[mpich-discuss] gdb + hydra
Christoph Sprenger
csprenger at wetafx.co.nz
Tue Sep 18 01:04:12 CDT 2012
still trying to get this to work.
i've also tried a vanilla tcsh and bash with no env set at all and both
seem to fail still.
same things persists when running mpiexec -n 1 gdb without xterm
Ubuntu 10.04.4 LTS
GNU bash, version 4.1.5(1)-release
tcsh 6.17.00 (Astron)
mpich2
./configure --enable-shared --enable-sharedlibs=gcc
#include "mpi.h"
#include <iostream>
int main(int argc, char *argv[])
MPI_Init(&argc, &argv);
int rank,size;
MPI_Comm_size( MPI_COMM_WORLD, &size );
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
std::cerr << "Hello World from rank " << rank << " / " << size <<
std::endl;
MPI_Finalize();
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/libthread_db.so.1".
[cli_0]: write_line error; fd=6 buf=:cmd=init pmi_version=1 pmi_subversion=1
system msg for write_line failure : Bad file descriptor
[cli_0]: Unable to write to PMI_fd
[cli_0]: write_line error; fd=6 buf=:cmd=get_appnum
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(392):
MPID_Init(107).......: channel initialization failed
MPID_Init(389).......: PMI_Get_appnum returned -1
[Inferior 1 (process 3132) exited with code 01]
is there anything else i can try to make this work ( eg different
configure options for hydra or mpich2 ) ?
Cheers,
Christoph
On 17/09/12 20:00, Christoph Sprenger wrote:
> I'm having some issues doing the following:
> mpiexec -n 1 xterm -e gdb -ex r --args ./app ...
> this used to work fine for me with 1.2.1 and mpd but seems to give me :
> pmi_subversion=1
> also tried :
> setenv HYDRA_LAUNCHER_AUTOFORK 0
> however it falls over in MPI_Init.
> seems like other people experienced this too, but i couldn't find a
> hint that seems to address this issue
> i've tried tried 1.4.1p1 and 1.5rc1.
> any help would be appreciated.
> Kind Regards,
> Christoph
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
