[mpich2-commits] r4038 - in mpich2/trunk/src/pm/hydra: . bootstrap control launcher pm
balaji at mcs.anl.gov
Thu Mar 12 15:34:48 CDT 2009
Author: balaji
Date: 2009-03-12 15:34:48 -0500 (Thu, 12 Mar 2009)
New Revision: 4038
Modified:
mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm
mpich2/trunk/src/pm/hydra/configure.in
mpich2/trunk/src/pm/hydra/control/Makefile.sm
mpich2/trunk/src/pm/hydra/launcher/Makefile.sm
mpich2/trunk/src/pm/hydra/pm/Makefile.sm
Log:
Committing some configuration setup changes to support runtime selection
of the bootstrap server. Also changed the naming convention to match
the rest of MPICH2.
This change in itself does not do anything for runtime selection of
bootstrap devices, but we'll need this when we actually add that code
in the future.
Modified: mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm
--- mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm 2009-03-12 20:33:40 UTC (rev 4037)
+++ mpich2/trunk/src/pm/hydra/bootstrap/Makefile.sm 2009-03-12 20:34:48 UTC (rev 4038)
@@ -4,5 +4,5 @@
# See COPYRIGHT in top-level directory.
-SUBDIRS_HYDRA_BSS = ssh fork
-SUBDIRS = utils @HYDRA_BSS@ .
+SUBDIRS_hydra_bss = ssh fork
+SUBDIRS = utils @hydra_bss_names@ .
Modified: mpich2/trunk/src/pm/hydra/configure.in
--- mpich2/trunk/src/pm/hydra/configure.in 2009-03-12 20:33:40 UTC (rev 4037)
+++ mpich2/trunk/src/pm/hydra/configure.in 2009-03-12 20:34:48 UTC (rev 4038)
@@ -64,47 +64,48 @@
dnl Check what boot-strap server we should use
AC_ARG_WITH(hydra-bss, [ --with-hydra-bss Boot-strap Server],
- [ HYDRA_BSS=$withval ],
- [ HYDRA_BSS=ssh ])
+ [ hydra_bss=$withval ],
+ [ hydra_bss=ssh ])
AC_MSG_CHECKING(boot-strap server)
-AC_MSG_RESULT($HYDRA_BSS)
-AC_SUBST(HYDRA_BSS)
+AC_MSG_RESULT($hydra_bss)
+hydra_bss_names="`echo $hydra_bss | sed -e 's/:/ /g' -e 's/,/ /g'`"
+AC_SUBST(hydra_bss_names)
dnl Check what process manager we should use
AC_ARG_WITH(hydra-pm, [ --with-hydra-pm Process Manager (central or distributed)],
- [ HYDRA_PM=$withval ],
- [ HYDRA_PM=central ])
+ [ hydra_pm=$withval ],
+ [ hydra_pm=central ])
AC_MSG_CHECKING(process manager)
-AC_MSG_RESULT($HYDRA_PM)
-AC_SUBST(HYDRA_PM)
+AC_MSG_RESULT($hydra_pm)
+AC_SUBST(hydra_pm)
dnl Check what job launcher we should use
AC_ARG_WITH(hydra-launcher, [ --with-hydra-launcher Job Launcher],
- [ HYDRA_LAUNCHER=$withval ],
- [ HYDRA_LAUNCHER=mpiexec ])
+ [ hydra_launcher=$withval ],
+ [ hydra_launcher=mpiexec ])
AC_MSG_CHECKING(job launcher)
-AC_MSG_RESULT($HYDRA_LAUNCHER)
-AC_SUBST(HYDRA_LAUNCHER)
+AC_MSG_RESULT($hydra_launcher)
+AC_SUBST(hydra_launcher)
dnl Check what control system we should use
AC_ARG_WITH(hydra-control, [ --with-hydra-control Control System],
- [ HYDRA_CONTROL=$withval ],
- [ HYDRA_CONTROL=consys ])
+ [ hydra_control=$withval ],
+ [ hydra_control=consys ])
AC_MSG_CHECKING(control system)
