[mpich-discuss] mpich2&open64 shared object compilation bug&fix
Pavan Balaji
balaji at mcs.anl.gov
Thu Sep 6 17:34:20 CDT 2012
Hello,
It looks like this patch needs to go into libtool, rather than in MPICH.
We can maintain a patch to libtool within mpich (at least till libtool
upstream integrates it), if you can provide us with one.
-- Pavan
On 09/06/2012 05:24 PM, Evren Yurtesen IB wrote:
> I was trying to compile mpich2 1.4.1p1 using open64 and oddly it kept
> failing with the following configure options...
> --enable-fast=O2 --enable-shared --enable-mpe --with-pmi=slurm
> --with-pm=none
> I have googled this and found the following forum post:
> http://devgurus.amd.com/thread/146210
> Where the exact error message which I was getting was mentioned:
> make[4]: Entering directory
> `/home2/ach/soft/wrfipkd/mpich2-1.3.1/src/binding/f90'
> FC mpi.f90
> make[4]: *** [mpi.lo] Error 1
> I have modified the configure script and managed to finish installation.
> (diff below). Can this fix be part of mpich2?
> --- configure.orig 2012-09-07 00:45:10.571555205 +0300
> +++ configure 2012-09-07 00:59:28.956554973 +0300
> @@ -16739,6 +16739,10 @@
> # Try to use the compiler name
> if test "$FC" = "ifort" -o "$FC" = "ifc" ; then
> pac_cv_fc_vendor=intel
> + elif test "$FC" = "openf90" ; then
> + pac_cv_fc_vendor=open64
> + elif test "$FC" = "openf95" ; then
> elif test "$FC" = "pgf90" ; then
> pac_cv_fc_vendor=pgi
> elif test "$FC" = "xlf90" -o "$FC" = "xlf90_r" ; then
> @@ -16785,6 +16789,14 @@
> fi
> + open64)
> + # open64 implements the GNU options
> + FC_SHL="$FC -shared -fPIC"
> + if test "$enable_rpath" = yes ; then
> + FC_LINKPATH_SHL="-Wl,-rpath -Wl,"
> + fi
> pgi)
> # Portland Group implements the GNU options
> Thanks,
> Evren
> PS. I created a ticket as well:
> https://trac.mcs.anl.gov/projects/mpich2/ticket/1690
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Pavan Balaji
http://www.mcs.anl.gov/~balaji
