[mpich-discuss] GCC 4.7.2 warnings
Pavan Balaji
balaji at mcs.anl.gov
Wed Sep 26 22:14:47 CDT 2012
Thanks. I've created a ticket for this.
https://trac.mcs.anl.gov/projects/mpich2/ticket/1696
I'll look into it as soon as I can get GCC 4.7.2 on my machine.
-- Pavan
On 09/26/2012 07:11 PM, Yauheni Zelenko wrote:
> Hi!
> I tried to compile r10272 tarball with GCC 4.7.2 and got next warnings which I think will be good idea to fix.
> src/mpltrmem.c: In function 'MPL_trdump':
> src/mpltrmem.c:536:14: warning: variable 'old_head' set but not used [-Wunused-but-set-variable]
> iterator.c: In function 'MPE_CallStack_iteratorInit':
> iterator.c:40:12: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> fancyprint.c: In function 'MPE_CallStack_fancyprint':
> fancyprint.c:39:12: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> clog_util.c: In function 'CLOG_Util_abort':
> clog_util.c:54:22: warning: variable 'isz' set but not used [-Wunused-but-set-variable]
> clog_commset.c: In function 'CLOG_CommSet_add_intracomm':
> clog_commset.c:310:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
> clog_commset.c: In function 'CLOG_CommSet_add_intercomm':
> clog_commset.c:369:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
> mpi-io/read.c: In function 'MPIOI_File_read':
> mpi-io/read.c:127:9: warning: implicit declaration of function 'MPIU_datatype_full_size' [-Wimplicit-function-declaration]
> mpi-io/read.c:127:9: warning: nested extern declaration of 'MPIU_datatype_full_size' [-Wnested-externs]
> mpi-io/read.c:173:9: warning: implicit declaration of function 'MPIU_read_external32_conversion_fn' [-Wimplicit-function-declaration]
> mpi-io/read.c:173:9: warning: nested extern declaration of 'MPIU_read_external32_conversion_fn' [-Wnested-externs]
> mpi-io/read_all.c: In function 'MPIOI_File_read_all':
> mpi-io/read_all.c:110:9: warning: implicit declaration of function 'MPIU_datatype_full_size' [-Wimplicit-function-declaration]
> mpi-io/read_all.c:110:9: warning: nested extern declaration of 'MPIU_datatype_full_size' [-Wnested-externs]
> mpi-io/read_all.c:127:9: warning: implicit declaration of function 'MPIU_read_external32_conversion_fn' [-Wimplicit-function-declaration]
> mpi-io/read_all.c:127:9: warning: nested extern declaration of 'MPIU_read_external32_conversion_fn' [-Wnested-externs]
> mpi-io/read_allb.c: In function 'MPIOI_File_read_all_begin':
> mpi-io/read_allb.c:107:9: warning: implicit declaration of function 'MPIU_datatype_full_size' [-Wimplicit-function-declaration]
> mpi-io/read_allb.c:107:9: warning: nested extern declaration of 'MPIU_datatype_full_size' [-Wnested-externs]
> mpi-io/read_allb.c:124:9: warning: implicit declaration of function 'MPIU_read_external32_conversion_fn' [-Wimplicit-function-declaration]
> mpi-io/read_allb.c:124:9: warning: nested extern declaration of 'MPIU_read_external32_conversion_fn' [-Wnested-externs]
> mpi-io/read_ordb.c: In function 'PMPI_File_read_ordered_begin':
> mpi-io/read_ordb.c:105:9: warning: implicit declaration of function 'MPIU_datatype_full_size' [-Wimplicit-function-declaration]
> mpi-io/read_ordb.c:105:9: warning: nested extern declaration of 'MPIU_datatype_full_size' [-Wnested-externs]
> mpi-io/read_ordb.c:123:9: warning: implicit declaration of function 'MPIU_read_external32_conversion_fn' [-Wimplicit-function-declaration]
> mpi-io/read_ordb.c:123:9: warning: nested extern declaration of 'MPIU_read_external32_conversion_fn' [-Wnested-externs]
> mpi-io/read_sh.c: In function 'PMPI_File_read_shared':
> mpi-io/read_sh.c:102:9: warning: implicit declaration of function 'MPIU_datatype_full_size' [-Wimplicit-function-declaration]
> mpi-io/read_sh.c:102:9: warning: nested extern declaration of 'MPIU_datatype_full_size' [-Wnested-externs]
> mpi-io/read_sh.c:143:9: warning: implicit declaration of function 'MPIU_read_external32_conversion_fn' [-Wimplicit-function-declaration]
> mpi-io/read_sh.c:143:9: warning: nested extern declaration of 'MPIU_read_external32_conversion_fn' [-Wnested-externs]
> mpi-io/write.c: In function 'MPIOI_File_write':
