[mpich2-commits] r3967 - in mpich2/trunk/src/pm/hydra: . bootstrap/ssh bootstrap/utils include utils utils/launch
balaji at mcs.anl.gov
Sat Mar 7 17:22:44 CST 2009
Author: balaji
Date: 2009-03-07 17:22:44 -0600 (Sat, 07 Mar 2009)
New Revision: 3967
Added:
mpich2/trunk/src/pm/hydra/include/hydra_launch.h
mpich2/trunk/src/pm/hydra/utils/launch/
mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm
mpich2/trunk/src/pm/hydra/utils/launch/args.c
mpich2/trunk/src/pm/hydra/utils/launch/launch.c
Removed:
mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_args.c
mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_launch.c
Modified:
mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c
mpich2/trunk/src/pm/hydra/bootstrap/utils/Makefile.sm
mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu.h
mpich2/trunk/src/pm/hydra/configure.in
mpich2/trunk/src/pm/hydra/utils/Makefile.sm
Log:
Move out common functionality as common utilities.
Modified: mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c
--- mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c 2009-03-07 21:47:37 UTC (rev 3966)
+++ mpich2/trunk/src/pm/hydra/bootstrap/ssh/ssh_launch.c 2009-03-07 23:22:44 UTC (rev 3967)
@@ -7,6 +7,7 @@
#include "hydra.h"
#include "hydra_sock.h"
#include "hydra_mem.h"
+#include "hydra_launch.h"
#include "bsci.h"
#include "bscu.h"
@@ -79,10 +80,10 @@
client_arg[arg++] = MPIU_Strdup("\"");
client_arg[arg++] = NULL;
- HYD_BSCU_Append_env(handle.system_env, client_arg, process_id);
- HYD_BSCU_Append_env(proc_params->prop_env, client_arg, process_id);
- HYD_BSCU_Append_wdir(client_arg);
- HYD_BSCU_Append_exec(proc_params->exec, client_arg);
+ HYDU_Append_env(handle.system_env, client_arg, process_id);
+ HYDU_Append_env(proc_params->prop_env, client_arg, process_id);
+ HYDU_Append_wdir(client_arg);
+ HYDU_Append_exec(proc_params->exec, client_arg);
for (arg = 0; client_arg[arg]; arg++);
@@ -90,9 +91,9 @@
/* The stdin pointer will be some value for process_id 0;
* for everyone else, it's NULL. */
- status = HYD_BSCU_Create_process(client_arg, (process_id == 0 ? &handle.in : NULL),
- &proc_params->out[i], &proc_params->err[i],
- &proc_params->pid[i]);
+ status = HYDU_Create_process(client_arg, (process_id == 0 ? &handle.in : NULL),
+ &proc_params->out[i], &proc_params->err[i],
+ &proc_params->pid[i]);
if (status != HYD_SUCCESS) {
HYDU_Error_printf("bootstrap spawn process returned error\n");
goto fn_fail;
@@ -151,7 +152,7 @@
client_arg[arg++] = MPIU_Strdup(hostname);
client_arg[arg++] = MPIU_Strdup("killall");
@@ -165,7 +166,7 @@
client_arg[arg++] = MPIU_Strdup(execname);
- status = HYD_BSCU_Create_process(client_arg, NULL, NULL, NULL, NULL);
+ status = HYDU_Create_process(client_arg, NULL, NULL, NULL, NULL);
goto fn_fail;
Modified: mpich2/trunk/src/pm/hydra/bootstrap/utils/Makefile.sm
--- mpich2/trunk/src/pm/hydra/bootstrap/utils/Makefile.sm 2009-03-07 21:47:37 UTC (rev 3966)
+++ mpich2/trunk/src/pm/hydra/bootstrap/utils/Makefile.sm 2009-03-07 23:22:44 UTC (rev 3967)
@@ -6,7 +6,7 @@
HYDRA_LIB_PATH = ../../lib
libhydra_a_DIR = ${HYDRA_LIB_PATH}
-libhydra_a_SOURCES = bscu_init.c bscu_finalize.c bscu_args.c bscu_wait.c bscu_launch.c bscu_signal.c
+libhydra_a_SOURCES = bscu_init.c bscu_finalize.c bscu_wait.c bscu_signal.c
INCLUDES = -I${abs_srcdir}/../../include \
-I${abs_srcdir}/../../../../include \
-I../../include \
Modified: mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu.h
--- mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu.h 2009-03-07 21:47:37 UTC (rev 3966)
+++ mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu.h 2009-03-07 23:22:44 UTC (rev 3967)
@@ -15,11 +15,7 @@
HYD_Status HYD_BSCU_Finalize_exit_status(void);
HYD_Status HYD_BSCU_Init_io_fds(void);
HYD_Status HYD_BSCU_Finalize_io_fds(void);
-HYD_Status HYD_BSCU_Create_process(char **client_arg, int *in, int *out, int *err, int *pid);
HYD_Status HYD_BSCU_Wait_for_completion(void);
-HYD_Status HYD_BSCU_Append_env(HYD_Env_t * env_list, char **client_arg, int id);
-HYD_Status HYD_BSCU_Append_exec(char **exec, char **client_arg);
-HYD_Status HYD_BSCU_Append_wdir(char **client_arg);
HYD_Status HYD_BSCU_Set_common_signals(void (*handler) (int));
void HYD_BSCU_Signal_handler(int signal);
Deleted: mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_args.c
--- mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_args.c 2009-03-07 21:47:37 UTC (rev 3966)
+++ mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_args.c 2009-03-07 23:22:44 UTC (rev 3967)
@@ -1,97 +0,0 @@
-/* -*- Mode: C; c-basic-offset:4 ; -*- */
- * (C) 2008 by Argonne National Laboratory.
