[mpich-discuss] BLCR library - Restart Problem
    Mehmet Kurt
    kurt.16 at buckeyemail.osu.edu
    Thu Sep 20 13:46:47 CDT 2012
I use a script file for both initial run and restart.
This is the command I use for initial run:
/home/kurt/mpich2-blcr-install/bin/mpiexec -env MPICH_ASYNC_PROGRESS 1 -disable-auto-cleanup -ckpointlib blcr -ckpoint-prefix ${CKPT_PATH} -f $hosts -np ${NUM_NODES}  ./md ${FREQUENCY} ${FAILING_IT}
And, this is for restart:
/home/kurt/mpich2-blcr-install/bin/mpiexec -env MPICH_ASYNC_PROGRESS 1 -disable-auto-cleanup -ckpointlib blcr -ckpoint-prefix ${CKPT_PATH} -ckpoint-num ${CK_NUM} -f $hosts -np ${NUM_NODES}
Mehmet
______________________
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] on behalf of Darius Buntinas [buntinas at mcs.anl.gov]
Sent: Thursday, September 20, 2012 2:18 PM
Subject: Re: [mpich-discuss] BLCR library - Restart Problem
Can you send us the command lines you used for the initial run and when restarting?
-d
On Sep 20, 2012, at 12:36 PM, Mehmet Kurt wrote:
> Hello,
> I'm using BLCR checkpointing library with mpich2-1.4.1p1.
> I have no problem with checkpointing my application, but when I want to restart it with the same set of nodes, nothing happens; it just hangs there.
> I connected the same node, which restarts the application by mpiexec, from another terminal. after running "top" command I saw that it
> creates a <DEFUNCT> process for my executable.
> Any ideas about what can cause this behavior?
> Thank you,
> Mehmet Can Kurt
> Graduate Student
> Computer Engineering Department
> Ohio State University
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