-AC_MSG_RESULT($HYDRA_CONTROL)
-AC_SUBST(HYDRA_CONTROL)
+AC_MSG_RESULT($hydra_control)
+AC_SUBST(hydra_control)
-dnl Check what control system we should use
+dnl Check what communication sub-system we should use
AC_ARG_WITH(hydra-css, [ --with-hydra-css Communication Sub-system],
- [ HYDRA_CSS=$withval ],
- [ HYDRA_CSS= ])
+ [ hydra_css=$withval ],
+ [ hydra_css= ])
AC_MSG_CHECKING(communication subsystem)
-if test "x$HYDRA_CSS" != "x" ; then
- AC_MSG_RESULT($HYDRA_CSS)
+if test "x$hydra_css" != "x" ; then
+ AC_MSG_RESULT($hydra_css)
else
AC_MSG_RESULT(none)
fi
-AC_SUBST(HYDRA_CSS)
+AC_SUBST(hydra_css)
dnl Debugging support
AC_ARG_ENABLE(g, [ --enable-g Enable Debugging],
@@ -253,6 +254,10 @@
dnl Place holder macro for finalization
PAC_SUBCONFIG_FINALIZE()
+for hydra_bss_name in ${hydra_bss_names}; do
+ hydra_bss_makefiles="$hydra_bss_makefiles bootstrap/${hydra_bss_name}/Makefile"
+done
dnl Final output
AC_OUTPUT(Makefile \
utils/Makefile \
@@ -266,14 +271,15 @@
utils/timer/Makefile \
launcher/Makefile \
launcher/utils/Makefile \
- launcher/${HYDRA_LAUNCHER}/Makefile \
+ launcher/${hydra_launcher}/Makefile \
control/Makefile \
control/utils/Makefile \
- control/${HYDRA_CONTROL}/Makefile \
+ control/${hydra_control}/Makefile \
pm/Makefile \
pm/utils/Makefile \
- pm/${HYDRA_PM}/Makefile \
+ pm/${hydra_pm}/Makefile \
demux/Makefile \
bootstrap/Makefile \
bootstrap/utils/Makefile \
- bootstrap/${HYDRA_BSS}/Makefile)
+ ${hydra_bss_makefiles}
Modified: mpich2/trunk/src/pm/hydra/control/Makefile.sm
--- mpich2/trunk/src/pm/hydra/control/Makefile.sm 2009-03-12 20:33:40 UTC (rev 4037)
+++ mpich2/trunk/src/pm/hydra/control/Makefile.sm 2009-03-12 20:34:48 UTC (rev 4038)
@@ -4,5 +4,5 @@
-SUBDIRS_HYDRA_CONTROL = consys
-SUBDIRS = utils @HYDRA_CONTROL@ .
+SUBDIRS_hydra_control = consys
+SUBDIRS = utils @hydra_control@ .
Modified: mpich2/trunk/src/pm/hydra/launcher/Makefile.sm
--- mpich2/trunk/src/pm/hydra/launcher/Makefile.sm 2009-03-12 20:33:40 UTC (rev 4037)
+++ mpich2/trunk/src/pm/hydra/launcher/Makefile.sm 2009-03-12 20:34:48 UTC (rev 4038)
@@ -4,8 +4,8 @@
-SUBDIRS_HYDRA_LAUNCHER = mpiexec
-SUBDIRS = utils @HYDRA_LAUNCHER@ .
+SUBDIRS_hydra_launcher = mpiexec
+SUBDIRS = utils @hydra_launcher@ .
mpich2-build-install mpich2-build-uninstall install install-alt:
- cd @HYDRA_LAUNCHER@ && ${MAKE} $@
+ cd @hydra_launcher@ && ${MAKE} $@
Modified: mpich2/trunk/src/pm/hydra/pm/Makefile.sm
--- mpich2/trunk/src/pm/hydra/pm/Makefile.sm 2009-03-12 20:33:40 UTC (rev 4037)
+++ mpich2/trunk/src/pm/hydra/pm/Makefile.sm 2009-03-12 20:34:48 UTC (rev 4038)
@@ -4,8 +4,8 @@
-SUBDIRS_HYDRA_PM = central
-SUBDIRS = utils @HYDRA_PM@ .
+SUBDIRS_hydra_pm = central
+SUBDIRS = utils @hydra_pm@ .
- cd @HYDRA_PM@ && ${MAKE} $@
+ cd @hydra_pm@ && ${MAKE} $@
More information about the mpich2-commits
