[mpich2-commits] r4031 - in mpich2/trunk/src/mpid/ch3/channels/nemesis: include nemesis/src
buntinas at mcs.anl.gov
Thu Mar 12 14:17:09 CDT 2009
Author: buntinas
Date: 2009-03-12 14:17:09 -0500 (Thu, 12 Mar 2009)
New Revision: 4031
Modified:
mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_impl.h
mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_shm.c
Log:
fixes #402 (NPB IS hangs) and other allgatherv hangs. Also narrowed down volatile qualifiers from entire struct down to individual fields so we wouldn't have to cast away volatile in some cases
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_impl.h
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_impl.h 2009-03-12 17:58:51 UTC (rev 4030)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/include/mpidi_ch3_impl.h 2009-03-12 19:17:09 UTC (rev 4031)
@@ -130,7 +130,7 @@
int (* lmt_done_recv)(struct MPIDI_VC *vc, struct MPID_Request *req);
/* LMT shared memory copy-buffer ptr */
- volatile struct MPID_nem_copy_buf *lmt_copy_buf;
+ struct MPID_nem_copy_buf *lmt_copy_buf;
MPIU_SHMW_Hnd_t lmt_copy_buf_handle;
int lmt_buf_num;
MPIDI_msg_sz_t lmt_surfeit;
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_shm.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_shm.c 2009-03-12 17:58:51 UTC (rev 4030)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_shm.c 2009-03-12 19:17:09 UTC (rev 4031)
@@ -8,7 +8,7 @@
#include "mpid_nem_datatypes.h"
#include "mpiu_os_wrappers.h"
-#if defined(USE_DBG_LOGGING) && 1
+#if defined(USE_DBG_LOGGING) && 0
#define DBG_LMT(x) x
#else
#define DBG_LMT(x)
@@ -69,13 +69,13 @@
typedef union
- int val;
+ volatile int val;
char padding[MPID_NEM_CACHE_LINE_LEN];
} MPID_nem_cacheline_int_t;
typedef union
- MPIDI_msg_sz_t val;
+ volatile MPIDI_msg_sz_t val;
} MPID_nem_cacheline_msg_sz_t;
@@ -83,9 +83,9 @@
struct
- MPIDU_Atomic_t rank;
- int remote_req_id;
- DBG_LMT(int ctr;)
+ MPIDU_Atomic_t rank; /* MPIDU_Atomic_t is already volatile */
+ volatile int remote_req_id;
+ DBG_LMT(volatile int ctr;)
} val;
} MPID_nem_cacheline_owner_info_t;
@@ -96,14 +96,15 @@
MPID_nem_cacheline_int_t sender_present; /* is the sender currently in the lmt progress function for this buffer */
MPID_nem_cacheline_int_t receiver_present; /* is the receiver currently in the lmt progress function for this buffer */
MPID_nem_cacheline_int_t len[NUM_BUFS];
- char underflow_buf[MPID_NEM_CACHE_LINE_LEN]; /* used when not all data could be unpacked from previous buffer */
- char buf[NUM_BUFS][MPID_NEM_COPY_BUF_LEN];
+ volatile char underflow_buf[MPID_NEM_CACHE_LINE_LEN]; /* used when not all data could be unpacked from previous buffer */
+ volatile char buf[NUM_BUFS][MPID_NEM_COPY_BUF_LEN];
} MPID_nem_copy_buf_t;
/* copy buffer flag values */
#define BUF_EMPTY 0
#define BUF_FULL 1
#define NO_OWNER -1
+#define IN_USE -2
/* pipeline values : if the data size is less than PIPELINE_THRESHOLD,
then copy no more than PIPELINE_MAX_SIZE at a time. */
@@ -114,10 +115,10 @@
static inline int lmt_shm_progress_vc(MPIDI_VC_t *vc, int *done);
static int lmt_shm_send_progress(MPIDI_VC_t *vc, MPID_Request *req, int *done);
static int lmt_shm_recv_progress(MPIDI_VC_t *vc, MPID_Request *req, int *done);
-static int MPID_nem_allocate_shm_region(volatile MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t handle);
-static int MPID_nem_attach_shm_region(volatile MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t handle);
-static int MPID_nem_detach_shm_region(volatile MPID_nem_copy_buf_t **buf, MPIU_SHMW_Hnd_t handle);
-static int MPID_nem_delete_shm_region(volatile MPID_nem_copy_buf_t **buf, MPIU_SHMW_Hnd_t *handle_p);
+static int MPID_nem_allocate_shm_region(MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t handle);
+static int MPID_nem_attach_shm_region(MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t handle);
