[mpich-discuss] I need help
Jayesh Krishna jayesh at mcs.anl.gov
Wed Sep 26 10:36:21 CDT 2012
 Can you provide us more information?
# Did you re-compile the application with MPICH2 (the correct include/lib paths etc)?
# Can you run the application without mpiexec (freefem++-mpi.exe)?
# Can you run the application using mpiexec with one process (mpiexec -n 1 freefem++-mpi.exe)?
# Did you try providing the complete path to mpiexec to launch the application (C:\Progra~1\MPICH2\bin\mpiexec -n 1 freefem++-mpi.exe)?
(PS: Please don't reply to other posts, it becomes difficult for us to sort it out.)
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Wednesday, September 26, 2012 12:49:18 AM
Subject: RE: [mpich-discuss] I need help
freefem++ is a free software for fluid dynamics which is built under C++. It has freefem++-mpi.exe (64 bit) as a utality to run its code for parallel processing by using MPI. I tried its examples and gets error as mentioned earlier. Howerver, it works well with MS-MPI (Microsoft MPI) while it hange with MPICH2 (64 bit).
> Date: Tue, 25 Sep 2012 09:43:04 -0500
> From: jayesh at mcs.anl.gov
> To: mpich-discuss at mcs.anl.gov
> CC: tahmush at hotmail.com
> Subject: Re: [mpich-discuss] I need help
> Hi,
> I would recommend first checking with the developers of Freefem++ to narrow down the source of the hang.
> Regards,
> Jayesh
> From: "Tahir Mushtaq" <tahmush at hotmail.com>
> Sent: Tuesday, September 25, 2012 2:01:39 AM
> Subject: [mpich-discuss] I need help
> Dear Sir,
> I am working on open software "Freefem++" for computational fluid. For parallel processing, it uses MPI. I have installed MPICH2 1.4.1p1 on Windows 7 successfully. When I want to run "Freefem++-mpi" , the program runs but does not end. It is ended by Ctrl C. Please help me how to fix it.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
