[mpich2-commits] r4023 - in mpich2/trunk/src/pm/hydra: bootstrap/ssh include launcher/mpiexec launcher/utils pm/central utils/args
balaji at mcs.anl.gov
Thu Mar 12 03:50:35 CDT 2009
Author: balaji
Date: 2009-03-12 03:50:34 -0500 (Thu, 12 Mar 2009)
New Revision: 4023
Modified:
mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c
mpich2/trunk/src/pm/hydra/include/hydra.h
mpich2/trunk/src/pm/hydra/include/hydra_base.h
mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
mpich2/trunk/src/pm/hydra/pm/central/central_launch.c
mpich2/trunk/src/pm/hydra/utils/args/args.c
Log:
Added some debug information. A lot more is needed.
Modified: mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c
--- mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c 2009-03-12 08:50:34 UTC (rev 4023)
@@ -59,10 +59,8 @@
/* The stdin pointer will be some value for process_id 0;
* for everyone else, it's NULL. */
- status =
- HYDU_Create_process(client_arg,
- (process_id == 0 ? &handle.in : NULL),
- &partition->out, &partition->err, &partition->pid);
+ status = HYDU_Create_process(client_arg, (process_id == 0 ? &handle.in : NULL),
+ &partition->out, &partition->err, &partition->pid);
if (status != HYD_SUCCESS) {
HYDU_Error_printf("bootstrap spawn process returned error\n");
goto fn_fail;
Modified: mpich2/trunk/src/pm/hydra/include/hydra.h
--- mpich2/trunk/src/pm/hydra/include/hydra.h 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/include/hydra.h 2009-03-12 08:50:34 UTC (rev 4023)
@@ -14,7 +14,7 @@
struct HYD_Handle_ {
char *base_path;
int proxy_port;
- char *boot_server;
+ char *bootstrap;
int debug;
int enablex;
Modified: mpich2/trunk/src/pm/hydra/include/hydra_base.h
--- mpich2/trunk/src/pm/hydra/include/hydra_base.h 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/include/hydra_base.h 2009-03-12 08:50:34 UTC (rev 4023)
@@ -83,15 +83,34 @@
} HYD_Env_prop_t;
#if !defined COMPILER_ACCEPTS_VA_ARGS
-#define HYDU_Print printf
+#define HYDU_Error_printf MPIU_Error_printf
+#elif defined COMPILER_ACCEPTS_FUNC && defined __LINE__
+#define HYDU_Error_printf(...) \
+ fprintf(stderr, "%s (%d): ", __func__, __LINE__); \
+ MPIU_Error_printf(__VA_ARGS__); \
+#elif defined __FILE__ && defined __LINE__
+ fprintf(stderr, "%s (%d): ", __FILE__, __LINE__); \
#else
-#define HYDU_Print(...) \
- int i; \
- for (i = 0; i < HYDU_Dbg_depth; i++) \
- printf(" "); \
- printf(__VA_ARGS__); \
+#endif
+#if !defined COMPILER_ACCEPTS_VA_ARGS
+#define HYDU_Debug if (handle.debug) printf
+#else
+#define HYDU_Debug(...) \
+ if (handle.debug) \
+ printf(__VA_ARGS__); \
#endif /* COMPILER_ACCEPTS_VA_ARGS */
#if !defined ENABLE_DEBUG
@@ -100,44 +119,19 @@
#define HYDU_FUNC_ENTER() \
- HYDU_Print("Entering function %s\n", __func__); \
- HYDU_Dbg_depth++; \
+ HYDU_Debug("Entering function %s\n", __func__); \
#define HYDU_FUNC_EXIT() \
- HYDU_Print("Exiting function %s\n", __func__); \
- HYDU_Dbg_depth--; \
+ HYDU_Debug("Exiting function %s\n", __func__); \
#else
#endif
-#if !defined COMPILER_ACCEPTS_VA_ARGS
-#define HYDU_Error_printf MPIU_Error_printf
-#elif defined COMPILER_ACCEPTS_FUNC && defined __LINE__
-#define HYDU_Error_printf(...) \
- fprintf(stderr, "%s (%d): ", __func__, __LINE__); \
- MPIU_Error_printf(__VA_ARGS__); \
-#elif defined __FILE__ && defined __LINE__
- fprintf(stderr, "%s (%d): ", __FILE__, __LINE__); \
-#else
-#endif
#endif /* HYDRA_BASE_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c 2009-03-12 08:50:34 UTC (rev 4023)
@@ -18,7 +18,7 @@