> mpi-io/write.c:126:2: warning: implicit declaration of function 'MPIU_external32_buffer_setup' [-Wimplicit-function-declaration]
> mpi-io/write.c:126:2: warning: nested extern declaration of 'MPIU_external32_buffer_setup' [-Wnested-externs]
> mpi-io/write_all.c: In function 'MPIOI_File_write_all':
> mpi-io/write_all.c:109:2: warning: implicit declaration of function 'MPIU_external32_buffer_setup' [-Wimplicit-function-declaration]
> mpi-io/write_all.c:109:2: warning: nested extern declaration of 'MPIU_external32_buffer_setup' [-Wnested-externs]
> mpi-io/write_allb.c: In function 'MPIOI_File_write_all_begin':
> mpi-io/write_allb.c:105:2: warning: implicit declaration of function 'MPIU_external32_buffer_setup' [-Wimplicit-function-declaration]
> mpi-io/write_allb.c:105:2: warning: nested extern declaration of 'MPIU_external32_buffer_setup' [-Wnested-externs]
> mpi-io/write_ord.c: In function 'PMPI_File_write_ordered':
> mpi-io/write_ord.c:100:2: warning: implicit declaration of function 'MPIU_external32_buffer_setup' [-Wimplicit-function-declaration]
> mpi-io/write_ord.c:100:2: warning: nested extern declaration of 'MPIU_external32_buffer_setup' [-Wnested-externs]
> mpi-io/write_ordb.c: In function 'PMPI_File_write_ordered_begin':
> mpi-io/write_ordb.c:106:2: warning: implicit declaration of function 'MPIU_external32_buffer_setup' [-Wimplicit-function-declaration]
> mpi-io/write_ordb.c:106:2: warning: nested extern declaration of 'MPIU_external32_buffer_setup' [-Wnested-externs]
> mpi-io/write_sh.c: In function 'PMPI_File_write_shared':
> mpi-io/write_sh.c:102:2: warning: implicit declaration of function 'MPIU_external32_buffer_setup' [-Wimplicit-function-declaration]
> mpi-io/write_sh.c:102:2: warning: nested extern declaration of 'MPIU_external32_buffer_setup' [-Wnested-externs]
> mpi-io/mpiu_external32.c: In function 'MPIU_write_external32_conversion_fn':
> mpi-io/mpiu_external32.c:24:5: warning: implicit declaration of function 'MPIR_Datatype_iscontig' [-Wimplicit-function-declaration]
> mpi-io/mpiu_external32.c:24:5: warning: nested extern declaration of 'MPIR_Datatype_iscontig' [-Wnested-externs]
> mpi-io/mpiu_external32.c:25:5: warning: passing argument 1 of 'MPI_Pack_external_size' discards 'const' qualifier from pointer target type [enabled by default]
> In file included from ./adio/include/adio.h:72:0,
> from mpi-io/mpioimpl.h:15,
> from mpi-io/mpiu_external32.c:6:
> /home/zelenko/Installs/mpich2-r10272/source/src/include/mpi.h:1137:5: note: expected 'char *' but argument is of type 'const char *'
> mpi-io/mpiu_external32.c:32:17: warning: passing argument 1 of 'MPI_Pack_external' discards 'const' qualifier from pointer target type [enabled by default]
> /home/zelenko/Installs/mpich2-r10272/source/src/include/mpi.h:1135:5: note: expected 'char *' but argument is of type 'const char *'
> mpi-io/mpiu_external32.c:47:17: warning: passing argument 1 of 'MPI_Pack_external' discards 'const' qualifier from pointer target type [enabled by default]
> mpi-io/mpiu_external32.c: In function 'MPIU_read_external32_conversion_fn':
> mpi-io/mpiu_external32.c:78:5: warning: passing argument 1 of 'MPI_Pack_external_size' discards 'const' qualifier from pointer target type [enabled by default]
> mpi-io/mpiu_external32.c:85:17: warning: passing argument 1 of 'MPI_Unpack_external' discards 'const' qualifier from pointer target type [enabled by default]
> /home/zelenko/Installs/mpich2-r10272/source/src/include/mpi.h:1157:5: note: expected 'char *' but argument is of type 'const char *'
> mpi-io/mpiu_external32.c:108:17: warning: passing argument 1 of 'MPI_Unpack_external' discards 'const' qualifier from pointer target type [enabled by default]
> mpi-io/mpiu_external32.c: In function 'MPIU_datatype_full_size':
> mpi-io/mpiu_external32.c:123:14: warning: unused variable 'extent' [-Wunused-variable]
> ./pm/pmiserv/pmiserv_utils.c: In function 'HYD_pmcd_pmi_fill_in_exec_launch_info':
> ./pm/pmiserv/pmiserv_utils.c:521:5: warning: 'nonfiller_pmi_ids' may be used uninitialized in this function [-Wmaybe-uninitialized]
> ./pm/pmiserv/pmiserv_utils.c:520:5: warning: 'filler_pmi_ids' may be used uninitialized in this function [-Wmaybe-uninitialized]