- * See COPYRIGHT in top-level directory.
-#include "hydra.h"
-#include "hydra_mem.h"
-#include "bsci.h"
-#include "bscu.h"
-HYD_Handle handle;
- int i, j, csh_format;
- HYD_Env_t *env;
- char *envstr, *tmp[HYDU_NUM_JOIN_STR], *inc;
- HYD_Status status = HYD_SUCCESS;
- HYDU_FUNC_ENTER();
- for (i = 0; client_arg[i]; i++);
- env = env_list;
- while (env) {
- j = 0;
- tmp[j++] = MPIU_Strdup(env->env_name);
- tmp[j++] = MPIU_Strdup("=");
- if (env->env_type == HYD_ENV_STATIC)
- tmp[j++] = MPIU_Strdup(env->env_value);
- else if (env->env_type == HYD_ENV_AUTOINC) {
- HYDU_Int_to_str(env->start_val + id, inc, status);
- tmp[j++] = MPIU_Strdup(inc);
- HYDU_FREE(inc);
- tmp[j++] = NULL;
- HYDU_STR_ALLOC_AND_JOIN(tmp, envstr, status);
- client_arg[i++] = MPIU_Strdup(envstr);
- HYDU_FREE(envstr);
- for (j = 0; tmp[j]; j++)
- HYDU_FREE(tmp[j]);
- client_arg[i++] = MPIU_Strdup(";");
- client_arg[i++] = MPIU_Strdup("export");
- client_arg[i++] = MPIU_Strdup(env->env_name);
- env = env->next;
- client_arg[i++] = NULL;
- fn_exit:
- HYDU_FUNC_EXIT();
- return status;
- fn_fail:
- goto fn_exit;
- int i, j;
- for (j = 0; exec[j]; j++)
- client_arg[i++] = MPIU_Strdup(exec[j]);
- HYDU_FUNC_EXIT();
- return status;
- int arg;
- for (arg = 0; client_arg[arg]; arg++);
- client_arg[arg++] = MPIU_Strdup("cd");
- client_arg[arg++] = MPIU_Strdup(handle.wdir);
- client_arg[arg++] = MPIU_Strdup(";");
- client_arg[arg++] = NULL;
- HYDU_FUNC_EXIT();
- return status;
Deleted: mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_launch.c
--- mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_launch.c 2009-03-07 21:47:37 UTC (rev 3966)
+++ mpich2/trunk/src/pm/hydra/bootstrap/utils/bscu_launch.c 2009-03-07 23:22:44 UTC (rev 3967)
@@ -1,105 +0,0 @@
-#include "hydra.h"
-#include "bsci.h"
-#include "bscu.h"
-HYD_Handle handle;
- int inpipe[2], outpipe[2], errpipe[2], arg, tpid;
- if (in != NULL) {
- if (pipe(inpipe) < 0) {
- HYDU_Error_printf("pipe error (errno: %d)\n", errno);
- status = HYD_SOCK_ERROR;
- goto fn_fail;
- if (pipe(outpipe) < 0) {
- goto fn_fail;
- if (pipe(errpipe) < 0) {
- goto fn_fail;
- /* Fork off the process */
- tpid = fork();
- if (tpid == 0) { /* Child process */
- close(outpipe[0]);
- close(1);
- if (dup2(outpipe[1], 1) < 0) {
- HYDU_Error_printf("dup2 error (errno: %d)\n", errno);
- goto fn_fail;
- close(errpipe[0]);
- close(2);
- if (dup2(errpipe[1], 2) < 0) {
- goto fn_fail;
- if (in != NULL) {
- close(inpipe[1]);
- close(0);
- if (dup2(inpipe[0], 0) < 0) {
- goto fn_fail;