printf("Usage: ./mpiexec [global opts] [exec1 local opts] : [exec2 local opts] : ...\n\n");
printf("Global Options (passed to all executables):\n");
- printf("\t-v/-vv/-vvv [Verbose level]\n");
+ printf("\t-v [Verbose mode]\n");
printf("\t--enable-x/--disable-x [Enable or disable X forwarding]\n");
printf("\t--proxy-port [Port on which proxies can listen]\n");
printf("\t-genv {name} {value} [Environment variable name and value]\n");
@@ -94,6 +94,7 @@
timeout = atoi(getenv("MPIEXEC_TIMEOUT"));
else
timeout = -1; /* Set a negative timeout */
+ HYDU_Debug("Timeout set to %d seconds (negative means infinite)\n", timeout);
HYDU_Time_set(&handle.timeout, &timeout);
/* Launch the processes */
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/utils.c 2009-03-12 08:50:34 UTC (rev 4023)
@@ -12,7 +12,6 @@
#define HYDRA_MAX_PATH 4096
HYD_Handle handle;
-int HYDU_Dbg_depth;
#define CHECK_LOCAL_PARAM_START(start, status) \
@@ -139,7 +138,7 @@
/* Check what debug level is requested */
- if (!strcmp(*argv, "-v") || !strcmp(*argv, "-vv") || !strcmp(*argv, "-vvv")) {
+ if (!strcmp(*argv, "-v")) {
CHECK_LOCAL_PARAM_START(local_params_started, status);
/* Debug level already set */
@@ -149,14 +148,8 @@
status = HYD_INTERNAL_ERROR;
goto fn_fail;
+ handle.debug = 1;
- if (!strcmp(*argv, "-v"))
- handle.debug = 1;
- else if (!strcmp(*argv, "-vv"))
- handle.debug = 2;
- else if (!strcmp(*argv, "-vvv"))
- handle.debug = 3;
continue;
@@ -458,32 +451,87 @@
HYD_Status HYD_LCHI_Print_parameters(void)
HYD_Env_t *env;
+ int i, j;
+ struct HYD_Proc_params *proc_params;
+ struct HYD_Partition_list *partition;
HYD_Status status = HYD_SUCCESS;
HYDU_FUNC_ENTER();
- HYDU_Print("mpiexec options:\n\n");
- HYDU_Print(" Debug level: %d\n", handle.debug);
- HYDU_Print(" Enable X: %d\n", handle.enablex);
- HYDU_Print(" Working dir: %s\n", handle.wdir);
+ HYDU_Debug("\n");
+ HYDU_Debug("=================================================");
+ HYDU_Debug("\n");
+ HYDU_Debug("mpiexec options:\n");
+ HYDU_Debug("----------------\n");
+ HYDU_Debug(" Base path: %s\n", handle.base_path);
+ HYDU_Debug(" Proxy port: %d\n", handle.proxy_port);
+ HYDU_Debug(" Bootstrap server: %s\n", handle.bootstrap);
+ HYDU_Debug(" Debug level: %d\n", handle.debug);
+ HYDU_Debug(" Enable X: %d\n", handle.enablex);
+ HYDU_Debug(" Working dir: %s\n", handle.wdir);
+ HYDU_Debug(" Host file: %s\n", handle.host_file);
- HYDU_Print("\n");
- HYDU_Print(" Global environment:\n");
+ HYDU_Debug("\n");
+ HYDU_Debug(" Global environment:\n");
+ HYDU_Debug(" -------------------\n");
for (env = handle.global_env; env; env = env->next)
- HYDU_Print(" %s=%s\n", env->env_name, env->env_value);
+ HYDU_Debug(" %s=%s\n", env->env_name, env->env_value);
- HYDU_Print("\n");
- HYDU_Print(" Hydra internal environment:\n");
- for (env = handle.system_env; env; env = env->next)
+ if (handle.system_env) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" Hydra internal environment:\n");
+ HYDU_Debug(" ---------------------------\n");
+ for (env = handle.system_env; env; env = env->next)
- HYDU_Print("\n");
- HYDU_Print(" User set environment:\n");
- for (env = handle.user_env; env; env = env->next)
+ if (handle.user_env) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" User set environment:\n");
+ HYDU_Debug(" ---------------------\n");
+ for (env = handle.user_env; env; env = env->next)
- HYDU_Print("\n");
+ HYDU_Debug("\n\n");
+ HYDU_Debug(" Process parameters:\n");
+ HYDU_Debug(" *******************\n");
