[mpich-discuss] rank 0 on one node
Mahesh Doijade maheshdoijade at gmail.com
Sun Sep 16 16:22:37 CDT 2012
    Initially you need to form the cluster by doing the ssh passwordless
login amongst the node in your cluster, then you have to create a
machinefile consisting of process to node mapping and pass it to mpiexec
while launching your MPI job. all the details about the creation of
machinefile and job launching is given in link below.
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
    So in your case of launching of the master process on the separate
desired node can be achieved through mentioning the same in the machinefile
and rest as required.
-- Mahesh Doijade
MTech - II (CSE) ,
Walchand College of Engineering, Sangli
On Mon, Sep 17, 2012 at 1:51 AM, rigved sharma
<rigved.sharma123 at gmail.com>wrote:
> hi,
> i have intel mpi configured on our cluster where we are running the job in
> which it is required that only master process should execute on 1 node (1
> seperate node of 8 procs) and rest 63 processes on 63 procs (8 nodes of 8
> proc each). how it can be acieved.
> -ruchir b.
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120917/104c44b6/attachment.html>
