[mpich2-commits] r4010 - in mpich2/trunk/src/mpi/romio: mpi-io mpi2-other/info
robl at mcs.anl.gov
robl at mcs.anl.gov
Wed Mar 11 10:54:16 CDT 2009
Author: robl
Date: 2009-03-11 10:54:16 -0500 (Wed, 11 Mar 2009)
New Revision: 4010
Added:
mpich2/trunk/src/mpi/romio/mpi-io/mpir-mpioinit.c
Modified:
mpich2/trunk/src/mpi/romio/mpi-io/Makefile.in
mpich2/trunk/src/mpi/romio/mpi-io/delete.c
mpich2/trunk/src/mpi/romio/mpi-io/mpioimpl.h
mpich2/trunk/src/mpi/romio/mpi-io/open.c
mpich2/trunk/src/mpi/romio/mpi-io/register_datarep.c
mpich2/trunk/src/mpi/romio/mpi2-other/info/info_create.c
Log:
make ADIO initialization code a common routine. Also, place ROMIO attributes
on comm_self, now that the standard explicitly states when attributes on
COMM_SELF are to be freed (early in MPI_FINALIZE). Addresses two of the three
parts of #222 (initialization code in MPI-IO)
Modified: mpich2/trunk/src/mpi/romio/mpi-io/Makefile.in
--- mpich2/trunk/src/mpi/romio/mpi-io/Makefile.in 2009-03-11 09:33:14 UTC (rev 4009)
+++ mpich2/trunk/src/mpi/romio/mpi-io/Makefile.in 2009-03-11 15:54:16 UTC (rev 4010)
@@ -32,7 +32,8 @@
wr_atalle.c write_allb.c write_alle.c \
get_posn_sh.c iread_sh.c read_sh.c write_sh.c \
iwrite_sh.c seek_sh.c read_ord.c read_orde.c write_ordb.c \
- read_ordb.c write_ord.c write_orde.c mpiu_greq.c register_datarep.c
+ read_ordb.c write_ord.c write_orde.c mpiu_greq.c register_datarep.c\
+ mpir-mpioinit.c
# EXTRA objects are ones that need to be included for all but MPICH2
MPIO_OBJECTS = close.o read.o open.o write.o set_view.o \
@@ -49,7 +50,7 @@
get_posn_sh.o iread_sh.o read_sh.o write_sh.o \
iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o \
read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o \
- register_datarep.o
+ register_datarep.o mpir-mpioinit.o
# MPIO_REQOBJECTS are the routines that provide the MPIO_Wait etc.
# routines (iotest.o, iowait.o iowaitall.o iowaitany.o iotestall.o
Modified: mpich2/trunk/src/mpi/romio/mpi-io/delete.c
--- mpich2/trunk/src/mpi/romio/mpi-io/delete.c 2009-03-11 09:33:14 UTC (rev 4009)
+++ mpich2/trunk/src/mpi/romio/mpi-io/delete.c 2009-03-11 15:54:16 UTC (rev 4010)
@@ -23,8 +23,6 @@
#include "mpioprof.h"
#endif
-extern int ADIO_Init_keyval;
MPI_File_delete - Deletes a file
@@ -36,7 +34,7 @@
int MPI_File_delete(char *filename, MPI_Info info)
- int flag, error_code, file_system;
+ int error_code, file_system;
char *tmp;
ADIOI_Fns *fsops;
static char myname[] = "MPI_FILE_DELETE";
@@ -52,35 +50,9 @@
MPIU_THREAD_CS_ENTER(ALLFUNC,);
MPIR_Nest_incr();
- /* first check if ADIO has been initialized. If not, initialize it */
- if (ADIO_Init_keyval == MPI_KEYVAL_INVALID) {
- MPI_Initialized(&flag);
+ MPIR_MPIOInit(&error_code);
+ if (error_code != MPI_SUCCESS) goto fn_exit;
- /* --BEGIN ERROR HANDLING-- */
- if (!flag) {
- error_code = MPIO_Err_create_code(MPI_SUCCESS, MPIR_ERR_RECOVERABLE,
- myname, __LINE__, MPI_ERR_OTHER,
- "**initialized", 0);
- error_code = MPIO_Err_return_file(MPI_FILE_NULL, error_code);
- goto fn_exit;
- /* --END ERROR HANDLING-- */
- MPI_Keyval_create(MPI_NULL_COPY_FN, ADIOI_End_call, &ADIO_Init_keyval,
- (void *) 0);
- /* put a dummy attribute on MPI_COMM_WORLD, because we want the delete
- function to be called when MPI_COMM_WORLD is freed. Hopefully the
- MPI library frees MPI_COMM_WORLD when MPI_Finalize is called,
- though the standard does not mandate this. */
- MPI_Attr_put(MPI_COMM_WORLD, ADIO_Init_keyval, (void *) 0);
- /* initialize ADIO */
- ADIO_Init( (int *)0, (char ***)0, &error_code);
/* resolve file system type from file name; this is a collective call */
ADIO_ResolveFileType(MPI_COMM_SELF, filename, &file_system, &fsops,
&error_code);
Modified: mpich2/trunk/src/mpi/romio/mpi-io/mpioimpl.h
--- mpich2/trunk/src/mpi/romio/mpi-io/mpioimpl.h 2009-03-11 09:33:14 UTC (rev 4009)
+++ mpich2/trunk/src/mpi/romio/mpi-io/mpioimpl.h 2009-03-11 15:54:16 UTC (rev 4010)
@@ -60,6 +60,10 @@
MPI_Delete_function ADIOI_End_call;
+/* common initialization routine */
+void MPIR_MPIOInit(int * error_code);
#ifdef MPI_hpux
Added: mpich2/trunk/src/mpi/romio/mpi-io/mpir-mpioinit.c
--- mpich2/trunk/src/mpi/romio/mpi-io/mpir-mpioinit.c (rev 0)
+++ mpich2/trunk/src/mpi/romio/mpi-io/mpir-mpioinit.c 2009-03-11 15:54:16 UTC (rev 4010)
@@ -0,0 +1,56 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2009 UChicago/Argonne LLC
+ * See COPYRIGHT in top-level directory.