+static int MPID_nem_detach_shm_region(MPID_nem_copy_buf_t **buf, MPIU_SHMW_Hnd_t handle);
+static int MPID_nem_delete_shm_region(MPID_nem_copy_buf_t **buf, MPIU_SHMW_Hnd_t *handle_p);
/* number of iterations to wait for the other side to process a buffer */
#define LMT_POLLS_BEFORE_YIELD 1000
@@ -179,7 +180,7 @@
for (i = 0; i < NUM_BUFS; ++i)
vc_ch->lmt_copy_buf->len[i].val = 0;
- MPIDU_Atomic_store((MPIDU_Atomic_t*)&vc_ch->lmt_copy_buf->owner_info.val.rank, NO_OWNER);
+ MPIDU_Atomic_store(&vc_ch->lmt_copy_buf->owner_info.val.rank, NO_OWNER);
vc_ch->lmt_copy_buf->owner_info.val.remote_req_id = MPI_REQUEST_NULL;
DBG_LMT(vc_ch->lmt_copy_buf->owner_info.val.ctr = 0);
@@ -329,19 +330,16 @@
int mpi_errno = MPI_SUCCESS;
MPIDI_CH3I_VC *vc_ch = (MPIDI_CH3I_VC *)vc->channel_private;
- volatile MPID_nem_copy_buf_t * const copy_buf = vc_ch->lmt_copy_buf;
+ MPID_nem_copy_buf_t * const copy_buf = vc_ch->lmt_copy_buf;
int prev_owner_rank;
MPID_Request *req;
MPIDI_STATE_DECL(MPID_STATE_GET_NEXT_REQ);
MPIDI_FUNC_ENTER(MPID_STATE_GET_NEXT_REQ);
- /* FIXME casting away volatile for now. In the longer run we need to
- constrain the volatile keyword to the right parts rather than the whole
- structure */
- prev_owner_rank = MPIDU_Atomic_cas_int((MPIDU_Atomic_t*)©_buf->owner_info.val.rank, NO_OWNER, MPIDI_Process.my_pg_rank);
+ prev_owner_rank = MPIDU_Atomic_cas_int(©_buf->owner_info.val.rank, NO_OWNER, MPIDI_Process.my_pg_rank);
- if (prev_owner_rank == MPIDI_Process.my_pg_rank)
+ if (prev_owner_rank == IN_USE || prev_owner_rank == MPIDI_Process.my_pg_rank)
/* last lmt is not complete (receiver still receiving */
MPIU_DBG_MSG(CH3_CHANNEL, VERBOSE, "waiting for receiver");
@@ -373,6 +371,10 @@
int i = 0;
MPIDU_Shm_read_barrier();
+ MPIU_DBG_STMT(CH3_CHANNEL, VERBOSE, if (copy_buf->owner_info.val.remote_req_id == MPI_REQUEST_NULL)
+ MPIU_DBG_MSG_D(CH3_CHANNEL, VERBOSE, "waiting for owner rank=%d", vc->pg_rank));
while (copy_buf->owner_info.val.remote_req_id == MPI_REQUEST_NULL)
if (i == LMT_POLLS_BEFORE_YIELD)
@@ -398,6 +400,8 @@
/* found request, clear remote_req_id field to prevent this buffer from matching future reqs */
+ MPIDU_Atomic_store(&vc_ch->lmt_copy_buf->owner_info.val.rank, IN_USE);
req = vc_ch->lmt_active_lmt->req;
@@ -436,7 +440,7 @@
MPIDI_msg_sz_t first;
MPIDI_msg_sz_t last;
int buf_num;
@@ -533,7 +537,7 @@
MPIDI_msg_sz_t last, expected_last;
int buf_num;
@@ -652,7 +656,7 @@
MPIU_DBG_MSG_D(CH3_CHANNEL, VERBOSE, "completed request local_req=%d", req->handle);
MPIDU_Shm_write_barrier();
- MPIDU_Atomic_store((MPIDU_Atomic_t*)©_buf->owner_info.val.rank, NO_OWNER);
+ MPIDU_Atomic_store(©_buf->owner_info.val.rank, NO_OWNER);
*done = TRUE;
MPIDI_CH3U_Request_complete(req);
@@ -805,7 +809,7 @@
#define FUNCNAME MPID_nem_allocate_shm_region
#undef FCNAME
#define FCNAME MPIDI_QUOTE(FUNCNAME)
MPIDI_STATE_DECL(MPID_STATE_MPID_NEM_ALLOCATE_SHM_REGION);
@@ -832,7 +836,7 @@
#define FUNCNAME MPID_nem_attach_shm_region
#undef FCNAME
MPIDI_STATE_DECL(MPID_STATE_MPID_NEM_ATTACH_SHM_REGION);
@@ -862,7 +866,7 @@
#define FUNCNAME MPID_nem_detach_shm_region
#undef FCNAME
-static int MPID_nem_detach_shm_region(volatile MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t handle)
+static int MPID_nem_detach_shm_region(MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t handle)
MPIDI_STATE_DECL(MPID_STATE_MPID_NEM_DETACH_SHM_REGION);
@@ -883,7 +887,7 @@
#define FUNCNAME MPID_nem_delete_shm_region
#undef FCNAME
-static int MPID_nem_delete_shm_region(volatile MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t *handle_p)
+static int MPID_nem_delete_shm_region(MPID_nem_copy_buf_t **buf_p, MPIU_SHMW_Hnd_t *handle_p)
MPIDI_STATE_DECL(MPID_STATE_MPID_NEM_DELETE_SHM_REGION);
More information about the mpich2-commits
