[mpich-discuss] can't connect
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Sep 19 09:42:55 CDT 2012
There could be an issue with network connectivity to that node in your cluster.
# Can you ping (ping 10.10.10.102) that node from other nodes?
# Do you have MPICH2 installed on that node?
# Can you run cpi.exe locally on that node?
Jayesh
----- Original Message -----
Sent: Wednesday, September 19, 2012 2:20:12 AM
Subject: [mpich-discuss] can't connect
I make 10 PC parallel to my experiment.
One PC have trouble. If that as master and the other as slave, program run well. But, if that was used as slave, my program can't run on that PC.
This error message :
abort: Unable to connect to ' 10.10.10.102:8676 ',
sock error:Error=-1
I use cpi.exe,still same error message.
Thanks in advance.
titia
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
