[mpich-discuss] MPI 64 bit for 64 bit code on windows7 64 bit
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Sep 24 13:31:38 CDT 2012
Can you send us a test program (source code) that fails?
(PS: I am assuming that you recompiled your code after installing the 64-bit libs.)
Jayesh
----- Original Message -----
From: "Marco De Gregorio" <marco.degregorio at iet.unipi.it>
Sent: Monday, September 24, 2012 11:21:46 AM
Subject: [mpich-discuss] MPI 64 bit for 64 bit code on windows7 64 bit
I work with a Fortran code. I use Visual Studio 2008 and Intel Fortran 11.
I have always used 32 bit MPI successfully.
Now I need to switch my code to 64 bit. First of all I uninstalled 32 bit MPICH2 and I installed mpich2-1.4.1p1-win-x86-64.
I have several problems.
When I launch my program, the first value of some integer array ( block_lengths ) changes sign after some MPI_GET_ADDRESS and I have an error message. Below you can find a piece of code.
block_lengths(:) = 1
!get addresses
CALL MPI_GET_ADDRESS(var_name%distance,address(1),MY_MPI_error)
CALL MPI_GET_ADDRESS(var_name%min_distance,address(2),MY_MPI_error)
CALL MPI_GET_ADDRESS(var_name%max_distance,address(3),MY_MPI_error)
CALL MPI_GET_ADDRESS(var_name%flag,address(4),MY_MPI_error)
So, I changed the position of these arrays in the code and I have bypass the error, but after the change, however the code doesn't work. The problem is with a mpi_send and mpi_receiver.
address is defined as INTEGER(KIND = MPI_ADDRESS_KIND) :: address(SIZE) , but write(*,*) MPI_GET_ADDRESS returns 4.
In the mpif.h I found:
INTEGER MPI_ADDRESS_KIND, MPI_OFFSET_KIND
PARAMETER (MPI_ADDRESS_KIND=8)
PARAMETER (MPI_OFFSET_KIND=8)
There is a mistake.
Do you have any idea to help me??
With 32 bit MPICH2 and 32 bit code I don't have error.
If I try mpiexec -n 1 code_64bit.exe , the 64 bit code works fine.
Thank you,
regards,
Ing. Marco De Gregorio
Microwave & Radiation Laboratory
Dip. Ingegneria dell'Informazione - Università di Pisa
via G. Caruso 16, 56122 Pisa - Italy
Lab: (+39)050.2217681
Mail: marco.degregorio at iet.unipi.it
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