+ i = 1;
+ for (proc_params = handle.proc_params; proc_params; proc_params = proc_params->next) {
+ HYDU_Debug(" Executable ID: %2d\n", i++);
+ HYDU_Debug(" -----------------\n");
+ HYDU_Debug(" Process count: %d\n", proc_params->exec_proc_count);
+ HYDU_Debug(" Executable: ");
+ for (j = 0; proc_params->exec[j]; j++)
+ HYDU_Debug("%s ", proc_params->exec[j]);
+ HYDU_Debug("\n");
+ if (proc_params->user_env) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" .....................\n");
+ for (env = proc_params->user_env; env; env = env->next)
+ j = 0;
+ for (partition = proc_params->partition; partition; partition = partition->next) {
+ HYDU_Debug("\n");
+ HYDU_Debug(" Partition ID: %2d\n", j++);
+ HYDU_Debug(" ----------------\n");
+ HYDU_Debug(" Partition name: %s\n", partition->name);
+ HYDU_Debug(" Partition process count: %d\n", partition->proc_count);
+ HYDU_Debug("\n");
+ HYDU_Debug("\n");
HYDU_FUNC_EXIT();
return status;
Modified: mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
--- mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c 2009-03-12 08:50:34 UTC (rev 4023)
@@ -30,6 +30,7 @@
+ HYDU_Debug("Partition list: ");
while (proc_params) {
if (!strcmp(handle.host_file, "HYDRA_USE_LOCALHOST")) {
@@ -37,6 +38,7 @@
proc_params->partition->name = MPIU_Strdup("localhost");
proc_params->partition->proc_count = proc_params->exec_proc_count;
total_procs = proc_params->exec_proc_count;
+ HYDU_Debug("%s:%d ", proc_params->partition->name, proc_params->exec_proc_count);
else {
total_procs = 0;
@@ -70,6 +72,9 @@
partition->proc_count = num_procs;
total_procs += num_procs;
+ HYDU_Debug("%s:%d ", partition->name, partition->proc_count);
if (total_procs == proc_params->exec_proc_count)
break;
@@ -84,6 +89,7 @@
/* Optimize the case where there is only one node */
if (run->next == NULL) {
run->proc_count = proc_params->exec_proc_count;
+ HYDU_Debug("%s:%d ", run->name, run->proc_count);
else {
while (total_procs != proc_params->exec_proc_count) {
@@ -91,6 +97,9 @@
partition = partition->next;
partition->name = MPIU_Strdup(run->name);
partition->proc_count = run->proc_count;
total_procs += partition->proc_count;
run = run->next;
@@ -99,6 +108,7 @@
proc_params = proc_params->next;
+ HYDU_Debug("\n");
fn_exit:
if (fp)
Modified: mpich2/trunk/src/pm/hydra/pm/central/central_launch.c
--- mpich2/trunk/src/pm/hydra/pm/central/central_launch.c 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/pm/central/central_launch.c 2009-03-12 08:50:34 UTC (rev 4023)
@@ -95,6 +95,7 @@
MPIU_Snprintf(port_str, strlen(hostname) + 1 + strlen(sport) + 1,
"%s:%s", hostname, sport);
HYDU_FREE(sport);
+ HYDU_Debug("Process manager listening on PMI port %s\n", port_str);
status = HYDU_Env_create(&env, "PMI_PORT", port_str);
@@ -200,6 +201,11 @@
partition->args[arg] = NULL;
HYDU_Append_exec(proc_params->exec, partition->args);
+ if (handle.debug) {
+ HYDU_Debug("Executable passed to the bootstrap: ");
+ HYDU_Dump_args(partition->args);
process_id += partition->proc_count;
Modified: mpich2/trunk/src/pm/hydra/utils/args/args.c
--- mpich2/trunk/src/pm/hydra/utils/args/args.c 2009-03-12 07:38:31 UTC (rev 4022)
+++ mpich2/trunk/src/pm/hydra/utils/args/args.c 2009-03-12 08:50:34 UTC (rev 4023)
@@ -92,8 +92,8 @@
HYDU_FUNC_ENTER();
for (arg = 0; args[arg]; arg++)
- fprintf(stderr, "%s ", args[arg]);
- fprintf(stderr, "\n");
+ printf("%s ", args[arg]);
+ printf("\n");
HYDU_FUNC_EXIT();
return status;
More information about the mpich2-commits