+#include <string.h>
+#include "mpioimpl.h"
+#ifdef HAVE_WEAK_SYMBOLS
+/* Include mapping from MPI->PMPI */
+#define MPIO_BUILD_PROFILING
+#include "mpioprof.h"
+#endif
+extern int ADIO_Init_keyval;
+/* common code to stuff an attribute on a communicator for the purpose of
+ * cleaning up in MPI_Finalize() */
+void MPIR_MPIOInit(int * error_code) {
+ int flag;
+ char myname[] = "MPIR_MPIOInit";
+ /* first check if ADIO has been initialized. If not, initialize it */
+ if (ADIO_Init_keyval == MPI_KEYVAL_INVALID) {
+ MPI_Initialized(&flag);
+ /* --BEGIN ERROR HANDLING-- */
+ if (!flag) {
+ *error_code = MPIO_Err_create_code(MPI_SUCCESS,
+ MPIR_ERR_RECOVERABLE, myname, __LINE__,
+ MPI_ERR_OTHER, "**initialized", 0);
+ *error_code = MPIO_Err_return_file(MPI_FILE_NULL, *error_code);
+ return;
+ /* --END ERROR HANDLING-- */
+ MPI_Keyval_create(MPI_NULL_COPY_FN, ADIOI_End_call, &ADIO_Init_keyval,
+ (void *) 0);
+ /* put a dummy attribute on MPI_COMM_SELF, because we want the delete
+ function to be called when MPI_COMM_SELF is freed. Clarified
+ in MPI-2 section 4.8, the standard mandates that attribugtes on
+ MPI_COMM_SELF get cleaned up early in MPI_Finalize */
+ MPI_Attr_put(MPI_COMM_SELF, ADIO_Init_keyval, (void *) 0);
+ /* initialize ADIO */
+ ADIO_Init( (int *)0, (char ***)0, error_code);
+ *error_code = MPI_SUCCESS;
+ * vim: ts=8 sts=4 sw=4 noexpandtab
Modified: mpich2/trunk/src/mpi/romio/mpi-io/open.c
--- mpich2/trunk/src/mpi/romio/mpi-io/open.c 2009-03-11 09:33:14 UTC (rev 4009)
+++ mpich2/trunk/src/mpi/romio/mpi-io/open.c 2009-03-11 15:54:16 UTC (rev 4010)
@@ -118,35 +118,9 @@
/* check if ADIO has been initialized. If not, initialize it */
+ if (error_code != MPI_SUCCESS) goto fn_fail;
- if (!flag) {
- MPIR_ERR_RECOVERABLE,
- goto fn_fail;
- (void *) 0);
-/* put a dummy attribute on MPI_COMM_WORLD, because we want the delete
-/* initialize ADIO */
file_system = -1;
Modified: mpich2/trunk/src/mpi/romio/mpi-io/register_datarep.c
--- mpich2/trunk/src/mpi/romio/mpi-io/register_datarep.c 2009-03-11 09:33:14 UTC (rev 4009)
+++ mpich2/trunk/src/mpi/romio/mpi-io/register_datarep.c 2009-03-11 15:54:16 UTC (rev 4010)
@@ -23,8 +23,6 @@
#endif
MPI_Register_datarep - Register functions for user-defined data
representations
@@ -79,34 +77,9 @@
- if (!flag) {
- goto fn_exit;
- (void *) 0);
/* check datarep isn't already registered */
for (datarep = ADIOI_Datarep_head; datarep; datarep = datarep->next) {
Modified: mpich2/trunk/src/mpi/romio/mpi2-other/info/info_create.c
--- mpich2/trunk/src/mpi/romio/mpi2-other/info/info_create.c 2009-03-11 09:33:14 UTC (rev 4009)
+++ mpich2/trunk/src/mpi/romio/mpi2-other/info/info_create.c 2009-03-11 15:54:16 UTC (rev 4010)
@@ -23,8 +23,6 @@
#endif
MPI_Info_create - Creates a new info object
@@ -35,34 +33,11 @@
int MPI_Info_create(MPI_Info *info)
- int flag, error_code;
+ int error_code;
- /* check if MPI itself has been initialized. If not, flag an error.
- Can't initialize it here, because don't know argc, argv */
- if (!flag) {
- FPRINTF(stderr, "Error: MPI_Init() must be called before using MPI_Info_create\n");
- MPI_Abort(MPI_COMM_WORLD, 1);
- (void *) 0);
*info = (MPI_Info) ADIOI_Malloc(sizeof(struct MPIR_Info));
(*info)->cookie = MPIR_INFO_COOKIE;
(*info)->key = 0;
@@ -71,5 +46,6 @@
/* this is the first structure in this linked list. it is
always kept empty. new (key,value) pairs are added after it. */
+fn_exit:
return MPI_SUCCESS;
More information about the mpich2-commits
