[mpich-discuss] mpich2&open64 shared object compilation bug&fix
Evren Yurtesen IB eyurtese at abo.fi
Thu Sep 6 18:41:22 CDT 2012
I tried 1.5rc1 and there seems to be other problems... I have no idea what
is this about... configured with: --enable-fast=O2 --enable-shared
--enable-mpe --with-pmi=slurm --with-pm=no
Just as a side note, same configure options work fine with GCC 4.7.1, but
that doesnt say much about who to blame :)
Making all in .
make[2]: Entering directory `/home/eyurtese/temp/mpich2-1.5rc1'
   CC       src/binding/f90/create_f90_real.lo
src/binding/f90/create_f90_real.c: In function
'PMPI_Type_create_f90_real':
src/binding/f90/create_f90_real.c:73: error: expected expression before
',' token
src/binding/f90/create_f90_real.c:74: warning: braces around scalar
initializer
src/binding/f90/create_f90_real.c:74: warning: (near initialization for
'f90_real_model[0].dtype')
src/binding/f90/create_f90_real.c:74: error: expected expression before
',' token
src/binding/f90/create_f90_real.c:74: warning: excess elements in scalar
initializer
make[2]: *** [src/binding/f90/create_f90_real.lo] Error 1
make[2]: Leaving directory `/home/eyurtese/temp/mpich2-1.5rc1'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/eyurtese/temp/mpich2-1.5rc1'
make: *** [all] Error 2
On Fri, 7 Sep 2012, Evren Yurtesen IB wrote:
> On Thu, 6 Sep 2012, Pavan Balaji wrote:
>> Your patch below is to configure (not configure.in) which is
>> auto-generated. The first step I'd recommend is to try out mpich2-1.5rc1.
>> That uses libtool for shared library support.  That'll at least confirm
>> whether libtool supports open64 or not.  If it doesn't, then a patch would
>> be required for libtool.
> Yes, I realized the configure.in later. My apologies, I am not very familiar
> with the configure system. Please see the attached diffs, what do you think
> about them?
> I will check 1.5 next.
> Thanks,
> Evren
>> -- Pavan
>> On 09/06/2012 05:47 PM, Evren Yurtesen IB wrote:
>>> Hmm, I am not quite sure? the configure.in file contains the information
>>> which should be changed?
>>> http://trac.mcs.anl.gov/projects/mpich2/browser/mpich2/branches/release/mpich2-1.4.x/configure.in
>>>> Hello,
>>>> It looks like this patch needs to go into libtool, rather than in MPICH.
>>>> We
>>>> can maintain a patch to libtool within mpich (at least till libtool
>>>> upstream
>>>> integrates it), if you can provide us with one.
>>>> -- Pavan
>>>> On 09/06/2012 05:24 PM, Evren Yurtesen IB wrote:
>>>>> I was trying to compile mpich2 1.4.1p1 using open64 and oddly it kept
>>>>> failing with the following configure options...
>>>>> --enable-fast=O2 --enable-shared --enable-mpe --with-pmi=slurm
>>>>> --with-pm=none
>>>>> I have googled this and found the following forum post:
>>>>> http://devgurus.amd.com/thread/146210
>>>>> Where the exact error message which I was getting was mentioned:
>>>>>     make[4]: Entering directory
>>>>> `/home2/ach/soft/wrfipkd/mpich2-1.3.1/src/binding/f90'
>>>>>      FC              mpi.f90
>>>>> make[4]: *** [mpi.lo] Error 1
>>>>> I have modified the configure script and managed to finish installation.
>>>>> (diff below). Can this fix be part of mpich2?
>>>>> --- configure.orig      2012-09-07 00:45:10.571555205 +0300
>>>>> +++ configure   2012-09-07 00:59:28.956554973 +0300
>>>>> @@ -16739,6 +16739,10 @@
>>>>>         # Try to use the compiler name
>>>>>         if test "$FC" = "ifort" -o "$FC" = "ifc" ; then
>>>>>             pac_cv_fc_vendor=intel
>>>>> +    elif test "$FC" = "openf90" ; then
>>>>> +        pac_cv_fc_vendor=open64
>>>>> +    elif test "$FC" = "openf95" ; then
>>>>>         elif test "$FC" = "pgf90" ; then
>>>>>             pac_cv_fc_vendor=pgi
>>>>>         elif test "$FC" = "xlf90" -o "$FC" = "xlf90_r" ; then
>>>>> @@ -16785,6 +16789,14 @@
>>>>>                    fi
>>>>> +               open64)
>>>>> +               # open64 implements the GNU options
>>>>> +               FC_SHL="$FC -shared -fPIC"
>>>>> +               if test "$enable_rpath" = yes ; then
>>>>> +                    FC_LINKPATH_SHL="-Wl,-rpath -Wl,"
>>>>> +               fi
>>>>>                    pgi)
>>>>>                    # Portland Group implements the GNU options
>>>>> Thanks,
>>>>> Evren
>>>>> PS. I created a ticket as well:
>>>>> https://trac.mcs.anl.gov/projects/mpich2/ticket/1690
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>>> To manage subscription options or unsubscribe:
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>> Pavan Balaji
>>>> http://www.mcs.anl.gov/~balaji
>> Pavan Balaji