> ./pm/pmiserv/pmip_cb.c: In function 'parse_exec_params':
> ./pm/pmiserv/pmip_cb.c:808:9: warning: null argument where non-null required (argument 1) [-Wnonnull]
> ./pm/pmiserv/pmip_cb.c:808:9: warning: null argument where non-null required (argument 2) [-Wnonnull]
> src/mpi/coll/opminloc.c: In function 'MPIR_MINLOC':
> src/mpi/coll/opminloc.c:85:24: warning: variable 'flen' set but not used [-Wunused-but-set-variable]
> src/mpi/coll/opmaxloc.c: In function 'MPIR_MAXLOC':
> src/mpi/coll/opmaxloc.c:86:24: warning: variable 'flen' set but not used [-Wunused-but-set-variable]
> src/mpid/ch3/src/ch3u_rma_sync.c: In function 'MPIDI_CH3I_Recv_rma_msg':
> src/mpid/ch3/src/ch3u_rma_sync.c:1124:5: warning: 'mpiu_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpid/ch3/src/mpidi_pg.c: In function 'connToString':
> src/mpid/ch3/src/mpidi_pg.c:972:5: warning: 'mpiu_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpid/ch3/channels/nemesis/src/ch3_progress.c: In function 'MPIDI_CH3I_Progress':
> src/mpid/ch3/channels/nemesis/src/ch3_progress.c:394:21: warning: comparison between 'MPIDI_CH3_Pkt_type_t' and 'enum MPID_nem_pkt_type' [-Wenum-compare]
> src/mpid/ch3/channels/nemesis/src/ch3_progress.c: In function 'MPID_nem_handle_pkt':
> src/mpid/ch3/channels/nemesis/src/ch3_progress.c:636:17: warning: comparison between 'MPIDI_CH3_Pkt_type_t' and 'enum MPID_nem_pkt_type' [-Wenum-compare]
> src/mpid/ch3/channels/nemesis/src/ch3_progress.c:684:13: warning: comparison between 'MPIDI_CH3_Pkt_type_t' and 'enum MPID_nem_pkt_type' [-Wenum-compare]
> src/mpid/ch3/channels/nemesis/netmod/tcp/socksm.c: In function 'alloc_sc_plfd_tbls':
> src/mpid/ch3/channels/nemesis/netmod/tcp/socksm.c:183:5: warning: the comparison will always evaluate as 'true' for the address of 'MPID_nem_tcp_g_lstn_sc' will never be NULL [-Waddress]
> src/mpid/ch3/channels/nemesis/netmod/tcp/socksm.c:184:5: warning: the comparison will always evaluate as 'true' for the address of 'MPID_nem_tcp_g_lstn_plfd' will never be NULL [-Waddress]
> src/mpid/common/datatype/mpid_type_debug.c: In function 'MPIDI_Datatype_printf':
> src/mpid/common/datatype/mpid_type_debug.c:238:59: warning: variable 'sticky_ub' set but not used [-Wunused-but-set-variable]
> src/mpid/common/datatype/mpid_type_debug.c:238:48: warning: variable 'sticky_lb' set but not used [-Wunused-but-set-variable]
> src/mpid/common/datatype/mpid_type_debug.c:238:44: warning: variable 'ub' set but not used [-Wunused-but-set-variable]
> src/mpid/common/datatype/mpid_type_debug.c:238:31: warning: variable 'true_ub' set but not used [-Wunused-but-set-variable]
> src/mpid/common/datatype/mpid_type_debug.c:236:11: warning: variable 'string' set but not used [-Wunused-but-set-variable]
> src/mpi/coll/iallgather.c: In function 'MPIR_Iallgather_bruck':
> src/mpi/coll/iallgather.c:329:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpi/coll/iallgather.c: In function 'MPIR_Iallgather_inter':
> src/mpi/coll/iallgather.c:580:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpi/coll/iallgatherv.c: In function 'MPIR_Iallgatherv_rec_dbl':
> src/mpi/coll/iallgatherv.c:257:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpi/coll/iallgatherv.c: In function 'MPIR_Iallgatherv_bruck':
> src/mpi/coll/iallgatherv.c:394:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpi/coll/iallreduce.c: In function 'MPIR_Iallreduce_redscat_allgather':
> src/mpi/coll/iallreduce.c:282:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpi/coll/iallreduce.c: In function 'MPIR_Iallreduce_rec_dbl':
> src/mpi/coll/iallreduce.c:425:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpi/coll/ired_scat_block.c: In function 'MPIR_Ireduce_scatter_block_inter':
> src/mpi/coll/ired_scat_block.c:899:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> src/mpi/coll/ireduce.c: In function 'MPIR_Ireduce_SMP':
> src/mpi/coll/ireduce.c:677:5: warning: 'mpir_sched_chkpmem_stk_[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
> Eugene.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Pavan Balaji
http://www.mcs.anl.gov/~balaji
