[mpich2-commits] r4048 - mpich2/trunk/src/mpi/romio/adio/common
robl at mcs.anl.gov
robl at mcs.anl.gov
Thu Mar 12 18:01:22 CDT 2009
Author: robl
Date: 2009-03-12 18:01:22 -0500 (Thu, 12 Mar 2009)
New Revision: 4048
Modified:
mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c
Log:
yay. the last of the unallocated handles. *and* it passes the romio tests.
thanks for the help, Dave!
Modified: mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c
--- mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c 2009-03-12 22:33:32 UTC (rev 4047)
+++ mpich2/trunk/src/mpi/romio/adio/common/cb_config_list.c 2009-03-12 23:01:22 UTC (rev 4048)
@@ -115,10 +115,19 @@
MPI_Keyval_create((MPI_Copy_function *) ADIOI_cb_copy_name_array,
(MPI_Delete_function *) ADIOI_cb_delete_name_array,
&cb_config_list_keyval, NULL);
+ /* Need a hook so we can cleanup in Finalize */
+ MPI_Attr_put(MPI_COMM_SELF, cb_config_list_keyval, NULL);
else {
MPI_Attr_get(comm, cb_config_list_keyval, (void *) &array, &found);
- if (found) {
+ /* see above: we put a cb_config_list_keyval with NULL array on
+ * COMM_SELF so we can clean it up on exit. So it's not enough
+ * to find the keyval. we also need a non-null array (every mpi
+ * program will have at least one element in the array --
+ * itself. Not doing this confuses the shared file ponters
+ * routines. I know it is ugly but I can't figure out a better
+ * way... if we find the e*/
+ if (found && (array != NULL)) {
*arrayp = array;
return 0;
@@ -375,7 +384,7 @@
ADIOI_UNREFERENCED_ARG(extra);
array = (ADIO_cb_name_array) attr_in;
- array->refct++;
+ if (array != NULL) array->refct++;
*attr_out = attr_in;
*flag = 1; /* make a copy in the new communicator */
@@ -393,10 +402,11 @@
ADIO_cb_name_array array;
ADIOI_UNREFERENCED_ARG(comm);
- ADIOI_UNREFERENCED_ARG(keyval);
array = (ADIO_cb_name_array) attr_val;
+ if (array == NULL)
+ goto fn_exit;
array->refct--;
if (array->refct <= 0) {
@@ -411,6 +421,8 @@
if (array->names != NULL) ADIOI_Free(array->names);
ADIOI_Free(array);
+fn_exit:
+ MPI_Keyval_free(&keyval);
return MPI_SUCCESS;
More information about the mpich2-commits