- if (chdir(handle.wdir) < 0) {
- if (chdir(getenv("HOME")) < 0) {
- HYDU_Error_printf("unable to set working directory to %s\n", handle.wdir);
- status = HYD_INTERNAL_ERROR;
- goto fn_fail;
- /* execvp the process */
- if (execvp(client_arg[0], client_arg) < 0) {
- HYDU_Error_printf("execvp error\n");
- goto fn_fail;
- else { /* Parent process */
- close(outpipe[1]);
- close(errpipe[1]);
- if (in)
- *in = inpipe[1];
- if (out)
- *out = outpipe[0];
- if (err)
- *err = errpipe[0];
- if (pid)
- *pid = tpid;
- fn_exit:
- HYDU_FUNC_EXIT();
- return status;
- fn_fail:
- goto fn_exit;
Modified: mpich2/trunk/src/pm/hydra/configure.in
--- mpich2/trunk/src/pm/hydra/configure.in 2009-03-07 21:47:37 UTC (rev 3966)
+++ mpich2/trunk/src/pm/hydra/configure.in 2009-03-07 23:22:44 UTC (rev 3967)
@@ -260,6 +260,7 @@
utils/env/Makefile \
utils/sock/Makefile \
utils/signals/Makefile \
+ utils/launch/Makefile \
launcher/Makefile \
launcher/utils/Makefile \
launcher/${HYDRA_LAUNCHER}/Makefile \
Added: mpich2/trunk/src/pm/hydra/include/hydra_launch.h
--- mpich2/trunk/src/pm/hydra/include/hydra_launch.h (rev 0)
+++ mpich2/trunk/src/pm/hydra/include/hydra_launch.h 2009-03-07 23:22:44 UTC (rev 3967)
@@ -0,0 +1,17 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2008 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#ifndef HYDRA_LAUNCH_H_INCLUDED
+#define HYDRA_LAUNCH_H_INCLUDED
+#include "hydra.h"
+HYD_Status HYDU_Append_env(HYD_Env_t * env_list, char **client_arg, int id);
+HYD_Status HYDU_Append_exec(char **exec, char **client_arg);
+HYD_Status HYDU_Append_wdir(char **client_arg);
+HYD_Status HYDU_Create_process(char **client_arg, int *in, int *out, int *err, int *pid);
+#endif /* HYDRA_LAUNCH_H_INCLUDED */
Modified: mpich2/trunk/src/pm/hydra/utils/Makefile.sm
--- mpich2/trunk/src/pm/hydra/utils/Makefile.sm 2009-03-07 21:47:37 UTC (rev 3966)
+++ mpich2/trunk/src/pm/hydra/utils/Makefile.sm 2009-03-07 23:22:44 UTC (rev 3967)
@@ -3,4 +3,4 @@
# See COPYRIGHT in top-level directory.
-SUBDIRS = dbg env sock signals .
+SUBDIRS = dbg env sock signals launch .
Property changes on: mpich2/trunk/src/pm/hydra/utils/launch
___________________________________________________________________
+ Makefile
Makefile.in
Added: mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm
--- mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/launch/Makefile.sm 2009-03-07 23:22:44 UTC (rev 3967)
@@ -0,0 +1,13 @@
+# (C) 2008 by Argonne National Laboratory.
+# See COPYRIGHT in top-level directory.
