i] = B[i] = i;
+    else {
+        for (i=0; i<SIZE; i++) {
+            A[i] = (-3)*i;
+            B[i] = (-4)*i;
+    MPI_Type_contiguous(2, MPI_INT, &contig_2ints);
+    MPI_Type_commit(&contig_2ints);
+    MPI_Win_create(B, SIZE*sizeof(int), sizeof(int), MPI_INFO_NULL,
+                   MPI_COMM_WORLD, &win);
+    MPI_Win_fence(0, win);
+    if (rank == 0) {
+        for (i=0; i<SIZE-1; i++)
+            MPI_Put(A+i, 2, MPI_INT, 1, i, 1, contig_2ints, win);
+    else {
+            MPI_Get(A+i, 2, MPI_INT, 0, i, 1, contig_2ints, win);
+        MPI_Accumulate(A+i, 2, MPI_INT, 0, i, 1, contig_2ints, MPI_SUM, win);
+    if (rank == 1) {
+        for (i=0; i<SIZE-1; i++) {
+            if (A[i] != B[i]) {
+                printf("Put/Get Error: A[i]=%d, B[i]=%d\n", A[i], B[i]);
+                errs++;
+    else {
+        if (B[SIZE-1] != SIZE - 1 - 3*(SIZE-1)) {
+            printf("Accumulate Error: B[SIZE-1] is %d, should be %d\n", B[SIZE-1], SIZE - 1 - 3*(SIZE-1));
+            errs++;
+    MPI_Win_free(&win);
+    MPI_Type_free(&contig_2ints);
+    MTest_Finalize(errs);
+    MPI_Finalize();
+    return 0;
Modified: mpich2/trunk/test/mpi/rma/testlist
--- mpich2/trunk/test/mpi/rma/testlist	2009-03-13 22:59:42 UTC (rev 4061)
+++ mpich2/trunk/test/mpi/rma/testlist	2009-03-13 23:08:21 UTC (rev 4062)
@@ -32,6 +32,7 @@
 fetchandadd_am 7
 fetchandadd_tree_am 7
 accfence2_am 4
+test1_dt 2 timeLimit=30
 nullpscw 7
 attrorderwin 1
 wincall 2
More information about the mpich2-commits mailing list
