[mpich-discuss] rank 0 on one node
Mahesh Doijade
maheshdoijade at gmail.com
Mon Sep 17 11:33:17 CDT 2012
I can't say particularly about running using torque but to run on
cluster using Intel MPI you can use the mpiexec -gwdir or -wdir options to
specify a working directory for the application.
For instance: mpiexec.exe -machinefile machine_file -n 4 -wdir
\\host\share_folder IMB-MPI1.exe
your machinefile need to contain process to node for example-
2:node1
3:node2
-- Mahesh Doijade
MTech - II (CSE) ,
Walchand College of Engineering, Sangli
Cell No.: 9969073453
http://www.hpc.wce.org.in/site/
On Mon, Sep 17, 2012 at 2:24 PM, rigved sharma
<rigved.sharma123 at gmail.com>wrote:
> Hi Mahesh,
> can you be more specific about it? we rae using intel mpi and torque.
> On 9/17/12, Mahesh Doijade <maheshdoijade at gmail.com> wrote:
> > Hi,
> > Initially you need to form the cluster by doing the ssh passwordless
> > login amongst the node in your cluster, then you have to create a
> > machinefile consisting of process to node mapping and pass it to mpiexec
> > while launching your MPI job. all the details about the creation of
> > machinefile and job launching is given in link below.
> > http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
> > So in your case of launching of the master process on the separate
> > desired node can be achieved through mentioning the same in the
> machinefile
> > and rest as required.
> > Regards,
> > -- Mahesh Doijade
> > MTech - II (CSE) ,
> > On Mon, Sep 17, 2012 at 1:51 AM, rigved sharma
> >> hi,
> >> i have intel mpi configured on our cluster where we are running the job
> >> in
> >> which it is required that only master process should execute on 1 node
> (1
> >> seperate node of 8 procs) and rest 63 processes on 63 procs (8 nodes of
> 8
> >> proc each). how it can be acieved.
> >> -ruchir b.
> >> _______________________________________________
> >> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> >> To manage subscription options or unsubscribe:
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120917/06bcdc4b/attachment-0001.html>
