[mpich2-commits] r3943 - in mpich2/trunk/src/util: . other
balaji at mcs.anl.gov
Thu Mar 5 15:25:26 CST 2009
Author: balaji
Date: 2009-03-05 15:25:26 -0600 (Thu, 05 Mar 2009)
New Revision: 3943
Added:
mpich2/trunk/src/util/other/
mpich2/trunk/src/util/other/Makefile.sm
mpich2/trunk/src/util/other/outliers.c
Modified:
mpich2/trunk/src/util/Makefile.sm
Log:
Added the outlier detection algorithm, though it's currently unused.
Modified: mpich2/trunk/src/util/Makefile.sm
--- mpich2/trunk/src/util/Makefile.sm 2009-03-05 20:38:38 UTC (rev 3942)
+++ mpich2/trunk/src/util/Makefile.sm 2009-03-05 21:25:26 UTC (rev 3943)
@@ -1,3 +1,3 @@
-SUBDIRS = mem info msgs instrm thread dbg param osserv procmap @logging_dir@ .
+SUBDIRS = mem info msgs instrm thread dbg param osserv procmap other @logging_dir@ .
SUBDIRS_logging_dir = logging
# Note info requires the PMPILIBNAME definition
Property changes on: mpich2/trunk/src/util/other
___________________________________________________________________
+ *.o
*.lo
Makefile
Makefile.in
*Debug*
*Release*
.deps
*.bb
*.bbg
*.da
*.gcov
*.gcda
*.gcno
.libs
.libstamp*
*.user
getfuncstack
.state-cache
Added: mpich2/trunk/src/util/other/Makefile.sm
--- mpich2/trunk/src/util/other/Makefile.sm (rev 0)
+++ mpich2/trunk/src/util/other/Makefile.sm 2009-03-05 21:25:26 UTC (rev 3943)
@@ -0,0 +1,2 @@
+lib${MPILIBNAME}_a_SOURCES = outliers.c
+INCLUDES = -I../../include -I${top_srcdir}/src/include
Added: mpich2/trunk/src/util/other/outliers.c
--- mpich2/trunk/src/util/other/outliers.c (rev 0)
+++ mpich2/trunk/src/util/other/outliers.c 2009-03-05 21:25:26 UTC (rev 3943)
@@ -0,0 +1,145 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2001 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#include "mpiimpl.h"
+#include <stdlib.h>
+#include <assert.h>
+#define GROUPSIZE 5
+/* Insertion sort on array 'a' containing n elements */
+static inline void isort(int a[], const int n)
+ int i;
+ int j;
+ int key;
+ for (j = 1; j < n; ++j) {
+ key = a[j];
+ i = j - 1;
+ while (i >= 0 && a[i] > key) {
+ a[i+1] = a[i];
+ i -= 1;
+ a[i+1] = key;
+/* Partition array 'a' of size n around the value pivot and returns
+ * the index of the pivot point */
+static inline int partition(const int pivot, int a[], const int n)
+ int i = 0;
+ int j = n-1;
+ int tmp;
+ while (1) {
+ while ((j > 0) && (a[j] < pivot)) --j;
+ while ((i < n) && (a[i] >= pivot)) ++i;
+ if (i < j) {
+ tmp = a[i];
+ a[i] = a[j];
+ a[j] = tmp;
+ else {
+ return j;
+/* This does all of the work for k_select */
+static void k_select_r(const int k, int a[], const int n, int *value)
+ int ngroups;
+ int i;
+ int median_median;
+ int surfeit;
+ int mk;
+ int *medians;
+ assert (k < n);
+ ngroups = (n + GROUPSIZE-1) / GROUPSIZE;
+ medians = malloc (ngroups * sizeof (int));
+ /* Divide 'a' into groups, sort the elements of each group and
+ pull out the median of each group */
+ for (i = 0; i < ngroups-1; ++i) {
+ isort(&a[i * GROUPSIZE], GROUPSIZE);
+ medians[i] = a[i*GROUPSIZE + GROUPSIZE/2];
+ surfeit = (n - i * GROUPSIZE);
+ isort(&a[i * GROUPSIZE], surfeit);
+ medians[i] = a[i*GROUPSIZE + surfeit/2];
+ if (ngroups == 1) {
+ *value = a[n - 1 - k];
+ free(medians);
+ return;
+ /* use k_select to find the median of medians */
+ k_select_r((ngroups / 2) - 1 + (ngroups % 2), medians, ngroups, &median_median);
+ free(medians);
+ /* partition array a around the median of medians and return the
+ index of the median of medians */
+ mk = partition(median_median, a, n);
+ /* if this is the last element, we're done */
+ if (mk == n - 1)
+ *value = a[mk];
+ else if (k <= mk)
+ /* call k_select to find the kth element in a[0..mk-1] (the
+ array up to the element before the median of medians) */
+ k_select_r(k, &a[0], mk + 1, value);
+ else
+ /* call k_select to find the (k-mk)th element in a[mk+1..n] (the
+ array starting from the element after the median of medians) */
+ k_select_r(k - (mk+1), &a[mk+1], n - (mk+1), value);
+/* Returns the value of the kth smallest element in array a of size
+ * n. Allocates an array and calls the recursive function k_select_r
+ * which does all the work */
+static int k_select(const int k, int a[], const int n, int *value)
+ int mpi_errno = MPI_SUCCESS;
+ int ngroups;
+ k_select_r(k - 1, a, n, value);
+ return mpi_errno;
+/* Returns the ratio of the maximum size and the outlier_frac
+ * percentile size. */
+int MPIU_Outlier_ratio(int * sizes, int n_sizes, double outlier_frac, double threshold)
+ int max, k_max, i;
+ double retval;
+ k_select(n_sizes, sizes, n_sizes, &max);
+ max = sizes[0];
+ for (i = 0; i < n_sizes; i++)
+ if (max < sizes[i])
+ max = sizes[i];
+ k_select((int) (n_sizes * outlier_frac), sizes, n_sizes, &k_max);
+ retval = (double) max / k_max;
+ if (retval > threshold) {
+ return 1;
+ else {
+ return 0;
More information about the mpich2-commits
