[mpich-discuss] installation of MPI2-1.4.1p1 on Win7-PC does not work (SMPD problem?)
Michael.Rachner at dlr.de
Fri Sep 14 04:39:04 CDT 2012
Dear developers of MPICH2,
I tried to install MPICH2 on my Windows7 (64-bit) PC (Intel XEON Quadcore, 16 GB RAM).
I do not know, which of the 2 packages that can be downloaded for Windows from
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
is the right one for my PC:
mpich2-1.4.1p1-win-x86-64.msi
or: mpich2-1.4.1p1-win-ia32
First question: which of the 2 packages is the right one?
So I installed both (logged in as administrator) . But with none of them I am able to run my SPRAYCORE.exe executable.
I use the following small batch-script runMPICH to start the execution under MPICH:
@echo ON
@echo.
@echo ###############################################################
@echo Start of script to run the SPRAYCORE-executable using MPICH
@echo on %1 processes under WINDOWS
@echo at: %DATE% %TIME%
@echo.
@echo script name : %0
@echo.
@echo with given argument: %*
@echo.
@REM --this is the installation obtained from installing the package mpich2-1.4.1p1-win-ia32.msi (downloaded 2012-09-13):
@rem @set MPI_DIR=C:\Program Files (x86)\MPICH2
@REM --this is the installation obtained from installing the package mpich2-1.4.1p1-win-x86-64 (downloaded 2012-09-14):
@set MPI_DIR=C:\Program Files\MPICH2
@if qqq%1 neq qqq goto L10
@echo **** ERROR: This script requires 1 argument, being the desired number (^>0) of processes
@echo --^> STOP will follow.
@goto EXIT
:L10
@set NUMPROCSWORLD=%1
@if qqq%NUMPROCSWORLD% LEQ qqq1 (
SPRAYCORE.exe
) else (
@rem "%MPI_DIR%"\bin\mpiexec.exe -help2
echo.
echo "%MPI_DIR%"\bin\smpd.exe -install
echo.
echo "%MPI_DIR%"\bin\mpiexec.exe -n %NUMPROCSWORLD% -localonly -l SPRAYCORE.exe -use_mpi
:EXIT
It got the following answers when running both installations:
This is the answer when using the installation from mpich2-1.4.1p1-win-x86-64.msi :
C:\Windows\System32>runMPICH 4
on 4 processes under WINDOWS
at: 14.09.2012 10:31:23.21
script name : runMPICH
with given argument: 4
"C:\Program Files\MPICH2"\bin\smpd.exe -install
OpenSCManager failed:
Zugriff verweigert (error 5)
Unable to remove the previous installation, install failed.
"C:\Program Files\MPICH2"\bin\mpiexec.exe -n 4 -localonly -l SPRAYCORE.exe -use_mpi
Unknown option: -d
Error while connecting to host, Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. (10
061)
Connect on sock (host=VT-001016D.intra.dlr.de, port=8676) failed, exhaused all end points
Unable to connect to 'VT-001016D.intra.dlr.de:8676',
sock error: Error = -1
ReadFile() failed, error 109
unable to start the local smpd manager.
And this is the answer when running the installation from mpich2-1.4.1p1-win-ia32.msi :
at: 14.09.2012 10:28:38.09
"C:\Program Files (x86)\MPICH2"\bin\smpd.exe -install
"C:\Program Files (x86)\MPICH2"\bin\mpiexec.exe -n 4 -localonly -l SPRAYCORE.exe -use_mpi
Please specify an authentication passphrase for smpd:
Unknown option: -d
061)
The host name mentioned in the answers is indeed correct: VT-001016D.intra.dlr.de
Translation of: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
No connection could be established, because the goal-computer refused the connection.
You see that the answers of the 2 installations differ only by asking the authentification SMPD passphrase (still 'behappy') or not.
It makes no difference, whether I do that as an administrator or as a normal user.
(By the way: It is cumbersome to be asked at every MPICH run for entering the passphrase!)
You see, there is a problem with the smpd.exe. The task manager shows that there is no process smpd.exe running on my machine.
(In contrast, on a WinXP-machine (32-bit) of a collegue that process is running automatically since startup of the computer. And there MPICH works.)
My 2nd Question: Can you help me?
Thank You,
Michael Rachner
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120914/ba06ad17/attachment-0001.html>
