[mpich2-commits] r4002 - in mpich2/trunk/src/pm/hydra: include launcher/mpiexec launcher/utils utils/timer
balaji at mcs.anl.gov balaji at mcs.anl.gov
Tue Mar 10 17:48:33 CDT 2009
Author: balaji
Date: 2009-03-10 17:48:33 -0500 (Tue, 10 Mar 2009)
New Revision: 4002
Modified:
   mpich2/trunk/src/pm/hydra/include/hydra_utils.h
   mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
   mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
   mpich2/trunk/src/pm/hydra/utils/timer/timer.c
Log:
Added back the code to wrap
Modified: mpich2/trunk/src/pm/hydra/include/hydra_utils.h
--- mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-03-10 22:20:00 UTC (rev 4001)
+++ mpich2/trunk/src/pm/hydra/include/hydra_utils.h	2009-03-10 22:48:33 UTC (rev 4002)
@@ -26,7 +26,7 @@
 struct HYD_Partition_list {
     char *name;
     int proc_count;
-    char **mapping;     /* Can be core IDs or something else */
+    char **mapping;             /* Can be core IDs or something else */
      * The boot-strap server is expected to start a single executable
@@ -48,8 +48,8 @@
      *   3. One proxy per physical node means that each partition will
      *      have a different group ID.
-    int group_id;       /* Assumed to be in ascending order */
-    int group_rank;     /* Rank within the group */
+    int group_id;               /* Assumed to be in ascending order */
+    int group_rank;             /* Rank within the group */
     int pid;
     int out;
     int err;
@@ -164,7 +164,7 @@
 #include <time.h>
 #endif /* HAVE_TIME */
 typedef struct timeval HYD_Time;
-void HYDU_Time_set(HYD_Time * time, int * val);
+void HYDU_Time_set(HYD_Time * time, int *val);
 int HYDU_Time_left(HYD_Time start, HYD_Time timeout);
Modified: mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c
--- mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c	2009-03-10 22:20:00 UTC (rev 4001)
+++ mpich2/trunk/src/pm/hydra/launcher/mpiexec/mpiexec.c	2009-03-10 22:48:33 UTC (rev 4002)
@@ -91,7 +91,7 @@
     if (getenv("MPIEXEC_TIMEOUT"))
         timeout = atoi(getenv("MPIEXEC_TIMEOUT"));
     else
-        timeout = -1; /* Set a negative timeout */
+        timeout = -1;   /* Set a negative timeout */
     HYDU_Time_set(&handle.timeout, &timeout);
     /* Launch the processes */
Modified: mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c
--- mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c	2009-03-10 22:20:00 UTC (rev 4001)
+++ mpich2/trunk/src/pm/hydra/launcher/utils/lchu.c	2009-03-10 22:48:33 UTC (rev 4002)
@@ -15,7 +15,7 @@
     FILE *fp = NULL;
     char line[2 * MAX_HOSTNAME_LEN], *hostname, *procs;
     struct HYD_Proc_params *proc_params;
-    struct HYD_Partition_list *partition;
+    struct HYD_Partition_list *partition, *run;
     int num_procs, total_procs;
     HYD_Status status = HYD_SUCCESS;
@@ -75,8 +75,28 @@
-        if (total_procs != proc_params->exec_proc_count)
-            break;
+        /* We don't have enough processes; use whatever we have */
+        if (total_procs != proc_params->exec_proc_count) {
+            for (partition = proc_params->partition;
+                 partition->next; partition = partition->next);
+            run = proc_params->partition;
+            /* Optimize the case where there is only one node */
+            if (run->next == NULL) {
+                run->proc_count = proc_params->exec_proc_count;
+            else {
+                while (total_procs != proc_params->exec_proc_count) {
+                    HYDU_Allocate_Partition(&partition->next);
+                    partition = partition->next;
+                    partition->name = MPIU_Strdup(run->name);
+                    partition->proc_count = run->proc_count;
+                    total_procs += partition->proc_count;
+                    run = run->next;
         proc_params = proc_params->next;
Modified: mpich2/trunk/src/pm/hydra/utils/timer/timer.c
--- mpich2/trunk/src/pm/hydra/utils/timer/timer.c	2009-03-10 22:20:00 UTC (rev 4001)
+++ mpich2/trunk/src/pm/hydra/utils/timer/timer.c	2009-03-10 22:48:33 UTC (rev 4002)
@@ -8,7 +8,7 @@
 /* FIXME: Here we assume that the timer is gettimeofday. */
     if (val == NULL) {
         /* Set time to right now */
@@ -40,7 +40,7 @@
             time_left = 0;
-fn_exit:
+  fn_exit:
     HYDU_FUNC_EXIT();
     return time_left;
More information about the mpich2-commits mailing list
