[mpich2-commits] r4050 - mpich2/trunk/test/mpi
chan at mcs.anl.gov
chan at mcs.anl.gov
Fri Mar 13 00:15:32 CDT 2009
Author: chan
Date: 2009-03-13 00:15:31 -0500 (Fri, 13 Mar 2009)
New Revision: 4050
Modified:
mpich2/trunk/test/mpi/configure.in
Log:
Fixed f77 and f90 build when the base f77/f90 compilers are naive compilers, i.e. not MPI wrapper compilers, by using the patch provided by David Gingold. The patch resolves bug report req#425. Also, fixed VPATH build for f77 and f90 support.
Modified: mpich2/trunk/test/mpi/configure.in
--- mpich2/trunk/test/mpi/configure.in 2009-03-13 01:52:57 UTC (rev 4049)
+++ mpich2/trunk/test/mpi/configure.in 2009-03-13 05:15:31 UTC (rev 4050)
@@ -206,6 +206,16 @@
enable_f77=no
fi
fi
+if test "$enable_f90" = yes ; then
+ AC_PROG_F90
+ if test -z "$BASEF90" ; then
+ BASEF90="$F90"
+ fi
+ # If there is no working F90, then set enable_f90 to no
+ if test -z "$F90" ; then
+ enable_f90=no
+ fi
+fi
if test "$enable_cxx" = yes ; then
AC_PROG_CXX
if test -z "$BASECXX" ; then
@@ -255,6 +265,11 @@
else
F77=$MPIF77
fi
+ if test -z "$MPIF90" ; then
+ F90=$with_mpi/bin/mpif90
+ else
+ F90=$MPIF90
+ fi
if test -z "$MPICXX" ; then
CXX=$with_mpi/bin/mpicxx
else
@@ -591,6 +606,11 @@
# MPI programs may require that the programs be run with mpiexec or
# something similar (this is true for the IBM MPI, for example).
rm -f f77/init/checksizes.c
+ # If it is a VPATH build, f77/init may not be there.
+ if test ! -d f77/init ; then
+ mkdir f77
+ mkdir f77/init
+ fi
cat > f77/init/checksizes.c <<EOF
#include "mpi.h"
#include <stdio.h>
@@ -719,7 +739,9 @@
elif test -z "$BASEF90" ; then
BASEF90=$F90
fi
- F90=$saveF90
+ if test -n "$BASEF90" ; then
+ F90=$saveF90
+ fi
fi
@@ -781,6 +803,11 @@
fi
if test -f f77/init/checksizes.c ; then
+ # If it is a VPATH build, f90/init may not be there.
+ if test ! -d f90/init ; then
+ mkdir f90
+ mkdir f90/init
+ fi
cp f77/init/checksizes.c f90/init
fi
fi
More information about the mpich2-commits
