[mpich-discuss] mpich2&open64 shared object compilation bug&fix
Pavan Balaji balaji at mcs.anl.gov
Thu Sep 6 17:49:57 CDT 2012
Your patch below is to configure (not configure.in) which is
auto-generated.  The first step I'd recommend is to try out
mpich2-1.5rc1.  That uses libtool for shared library support.  That'll
at least confirm whether libtool supports open64 or not.  If it doesn't,
then a patch would be required for libtool.
  -- Pavan
On 09/06/2012 05:47 PM, Evren Yurtesen IB wrote:
> Hmm, I am not quite sure? the configure.in file contains the information
> which should be changed?
> http://trac.mcs.anl.gov/projects/mpich2/browser/mpich2/branches/release/mpich2-1.4.x/configure.in
> On Thu, 6 Sep 2012, Pavan Balaji wrote:
>> Hello,
>> It looks like this patch needs to go into libtool, rather than in MPICH.  We
>> can maintain a patch to libtool within mpich (at least till libtool upstream
>> integrates it), if you can provide us with one.
>> -- Pavan
>> On 09/06/2012 05:24 PM, Evren Yurtesen IB wrote:
>>> I was trying to compile mpich2 1.4.1p1 using open64 and oddly it kept
>>> failing with the following configure options...
>>> --enable-fast=O2 --enable-shared --enable-mpe --with-pmi=slurm
>>> --with-pm=none
>>> I have googled this and found the following forum post:
>>> http://devgurus.amd.com/thread/146210
>>> Where the exact error message which I was getting was mentioned:
>>>     make[4]: Entering directory
>>> `/home2/ach/soft/wrfipkd/mpich2-1.3.1/src/binding/f90'
>>>      FC              mpi.f90
>>> make[4]: *** [mpi.lo] Error 1
>>> I have modified the configure script and managed to finish installation.
>>> (diff below). Can this fix be part of mpich2?
>>> --- configure.orig      2012-09-07 00:45:10.571555205 +0300
>>> +++ configure   2012-09-07 00:59:28.956554973 +0300
>>> @@ -16739,6 +16739,10 @@
>>>         # Try to use the compiler name
>>>         if test "$FC" = "ifort" -o "$FC" = "ifc" ; then
>>>             pac_cv_fc_vendor=intel
>>> +    elif test "$FC" = "openf90" ; then
>>> +        pac_cv_fc_vendor=open64
>>> +    elif test "$FC" = "openf95" ; then
>>>         elif test "$FC" = "pgf90" ; then
>>>             pac_cv_fc_vendor=pgi
>>>         elif test "$FC" = "xlf90" -o "$FC" = "xlf90_r" ; then
>>> @@ -16785,6 +16789,14 @@
>>>                    fi
>>> +               open64)
>>> +               # open64 implements the GNU options
>>> +               FC_SHL="$FC -shared -fPIC"
>>> +               if test "$enable_rpath" = yes ; then
>>> +                    FC_LINKPATH_SHL="-Wl,-rpath -Wl,"
>>> +               fi
>>>                    pgi)
>>>                    # Portland Group implements the GNU options
>>> Thanks,
>>> Evren
>>> PS. I created a ticket as well:
>>> https://trac.mcs.anl.gov/projects/mpich2/ticket/1690
>>> _______________________________________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
Pavan Balaji