+HYDRA_LIB_PATH = ../../lib
+libhydra_a_DIR = ${HYDRA_LIB_PATH}
+libhydra_a_SOURCES = args.c launch.c
+INCLUDES = -I${abs_srcdir}/../../include \
+ -I${abs_srcdir}/../../../../include \
+ -I../../include \
+ -I../../../../include
Added: mpich2/trunk/src/pm/hydra/utils/launch/args.c
--- mpich2/trunk/src/pm/hydra/utils/launch/args.c (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/launch/args.c 2009-03-07 23:22:44 UTC (rev 3967)
@@ -0,0 +1,96 @@
+#include "hydra.h"
+#include "hydra_mem.h"
+HYD_Handle handle;
+ int i, j, csh_format;
+ HYD_Env_t *env;
+ char *envstr, *tmp[HYDU_NUM_JOIN_STR], *inc;
+ HYD_Status status = HYD_SUCCESS;
+ HYDU_FUNC_ENTER();
+ for (i = 0; client_arg[i]; i++);
+ env = env_list;
+ while (env) {
+ j = 0;
+ tmp[j++] = MPIU_Strdup(env->env_name);
+ tmp[j++] = MPIU_Strdup("=");
+ if (env->env_type == HYD_ENV_STATIC)
+ tmp[j++] = MPIU_Strdup(env->env_value);
+ else if (env->env_type == HYD_ENV_AUTOINC) {
+ HYDU_Int_to_str(env->start_val + id, inc, status);
+ tmp[j++] = MPIU_Strdup(inc);
+ HYDU_FREE(inc);
+ tmp[j++] = NULL;
+ HYDU_STR_ALLOC_AND_JOIN(tmp, envstr, status);
+ client_arg[i++] = MPIU_Strdup(envstr);
+ HYDU_FREE(envstr);
+ for (j = 0; tmp[j]; j++)
+ HYDU_FREE(tmp[j]);
+ client_arg[i++] = MPIU_Strdup(";");
+ client_arg[i++] = MPIU_Strdup("export");
+ client_arg[i++] = MPIU_Strdup(env->env_name);
+ env = env->next;
+ client_arg[i++] = NULL;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
+ int i, j;
+ for (j = 0; exec[j]; j++)
+ client_arg[i++] = MPIU_Strdup(exec[j]);
+ HYDU_FUNC_EXIT();
+ return status;
+ int arg;
+ for (arg = 0; client_arg[arg]; arg++);
+ client_arg[arg++] = MPIU_Strdup("cd");
+ client_arg[arg++] = MPIU_Strdup(handle.wdir);
+ client_arg[arg++] = MPIU_Strdup(";");
+ client_arg[arg++] = NULL;
+ HYDU_FUNC_EXIT();
+ return status;
Added: mpich2/trunk/src/pm/hydra/utils/launch/launch.c
--- mpich2/trunk/src/pm/hydra/utils/launch/launch.c (rev 0)
+++ mpich2/trunk/src/pm/hydra/utils/launch/launch.c 2009-03-07 23:22:44 UTC (rev 3967)
@@ -0,0 +1,104 @@
+#include "hydra.h"
+HYD_Handle handle;
+ int inpipe[2], outpipe[2], errpipe[2], arg, tpid;
+ if (in != NULL) {
+ if (pipe(inpipe) < 0) {
+ HYDU_Error_printf("pipe error (errno: %d)\n", errno);
+ status = HYD_SOCK_ERROR;
+ goto fn_fail;
+ if (pipe(outpipe) < 0) {
+ goto fn_fail;
+ if (pipe(errpipe) < 0) {
+ goto fn_fail;
+ /* Fork off the process */
+ tpid = fork();
+ if (tpid == 0) { /* Child process */
+ close(outpipe[0]);
+ close(1);
+ if (dup2(outpipe[1], 1) < 0) {
+ HYDU_Error_printf("dup2 error (errno: %d)\n", errno);
+ goto fn_fail;
+ close(errpipe[0]);
+ close(2);
+ if (dup2(errpipe[1], 2) < 0) {
+ goto fn_fail;
+ if (in != NULL) {
+ close(inpipe[1]);
+ close(0);
+ if (dup2(inpipe[0], 0) < 0) {
+ goto fn_fail;
+ if (chdir(handle.wdir) < 0) {
+ if (chdir(getenv("HOME")) < 0) {
+ HYDU_Error_printf("unable to set working directory to %s\n", handle.wdir);
+ status = HYD_INTERNAL_ERROR;
+ goto fn_fail;
+ /* execvp the process */
+ if (execvp(client_arg[0], client_arg) < 0) {
+ HYDU_Error_printf("execvp error\n");
+ goto fn_fail;
+ else { /* Parent process */
+ close(outpipe[1]);
+ close(errpipe[1]);
+ if (in)
+ *in = inpipe[1];
+ if (out)
+ *out = outpipe[0];
+ if (err)
+ *err = errpipe[0];
+ if (pid)
+ *pid = tpid;
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
More information about the mpich2-commits
